Specification Sheet for SMD Power Inductor
Specification Sheet for Approved
Customer Name:
Customer Part No.:
Ceaiya Part No:
MTC160808 Series
Spec No:
T1608
【For Customer Approval Only】
If you Approval, Please Stamp
【RoHS Compliant Parts】
Approved
By
李庆辉
Checked By
Prepared By
刘志坚
劳水花
Shenzhen Ceaiya Electronics Co., Ltd.
地址 1: 深圳市龙华区观澜街道银星智界一期综合楼 716 号
地址 2:广东省东莞清溪镇青滨东路 105 号力合紫荆智能制造中心 10 栋
Http//www.szceaiya.com
Tel: 0769-89135516
Fax: 0769-89135519
1
【Version of Changed Record】
Rev.
Effective Date
Changed Contents
Change Reasons
Approved By
A0
2022-06-09
New release
Li qing hui
2
1. Scope
This specification applies to the MTC160808 Series of wire wound SMD power inductor.
2. Product Description and Identification (Part Number)
1) Description:
MTC160808 series of Wire wound SMD power inductor.
2) Product Identification (Part Number)
MTC
160808 - 1R0
M
T
①
②
③
④
⑤
①
Type
MTC
②
Mini Molded Chip Power Inductor
③
External Dimensions(L×W×H) 【mm】
160808
1.6×0.8×0.8
Nominal Inductance
Example
Example
1R0
1.0uH
100
10uH
101
100uH
⑤
④
Inductance Tolerance
N
±30%
M
±20%
Packing
T
Tape Carrier Package
3. Electrical Characteristics
Please refer to Item 5.
1) Operating temperature range (individual chip without packing): -40℃ ~ +125℃ (Including Self-heating).
2) Storage temperature range (packaging conditions): -10℃ ~ +40℃ and RH 70% (Max.).
4. Shape and Dimensions (Unit:mm)
Dimensions and recommended PCB pattern for reflow soldering, please see Fig4-1 and Table4-1
Shape and Dimensions:
Recommended pad:
Fig4-1.
Table 4-1.
A
B
1.6±0.2
0.8±0.2
C
D
a
0.90Max 0.50±0.2 0.70 Ref
b
c
0.55 Ref
1.0 Ref
3
5. Electrical Characteristics
Inductance
Part Number
DC
Resistance
Saturation
Current
Heat Rating
Current
1MHz/1V
Max.
Typ.
Max.
Typ.
Max.
Typ.
Units
uH
Ω
Ω
A
A
A
A
Symbol
L
MTC160808-1R0MT
1.0±20%
20%
0.140
0.115
2.0
2.3
1.3
1.6
MTC160808-2R2MT
2.2±20%
20%
0.300
0.250
1.2
1.4
0.9
1.0
DCR
Isat
Irms
Note:※1:
1: Rated current: Isat(max.)or Irms(max.),whichever is smaller;
※2: Saturation Current: Max. Value, DC current at which the inductance drops less than 30% from its value
without current; Typ. Value, DC current at which the inductance drops 30% from its value without current;
※3:
3: Irms: DC current that causes the temperature rise (△T) from 20℃ ambient.
For Max. Value, △T<40℃;; for Typ. Value, △T is approximate 40℃.
The part temperature (ambient + temp. rise) should not exceed 125℃
125 under worst case operating conditions.
Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provisions all affect
the part temperature. Part temperature should be verified in the end application.
※4:Absolute
Absolute maximum voltage:DC 20V
2
6. Structure
The structure of MTC160808 product.
①
②
NO.
①
Components
Core
Material
Soft magnetic Metal
②
Wire
Polyurethane system enameled copper wire
③-1
③-2
Electrodes
Inside Cu
Ni+Sn Plating Chemicals
△f: Clearance between terminal and the surface of plate must be 0.12mm
0. mm max when coil is placed on a flat plate.
4
7. Reliability Test
Items
Requirements
7.1
Bonding
Strength
7.2
Bending
Strength
Test Methods and Remarks
It shall be soldered on the substrate.
Applying Force(F): 10N
Hold Duration: 5s
Chip coil shall not be damaged.
Substrate: Glass-epoxy substrate
(100×40×1.0mm)
Speed of Applying Force: 0.5mm / s
Deflection: 2mm
Hold Duration: 20s
7.3
Vibration
7.4
Solderability
No visible mechanical damage.
Inductance change: Within ±10%
1) Solder the inductor to the testing jig (glass epoxy
board) using eutectic solder.
2) The inductor shall be subjected to a simple harmonic
motion having total amplitude of 1.5mm, the frequency
being varied uniformly between the approximate limits
of 10 and 55Hz.
3) The frequency range from 10 to 55Hz and return to
10Hz shall be traversed in approximately 1 minute. this
motion shall be applied for a period of 2 hours in each
3mutually perpendicular directions (total of 6 hours).
The wetting area of the electrode shall
Flux:Ethanol solution of rosin,25(wt)%
be at least 90% covered with new
Solder : Sn-3.0Ag-0.5Cu
solder coating.
Pre-Heating:150±10°C / 60 to 90s
Solder Temperature:245±5°C
Immersion Time:3 s
7.5
Resistance to
Soldering
Heat
Appearance:No damage
Reflow soldering method
Inductance Change : within ±10%
Flux: Ethanol solution of rosin,25(wt)%
Solder: Sn-3.0Ag-0.5Cu
Pre-Heating: 150 to 180°C / 60 to 120s
Solder Temperature: 230°C min. / 20 to 40s
Peak Temperature: 250+5/-0°C
Reflow times: 2 times max
Test board shall be 0.8 mm thick. Base material shall
be glass epoxy resin.
Then measured after exposure Standard atmospheric
conditions for 1~2h.
5
7. Reliability Test
Items
Requirements
7.6
Heat
Temperature: 125±2°C
Time: 500h (±12h)
Resistance
7.7
Cold
Temperature: -40±2°C
Time: 500h (±12h)
Resistance
7.8
Humidity
Temperature: 40±2°C
Humidity: 90 to 95%(RH)
Time: 500h (±12h)
Then measured after
7.9
Temperature
Cycle
1 cycle:
1 step: -40±2°C / 30±3m
2 step: Ordinary temp. / 3m max.
3 step: +125±2°C / 30±3m
4 step: Ordinary temp. / 3m max.
Total of 100 cycles
6
8.Packaging and Marking:
8-1.Carrier Tape Dimensions:
E
P
P2
W
F
P0
ITEM
W
A0
B0
K0
P
F
E
D0
P0
P2
T
DIM
8.00
1.0
1.80
1.10
4.00
3.5
1.75
1.50
4.00
2.00
0.20
TOLE
±0.3
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
+0.1
±0.1
±0.1
±0.05
8-2.Taping Dimensions:
8-3.Reel Dimensions:
Carrier Tape Reel
B
A
C
N
G
Type
A
8mm
178
B
20.7±0.8
C
13±0.4
G
N
T
9
60
10.8
8-4. Packaging Quantity:
3KPCS/ Reel
7
很抱歉,暂时无法提供与“MTC160808-1R0MT”相匹配的价格&库存,您可以联系我们找货
