Lead-Free Current Sensing Resistors
RLM Series
( Halogen-Free )
Document No
TRLM-256Z001A
Issued date
2019/01/22
page
1/6
1. Scope:
This specification applied to the products of Lead-Free current sensing resistor of metal foil for Lead-Free
RLM series manufactured by TA-I TECHNOLOGY CO.,LTD.
2. Type Designation:
RLM
Item
25
Series
No.
25:2512(6432)
F
Resistance
tolerance
F:±1%
E
Packaging
E
Power Rating
E: Embossed Tape
C=1W
G:±2%
E=2W
J:±5%
G=3W
M
Metal
M=MnCu
R50M
Resistance
e.g :
R50m=0.5mΩ
3. Construction and Dimension :
3.1 Construction:
Over-Coat
Ni / Sn
Plating
Metal Alloy Plate
3.2 Dimension:
R50m
UNIT : mm
Style
RLM25
L
6.4±0.2
W
3.2±0.2
C
2.6±0.2
t
Material
Metal:
Copper-Manganese
Alloy
0.6 ±0.20 Over Coating:molding
Compound UL-94V-0 grade
TA-I TECHNOLOGY CO., LTD
RLM Series
( Halogen-Free )
Document No
TRLM-256Z001A
Issued date
2019/01/22
page
2/6
4. Features:
Type
RLM25
1W、2 W、3W
Power Rating
Resistance Value
0.5mΩ~0.75mΩ
-55℃~+170℃
±75ppm/℃
±1%、±2%、±5%
Over 100MΩ
(P*R)1/2
Operation Temperature Range
Temperature Coefficient of Resistance
Tolerance
Insulation Resistance
Maximum Working Voltage(V)
5. Reliability Tests :
Test Items
of Resistance
Load Life
Reference
standard
IEC60115-1 4.8
JIS C 5201-1 4.8
IEC60115-1 4.25.1
JIS C 5201-1 4.25.1
Condition of Test
+25℃ ~ +125℃
Test Limits
Refer 4.0
1000hours at rated power,
70℃, 1.5hours “ON”,
0.5hour “OFF”
< ±1%
Short Time Overload
IEC60115-1-4.13
JIS-C5201-4.13
5 X rated power for 5s
< ±0.5%
Moisture no Load
IEC60115-1 4.13
JIS C 5201-1 4.13
85℃, 85%RH, 1000hrs
< ±0.5%
Temperature cycle
IEC60115-1 4.24.2.1a)
JIS C 5201-1 4.24.2.1a)
Resistance to Soldering Heat
IEC60115-1 4.19
JIS C 5201-1 4.19
-55℃ & +155℃, 300cycle,
< ±0.5%
15min per extreme condition
260±5℃ for20±1 sec
< ±0.5%
Solderability
IEC60115-1 4.18
JIS C 5201-1 4.18
245±5℃, 2±0.5sec
At least 95% of surface
area of electrode shall
be covered with new
solder
High Temperature Exposure
IEC60115-1 4.17
JIS C 5201-1 4.17
170℃, 1000hrs
< ±1%
Low Temperature Storage
IEC60115-1 4.23.2
JIS C 5201-1 4.23.2
-55℃, 1000hrs
100 MΩ
IEC60115-1 4.33
JIS C 5201-1 4.33
Document No
TRLM-256Z001A
Issued date
2019/01/22
page
3/6
RLM Series
( Halogen-Free )
Power Ratio (%)
5.1Derating Curve
100
-55
70
170
Ambient Temperature (℃)
5.2 Rated Current
The rated current is calculated by the following formula:
I: Rated Current (A)
I=
P: Rated Power (W)
R: Resistance Value (Ω)
6. Recommended Solder Pad Dimension
b
L
a
Cu Trace
Sensing Trace
Resistance Range
(Ω)
a
b
L
0.0005~0.00075
4.0
3.1
1.3
Unit: mm
Document No
TRLM-256Z001A
Issued date
2019/01/22
page
4/6
RLM Series
( Halogen-Free )
7. Number of Package:
4000 Pieces / package
8. Label:
Date Code
Series
QTY: 4000 PCS
T019C0071H
LOT NO:
Resistance
MR50M FEE
0308
RLM25FEEM
Tolerance
Package
Power Rating
9. Taping
Packing
Emboss
Type
A
RLM25
3.6+0.2
-0.18
B
6.9±0.2
W
12.±0.2
F
5.5±0.05
E
1.75±0.1
P1
4.0±0.1
P2
2.0±0.05
P0
D0
T
4.0±0.05
ψ1.5
(+0.1/-0)
0.85±0.15
Unit: mm
RLM Series
( Halogen-Free )
Document No
TRLM-256Z001A
Issued date
2019/01/22
page
5/6
10. Reel Specification
Series
ψA
ψB
ψC
W
T
13.0±1.0
15.4±2.0
+0
RLM 25
60 ±1.0
180
13.0±1.0
-3
Unit: mm
11. Peeling Strength of Top Cover Tape
Test Condition: 0.1 to 0.7 N at a peel-off speed of 300 mm / min.
pull
300 mm/min
top cover tape
10 ~15∘
standard: 0.1 ~ 0.7 N
carrier tape
12. Storage Conditions:
Temperature: 5℃~35℃,Humidity:40%~75%
13. Shelf Life:
2 years from manufacturing date.
Document No
TRLM-256Z001A
Issued date
2019/01/22
page
6/6
RLM Series
( Halogen-Free )
14. Recommend IR – Reflow profile : (solder : Sn96.5 / Ag3 / Cu0.5)
Peak : 250
5
℃ , 5 sec
Pre – heat Zone : 150 to 180 ℃, 90±30 sec
Soldering Zone : 230℃ or higher , 30±10 sec
Iron Solder:350±10℃ , 3+1/-0 sec
15. ECN
Engineering Change Notice: The customer will be informed with ECN if there is significant
modification on the characteristics and materials described in Approval Sheet.
16. Manufacturing Country & City :
TA-I TECHNOLOGY CO., LTD. ( Taiwan– Tao Yuan )
Tel: (+886) 3-3246169
Fax : (+886) 3-3246167
Associated companies :
(1)TA-I TECHNOLOGY ( SU ZHOU ) CO., LTD. ( China – Su Zhou)
Tel :(+86) 512-63457879
Fax : (+86) 512-63457869
(2) TA-I TECHNOLOGY ELECTRONIC (DONGGUAN ) CO., LTD. ( China –Dongguan )
Tel : (+86) 769-8339-4790〜3
Fax : (+86) 769-8339-4794
(3) FORTUNE TASK RESISTOR FACTORY
( China – Dongguan )
(4) TAI OHM ELECTRONICS ( M ) SDN. BHD. ( Malaysia – Penang )
Tel :(+60) 4- 3900480
Fax : (+60) 4-3901481
(5) P.T.TAI ELECTRONIC Indonesia ( Indonesia – Jakarta )
Tel :(+62) 21-44820254
Fax : (+62) 21-44820256
很抱歉,暂时无法提供与“RLM25FECMR010”相匹配的价格&库存,您可以联系我们找货
