49SAT04000201080JY
49SAT04000201080JY
    JGHC(晶光华)
    HC-49S
49SAT04000201080JY 数据手册
www.jghcorp.com 【深圳市晶光华电子有限公司】    External dimensions: 11.5 x 4.8 x 3.8mm;  A great number of standard frequencies;  High frequency pullability and low equivalent series resistance;  Highly mass production capability;  Applications: PC, STB, LCDM and Cable Modem; Frequency range: 3.579545MHz ~ 64MHz; Surface mount type crystal units; Crystals specifications ITEMS(项目) PARAMETER(规格说明) Frequency Range 3.2 ~ 90MHz Frequency Tolerance (at 25 ℃) ± 20ppm, or specify Frequency Stability Over Operating Temperature Range ± 20ppm, or specify Operating Temperature Range - 20 ~ +70 ℃, or specify Shunt Capacitance (C0) 7 pF Max. Drive Level 1 ~ 500 uW (50 uW typical) Load Capacitance Series, 9 pF 12 pF 16 pF, 18 pF, 20 pF, 22 pF, or specify Aging (at 25 ℃ ) ± 3 ppm / year Max. Storage Temperature Range - 40 ~ + 85 ℃ Packing Unit 1,000pcs/Reel Equivalent Series Resistance(ESR) Fundamental 3.2-3.686MHZ 200 Ω Max 27-30MHZ 100 Ω Max 3.686-5MHZ 150Ω Max 30-50MHZ 80Ω Max 5-10MHZ 80 Ω Max 50-90MHZ 60 Ω Max 10-14MHZ 40 Ω Max 14-30MHZ 30Ω Max Dimensions
49SAT04000201080JY 价格&库存
很抱歉,暂时无法提供与“49SAT04000201080JY”相匹配的价格&库存,您可以联系我们找货
49SAT04000201080JY
    • 5+0.68202
    • 50+0.55242
    • 150+0.48762
    库存:197
