SS32A-SS320A
SCHOTTKY BARRIER DIODE
FEATURES
Small Surface Mount device
Low power loss, high efficiency
High temperature soldering guaranteed:260°C/10 seconds at terminals
Guard ring for over voltage protection
For use in low voltage high frequency inverters,
free wheeling, and polarity protection applications
SMA
MECHANICAL DATA
Case: SMA(DO214AC)
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.065grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol SS32A SS33A SS34A SS36A SS38A SS310ASS315ASS320A Unit
Repetitive peak reverse voltage VRRM
40
60
80
100
150
200
V
DC Reverse Voltage
VR
40
60
80
100
150
200
V
RMS Reverse Voltage
Non-Repetitive Peak Forward
Surge Current @ t = 8.3 ms
Mean rectifying current
VRMS
14
21
28
42
56
70
105
140
V
IFSM
80
A
3.0
A
Thermal Resistance
IF
RθJA
85
°C/W
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 ~+175
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Forward voltage
Reverse current T=25°C
Reverse current T=100°C
Junction capacitance
Symbol SS32A SS33A SS34A SS36A SS38A SS310A SS315A SS320A Unit
VF
IR
IR
CJ
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
0.55
0.7
0.85
0.5
E-mail:hkt@heketai.com
0.95
V
mA
mA
pF
Conditions
IF=3A
V=VR
V=4V,f=1MHz
1/4
SS32A-SS320A
Typical Characteristics
AVERAGE FORWARD CURRENT (A)
3.5
SS35L-SS320L
3
2.5
2
SS32L-SS34L
1.5
1
0.5
RESISTIVE OR
INDUCTIVELOAD
60
70
80
90
FIG. 2 MAXIMUM NON-REPETITIVE FORWARD SURGE
CURRENT
PEAK FORWARD SURGE CURRENT (A)
FIG.1 FORWARD CURRENT DERATING CURVE
8.3ms Single Half Sine Wave
JEDEC Method
80
60
SS32L-SS34L
40
100 110 120 130 140 150
LEAD TEMPERATURE
SS35L-SS320L
1
INSTANTANEOUS REVERSE A
CURRENT (mA)
INSTANTANEOUS FORWARD A
CURRENT (A)
TJ=125℃
SS32L-SS34L
10
SS315L-SS320L
1
SS39L-SS310L
PULSE WIDTH=300μs
1% DUTY CYCLE
0.4
0.6
0.8
1
1.2
1.4
10
1
TJ=75℃
0.1
TJ=25℃
0.01
SS32L-SS34L
SS35L-SS320L
0.001
FIG. 5 TYPICAL JUNCTION CAPACITANCE
100
SS39L-SS320L
f=1.0MHz
Vsig=50mVp-p
1
10
100
TRANSIENT THERMAL IMPEDANCE A
(℃/W)
CAPACITANCE (pF)
SS35L-SS36L
0.1
40
60
80
100
120
140
FIG. 6 TYPICAL TRANSIENT THERMAL IMPEDANCE
100
SS32L-SS34L
10
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FORWARD VOLTAGE (V)
1000
100
FIG. 4 TYPICAL REVERSE CHARACTERISTICS
100
SS35L-SS36L
0.1
10
NUMBER OF CYCLES AT 60 Hz
(oC)
FIG. 3 TYPICAL FORWARD CHARACTERISTICS
100
100
10
1
0.1
0.01
0.1
1
10
100
2/4
SS32A-SS320A
SMA Package Outline Dimensions
Symbol
Dimensions In Millimeters
Min.
Max.
A
2.20
B
Dimensions In Inches
Max.
2.80
Min.
0.086
1.30
1.70
0.051
0.067
C
4.70
5.30
0.185
0.209
D
1.70
2.55
0.067
0.100
E
0.90
1.50
0.035
0.059
F
0.90
1.50
0.035
0.059
0.110
SMA Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
SS32A-SS320A
SMA Tape and Reel
SMA Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SMA
2.89
5.35
2.68
Ø1.50
1.75
5.50
4.00
4.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SMA Tape Leader and Trailer
SMA Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
12.40
17.60
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“SS310A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.14450
- 50+0.13175
- 500+0.11475
- 1000+0.10200
- 2500+0.09605
