No.:
Date:
RMC-K-HTS-0006
2022. 8. 19
/13
Data sheet
Title:
FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE
Style:
RMC1/32,1/20,1/16S,1/16,1/10,1/8,1/4,1/2,1
RoHS COMPLIANCE ITEM
Halogen and Antimony Free
Note: ・Stock conditions
Temperature: +5°C ∼ +35°C
Relative humidity: 25% ∼ 75%
The period of guarantee: Within 2 year from shipment by the company.
Solderability shall be satisfied.
・Product specification contained in this data sheet are subject to change
at any time without notice
・If you have any questions or a Purchasing Specification for any quality
agreement is necessary, please contact our sales staff.
Hokkaido Research Center
Approval by: T. Sannomiya
Drawing by: M. Shibuya
No: RMC−K−HTS−0006
Title:
Page:
/13
1/18
1. Scope
1.1 This data sheet covers the detail requirements for fixed thick film chip resistors; rectangular type, style of RMC1/32, 1/20,
1/16S, 1/16, 1/10, 1/8, 1/4, 1/2, 1.
1.2 Applicable documents
JIS C 5201−1:2011, JIS C 5201−8:2014, JIS C 5201−8−1: 2014
IEC60115−1:2008, IEC60115−8: 2009, IEC60115−8−1: 2014
EIAJ RC−2134C−2010
2. Classification
Type designation shall be the following form.
(Example)
1)
RMC
1/8
123
1
2
3
4
Style
2)
RMC
1/8
JP
1
2
4
Style
1 Fixed thick film chip resistors; rectangular type
2 Rated dissipation and / or dimension
3 Temperature coefficient of resistance
K
−(Dash)
J
5
TP
6
TP
6
Style
±100×10−6/ °C
Standard
4 Rated resistance
123
E24 Series, 3 digit, Ex. 123--> 12kΩ,
1000
E96 Series, 4 digit, Ex. 1000-->100Ω
1022--> 10.2kΩ
JP
Chip jumper
5 Tolerance on rated resistance
D
±0.5%
F
±1%
G
±2%
J
±5%
6 Packaging form 1. Scope
B
Bulk (loose package)
PA
Press pocket taping
TH
Paper taping
TP
TE
Embossed taping
Product specification contained in this data sheet are subject to change at any time without notice.
If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff.
Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2022.8.19
No: RMC−K−HTS−0006
Title:
Page:
/13
2/18
3. Rating
3.1 The ratings shall be in accordance with Table−1.
Table−1(1)
Style
RMC1/32
RMC1/20
Rated
dissipation
(W)
0.03
0.05
resistance (10−6 / °C)
Standard
Standard
K
Standard
K
RMC1/16S
0.1
Standard
K
RMC1/16
0.1
Standard
K
Standard
K
RMC1/10
0.125
Standard
Rated resistance
range (Ω)
±200
±300
+600∼−200
±200
±300
+600∼−200
±200
±200
+350∼−100
+600∼−200
±200
±200
+350∼−100
+600∼−200
±100
±200
±100
±200
+500∼−200
±200
±200
+500∼−200
±100
±100
+500∼−200
±200
+500∼−200
±200
+500∼−200
±100
±200
100∼1M
10∼91
4.7∼9.1
100∼1M
10∼91
1.0∼9.1
10∼1M
10∼10M
4.02∼9.76
1∼3.92
10∼1M
10∼10M
4.3∼9.1
1∼3.9
10∼1M
1.02M∼3.3M
10∼1M
1.02M∼10M
1∼9.76
10∼3.3M
10∼10M
1∼9.1
10∼3.3M
10∼10M
1∼9.76
10∼10M
1.0∼9.1
10∼22M
1.0∼9.1
10∼2.2M
2.21M∼3.3M
±100
±200
+500∼−200
±200
+500∼−200
±200
+500∼−200
10∼2.2M
2.21M∼10M
1.0∼9.76
10∼10M
1.0∼9.1
10∼22M
1.0∼9.1
Preferred
number series
for resistors
Tolerance on
rated resistance
E24, 96
F(±1%)
E24
J(±5%)
D(±0.5%)
E24, 96
F(±1%)
G(±2%)
E24
J(±5%)
D(±0.5%)
E24, 96
F(±1%)
G(±2%)
E24
J(±5%)
D(±0.5%)
E24, 96
F(±1%)
G(±2%)
E24
J(±5%)
D(±0.5%)
E24,96
F(±1%)
G(±2%)
E24
J(±5%)
No: RMC−K−HTS−0006
Title:
Page:
/13
3/18
Table−1(2)
Style
RMC1/8
Rated
dissipation
(W)
resistance (10-6 / °C)
K
±100
10∼1M
Standard
±200
+500∼−200
±200
+500∼−200
±200
+500∼−200
1.02M∼10M
1.0∼9.76
10∼10M
1.0∼9.1
10∼24M
1.0∼9.1
±100
10∼1M
±200
+500∼−200
1.02M∼10M
1.0∼9.76
10∼10M
10∼22M
1.0∼9.1
10∼1M
1.0∼9.76
10∼1M
10∼22M
1.0∼9.1
10∼1M
1.0∼9.76
10∼1M
10∼22M
1.0∼9.1
0.25
K
RMC1/4
0.5
Standard
RMC1/2
RMC1
0.75
1.0
±200
K
+500∼−200
±100
+500∼−200
Standard
±200
K
+500∼−200
±100
+500∼−200
Standard
±200
+500∼−200
Style
Rated resistance
range (Ω)
Limiting element
voltage (V)
15
25
Insulation voltage
(V)
Preferred
number series
for resistors
Tolerance on
rated resistance
D(±0.5%)
E24,96
F(±1%)
G(±2%)
E24
J(±5%)
D(±0.5%)
E24,96
F(±1%)
G(±2%)
E24
E24, 96
J(±5%)
F(±1%)
G(±2%)
E24
E24, 96
J(±5%)
F(±1%)
G(±2%)
E24
J(±5%)
Category temperature
range (°C)
−55∼+125
RMC1/32
50
RMC1/20
RMC1/16S
50
100
RMC1/16
RMC1/10
150
−55∼+155
RMC1/8
RMC1/4
500
200
RMC1/2
RMC1
Note. Rated current of chip jumper: RMC1/32: 0.5(A), RMC1/20, 1/16S: 1(A),
RMC1/16, 1/10, 1/8, 1/4, 1/2,1: 2(A)
Note. Resistance value of chip jumper: 50 mΩ max.
No: RMC−K−HTS−0006
Title:
3.2 Climatic category
3.2.1 RMC1/32
55/125/56
Lower category temperature
Upper category temperature
Duration of the damp heat, steady state test
− 55 °C
+125 °C
56days
3.2.2 RMC1/20,1/16S,1/16,1/10,1/8,1/4,1/2,1
55/155/56
− 55 °C
+155 °C
56days
3.3 Stability class
2%
Page:
/13
4/18
Limits for change of resistance:
−for long−term tests
±(2%+0.1Ω) Chip jumper: 50 mΩ max.
*RMC1/32. 1/20: ±(3%+0.1Ω)
−for short−term tests
±(0.5%+0.05Ω) Chip jumper: 50 mΩ max.
3.4 Derating
The derated values of dissipation (or current rating in case of chip jumper) at temperature in excess of 70 °C shall be as
indicated by the following curve.
100
Percentage of the
rated dissipation
(Current) (%)
−55
RMC1/20,1/16S,1/16,1/10,1/8,1/4, 1/2,1
RMC1/32
Area of recommended
operation
70
125
155
Ambient temperature (°C)
Figure−1 Derating curve
3.5 Rated voltage
d. c. or a. c. r. m. s. voltage calculated from the square root of the product of the rated resistance and the rated dissipation.
E : Rated voltage (V)
E =
P · R
P : Rated dissipation (W)
R : Rated resistance (Ω)
Limiting element voltage can only be applied to resistors when the resistance value is equal to or higher than the critical
resistance value.
At high value of resistance, the rated voltage may not be applicable.
No: RMC−K−HTS−0006
Title:
Page:
/13
5/18
4. Packaging form
The standard packaging form shall be in accordance with Table−2.
Table−2
Symbol
B
TH
TP
Press pocket taping
(paper taping)
Paper taping
Paper taping
TE
Embossed taping
PA
Standard packaging
quantity / units
Packaging form
1,000 pcs.
20,000 pcs.
15,000 pcs.
10,000 pcs.
5,000 pcs.
8mm width, 2mm pitches
8mm width, 4mm pitches
12mm width, 4mm pitches
4,000 pcs.
Application
,1/8,1/4,1/2,1
RMC1/32
RMC1/20
RMC1/16S
RMC1/16, 1/10, 1/8
RMC1/4
RMC1/2, 1
5. Dimensions
5.1 The resistor shall be of the design and physical dimensions in accordance with Figure−2 and Table−3.
z
W
z
L
c
d
d
H
c
Style
RMC1/32
RMC1/20
RMC1/16S
RMC1/16
RMC1/10
RMC1/8
RMC1/4
RMC1/2
RMC1
L
0.4±0.02
0.6±0.03
1.0±0.05
1.6±0.1
2.0±0.1
3.1±0.1
3.1±0.15
5.0±0.15
6.3±0.15
W
0.2±0.02
0.3±0.03
0.5±0.05
+0.15
0.8−0.05
1.25±0.10
1.6±0.15
2.5±0.15
2.5±0.15
3.2±0.15
Figure−2
Table−3
H
0.13±0.02
0.23±0.03
0.35±0.05
0.45±0.10
0.55±0.10
0.55±0.10
0.55±0.15
0.55±0.15
0.55±0.15
Unit : mm
c
0.08±0.03
0.1±0.05
0.2±0.1
0.3±0.1
0.4±0.2
0.5±0.25
0.5±0.25
0.6±0.2
0.6±0.2
d
0.1±0.03
0.15±0.05
+0.05
0.25−0.10
0.3±0.1
0.4±0.2
0.5±0.25
0.5±0.25
0.6±0.2
0.6±0.2
z
0.05~0.3
0.05~0.3
0.05~0.35
0.05~0.35
No: RMC−K−HTS−0006
Title:
Page:
/13
6/18
5.2 Net weight (Reference)
Style
Net weight(mg)
RMC1/32
0.035
RMC1/20
0.16
RMC1/16S
0.6
RMC1/16
2
RMC1/10
5
RMC1/8
9
RMC1/4
16
RMC1/2
25
RMC1
40
6. Marking
The Rated resistance of RMC1/32, 1/20, 1/16S is not be marked.
6.1 RMC1/10,1/8,1/4,1/2,1
The nominal resistance shall be marked in 3 digits or 4 digits and marked on over coat side.
• Malaysia products: E24 series: 3 digits, E96 series: 4 digits
In case of the resistance value that E96 overlaps with E24, It is marked by either.
• China products(RMC1/10,1/8): J(±5%): 3 digits, F(±1%): 4 digits
Marking example
Contents
Application
Malaysia
China
123
123
12×10 3 [Ω] → 12 [kΩ]
Less than 10Ω of RMC1/8,1/4,1/2,1
2R2
2R2
2. 2 [Ω]
2.2
2R2
Less than 10Ω of RMC1/10
2. 2 [Ω]
5623
5623
562×10 3 [Ω] → 562[kΩ]
12R7
12R7 12.7 [Ω]
RMC1/10,1/81/4,1/2,1
6.2 RMC1/16
The nominal resistance shall be marked in 3 digits (E24 and/or E96) and marked on over coat side.
No marking in the E96 series of a Malaysia.
In case of the resistance value that E96 overlaps with E24, there is a case to mark in E96.
Marking example
Contents
Application
Malaysia
China
123
123
E24
E24
2. 2 [Ω]
2R2
2R2
No marking
02C
E96
102×102 [Ω] → 10.2 [kΩ]
No marking
51X
E96
332×10−1 [Ω] → 33.2 [Ω]
No: RMC−K−HTS−0006
Title:
6.2.1 Symbol for E96 series of resistance value
E96
Symbol
E96
Symbol
100
01
162
21
102
02
165
22
105
03
169
23
107
04
174
24
110
05
178
25
113
06
182
26
115
07
187
27
118
08
191
28
121
09
196
29
124
10
200
30
127
11
205
31
130
12
210
32
133
13
215
33
137
14
221
34
140
15
226
35
143
16
232
36
147
17
237
37
150
18
243
38
154
19
249
39
158
40
6.2.2 Symbol of multipliers
Symbol
Y
X
10−1
Multipliers 10−2
A
100
6.3 Marking example of Jumper Chip
Marking example
Contents
Malaysia
China
or 000
000
JP
000
B
101
E96
261
267
274
280
287
294
301
309
316
324
332
340
348
357
365
374
388
392
402
412
Symbol
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
C
102
D
103
E96
422
432
442
453
464
475
487
499
511
523
536
549
562
576
590
604
619
634
649
665
Symbol
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
E
104
F
105
Page:
E96
681
698
715
732
750
768
787
806
825
845
866
887
909
931
953
976
/13
7/18
Symbol
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
Application
RMC1/16
RMC1/10,1/8
RMC1/4,1/2,1
No: RMC−K−HTS−0006
Title:
Page:
/13
8/18
7. Performance
7.1 The standard condition for tests shall be in accordance with Sub−clause 4.2, JIS C 5201−1: 2011.
7.2 The performance shall be satisfied in Table−4.
Table−4(1)
Performance requirements
No.
Test items
Condition of test (JIS C 5201−1)
1
Visual examination
As in 4.4.1
Sub−clause 4.4.1
The marking shall be legible, as
Checked by visual examination.
checked by visual examination.
2
Dimension
As specified in Table−3 of this
Sub−clause 4.4.2
specification.
Resistance
As in 4.5.2
Sub−clause 4.5
The
resistance
value
shall
correspond with the rated resistance
taking into account the specified
tolerance.
Chip jumper: 50mΩ max.
3
Voltage proof
Sub−clause 4.7
No breakdown or flash over
Method: 4.6.1.4(See Figure−5)
Test voltage: Alternating voltage with a peak
value of 1.42 times the
insulation voltage.
Duration: 60 s ± 5 s
R≥1GΩ
Insulation resistance
Test voltage: Insulation voltage
Duration: 1 min.
4
Solderability
As in 4.17.4.5
Sub−clause 4.17
The terminations shall be covered
Without ageing
Flux: The resistors shall be immersed in a with a smooth and bright solder
coating.
non−activated soldering flux for 2s.
Bath temperature: 235 °C ± 5 °C
Immersion time: 2 s ± 0.5 s
5
Mounting
Sub−clause 4.31
Substrate material: Epoxide woven glass
Test substrate: Figure−3
Overload
Sub−clause 4.13
(in the mounted state)
The applied voltage shall be 2.5 times the
rated voltage or twice the limiting element
voltage, whichever is the less severe.
Duration: 2 s
No visible damage
Visual examination
∆R ≤ ± (1%+0.05Ω)
Resistance
Solvent resistance of the Sub−clause 4.30
Legible marking
marking
Solvent: 2−propanol
Solvent temperature: 23 °C ± 5 °C
Method 1
Rubbing material: cotton wool
Without recovery
No: RMC−K−HTS−0006
Title:
No
6
Table−4(2)
Mounting
Sub−clause 4.31
Test substrate: Figure−4
Bound strength of the end face Sub−clause 4.33
plating
Bent value: 3 mm (3225 size max.)
1 mm (5025 size min.)
Resistance
Test items
Final measurements
7
Resistance to soldering heat
Sub−clause 4.33.6
Visual examination
Sub−clause 4.18
Solder temperature: 260 °C ± 5 °C
Immersion time: 10 s ± 0.5 s
Visual examination
Resistance
Component solvent resistance
8
Mounting
Adhesion
Rapid change temperature
Sub−clause 4.29
Solvent: 2−propanol
Method 2
Recovery: 48 h
Visual examination
Resistance
Page:
/13
9/18
∆R ≤ ± (0.5%+0.05Ω)
No visible damage
As in 4.18.3.4
No sign of damage such as cracks.
∆R ≤ ± (0.5%+0.05Ω)
No visible damage
∆R ≤ ± (0.5%+0.05Ω)
Sub−clause 4.31
Sub−clause 4.32
Force: 5 N
(RMC1/32: 2N, RMC1/20: 3N)
Duration: 10 s ± 1 s
No visible damage
Visual examination
Sub−clause 4.19
RMC1/32
Lower category temperature: −55 °C
Upper category temperature: +125 °C
Upper category temperature: +155 °C
Duration of exposure at each temperature: 30
min.
Number of cycles: 5 cycles.
No visible damage
Visual examination
∆R ≤ ±(0.5%+0.05Ω)
Resistance
No: RMC−K−HTS−0006
Title:
No
9
Test items
Climatic sequence
−Dry heat
−Damp heat, cycle
(12+12hour cycle)
First cycle
−Cold
−Damp heat, cycle
(12+12hour cycle)
Remaining cycle
−D.C. load
10
Mounting
Endurance at 70 °C
Page:
/13
10/18
Table−4(3)
Sub−clause 4.23
Sub−clause 4.23.2
RMC1/32
Test temperature: +125 °C
RMC1/20,1/16S,1/16,1/10,1/8,1/4,1/2,1:
Test temperature: +155 °C
Duration: 16 h
Sub−clause 4.23.3
Test method: 2
Test temperature: 55 °C
[Severity(2)]
Sub−clause 4.23.4
Test temperature −55 °C
Duration: 2h
Sub−clause 4.23.6
Test method: 2
[Severity (2)]
Sub−clause 4.23.7
The applied voltage shall be the rated voltage
or the limiting element voltage whichever is
the smaller.
Duration: 1 min.
No visible damage
Visual examination
RMC1/32,1/20: ∆R ≤ ± (3%+0.1Ω)
Resistance
Others: ∆R ≤ ± (2%+0.1Ω)
Sub−clause 4.31
(RMC1may use Alumina substrate.)
Sub−clause 4.25.1
Ambient temperature: 70 °C ± 2 °C
Duration: 1000 h
The voltage shall be applied in cycles of 1.5 h
on and 0.5 h off.
the smaller.
Examination at 48 h , 500 h and
1000 h:
No visible damage
Visual examination
Resistance
No: RMC−K−HTS−0006
Title:
No
11
12
13
Page:
/13
11/18
Table−4(4)
Mounting
Sub−clause 4.31
Variation of resistance with Sub−clause 4.8
As in Table−1
temperature
RMC1/32:
−55 °C / +20 °C
+20 °C / +125°C
−55 °C / +20 °C
+20 °C / +155°C
Mounting
Sub−clause 4.31
Damp heat, steady state
Sub−clause 4.24
Ambient temperature: 40 °C ± 2 °C
Relative humidity : 93 +2
−3 %
a) 1st group: without voltage applied.
b) 2nd group: The d. c. voltage shall be
applied continuously.
The voltage shall be accordance with
Sub−clause 4.24.2.1 b). without polarizing
voltage [4.24.2.1, c)]
No visible damage
Visual examination
Legible marking
Resistance
Dimensions (detail)
Sub−clause 4.4.3
As in Table−3
Test items
Mounting
Sub−clause 4.31
Endurance at upper category Sub−clause 4.25.3
temperature
RMC1/32:
Ambient temperature:125 °C ± 2 °C
Ambient temperature:155 °C ± 2 °C
Duration: 1000 h
Examination at 48 h, 500 h and
1000 h:
Visual examination
Resistance
No visible damage
No: RMC−K−HTS−0006
Title:
/13
Page:
12/18
c
2.0
4.5
d
7.5
7.5
8. Test substrate
c
Unit: mm
a
:Copper clad
b
40
:Solder resist
d
Style
RMC1/2
RMC 1
10.16
a
4.0
5.0
b
7.5
9.0
60.96
RMC1/2, 1 TEST SUBSTRATE
Soldering land
:Solder resist
25
a
3.5 3
:Copper clad
d
Unit: mm
b
c
7.5
5.5
Style
a
RMC1/32
0.2
RMC1/20
0.3
RMC1/16S
0.6
5.08 5.08
3
RMC1/16
1.0
2.5
58.5
RMC1/10
1.2
RMC1/8
2.1
RMC1/4
2.2
RMC1/20, 1/16S, 1/16, 1/10, 1/8, 1/4 TEST SUBSTRATE
Figure−3
Remark 1). Material: Epoxide woven glass
Thickness: 1.6mm Thickness of copper clad: 0.035mm
2). In the case of connection by connector, the connecting terminals are gold plated.
However, the plating is not necessary when the connection is made by soldering.
b
0.56
1.5
1.9
3.6
4.0
3.9
5.0
c
0.2
0.45
0.7
1.0
1.5
1.7
2.9
d
5.3
5.2
4.9
4.5
4.3
3.4
3.3
No: RMC−K−HTS−0006
Title:
Page:
/13
13/18
Unit: mm
:Copper clad
40
c
1
a
:Solder resist
Style
RMC1/2
RMC 1
b
a
4.0
5.0
b
7.5
9.0
c
3.0
4.0
100
RMC1/2, 1 BOUND STRENGTH OF THE END FACE PLATING TEST SUBSTRATE
Unit: mm
a
:Copper clad
1
4.5
:Solder resist
40
d
c
d
Style
RMC1/20
RMC1/16S
RMC1/16
RMC1/10
RMC1/8
RMC1/4
b
70
100
Soldering land
a
0.3
0.6
1.0
1.2
2.5
2.2
b
1.1
1.9
3.6
4.0
5.0
5.0
c
0.45
0.7
1.20
1.65
2.0
2.9
d
2.15
2.0
3.0
3.0
2.5
2.5
RMC1/20,1/16S,1/16,1/10,1/8,1/4 BOUND STRENGTH OF THE END FACE PLATING TEST SUBSTRATE
Unit: mm
:Copper clad
5.5
:Solder resist
40
0.5
70
0.53
0.2
0.5 0.2 0.5
Soldering land
0.56
100
RMC1/32 BOUND STRENGTH OF THE END FACE PLATING TEST SUBSTRATE
Figure−4
No: RMC−K−HTS−0006
Title:
⋅ RMC1/16S,1/16,1/10,1/8,1/4,1/2,1
Page:
/13
14/18
⋅ RMC1/32, 1/20
Insulation plate
Metal block measurement
Point A
V
Metal plate
R0.25∼R0.5mm
Measurement
point B
Insulation surface
Component
Pressure by
spring (1±0.2N)
Figure−5
9. Taping
9.1 Applicable documents JIS C 0806−3: 2014, EIAJ ET−7200C: 2010
9.2 Taping dimensions
9.2.1 Press pocket taping (Paper taping, 8mm width, 2mm pitches)
Taping dimensions shall be in accordance with Figure−6 and Table−5.
Unit: mm
4±0.05
Sprocket hole
t1
φ1.5 +0.1
1.75±0.1
B
8±0.2
A
t3
2±0.05
Carrier cavity
t2
3.5±0.05
Direction of unreeling
Figure−6
Table−5
Style
RMC1/32
RMC1/20
A
0.24±0.03
0.37±0.05
B
0.45±0.03
0.67±0.05
t1
0.31±0.03
0.42±0.03
t2
0.36±0.03
0.45±0.05
Unit: mm
t3
0.15±0.02
0.27±0.02
No: RMC−K−HTS−0006
Title:
Page:
/13
15/18
9.2.2 Paper taping (8mm width, 2mm pitches)
Taping dimensions shall be in accordance with Figure−7 and Table−6.
4±0.1
t1
Sprocket hole
φ1.5
Unit: mm
1.75±0.1
0 .1
+0
B
8±0.2
A
t2
2±0.05
Carrier cavity
3.5±0.05
Style
RMC1/16S
A
0.65+0.05
−0.10
Figure−7
Table−6
B
1.15 −+0.05
0.10
t1
0.4 ± 0.05
Unit: mm
t2
0.5max.
9.2.3 Paper taping (8mm width, 4mm pitches)
Taping dimensions shall be in accordance with Figure−8 and Table−7.
Unit: mm
4±0.1
t
1
Sprocket hole
φ1.5
2±0.05
+0.1
1.75±0.1
B
8±0.2
A
t
Carrier cavity
2
4±0.1
3.5±0.05
Style
RMC1/16
RMC1/10
RMC1/8
Figure−8
Table−7
A
B
1.15±0.15
1.9±0.2
1.65±0.15
2.5±0.2
2.00±0.15
3.6±0.2
t1
0.6±0.1
Unit: mm
t2
0.8max.
0.8±0.1
1.0max.
No: RMC−K−HTS−0006
Title:
Page:
/13
16/18
9.2.4 Embossed taping dimensions shall be in accordance with Figure−9 and Table−8.
Unit: mm
0.3 max.
2±0.05
Sprocket hole
φ1.5+0.1
1.75±0.1
4±0.1
Carrier cavity
t1
Style
RMC1/4
RMC1/2
RMC 1
A
2.85±0.20
3.1±0.2
3.6±0.2
W
B
E
A
4±0.1
Figure−9
Table−8
B
W
3.5±0.2
8.0±0.3
5.5±0.2
12.0±0.3
6.9±0.2
E
3.5±0.05
Unit: mm
t1
1.0±0.2
5.5±0.05
1.1±0.15
1). The cover tapes shall not cover the sprocket holes.
2). Tapes in adjacent layers shall not stick together in the packing.
3). Components shall not stick to the carrier tape or to the cover tape.
4). Pitch tolerance over any 10 pitches ±0.2mm.
5). The peel strength of the top cover tape shall be with in 0.1N to 0.5N on the test method as shown in the
following RMC1/32,1/20: Figure−10, RMC1/16S, 1/16, 1/10, 1/8: Figure−11, RMC1/4, 1/2, 1: Figure−12.
6). When the tape is bent with the minimum radius for RMC1/32, 1/20, 1/16S, 1/16, 1/10,1/8, 1/4: 25 mm, or RMC1/2, 1: 30
mm, the tape shall not be damaged and the components shall maintain their position and orientation in the tape.
7). In no case shall there be two or more consecutive components missing.
The maximum number of missing components shall be one or 0.1%, whichever is greater.
8). The resistors shall be faced to upward at the over coating side in the carrier cavity.
Top cover tape
Carrier tape
165°to180°
Peel−off
( About 300mm/ min)
Figure−10
Top cover tape
Carrier tape
165°to180°
Peel−off
( About 300mm/ min)
Figure−11
No: RMC−K−HTS−0006
Title:
Page:
/13
17/18
Top cover tape
Carrier tape
Peel−off
(About 300mm/ min)
165°to180°
Figure−12
9.3 Reel dimension
Reel dimensions shall be in accordance with the following Figure−13 and Table−9.
Plastic reel (Based on EIAJ ET−7200C)
Unit: mm
φ60
φ13±0.2
2±0.5
φ180 −1.5
Marking A
φ21±0.8
Marking B
A
B
Figure−13
Table−9
Unit: mm
B
Note
Injection molding
11.4±1.0
RMC1/32, 1/20, 1/16S, 1/16, 1/10, 1/8, 1/4
9 +1.0
13±1.0
Vacuum forming
RMC1/2, 1
17±1.0
Vacuum
forming
13 +1.0
Note: Marking label shall be marked on a place of Marking A or two place of marking A and B.
A
Style
9.4 Leader and trailer tape.
(Example)
400mm min.
100mm min.
160mm min.
End
Start
Trailer
Leader
Figure−14
No: RMC−K−HTS−0006
Title:
Page:
/13
18/18
10. Marking on package
The label of a minimum package shall be legibly marked with follows.
10.1 Marking A
(1) Classification
(Style, Temperature coefficient of resistance, Rated resistance, Tolerance on rated resistance, Packaging form)
(2) Quantity (3) Lot number (4) Manufacturer’s name or trade mark
10.2 Marking B (KAMAYA Control label)
(5) Others
