MUR410~MUR4100
4.0Amp Ultra Fast Silicon Rectifiers
DO-27
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Open Junction chip
Low reverse leakage
0.945 (24.0)
MIN.
0.220 (5.6)
0.197(5.0)
DIA.
High forward surge current capability
High temperature soldering guaranteed
0.375(9.5)
0.285(7.2)
250 C/10 seconds at terminals
Mechanical Data
0.945 (24.0)
MIN.
Case : Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
0.052 (1.3)
0.035(0.9)
DIA.
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0345 ounce, 0.98 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,
for capacitive load current derate by 20%.
Parameter
SYMBOLS
MUR
410
MUR
420
MUR
440
MUR
460
MUR
480
MUR
4100
UNITS
Maximum repetitive peak reverse voltage
VRRM
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
70
140
280
420
560
700
V
Maximum DC blocking voltage
VDC
100
200
400
600
800
1000
V
Maximum average forward rectified current
at TL =100 C
I(AV)
4.0
A
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
IFSM
150.0
A
Maximum instantaneous forward voltage at 3.0A
VF
0.95
1.28
1.85
V
Maximum DC reverse current T A =25 C
at rated DC blocking voltage TA=125 C
IR
Maxinum reverse recovery time(Note 1)
Trr
Typical junction capacitance (Note2)
CJ
75.0
pF
RqJA
45.0
C/W
-55 to +150
C
Typical thermal resistance
Operating junction and storage temperature range TJ,TSTG
10.0
500
45
50
uA
ns
75
Note: 1.Reverse recovery time test condition: IF=0.5A IR=1.0A Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
+86-769-22857832
huixin@hxkj.hk
Rev.01
Page 1 of 2
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
4.0
Peak Forward Surage Current
Amperes
210
3.5
180
3.0
150
Amperes
Average Forward Rectified Current
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
2.5
120
2.0
1.5
1.0
0.5
0.0
60
80
100
120
140
90
f=60Hz
60
160
30
1Cycle
10
Lead Temperature
100
Number of cycles
10
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
MUR410-MUR420
MUR440-MUR460
MUR480-MUR4100
0.01
0.2
0.6
1.0
1.4
1.8
2.0
Instantaneous Forward Voltage
Volts
+86-769-22857832
huixin@hxkj.hk
100
Micro Amperes
Instantaneous Forward Current
Amperes
Instantaneous Reverse Leakage Current
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
Tj = 125°C
10
1.0
Tj = 25°C
0.1
0.01
60
80
100
120
140
Percent Of Rated Peak Reverse Voltage(%)
Rev.01
Page 2 of 2
很抱歉,暂时无法提供与“MUR460”相匹配的价格&库存,您可以联系我们找货
