HoRS2512-1W-390mR-1% 数据手册
系列号
修订日期
HoRS贴片陶瓷系列规格书
版本号
HoRS
2020-03-06
Ho-A0
■Scope
-This specification applies to all sizes of rectangular-type fixed chip
resistors with Ruthenium-base as material.
■Features
-Low inductance
-Highly reliable multilayer electrode construction
-Higher component and equipment reliability
-Reduced size of final equipment reliability
-RoHS Compliance
■Construction
■Applications
-Power Management Applications
L
-Switching Power Supply
D1
-Over Current Protection in Audio Application
-Voltage Regulation Module (VRM)
W
3
4
5
6
T
-DC-DC Converter, Battery Pack, Charger, Adaptor
-Automotive Engine Control
-Disk Driver
9 8 7 1 2
D2
1 Alumina Substrate
4 Edge Electrode
7 Resistor Layer
2 Bottom Electrode
5 Barrier Layer
8 Primary Overcoat
3 Top Electrode
6 External Electrode
9 Secondary Overcoat
■Dimensions
L
W
T
D1
D2
(mm)
(mm)
(mm)
(mm)
(mm)
Weight
(g)
(1000pcs)
Type
Size
(Inch)
RS
0402
1.00±0.05
0.50±0.05
0.35±0.05
0.20±0.10
0.20±0.10
0.620
RS
0603
1.60±0.10
0.80±0.10
0.45±0.10
0.30±0.20
0.30±0.20
2.042
RS
0805
2.00±0.10
1.25±0.10
0.50±0.10
0.35±0.20
0.40±0.20
4.368
RS
1206
3.10±0.10
1.55±0.10
0.55±0.10
0.50±0.25
0.50±0.20
8.947
RS
1210
3.10±0.10
2.60±0.15
0.55±0.10
0.50±0.25
0.50±0.20
15.959
RS
2010
5.00±0.10
2.50±0.15
0.55±0.10
0.60±0.25
0.50±0.20
24.241
RS
2512
6.35±0.10
3.10±0.15
0.55±0.10
0.60±0.25
0.50±0.20
39.448
地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼
深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn
系列号
HoRS
修订日期
HoRS贴片陶瓷系列规格书
2020-03-06
Ho-A0
版本号
■Part Numbering
Ho
制造商
毫欧电子
1W
2512
RS
产品系列
封装尺寸
贴片陶瓷
0402
0603
0805
1206
1210
2010
2512
■Recommend Land Pattern
200mR
额定功率(W)
精度(%)
阻值(mR)
1/16W
1/10W
1/8W
1/4W
1/3W
1%
- 0R047: 0.047Ω
- - - 0R1: 0.1Ω
F: ±1%
J: ±5%
“-“ to fill up 6 spaces
3/4W
1W
■Derating Curve
100
B
Power ratio(%)
C
A
A
(mm)
B
(mm)
C
(mm)
RS0402
0.50
0.45
0.60
RS0603
0.90
0.60
0.90
RS0805
1.20
0.70
1.30
RS1206
2.00
0.90
1.60
RS1210
2.00
0.90
2.80
RS2010
3.80
0.90
2.80
RS2512
3.80
1.60
3.50
Type
80
60
40
60
80
100
120
140
160
Ambient Temperature(℃)
■Soldering Condition
IR Reflow Soldering
Wave Soldering (Flow Soldering)
(1) Time of IR reflow soldering at maximum temperature point 260°C:10s
(2) Time of wave soldering at maximum temperature point 260°C:10s
(3) Time of soldering iron at maximum temperature point 410°C:5s
180
系列号
修订日期
HoRS贴片陶瓷系列规格书
版本号
HoRS
2020-03-06
Ho-A0
■Standard Electrical Specifications
Item
Power Rating
at 70°C
Operating Temp. Max. Operating
Range
Current
Type
Resistance Range
(mΩ)
±1%
TCR
(PPM/°C)
±5%
RS0402
1/16W
-55 ~ +155°C
1.11A
50 - 91
100 - 976
±800
±500
RS0603
1/10W
-55 ~ +155°C
2.23A
20 - 47
50 - 91
100 - 976
±1200
±800
±500
RS0805
1/8W
-55 ~ +155°C
3.53A
RS1206
1/4W
-55 ~ +155°C
5.00A
10 - 18
20 - 47
50 - 91
100 - 976
±1500
±1200
±800
±500
RS1210
1/3W
-55 ~ +155°C
5.77A
RS2010
3/4W
-55 ~ +155°C
8.66A
10 - 18
20 - 91
100 - 976
±1500
±800
±500
RS2512
1W
-55 ~ +155°C
10.0A
Operating Voltage=√(P*R)
; Overload Voltage=2.5*√(P*R)
■High Power Electrical Specifications
Item
Type
Power Rating
at 70°C
Range
Current
Resistance Range
(mΩ)
±1%
TCR
(PPM/°C)
±5%
RS0402
1/10W
-55 ~ +155°C
1.40A
50 - 91
100 - 976
±800
±500
RS0603
1/8W
-55 ~ +155°C
2.50A
20 - 47
50 - 91
100 - 976
±1200
±800
±500
RS0805
1/4W
-55 ~ +155°C
5.00A
RS1206
1/2W
-55 ~ +155°C
7.07A
10 - 18
20 - 47
50 - 91
100 - 976
±1500
±1200
±800
±500
RS1210
1/2W
-55 ~ +155°C
7.07A
RS2010
1W
-55 ~ +155°C
10.0A
10 - 18
20 - 91
100 - 976
±1500
±800
±500
RS2512
2W
-55 ~ +155°C
14.1A
Operating Current=√(P/R)
系列号
HoRS贴片陶瓷系列规格书
修订日期
版本号
HoRS
2020-03-06
Ho-A0
■Environmental Characteristics
Requirement
Item
Temperature Coefficient of
Resistance (T.C.R.)
Short Time Overload
Test Method
±5%
±1%
JIS-C-5201-1 4.8
IEC-60115-1 4.8
As Spec.
±(1.0%+0.05Ω)
Insulation Resistance
≥10G
Endurance
±(1.0%+0.10Ω)
-55°C~+125°C, 25°C is the reference temperature
JIS-C-5201-1 4.13
IEC-60115-1 4.13
±(2.0%+0.05Ω)
JIS-C-5201-1 4.6
IEC-60115-1 4.6
Max. Overload Voltage for 1 minute
JIS-C-5201-1 4.25
IEC-60115-1 4.25.1
±(2.0%+0.10Ω)
Damp Heat with Load
±(1.0%+0.10Ω)
±(2.0%+0.10Ω)
Dry Heat
±(1.0%+0.05Ω)
±(1.5%+0.10Ω)
±(1.0%+0.05Ω)
Solderability
95% min. coverage
Resistance to Soldering Heat ±(0.5%+0.05Ω)
Leaching
Rapid Change of
Temperature
70±2°C, RCWV for 1000 hrs with 1.5 hrs “ON” and
0.5 hr “OFF”
JIS-C-5201-1 4.24
IEC-60115-1 4.24
40±2°C, 90~95% R.H., RCWV for 1000 hrs with 1.5
hrs “ON” and 0.5 hr “OFF”
JIS-C-5201-1 4.23
IEC-60115-1 4.23.2
at +155°C for 1000 hrs
JIS-C-5201-1 4.33
IEC-60115-1 4.33
Bending Strength
Voltage Proof
RCWV*2.5 or Max. Overload Voltage whichever is
lower for 5 seconds, 2 seconds for High Power Series
±(1.0%+0.05Ω)
±(1.0%+0.05Ω)
No breakdown or flashover
Individual leaching area ≦5%
Total leaching area ≦ 10%
±(0.5%+0.05Ω)
±(1.0%+0.05Ω)
Bending once for 5 seconds
2010, 2512 sizes: 2mm
Other sizes: 3mm
JIS-C-5201-1 4.17
IEC-60115-1 4.17
245±5°C for 3 seconds
JIS-C-5201-1 4.18
IEC-60115-1 4.18
260±5°C for 10 seconds
JIS-C-5201-1 4.7
IEC-60115-1 4.7
1.42 times Max. Operating Voltage for 1 minute
JIS-C-5201-1 4.18
IEC-60068-2-58 8.2.1
260±5°C for 30 seconds
JIS-C-5201-1 4.19
IEC-60115-1 4.19
-55°C to +155°C, 5 cycles
RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower.
■ Storage Temperature: 15~28°C; Humidity < 80%RH
系列号
HoRS
修订日期
HoRS贴片陶瓷系列规格书
2020-03-06
Ho-A0
版本号
▓Packaging
Reel Specifications & Packaging Quantity
Type
RS0402
Packaging
Quantity
Paper
RS0603
RS0805
RS1206
Paper
RS1210
RS2010)
RS2512
Embossed
Tape Width
Reel
Diameter
ΦA
(mm)
10K
8mm
7 inch
178.5±1.5
20K
8mm
10 inch
254±1.0
40K
8mm
13 inch
330±1.0
5K
8mm
7 inch
178.5±1.5
10K
8mm
10 inch
254±1.0
20K
8mm
13 inch
330±1.0
4K
12mm
7 inch
178.5±1.5
8K
12mm
10 inch
250±1.0
Bottom Tape
Top Tape
Paper Tape Specifications
ΦB
(mm)
ΦC
(mm)
W
(mm)
T
(mm)
13.0±0.2
9.0±0.5
12.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
13.0±0.2
9.0±0.5
12.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
+1/-0
13.0±0.5
13.0±0.5
15.5±0.5
62±0.5
13.0±0.5
12.5±0.5
16.5±0.5
60
60
60
+1/-0
+1/-0
ψ D0
E
A
F
W
B
T
Paper Tape
Type
A
(mm)
B
(mm)
W
(mm)
P1
Resistor
E
(mm)
F
(mm)
P0
(mm)
P2
P0
P1
(mm)
Direction of unreeling
P2
(mm)
ΦD0
(mm)
T
(mm)
RS0402
0.65±0.10 1.15±0.10
8.0±0.20
1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10
RS0603
1.10±0.10 1.90±0.10
8.0±0.20
1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10
RS0805
1.60±0.10 2.40±0.20
8.0±0.20
1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10
RS1206
1.90±0.10 3.50±0.20
8.0±0.20
RS1210
2.90±0.10 3.50±0.20
8.0±0.20
系列号
HoRS
修订日期
HoRS贴片陶瓷系列规格书
2020-03-06
Ho-A0
版本号
Embossed Plastic Tape Specifications
Top Tape
ψ D0
E
A
F
B
T
P1
Resistor
P2
P0
W
ψD11.5+0.25,-0
Embossed Tape
A
(mm)
B
(mm)
W
(mm)
E
(mm)
F
(mm)
RS2010
2.8±0.10
5.5±0.10
12.0±0.30
1.75±0.10
5.5±0.05
4.00±0.10 4.00±0.10
2.00±0.05 1.50+0.1, -0
1.2
+0
RS2512
3.5±0.10
6.7±0.10
12.0±0.30
1.75±0.10
5.5±0.05
4.00±0.10 4.00±0.10
1.2
+0
Type
P0
(mm)
P1
(mm)
P2
(mm)
ΦD0
(mm)
T
(mm)
■Marking
No Marking for 0402
1%, 5% for 0805/1206/1210/2010/2512: 4 digits marking
Example:
Resistance
Marking
47mΩ
R047
75mΩ
R075
15mΩ
R015
750mΩ
R750
820mΩ
R820
5% for 0603: 3 digits marking in E24
1% for 0603: 3 digits marking with under-line in E96 (non-including E24 series)
R10
3 digits marking for E24 or R value suffix is zero in E96: R10=100mΩ; R28=280mΩ
243
3 digits marking for E96: 243=243mΩ; 511=511mΩ
HoRS2512-1W-390mR-1% 价格&库存
很抱歉,暂时无法提供与“HoRS2512-1W-390mR-1%”相匹配的价格&库存,您可以联系我们找货
