HoCR0805-1/8W-84.5K-1%
    MILLIOHM(毫欧)
HoCR0805-1/8W-84.5K-1% 数据手册
HoCR贴片陶瓷系列规格书 系列号 HoCR 修订日期 2020-03-26 版本号 Ho-A0 ■Scope -This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. ■Features -Small size and light weight -Highly reliable multilayer electrode construction -Compatible with all soldering process -Long side terminations ■Construction ■Applications L -Telecommunication Equipments D1 -Radio and Tape Recorders, TV Tuners 3 4 5 6 W T 9 87 1 -Digital Cameras, Watches, Pocket Calculators -Computers, Instruments -Medical and Military Equipment 2 D2 1 Alumina Substrate 4 Edge Electrode 7 Resistor Layer 2 Bottom Electrode 5 Barrier Layer 8 Primary Overcoat 3 Top Electrode 6 External Electrode 9 Secondary Overcoat ■Dimensions Type Size (Inch) D1 D2 (mm) T (mm) (mm) (mm) Weight (g) (1000pcs) L W (mm) CR 01005 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 0.037 CR 0201 0.60±0.03 0.30±0.03 0.23±0.03 0.15±0.05 0.15±0.05 0.150 CR 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 CR 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 CR 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 CR 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 CR 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 CR 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 CR 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 CR 1225 3.10±0.15 6.30±0.15 0.90±0.15 0.60±0.30 0.80±0.25 64.88 CR 0612 1.55±0.10 3.10±0.15 0.55±0.10 0.25±0.15 0.35±0.15 9.31 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoCR贴片陶瓷系列规格书 修订日期 版本号 Ho 制造商 1/8W 0805 CR 产品系列 封装尺寸 01005 毫欧电子 贴片陶瓷 额定功率(W) 1/32W 1/20W 1/16W 1/10W 1/8W 1/4W 1/3W 3/4W 0201 0402 0603 0805 1206 1210 2010 2512 1225 0612 HoCR 2020-03-06 Ho-A0 1R 1% 阻值(mR) 精度(%) - - - 1R2: 1.2Ω - - - 3K3: 3.3KΩ - - - 10K: 10KΩ - - 100K: 100KΩ “-“ to fill up 6 spaces B: ±0.1% C: ±0.25% D: ±0.5% F: ±1% J: ±5% 1W 2W 0.75W ■Standard Electrical Specifications Item Type CR01005 Power Rating at 70°C Jumper Rated Current 1/32W Operating Temp. Range Max. Operating Voltage Max. Overload Voltage 15V 30V CR0402 0Ω (
HoCR0805-1/8W-84.5K-1% 价格&库存
很抱歉,暂时无法提供与“HoCR0805-1/8W-84.5K-1%”相匹配的价格&库存,您可以联系我们找货
