SR520 THRU SR5200 DO-27
Schottky Barrier Rectifiers
Reverse Voltage - 20 to 200 V
Forward Current - 5 A
FEATURES
Guardring for overvoltage protection
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed
250℃ /10 seconds at terminals
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: DO-201AD/ DO-27
Terminals: Solderable per MIL-STD-750, Method 2026
DO-201AD/ DO-27
Approx. Weight: 0. 98 g / 0.0345oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
SR520
SR540
SR560
SR580
SR5100
SR5150
SR5200
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
60
80
100
150
200
V
Maximum RMS voltage
VRMS
14
28
42
56
70
105
140
V
Maximum DC Blocking Voltage
VDC
60
80
100
150
200
V
Maximum Average Forward Rectified Current
at Tc = 100 °C
IF(AV)
5.0
A
Peak Forward Surge Current 8.3 ms Single
Half Sine Wave Superimposed on Rated Load
IFSM
120.0
A
Maximum Instantaneous Forward Voltage at 5.0A
VF
Parameter
0.55
Maximum DC Reverse Current T a = 25 °C
at Rated DC Blocking Voltage
T a=125 °C
Typical Thermal Resistance
Operating junction temperature range
Storage Temperature Range
0.70
0.85
0.5
50
IR
0.95
0.05
10
V
mA
RθJA
55
°C/W
Tj
-55 ~ +150
°C
Tstg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
140
Peak Forward Surage Current
Amperes
8.0
7.0
6.0
Amperes
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
5.0
4.0
3.0
2.0
1.0
0.0
60
80
100
120
140
120
100
80
60
f=60Hz
40
1Cycle
1
10
100
Lead Temperature
Number of cycles
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
50
100
TJ=25 C
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
SB520-SB560
SB580-SB5200
10.0
1
0.1
SB520-SB540
SB560
SB580-SB5100
SB5150-SB5200
0.01
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
10
TJ=100 C
1
0.1
0.01
0.001
TJ=25 C
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
www.yfwdiode.com
2/3
Package Outline
DO-201AD(DO-27)
D
DIMENSIONS
A
DIM
A
B
C
D
Cathode
Mark
B
INCHES
MIN
----.048
1.000
MAX
.370
.250
.052
MM
MIN
----1.20
25.40
MAX
9.50
6.40
1.30
NOTE
D
C
Summary of Packing Options
Package
DO-201AD(DO-27)
www.yfwdiode.com
Packing Description
Packing Quantity
BOX
250/1000/1250
3/3
Industry Standard
EIA-481-1
很抱歉,暂时无法提供与“SR5100”相匹配的价格&库存,您可以联系我们找货
