Stackpole Electronics, Inc.
HMC Series
Resistive Product Solutions
High Value Thick Film Chip Resistor
Features:
R Value extension of RMCF product
Highly stable performance over time
Power derating from 100% at 70ºC to zero at 125ºC
E12 and E24 values
Nickel barrier terminations
RoHS compliant by means of exemption 7c-I
Halogen free
REACH compliant
Electrical Specifications
Type/Code
HMC0402
Power Rating
(W) @ 70ºC
Maximum
Working
Voltage (V) (1)
0.063
Maximum
Overload
Voltage (V)
50
± 200
100
0.1
50
1%
11M - 20M
± 400
± 200
HMC0603
Ohmic Range (Ω) and Tolerance
TCR (ppm/ºC)
100
HMC1206
0.125
0.25
150
22M - 100M
± 400
300
200
0.33
200
400
HMC2010
0.75
200
400
HMC2512
1
250
22M - 100M
± 500
± 200
11M - 20M
110M - 1G
22M - 100M
± 500
± 1000
510M - 1G
± 1500
1.2G - 10G
110M - 500M
± 200
11M - 20M
± 400
22M - 100M
30M - 100M
± 500
110M - 500M
± 1000
510M - 1G
± 1500
1.2G - 10G
± 200
11M - 20M
400
HMC1210
10%
11M - 20M
± 400
HMC0805
5%
500
11M - 20M
± 400
22M - 100M
± 200
11M - 20M
± 400
22M - 100M
± 200
11M - 20M
± 400
22M - 100M
(1) Lesser of √ P*R or maximum working voltage.
Mechanical Specifications
Type/Code
HMC0402
HMC0603
HMC0805
L
Body Length
0.039 ± 0.002
1.00 ± 0.05
0.063 ± 0.004
1.60 ± 0.10
0.079 ± 0.008
2.00 ± 0.20
W
Body Width
0.020 ± 0.002
0.50 ± 0.05
0.031 ± 0.004
0.80 ± 0.10
0.049 ± 0.004
1.25 ± 0.10
Rev Date: 5/12/2023
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
H
Body Height
0.014 ± 0.002
0.35 ± 0.05
0.018 ± 0.004
0.45 ± 0.10
0.020 ± 0.004
0.50 ± 0.10
1
a
Top Termination
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
b
Bottom Termination
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
Unit
inches
mm
inches
mm
inches
mm
www.seielect.com
marketing@seielect.com
HMC Series
Mechanical Specifications (cont.)
L
Body Length
0.122 ± 0.006
3.10 ± 0.15
W
Body Width
0.061 ± 0.004
1.55 ± 0.10
H
Body Height
0.022 ± 0.006
0.55 ± 0.15
a
Top Termination
0.020 ± 0.010
0.50 ± 0.25
b
Bottom Termination
0.020 ± 0.008
0.50 ± 0.20
inches
mm
HMC1210
0.126 ± 0.008
3.20 ± 0.20
0.102 ± 0.006
2.60 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.020 ± 0.008
0.50 ± 0.20
0.020 ± 0.008
0.50 ± 0.20
inches
mm
HMC2010
0.197 ± 0.008
5.00 ± 0.20
0.098 ± 0.006
2.50 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.024 ± 0.010
0.60 ± 0.25
0.020 ± 0.008
0.50 ± 0.20
inches
mm
HMC2512
0.250 ± 0.008
6.35 ± 0.20
0.126 ± 0.006
3.20 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.024 ± 0.010
0.60 ± 0.25
0.020 ± 0.008
0.50 ± 0.20
inches
mm
Type/Code
HMC1206
Unit
Performance Characteristics
Test
Long Term Stability
High Temperature Loading
Resistance to Solder Heat
Short Time Overload
Operating temperature range is -55ºC to +125ºC
Test Condition (JIS C 5202)
Test Result
Nominal temperature & humidity for 1000 hours
15 VDC, 1.5 hour ON, 0.5 hour OFF, 1000 hours 70ºC
260ºC ± 5ºC, 10 seconds +1/-0
5 seconds at maximum overload voltage
± 0.5%
± 3%
± 1%
± 2%
Power Derating Curve:
Rev Date: 5/12/2023
2
www.seielect.com
HMC Series
Recommended Pad Layouts
Type/Code
HMC0402
HMC0603
HMC0805
HMC1206
HMC1210
HMC2010
HMC2512
A
B
C
Unit
0.020
0.50
0.035
0.90
0.047
1.20
0.079
2.00
0.079
2.00
0.150
3.80
0.193
4.90
0.018
0.45
0.024
0.60
0.028
0.70
0.035
0.90
0.035
0.90
0.035
0.90
0.063
1.60
0.024
0.60
0.035
0.90
0.051
1.30
0.063
1.60
0.110
2.80
0.110
2.80
0.138
3.50
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Difference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Rev Date: 5/12/2023
3
www.seielect.com
HMC Series
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
SMD
Surface Mount Chip Resistor
Note (1): RoHS Compliant by means of exemption 7c-I.
HMC
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
YES(1)
100% Matte Sn over Ni
Jan-04
04/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Rev Date: 5/12/2023
4
www.seielect.com
HMC Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
H
M
Product Series
Code Description
High Value
HMC
Thick Film
C
Size
Code
W
0402 0.063
0603
0.1
0805 0.125
1206
0.25
0.33
1210
2010
0.75
2512
1
Tolerance
Code Tol
Value
F
1%
E24
J
5%
K
10%
Rev Date: 5/12/2023
5
Code
T
5
F
T
4
Packaging
Description
Size
0402
7" Reel
0603, 0805
Paper Tape
1206, 1210
7" Reel
2010
Plastic Tape
2512
7
M
Resistance Value
Quantity
10000
5000
4000
Four characters with the
multiplier used as the
decimal holder.
30 Mohm = 30M0
100 Mohm = 100M
1.2 Gohm = 1G20
www.seielect.com
很抱歉,暂时无法提供与“HMC0603KT200M”相匹配的价格&库存,您可以联系我们找货
