RGC Series
Stackpole Electronics, Inc.
Semi-Precision Thick Film Chip Resistor
Resistive Product Solutions
Features:
Precision performance
Highly stable performance over time
Tolerances of 0.1% may be available - contact Stackpole for details
Temperature coefficient of resistance as low as ± 50 ppm/ºC
RoHS compliant and halogen free
REACH compliant
0402 and 0603 package sizes are qualified to AEC-Q200
Electrical Specifications
Power Rating (W)
@ 70ºC
Maximum
Working
Voltage (V) (1)
Maximum
Overload
Voltage (V)
TCR
(ppm/ºC)
0.1%
0.5%
1%
RGC0201
0.05
25
50
± 200
10 - 10M
RGC0402
0.063
50
100
± 50
± 100
10 - 1M
± 200
1.02M - 10M
± 50
10 - 1M
± 100
± 200
± 50
10 - 1M
Type / Code
RGC0603
RGC0805
RGC1206
0.1
0.125
0.25
0.25
RGC1210
RGC2010
0.33
0.75
75
150
150
300
200
400
200
200
200
RGC2512
1
± 50
10 - 1M
100 - 1M
1 - 1M
10 - 10M
10 - 1M
1.02M - 10M
1 - 10M
10 - 10M
10 - 1M
1.02M - 10M
1 - 10M
10 - 10M
10 - 1M
1.02M - 10M
± 100
10 - 1M
400
± 50
± 100
± 200
± 50
± 100
10 - 1M
± 200
1.02M - 10M
± 100
± 50
10 - 1M
1 - 9.76
500
1 - 9.76
10 - 10M
10 - 1M
10 - 10M
1.02M - 10M
1 - 10M
10 - 10M
10 - 1M
10 - 10M
10 - 1M
± 100
± 200
1 - 10M
400
400
250
± 100
± 200
± 100
± 200
400
200
Ohmic Range (Ω) and Tolerance
10 - 10M
1.02M - 10M
Note: (1) Lesser of √ P*R or maximum working voltage
Mechanical Specifications
Type / Code
Weight (g)
(1000 pc.)
RGC0201
0.150
L
Body Length
0.024 ± 0.001
0.60 ± 0.03
W
Body Width
0.012 ± 0.001
0.30 ± 0.03
Rev Date: 04/22/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
H
Body Height
0.009 ± 0.001
0.23 ± 0.03
a
Top Termination
0.006 ± 0.002
0.15 ± 0.05
b
Bottom Termination
0.006 ± 0.002
0.15 ± 0.05
Unit
inches
mm
www.seielect.com
marketing@seielect.com
RGC Series
Mechanical Specifications (cont.)
Type / Code
Weight (g)
(1000 pc.)
RGC0402
0.620
RGC0603
2.042
RGC0805
4.368
RGC1206
8.947
RGC1210
15.959
RGC2010
24.241
RGC2512
39.448
L
Body Length
0.039 ± 0.004
1.00 ± 0.10
0.063 ± 0.004
1.60 ± 0.10
0.079 ± 0.004
2.00 ± 0.10
0.122 ± 0.006
3.10 ± 0.15
0.126 ± 0.010
3.20 ± 0.25
0.197 ± 0.008
5.00 ± 0.20
0.250 ± 0.008
6.35 ± 0.20
W
Body Width
0.020 ± 0.002
0.50 ± 0.05
0.031 ± 0.004
0.80 ± 0.10
0.049 ± 0.004
1.25 ± 0.10
0.061 ± 0.004
1.55 ± 0.10
0.102 ± 0.006
2.60 ± 0.15
0.098 ± 0.006
2.50 ± 0.15
0.124 ± 0.008
3.15 ± 0.20
H
Body Height
0.012 ± 0.004
0.30 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
0.020 ± 0.004
0.50 ± 0.10
0.024 ± 0.006
0.60 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.004
0.55 ± 0.10
a
Top Termination
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.010
0.40 ± 0.25
0.020 ± 0.010
0.50 ± 0.25
0.020 ± 0.010
0.50 ± 0.25
0.024 ± 0.010
0.60 ± 0.25
0.024 ± 0.010
0.60 ± 0.25
b
Bottom Termination
0.010 ± 0.006
0.25 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.008
0.50 ± 0.20
0.024 ± 0.012
0.60 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test
Test Specification
± 1% and below
Temperature Coefficient of
Resistance
As specified.
Short Time Overload
±(1% + 0.05Ω)
Insulation resistance
≥ 10G
Endurance
±(1% + 0.1Ω)
Damp Heat with Load
±(1% + 0.1Ω)
Dry Heat
±(1% + 0.05Ω)
Bending Strength
±(1% + 0.05Ω)
Solderability
95% minimum coverage
Resistance to Soldering Heat
±(0.5% + 0.05Ω)
Voltage Proof
No breakdown or flashover
2
Test Method
JIS-C-5201-1 4.8
IEC-60115-1 4.8
-55°C +125°C, 25°C is the reference temperature
JIS-C-5201-1 4.13
IEC-60115-1 4.13
RCWV*2.5 or max. overload voltage whichever
is lower for 5 seconds;
2 seconds for high power series
JIS-C-5201-1 4.6
IEC-60115-1 4.6
Max. overload voltage for 1 minute
JIS-C-5201-1 4.25
IEC-60115-1 4.25.1
70 ± 2°C, RCWV for 1000 hours with 1.5 hours
"ON" and 0.5 hour "OFF"
JIS-C-5201-1 4.24
IEC-60115-1 4.24
40 ± 2°C, 90 ~ 95% R.H., RCWV for 1000 hours
with 1.5 hour "ON" and 0.5 hour "OFF"
JIS-C-5201-1 4.23
IEC-60115-1 4.23.2
at +125 / +155°C for 1000 hours
JIS-C-5201-1 4.33
IEC-60115-1 4.33
Bending once for 5 seconds
2010, 2512 sizes: 2 mm; other sizes: 3 mm
JIS-C-5201-1 4.17
IEC-60115-1 4.17
245 ± 5°C for 3 seconds
JIS-C-5201-1 4.18
IEC-60115-1 4.18
260 ± 5°C for 10 seconds
JIS-C-5201-1 4.7
IEC-60115-1 4.7
1.42 times max. operating voltage for 1 minute
www.seielect.com
RGC Series
Performance Characteristics (cont.)
Test
Test Specification
± 1% and below
Individual leaching area ≤ 5%
Total leaching area ≤ 10%
Test Method
JIS-C-5201-1 4.18
IEC-60068-2-58 8.2.1
260 ± 5°C for 30 seconds
JIS-C-5201-1 4.19
Rapid Change of Temperature
±(0.5% + 0.05Ω)
IEC-60115-1 4.19
-55°C to +125 / +155°C, 5 cycles
RCWV (Rated Continuous Working Voltage) = √ P*R or max. operating voltage whichever is lower
Storage temperature: 25 ± 3ºC; humidity < 80% RH
Operating temperature range for 0201 is -55°C to +125°C
Operating temperature range for 0402 - 2512 is -55°C to 155°C
Leaching
Power Derating Chart:
Recommended Pad Layout
Type / Code
RGC0201
RGC0402
RGC0603
RGC0805
RGC1206
a
b
c
Unit
0.012
0.30
0.020
0.50
0.035
0.90
0.047
1.20
0.079
2.00
0.010
0.25
0.018
0.45
0.024
0.60
0.028
0.70
0.035
0.90
0.012
0.30
0.024
0.60
0.035
0.90
0.051
1.30
0.063
1.60
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
3
www.seielect.com
RGC Series
Recommended Pad Layout (cont.)
Soldering Profiles
(1) Time of IR reflow soldering at maximum temperature point 260ºC : 10 seconds
(2) Time of wave soldering at maximum temperature point 260ºC : 10 seconds
(3) Time of soldering iron at maximum temperature point 410ºC : 5 seconds
Packaging Specifications
4
www.seielect.com
很抱歉,暂时无法提供与“RGC0402FTD10R0”相匹配的价格&库存,您可以联系我们找货
