RMCS Series
Stackpole Electronics, Inc.
Sulfur Resistant Thick Film Chip Resistor
Resistive Product Solutions
Features:
Inner terminations engineered to deter sulfur contamination
Non-standard resistance values available
Zero ohm available (max. resistance 0.05Ω)
“-HP” denotes high power
RoHS compliant and halogen free
REACH compliant
Electrical Specifications
Maximum
Overload
0.05
Maximum
Working
Voltage (V)(1)
25
Voltage (V)(2)
50
Maximum
Current
Jumper (A)
1
RMCS0402
0.063
50
100
1
RMCS0603
0.1
75
150
1
RMCS0805
0.125
150
300
2
RMCS1206
0.25
200
400
2
RMCS1210
0.33
200
400
2.5
RMCS2010
0.75
200
400
3.5
RMCS2512
1
250
500
4
Type/Code
Power Rating
(W) @ 70ºC
RMCS0201
TCR (ppm/ºC)
± 200
± 200
± 100
± 200
± 200
± 100
± 200
± 200
± 100
± 200
± 200
± 100
± 200
± 200
± 100
± 200
± 200
± 100
± 200
± 200
± 100
± 200
Ohmic Range (Ω) and Tolerance
0.5%
1%
5%
1 - 10M
1 - 9.76
10 - 1M
1.02M - 10M
1 - 9.76
10 - 1M
1.02M - 10M
1 - 9.76
10 - 1M
1.02M - 10M
1 - 9.76
10 - 1M
1.02M - 10M
1 - 9.76
10 - 1M
1.02M - 10M
1 - 9.76
10 - 1M
1.02M - 10M
1 - 9.76
10 - 1M
1.02M - 10M
(1) Lesser of √ P*R or maximum working voltage, whichever is lower.
(2) 2.5* √ P*R or Max. Overload Voltage listed above, whichever is lower.
Electrical Specifications – High Power
Power Rating (W) Maximum Working Maximum Overload
Type/Code
TCR (ppm/ºC)
@ 70ºC
Voltage (V)(1)
Voltage (V)(2)
RMCS0201_-HP
0.083
25
50
± 200
± 200
RMCS0402_-HP
0.1
50
100
± 100
± 200
RMCS0603_-HP
0.25
75
150
± 100
± 200
RMCS0805_-HP
0.33
150
300
± 100
± 200
RMCS1206_-HP
0.5
200
400
± 100
± 200
RMCS1210_-HP
0.75
200
400
± 100
± 200
RMCS2010_-HP
1
200
400
± 100
± 400
RMCS2512_-HP
2
200
400
± 100
(3) 0.5% tolerance for 0603 and 0805 requires lower power rating. Contact Stackpole for details.
Rev Date: 1/12/2023
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
1%
5%
0.5%(3)
10 - 1M
1 - 9.76
10 - 1M
10 - 1M
1 - 9.76
10 - 1M
10 - 1M
1 - 9.76
10 - 1M
10 - 1M
1 - 9.76
10 - 1M
10 - 1M
1 - 9.76
10 - 1M
10 - 1M
1 - 9.76
10 - 1M
10 - 1M
1 - 9.76
10 - 1M
10 - 10M
www.seielect.com
marketing@seielect.com
RMCS Series
Mechanical Specifications
Type/Code
Weight (g)
(1000 pieces)
RMCS0201
0.15
RMCS0402
0.62
RMCS0603
2.042
RMCS0805
4.368
RMCS1206
8.947
RMCS1210
15.959
RMCS2010
24.241
RMCS2512
39.448
RMCS2512_-HP
39.448
L
Body Length
0.024 ± 0.001
0.60 ± 0.03
0.039 ± 0.006
1.00 ± 0.15
0.063 ± 0.008
1.60 ± 0.20
0.079 ± 0.008
2.00 ± 0.20
0.122 ± 0.006
3.10 ± 0.15
0.122 ± 0.006
3.10 ± 0.15
0.197 ± 0.008
5.00 ± 0.20
0.248 ± 0.008
6.30 ± 0.20
0.248 ± 0.008
6.30 ± 0.20
W
Body Width
0.012 ± 0.001
0.30 ± 0.03
0.020 ± 0.002
0.50 ± 0.05
0.031 ± 0.004
0.80 ± 0.10
0.049 ± 0.006
1.25 ± 0.15
0.061 ± 0.010
1.55 ± 0.25
0.102 ± 0.012
2.60 ± 0.30
0.098 ± 0.008
2.50 ± 0.20
0.124 ± 0.008
3.15 ± 0.20
0.126 ± 0.008
3.20 ± 0.20
H
Body Height
0.009 ± 0.001
0.23 ± 0.03
0.014 ± 0.004
0.35 ± 0.10
0.018 ± 0.006
0.45 ± 0.15
0.020 ± 0.006
0.50 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.004
0.55 ± 0.10
0.022 ± 0.006
0.55 ± 0.15
0.024 ± 0.008
0.60 ± 0.20
a
Top Termination
0.006 ± 0.002
0.15 ± 0.05
0.008 ± 0.006
0.20 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.014 ± 0.008
0.35 ± 0.20
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.010
0.50 ± 0.25
0.024 ± 0.010
0.60 ± 0.25
0.024 ± 0.010
0.60 ± 0.25
0.024 ± 0.012
0.60 ± 0.30
b
Bottom Termination
0.006 ± 0.002
0.15 ± 0.05
0.008 ± 0.006
0.20 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.016 ± 0.008
0.40 ± 0.20
0.020 ± 0.008
0.50 ± 0.20
0.020 ± 0.008
0.50 ± 0.20
0.020 ± 0.012
0.50 ± 0.30
0.022 ± 0.010
0.55 ± 0.25
0.024 ± 0.012
0.60 ± 0.30
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test
Short Time Overload
Insulation Resistance
Endurance
Damp Heat with Load
Dry Heat
Bending Strength
Solderability
Resistance to
Soldering Heat
Voltage Proof
Leaching
Rapid change of
Temperature
Test Method
JIS-C-5201-1 4.13
IEC-60115-1 4.13
±1% and below
± (1% + 0.05Ω)
Test Specification
±5%
± (2% + 0.05Ω)
JIS-C-5201-1 4.6
≥10G
IEC-60115-1 4.6
JIS-C-5201-1 4.25
± (2% + 0.1Ω)
± (3% + 0.1Ω)
IEC-60115-1 4.25.1
JIS-C-5201-1 4.24
± (2% + 0.1Ω)
± (3% + 0.1Ω)
IEC-60115-1 4.24
JIS-C-5201-1 4.23
± (1% + 0.05Ω)
± (1.5% + 0.1Ω)
IEC-60115-1 4.23.2
JIS-C-5201-1 4.33
± (1% + 0.05Ω)
± (1% + 0.05Ω)
IEC-60115-1 4.33
JIS-C-5201-1 4.17
95% minimum coverage
IEC-60115-1 4.17
JIS-C-5201-1 4.18
± (0.5% + 0.05Ω) ± (1% + 0.05Ω)
IEC-60115-1 4.18
JIS-C-5201-1 4.7
No breakdown or flashover
IEC-60115-1 4.7
JIS-C-5201-1 4.18
Individual leaching area ≤ 5%
IEC-60068-2-58 8.2.1
Total leaching area ≤ 10%
JIS-C-5201-1 4.19
IEC-60115-1 4.19
Sulfur Test
ASTM-B-809-95
± (0.5% + 0.05Ω) ± (0.5% + 0.05Ω)
Jumper
< 50mΩ
Test Condition
RCWV*2.5 or Max. Overload Voltage whichever
is lower for 5 seconds,
2 seconds for high power series.
Max. Overload Voltage for 1 minute
< 100mΩ
< 100mΩ
70ºC ± 2ºC, RCWV for 1000 hours with
1.5 hours "ON" and 0.5 hour "OFF"
40ºC ± 2ºC, 90~95% R.H., RCWV for 1000 hours
with 1.5 hours "ON" and 0.5 hour "OFF"
< 50mΩ
At +125ºC/+155ºC for 1000 hours
< 50mΩ
Bending once for 5 seconds
2010, 2512 sizes: 2 mm / Other sizes: 3 mm
245ºC ± 5ºC for 3 seconds
< 50mΩ
260ºC ± 5ºC for 10 seconds
1.42 times Max. Operating Voltage for 1 minute
260ºC ± 5ºC for 30 seconds
< 50mΩ
-55ºC to +125ºC/+155ºC, 5 cycles
< 50mΩ
H2S, 50ºC ± 2ºC, 91~93% R.H.,
no power rating for 1000 hours
RCWV (Rated Continuous Working Voltage) = √ P*R or Max. Operating Voltage, whichever is lower.
Storage Temperature: 15ºC ~ 28ºC. Humidity < 80% R.H.
Operating temperature range is -55°C to +155°C
Rev Date: 1/12/2023
2
www.seielect.com
RMCS Series
Power Derating Curve:
Packaging Specifications – Paper Tape
Type/Code
RMCS0201
RMCS0402
RMCS0603
RMCS0805
RMCS1206
RMCS1210
L
± 0.002
± 0.05
± 0.006
± 0.15
± 0.010
± 0.25
± 0.010
± 0.25
± 0.008
± 0.20
± 0.010
± 0.25
P0
0.027
0.68
0.045
1.15
0.075
1.90
0.094
2.40
0.138
3.50
0.138
3.50
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.079
2.00
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
Type/Code
RMCS0201
RMCS0402
RMCS0603
RMCS0805
RMCS1206
RMCS1210
M
0.015
0.38
0.026
0.65
0.043
1.10
0.063
1.60
0.075
1.90
0.110
2.80
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
W
± 0.002
± 0.05
± 0.006
± 0.15
± 0.010
± 0.25
± 0.010
± 0.25
± 0.008
± 0.20
± 0.008
± 0.20
P1
Rev Date: 1/12/2023
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
3
E
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
± 0.008
± 0.20
P2
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
F
0.069 ± 0.004
1.75 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
ØD0
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
0.017
0.42
0.018
0.45
0.028
0.70
0.033
0.85
0.033
0.85
0.030
0.75
+0.004 / -0
+0.10 / -0
+0.004 / -0
+0.10 / -0
+0.004 / -0
+0.10 / -0
+0.004 / -0
+0.10 / -0
+0.004 / -0
+0.10 / -0
+0.004 / -0
+0.10 / -0
Unit
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
± 0.002
± 0.05
K1
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RMCS Series
Packaging Specifications – Embossed Plastic Tape
Type/Code
RMCS2010
RMCS2512
0.110
2.80
0.138
3.50
L
± 0.008
± 0.20
± 0.008
± 0.20
P0
0.217
5.50
0.264
6.70
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
Type/Code
RMCS2010
RMCS2512
0.004
0.10
0.004
0.10
M
± 0.008
± 0.20
± 0.008
± 0.20
P1
0.472
12.00
0.472
12.00
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
W
± 0.012
± 0.30
± 0.012
± 0.30
P2
0.002
0.05
0.002
0.05
E
0.069 ± 0.004
1.75 ± 0.10
0.069 ± 0.004
1.75 ± 0.10
ØD0
0.059 +0.004 / -0
1.50 +0.10 / -0
0.059 +0.004 / -0
1.50 +0.10 / -0
0.217
5.50
0.217
5.50
0.047
1.20
0.047
1.20
F
± 0.002
± 0.05
± 0.002
± 0.05
K2
Unit
inches
mm
inches
mm
Unit
inches
mm
inches
mm
Recommended Pad Layout
Type/Code
a
b
c
Unit
RMCS0201
0.012
0.30
0.010
0.25
0.012
0.30
inches
mm
0.024
0.60
0.035
0.90
0.051
1.30
0.087
2.20
0.079
2.00
0.150
3.80
0.193
4.90
0.020
0.50
0.031
0.80
0.031
0.80
0.039
1.00
0.035
0.90
0.035
0.90
0.063
1.60
0.028
0.70
0.039
1.00
0.055
1.40
0.067
1.70
0.110
2.80
0.110
2.80
0.138
3.50
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
RMCS0402
RMCS0603
RMCS0805
RMCS1206
RMCS1210
RMCS2010
RMCS2512
Rev Date: 1/12/2023
4
www.seielect.com
RMCS Series
Soldering Condition
(1) Time of IR reflow soldering at maximum temperature point 260°C: 10 seconds
(2) Time of wave soldering at maximum temperature point 260°C: 10 seconds
(3) Time of soldering iron at maximum temperature point 410°C: 5 seconds
Rev Date: 1/12/2023
5
www.seielect.com
RMCS Series
Rev Date: 1/12/2023
6
www.seielect.com
RMCS Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Package /
Termination
Type
Description
SMD
Surface Mount Chip Resistor
Note (1): RoHS Compliant by means of exemption 7c-I.
RMCS
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
YES(1)
100% Matte Sn over Ni
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
R
M
Product Series
Sulfur
Resistant
RMCS
C
Size
0201
0402
0603
0805
1206
1210
2010
2512
S
Power Rating (W)
RMCS
-HP
0.05
0.083
0.063
0.1
0.1
0.25
0.125
0.33
0.25
0.5
0.33
0.75
0.75
1
1
2
J
T
4
K
Tolerance
Packaging
Code Tol
Value
Code Description
Size
Quantity
D
0.5%
E96
0201, 0402 10000
7" Reel
F
1% E96, E24
0603, 0805
Paper Tape
5000
T
J
5%
E24
1206, 1210
Z
Jumper
7" Reel
2010, 2512 4000
Plastic Tape
Rev Date: 1/12/2023
7
7
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
1 ohm = 1R00
100 Kohm = 100K
1.02 Mohm = 1M02
Zero ohm jumper = 0R00
H
P
Special
Code Description
blank Standard
-HP High Power
www.seielect.com
很抱歉,暂时无法提供与“RMCS1210FT10R0”相匹配的价格&库存,您可以联系我们找货
