Document: W03010212, Rev: C
WS12P4N3
Transient Voltage Suppressor
Features
3250 Watts Peak Power (tp = 8/20μs)
Excellent Clamping Capability
Low Leakage Current
Working Voltages: 12V
DFN2020-3L
(bottom view)
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 130A (8/20μs)
Mechanical Characteristics
Applications
DFN2020-3L package
I/O Interfaces
Marking : Marking Code
Power lines
Packaging : Tape and Reel per EIA 481
Automotive and Telecommunication
RoHS Compliant
Computer & Consumer Electronics
Industrial Electronics
Microcontroller Input Protection
PIN Configuration
Pin3
Pin1、2
©2019 WAYON Corporation
www.way-on.com
1/5
WS12P4N3
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp = 8/20μs )
PPP
3250
Watts
Peak Pulse Current ( tp = 8/20μs )
IPP
130
A
Operating Temperature
TJ
-55 to + 125
TSTG
-55 to +150
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
Parameter
I
IPP
Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IF
Reverse Stand-Off Voltage
VC VBR VRWM
Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
V
IR VF
IT
IPP
Electrical Characteristics
WS12P4N3
Parameter
Reverse Breakdown Voltage
Symbol
Conditions
Minimum
Typical
VRWM
13.3
Maximum
Units
12
V
16
V
500
nA
25
V
VBR
IT=1mA
IR
VRWM=12V, T=25℃
Clamping Voltage1
VC
IPP=130A, tp=8/20μs
22
Dynamic Resistance2,3
RDYN
TLP=0.2/100ns
0.03
Ω
ESD Clamping Voltage1
VC
IPP = 4A,
tp = 0.2/100ns (TLP)
14.7
V
VC
IPP = 16A,
15
V
Junction Capacitance
Cj
VR =0V, f =1MHz
800
1000
pF
Note:1.Measured from pin 3 to pin 1& pin 2;
2.TLP Setting:tp=100ns, tr=0.2ns, ITLP and VTLP sample window:t1=70ns to t2=90ns;
3.Dynamic resistance calculated from IPP=4A to IPP=16A using “Best Fit”.
www.way-on.com
2/5
WS12P4N3
Typical Characteristics
Figure 2: Power Derating Curve
100
10
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power Vs Pulse Time
3250W 8/20µs
Waveform
1
110
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Ambient Temperature - TA (℃)
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
Figure 3: Clamping Voltage vs. Peak Pulse
Current
24
1.2
1
Cj(VR)/Cj(VR=0)
Clamping Voltage -Vc(V)
1.1
12
8
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
4
0.1
50
75
100
125
3
6
9
12
15
Reverse Voltage -VR(V)
Peak Pulse Current -Ipp(A)
Figure 6: TLP I-V Curve
Figure 5: 8/20µs Pulse Waveform
tr=8µs
110
80
70
60
50
40
Half Value Ipp/2
30
15
TLP Current (A)
Percent Ipp
90
Waveform
Paramters
tr=8µs
td=20µs
100
RDYN=0.03 Ohms
10
5
TLP
Parameters:
tp=100ns
tr=0.2ns
td=20µs
10
Time (µs)
5
10
15
TLP Voltage (V)
www.way-on.com
3/5
WS12P4N3
Soldering Parameters
Pb – Free assembly
Reflow Condition
Pre Heat
Temperature Min (Ts(min))
Temperature Max (Ts(max))
Time (min to max) (ts )
Average ramp up rate (Liquidus Temp) (TL) to peak
TS(max) to TL——Ramp-up Rate
Temperature (TL) (Liquidus)
Reflow
Temperature (tL)
Peak Temperature (TP)
150°C
200°C
60 – 190 secs
5°C/second max
5°C/second max
217°C
60 – 150 seconds
260+0/-5 °C
Time within actual peak Temperature (tp )
20 – 40 seconds
Ramp-down Rate
Time 25°C to peak Temperature (TP)
Do not exceed
5°C/second max
8 minutes Max.
280°C
Reflow Condition
www.way-on.com
4/5
WS12P4N3
Outline Drawing –DFN2020-3L
PACKAGE OUTLINE
D
b
b1
DFN2020-3L
L1
3
h
K
PIN1
SYMBOL
A
A1
b
b1
c
D
D2
e
E
E2
E3
L
L1
h
K
h
E3
E
E2
D2
L
(laser mark)
1
b1 2
2
e
1
b
TOP VIEW
A1
c
A
BOTTOM VIEW
SIDE VIEW
MILIMETER
NOM
MAX
0.55
0.60
0.02
0.05
0.30
0.35
0.20REF
0.152REF
1.90
2.00
2.10
1.40
1.50
1.60
1.30BSC
1.90
2.00
2.10
0.95
1.05
1.15
0.20
0.30
0.40
0.35
0.40
0.45
0.20
0.25
0.30
0.20REF
0.20
0.30
0.40
MIN
0.45
0.00
0.25
Land Pattern
0.5 0.3
0.5 0.3
1.2
1.8
1.3
0.5
0.5
Marking Codes
Marking Code
Part Number
3
WS12P4N3
M12A
XXXX
1
2
Package Information
Qty:3k/Reel
CONTACT INFORMATION
Shanghai Wayon Semiconductor Co.,Ltd
No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207
Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com
WAYON website: http://www.way-on.com
For additional information, please contact your local Sales Representative.
® is registered trademark of Wayon Corporation.
Specifications are subject to change without notice.
The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time.
Users should verify actual device performance in their specific applications.
www.way-on.com
5/5
很抱歉,暂时无法提供与“WS12P4N3”相匹配的价格&库存,您可以联系我们找货
