HMC-T2220
HMC-T2220
    AD(亚德诺)
    SIGNAL GENERATOR 20GHZ 1CH
HMC-T2220 数据手册
Analog Devices Welcomes Hittite Microwave Corporation NO CONTENT ON THE ATTACHED DOCUMENT HAS CHANGED www.analog.com www.hittite.com THIS PAGE INTENTIONALLY LEFT BLANK HMC-T2220 Synthesized Signal Generator, 10 MHz to 20 GHz 2 Elizabeth Drive, Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.tm-hittite.com Instrumentation Product Support at TE@hittite.com HMC-T2220 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz v06.0714 Wide Frequency Range, 10 MHz to 20 GHz Signal Generator! The HMC-T2220 is an easy to implement test equipment solution designed to fulfill your signal generation needs. Built on a foundation of high quality and market leading Hittite MMICs, the HMC-T2220 provides the highest output power, lowest harmonic levels and broadest frequency range amongst signal generators of its size and cost. This compact and lightweight signal generator also features USB, GPIB and Ethernet interfaces ensuring carefree integration within various test environments while improving overall productivity and equipment utilization. The HMC-T2220 incorporates several product upgrades: reduced spurious, wider dynamic range, higher frequency resolution, higher RF output power, reduced RF off leakage, quieter fan operation, improved front panel knob functions for display scrolling, a ruggedized handle that is customer removable, and an added TRIGGER OUT function. Synthesized Signal Generator Applications 2  ATE  Test & Measurement  R&D Laboratories Advantages  Versatile: Higher Drive Simplifies Test Set-Ups  Efficient: 300 µs Frequency Switching  Reliable: Incorporates Hittite MMICs  Flexible: Manual or Software Control Via USB, GPIB or Ethernet Performance  High Output Power: +26 dBm @ 1 GHz  Wide Frequency Range: 10 MHz to 20 GHz  Excellent Phase Noise Performance: -98 dBc/Hz @ 10 kHz Offset @ 10 GHz  Spurious Rejection: -70 dBc @ 10 GHz  Power Resolution: 0.1 dB  Frequency Resolution: 1 Hz 2 Elizabeth Drive • Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.tm-hittite.com Instrumentation Product Support at TE@hittite.com HMC-T2220 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz Frequency Output Power Range @ 25°C Accuracy: As Per Internal Ref. ±1.5 ppm Resolution: 1 Hz Internal Reference: 10 MHz Aging Rate: 60 dB Resolution: 0.1 dB Power Accuracy: ± 1 dB > 500 MHz ± 2 dB ≤ 500 MHz ± 2 dB < -20 dBm (All Frequencies) RF Off: < -80dBm 0.01 0.05 0.1 0.5 1 2 5 10 15 20 10 -60 -80 -100 -120 -140 -160 10 1 10 2 10 3 10 4 10 5 10 6 10 7 10 8 OFFSET FREQUENCY (Hz) 10 MHz 50 MHz 100 MHz 1 GHz 5 GHz 10 GHz 15 GHz 20 GHz RF Output Impedance VSWR < 2.0:1 SSB Phase Noise (dBc/Hz) 2nd Harmonics (dBc) -34 -30 -31 -34 -33 -43 -32 -34 -39 -55 3rd Harmonics (dBc) -44 -42 -46 -55 -52 -57 -54 -58 -48 - Offset From Carrier Frequency (GHz) 10 Hz 100 Hz 1 kHz 0.01 0.05 0.10 0.50 1 5 10 15 20 -87 -86.4 -86 -82 -77 -64 -58 -56 -51 -97 -96.2 -97 -95 -89 -75 -69 -66 -63 -106 -106 -107 -119 -113 -99 -92 -89 -86 10 kHz 100 kHz 1 MHz 10 MHz -113 -112 -114 -125 -119 -105 -98 -95 -92 -107 -108 -108 -125 -119 -105 -99 -94 -93 Output Noise: Floor < -155 dBc/Hz Output Power = +10 dBm -126 -128 -129 -139 -135 -124 -118 -111 -112 -140 -140 -143 -143 -144 -145 -143 -134 -137 Synthesized Signal Generator Frequency (GHz) 0.01 0.05 0.1 0.5 1 2 4 10 15 20 20 -40 (Maximum) SSB PHASE NOISE (dBc/Hz) Output Power Frequency (GHz) v06.0714 Above data is typical performance at +25°C after 30 minutes of warm-up time unless otherwise stated. 2 Elizabeth Drive • Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.tm-hittite.com Instrumentation Product Support at TE@hittite.com 3 HMC-T2220 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz General Specifications Frequency: Accuracy: For < 2.5 GHz, Reference +0/-90 nHz For > 2.5 GHz, Reference +0/-2.88 uHz Internal Reference: ±1.5 ppm Resolution: 1 Hz Aging Rate:
HMC-T2220 价格&库存
很抱歉,暂时无法提供与“HMC-T2220”相匹配的价格&库存,您可以联系我们找货
