HMC-T2240
HMC-T2240
    AD(亚德诺)
    SIGNAL GENERATOR 40GHZ 1CH
HMC-T2240 数据手册
Analog Devices Welcomes Hittite Microwave Corporation NO CONTENT ON THE ATTACHED DOCUMENT HAS CHANGED www.analog.com www.hittite.com THIS PAGE INTENTIONALLY LEFT BLANK HMC-T2240 Synthesized Signal Generator, 10 MHz to 40 GHz 2 Elizabeth Drive • Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.tm-hittite.com Instrumentation Product Support at TE@hittite.com HMC-T2240 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 40 GHz v09.0714 Wide Frequency Range, 10 MHz to 40 GHz Signal Generator! The HMC-T2240 is an easy to implement test equipment solution designed to fulfill your signal generation needs. Built on a foundation of high quality and market leading Hittite MMICs, the HMC-T2240 provides the highest output power, lowest harmonic levels and broadest frequency range amongst signal generators of its size and cost. This compact and lightweight signal generator also features USB, GPIB and Ethernet interfaces ensuring carefree integration within various test environments while improving overall productivity and equipment utilization. Applications  ATE  Test & Measurement Synthesized Signal Generator  R&D Laboratories 2 Advantages  Versatile: Higher Drive Simplifies Test Set-Ups  Efficient: 500 µs Frequency Switching  Reliable: Incorporates Hittite MMICs  Flexible: Manual or Software Control Via USB, GPIB or Ethernet Performance  High Output Power: +27 dBm @ 1 GHz  Wide Frequency Range: 10 MHz to 40 GHz  Excellent Phase Noise Performance: -98 dBc/Hz @ 10 kHz Offset @ 10 GHz  Spurious Rejection: -70 dBc @ 10 GHz  Power Resolution: 0.1 dB  Frequency Resolution: 1 Hz 2 Elizabeth Drive • Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.tm-hittite.com Instrumentation Product Support at TE@hittite.com HMC-T2240 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 40 GHz Frequency v09.0714 Output Power Range @ 25°C Accuracy: As Per Internal Ref. ±1.5 ppm Resolution: 1 Hz Internal Reference: 10 MHz Aging Rate: 60 dB Resolution: 0.1 dB Power Accuracy: ± 1 dB > 500 MHz ± 2 dB ≤ 500 MHz ± 2 dB < -20 dBm (All Frequencies) RF OFF < -70 dBm -40 -60 -80 -100 -120 -140 -160 1e+1 1e+2 1e+3 1e+4 1e+5 1e+6 1e+7 OFFSET FREQUENCY (Hz) 10 MHz 100 MHz 500 MHz 1 GHz 5 GHz 10 GHz Spurious @ 10 dBm Output 15 GHz 20 GHz 25 GHz 30 GHz 40 GHz < -70 dBc @ Integer Frequencies < -65 dBc @ Fractional Frequencies 20 GHz Harmonics Frequency (GHz) 0.01 0.05 0.1 0.5 1 2 5 10 15 20 25 SSB Phase Noise (dBc/Hz) 2nd Harmonics (dBc) -37 -30 -30 -35 -34 -30 -32 -34 -47 -55 -35 Output Power = +10 dBm 3rd Harmonics (dBc) -45 -42 -40 -58 -52 -48 -58 -68 -75 - Offset From Carrier Frequency (GHz) 10 Hz 100 Hz 1 kHz 0.01 0.10 0.50 1 5 10 15 20 25 30 40 -85 -88 -83 -79 -64 -57 -54 -52 -51 -50 -48 -95 -97 -95 -89 -76 -71 -66 -64 -61 -60 -57 -105 -106 -118 -112 -98 -93 -88 -86 -83 -83 -81 10 kHz 100 kHz 1 MHz 10 MHz -112 -114 -124 -118 -104 -98 -94 -92 -89 -88 -86 -107 -108 -124 -119 -105 -99 -94 -93 -87 -87 -87 Output Noise: Floor < -150 dBc/Hz 10 MHz to 20 GHz -126 -128 -139 -135 -124 -118 -111 -112 -102 -106 -107 -140 -142 -142 -144 -145 -142 -134 -137 -126 -128 -130 Synthesized Signal Generator Output Power 40 < -140 dBc/Hz 20 GHz to 40 GHz Above data is typical performance at +25°C after 30 minutes of warm-up time unless otherwise stated. 2 Elizabeth Drive • Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.tm-hittite.com Instrumentation Product Support at TE@hittite.com 3 HMC-T2240 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 40 GHz General Specifications Frequency: Accuracy: For < 2.5 GHz, Reference +0/-90 nHz For > 2.5 GHz, Reference +0/-2.88 uHz Internal Reference: ±1.5 ppm Resolution: 1 Hz Aging Rate:
HMC-T2240 价格&库存
很抱歉,暂时无法提供与“HMC-T2240”相匹配的价格&库存,您可以联系我们找货
