440K-T11279
440K-T11279
    ALLEN-BRADLEY
    440K-T11279 - Tongue Switches - Allen-Bradley
440K-T11279 数据手册
Interlock Switches Tongue Switches Trojan T15 Specifications Standards EN954-1, ISO13849-1, IEC/EN60204-1, NFPA79, EN1088, ISO14119, IEC/ EN60947-5-1, ANSI B11.19, AS4024.1 Cat. 1 Device per EN954-1 Dual channel interlocks suitable for Cat. 3 or 4 systems CE marked for all applicable directives, cULus and TUV Nord 2 N.C. or 1 N.C. direct opening action 600V 1.2A 600V 0.4A 500V 240V 120V 1.4A 3A 6A 500V 250V 125V 0.55A 1.1A 2.2A Category Approvals Safety Contacts Designation/Utilization Cat. A600/AC-15 (Ue) (Ie) N600/DC-13 (Ue) (Ie) Description The Trojan T15 is a compact universal tongue actuated safety interlock switch designed to fit at the opening edge of sliding, hinged or lift-off guards. With its dual entry slots and rotatable head, movable only by releasing the cover screws, the Trojan T15 can offer four different options for actuator entry. The Trojan T15 features a compact housing, only 75 x 52 x 32mm (2.95 x 2.04 x 1.25in) and includes direct opening action contacts and a tamper-resistant mechanism. The Trojan T15 has 2 N.C. safety contacts or 1 N.C. safety contact and 1 N.O. auxiliary contact. The unit is sealed to IP67 and has three M20 conduit entries. Operation of the switch is achieved by the insertion of the specially profiled stainless steel actuator which should be permanently fixed to the leading edge of the guard door. The standard T15 incorporates actuator retention force of 30N. An optional catch mechanism helps keep doors shut on vibrating machinery. Max. Switched Current/ Voltage/Load Thermal Current (lth) Min Current Safety Contact Gap Rtd. Insulation Voltage Auxiliary Contacts Pollution Degree ➊ Actuator Travel for Positive Opening Min Operating Radius Break Contact Min Force Max Actuation Speed Max Actuation Frequency Case Material Actuator Material Protection Conduit Entry Operating Temperature Fixing Mounting Mechanical Life Electrical Life Weight Colour 500V/500VA 10A 5V 5mA DC >2 x 2mm (0.078in) (Ui) 500V 1 N.O. 3 6mm (0.236in) 175mm (6.89in) 60mm (2.36in) with flexible actuator 30N (6.7lb) 160mm (6.29) per sec 2 Cycle per sec UL approved glass filled polybutylene terephthalate Stainless Steel IP67 3 x M20 or quick disconnect style -20°C to +80°C (-4°F to +176°F) 2 x M5 Any position 1,000,000 operations 1,000,000 operations 120g (0.265lbs) Red Rtd. Impulse Withstand Volt. (Uimp) 2500V Features • • • • • Compact size, 75 x 52 x 32mm (2.95 x 2.05 x 1.26in) case 30N actuator retention force Strong and versatile, can be used in most applications Contacts: 2 N.C. safety or 1 N.C. safety & 1 N.O. auxiliary GD2 style available for demanding applications ➊ Conductive pollution occurs, or dry, non conductive pollution occur which becomes conductive due to condensation. Applications Note: Lift-off guards require good alignment when using tongue actuated interlock switches. IMPORTANT: It must not be possible to lift the guard without actuating the interlock. An interlock on either side may be required. 3-10 Interlock Switches Tongue Switches Trojan T15 Product Selection Contacts Model Type Safety Aux. Actuator Standard 2 N.C. Standard 1 N.C. 1 N.O. — Fully-Flex — Standard Fully-Flex — Standard 2 N.C. GD2 Front Entry 1 N.C. 1 N.O. — Fully-Flex — Standard Fully-Flex — Standard 440K-T11303 440K-T11395 440K-T11269 440K-T11305 440K-T11396 440K-T11270 440K-T11463 440K-T11397 440K-T11280 440K-T11398 440K-T11399 440K-T11279 M20 Conduit 1/2in NPT Adaptor 440K-T11267 440K-T11273 — 440K-T11268 440K-T11276 — 440K-T11288 440K-T11287 — 440K-T11284 440K-T11283 — Quick Disconnect End Entry 440K-T11307 440K-T11384 440K-T11385 440K-T11386 440K-T11387 440K-T11388 440K-T11389 440K-T11390 440K-T11391 440K-T11392 440K-T11393 440K-T11394 Recommended mating cable, 2m (6.5ft). See page 15-10 for details and additional lengths. 889D-F4AC-2 Accessories Description For Dimensions See Page Catalogue Number Standard Actuator (Standard model only) 14-5 440K-A11238 GD2 Standard Actuator (GD2 model only) 14-4 440G-A27011 Flat Actuator 14-5 440K-A11112 3-11 Interlock Switches Tongue Switches Trojan T15 Accessories (continued) Description For Dimensions refer to page Catalogue Number Alignment Guide with Semi-Flexible Actuator (Discard the Alignment Guide for GD2) 14-5 440K-A11144 Alignment Guide with Fully-Flexible Actuator (Discard the Alignment Guide for GD2) 14-6 440K-A27010 Sliding Bolt Actuator 14-4 440G-A27163 Catch and Retainer Kit (Standard Model Only) 14-4 440K-A11094 Optional Items Alignment Guide and Flexible Actuator Catch and Retainer Used to keep guards on vibrating machinery closed. The quick-disconnect option allows a quick connection facility. Plug In Connection For use with flexible actuator 15° flexibility in any direction 3-12 Interlock Switches Tongue Switches Trojan T15 Approximate Dimensions—mm (inches) Dimensions are not intended to be used for installation purposes. 20.5 (0.81) 52 40 (1.57) (2.05) 5.5 (0.22) Fixing holes for M5 screws 5 (0.2) GD2 Guides 5 (0.2) 32 (1.26) 15 (0.59) 16 (0.62) 33.4 (1.31) 41 (1.61) 75 (2.95) 5.5 (0.22) 31 (1.22) 13 (0.51) 20.5 (0.81) 15.75 (0.62) Typical Wiring Diagrams (shown with guard closed, actuator inserted) 1 N.C. + 1 N.O. (BBM) 2 N.C. 23 24 11 12 21 22 11 12 1 N.C. + 1 N.O. Connector Pinout 1 Terminal 11 N.C. 12 23 N.O. 4 24 1 N.C. & 1 N.O. (BBM) 20 11/12 23/24 15 10 6 0mm 20 11/12 21/22 15 2 N.C. Terminal 11 N.C. 12 21 N.C. 22 2 N.C. 10 6 0mm Contact Contact 2 3 1 4 3 2 Contact Action Contact Open Contact Closed Actuator withdrawal distance from full insertion 6.5 3-13
440K-T11279
物料型号: - Trojan T15
器件简介: - Trojan T15是一款紧凑型通用舌动安全联锁开关,设计用于安装在滑动、铰接或可拆卸式防护罩的开口边缘。具有双入口槽和可旋转头部,仅在松开盖板螺丝后可移动,提供四种不同的执行器入口选项。
引脚分配: - Trojan T15具有2个常闭安全接触点或1个常闭安全接触点和1个常开辅助接触点。
参数特性: - 尺寸:75 x 52 x 32mm(2.95 x 2.04 x 1.25in) - 执行器保持力:30N - 密封等级:IP67 - 导线入口:三个M20或快速断开式 - 操作温度:-20°C至+80°C(-4°F至+176°F) - 安装:任意位置 - 机械寿命:100万次操作 - 电气寿命:100万次操作 - 重量:120g(0.265lbs) - 颜色:红色
功能详解: - 通过插入特殊剖面的不锈钢执行器来操作开关,该执行器应永久固定在防护罩门的前沿。 - 标准T15包含执行器保持力为30N。 - 可选的锁定机制有助于在振动机械上保持门关闭。
应用信息: - 使用舌动联锁开关时,需要确保防护罩的良好对齐。重要的是,不能在不激活联锁的情况下提起防护罩。可能需要任一侧的联锁。
封装信息: - 材料:UL认证的玻璃填充聚对苯二甲酸丁二醇酯 - 执行器材料:不锈钢 - 固定:2xM5
440K-T11279 价格&库存
很抱歉,暂时无法提供与“440K-T11279”相匹配的价格&库存,您可以联系我们找货
