Telaire
Accessories
Calibration Kits,
Enclosures, Software,
Cables
Calibration Kits
The Calibration Kit Model T2075NG includes all of the
necessary components for calibrating the Telaire® 7001
and Ventotstat 8000 and 8100 series models. The kit is
housed in a carrying case with only one replacement
part (calibration gas (not supplied)) required. A 16
liter gas bottle (not supplied) can perform up to 20
calibrations. Calibration Kit Model T2076NG calibrates
the Vaporstat 9002.
Accessory Enclosures
Telaire offers four enclosures to expand the Ventostat
and Vaporstat installation options: Model T1508
Aspiration Box, Model T1505 Splash Resistant
Enclosure, and Model T1551 and T1552 Outdoor Air
Enclosures.
Software
Windows based VG Graphing Software allows you
to easily download your IAQ measurements and
customize graphs.
Amphenol
Advanced Sensors
2080 CO2 View Logging Software
CO2 View is a Windows based program that interfaces
with the 7000 series. This easy to use program displays
and graphs real-time CO2 levels at a user adjustable
interval.
UIP T2090
Modify your 8000 series (T8100, T8200, T8300).
7001 Accessories
The Telaire 7001 hand held CO2 and temperature
monitor is equipped with an output for recording data.
The cable, Model T2070, can be used with devices that
accept a 0 to 4V signal.
A relative humidity and datalogging kit with graphing
software, Model T2077, is available for long term
monitoring.
Part 62933 is an adapter for international operation.
Calibration Kits
T2075NG and T2076NG
Calibration Process
The calibration is simple and can be done in just a few
minutes. Each CO2 model has a calibration process
similar to the following:
• Connect the tubing assembly to the sensor and
connect the regulator to the gas bottle.
• Initiate the calibration process by using the sensor
buttons and display.
• The process is automatically run by the sensor and
will signal upon completion.
• Last, disconnect the tubing and gas regulator.
T2075NG Components
The Calibration Kit Model T2075NG includes:
• Instruction sheet
• Tubing assembly
• Gas regulator with gauge
• Carrying case.
The illustration shows the complete set-up
for calibrating a sensor with display.
*Nitrogen gas not included.
Requires disposable gas tank: CGA600, 99.95%
Nitrogen 20 bar fill pressure, approximately one liter.
T2076NG Components
The Calibration Kit Model T2076NG includes:
• Instruction sheet
• Tubing assembly
Calibrates the following models:
• Ventostat 8000 and 8100 Series
• Telaire 7000 Series
• Use in conjunction with UIP software for T8000 series
• Carrying case.
• Flow Meter
• Vaporstat 9002
Enclosures
Specifications
Tubing on 1508 Only
P ower R equirements
18-36 VAC rms or
18-42 VDC
100 mA P eak,
70 mA avg @ 24 VDC
The Model 1508 is designed for in-duct sampling of
CO2 concentrations at flow rates greater than 400
fpm. Clear cover allows for observation of the sensor.
Enclosure is screwed to the duct with probe inserted
into airstream. Air sampling probe is 1 in (25.4 mm)
diameter and 8 in (203.2 mm) long. Enclosure (ABS
plastic) has knockouts for conduit connection. CO2
Sensor not included.
T1505 Splash Resistant Enclosure
The Model 1505 is designed to protect the sensor
in damp or wet environments which might occur in
agricultural, industrial or food processing environments.
This enclosure (ABS plastic) is designed to protect the
sensor from dripping or sprayed water. The transparent
cover allows for viewing of the sensor/display. Four
diffusion ports allow for entry of CO2. Knockouts are
provided for conduit connection. Response time of
the sensor is slowed to approximately 30 minutes
to measure a 90% step change in concentrations.
Enclosure is designed to screw directly to a wall. CO2
sensor not included.
T1551 Outside Air Enclosure
The Model 1551 is a rugged weatherproof enclosure
(ABS plastic), designed to allow the 8000 series sensor
to operate in an outdoor environment and/or where
ambient temperatures are below freezing. The 1551 is
ideal for monitoring outside air or CO2 as a surrogate
for combustion fumes in parking garages, tunnels and
loading docks. This enclosure features a temperature
control circuit and internal heaters to maintain the
sensor within its normal operating temperature range,
even if temperatures outside the enclosure are as
low as –20°F (-29°C). Four diffusion ports allow for
entry of CO2. Response time of the sensor is slowed
approximately 30 minutes to measure a 90% step
change in concentrations. Enclosure is designed to
screw directly to a wall. CO2 sensor not included.
Pin Designations
1. AC+ / DC+
2. AC- / GND
T1508 Aspiration Box
Pin Designations
1. Not Used
2. Not Used
3. Relay Norm Open
4. Relay Common
5. Relay Norm Closed
6. 4-20mA Output
7. Signal Ground
8. 0-10V Output
Enclosures are compatible with all Ventostat 8000
series (except the 8003 and 8009) and Vaporstat 9002
models.
Mounting Bracket
(Pre-Installed on 1551)
Any of the Ventostat
8000 Series Sensors
Cover
Cover Removed
Spouts on
1505 and 1551 Only
Extension Tube
on 1508 Only
7 in
(177.8 mm)
6.5 in (165.1 mm)
1.13 in (28.7 mm)
1.13 in (28.7 mm) and 1.7in (43.18 mm)
0.88 in (22.35 mm)
3.75 in (95.25 mm)
4.25 in (107.95 mm)
3.5 in (88.9 mm)
10.5 in (266.7mm)
7 in (177.8 mm)
T1552 Outside Air Enclosure
The Model 1552 is a rugged weatherproof enclosure
ambient temperatures are below freezing. The 1552 is
low as -20°F (-29°C). Four diffusion ports allow for
to approximately 30 minutes to measure a 90% step
screw directly to a wall. CO2 sensor not included. Power
consumption is 24V, 1.5 Amp (max), and includes the
Ventostat 8000 series.
Power Consumption
24V, 1.5 Amp (maximum) – including sensor
Software
T2072 and T2080
Software Compatibility
Windows 7
Product Supporting
Telaire 7001, all 8000 Series Products, 6003 Module
Functionality
• Log and Graph CO2 Levels (Sequential Record,
No Time Stamp)
Sample of the Display During “Real-time” Graphing
• Store Logged Files to a .TXT format for use with
other programs
• Perform Zero and Span Calibration On Telaire’s 8000,
7001 and 6000 series sensors
Connection Port
PC RS-232 Port, Telaire Product RJ45 Connector
(Cable P/N 62285 available)
62285 Connection Cable
Telaire Part No. 62285
Graphing Adjustments
• Sample Time Interval
The software features:
• Number of Measurements Displayed
• Altitude adjustment for maximum accuracy
performance
• Display Maximum/Minimum
• Analog output adjustment
• Display Mean
• Single point and span gas calibration
• Display Standard Deviation
• Turn on and off ABC Logic™
• Display Best Fit Line
• Change temperature display units
• Graphing and logging of CO2, temperature and %RH
(H Versions only)
Ventostat UIP Software (T2090)
The Ventostat UIP software allows you to modify the
standard settings on the T8100, T8200 and T8300
series products.
The software can be used by distributors to make
modifications to the Ventostat prior to shipping to
the customer, as well as to make adjustments in the
field. The USB cable supplies power to the Ventostat,
negating the need for a separate power supply.
The T2090 UIP software kit is supplied with a USB-toVentostat cable and software CD.
Amphenol
Advanced Sensors
www.telaire.com
www.amphenol-sensors.com
© 2014 Amphenol Corporation. All Rights Reserved. Specifications are subject to change without notice.
Other company names and product names used in this document are the registered trademarks or
trademarks of their respective owners.
AAS-920-318B-04/2014
很抱歉,暂时无法提供与“T1505”相匹配的价格&库存,您可以联系我们找货
