A
B
C
D
E
G
F
H
REVISIONS
AMPHENOL PART NUMBER CONFIGURATION
U95 - T 1 X 1 -1 X X X
REV
HEAT SINK OPTION
1
1 = NO HEAT SINK OR CLIP SHIPPED
5 = ROUND PIN STYLE (H=6.5mm; SAN HEIGHT)--(NOT AVAILABLE WITH QUAD LIGHT PIPE)
6 = ROUND PIN STYLE (H=4.2mm; PCI HEIGHT)--(NOT AVAILABLE WITH QUAD LIGHT PIPE)
7 = ROUND PIN STYLE (H=13.5mm; TALL)--(NOT AVAILABLE WITH QUAD LIGHT PIPE)
A = SQUARE PIN STYLE (H=6.5mm; SAN HEIGHT)
B = SQUARE PIN STYLE (H=4.2mm; PCI HEIGHT)
C = SQUARE PIN STYLE (H=13.5mm; TALL)
N = PIN-FIN STYLE FOR SIDE TO SIDE AIR FLOW (H=6.5mm; SAN HEIGHT)
P = PIN-FIN STYLE FOR SIDE TO SIDE AIR FLOW (H=4.2mm; PCI HEIGHT)
R = PIN-FIN STYLE FOR SIDE TO SIDE AIR FLOW (H=13.5mm; TALL)
Y = EXTRUDED FIN STYLE FOR FRONT - BACK AIR FLOW (H=6.94mm)
W = EXTRUDED FIN STYLE FOR FRONT - BACK AIR FLOW (H=8.72mm)
DESCRIPTION, ECN, EAR NO.
H
ADDED HEAT SINK OPTIONS
DATE
APP'D
JAN. 16/15
AC
J
PCB FRONT EDGE NOTE ADDED
APR 22/15
AC
K
COMPLIANT PIN LEAD IN TIP SHORTENED FOR THINNER B2B PCB APPLICATION
JUL 10/15
AC
PACKAGING OPTION
1 = TRAY PACKAGING (LIGHT PIPE AND/OR HEAT SINK SHIPPED
LOOSE IF ORDERED)
A = TRAY PACKAGING (LIGHT PIPE AND/OR HEAT SINK ASSEMBLED
TO THE CAGE)
2
1
2
OPTIONAL LIGHT PIPE
0 = NO LIGHT PIPE
1 = DUAL BARREL LIGHT PIPE - ROUND OUTLET
7 = SINGLE BARREL LIGHT PIPE - ROUND OUTLET
4 = QUAD BARREL LIGHT PIPE - ROUND OUTLET
NOTE: FOR DIMENSION "H" SEE SHEET 2
OPTIONAL DUST COVER (CONDUCTIVE)
0 = WITHOUT DUST COVER
D= WITH DUST COVER (SHIPPED LOOSE PIECE)
3
3
VIEW WITH NO LIGHT PIPE
AND NO HEAT SINK
(NO DUST COVER)
(P/N U95-T111-1001)
4
AND EXTRUDED HEAT SINK
(NO DUST COVER)
(P/N U95-T1W1-100A)
AND ROUND PIN HEAT SINK
(NO DUST COVER)
(P/N U95-T151-100A)
4
5
5
VIEW WITH SINGLE BARREL LIGHT PIPE
(NO DUST COVER)
(P/N U95-T151-107A)
AND PIN FIN HEAT SINK
(NO DUST COVER)
(P/N U95-T1N1-101A)
VIEW WITH QUAD BARREL LIGHT PIPE
AND SQUARE PIN HEAT SINK
(NO DUST COVER)
(P/N U95-T1A1-104A)
UNLESS SPECIFIED OTHERWISE
UNIT
6
CONDUCTIVE DUST COVER
SHOWN (OPTIONAL)
(SHIPPED LOOSE)
(P/N U79-111-9000-P)
REFERENCE IN PARENTHESES
DRAWN
A.C.
JUL5/13
CHECKED
ZLJ
JUL5/13
ZLJ
JUL5/13
M.E. APP'D
Q.A. APP'D
GENERAL TOLERANCES
THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE
OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP.
A
MILLIMETERS
B
C
D
DWG APP'D
1 DECIMAL PLACE
0.2
ENG. REL. NO.
2 DECIMAL PLACES
0.15
REF.
1
THIRD
ANGLE
PROJECTION
ANGULAR DEGREES
E
Amphenol High Speed Interconnects
A Division of Amphenol Corp. www.amphenol-highspeed.com
UltraPort QSFP 1X1 CAGE ASSEMBLY
THRU BEZEL TWO REAR PIN
WITH HEAT SINK AND LIGHT PIPE OPTIONS
DWG. NO.
REV
F
K
P-U95-T1X1-1XXX
DO NOT
SCALE
DRAWING CODE ID NO.
03554 DWG SIZE: C
G
SCALE:
SHEET 1 OF 5
3:1
H
6
A
B
C
D
E
G
F
H
1
1
4.00
2.00
J
2
13.8
18.75±0.10
(INSIDE TO INSIDE
OF THE CAGE)
3
2
12.8
9.70
8.90±0.10
(INSIDE TO
INSIDE OF
THE CAGE)
2.30 0.10 TYP.
COMPLIANT PINS
3.6
60.92
(12.6)
(PCB TO HEAT SINK CLIP TOP
SURFACE UNMATED, 11.8 FOR QUAD LP OPTION)
1.7
66.3
3
3
VIEW WITH DUAL BARREL LIGHT PIPE
(NO DUST COVER)
(P/N U95-T151-101A)
4
4
H
SQUARE PIN STYLE WITHOUT LP
(FOR REFERENCE ONLY)
ROUND PIN STYLE WITHOUT LP
5
PART NUMBER
U95-T15(N, A)1-1XXX
U95-T16(P, B)1-1XXX
U95-T17(R, C)1-1XXX
U95-T1Y1-1XXX
U95-T1W1-1XXX
DIM "J"
15.10
12.80
22.10
15.54
17.32
PIN FIN STYLE WITHOUT LP
DIM "H"
6.50
4.20
13.50
6.94
8.72
5
NOTES:
1.
2.
6
3.
MATERIAL:
CAGE AND EMI SPRINGS: COPPER ALLOY
CAGE PLATING: 2.54m [100"] MIN. NICKEL.
LIGHT PIPE: GE LEXAN RESIN, CLEAR OPTICAL GRADE
HEAT SINK: ALUMINUM ALLOY, NICKEL PLATED
HEAT SINK CLIP: STAINLESS STEEL
DUST COVER: CONDUCTIVE RUBBER
ROUND PIN STYLE WITH LP
(FOR REFERENCE ONLY,
LAYOUT MAY VARY W/ LP OPTION)
SQUARE PIN STYLE WITH LP
DUST COVER IS SHIPPED AS A LOOSE PIECE IF ORDERED.
UNIT
MILLIMETERS
DIMENSION "J" IS IN THE UNPLUGGED STATE
B
DRAWN
A.C.
JUL5/13
CHECKED
ZLJ
JUL5/13
ZLJ
JUL5/13
M.E. APP'D
Q.A. APP'D
GENERAL TOLERANCES
A
PIN FIN STYLE WITH LP
FIN STYLE WITH LP
LAYOUT MAY VARY W/ LP OPTION) LAYOUT MAY VARY W/ LP OPTION)
C
D
DWG APP'D
1 DECIMAL PLACE
0.2
ENG. REL. NO.
2 DECIMAL PLACES
0.15
REF.
1
THIRD
ANGLE
PROJECTION
ANGULAR DEGREES
E
DWG. NO.
REV
P-U95-T1X1-1XXX
DO NOT
SCALE
DRAWING CODE ID NO.
F
03554 DWG SIZE: C
G
SCALE:
K
SHEET 2 OF 5
3:1
H
6
A
B
C
D
E
G
F
H
1
16.8
1
7.2
1.1
3.4
(FOR DUAL BARREL LIGHT PIPE)
SOLDER PADS FOR LED'S
PADS TO BE SPECIFIED
BY THE CUSTOMER
(FOR SINGLE BARREL LIGHT PIPE)
(FOR QUAD
BARREL LIGHT PIPE)
2
16.20 MAX
(SURFACE TRACES PERMITTED
WITHIN THIS LENGTH)
16.28
2
10.10
A
A
0.80
(36 PLC.)
6.70
WITHIN THIS SHADED AREA
0.53
13.49 MIN
38
12.49 MAX
1
19
12.79
3
0.40
1.80±0.03 (38 PLC.)
0.05 S K S L S
7.6
2.50
3.1
3.1
9.00
(6 PLC.)
3.50 MAX
1.69 MAX
THIS AREA DENOTES
COMPONENT KEEP-OUT
(TRACES ALLOWED)
4
19.00
22.15 MIN
(SEE NOTE 1)
Y
0.1 L
1.55±0.05
0.1 L A X Y
15.02 MAX
1.55±0.05
A X KS
L
15.80
4
K
19.20 MAX
DETAIL A
SCALE 4 : 1
1.44 MIN
HATCHED AREA DENOTES
COMPONENT AND TRACE KEEPOUT
(EXCEPT CHASSIS GROUND)
BSC
X
0.35±0.03 (38 PLC.)
0.05 S K S L S
7.37
37.00 MAX
(SEE NOTE 2)
BSC
5
11.19 MAX
1.05±0.05
(12 PLC.)
(SEE NOTE 3)
0.1 M A K S L S
7.6
3
16.50
5
RECOMMENDED PC BOARD LAYOUT
(COMPONENT SIDE OF BOARD)
(SEE NOTE 1)
NOTES:
UNIT
6
1.
DATUMS X AND Y ESTABLISHED BY CUSTOMER'S FIDUCIAL.
2.
LOCATION OF EDGE OF PCB IS APPLICATION SPECIFIC.
3.
FINISHED HOLE SIZE.
B
DRAWN
A.C.
JUL5/13
CHECKED
ZLJ
JUL5/13
ZLJ
JUL5/13
M.E. APP'D
Q.A. APP'D
GENERAL TOLERANCES
A
MILLIMETERS
C
D
DWG APP'D
1 DECIMAL PLACE
0.2
ENG. REL. NO.
2 DECIMAL PLACES
0.15
REF.
1
THIRD
ANGLE
PROJECTION
ANGULAR DEGREES
E
DWG. NO.
REV
P-U95-T1X1-1XXX
DO NOT
SCALE
DRAWING CODE ID NO.
F
03554 DWG SIZE: C
G
SCALE:
K
SHEET 3 OF 5
3:1
H
6
A
B
C
D
E
G
F
H
1
1
13.40
10.60
6.20
A
2
(SEE PAGE 3)
A
3.40
1.10
(SEE PAGE 3)
2
A
13.49
MIN
1
3.10
(2 PLC)
12.79
1
19
19
THIS AREA DENOTES
COMPONENT KEEP-OUT
(TRACES ALLOWED)
7.60
(2 PLC.)
3
3
K
3.10
(2 PLC.)
1.05±0.05
(24 PLC.)
(SEE NOTE 3)
L
0.1 M A K S L S
4.50
(14 PLC.)
4
37.00 MAX
(SEE NOTE 2)
THIS AREA DENOTES
COMPONENT KEEP-OUT
(TRACES ALLOWED)
BSC
4
COMPONENT AND TRACE KEEP-OUT
2.35 MIN
19.00
22.15 MIN
5
BSC
X
(SEE NOTE 1)
Y
5
RECOMMENDED BELLY-TO-BELLY PC BOARD LAYOUT
(SEE NOTE 1)
NOTES:
1.
6
UNIT
MILLIMETERS
2.
FINISHED HOLE SIZE.
A
B
A.C.
JUL5/13
CHECKED
ZLJ
JUL5/13
ZLJ
JUL5/13
M.E. APP'D
Q.A. APP'D
GENERAL TOLERANCES
3.
DRAWN
C
D
DWG APP'D
1 DECIMAL PLACE
0.2
ENG. REL. NO.
2 DECIMAL PLACES
0.15
REF.
1
THIRD
ANGLE
PROJECTION
ANGULAR DEGREES
E
DWG. NO.
REV
P-U95-T1X1-1XXX
DO NOT
SCALE
DRAWING CODE ID NO.
F
03554 DWG SIZE: C
G
SCALE:
K
SHEET 4 OF 5
3:1
H
6
A
B
C
D
E
G
F
H
1
1
43.00±0.30
1.00
R0.30 MAX
(TYP.)
BEZEL
C
CENTER LINE OF
CONNECTOR GUIDE POST
6.00 MIN.
(SEE NOTE)
2
2
1.7
0.15±0.10
BEZEL CUT-OUT
BELOW PCB)
(TYP.)
2.85
HOST BOARD
(2.55)
(BEZEL CUT-OUT
SPACING FOR 2.85MM PCB)
3
3
C
4.00 TYP.
RECOMMENDED BELLY-TO-BELLY MOUNTING DESIGN
SECTION C-C
2.70
7.86
7.86
4
20.00±0.10
2.70
4.00
2.70
4
21.00±0.10
MIN
21.00±0.10
MIN
RECOMMENDED SINGLE SIDED
MOUNTING DESIGN
FOR SINGLE LIGHT PIPE
MOUNTING DESIGN
4.00 TYP.
7.86 TYP.
2.70
10.15±0.10
7.86
5
5
21.00±0.10
MIN.
1.44 MIN.
21.00±0.10
MIN
RECOMMENDED SINGLE SIDED MOUNTING DESIGN
FOR DUAL LIGHT PIPE
MOUNTING DESIGN
UNIT
6
MILLIMETERS
NOTES:
GENERAL TOLERANCES
A.C.
JUL5/13
CHECKED
ZLJ
JUL5/13
ZLJ
JUL5/13
M.E. APP'D
Q.A. APP'D
A
DRAWN
B
C
D
DWG APP'D
1 DECIMAL PLACE
0.2
ENG. REL. NO.
2 DECIMAL PLACES
0.15
REF.
1
THIRD
ANGLE
PROJECTION
ANGULAR DEGREES
E
DWG. NO.
REV
P-U95-T1X1-1XXX
DO NOT
SCALE
DRAWING CODE ID NO.
F
03554 DWG SIZE: C
G
SCALE:
K
SHEET 5 OF 5
3:1
H
6
很抱歉,暂时无法提供与“U95-T111-1001”相匹配的价格&库存,您可以联系我们找货
