A-TB500-T314
A-TB500-T314
    ASSMANN
    插件,P=5mm
    接线端子 间距P=5.00mm 14Pin(1x14) 插件
A-TB500-T314 数据手册
1 2 3 5 4 6 7 A A Material Terminal body (metal housing): Brass stamped Terminal screw: Steel Zinc plating "+/-" slot type Wire guard: Stainless steel Surface of solder tail: Tin plated Insulator (housing): Thermoplastic (UL94V-0) ,Green B P.C.B. LAYOUT Electrical C C Voltage rating: 300VAC Current rating: 8A Wire range: Solid wire(AWG): 14-26 Stranded wire(AWG): 14-26 Torque(Lb-In): 3.5 Screw: M2.5 Wire strip length: 5-6mm Withstanding Voltage: 1.6KV D Safety Approval: c B D us E E F F N=Number of contacts Scale RoHS compliant G 1:1 Date TOLERANCE Unit: mm Name Drawn 29.07.2009 Dean Approved 18.04.2016 Joanna X. X.X Customer-No. G ASSMANN WSW-No. A-TB500-T3xx X.XX 2 DIM File No.: E349947 TOL H Angle 1 2 Drawing-No. 2 Add UL 18.04.2016 Joanna 1 Drawn 29.07.2009 Dean Date Name rev02 ASS 3593 CO Replace TOL Id. Modification 3 4 5 6 Sheet 7 H
A-TB500-T314 价格&库存
很抱歉,暂时无法提供与“A-TB500-T314”相匹配的价格&库存,您可以联系我们找货
