T50024
T50024
    ATM
    T50024 - OUTLINE, COAX TERMINATION - Advanced Technical Materials Inc.
T50024 数据手册
2 REV A 1 REVISION HISTORY AUTH DATE DESCRIPTION 5/28/2008 INITIAL RELEASE - 10.39 B 4.50 B 2.60 1.31 POWER RATING: 500 WATTS FREQUENCY (Ghz) 2.0 - 4.2 2.0 - 8.0 3.7 - 8.4 2.0 - 12.4 3.0 - 12.4 2.0 - 2.4 1.5:1 2.0 - 2.4 1.5:1 2.0 - 2.4 1.5:1 TYPE-N FEMALE CONNECTOR VSWR 2.4 - 3.0 1.45:1 3.0 - 4.2 1.30:1 3.0 - 8.0 1.30:1 Model # T50024 2.4 - 3.0 1.45:1 1.30:1 2.4 - 3.0 1.45:1 1.30:1 T50024F T50025 3.0 - 12.4 1.30:1 T50024G T50025G A A THIRD ANGLE PROJECTION: UNLESS OTHERWISE NOTED, DIMENSIONS ARE IN INCHES, TOLERANCES ARE: FRACTIONS: ±1/64 ANGLES: ±1/2° DRAWN CHKD. APPROVALS BF MR FINISH: BLACK ANODIZE OR HIGH TEMP BLACK PAINT DATE 5/28/2008 5/28/2008 5/28/2008 ADVANCED TECHNICAL MATERIALS, INC. TEL: (631) 289-0363 FAX: (631) 289-0358 www.atmmicrowave.com THE INFORMATION IN THIS DRAWING IS PROPRIETARY AND SHALL NOT BE USED OR DISCLOSED WITHOUT THE PRIOR WRITTEN CONSENT OF ATM, INC. DO NOT SCALE DWG. BASIC DIMENSION UNDER 6" 6" - 12" OVER 12" DECIMALS 2 PLACE 3 PLACE APRVD. MB MATERIAL TREATMENT FINISH `.02 `.03 `.06 `.005 `.010 `.015 AL ALY TYPE 6061-T6 BODY SIZE A CAGE CODE OUTLINE, COAX TERMINATION ATM DWG # 0R8N4 8799 REVISION SHEET A SEE NOTES MODEL # 2 SEE NOTES 1 1 OF 1
T50024 价格&库存
很抱歉,暂时无法提供与“T50024”相匹配的价格&库存,您可以联系我们找货
