T0797
T0797
    ATMEL(爱特梅尔)
    T0797 - 65 - 300 MHz SiGe IF Receiver / Demodulator - ATMEL Corporation
T0797 数据手册
Features • • • • Gain control in 20-dB steps Very low I/Q amplitude and phase errors High input P1dB Buffered IF OUT available through baseband output Applications • Infrastructure digital communication systems • GSM/cellular transceivers • ISM band transceivers Electrostatic sensitive device. Observe precautions for handling. 65 - 300 MHz SiGe IF Receiver / Demodulator T0797 Description The T0797 is a multi-purpose demodulator RFIC. The silicon monolithic integrated circuit is a designed in Atmels advanced SiGe technology. This demodulator is capable of both quadrature demodulation or direct IF output. Features include switchable gain control on a frequency range from 65 MHz to 300 MHz. The device performs a very low amplitude as well as phase error and allows high input P1dB. The T0797 targets a variety of system applications for communications including 3G wireless. Block Diagram Figure 1. GC1 5 GC2 4 2 1 BBIP BBIN IFP IFN 8 9 ϕ 16 15 13 12 BBQP BBQN LOP LON Rev. A2, 03-Dec-01 Preliminary Information 1 (10) Preliminary Information Ordering Information Extended Type Number T0797 Package TSSOP16 Remarks Pin Configuration Figure 2. BBIN BBIP VCC GC2 GC1 GND VCC IFP 1 2 3 4 5 6 7 8 16 15 14 13 12 11 10 9 BBQP BBQN VCC LOP LON GND VCC IFN Pin Description Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Symbol BBIN BBIP VCC GC2 GC1 GND VCC IFP IFN VCC GND LON LOP VCC BBQN BBQP Baseband I-axis negative output Baseband I-axis positive output 5 V power supply Gain control input, stage 2 Gain control input, stage 1 Ground 5 V power supply IF positive input IF negative input 5 V power supply Ground Local oscillator, negative input Local oscillator, positive input 5 V power supply Baseband Q-axis negative output Baseband Q-axis positive output Function 2 (10) T0797 Rev. A2, 03-Dec-01 T0797 Absolute Maximum Ratings All voltages are referred to GND. Parameter Supply voltage LO input IF input Operating temperature Storage temperature Note: Symbol VCC LOP, LON IFN, IFP TOP Tstg Value 5.5 10 10 -40 to +85 -65 to +150 Unit V dBm V °C °C The part may not survive all maximums applied simultaneously Thermal Resistance Parameter Junction ambient Symbol RthJA Value tbd Unit K/W Electrical Characteristics Test conditions: VCC = 5 V, Tamb = 25°C, LO input: 0 dBm@200 MHz IF input: @200.1 MHz, GC1 = 0, GC2 = 0; 0 dBm IF input: @200.1 MHz, GC1 = 1, GC2 = 0; -20 dBm IF input: @200.1 MHz, GC1 = 1, GC2 = 1; -40 dBm No. 1 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 1.10 1.11 1.12 1.13 1.14 Parameters Frequency range Return loss Gain Input P1dB Input IP3 Noise figure Gain Input P1dB Input IP3 Noise figure Gain Input P1dB Input IP3 Noise figure Gain set = high; GC1 = GC2 = 0 Gain set = high; GC1 = 1; GC2 = 0 Gain set = high; GC1 = GC2 = 1 Test Conditions Pin 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 Symbol f RL G P1dB IIP3 NF G P1dB IIP3 NF G P1dB IIP3 NF –3 Min. 65 Typ. 120 220 20 35 –30 –20 6 15 –10 0 10 –5 10 20 30 Max. 300 Unit MHz dB dB dBm dBm dB dB dBm dBm dB dB dBm dBm dB Type* B D A C B D A C B D A C B D IF input (I/Q mixing to baseband) *) Type means: A = 100% tested, B = 100% correlation tested, C = Characterized on samples, D = Design parameter Preliminary Information Rev. A2, 03-Dec-01 3 (10) Preliminary Information Electrical Characteristics Test conditions: VCC = 5 V, Tamb = 25°C, LO input: 0 dBm@200 MHz IF input: @200.1 MHz, GC1 = 0, GC2 = 0; 0 dBm IF input: @200.1 MHz, GC1 = 1, GC2 = 0; -20 dBm IF input: @200.1 MHz, GC1 = 1, GC2 = 1; -40 dBm No. 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 2.10 2.11 2.12 2.13 2.14 3 3.1 3.2 3.3 3.4 3.5 4 4.1 4.2 5 5.1 5.2 Parameters Frequency range Return loss Gain Input P1dB Input IP3 Noise figure Gain Input P1dB Input IP3 Noise figure Gain Input P1dB Input IP3 Noise figure I/Q Output I/Q output frequency range I/Q output amplitude error I/Q phase error I/Q output common mode voltage I/Q output differential offset voltage LO input LO input level Return loss Miscellaneous Supply voltage Supply current 3, 7, 10, 14 3, 7, 10, 14 VCC ICC 4.75 5 180 5.25 V mA A A 12, 13 12, 13 PLO RLLO –3 0 20 +3 dBm dB D D 1, 2, 15, 16 1, 2, 15, 16 1, 2, 15, 16 1, 2, 15, 16 1, 2, 15, 16 Voffset fI/Q DC –0.2 –2 2.5 10 500 +0.2 +2 MHz dB deg V mV D A A A A Gain set = high; GC1 = GC2 = 0 Gain set = high; GC1 = 1; GC2 = 0 Gain set = high; GC1 = GC2 = 1 Test Conditions Pin 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 8, 9 Symbol f RL G P1dB IIP3 NF G P1dB IIP3 NF G P1dB IIP3 NF Min. 65 Typ. 120 220 20 40 –26 –16 6 20 –6 4 9 0 14 24 30 Max. 300 Unit MHz dB dB dBm dBm dB dB dBm dBm dB dB dBm dBm dB Type* B D A C B D A C B D A C B D Stuck Mixer (DC to LO port – gain-controlled amplifier) *) Type means: A = 100% tested, B = 100% correlation tested, C = Characterized on samples, D = Design parameter 4 (10) T0797 Rev. A2, 03-Dec-01 T0797 Typical Device Performance Figure 3. Gain vs. pin high-gain state (11) 35 Gain (dB) 34 33 32 31 30 -40 -38 -36 -34 -32 -30 -28 -26 Pin (dBm ) Figure 4. Gain vs. pin low-gain state (00) -3 -4 Gain (dB) -5 -6 -7 -8 0 5 Pin (d Bm ) 10 15 Figure 5. Gain vs. pin medium-gain state (10) 16 Gain (dB) 15 14 13 12 11 -20 -18 -16 -14 -12 -10 -8 -6 Pin (dBm ) Preliminary Information Rev. A2, 03-Dec-01 5 (10) Preliminary Information Demo Test Board Schematic Figure 6. L4 BBIN C17 C18 BBIP L5 C15 C16 R7 1 2 3 4 5 6 7 8 C7 16 15 14 13 12 11 10 9 C8 C2 C3 R6 C5 C4 L2 BBQN R8 R5 L1 BBQP 5V R3 GC2 GC1 5V R1 Vcc C20 Vcc C11 C21 LOin T0797 T2 Vcc C6 Vcc C19 C12 5V L3 C1 Vcc T1 Bill of Materials Component Designator D1 J2, J3, J4, J5, J6, J7 Value Vendor Atmel Johnson Components Mini-Circuits IFin Part Number T0797 142-0701-851 Description IF receiver SMA end launch connector Transformer 1206 size supply bypass capacitor 0603 size 0603 size 1210 size 0603 size 1206 size 0603 size T1, T2 C1 R1, R3 C6, C19, C20, C21 L1, L2, L3, L4, L5 C7, C8, C11, C12 R5, R6, R7, R8 C2, C3, C4, C5, C15, C16, C17, C18 1uF 1 kohm 1nF 1uH 68pF 0 Ohm 820pF TC1-1 6 (10) T0797 Rev. A2, 03-Dec-01 T0797 Demo Test Board (Fully Asembled PCB) Figure 7. J6 J7 J4 J5 C18 L5 C16 C17 L4 C15 L1 C5 C2 C4 C3 L2 R7 R8 R5 R6 1.96 C20 R3 S2 S1 R1 C6 C7 U1 C21 C11 C12 C19 C8 J3 T2 T1 L3 1 C1 2 J1 J2 1.96 Note: Dimensions in inches Recommended Package Footprint Figure 8. 1.25 0.25 0.74 0.4 0.74 3.0 3.0 φ0.33 via 0.7 0.9 6.9 - Indicates metalization all units are in mm - vias connect pad to underlying ground plane Remark: Heatslug must be soldered to GND Preliminary Information Rev. A2, 03-Dec-01 7 (10) Preliminary Information Package Information 8 (10) T0797 Rev. A2, 03-Dec-01 T0797 Ozone Depleting Substances Policy Statement It is the policy of Atmel Germany GmbH to 1. Meet all present and future national and international statutory requirements. 2. Regularly and continuously improve the performance of our products, processes, distribution and operating systems with respect to their impact on the health and safety of our employees and the public, as well as their impact on the environment. It is particular concern to control or eliminate releases of those substances into the atmosphere which are known as ozone depleting substances (ODSs). The Montreal Protocol (1987) and its London Amendments (1990) intend to severely restrict the use of ODSs and forbid their use within the next ten years. Various national and international initiatives are pressing for an earlier ban on these substances. Atmel Germany GmbH has been able to use its policy of continuous improvements to eliminate the use of ODSs listed in the following documents. 1. Annex A, B and list of transitional substances of the Montreal Protocol and the London Amendments respectively 2. Class I and II ozone depleting substances in the Clean Air Act Amendments of 1990 by the Environmental Protection Agency (EPA) in the USA 3. Council Decision 88/540/EEC and 91/690/EEC Annex A, B and C (transitional substances) respectively. Atmel Germany GmbH can certify that our semiconductors are not manufactured with ozone depleting substances and do not contain such substances. Preliminary Information Rev. A2, 03-Dec-01 9 (10) A tmel Sales Offices France 3, Avenue du Centre 78054 St.-Quentin-en-Yvelines Cedex Tel: +33 1 30 60 70 00 Fax: +33 1 30 60 71 11 Sweden Kavallerivaegen 24, Rissne 17402 Sundbyberg Tel: +46 8 587 48 800 Fax: +46 8 587 48 850 Hong Kong Room #1219, Chinachem Golden Plaza 77 Mody Road, Tsimhatsui East East Kowloon, Hong Kong Tel: +852 23 789 789 Fax: +852 23 755 733 Germany Erfurter Strasse 31 85386 Eching Tel: +49 89 319 70 0 Fax: +49 89 319 46 21 Kruppstrasse 6 45128 Essen Tel: +49 201 247 30 0 Fax: +49 201 247 30 47 Theresienstrasse 2 74072 Heilbronn Tel: +49 7131 67 36 36 Fax: +49 7131 67 31 63 United Kingdom Easthampstead Road Bracknell Berkshire RG12 1LX Tel: +44 1344 707 300 Fax: +44 1344 427 371 Korea 25-4, Yoido-Dong, Suite 605, Singsong Bldg. Youngdeungpo-Ku 150-010 Seoul Tel: +822 785 1136 Fax: +822 785 1137 USA Western 2325 Orchard Parkway San Jose, California 95131 Tel: +1 408 441 0311 Fax: +1 408 436 4200 Rep. of Singapore Keppel Building #03-00 25 Tampines Street 92, Singapore 528877 Tel: +65 260 8223 Fax: +65 787 9819 USA Eastern 1465 Route 31, Fifth floor Annandale New Jersey 08801 Tel: +1 908 848 5208 Fax: +1 908 848 5232 Italy Via Grosio, 10/8 20151 Milano Tel: +39 02 38 03 71 Fax: +39 02 38 03 72 34 Taiwan, R.O.C. 8F-2, 266 Sec.1 Wen Hwa 2 Rd. Lin Kou Hsiang, 244 Taipei Hsien Tel: +886 2 2609 5581 Fax: +886 2 2600 2735 Spain Principe de Vergara, 112 28002 Madrid Tel: +34 91 564 51 81 Fax: +34 91 562 75 14 Japan Tonetsushinkawa Bldg. 1-24-8 Shinkawa Chuo Ku Tokyo 104-0033 Tel: +81 3 3523 3551 Fax: +81 3 3523 7581 Web Site http://www.atmel-wm.com © A tmel Germany GmbH 2001. Atmel Germany GmbH makes no warranty for the use of its products, other than those expressly contained in the Company ’s standard warranty which is detailed in Atmel Germany GmbH ’s Terms and Conditions. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Atmel Germany GmbH are granted by the Company in connection with the sale of Atmel Germany GmbH products, expressly or by implication. Atmel Germany GmbH ’s products are not authorized for use as critical components in life support devices or systems. Data sheets can also be retrieved fron the Internet: http://www.atmel-wm.com Rev. A2, 03-Dec-01
T0797 价格&库存
很抱歉,暂时无法提供与“T0797”相匹配的价格&库存,您可以联系我们找货
