T5744
T5744
    ATMEL(爱特梅尔)
    T5744 - UHF ASK Receiver - ATMEL Corporation
T5744 数据手册
Features • Minimal External Circuitry Requirements, no RF Components on the PC Board Except • • • • • • • • • • • • Matching to the Receiver Antenna High Sensitivity, Especially at Low Data Rates SSO20 and SO20 package Fully Integrated VCO Supply Voltage 4.5 V to 5.5 V, Operating Temperature Range -40°C to 105°C Single-ended RF Input for Easy Adaptation to l/4 Antenna or Printed Antenna on PCB Low-cost Solution Due to High Integration Level Various Types of Protocols Supported (i.e., PWM, Manchester and Biphase) Distinguishes the Signal Strength of Several Transmitters via RSSI (Received Signal Strength Indicator) ESD Protection According to MIL-STD. 883 (4KV HBM) High Image Frequency Suppression Due to 1 MHz IF in Conjunction with a SAW Frontend Filter, up to 40 dB is thereby Achievable with Newer SAWs Power Management (Polling) is Possible by Means of a Separate Pin via the Microcontroller Receiving Bandwidth BIF = 600 kHz UHF ASK Receiver T5744 Description The T5744 is a PLL receiver device for the receiving range of f 0 = 300 MHz to 450 MHz. It is developed for the demands of RF low-cost data communication systems with low data rates and fits for most types of modulation schemes including Manchester, Biphase and most PWM protocols. Its main applications are in the areas of telemetering, security technology and keyless-entry systems. Figure 1. System Block Diagram UHF ASK/FSK Remote control transmitter UHF ASK Remote control receiver 1 Li cell U2741B T5744 Demod. Data interface 1...3 µC Keys Encoder M44Cx9x XTO PLL IF Amp Antenna Antenna VCO PLL XTO Power amp. LNA VCO Rev. 4521B–RKE–01/03 1 Pin Configuration Figure 2. Pinning SO20 and SSO20 ENABLE LFGND MODE DATA DVCC RSSI XTO LFVCC n.c. 10 11 TEST 20 16 15 14 13 19 18 17 T5744 8 2 4 6 1 3 5 CDEM DGND AGND AVCC BR_0 BR_1 7 LNAGND Pin Description Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Symbol BR_0 BR_1 CDEM AVCC AGND DGND MIXVCC LNAGND LNA_IN n.c. LFVCC LF LFGND XTO DVCC MODE RSSI TEST ENABLE DATA Function Baud rate select LSB Baud rate select MSB Lower cut-off frequency data filter Analog power supply Analog ground Digital ground Power supply mixer High-frequency ground LNA and mixer RF input Not connected Power supply VCO Loop filter Ground VCO Crystal oscillator Digital power supply Selecting 433.92 MHz /315 MHz Low: 315 MHz (USA) High: 433.92 MHz (Europe) Output of the RSSI amplifier Test pin, during operation at GND Selecting operation mode Low: sleep mode High: receiving mode Data output 2 T5744 4521B–RKE–01/03 MIXVCC LNA_IN 9 12 LF T5744 Figure 3. Block Diagram BR_0 BR_1 CDEM ASKDemodulator and data filter RSSI Dem_out Data interface DATA RSSI AVCC RSSI IF Amp Test TEST AGND DGND 4. Order MODE DVCC ENABLE LFGND Standby logic LFVCC IF Amp MIXVCC LPF 3 MHz LNAGND LPF 3 MHz VCO XTO XTO f LNA_IN LNA 64 LF RF Front End The RF front end of the receiver is a heterodyne configuration that converts the input signal into a 1-MHz IF signal. According to Figure 3, the front end consists of an LNA (Low-Noise Amplifier), LO (Local Oscillator), a mixer and RF amplifier. The LO generates the carrier frequency for the mixer via a PLL synthesizer. The XTO (crystal oscillator) generates the reference frequency fXTO. The VCO (Voltage-Controlled Oscillator) generates the drive voltage frequency fLO for the mixer. fLO is dependent on the voltage at Pin LF. fLO is divided by factor 64. The divided frequency is compared to fXTO by the phase frequency detector. The current output of the phase frequency detector is connected to a passive loop filter and thereby generates the control voltage VLF for the VCO. By means of that configuration, VLF is controlled in a way that fLO/64 is equal to fXTO. If fLO is determined, fXTO can be calculated using the following formula: fXTO = fLO/64 The XTO is a one-pin oscillator that operates at the series resonance of the quartz crystal. According to Figure 4, the crystal should be connected to GND via a capacitor CL. The value of that capacitor is recommended by the crystal supplier. The value of CL should be optimized for the individual board layout to achieve the exact value of fXTO and hereby of fLO. When designing the system in terms of receiving bandwidth, the accuracy of the crystal and the XTO must be considered. 3 4521B–RKE–01/03 Figure 4. PLL Peripherals VS DVCC CL XTO LFGND LF VS R1 C9 C10 R1 = 820 W C9 = 4.7 nF C10 = 1 nF LFVCC The passive loop filter connected to Pin LF is designed for a loop bandwidth of BLoop = 100 kHz. This value for BLoop exhibits the best possible noise performance of the LO. Figure 4 shows the appropriate loop filter components to achieve the desired loop bandwidth fLO is determined by the RF input frequency fRF and the IF frequency fIF using the following formula: fLO = fRF - fIF To determine fLO, the construction of the IF filter must be considered at this point. The nominal IF frequency is fIF = 1 MHz. To achieve a good accuracy of the filter's corner frequencies, the filter is tuned by the crystal frequency fXTO. This means that there is a fixed relation between fIF and fLO that depends on the logic level at pin mode. This is described by the following formulas: MODE = 0 USA fIF = fLO/314 MODE = 1 Europe fIF = fLO/432.92 The relation is designed to achieve the nominal IF frequency of fIF = 1 MHz for most applications. For applications where fRF = 315 MHz, MODE must be set to '0'. In the case of fRF = 433.92 MHz, MODE must be set to '1'. For other RF frequencies, fIF is not equal to 1 MHz. fIF is then dependent on the logical level at Pin MODE and on fRF. Table 1 summarizes the different conditions. The RF input either from an antenna or from a generator must be transformed to the RF input Pin LNA_IN. The input impedance of that pin is provided in the electrical parameters. The parasitic board inductances and capacitances also influence the input matching. The RF receiver T5744 exhibits its highest sensitivity at the best signal-tonoise ratio in the LNA. Hence, noise matching is the best choice for designing the transformation network. A good practice when designing the network, is to start with power matching. From that starting point, the values of the components can be varied to some extent to achieve the best sensitivity. If a SAW is implemented into the input network a mirror frequency suppression of D P Ref = 40 dB can be achieved. There are SAWs available that exhibit a notch at Df = 2 MHz. These SAWs work best for an intermediate frequency of IF = 1 MHz. The selectivity of the receiver is also improved by using a SAW. In typical automotive applications, a SAW is used. 4 T5744 4521B–RKE–01/03 T5744 Figure 5 shows a typical input matching network for f RF = 3 15 MHz and f RF = 433.92 MHz using a SAW. Figure 6 illustrates the input matching to 50 W w ithout a SAW. The input matching networks shown in Figure 6 are the reference networks for the parameters given in the electrical characteristics. Table 1. Calculation of LO and IF Frequency Conditions Local Oscillator Frequency Intermediate Frequency fRF = 315 MHz, MODE = 0 fRF = 433.92 MHz, MODE = 1 fLO = 314 MHz fLO = 432.92 MHz fIF = 1 MHz fIF = 1 MHz 300 MHz < fRF < 365 MHz, MODE = 0 f RF f LO = ------------------1 1 + --------314 f RF f LO = --------------------------1 1 + ----------------432.92 f LO f IF = --------314 365 MHz < fRF < 450 MHz, MODE = 1 f LO f IF = ----------------432.92 Figure 5. Input Matching Network with SAW Filter 8 LNAGND 8 LNAGND T5744 C3 22p L 25n 9 LNA_IN C3 47p L 25n 9 T5744 LNA_IN C16 C17 8.2p TOKO LL2012 F27NJ C16 C17 22p TOKO LL2012 F47NJ 100p fRF = 433.92 MHz L3 27n 100p fRF = 315 MHz L2 TOKO LL2012 F82NJ C2 10p 82n L3 47n RFIN C2 8.2p L2 TOKO LL2012 F33NJ 33n 1 2 IN OUT OUT_GND IN_GND CASE_GND 3,4 7,8 B3555 5 6 RFIN 1 2 IN OUT OUT_GND IN_GND CASE_GND 3,4 7,8 B3551 5 6 5 4521B–RKE–01/03 Figure 6. Input Matching Network without SAW Filter fRF = 433.92 MHz 8 LNAGND fRF = 315 MHz 8 LNAGND T5744 9 C3 15p 25n LNA_IN 9 C3 33p 25n T5744 LNA_IN RFIN 3.3p 22n 100p TOKO LL2012 F22NJ RFIN 3.3p 39n 100p TOKO LL2012 F39NJ Please note that for all coupling conditions (see Figure 5 and Figure 6), the bond wire inductivity of the LNA ground is compensated. C3 forms a series resonance circuit together with the bond wire. L = 25 nH is a feed inductor to establish a DC path. Its value is not critical but must be large enough not to detune the series resonance circuit. For cost reduction, this inductor can be easily printed on the PCB. This configuration improves the sensitivity of the receiver by about 1 dB to 2 dB. Analog Signal Processing IF Amplifier The signals coming from the RF front end are filtered by the fully integrated 4th-order IF filter. The IF center frequency is fIF = 1 MHz for applications where fRF = 315 MHz or fRF = 433.92 MHz is used. For other RF input frequencies, refer to Table 1 to determine the center frequency. The receiver T5744 employs an IF bandwidth of B IF = 6 00 kHz and can be used together with the U2741B in ASK mode. RSSI Amplifier The subsequent RSSI amplifier enhances the output signal of the IF amplifier before it is fed into the demodulator. The dynamic range of this amplifier is DRRSSI = 60 dB. If the RSSI amplifier is operated within its linear range, the best S/N ratio is maintained. If the dynamic range is exceeded by the transmitter signal, the S/N ratio is defined by the ratio of the maximum RSSI output voltage and the RSSI output voltage due to a disturber. The dynamic range of the RSSI amplifier is exceeded if the RF input signal is about 60 dB higher compared to the RF input signal at full sensitivity. The output voltage of the RSSI amplifier (VRSSI) is available at Pin RSSI. Using the RSSI output signal, the signal strength of different transmitters can be distinguished. The usable input power range PRef is -100 dBm to -55 dBm. Since different RF input networks may exhibit slightly different values for the LNA gain, the sensitivity values given in the electrical characteristics refer to a specific input matching. This matching is illustrated in Figure 6 and exhibits the best possible sensitivity. Pin RSSI 6 T5744 4521B–RKE–01/03 T5744 Figure 7. RSSI Characteristics 3.0 2.8 2.6 Tamb = 40°C 2.4 2.2 2.0 1.8 1.6 min. 1.4 1.2 1.0 -130.0 105°C 25°C max. VRRSI (V) -110.0 -90.0 -70.0 -50.0 -30.0 PRef (dBm) ASK Demodulator and Data Filter The signal coming from the RSSI amplifier is converted into the raw data signal by the ASK demodulator. An automatic threshold control circuit (ATC) is employed to set the detection reference voltage to a value where a good signal-to-noise ratio is achieved. This circuit also implies the effective suppression of any kind of inband noise signals or competing transmitters. If the S/N ratio exceeds 10 dB, the data signal can be detected properly. The output signal of the demodulator is filtered by the data filter before it is fed into the digital signal processing circuit. The data filter improves the S/N ratio as its passband can be adopted to the characteristics of the data signal. The data filter consists of a 1storder highpass and a 1st-order lowpass filter. The highpass filter cut-off frequency is defined by an external capacitor connected to Pin CDEM. The cut-off frequency of the highpass filter is defined by the following formula: 1 fcu_DF = ------------------------------------------------2 ´ p ´ R 1 ´ CDEM Recommended values for CDEM are given in the electrical characteristics. The cut-off frequency of the lowpass filter is defined by the selected baudrate range (BR_Range). BR_Range is defined by the Pins BR_0 and BR_1. BR_Range must be set in accordance to the used baudrate. BR_1 BR_0 BR_Range 0 0 1 1 0 1 0 1 0 1 2 2 Each BR_Range is defined by a minimum and a maximum edge-to-edge time (tee_sig). These limits are defined in the electrical characteristics. They should not be exceeded to maintain full sensitivity of the receiver. 7 4521B–RKE–01/03 Receiving Characteristics The RF receiver T5744 can be operated with and without a SAW front-end filter. In a typical automotive application, a SAW filter is used to achieve better selectivity. The selectivity with and without a SAW front-end filter is illustrated in Figure 7. Note that the mirror frequency is reduced by 40 dB. The plots are printed relatively to the maximum sensitivity. If a SAW filter is used, an insertion loss of about 4 dB must be considered. When designing the system in terms of receiving bandwidth, the LO deviation must be considered as it also determines the IF center frequency. The total LO deviation is calculated to be the sum of the deviation of the crystal and the XTO deviation of the T5744. Low-cost crystals are specified to be within ±100 ppm. The XTO deviation of the T5744 is an additional deviation due to the XTO circuit. This deviation is specified to be ±30 ppm. If a crystal of ±100 ppm is used, the total deviation is ±130 ppm in that case. Note that the receiving bandwidth and the IF-filter bandwidth are equivalent. Figure 8. Receiving Frequency Response 0.0 without SAW -20.0 dP (dB) -40.0 -60.0 -80.0 with SAW -100.0 -6.0 -5.0 -4.0 -3.0 -2.0 -1.0 0.0 1.0 2.0 3.0 4.0 5.0 6.0 df (MHz) Basic Clock Cycle of the Digital Circuitry The complete timing of the digital circuitry and the analog filtering is derived from one clock. According to Figure 9, this clock cycle TClk is derived from the crystal oscillator (XTO) in combination with a divider. The division factor is controlled by the logical state at Pin MODE. According to chapter 'RF Front End', the frequency of the crystal oscillator (fXTO) is defined by the RF input signal (fRFin) which also defines the operating frequency of the local oscillator (fLO). Figure 9. Generation of the Basic Clock Cycle T Clk MODE Divider :14/:10 f 16 DVCC 15 XTO XTO 14 L : USA(:10) H: Europe(:14) XTO 8 T5744 4521B–RKE–01/03 T5744 Pin MODE can now be set in accordance with the desired clock cycle TClk. TClk controls the following application-relevant parameters: Timing of the analog and digital signal processing IF filter center frequency (fIF0) Most applications are dominated by two transmission frequencies: fSend = 315 MHz is mainly used in USA, fSend = 433.92 MHz in Europe. In order to ease the usage of all TClkdependent parameters, the electrical characteristics display three conditions for each parameter. • • • Application USA (fXTO = 4.90625 MHz, MODE = L, TClk = 2.0383 µs) Application Europe (fXTO = 6.76438 MHz, MODE = H, TClk = 2.0697 µs) Other applications (TClk is dependent on fXTO and on the logical state of Pin MODE. The electrical characteristic is given as a function of TClk). The clock cycle of some function blocks depends on the selected baud rate range (BR_Range) which is defined by the Pins BR_0 and BR_1. This clock cycle T XClk is defined by the following formulas for further reference: BR_Range = BR_Range0: BR_Range1: BR_Range2: BR_Range3: TXClk = 8 ´ TClk TXClk = 4 ´ TClk TXClk = 2 ´ TClk TXClk = 1 ´ TClk Pin ENABLE Via the Pin ENABLE the operating mode of the receiver can be selected (see Figure 10 and Figure 11). If the Pin ENABLE is held to Low, the receiver remains in sleep mode. All circuits for signal processing are disabled and only the XTO is running in that case. The current consumption is IS = ISoff in that case. During the sleep mode the receiver is not sensitive to a transmitter signal. To activate the receiver, the Pin ENABLE must be held to High. During the start-up period, TStartup, all signal processing circuits are enabled and settled. The duration of the start-up period depends on the selected baud-rate range (BR_Range). After the start-up period, all circuits are in a stable condition and the receiver is in the receiving mode. In receiving mode, the internal data signal (Dem_out) is switched to Pin DATA. To avoid incorrect timing at the begin of the data stream, the begin is synchronized to a falling edge of the incoming data signal. The receiver stays in the receiving mode until it is switched back to sleep mode via Pin ENABLE. During start-up and receiving mode, the current consumption is IS = ISon. 9 4521B–RKE–01/03 Figure 10. Enable Timing (1) Dem_out ENABLE DATA Sleep mode Start-up mode Receiving mode tee_sig I S = I Soff I S = I Son TStart-up I S = I Son Figure 11. Enable Timing (2) Dem_out ENABLE DATA Sleep mode Start-up mode Receiving mode tee_sig I S = I Soff I S = I Son TStart-up I S = I Son Digital Signal Processing The data from the ASK demodulator (Dem_out) is digitally processed in different ways and as a result converted into the output signal DATA. This processing depends on the selected baudrate range (BR_Range). Figure 12 illustrates how Dem_out is synchronized by the extended basic clock cycle TXClk. Data can change its state only after TXClk has elapsed. The edge-to-edge time period tee_sig of the DATA signal as a result is always an integral multiple of TXClk. The minimum time period between two edges of the data signal is limited to tee_sig ³ TDATA_min. This implies an efficient suppression of spikes at the DATA output. At the same time it limits the maximum frequency of edges at DATA. This eases the interrupt handling of a connected microcontroller. 10 T5744 4521B–RKE–01/03 T5744 Figure 12. Synchronization of the Demodulator Output TXClk Dem_out Data_out (DATA) tee_sig Figure 13. Debouncing of the Demodulator Output Dem_out DATA tDATA_min tDATA_min tDATA_min tee tee tee Absolute Maximum Ratings Parameters Symbol Min. Max. Unit Supply voltage Power dissipation Juntion temperature Storage temperature Ambient temperature Maximum input level, input matched to 50 W VS Ptot Tj Tstg Tamb Pin_max -55 -40 6 450 150 +125 +105 10 V mW °C °C °C dBm Thermal Resistance Parameters Symbol Value Unit Junction ambient SO20 package Junction ambient SSO20 package RthJA RthJA 100 100 K/W K/W 11 4521B–RKE–01/03 Electrical Characteristics All parameters refer to GND, Tamb = -40°C to +105°C, VS = 4.5 V to 5.5 V, f0 = 433.92 MHz and f0 = 315 MHz, unless otherwise specified. (VS = 5 V, Tamb = 25°C) Parameters Test Conditions Symbol 6.76438 MHz Osc. (MODE:1) Min. Typ. Max. 4.90625 MHz Osc. (MODE:0) Min. Typ. Max. Variable Oscillator Unit Min. Typ. Max. Basic Clock Cycle of the Digital Circuitry Basic clock cycle Extended basic clock cycle MODE = 0 (USA) MODE = 1 (Europe) BR_Range0 BR_Range1 BR_Range2 BR_Range3 BR_Range0 BR_Range1 BR_Range2 BR_Range3 TClk 2.0383 2.0697 2.0697 2.0383 16.3 8.2 4.1 2.0 1827 1045 1045 653 1/(fxto/10) 1/(fxto/14) 8 ´ TClk 4 ´ TClk 2 ´ TClk 1 ´ TClk 896.5 512.5 512.5 320.5 ´ TClk 1/(fxto/10) 1/(fxto/14) 8 ´ TClk 4 ´ TClk 2 ´ TClk 1 ´ TClk 896.5 512.5 512.5 320.5 ´ TClk µs µs µs µs µs µs µs µs µs µs µs TXClk 16.6 8.3 4.1 2.1 1855 1061 1061 663 16.6 8.3 4.1 2.1 1855 1061 1061 663 16.3 8.2 4.1 2.0 1827 1045 1045 653 Start-up time (see Figure 10 and Figure 11) TStartup Receiving Mode Intermediate frequency Minimum time period between edges at Pin DATA Edge to edge time period of the data signal for full sensitivity MODE=0 (USA) MODE=1 (Europe) fIF 1.0 165 83 41.4 20.7 165 83 41.4 20.7 163 81 40.7 20.4 1.0 fXTO ´ 64 / 314 fXTO ´ 64 / 432.92 163 81 40.7 20.4 10 ´ TXClk 10 ´ TXCl 10´ TXClk 10 ´ TXClk BR_Range ´ 2 µs/TCLK 10 ´ TXClk 10 ´ TXCl 10´ TXClk 10 ´ TXClk MHz MHz µs µs µs µs BR_Range0 BR_Range1 BR_Range2 BR_Range3 (Figure 13) BR_Range0 BR_Range1 BR_Range2 BR_Range3 (Figure 10) TDATA_min tee_sig 400 200 100 50 8479 8479 8479 8479 400 200 100 50 8350 8350 8350 8350 4097 ´ TCLK µs µs µs µs Electrical Characteristics (continued) Parameters Test Conditions Symbol Min. Typ. Max. Unit Current consumption Sleep mode (XTO active) IC active (startup-, receiving mode) Pin DATA = H ISoff ISon 190 7.1 276 8.7 µA mA LNA Mixer Third-order intercept point LNA/ mixer/ IF amplifier input matched according to Figure 6 Input matched according to Figure 6, required according to I-ETS 300220 Input matching according to Figure 6 at 433.92 MHz at 315 MHz Input matched according to Figure 6, referred to RFin IIP3 -28 dBm LO spurious emission at RFIn Noise figure LNA and mixer (DSB) LNA_IN input impedance 1 dB compression point (LNA, mixer, IF amplifier) ISLORF NF ZiLNA_IN IP1db -73 -57 dBm 7 1.0 || 1.56 1.3 || 1.0 -40 dB kW || pF kW || pF dBm 12 T5744 4521B–RKE–01/03 T5744 Electrical Characteristics (continued) Parameters Test Conditions Symbol Min. Typ. Max. Unit Maximum input level Local Oscillator Input matched according to Figure 6, BER £ 10-3 Pin_max -20 dBm Operating frequency range VCO Phase noise VCO / LO fosc = 432.92 MHz at 1 MHz at 10 MHz at ± fXTO fVCO L (fm) 299 449 MHz -93 -113 -55 190 -90 -110 -47 dBC/Hz dBC/Hz dBC MHz/V Spurious of the VCO VCO gain Loop bandwidth of the PLL KVCO For best LO noise (design parameter) R1 = 820 W C9 = 4.7 nF C10 = 1 nF XTO crystal frequency, appropriate load capacitance must be connected to XTAL fXTAL = 6.764375 MHz (EU) fXTAL = 4.90625 MHz (US) BLoop 100 kHz Capacitive load at Pin LF XTO operating frequency CLF_tot 10 nF fXTO 6.764375 -30 ppm 4.90625 -30 ppm 6.764375 4.90625 6.764375 +30 ppm 4.90625 +30 ppm 150 220 6.5 MHz MHz W W Series resonance resistor of the crystal Static capacitance of the crystal Analog Signal Processing fXTO = 6.764 MHz 4.906 MHz RS Co pF Input sensitivity Input matched according to Figure 6 ASK (level of carrier) BER £ 10-3 (Manchester), fin = 433.92 MHz/ 315 MHz T = 25°C, VS = 5 V, fIF = 1 MHz BR_Range0 (1 kBd) BR_Range1 (2 kBd) BR_Range2 (4kBd) BR_Range3 (8 kBd) PRef_ASK -107 -105 -103 -101 DPRef -110 -108 -106 -104 -112 -110 -108 -106 dBm dBm dBm dBm Sensitivity variation for the full operating range compared to Tamb = 25°C, VS = 5 V Sensitivity variation for full operating range including IF filter compared to Tamb = 25°C, VS = 5 V S/N ratio to suppress inband noise signals fin = 433.92 MHz/ 315 MHz fIF = 1 MHz PASK = PRef_ASK + DPRef fin = 433.92 MHz/ 315 MHz fIF = 0.79 MHz to 1.21 MHz fIF = 0.73 MHz to 1.27 MHz PASK = PRef_ASK + DPRef +2.5 -1.5 dB DPRef +5.5 +7.5 10 -1.5 -1.5 12 dB dB dB SNR 13 4521B–RKE–01/03 Electrical Characteristics (continued) Parameters Test Conditions Symbol Min. Typ. Max. Unit Dynamic range RSSI amplifier RSSI output voltage range RSSI gain RI of Pin CDEM for cut-off frequency calculation Recommended CDEM for best performance DRRSSI VRSSI GRSSI 1.0 60 3.0 20 28 40 33 18 10 6.8 1.75 3.5 7.0 14.0 2.2 4.4 8.8 17.6 2.65 5.3 10.6 21.2 55 dB V mV/dB kW nF nF nF nF kHz kHz kHz kHz 1 fcu_DF = ------------------------------------------------2 ´ p ´ R 1 ´ CDEM BR_Range0 BR_Range1 BR_Range2 BR_Range3 Upper cut-off frequency BR_Range0 BR_Range1 BR_Range2 BR_Range3 RI CDEM Upper cut-off frequency data filter fu Digital Ports Data output - Saturation voltage LOW - Internal pull-up resistor ENABLE input - Low-level input voltage - High-level input voltage MODE input - Low-level input voltage - High-level input voltage BR_0 input - Low-level input voltage - High-level input voltage BR_1 input - Low-level input voltage - High-level input voltage TEST input - Low-level input voltage Iol = 1 mA VOI RPup VIl VIh VIl VIh VIl VIh VIl VIh 39 0.08 50 0.3 65 0.2 ´ VS V kW V V V V V V V V V Sleep mode Receiving mode Division factor = 10 Division factor = 14 0.8 ´ VS 0.8 ´ VS 0.2 ´ VS 0.8 ´ VS 0.2 ´ VS 0.8 ´ VS 0.2 ´ VS Test input must always be set to LOW VIl 0.2 ´ VS 14 T5744 4521B–RKE–01/03 T5744 Figure 14. Application Circuit: fRF = 433.92 MHz, without SAW Filter VS C7 2.2uF 10% GND C6 10nF 10% C14 39nF 5% 1 2 3 4 5 6 7 T5744 BR_0 BR_1 CDEM AVCC AGND DGND MIXVCC DATA ENABLE TEST RSSI MODE DVCC XTO LFGND LF LFVCC 20 19 18 17 16 15 14 13 12 11 DATA ENABLE RSSI Q1 C11 C13 10nF 10% C3 15pF 5% np0 8 LNAGND 9 LNA_IN 10 NC 12pF 6.76438MHz 2% np0 C15 150pF 10% C12 10nF 10% C8 150pF 10% KOAX C17 3.3pF 5% np0 C16 100pF 5% np0 L2 TOKO LL2012 F22NJ 22nH 5% R1 820 5% C9 4.7nF 5% C10 1nF 5% Figure 15. Application Circuit: fRF = 315 MHz, without SAW Filter VS C7 2.2uF 10% GND C13 10nF 10% C6 10nF 10% T5744 C14 39nF 5% 1 2 3 4 5 6 7 8 9 10 BR_0 BR_1 CDEM AVCC AGND DGND MIXVCC LNAGND LNA_IN NC DATA ENABLE TEST RSSI MODE DVCC XTO LFGND LF LFVCC 20 19 18 17 16 15 14 13 12 11 DATA ENABLE RSSI Q1 4.90625MHz C11 15pF 2% np0 C3 33pF 5% np0 C15 150pF 10% C12 10nF 10% C8 150pF 10% KOAX C17 3.3pF 5% np0 C16 100pF 5% np0 L2 TOKO LL2012 F39NJ 39nH 5% R1 820 5% C9 4.7nF 5% C10 1nF 5% 15 4521B–RKE–01/03 Figure 16. Application Circuit: fRF = 433.92 MHz, with SAW Filter VS C7 2.2uF 10% GND C13 10nF 10% C6 10nF 10% T5744 C14 39nF 5% 1 2 3 4 5 6 7 BR_0 BR_1 CDEM AVCC AGND DGND MIXVCC DATA ENABLE TEST RSSI MODE DVCC XTO LFGND LF LFVCC 20 19 18 17 16 15 14 13 12 11 DATA ENABLE RSSI Q1 C11 C3 22pF 5% np0 8 LNAGND 9 LNA_IN 10 NC 6.76438MHz 12pF 2% np0 C15 150pF 10% C16 100pF 5% np0 C17 C12 10nF 10% C8 150pF 10% 8,2pF 5% np0 L3 TOKO LL2012 F27 NJ 27nH 5% R1 820 5% C9 4.7nF 5% C10 1nF 5% KOAX L2 TOKO LL2012 F33NJ 33nH 5% C2 8.2pF 5% np0 1 2 3 4 IN IN_GND CASE_GND CASE_GND B3555 OUT OUT_GND CASE_GND CASE_GND 5 6 7 8 Figure 17. Application Circuit: fRF = 315 MHz, witht SAW Filter VS C7 2.2uF 10% GND C13 10nF 10% C6 10nF 10% T5744 C14 39n F 5% 1 2 3 4 5 6 7 8 9 10 BR_0 BR_1 CDEM AVCC AGND DGND MIXVCC LNAGND LNA_IN NC DATA ENABLE TEST RSSI MODE DVCC XTO LFGND LF LFVCC 20 19 18 17 16 15 14 13 12 11 DATA ENABLE RSSI Q1 C11 C3 47pF 5% np0 C15 150pF 10% 15pF 4.90625MHz 2% np0 C16 100pF 5% np0 C17 C12 10nF 10% C8 150pF 10% 22pF 5% np0 L3 TOKO LL2012 F47NJ 47nH 5% R1 820 5% C9 4.7nF 5% C10 1nF 5% KOAX L2 TOKO LL2012 F82NJ C2 82nH 10pF 5% 5% np0 1 2 3 4 IN IN_GND CASE_GND CASE_GND B3551 OUT OUT_GND CASE_GND CASE_GND 5 6 7 8 16 T5744 4521B–RKE–01/03 T5744 Ordering Information Extended Type Number Package Remarks T5744-TKS T5744-TKQ T5744-TGS T5744-TGQ SSO20 SSO20 SO20 SO20 Tube Taped and reeled Tube Taped and reeled Package Information Package SO20 Dimensions in mm 12.95 12.70 9.15 8.65 7.5 7.3 2.35 0.25 10.50 10.20 11 0.4 1.27 11.43 20 0.25 0.10 technical drawings according to DIN specifications 1 10 17 4521B–RKE–01/03 Package SSO20 Dimensions in mm 6.75 6.50 5.7 5.3 4.5 4.3 1.30 0.25 0.65 5.85 20 11 0.15 0.05 0.15 6.6 6.3 technical drawings according to DIN specifications 1 10 18 T5744 4521B–RKE–01/03 Atmel Headquarters Corporate Headquarters 2325 Orchard Parkway San Jose, CA 95131 TEL 1(408) 441-0311 FAX 1(408) 487-2600 Atmel Operations Memory 2325 Orchard Parkway San Jose, CA 95131 TEL 1(408) 441-0311 FAX 1(408) 436-4314 RF/Automotive Theresienstrasse 2 Postfach 3535 74025 Heilbronn, Germany TEL (49) 71-31-67-0 FAX (49) 71-31-67-2340 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906 TEL 1(719) 576-3300 FAX 1(719) 540-1759 Europe Atmel Sarl Route des Arsenaux 41 Case Postale 80 CH-1705 Fribourg Switzerland TEL (41) 26-426-5555 FAX (41) 26-426-5500 Microcontrollers 2325 Orchard Parkway San Jose, CA 95131 TEL 1(408) 441-0311 FAX 1(408) 436-4314 La Chantrerie BP 70602 44306 Nantes Cedex 3, France TEL (33) 2-40-18-18-18 FAX (33) 2-40-18-19-60 Biometrics/Imaging/Hi-Rel MPU/ High Speed Converters/RF Datacom Avenue de Rochepleine BP 123 38521 Saint-Egreve Cedex, France TEL (33) 4-76-58-30-00 FAX (33) 4-76-58-34-80 Asia Room 1219 Chinachem Golden Plaza 77 Mody Road Tsimhatsui East Kowloon Hong Kong TEL (852) 2721-9778 FAX (852) 2722-1369 ASIC/ASSP/Smart Cards Zone Industrielle 13106 Rousset Cedex, France TEL (33) 4-42-53-60-00 FAX (33) 4-42-53-60-01 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906 TEL 1(719) 576-3300 FAX 1(719) 540-1759 Scottish Enterprise Technology Park Maxwell Building East Kilbride G75 0QR, Scotland TEL (44) 1355-803-000 FAX (44) 1355-242-743 Japan 9F, Tonetsu Shinkawa Bldg. 1-24-8 Shinkawa Chuo-ku, Tokyo 104-0033 Japan TEL (81) 3-3523-3551 FAX (81) 3-3523-7581 e-mail literature@atmel.com Web Site http://www.atmel.com © Atmel Corporation 2002. Atmel Corporation makes no warranty for the use of its products, other than those expressly contained in the Company’s standard warranty which is detailed in Atmel’s Terms and Conditions located on the Company’s web site. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Atmel are granted by the Company in connection with the sale of Atmel products, expressly or by implication. Atmel’s products are not authorized for use as critical components in life support devices or systems. Atmel ® i s the registered trademark of Atmel. Other terms and product names may be the trademarks of others. Printed on recycled paper. 4521B–RKE–01/03 xM This datasheet has been download from: www.datasheetcatalog.com Datasheets for electronics components.
T5744
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一种光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,包括输入侧的发光二极管引脚和输出侧的晶体管引脚。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过光电效应实现电信号隔离,适用于数字信号传输。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm。
T5744 价格&库存
很抱歉,暂时无法提供与“T5744”相匹配的价格&库存,您可以联系我们找货
