Features
• Integrated PLL Loop Filter • ESD Protection also at ANT1/ANT2
(4 kV HBM/200 V MM; Except Pin 2: 4 kV HBM/100 V MM)
• High Output Power (5.5 dBm) with Low Supply Current (8.5 mA) • Modulation Scheme ASK/FSK • • • • • • • •
– FSK Modulation is Achieved by Connecting an Additional Capacitor Between the XTAL Load Capacitor and the Open Drain Output of the Modulating Microcontroller Easy to Design-in Due to Excellent Isolation of the PLL from the PA and Power Supply Single Li-cell for Power Supply Supply Voltage 2.0 V to 4.0 V in the Temperature Range of -40° C to 85° C/125° C Package TSSOP8L Single-ended Antenna Output with High Efficient Power Amplifier CLK Output for Clocking the Microcontroller One-chip Solution with Minimum External Circuitry 125° C Operation for Tire Pressure Systems
UHF ASK/FSK Transmitter T5750
Description
The T5750 is a PLL transmitter IC which has been developed for the demands of RF low-cost transmission systems at data rates up to 32 kBaud. The transmitting frequency range is 868 MHz to 928 MHz. It can be used in both FSK and ASK systems.
Preliminary
Figure 1. System Block Diagram
UHF ASK/FSK Remote control transmitter UHF ASK/FSK Remote control receiver
1 Li cell
T5750
T5760/ T5761
PLL
Demod.
Control
1...3
µC
Keys
Encoder M44Cx9x
XTO
IF Amp
Antenna Antenna VCO PLL XTO
Power amp.
LNA
VCO
Rev. 4546B–RKE–07/04
Pin Configuration
Figure 2. Pinning TSSOP8L
CLK 1 8 ENABLE GND
PA_ENABLE
2 T5750
7
ANT2
3
6
VS
ANT1
4
5
XTAL
Pin Description
Pin Symbol Function Configuration
VS
1
CLK
Clock output signal for micro con roller The clock output frequency is set by the crystal to fXTAL/4
100 100
CLK
PA_ENABLE
50k
Uref=1.1V
2
PA_ENABLE
Switches on power amplifier, used for ASK modulation
20 µA
ANT1
3 4
ANT2 ANT1
Emitter of antenna output stage Open collector antenna output
ANT2
VS 1.5k 1.2k
VS
5
XTAL
Connection for crystal
XTAL
182 mA
6 7 8
VS GND ENABLE
Supply voltage Ground Enable input
See ESD protection circuitry (see Figure 8 on page 8) See ESD protection circuitry (see Figure 8 on page 8)
ENABLE 200k
2
T5750 [Preliminary]
4546B–RKE–07/04
T5750 [Preliminary]
Figure 3. Block Diagram
T5750
Power up / down CLK
1
f 4 f
64
ENABLE
8
PA_ENABLE
GND
2
PFD
7
CP ANT2 VS
3
LF
6
ANT1
XTAL
PA
4
VCO
XTO
5
PLL
General Description
This fully integrated PLL transmitter allows particularly simple, low-cost RF miniature transmitters to be assembled. The VCO is locked to 64 × fXTAL hence a 13.5672 MHz crystal is needed for a 868.3 MHz transmitter and a 14.2969 MHz crystal for a 915 MHz transmitter. All other PLL and VCO peripheral elements are integrated. The XTO is a series resonance oscillator so that only one capacitor together with a crystal connected in series to GND are needed as external elements. The crystal oscillator together with the PLL needs typically 1.7 V, VPA_ENABLE < 0.25 V Power up, VS = 3.0 V, VENABLE > 1.7 V, VPA_ENABLE > 1.7 V VS = 3.0 V, Tamb = 25° C, f = 868.3 MHz, ZLoad = (166 + j226) Ω Symbol Min. Typ. Max. 350 7
很抱歉,暂时无法提供与“T5750”相匹配的价格&库存,您可以联系我们找货
