T5753
T5753
    ATMEL(爱特梅尔)
    T5753 - UHF ASK/FSK TRANSMITTER - ATMEL Corporation
T5753 数据手册
Features • Integrated PLL Loop Filter • ESD Protection (4 kV HBM/ 200 V MM; Except Pin 2: 4 kV HBM/ 100 V MM) also at ANT1/ANT2 • High Output Power (8.0 dBm) with Low Supply Current (9.0 mA) • Modulation Scheme ASK/FSK • • • • • • • • – FSK Modulation is Achieved by Connecting an Additional Capacitor Between the XTAL Load Capacitor and the Open Drain Output of the Modulating Microcontroller Easy to Design-in Due to Excellent Isolation of the PLL from the PA and Power Supply Single Li-cell for Power Supply Supply Voltage 2.0 V to 4.0 V in the Temperature Range of -40° C to 85° C/125° C Package TSSOP8L Single-ended Antenna Output with High Efficient Power Amplifier CLK Output for Clocking the Microcontroller One-chip Solution with Minimum External Circuitry 125° C Operation for Tire Pressure Systems UHF ASK/FSK Transmitter T5753 Description The T5753 is a PLL transmitter IC which has been developed for the demands of RF low-cost transmission systems at data rates up to 32 kBaud. The transmitting frequency range is 310 MHz to 330 MHz. It can be used in both FSK and ASK systems. Figure 1. System Block Diagram UHF ASK/FSK Remote control transmitter UHF ASK/FSK Remote control receiver 1 Li cell T5753 Encoder ATARx9x XTO PLL Antenna Antenna VCO U3741B/ U3745B/ T5743/ T5744 Demod. 1...3 Control Keys IF Amp PLL XTO Power amp. LNA VCO Microcontroller Rev. 4510F–RKE–07/04 Pin Configuration Figure 2. Pinning TSSOP8L CLK 1 8 ENABLE GND PA_ENABLE 2 T5753 7 ANT2 3 6 VS ANT1 4 5 XTAL Pin Description Pin Symbol Function Configuration VS 1 CLK Clock output signal for microcontroller The clock output frequency is set by the crystal to fXTAL/4 100 100 CLK PA_ENABLE 50k Uref = 1.1V 2 PA_ENABLE Switches on power amplifier, used for ASK modulation 20 µA ANT1 3 4 ANT2 ANT1 Emitter of antenna output stage Open collector antenna output ANT2 VS 1.5k 1.2k VS 5 XTAL Connection for crystal XTAL 182 µA 6 7 8 VS GND ENABLE Supply voltage Ground Enable input See ESD protection circuitry (see Figure 8 on page 8) See ESD protection circuitry (see Figure 8 on page 8) ENABLE 200k 2 T5753 4510F–RKE–07/04 T5753 Figure 3. Block Diagram T5753 Power up/down CLK f 4 f 32 ENABLE 1 8 PA_ENABLE GND 2 PFD 7 CP ANT2 VS 3 LF 6 ANT1 XTAL PA 4 VCO XTO 5 PLL General Description This fully integrated PLL transmitter allows particularly simple, low-cost RF miniature transmitters to be assembled. The VCO is locked to 32 f XTAL h ence a 9.8438 MHz crystal is needed for a 315 MHz transmitter. All other PLL and VCO peripheral elements are integrated. The XTO is a series resonance oscillator so that only one capacitor together with a crystal connected in series to GND are needed as external elements. The crystal oscillator together with the PLL needs typically < 3 ms until the PLL is locked and the CLK output is stable. There is a wait time of ≥ 3 ms until the CLK is used for the microcontroller and the PA is switched on. The power amplifier is an open-collector output delivering a current pulse which is nearly independent from the load impedance. The delivered output power is hence controllable via the connected load impedance. This output configuration enables a simple matching to any kind of antenna or to 50 Ω. A high power efficiency of η= Pout/(IS,PA VS) of 40% for the power amplifier results when an optimized load impedance of ZLoad = (255 + j192) Ω is used at 3 V supply voltage. 3 4510F–RKE–07/04 Functional Description If ENABLE = L and the PA_ENABLE = L, the circuit is in standby mode consuming only a very small amount of current so that a lithium cell used as power supply can work for several years. With ENABLE = H the XTO, PLL and the CLK driver are switched on. If PA_ENABLE remains L only the PLL and the XTO is running and the CLK signal is delivered to the microcontroller. The VCO locks to 32 times the XTO frequency. With ENABLE = H and PA_ENABLE = H the PLL, XTO, CLK driver and the power amplifier are on. With PA_ENABLE the power amplifier can be switched on and off, which is used to perform the ASK modulation. ASK Transmission Th e T 57 5 3 i s a c t i v at e d b y E NA B L E = H . P A _ E NA B L E m us t r e ma i n L f or typically ≥ 3 ms, then the CLK signal can be taken to clock the microcontroller and the output power can be modulated by means of Pin PA_ENABLE. After transmission PA_ENABLE is switched to L and the microcontroller switches back to internal clocking. The T5753 is switched back to standby mode with ENABLE = L. Th e T 57 5 3 i s a c t i v at e d b y E NA B L E = H . P A _ E NA B L E m us t r e ma i n L f or typically ≥ 3 ms, then the CLK signal can be taken to clock the microcontroller and the power amplifier is switched on with PA_ENABLE = H. The chip is then ready for FSK modulation. The microcontroller starts to switch on and off the capacitor between the XTAL load capacitor and GND with an open-drain output port, thus changing the reference frequency of the PLL. If the switch is closed, the output frequency is lower than if the switch is open. After transmission PA_ENABLE is switched to L and the microcontroller switches back to internal clocking. The T5753 is switched back to standby mode with ENABLE = L. The accuracy of the frequency deviation with XTAL pulling method is about ±25% when the following tolerances are considered. Figure 4. Tolerances of Frequency Modulation FSK Transmission ~ VS CStray1 XTAL CStray2 CM LM C0 Crystal equivalent circuit RS C4 C5 CSwitch Using C4 = 8.2 pF ± 5%, C5 = 10 pF ± 5%, a switch port with CSwitch = 3 pF ± 10%, stray capacitances on each side of the crystal of C Stray1 = CStray2 = 1 pF ± 10%, a parallel capacitance of the crystal of C0 = 3.2 pF ± 10% and a crystal with CM = 13 fF ± 10%, an FSK deviation of ±21.5 kHz typical with worst case tolerances of ±16.25 kHz to ±28.01 kHz results. ~ CLK Output Clock Pulse Take-over An output CLK signal is provided for a connected microcontroller, the delivered signal is CMOS compatible if the load capacitance is lower than 10 pF. The clock of the crystal oscillator can be used for clocking the microcontroller. Atmel’s ATARx9x has the special feature of starting with an integrated RC-oscillator to switch on the T5753 with ENABLE = H, and after 1 ms to assume the clock signal of the transmission IC, so that the message can be sent with crystal accuracy. 4 T5753 4510F–RKE–07/04 T5753 Output Matching and Power Setting The output power is set by the load impedance of the antenna. The maximum output power is achieved with a load impedance of ZLoad,opt = (255 + j192) Ω. There must be a low resistive path to VS to deliver the DC current. The delivered current pulse of the power amplifier is 9 mA and the maximum output power is delivered to a resistive load of 400 Ω if the 1.0 pF output capacitance of the power amplifier is compensated by the load impedance. An optimum load impedance of: ZLoad = 400 Ω || j/(2 × π 1.0 pF) = (255 + j192) Ω thus results for the maximum output power of 8 dBm. The load impedance is defined as the impedance seen from the T5753’s ANT1, ANT2 into the matching network. Do not confuse this large signal load impedance with a small signal input impedance delivered as input characteristic of RF amplifiers and measured from the application into the IC instead of from the IC into the application for a power amplifier. Less output power is achieved by lowering the real parallel part of 400 Ω where the parallel imaginary part should be kept constant. Output power measurement can be done with the circuit of Figure 5. Note that the component values must be changed to compensate the individual board parasitics until the T5753 has the right load impedance ZLoad,opt = (255 + j192) Ω. Also the damping of the cable used to measure the output power must be calibrated out. Figure 5. Output Power Measurement VS C1 = 1n L1 = 56n Power meter Z = 50 Ω ZLopt ANT2 ~ C2 = 3.3p Rin 50 Ω ANT1 Application Circuit For the blocking of the supply voltage a capacitor value of C3 = 68 nF/X7R is recommended (see Figure 6 on page 6 and Figure 7 on page 7). C1 and C2 are used to match the loop antenna to the power amplifier where C 1 t ypically is 22 pF/NP0 and C2 i s 10.8 pF/NP0 (18 pF + 27 pF in series); for C2 two capacitors in series should be used to achieve a better tolerance value and to have the possibility to realize the ZLoad,opt by using standard valued capacitors. C1 forms together with the pins of T5753 and the PCB board wires a series resonance loop that suppresses the 1st harmonic, hence the position of C1 on the PCB is important. Normally the best suppression is achieved when C1 is placed as close as possible to the pins ANT1 and ANT2. The loop antenna should not exceed a width of 1.5 mm, otherwise the Q-factor of the loop antenna is too high. L1 ([50 nH to 100 nH) can be printed on PCB. C4 should be selected that the XTO runs on the load resonance frequency of the crystal. Normally, a value of 12 pF results for a 15 pF load-capacitance crystal. ~ 5 4510F–RKE–07/04 Figure 6. ASK Application Circuit S1 BPXY ATARx9x VDD 1 VSS 20 VS S2 BPXY BPXY OSC1 BPXY 7 T5753 Power up/down CLK 1 f 4 f 32 ENABLE 8 PA_ENABLE GND 2 PFD 7 C3 C2 CP ANT2 VS 3 LF 6 VS Loop Antenna C1 XTAL ANT1 XTAL PA 4 L1 VCO XTO 5 C4 PLL VS 6 T5753 4510F–RKE–07/04 T5753 Figure 7. FSK Application Circuit ATARx9x S1 BPXY VDD 1 S2 BPXY VSS 20 VS BPXY BP42/T2O 18 OSC1 BPXY 7 T5753 Power up/down CLK 1 f 4 f 32 ENABLE 8 PA_ENABLE GND 2 PFD 7 C3 C2 CP ANT2 VS 3 LF 6 VS Loop Antenna C1 ANT1 XTAL XTAL PA C5 C4 4 L1 VCO XTO 5 PLL VS 7 4510F–RKE–07/04 Figure 8. ESD Protection Circuit VS ANT1 CLK PA_ENABLE ANT2 XTAL ENABLE GND Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Parameters Supply voltage Power dissipation Junction temperature Storage temperature Ambient temperature Input voltage Note: Symbol VS Ptot Tj Tstg Tamb VmaxPA_ENABLE -55 -55 -0.3 Minimum Maximum 5 100 150 125 125 (VS + 0.3) (1) Unit V mW °C °C °C V 1. If VS + 0.3 is higher than 3.7 V, the maximum voltage will be reduced to 3.7 V. Thermal Resistance Parameters Junction ambient Symbol RthJA Value 170 Unit K/W 8 T5753 4510F–RKE–07/04 T5753 Electrical Characteristics VS = 2.0 V to 4.0 V, Tamb = -40° C to 125° C unless otherwise specified. Typical values are given at VS = 3.0 V and Tamb = 25° C. All parameters are referred to GND (pin 7). Parameters Test Conditions Power down, VENABLE < 0.25 V, -40° C to 85° C VPA-ENABLE < 0.25 V, -40°C to +125° C VPA-ENABLE < 0.25 V, 25°C (100% correlation tested) Power up, PA off, VS = 3 V, VENABLE > 1.7 V, VPA-ENABLE < 0.25 V Power up, VS = 3.0 V, VENABLE > 1.7 V, VPA-ENABLE > 1.7 V VS = 3.0 V, Tamb = 25° C, f = 315 MHz, ZLoad = (255 + j192) W Tamb = -40° C to +85° C, VS = 3.0 V VS = 2.0 V Tamb = -40°C to +125°C, VS = 3.0 V VS = 2.0 V, POut = PRef + ∆PRef Selectable by load impedance fCLK = f0/128 Load capacitance at Pin CLK = 10 pF fO ± 1 × fCLK fO ± 4 × fCLK other spurious are lower fXTO = f0/32 fXTAL = resonant frequency of the XTAL, CM ≤10 fF, load capacitance selected accordingly Tamb = -40° C to +85° C, Tamb = -40° C to +125° C Referred to fPC = fXT0, 25 kHz distance to carrier 25 kHz distance to carrier at 1 MHz at 36 MHz fVCO 310 f0/128 CLoad ≤10 pF V0h V0l Rs VS × 0.8 VS × 0.2 110 7 Symbol Min. Typ. Max. 350 7
T5753
### 物料型号 T5753-6AQ,封装为TSSOP8L。
### 器件简介 T5753是一款PLL发射器IC,专为低成本射频传输系统而开发,支持数据速率高达32 kBaud,发射频率范围在310 MHz到330 MHz之间。它可用于FSK和ASK系统。
### 引脚分配 - Pin 1: CLK,为微控制器提供时钟输出信号。 - Pin 2: PA_ENABLE,用于打开功率放大器,用于ASK调制。 - Pin 3: ANT2,天线输出级的发射器。 - Pin 4: ANT1,天线输出级的发射器。 - Pin 5: XTAL,连接晶体。 - Pin 6: VS,供电电压。 - Pin 7: GND,地。 - Pin 8: ENABLE,使能输入。
### 参数特性 - 集成PLL环滤波器。 - 集成ESD保护,4 kV HBM/200 V MM(Pin 2为4 kV HBM/100 V MM)。 - 高输出功率(8.0 dBm)与低供电电流(9.0 mA)。 - 调制方案包括ASK/FSK。 - 单锂电芯供电。 - 工作电压2.0 V至4.0 V,温度范围-40°C至85°C/125°C。
### 功能详解 T5753通过ENABLE引脚激活,可实现ASK和FSK调制。FSK调制通过在XTAL负载电容和微控制器的开漏输出之间连接额外电容实现。该IC具有单芯片解决方案,外部电路最小化。
### 应用信息 T5753可用于轮胎压力系统,支持125°C操作。它允许组装特别简单、低成本的RF微型发射器,并且所有PLL和VCO周边元件都已集成。
### 封装信息 T5753采用TSSOP8L封装,尺寸以毫米为单位。
T5753 价格&库存
很抱歉,暂时无法提供与“T5753”相匹配的价格&库存,您可以联系我们找货
