T5754
T5754
    ATMEL(爱特梅尔)
    T5754 - UHF ASK/FSK Transmitter - ATMEL Corporation
T5754 数据手册
Features • Integrated PLL Loop Filter • ESD Protection also at ANT1/ANT2 (4 kV HBM/200V MM; Except Pin 2: 4 kV HBM/100V MM) • High Output Power (7.5 dBm) with Low Supply Current (9.0 mA) • Modulation Scheme ASK/ FSK – FSK Modulation is Achieved by Connecting an Additional Capacitor Between the XTAL Load Capacitor and the Open Drain Output of the Modulating Microcontroller Easy to Design-in Due to Excellent Isolation of the PLL from the PA and Power Supply Single Li-cell for Power Supply Supply Voltage 2.0V to 4.0V in the Temperature Range of –40°C to 85°C/125°C Package TSSOP8L Single-ended Antenna Output with High Efficient Power Amplifier CLK Output for Clocking the Microcontroller One-chip Solution with Minimum External Circuitry 125° C Operation for Tire Pressure Systems • • • • • • • • UHF ASK/FSK Transmitter T5754 1. Description The T5754 is a PLL transmitter IC which has been developed for the demands of RF low-cost transmission systems at data rates up to 32 kBaud. The transmitting frequency range is 429 MHz to 439 MHz. It can be used in both FSK and ASK systems. Figure 1-1. 1 Li cell System Block Diagram UHF ASK/FSK Remote control transmitter T5754 U3741B/ U3745B/ T5743/ T5744 PLL Antenna XTO VCO Antenna PLL XTO UHF ASK/FSK Remote control receiver 1 to 3 Demod Control Microcontroller Keys Encoder ATARx9x Power amp. LNA VCO 4511I–RKE–02/07 2. Pin Configuration Figure 2-1. Pinning TSSOP8L CLK PA_ENABLE ANT2 ANT1 1 2 3 4 8 7 6 5 ENABLE GND VS XTAL Table 2-1. Pin Pin Description Symbol Function Configuration VS 1 CLK Clock output signal for micro con roller The clock output frequency is set by the crystal to fXTAL/4 100Ω CLK 100Ω PA_ENABLE 50 kΩ UREF = 1.1V 2 PA_ENABLE Switches on power amplifier, used for ASK modulation 20 µA ANT1 3 4 ANT2 ANT1 Emitter of antenna output stage Open collector antenna output ANT2 2 T5754 4511I–RKE–02/07 T5754 Table 2-1. Pin Pin Description (Continued) Symbol Function Configuration VS VS 1.5 kΩ 1.2 kΩ 5 XTAL Connection for crystal XTAL 182 µA 6 7 VS GND Supply voltage Ground See ESD protection circuitry (see Figure 4-5 on page 9) See ESD protection circuitry (see Figure 4-5 on page 9) ENABLE 200 kΩ 8 ENABLE Enable input Figure 2-2. Block Diagram T5754 Power up/down f 1 4 8 CLK ENABLE f 32 PA_ENABLE 2 PDF 7 GND CP ANT2 3 LF 6 VS ANT1 4 PA PLL VCO XTO 5 XTAL 3 4511I–RKE–02/07 3. General Description This fully integrated PLL transmitter allows particularly simple, low-cost RF miniature transmitters to be assembled. The VCO is locked to 32 fXTAL hence a 13.56 MHz crystal is needed for a 433.92 MHz transmitter. All other PLL and VCO peripheral elements are integrated. The XTO is a series resonance oscillator so that only one capacitor together with a crystal connected in series to GND are needed as external elements. The crystal oscillator together with the PLL needs typically < 1 ms until the PLL is locked and the CLK output is stable. There is a wait time of ≥ 1 ms until the CLK is used for the microcontroller and the PA is switched on. The power amplifier is an open-collector output delivering a current pulse which is nearly independent from the load impedance. The delivered output power is hence controllable via the connected load impedance. This output configuration enables a simple matching to any kind of antenna or to 50Ω. A high power efficiency of η= Pout/(IS,PA VS) of 36% for the power amplifier results when an optimized load impedance of ZLoad = (166 + j223)Ω is used at 3V supply voltage. 4. Functional Description If ENABLE = L and the PA_ENABLE = L, the circuit is in standby mode consuming only a very small amount of current so that a lithium cell used as power supply can work for several years. With ENABLE = H the XTO, PLL and the CLK driver are switched on. If PA_ENABLE remains L only the PLL and the XTO is running and the CLK signal is delivered to the microcontroller. The VCO locks to 32 times the XTO frequency. With ENABLE = H and PA_ENABLE = H the PLL, XTO, CLK driver and the power amplifier are on. With PA_ENABLE the power amplifier can be switched on and off, which is used to perform the ASK modulation. 4.1 ASK Transmission The T5754 is activated by ENABLE = H. PA_ENABLE must remain L for t ≥1 ms, then the CLK signal can be taken to clock the microcontroller and the output power can be modulated by means of pin PA_ENABLE. After transmission PA_ENABLE is switched to L and the microcontroller switches back to internal clocking. The T5754 is switched back to standby mode with ENABLE = L. 4.2 FSK Transmission The T5754 is activated by ENABLE = H. PA_ENABLE must remain L for t ≥1 ms, then the CLK signal can be taken to clock the microcontroller and the power amplifier is switched on with PA_ENABLE = H. The chip is then ready for FSK modulation. The microcontroller starts to switch on and off the capacitor between the XTAL load capacitor and GND with an open-drain output port, thus changing the reference frequency of the PLL. If the switch is closed, the output frequency is lower than if the switch is open. After transmission PA_ENABLE is switched to L and the microcontroller switches back to internal clocking. The T5754 is switched back to standby mode with ENABLE = L. The accuracy of the frequency deviation with XTAL pulling method is about ±25% when the following tolerances are considered. 4 T5754 4511I–RKE–02/07 T5754 Figure 4-1. Tolerances of Frequency Modulation VS CStray1 LM XTAL CM RS CStray2 C4 C0 Crystal equivalent circuit C5 CSwitch Using C4 = 9.2 pF ±2%, C5 = 6.8 pF ±5%, a switch port with CSwitch = 3 pF ±10%, stray capacitances on each side of the crystal of CStray1 = CStray2 = 1 pF ±10%, a parallel capacitance of the crystal of C0 = 3.2 pF ±10% and a crystal with CM = 13 fF ±10%, an FSK deviation of ±21 kHz typical with worst case tolerances of ±16.3 kHz to ±28.8 kHz results. 4.3 CLK Output An output CLK signal is provided for a connected microcontroller, the delivered signal is CMOS compatible if the load capacitance is lower than 10 pF. 4.3.1 Clock Pulse Take-over The clock of the crystal oscillator can be used for clocking the microcontroller. Atmel ® ’s ATARx9x has the special feature of starting with an integrated RC-oscillator to switch on the T5754 with ENABLE = H, and after 1 ms to assume the clock signal of the transmission IC, so that the message can be sent with crystal accuracy. Output Matching and Power Setting The output power is set by the load impedance of the antenna. The maximum output power is achieved with a load impedance of ZLoad,opt = (166 + j223)Ω. There must be a low resistive path to VS to deliver the DC current. The delivered current pulse of the power amplifier is 9 mA and the maximum output power is delivered to a resistive load of 465Ω if the 1.0 pF output capacitance of the power amplifier is compensated by the load impedance. An optimum load impedance of: ZLoad = 465Ω || j/(2 × π 1.0 pF) = (166 + j223)Ω thus results for the maximum output power of 7.5 dBm. The load impedance is defined as the impedance seen from the T5754’s ANT1, ANT2 into the matching network. Do not confuse this large signal load impedance with a small signal input impedance delivered as input characteristic of RF amplifiers and measured from the application into the IC instead of from the IC into the application for a power amplifier. Less output power is achieved by lowering the real parallel part of 465Ω where the parallel imaginary part should be kept constant. Output power measurement can be done with the circuit of Figure 4-2 on page 6. Note that the component values must be changed to compensate the individual board parasitics until the T5754 has the right load impedance ZLoad,opt = (166 + j223)Ω. Also the damping of the cable used to measure the output power must be calibrated out. 4.3.2 5 4511I–RKE–02/07 Figure 4-2. Output Power Measurement VS C1 1 nF L1 ANT1 ZLopt ANT2 33 nH C2 2.2 pF Z = 50Ω Power meter Rin 50Ω 4.4 Application Circuit For the supply-voltage blocking capacitor C3 a value of 68 nF/X7R is recommended (see Figure 4-3 on page 7 and Figure 4-4 on page 8). C1 and C2 are used to match the loop antenna to the power amplifier where C1 typically is 8.2 pF/NP0 and C2 is 6 pF/NP0 (10 pF + 15 pF in series); for C2 two capacitors in series should be used to achieve a better tolerance value and to have the possibility to realize the ZLoad,opt by using standard valued capacitors. C1 forms together with the pins of T5754 and the PCB board wires a series resonance loop that suppresses the 1st harmonic, hence the position of C1 on the PCB is important. Normally the best suppression is achieved when C1 is placed as close as possible to the pins ANT1 and ANT2. The loop antenna should not exceed a width of 1.5 mm, otherwise the Q-factor of the loop antenna is too high. L1 ([50 nH to 100 nH) can be printed on PCB. C4 should be selected that the XTO runs on the load resonance frequency of the crystal. Normally, a value of 12 pF results for a 15 pF load-capacitance crystal. 6 T5754 4511I–RKE–02/07 T5754 Figure 4-3. ASK Application Circuit S1 BPXY ATARx9x 1 VDD VS VSS 20 S2 BPXY BPXY OSC1 7 BPXY T5754 Power up/down CLK 1 f 4 8 ENABLE f 32 PA_ENABLE 2 PDF 7 GND C3 CP ANT2 3 Loop Antenna C1 LF 6 VS VS C2 ANT1 4 L1 PA PLL VCO XTO 5 XTAL XTAL C4 VS 7 4511I–RKE–02/07 Figure 4-4. FSK Application Circuit S1 BPXY ATARx9x 1 VDD VS VSS 20 S2 BPXY BPXY 18 OSC1 7 BP42/T2O BPXY T5754 Power up/down CLK 1 f 4 8 ENABLE f 32 PA_ENABLE 2 PDF 7 GND C3 CP ANT2 3 Loop Antenna C1 LF 6 VS C5 ANT1 4 L1 PA PLL VCO XTO 5 C4 XTAL XTAL VS C2 VS 8 T5754 4511I–RKE–02/07 T5754 Figure 4-5. ESD Protection Circuit VS ANT1 CLK PA_ENABLE ANT2 XTAL ENABLE GND 5. Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Parameters Supply voltage Power dissipation Junction temperature Storage temperature Ambient temperature Input voltage Note: Symbol VS Ptot Tj Tstg Tamb VmaxPA_ENABLE –55 –55 –0.3 Minimum Maximum 5 100 150 125 125 (VS + 0.3) (1) Unit V mW °C °C °C V 1. If VS + 0.3 is higher than 3.7V, the maximum voltage will be reduced to 3.7V. 6. Thermal Resistance Parameters Junction ambient Symbol RthJA Value 170 Unit K/W 7. Electrical Characteristics VS = 2.0V to 4.0V, Tamb = –40°C to 125°C unless otherwise specified. Typical values are given at VS = 3.0 V and Tamb = 25°C. All parameters are referred to GND (pin 7). Parameters Test Conditions Power down VENABLE < 0.25V, –40°C to 85°C VPA-ENABLE < 0.25V, –40°C to +125°C VPA-ENABLE < 0.25V, 25°C (100% correlation tested) Power up, PA off, VS = 3V, VENABLE > 1.7V, VPA-ENABLE < 0.25V Power up, VS = 3.0V, VENABLE > 1.7V, VPA-ENABLE > 1.7V VS = 3.0V, Tamb = 25°C, f = 433.92 MHz, ZLoad = (166 + j233)Ω Symbol Min. Typ. Max. 350 7 < 10 Unit nA µA nA Supply current IS_Off Supply current Supply current Output power Note: IS IS_Transmit PRef 5.5 3.7 9 7.5 4.8 11.6 10 mA mA dBm 1. If VS is higher than 3.6V, the maximum voltage will be reduced to 3.6V. 9 4511I–RKE–02/07 7. Electrical Characteristics (Continued) VS = 2.0V to 4.0V, Tamb = –40°C to 125°C unless otherwise specified. Typical values are given at VS = 3.0 V and Tamb = 25°C. All parameters are referred to GND (pin 7). Parameters Output power variation for the full temperature range Test Conditions Tamb = –40°C to +85°C, VS = 3.0V VS = 2.0V Tamb = –40°C to +125°C, VS = 3.0V VS = 2.0V POut = PRef + ∆PRef Selectable by load impedance fCLK = f0/128 Load capacitance at pin CLK = 10 pF fO ±1 × fCLK fO ±4 × fCLK other spurious are lower fXTO = f0/32 fXTAL = resonant frequency of the XTAL, CM ≤ 10 fF, load capacitance selected accordingly Tamb = –40°C to +85°C Tamb = –40°C to +125°C Referred to fPC = fXT0, 25 kHz distance to carrier 25 kHz distance to carrier at 1 MHz at 36 MHz fVCO 429 f0/128 CLoad ≤10 pF V0h V0l Rs Duty cycle of the modulation signal = 50% Duty cycle of the modulation signal = 50% Low level input voltage High level input voltage Input current high Low level input voltage High level input voltage Input current high VIl VIh IIn VIl VIh IIn 0 0 1.7 20 1.7 0.25 VS(1) 5 VS × 0.8 VS × 0.2 110 7 32 32 0.25 Symbol ∆PRef ∆PRef ∆PRef ∆PRef POut_typ 0 Min. Typ. Max. –1.5 –4.0 –2.0 –4.5 7.5 Unit dB dB dB dB dBm Output power variation for the full temperature range Achievable output-power range Spurious emission –55 –52 dBc dBc Oscillator frequency XTO (= phase comparator frequency) fXTO –30 –40 fXTAL 250 –116 –86 –94 –125 –110 –80 –90 –121 439 +30 +40 ppm ppm kHz dBc/Hz dBc/Hz dBc/Hz dBc/Hz MHz MHz V V Ω pF kHz kHz V V µA V V µA PLL loop bandwidth Phase noise of phase comparator In loop phase noise PLL Phase noise VCO Frequency range of VCO Clock output frequency (CMOS microcontroller compatible) Voltage swing at pin CLK Series resonance R of the crystal Capacitive load at pin XT0 FSK modulation frequency rate ASK modulation frequency rate ENABLE input PA_ENABLE input Note: 1. If VS is higher than 3.6V, the maximum voltage will be reduced to 3.6V. 10 T5754 4511I–RKE–02/07 T5754 8. Ordering Information Extended Type Number T5754-6AQJ T5754-6APJ Package TSSOP8L TSSOP8L Remarks Taped and reeled, Marking: T574, Pb-free Taped and reeled, Marking: T574, small reel, Pb-free 9. Package Information Package: TSSOP 8L Dimensions in mm 0.85±0.05 1-0.15 +0.05 3±0.1 3±0.1 0.31-0.07 0.65 nom. 3 x 0.65 = 1.95 nom. 8 5 3.8±0.3 4.9±0.1 technical drawings according to DIN specifications Drawing-No.: 6.543-5083.01-4 Issue: 2; 15.03.04 1 4 5 0.15-0.02 +0.0 +0.06 0.1±0.05 11 4511I–RKE–02/07 10. Revision History Please note that the following page numbers referred to in this section refer to the specific revision mentioned, not to this document. Revision No. 4711I-RKE-02/07 4711H-RKE-09/05 History • Put datasheet in a new template • Pb-free logo on page 1 deleted • Pb-free logo on page 1 added • Ordering Information on page 11 changed • Put datasheet in a new template • Package Information (page 11): Replace old package drawing through current version • • • • • Abs. Max. Ratings table (page 9): row “Input voltage” added Abs. Max. Ratings table (page 9): table note 1 added El. Char. table (pages 9 to 10): row “PA_ENABLE input“ changed El. Char. table (pages 9 to 10): table note 1 added Ordering Information table (page 11): Remarks changed 4711G-RKE-05/05 4711F-RKE-07/04 12 T5754 4511I–RKE–02/07 Atmel Corporation 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 487-2600 Atmel Operations Memory 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 436-4314 RF/Automotive Theresienstrasse 2 Postfach 3535 74025 Heilbronn, Germany Tel: (49) 71-31-67-0 Fax: (49) 71-31-67-2340 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906, USA Tel: 1(719) 576-3300 Fax: 1(719) 540-1759 Regional Headquarters Europe Atmel Sarl Route des Arsenaux 41 Case Postale 80 CH-1705 Fribourg Switzerland Tel: (41) 26-426-5555 Fax: (41) 26-426-5500 Microcontrollers 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 436-4314 La Chantrerie BP 70602 44306 Nantes Cedex 3, France Tel: (33) 2-40-18-18-18 Fax: (33) 2-40-18-19-60 Biometrics Avenue de Rochepleine BP 123 38521 Saint-Egreve Cedex, France Tel: (33) 4-76-58-47-50 Fax: (33) 4-76-58-47-60 Asia Room 1219 Chinachem Golden Plaza 77 Mody Road Tsimshatsui East Kowloon Hong Kong Tel: (852) 2721-9778 Fax: (852) 2722-1369 ASIC/ASSP/Smart Cards Zone Industrielle 13106 Rousset Cedex, France Tel: (33) 4-42-53-60-00 Fax: (33) 4-42-53-60-01 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906, USA Tel: 1(719) 576-3300 Fax: 1(719) 540-1759 Scottish Enterprise Technology Park Maxwell Building East Kilbride G75 0QR, Scotland Tel: (44) 1355-803-000 Fax: (44) 1355-242-743 Japan 9F, Tonetsu Shinkawa Bldg. 1-24-8 Shinkawa Chuo-ku, Tokyo 104-0033 Japan Tel: (81) 3-3523-3551 Fax: (81) 3-3523-7581 Literature Requests www.atmel.com/literature Disclaimer: T he information in this document is provided in connection with Atmel products. No license, express or implied, by estoppel or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Atmel products. EXCEPT AS SET FORTH IN ATMEL’S TERMS AND CONDITIONS OF SALE LOCATED ON ATMEL’S WEB SITE, ATMEL ASSUMES NO LIABILITY WHATSOEVER AND DISCLAIMS ANY EXPRESS, IMPLIED OR STATUTORY WARRANTY RELATING TO ITS PRODUCTS INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTY OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, CONSEQUENTIAL, PUNITIVE, SPECIAL OR INCIDENTAL DAMAGES (INCLUDING, WITHOUT LIMITATION, DAMAGES FOR LOSS OF PROFITS, BUSINESS INTERRUPTION, OR LOSS OF INFORMATION) ARISING OUT OF THE USE OR INABILITY TO USE THIS DOCUMENT, EVEN IF ATMEL HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. A tmel makes no representations or warranties with respect to the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Atmel does not make any commitment to update the information contained herein. Unless specifically provided otherwise, Atmel products are not suitable for, and shall not be used in, automotive applications. Atmel’s products are not intended, authorized, or warranted for use as components in applications intended to support or sustain life. © 2007 Atmel Corporation. A ll rights reserved. A tmel ®, logo and combinations thereof, Everywhere You Are® a nd others are registered trademarks or trademarks of Atmel Corporation or its subsidiaries. Other terms and product names may be trademarks of others. 4511I–RKE–02/07
T5754
1. 物料型号: - 型号为T5754,是一款PLL发射器IC,用于低成本传输系统的RF传输,数据速率可达32kBaud,频率范围为429MHz至439MHz,适用于FSK和ASK系统。
2. 器件简介: - T5754是一款全集成PLL发射器,允许组装简单、低成本的RF微型发射器。VCO锁定至32倍的XTAL频率,因此需要一个13.56MHz的晶体来实现433.92MHz的发射器。所有其他PLL和VCO周边元件都集成在芯片中。
3. 引脚分配: - 引脚1(CLK):为微控制器提供时钟输出信号,频率由晶体决定。 - 引脚2(PA_ENABLE):用于ASK调制,打开功率放大器。 - 引脚3(ANT2)和引脚4(ANT1):天线输出级的发射器,开路集天线输出。 - 引脚5(XTAL):晶体连接。 - 引脚6(VS):供电电压。 - 引脚7(GND):地线。 - 引脚8(ENABLE):使能输入。
4. 参数特性: - 供电电压:2.0V至4.0V。 - 工作温度范围:-40°C至85°C/125°C。 - 封装:TSSOP8L。 - 单端天线输出,高效率功率放大器。 - 单芯片解决方案,外部电路最少。
5. 功能详解: - 如果ENABLE=L和PA_ENABLE=L,电路处于待机模式,消耗极少电流。 - 与ENABLE=H,XTO、PLL和CLK驱动被打开。如果PA_ENABLE保持L,只有PLL和XTO运行,CLK信号提供给微控制器。 - 与ENABLE=H和PA_ENABLE=H,PLL、XTO、CLK驱动和功率放大器都打开。PA_ENABLE用于打开和关闭功率放大器,执行ASK调制。
6. 应用信息: - 适用于轮胎压力系统,125°C操作。 - 应用电路包括供电电压阻断电容器C3,以及用于匹配环天线到功率放大器的C1和C2。
7. 封装信息: - 封装类型为TSSOP8L,有具体的尺寸图。
T5754 价格&库存
很抱歉,暂时无法提供与“T5754”相匹配的价格&库存,您可以联系我们找货
