T6818
T6818
    ATMEL(爱特梅尔)
    T6818 - Triple Halfbridge DMOS Output Driver with Serial Input Control - ATMEL Corporation
T6818 数据手册
Features • • • • • • • • • • • • • Supply Voltage up to 40 V RDSon Typically 0.5 Ω at 25°C, Maximum 1.1 Ω at 150°C Up to 1.5 A Output Current Three Half-bridge Outputs Formed by Three High-side and Three Low-side Drivers Capable to Switch all Kinds of Loads Such as DC Motors, Bulbs, Resistors, Capacitors and Inductors No Shoot-through Current Very Low Quiescent Current IS < 5 µA in Standby Mode versus Total Temperature Range Outputs Short-circuit Protected Overtemperature Protection for Each Switch and Overtemperature Prewarning Undervoltage Protection Various Diagnostic Functions Such as Shorted Output, Open-load, Overtemperature and Power-supply Fail Detection Serial Data Interface, Daisy Chain Capable, up to 2 MHz Clock Frequency SO14 Power Package Triple Halfbridge DMOS Output Driver with Serial Input Control T6818/ATA6828 1. Description The T6818/ATA6828 are fully protected driver interfaces designed in 0.8-µm BCDMOS technology. They are used to control up to 3 different loads by a microcontroller in automotive and industrial applications. Each of the 3 high-side and 3 low-side drivers is capable to drive currents up to 1.5 A. The drivers are internally connected to form 3 half-bridges and can be controlled separately from a standard serial data interface. Therefore, all kinds of loads such as bulbs, resistors, capacitors and inductors can be combined. The IC design especially supports the application of H-bridges to drive DC motors. Protection is guaranteed regarding short-circuit conditions, overtemperature and undervoltage. Various diagnostic functions and a very low quiescent current in stand-by-mode opens a wide range of applications. Automotive qualification (protection against conducted interferences, EMC protection and 2-kV ESD protection) gives added value and enhanced quality for exacting requirements of automotive applications. Rev. 4530G–BCD–09/05 Figure 1-1. Block Diagram n. u. n. u. O C S n. u. n. u. n. u. n. u. n. u. n. u. H S 3 L S 3 H S 2 L S 2 H S 1 L S 1 S R R 3 VS Input register Output register DI 5 P S F O P L S C D n. u. n. u. n. u. n. u. n. u. n. u. H S 3 Serial interface L S 3 H S 2 L S 2 H S 1 L S 1 T P Charge pump CLK 6 CS 4 Fault detect INH 10 Fault detect Fault detect UV protection 11 Control logic VCC DO 9 Power-on reset 1 7 GND GND GND GND Fault detect Fault detect Fault detect Thermal protection 13 OUT1 8 14 2 OUT3 12 OUT2 2 T6818/ATA6828 4530G–BCD–09/05 T6818/ATA6828 2. Pin Configuration Figure 2-1. Pining SO14/PSO14 GND OUT3 VS CS DI CLK GND 1 2 3 4 5 6 7 14 13 12 11 10 9 8 GND OUT1 OUT2 VCC INH DO GND Table 2-1. Pin 1 Pin Description Symbol GND Function T6818: ground; reference potential; internal connection to pin 7, 8 and 14; cooling tab ATA6828: additional connection to heat slug Half-bridge output 3; formed by internally connected power MOS high-side switch 3 and low-side switch 3 with internal reverse diodes; short circuit protection; overtemperature protection; diagnosis for short and open load Power supply for output stages OUT1, OUT2 and OUT3, internal supply Chip select input; 5-V CMOS logic level input with internal pull up; low = serial communication is enabled, high = disabled Serial data input; 5-V CMOS logic level input with internal pull down; receives serial data from the control device; DI expects a 16-bit control word with LSB being transferred first Serial clock input; 5-V CMOS logic level input with internal pull down; controls serial data input interface and internal shift register (fmax = 2 MHz) Ground; see pin 1 Ground; see pin 1 Serial data output; 5-V CMOS logic level tri-state output for output (status) register data; sends 16-bit status information to the microcontroller (LSB is transferred first); output will remain tri-stated unless device is selected by CS = low, therefore, several ICs can operate on one data output line only. Inhibit input; 5-V logic input with internal pull down; low = standby, high = normal operation Logic supply voltage (5 V) Half-bridge output 2; see pin 2 Half-bridge output 1; see pin 2 Ground; see pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 OUT3 VS CS DI CLK GND GND DO INH VCC OUT2 OUT1 GND 3 4530G–BCD–09/05 3. Functional Description 3.1 Serial Interface Data transfer starts with the falling edge of the CS signal. Data must appear at DI synchronized to CLK and are accepted on the falling edge of the CLK signal. LSB (bit 0, SRR) has to be transferred first. Execution of new input data is enabled on the rising edge of the CS signal. When CS is high, pin DO is in tri-state condition. This output is enabled on the falling edge of CS. Output data will change their state with the rising edge of CLK and stay stable until the next rising edge of CLK appears. LSB (bit 0, TP) is transferred first. Figure 3-1. CS Data Transfer DI SRR LS1 HS1 LS2 HS2 LS3 HS3 n. u. n. u. n. u. n. u. n. u. n. u. OCS n. u. n. u. 0 CLK 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 DO TP S1L S1H S2L S2H S3L S3H n. u. n. u. n. u. n. u. n. u. n. u. SCD OPL PSF Table 3-1. Bit 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Input Data Protocol Input Register SRR LS1 HS1 LS2 HS2 LS3 HS3 n. u. n. u. n. u. n. u. n. u. n. u. OCS n. u. n. u. Function Status register reset (high = reset; the bits PSF, OPL and SCD in the output data register are set to low) Controls output LS1 (high = switch output LS1 on) Controls output HS1 (high = switch output HS1 on) See LS1 See HS1 See LS1 See HS1 Not used Not used Not used Not used Not used Not used Overcurrent shutdown (high = overcurrent shutdown is active) Not used Not used 4 T6818/ATA6828 4530G–BCD–09/05 T6818/ATA6828 Table 3-2. Bit 0 1 2 3 4 5 6 7 8 9 10 11 12 13 Output Data Protocol Output (Status) Register TP Status LS1 Status HS1 Status LS2 Status HS2 Status LS3 Status HS3 n. u. n. u. n. u. n. u. n. u. n. u. SCD Function Temperature prewarning: high = warning High = output is on, low = output is off; not affected by SRR High = output is on, low = output is off; not affected by SRR Description see LS1 Description see HS1 Description see LS1 Description see HS1 Not used Not used Not used Not used Not used Not used Short circuit detected: set high when at least one high-side or low-side switch is switched off by a short-circuit condition. Bits 1 to 6 can be used to detect the shorted switch. Open load detected: set high, when at least one active high-side or lowside switch sinks/sources a current below the open load threshold current. Power-supply fail: undervoltage at pin VS detected 14 15 OPL PSF After power-on reset, the input register has the following status: Bit 15 x Bit 14 x Bit 13 (OCS) H x x x x x x Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Bit 7 Bit 6 (HS3) L Bit 5 (LS3) L Bit 4 (HS2) L Bit 3 (LS2) L Bit 2 (HS1) L Bit 1 (LS1) L Bit 0 (SRR) L The following patterns are used to enable internal test modes of the IC. It is not recommended to use these patterns during normal operation. Bit 15 H H H Bit 14 H H H Bit 13 (OCS) H H H H L L H L L L H L L H L L L H L L H Bit 12 Bit 11 Bit 10 Bit 9 Bit 8 Bit 7 Bit 6 (HS3) L L L Bit 5 (LS3) L L L Bit 4 (HS2) L L L Bit 3 (LS2) L L L Bit 2 (HS1) L L L Bit 1 (LS1) L L L Bit 0 (SRR) L L L 5 4530G–BCD–09/05 3.2 Power-supply Fail In case of undervoltage at pin VS, the Power-Supply Fail bit (PSF) in the output register is set and all outputs are disabled. To detect an undervoltage, its duration has to last longer than the undervoltage detection delay time tdUV. The outputs are enabled immediately when supply voltage recovers normal operation value. The PSF bit stays high until it is reset by the SRR bit in the input register. 3.3 Open-load Detection If the current through a high-side or low-side switch in ON-state stays below the open-load detection threshold, the open-load detection bit (OPL) in the output register is set. The OPL bit stays high until it is reset by the SRR bit in the input register. To detect an open load, its duration has to last longer than the open-load detection delay time tdSd. 3.4 Overtemperature Protection If the junction temperature of one or more output stages exceeds the thermal prewarning threshold, T jPW set , the temperature prewarning bit (TP) in the output register is set. When the temperature falls below the thermal prewarning threshold, TjPW reset, the bit TP is reset. The TP bit can be read without transferring a complete 16-bit data word. The status of TP is available at pin DO with the falling edge of CS. After the microcontroller has read this information, CS is set high and the data transfer is interrupted without affecting the status of input and output registers. If the junction temperature of one or more output stages exceeds the thermal shutdown threshold, Tj switch off, all outputs are disabled and the corresponding bits in the output register are set to low. The outputs can be enabled again when the temperature falls below the thermal shutdown threshold, Tjswitch on and the SRR bit in the input register is set to high. Hysteresis of thermal prewarning and shutdown threshold avoids oscillations. 3.5 Short-circuit Protection The output currents are limited by a current regulator. Overcurrent detection is activated by writing a high to the OCS bit in the input register. When the current in an output stage exceeds the overcurrent limitation and shutdown threshold, it is switched off after a delay time (tdSd). The short-circuit detection bit (SCD) is set and the corresponding status bit in the output register is set to low. For OCS = low the overcurrent shutdown is inactive. The SCD bit is also set if the current exceeds the overcurrent limitation and shutdown threshold, but the outputs are not affected. By writing a high to the SRR bit in the input register the SCD bit is reset and the disabled outputs are enabled. 3.6 Inhibit 0 V applied to pin 10 (INH) inhibits the T6818/ATA6828. All output switches are then turned off and switched to tri-state. The data in the output register are deleted. The current consumption is reduced to less than 5 µA at pin VS and less than 25 µA at pin VCC. The output switches can be activated again by switching pin 10 (INH) to 5 V which initiates an internal power-on reset. 6 T6818/ATA6828 4530G–BCD–09/05 T6818/ATA6828 4. Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. All values refer to GND pins. Parameters Supply voltage Supply voltage t < 0.5 s; IS > –2 A Logic supply voltage Logic input voltage Logic output voltage Input current Output current Output current Output voltage Reverse conducting current (tpulse = 150 µs) Junction temperature range Storage temperature range Pin 3 3 11 4 to 6, 10 9 4 to 6, 10 9 2, 12 and 13 2, 12 and 13 2, 12 and 13 towards pin 3 Symbol VVS VVS VVCC VCS,VDI, VCLK, VINH VDO ICS,IDI, ICLK, IINH IDO IOut3, IOut2, IOut1 IOut3, IOut2, IOut1 IOut3, IOut2, IOut1 TJ TSTG Value –0.3 to +40 –1 –0.3 to +7 –0.3 to VVCC+0.3 –0.3 to VVCC+0.3 –10 to +10 –10 to +10 Internally limited, see output specification –0.3 to +40 17 –40 to +150 –55 to +150 Unit V V V V V mA mA V A °C °C 5. Thermal Resistance Parameters T6818 Junction pin Junction ambient ATA6828 Junction pin Junction ambient Measured to heat slug GND pins 1, 7, 8 and 14 RthJP RthJA 5 30 K/W K/W Measured to GND Pins 1, 7, 8 and 14 RthJP RthJA 30 65 K/W K/W Test Conditions Symbol Value Unit 6. Operating Range Parameters Supply voltage Logic supply voltage Logic input voltage Serial interface clock frequency Junction temperature range Note: 1. Threshold for undervoltage detection Symbol VVS VVCC VCS,VDI, VCLK, VINH fCLK Tj Value VUV (1) Unit V V V MHz °C to 40 4.75 to 5.25 –0.3 to VVCC 2 –40 to +150 7 4530G–BCD–09/05 7. Noise and Surge Immunity Parameters Conducted interferences Interference suppression ESD (Human Body Model) ESD (Machine Model) Note: 1. Test pulse 5: Vsmax = 40 V Test Conditions ISO 7637-1 VDE 0879 Part 2 ESD S 5.1 JEDEC A115A Value Level 4(1) Level 5 2 kV 200 V 8. Electrical Characteristics 7.5 V < VVS < 40 V; 4.75 V < VVCC < 5.25 V; INH = High; –40°C < Tj < 150° C; unless otherwise specified, all values refer to GND pins. No. 1 1.1 1.2 1.3 1.4 1.5 1.6 Parameters Current Consumption Quiescent current VS Test Conditions VVS < 20 V, INH = low Pin 3 11 3 11 3 3 Symbol IVS IVCC IVS IVCC IVS IVS Min. Typ. 1 15 4 350 Max. 5 25 6 500 5.5 10 Unit µA µA mA µA mA mA Type* A A A A A A 4.75 V < VVCC < 5.25 V, Quiescent current VCC INH = low Supply current VS Supply current VCC Discharge current VS Discharge current VS VVS < 20 V normal operating, all outputs off 4.75 V < VVCC < 5.25 V, normal operating VVS = 32.5 V, INH = low VVS = 40 V, INH = low 0.5 2.5 2 2.1 2.2 2.3 2.4 2.5 Undervoltage Detection, Power-on Reset Power-on reset threshold Power-on reset delay time After switching on VCC 3 3 11 VVCC tdPor VUv 3.2 30 5.6 0.6 10 40 3.9 95 4.4 190 7.0 V µs V V µs A A A A A Undervoltage-detection VCC = 5 V threshold Undervoltage-detection VCC = 5 V hysteresis Undervoltage-detection delay time ∆VUv tdUV 3 3.1 3.2 3.3 3.4 3.5 Note: Thermal Prewarning and Shutdown Thermal prewarning set Thermal prewarning reset Thermal prewarning hysteresis Thermal shutdown off Thermal shutdown on TjPW set TjPW reset 120 105 145 130 15 150 135 175 160 200 185 170 155 °C °C °C °C °C B B B B B ∆TjPW Tj switch off Tj switch on *) Type means: A =100% tested, B = 100% correlation tested, C = Characterized on samples, D = Design parameter 1. Delay time between rising edge of input signal at pin CS after data transmission and switch on output stages to 90% of final level. Device not in standby for t > 1 ms 8 T6818/ATA6828 4530G–BCD–09/05 T6818/ATA6828 8. Electrical Characteristics (Continued) 7.5 V < VVS < 40 V; 4.75 V < VVCC < 5.25 V; INH = High; –40°C < Tj < 150° C; unless otherwise specified, all values refer to GND pins. No. 3.6 Parameters Thermal shutdown hysteresis Ratio thermal shutdown off/thermal prewarning set Ratio thermal shutdown on/thermal prewarning reset Test Conditions Pin Symbol ∆Tj switch off Tj switch off/ TjPW set Tj switch on/ TjPW reset Min. Typ. 15 Max. Unit °C Type* B 3.7 1.05 1.2 B 3.8 1.05 1.2 B 4 4.1 Output Specification (OUT1-OUT3) IOut 1-3 = –1.3 A On resistance IOut 1-3 = 1.3 A High-side output leakage current Low-side output leakage current High-side switch reverse diode forward voltage VOut 1-3 = 0 V, output stages off VOut 1-3 = VVS, output stages off IOut 1-3 = 1.5 A 2, 12, 13 2, 12, 13 2, 12, 13 2, 12, 13 2, 12, 13 2, 12, 13 2, 12, 13 2, 12, 13 RDSOn1-3 RDSOn1-3 IOut1-3 IOut1-3 VOut1-3 – VVS VOut 1-3 IOut1-3 –1.5 –15 200 1.1 1.1 Ω Ω µA µA A A A A 4.2 4.3 4.4 4.5 1.5 V A 4.6 Low-side switch reverse IOut 1-3 = –1.5 A diode forward voltage High-side overcurrent limitation and shutdown threshold Low-side overcurrent limitation and shutdown threshold Overcurrent shutdown delay time High-side open-load detection threshold Low-side open-load detection threshold Open-load detection delay time High-side output switch VVS = 13 V RLoad = 30 Ω on delay(1) Low-side output switch VVS = 13 V on delay(1) RLoad = 30 Ω High-side output switch VVS = 13 V off delay(1) RLoad = 30 Ω V A 4.7 –2.5 –2 –1.5 A A 4.8 IOut1-3 tdSd 1.5 2 2.5 A A 4.9 4.10 4.11 4.12 4.13 4.14 4.15 10 –45 15 200 –30 30 40 –15 45 600 20 20 20 µs mA mA µs µs µs µs A A A A A A A 2, 12, 13 2, 12, 13 IOut1-3 IOut1-3 tdSd tdon tdon tdoff *) Type means: A =100% tested, B = 100% correlation tested, C = Characterized on samples, D = Design parameter Note: 1. Delay time between rising edge of input signal at pin CS after data transmission and switch on output stages to 90% of final level. Device not in standby for t > 1 ms 9 4530G–BCD–09/05 8. Electrical Characteristics (Continued) 7.5 V < VVS < 40 V; 4.75 V < VVCC < 5.25 V; INH = High; –40°C < Tj < 150° C; unless otherwise specified, all values refer to GND pins. No. 4.16 Parameters Test Conditions Pin Symbol tdoff tdon – tdoff Min. Typ. Max. 3 Unit µs Type* A Low-side output switch VVS = 13 V off delay(1) RLoad = 30 Ω Dead time between corresponding highand low-side switches Input voltage low-level threshold Input voltage high-level threshold Hysteresis of input voltage Pull-down current pin DI, CLK, INH Pull-up current Pin CS VDI, VCLK, VINH = VCC VCS = 0 V VVS = 13 V RLoad = 30 Ω 4.17 1 µs A 5 5.1 5.2 5.3 5.4 5.5 6 6.1 6.2 6.3 Logic Inputs DI, CLK, CS, INH 4-6, 10 4-6, 10 4-6, 10 5, 6, 10 4 VIL VIH 0.3 × VVCC 0.7 × VVCC 50 10 –65 700 65 –10 V V mV µA µA A A B A A ∆VI IPD IPU Serial Interface – Logic Output DO Output-voltage low level IDOL = 2 mA Output-voltage high level Leakage current (tri-state) IDOL = –2 mA VCS = VCC 0V < VDO < VVCC 9 9 9 VDOL VDOH IDO VVCC – 0.7 V –10 10 0.4 V V µA A A A 7 7.1 Inhibit Input — Timing Delay time from standby to normal operation tdINH 100 µs A *) Type means: A =100% tested, B = 100% correlation tested, C = Characterized on samples, D = Design parameter Note: 1. Delay time between rising edge of input signal at pin CS after data transmission and switch on output stages to 90% of final level. Device not in standby for t > 1 ms 10 T6818/ATA6828 4530G–BCD–09/05 T6818/ATA6828 9. Serial Interface – Timing No. 8.1 8.2 8.3 8.4 8.5 8.6 8.7 8.8 8.9 Parameters Test Conditions Pin 9 9 9 9 9 4 4 4 6 6 6 6 6 5 5 Timing Chart No.(1) 1 2 – – 10 4 8 9 5 6 – 7 3 11 12 Symbol tENDO tDISDO tDOf tDOr tDOVal tCSSethl tCSSetlh tCSh tCLKh tCLKl tCLKp tCLKSethl tCLKSetlh tDIset tDIHold Min. Typ. Max. 200 200 100 100 200 Unit ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns Type* D D D D D D D D D D D D D D D DO enable after CS CDO = 100 pF falling edge DO disable after CS CDO = 100 pF rising edge DO fall time DO rise time DO valid time CS setup time CS setup time CS high time CLK high time CDO = 100 pF CDO = 100 pF CDO = 100 pF 225 225 500 225 225 500 225 225 40 40 8.10 CLK low time 8.11 CLK period time 8.12 CLK setup time 8.13 CLK setup time 8.14 DI setup time 8.15 DI hold time Note: 1. See Figure 9-1 on page 12 *) Type means: A =100% tested, B = 100% correlation tested, C = Characterized on samples, D = Design parameter 11 4530G–BCD–09/05 Figure 9-1. Serial Interface Timing with Chart Numbers 1 2 CS DO 9 CS 4 7 CLK 5 3 6 8 DI 11 CLK 10 12 DO Inputs DI, CLK, CS: High level = 0.7 × VCC, low level = 0.3 × VCC Output DO: High level = 0.8 × VCC, low level = 0.2 × VCC 12 T6818/ATA6828 4530G–BCD–09/05 T6818/ATA6828 10. Application Circuit VCC U5021M Watchdog Trigger Reset Enable VS n. u. n. u. O C S n. u. n. u. n. u. n. u. n. u. n. u. H S 3 L S 3 H S 2 L S 2 H S 1 L S 1 S R R 3 VS BYT41D VBatt Input register Output register Serial interface n. u. n. u. n. u. n. u. H S 3 L S 3 H S 2 L S 2 H S 1 LT SP 1 Charge pump Microcontroller DI 5 P S F O P L S C D n. u. n. u. CLK 6 CS 4 Fault detect Fault detect Fault detect UV protection 11 INH 10 Control logic VCC DO 9 1 GND 7 GND Fault detect Fault detect Fault detect Thermal protection 2 OUT3 8 14 GND GND 12 OUT2 13 OUT1 VCC M M 10.1 Application Notes It is strongly recommended to connect the blocking capacitors at VCC and VS as close as possible to the power supply and GND pins. Recommended value for capacitors at VS: Electrolytic capacitor C > 22 µF in parallel with a ceramic capacitor C = 100 nF. Value for electrolytic capacitor depends on external loads, conducted interferences and reverse conducting current IOut1,2,3 (see “Absolute Maximum Ratings” on page 7). Recommended value for capacitors at VCC: Electrolytic capacitor C > 10 µF in parallel with a ceramic capacitor C = 100 nF. To reduce thermal resistance it is recommended to place cooling areas on the PCB as close as possible to the GND pins. Negative spikes at the output pins (e.g. negative spikes caused by an inductive load switched off with a high side driver) may activate the overtemperature protection function of the T6818/ATA6828. In this condition, all outputs will be switched off simultaneously. If this behavior is not acceptable or compatible with your application functionally, it is necessary, that for switching on required outputs again, the SRR bit (Status Register Reset) is set, to ensure a reset of the overtemperature function. 4530G–BCD–09/05 + Power-on reset + 13 V VCC VCC 5V 13 11. Ordering Information Extended Type Number T6818-TUSY T6818-TUQY ATA6828-T2SY ATA6828-T2QY Package SO14 SO14 PSO14 PSO14 Remarks Power package, tubed, lead-free Power package, taped and reeled, lead-free Power package with heat slug, tubed, lead-free Power package with heat slug, taped and reeled, lead-free 12. Package Information Package SO14 Dimensions in mm 8.75 5.2 4.8 3.7 1.4 0.4 1.27 7.62 14 8 0.25 0.10 0.2 3.8 6.15 5.85 technical drawings according to DIN specifications 1 7 14 T6818/ATA6828 4530G–BCD–09/05 T6818/ATA6828 1 Package: PSO14 with heat slug Dimensions in mm 2.54-0.5 7 heat slug exposed ∅ 0.4 A B 14 6.86 8 technical drawings according to DIN specifications 1.62 max. 8.75±0.1 A 0.23 0.1 max. 0.41 1.27 nom. 1.52 max. 3.99 max. 4.27±0.4 6±0.2 B 6 x 1.27 = 7.62 nom. Drawing-No.: 6.541-5051.01-4 Issue: 2; 18.08.05 13. Revision History Please note that the following page numbers referred to in this section refer to the specific revision mentioned, not to this document. Revision No. 4530G-BCD-09/05 History • Complete datasheet: T6828 changed in ATA6828 • Ordering Information on page 14 changed • Package drawing on page 15 changed • Lead-free Logo on page 1 added • Table “Ordering Information” on page 14 changed • Table “Ordering Information” on page 14 changed • Features on page 1 changed 4530F-BCD-03/05 4530E-BCD-07/04 4530D-BCD-04/04 15 4530G–BCD–09/05 Atmel Corporation 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 487-2600 Atmel Operations Memory 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 436-4314 RF/Automotive Theresienstrasse 2 Postfach 3535 74025 Heilbronn, Germany Tel: (49) 71-31-67-0 Fax: (49) 71-31-67-2340 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906, USA Tel: 1(719) 576-3300 Fax: 1(719) 540-1759 Regional Headquarters Europe Atmel Sarl Route des Arsenaux 41 Case Postale 80 CH-1705 Fribourg Switzerland Tel: (41) 26-426-5555 Fax: (41) 26-426-5500 Microcontrollers 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 436-4314 La Chantrerie BP 70602 44306 Nantes Cedex 3, France Tel: (33) 2-40-18-18-18 Fax: (33) 2-40-18-19-60 Biometrics/Imaging/Hi-Rel MPU/ High Speed Converters/RF Datacom Avenue de Rochepleine BP 123 38521 Saint-Egreve Cedex, France Tel: (33) 4-76-58-30-00 Fax: (33) 4-76-58-34-80 Asia Room 1219 Chinachem Golden Plaza 77 Mody Road Tsimshatsui East Kowloon Hong Kong Tel: (852) 2721-9778 Fax: (852) 2722-1369 ASIC/ASSP/Smart Cards Zone Industrielle 13106 Rousset Cedex, France Tel: (33) 4-42-53-60-00 Fax: (33) 4-42-53-60-01 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906, USA Tel: 1(719) 576-3300 Fax: 1(719) 540-1759 Scottish Enterprise Technology Park Maxwell Building East Kilbride G75 0QR, Scotland Tel: (44) 1355-803-000 Fax: (44) 1355-242-743 Japan 9F, Tonetsu Shinkawa Bldg. 1-24-8 Shinkawa Chuo-ku, Tokyo 104-0033 Japan Tel: (81) 3-3523-3551 Fax: (81) 3-3523-7581 Literature Requests www.atmel.com/literature Disclaimer: T he information in this document is provided in connection with Atmel products. No license, express or implied, by estoppel or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Atmel products. EXCEPT AS SET FORTH IN ATMEL’S TERMS AND CONDITIONS OF SALE LOCATED ON ATMEL’S WEB SITE, ATMEL ASSUMES NO LIABILITY WHATSOEVER AND DISCLAIMS ANY EXPRESS, IMPLIED OR STATUTORY WARRANTY RELATING TO ITS PRODUCTS INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTY OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, CONSEQUENTIAL, PUNITIVE, SPECIAL OR INCIDENTAL DAMAGES (INCLUDING, WITHOUT LIMITATION, DAMAGES FOR LOSS OF PROFITS, BUSINESS INTERRUPTION, OR LOSS OF INFORMATION) ARISING OUT OF THE USE OR INABILITY TO USE THIS DOCUMENT, EVEN IF ATMEL HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. A tmel makes no representations or warranties with respect to the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Atmel does not make any commitment to update the information contained herein. Unless specifically provided otherwise, Atmel products are not suitable for, and shall not be used in, automotive applications. Atmel’s products are not intended, authorized, or warranted for use as components in applications intended to support or sustain life. © Atmel Corporation 2005 . A ll rights reserved. Atmel ®, logo and combinations thereof, Everywhere You Are ® a nd others, are registered trademarks or trademarks of Atmel Corporation or its subsidiaries. Other terms and product names may be trademarks of others. Printed on recycled paper. 4530G–BCD–09/05
T6818
1. 物料型号: - T6818/ATA6828
2. 器件简介: - T6818/ATA6828是采用0.8-µm BCDMOS技术设计的全保护驱动接口,用于通过微控制器控制最多3种不同的负载,应用于汽车和工业领域。每个高侧和低侧驱动器能够驱动高达1.5A的电流,内部连接形成3个半桥,可以控制各种负载,如灯泡、电阻器、电容器和电感器。
3. 引脚分配: - 1号引脚:GND(地) - 2号引脚:OUT3(半桥输出3) - 3号引脚:VS(输出阶段电源) - 4号引脚:CS(芯片选择输入) - 5号引脚:DI(串行数据输入) - 6号引脚:CLK(串行时钟输入) - 7号引脚:GND(地) - 8号引脚:GND(地) - 9号引脚:DO(串行数据输出) - 10号引脚:INH(禁止输入) - 11号引脚:VCC(逻辑电源电压) - 12号引脚:OUT2(半桥输出2) - 13号引脚:OUT1(半桥输出1) - 14号引脚:GND(地)
4. 参数特性: - 供电电压高达40V - RDS(on)典型值25°C时为0.5Ω,150°C时最大为1.1Ω - 输出电流高达1.5A - 无射击电流 - 待机模式下极低的静态电流I_S<5μA - 过温保护和过温预警 - 欠压保护 - 多种诊断功能,如短路输出、开路负载、过温和电源失败检测 - 串行数据接口,支持多达2MHz的时钟频率 - SO14功率封装
5. 功能详解: - 包括串行接口的数据传输、电源失败检测、开路负载检测、过温保护、短路保护和禁止功能。
6. 应用信息: - 强烈建议在VCC和VS电源和GND引脚附近连接去耦电容。对于VS,推荐使用电解电容(大于22μF)和陶瓷电容(100nF)并联。对于VCC,推荐使用电解电容(大于10μF)和陶瓷电容(100nF)并联。
7. 封装信息: - T6818-TUSY:SO14功率封装,无铅 - T6818-TUQY:SO14功率封装,带胶带和卷轴,无铅 - ATA6828-T2SY:PSO14功率封装,带热沉,无铅 - ATA6828-T2QY:PSO14功率封装,带热沉,带胶带和卷轴,无铅
T6818 价格&库存
很抱歉,暂时无法提供与“T6818”相匹配的价格&库存,您可以联系我们找货
