BL-T4534
BL-T4534
    BRIGHT(博瑞泰)
    BL-T4534 - GaP/GaP Hi-Eff Red Low power consumption. - BRIGHT LED ELECTRONICS CORP
BL-T4534 数据手册
BRIGHT LED ELECTRONICS CORP. SINCE 1981 BL-T4534 ● Features: 1. Chip material: GaP/GaP 2. Emitted color : Hi-Eff Red 3. Lens Appearance : Red Diffused 4. Low power consumption. 5. High efficiency. 6. Versatile mounting on P.C. Board or panel. 7. Low current requirement. 8. 2.8x4.3x7.5mm package 9. This product don’t contained restriction substance, compliance ROHS standard. ● Package Dimensions: 4.3(.169) 3.3(.130) 2.8(.110) 3.5(.138) 4.4(.173) 4.0(.157) 3.4(.134) 1.5(.059) MAX. 25.4(1.00) MIN. 0.5(.020) SQ. TYP. CATHODE 1.0(.039) MIN. 2.54(.100) NOM. ● Applications: 1. TV set 2. Monitor 3. Telephone 4. Computer 5. Circuit board Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.25mm (0.01”) unless otherwise specified. 3. Lead spacing is measured where the leads emerge from the package. 4. Specifications are subject to change without notice. ● Absolute Maximum Ratings(Ta=25℃) Parameter Power Dissipation Forward Current Peak Forward Current*1 Reverse Voltage Operating Temperature Storage Temperature Soldering Temperature 1 Symbol Pd IF IFP VR Topr Tstg Tsol Rating 80 30 150 5 -40℃~80℃ -40℃~85℃ 260℃(for 5 seconds) Unit mW mA mA V * Condition for IFP is pulse of 1/10 duty and 0.1msec width. Ver.2.0 Page: 1 of 2 BRIGHT LED ELECTRONICS CORP. SINCE 1981 BL-T4534 ● Electrical and optical characteristics(Ta=25℃) Parameter Forward Voltage Luminous Intensity Symbol VF Iv IR λp λd ∆λ 2θ1/2 Condition IF=20mA IF=20mA VR=5V IF=20mA IF=20mA IF=20mA IF=20mA Min. 617 - Typ. 2.0 6.0 640 45 100 Max. 2.6 100 638 - Unit V mcd Reverse Current Peak Wave Length Dominant Wave Length Spectral Line Half-width Viewing Angle µA nm nm nm deg ● Typical Electro-Optical Characteristics Curves Fig.1 Relative intensity vs. Wavelength 1.0 60 Fig.2 Forward current derating curve vs. Ambient temperature 50 Relative radiant intensity Forward current(mA) 40 0.5 30 20 10 0 540 640 740 0 20 40 60 80 100 Wavelength λ (nm) Ambient temperature Ta(℃) Fig.3 Forward current vs. Forward voltage 50 3.0 Fig.4 Relative luminous intensity vs. Ambient temperature 40 Relative luminous intensity 1 2 3 4 5 2.5 Forward current(mA) 2.0 30 1.5 20 1.0 10 0.5 0 0 -40 -20 0 20 40 60 Forward voltage(V) Ambient temperature Ta(℃) Fig.5 Relative luminous intensity vs. Forward current 2.0 Fig.6 Radiation diagram 0 10 20 30 Relative luminous intensity(@20mA) 1.5 Relative radiant intensity 40 1.0 0.9 0.8 50 60 70 0.7 80 90 1.0 0.5 0 10 20 30 40 50 0.5 0.3 0.1 0.2 0.4 0.6 Forward current (mA) Ver.2.0 Page: 2 of 2
BL-T4534 价格&库存
很抱歉,暂时无法提供与“BL-T4534”相匹配的价格&库存,您可以联系我们找货
QBL8IB60D
    • 1+3.24485
    • 30+3.13296
    • 100+2.90918
    • 500+2.68539
    • 1000+2.5735
    库存:34
