VFM40-T5125
VFM40-T5125
    CUI
    VFM40-T5125 - open frame AC/DC power supply - CUI INC,
VFM40-T5125 数据手册
rev. rev. page date 1 of 3 08/2007 PART NUMBER: VFM40 multiple output series DESCRIPTION: open frame AC/DC power supply features ·universal input: 90~264VAC ·2”x4” footprint ·industry-standard pin out ·efficiency at 75% typical (70% for VFM40-T3512) ·meets UL/cUL, TUV, CE ·Pi input filter ·conductive EMI meets CISPR/FCC class B ·multiple output output voltage 5V(V1) 12V(V2) VFM40-D524 5V(V1 ) 24V(V2 ) VFM40-T5125 5V(V1 ) 12V(V2 ) -5V(V3 ) VFM40-T512 5V(V1 ) 12V(V2 ) -12V(V3 ) VFM40-T515 5V(V 1) 15V(V2 ) -15V(V3) VFM40-T52412 5V(V1 ) 24V(V2 ) -12V(V3) VFM40-T5245 5V(V1 ) 24V(V2 ) -5V(V3 ) VFM40-T52412-1 5V(V1 ) 24V(V2 ) 12V(V3 ) VFM40-T3512 3.3V(V1 ) 5V(V2 ) 12V(V3 ) model number VFM40-D512 output current min. rated max. 0.4 3.2 5.0 0.2 2.0 2.5 0.4 3.2 5.0 0.2 1.0 1.5 0.4 3.0 5.0 0.2 2.0 2.5 0 0.3 0.5 0.4 3.0 5.0 0.2 2.0 2.5 0 0.3 0.5 0.4 3.0 5.0 0.2 1.5 2.3 0 0.3 0.5 0.4 3.0 5.0 0.2 1.0 1.5 0 0.3 0.5 0.4 3.0 5.0 0.2 1.0 1.5 0 0.4 0.2 0 0.4 0.2 0 0.3 3.0 1.0 0.3 5.0 2.0 0.3 0.5 5.0 1.5 0.5 7.0 3.5 0.5 ripple 1 (mVp-p) 50 120 50 240 50 120 50 50 120 120 50 150 150 50 240 120 50 240 50 50 240 120 50 50 120 voltage accuracy 2 ±3% ±4% ±3% ±4% ±3% ±4% ±3% ±3% ±4% ±3% ±3% ±4% ±3% ±3% ±4% ±3% ±3% ±4% ±3% ±3% ±4% ±3% ±3% ±4% ±3% line reg. 3 ±1% ±2% ±1% ±2% ±1% ±2% ±1% ±1% ±2% ±1% ±1% ±2% ±1% ±1% ±2% ±1% ±1% ±2% ±1% ±1% ±2% ±1% ±1% ±2% ±1% load reg. 4 ±3% ±5% ±3% ±5% ±3% ±5% ±1% ±3% ±5% ±1% ±3% ±5% ±1% ±3% ±5% ±1% ±3% ±5% ±1% ±3% ±5% ±1% ±3% ±5% ±1% O/P power max. 40.0W 40.0W 40.5W efficiency (typ.) 77% 78% 75% 42.6W 75% 42.0W 75% 42.6W 75% 40.5W 75% 42.6W 75% 30.0W 70% NOTES: 1. add a 0.1µF ceramic capacitor and a 10µF E.L. capacitor to output for ripple and noise measuring @20MHz BW. 2. voltage accuracy is set at full load 3. line regulation is measured from 100VAC to 240VAC with full load. 4. load regulation is measured from 60% to 100% full load and from 60% to 20% full load (60% ±40% full load). 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 phone fax rev. page date 2 of 3 08/2007 PART NUMBER: VFM40 multiple output series DESCRIPTION: open frame AC/DC power supply INPUT v oltage frequency inrush current input current conducted EMI isolation leakage current 90-264VAC; 120-370VDC 47 to 440Hz 50A max. @ 264VAC 1A max. (RMS) @ 115VAC CISPR/FCC Class B input to output = 4,242VDC 0.5mA max. OUTPUT maximum power for convection cooling 30 VFM forced air hold up time short circuit / overload protection over voltage protection adjustment range 40W (VFM40-T3512, 30W) 50W (VFM40-T3512, 40W) 20mS typ. @ 115VAC auto recovery (all outputs) 3.6-4.6V/5.7-6.7V on V1 (3.3V/5V) 120%-140% on V2(12V/15V/24V) 10% typ. ENVIRONMENTAL CHARACTERISTICS operating temperature storage temperature 0°C-50°C -20°C-85°C MECHANICAL OUTLINE dimensions 4x2x1.2 inches ( 101.6x50.8x30.48 mm 3) 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 phone fax rev. page date 3 of 3 08/2007 PART NUMBER: VFM40 multiple output series DESCRIPTION: open frame AC/DC power supply DIMENSIONS (mm) DERATING CURVE VFM40D-01, 40D-02, 40T-01, 40T-02, 40T-03, 40T-04, 40T-05, 40T-06 VFM40T-07 50 40 30 20 10 0 0 10 20 30 40 50 60 70 Ambient Temperature(˚C) 20LFM(Natural Convection) 100LFM 40 30 20 10 0 0 10 20 30 40 50 60 70 Ambient Temperature(˚C) 20LFM(Natural Convection) 100LFM 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382 phone fax
VFM40-T5125
1. 物料型号: - VFM40系列:包括VFM40-D512、VFM40-D524、VFM40-T5125、VFM40-T512、VFM40-T515、VFM40-T52412、VFM40-T5245、VFM40-T52412-1、VFM40-T3512等。
2. 器件简介: - 开放框架式交流/直流电源,具有通用输入、2x4英寸的尺寸、行业标准引脚排列、效率达到75%(VFM40-T3512为70%)、符合UL/cUL、TUV、CE认证、Pi型输入滤波器、导电EMI满足CISPR/FCC B类标准、多路输出。
3. 引脚分配: - 引脚1至引脚6分别为:COM、V3、V2、V1、V1、COM。
4. 参数特性: - 输入电压:90~264VAC,47至440Hz频率。 - 浪涌电流:最大50A@264VAC。 - 输入电流:最大1ARMS@115VAC。 - 传导EMI:满足CISPR/FCC Class B标准。 - 隔离:输入到输出为4,242VDC。 - 漏电流:最大0.5mA。
5. 功能详解: - 最大功率:自然冷却40W(VFM40-T3512为30W),强制风冷50W(VFM40-T3512为40W)。 - 保持时间:115VAC时典型20ms。 - 短路/过载保护:自动恢复(所有输出)。 - 芯片过压保护:V1(3.3V/5V)3.6-4.6V/5.7-6.7V,V2(12V/15V/24V)120%-140%。 - 调整范围:典型10%。
6. 应用信息: - 工作温度:0°C-50°C。 - 存储温度:-20°C-85°C。
7. 封装信息: - 尺寸:具体尺寸图见PDF文档的第三页。
VFM40-T5125 价格&库存
很抱歉,暂时无法提供与“VFM40-T5125”相匹配的价格&库存,您可以联系我们找货
