STANDARD Resistive Touch Panel Specification FID-550 7-Wire Series
Input Panel Panel Drive change over switch Noise Filter MCU Interface Control Section A/D converter
s FEATURES • Superior long life, using a unique construction method offering improved life over typical technologies; by sensing data input only on the glass layer, typically a 10x improvement in product life is achived. • Excellent specification and high quality - Anti-Newton ring technology - High reliability materials • Pen/Finger, Pen Only, Finger Only, Light Touch types available • Transparency 80% - typical s PART NUMBERS Touch Panels:
Part Number N010-0510-T302 N010-0510-T211 N010-0550-T913 Size 17" 15" 13.3" Type Pen/Finger Pen/Finger Pen/Finger Pen/Finger
s PART NUMBERS Controller Boards:
Part Number N16B-0558-B240 N16B-0558-B720
Type 7-Wire, RS232 7-Wire, USB
N010-0550-T711 12.1" N010-0551-T242 N010-0550-T811
s PART NUMBERS Interface Controller Chips:
12.1" Pen/Finger (light touch type) 11.3 Pen/Finger Pen only Pen/Finger
Part Number N010-0559-V022 NC41120-0015
N010-0550-T601 10.4" N010-0550-T611 10.4"
N010-0550-T621 10.4" Pen/Finger (light touch type) N010-0550-T511 N010-0550-T341 9.5" 8.4" Pen/Finger Pen/Finger
FID-550 SERIES
s DIMENSION EXAMPLE (10.4” SHOWN)
(3.50) (11.50) 243.80 236.80 217.10 (transparent area) 215.10 213.10 (input area) 123.75
23.20
2.0 ± ±1.0
±1.0
1 12.5 0.5
±1.0 Top
± 47.00 93.70 ±
3.50
187.40 180.40 164.40 (transparent area) 162.40 160.40 (input area) 47.0 x 3=141.00
(8.00)
1
Left
7 16.00 22.00
90.5±1.0
Unit: mm
(3.50)
Bottom
s DETAILED SPECIFICATION s 1.0 APPLICATION This specification applies to the 10.4" (inch) standard Touch Panel (Pen/Finger type). P/N is N010-0550-T611. s 2.0 ADDITIONAL APPLICATIONS Control IC specifications and Control PCB, complete Touch Panel Specifications are also applicable. s 3.0 DISCRIPTION AND BLOCK DIAGRAM This panel in combination with a control IC chip is used to transfer the co-ordinates of the touched position to the host system (see block diagram above). s 4.0 DRAWING (Please see the diagram above.) Definitions of the major dimensions indicated on this diagram: Effective Input Area (A) Area guaranteed to meet all the characteristics detailed in this specification View / Transparent Area (B) The area inside the adhesive zone or electrode pattern. Anti-input Area (C) An insulating area allowed to protect the touch panel from giving false readings when an enclosure touches the panel. s 5.0 CHARACTERISTICS s 5.1 MECHANICAL Operating Force 0.05~0.49 N (5 ~ 50gF) Measured with a Silicon Measurement Rod R 8 (Round type 8mm) Silicon Rubber Hardness 60˚C Hardness of Surface Pencil hardness 3H minimum against specification JIS K-5400 s 5.2 OPTICAL Transparency Haze Silicon Rubber Rod 78% min measured in the effective input area to JIS K 7105 using a MURAKAMI SHIKISAI KENKYUSHO type IIR 100 meter. Typically 80%. 5% measured in the effective input area using a MURAKAMI SHIKISAI KENKYUSHO type IIR 100 meter with an Anti Glare treated surface.
A B
C
Force
2
FID-550 SERIES
s 5.3 ELECTRICAL Location Accuracy: Linearity: Current Consumption: Switch Bounce (Chattering): Insulation resistance: Dielectric Strength: ±2.5mm Measured over 9 points (See note 1) 1.5% 20mA max at DC 5V when applying 5VDC between pins 3 & 5 10ms min when using the silicon rubber measurement rod. 10MΩ minimum at 25KV DC applied between pins 3 & 7 or between 5 and 7 25KV DC for 1 minute
Note 1:
Co-ordinate Point
Measurement condition of linearity is corrected within the control IC. In general the location accuracy is specified as follows: Actual co-ordinate point - theoretical co-ordinate point = location accuracy. In general a 9 point co-ordinate calibration system is used to adjust the micro controller accuracy. (20 point can be used in combination with an EEPROM design).
Theoretical Error Actual
Note 2:
Pins 3, 5 and 7 are the glass and film connection points.
Distance
s
5.4 ENVIRONMENTAL -5˚C to 60˚C -30˚C to 70˚C 20% to 90% RH with a Maximum wet bulb temperature of 38˚C 10% ~ 90% RH with a Maximum wet bulb temperature of 38˚C Coating with the following chemicals and storing at room temperature for 2 hours gives no problems. 10% NaCl-water solution, ethyl-acetate, ethylalcohol, toluene, methyl-ethyl-ketone.
Operating Temperature (*): Storage Temperature: Operating Humidity: Storage Humidity: Chemical Resistance:
s
5.5 PEN LIFE 1,000,000 words minimum 10,000,000 times minimum
Character Writing life: Touch Input life :
Note 1:
Words are written in the notes area and the size of the word is 7.5mm x 6.75mm. A word is any Alphabet / Number / Mark. The pen is as shown below and applies a force of 250g. A failure is judged to happen when the current consumption or insulation resistance or dielectric strength are not met as shown in 5.3. The location accuracy with 9 point calibration must be ±4.4 mm max.
Effective input area Notes
10 mm
9 mm
0.
8
Ø6.0
Ø2.0
3.5 110.0±1.0
3.0
Ø2
R
9.0
1.0
1.5
Ø 4.6
.0
3
FID-550 SERIES
s
5.6 FINGER LIFE A finger is simulated by a silicon rubber plunger R8 (Round type 8mm size) hardness 60˚C at 200g at frequency 5Hz. A failure is judged to happen when the current consumption or insulation resistance or dielectric strength are not met as shown in 5.3. The location accuracy with 9 point calibration must be ±4.4 mm max. Typical operating force is 150g max.
s
5.7 INFORMATION ON THE PANEL
The panel part number is visible from the film side The production information is visible from the glass side. Production year 99 00 etc. 1 2 3 4 5 6 7 8 9 X Y Z or 1 2 3 4 5 6 7 8 9 X Y Z 2 3 4 5 6 7 8 9 X Y Z or 23456789XYZ YZ January Production February Production December Production
s s
6 PACKAGING 6.1 PACKING SPECIFICATION
Vibration: 10~55 Hz at 1 Octave per minute 10G 20 cycles with one side 0.75mm Drop test: 60cm Drop 1 corner, 3 crease lines and 6 faces. 1 each 1 time After the test no glass: flaw or crack is seen, and no dent or scratch on the film. Also glass and film must not separate. s 6.1 PACKING DETAILS
Each touch panel is placed into a plastic bag and is held in place by a slit cut into the side of the cardboard. A second insertion piece is placed into the carton to again add stability. The qty is written on the side of the box. For example the T611 has 26 pieces per box. Insert Touch panel with bag Slit in cardboard
4
FID-550 SERIES
s
7.0 REJECT CRITERIA
Description Film Dent Reject Criteria Area ≥ 0.1mm2 Area ≥ 0.05mm2 & area < 0.1mm2 Area < 0.05mm2 Area > 0.1mm2 Area ≥ 0.05mm2 & area < 0.1mm2 Area < 0.05mm2 Area ≥ 0.1mm Area ≥ 0.03mm & width
很抱歉,暂时无法提供与“N010-0550-T611”相匹配的价格&库存,您可以联系我们找货
