N010-0554-T347
N010-0554-T347
    FUJITSU(富士通)
    N010-0554-T347 - STANDARD Resistive Touch Panel Specification - Fujitsu Component Limited.
N010-0554-T347 数据手册
STANDARD Resistive Touch Panel Specification 554 4-Wire Series RoHS compliant Input Panel Panel Drive change over switch Noise Filter n FEATURES • Superior quality standard 4 wire resistive analog touch panel • Excellent specification and high quality - Anti Newton ring technology - High reliability materials • Pen/finger type • Transparency - 80% typical • RoHS compliant n PART NUMBERS Touch Panels: Part Number N010-0554-T902 N010-0554-T805 N010-0554-T347 N010-0519-T742 N010-0554-T504 N010-0554-T511 N010-0554-T048 n PART NUMBERS Controller Boards: Part Number N16B-0558-B270 N16B-0558-B730 Type 4-Wire, RS232 4-Wire, USB Size 15.0” 12.1” 10.4” 8.4” 8.4” 8.4” 6.4” Type Pen/Finger Pen/Finger Pen/Finger Pen/Finger Pen/FInger Pen/Finger Pen/Finger (86% clear) n PART NUMBERS Interface Controller Chips: Part Number N010-0559-V036 NC41120-0018 Type 4-Wire, RS232 4-Wire, USB Part Number N010-0554-T043 N010-0554-T009 N010-0554-T241 N010-0556-T408 N010-0554-T703 N010-0516-T407 Size 6.4” 5.7” 4.3 3.9” 3.8” 3.7” Type Pen/Finger (80% AG) Pen/Finger Pen Finger (86%, AS, DPET) Pen/Finger Pen/Finger Pen/Finger MCU Control Section A/D converter Interface 554 SERIES n DIMENSION EXAMPLE (10.4” SHOWN) (8.00) (8.70) 9.50 Anti-input area (10.00) 228.20 216.20: Transparent area 214.80: Boundary line of the top enclosure 213.20 212.20: Guaranteed active area 112.10 8.00 7.50 87.70 159.40: Guaranteed Active Area 160.40 8.00 7.50 Antiinput area 6.70 162.00: Boundary Line of top enclosure 4.00 4.70 5.50 Anti-input area 6.00 5.40 164.60: Transparent Area 175.40 Top 87.70±0.1 5.00±0.5 #4 4.00 10.20 26.50 #1 15.00 Left Right 75.00±1.0 6.70 n DETAILED SPECIFICATION n 1.0 APPLICATION This specification applies to the standard FID-554 seriesTouch Panel (Pen/Finger type). n 2.0 ADDITIONAL APPLICATIONS Complete specification document is available upon request for customers with whom we have an approved NDA in place. n 3.0 DESCRIPTION AND BLOCK DIAGRAM This panel in combination with a control IC chip is used to transfer the co-ordinates of the touched position to the host system (see block diagram above). n 4.0 DRAWING (Please see the diagram above.) Definitions of the major dimensions indicated on this diagram: Effective Input Area (A) Area guaranteed to meet all the characteristics detailed in this specification Anti-input Area (C) An insulating area allowed to protect the touch panel from giving false readings when an enclosure touches the panel. (See fixing instructions) n 5.0 CHARACTERISTICS n 5.1 MECHANICAL Operating Force 5.40 Bottom Unit: mm A B C Force 0.05~0.49 N (5 ~ 50gF) Measured with a Silicon Measurement Rod R 8 (Round type 8mm) Silicon Rubber Hardness 60˚C Pencil hardness 3H minimum against specification JIS K-5400 Silicon Rubber Rod 78% min. measured in the effective input area to JIS K 7105 using a MURAKAMI SHIKISAI KENKYUSHO type IIR 100 meter. 5% type measured in the effective input area using a MURAKAMI SHIKISAI KENKYUSHO type IIR 100 meter with an Anti Glare treated 2 Hardness of Surface n 5.2 OPTICAL Transparency Haze 554 SERIES n 5.3 ELECTRICAL Rated Voltage: Resistance X axis: Resistance Y axis: Switch Bounce (Chattering): Insulation resistance: Dielectric Strength: Linearity: DC 7V max. 300 to 850 Ω (at the connector) 100 to 600 Ω (at the connector) 20ms min when using the silicon rubber measurement rod 10MΩ minimum at 25KV DC No problems when at 25KV DC for 1 minute 2% max. Co-ordinate Point Note 1: Measurement condition of linearity is corrected within the control IC. In general the location accuracy is specified as follows: Actual co-ordinate point - theoretical co-ordinate point = location accuracy. In general a 9 point co-ordinate calibration system is used to adjust the micro controller accuracy. (20 point can be used in combination with an EEPROM design). Theoretical Error Actual Distance n 5.4 ENVIRONMENTAL -5˚C to 60˚C -20˚C to 70˚C 20% to 85% RH with a Maximum wet bulb temperature of 38˚C 10% to 90% RH with a Maximum wet bulb temperature of 38˚C Coating with the following chemicals and storing at room temperature for 2 hours gives no problems. 10% NaCl-water solution, ethyl-acetate, ethylalcohol, toluene, methyl-ethyl-ketone No issues down to 0.5 x Normal Air pressure Operating Temperature (*): Storage Temperature: Operating Humidity: Storage Humidity: Chemical Resistance: Low Air Pressure: n 5.5 PEN LIFE Note taking life: 100,000 words minimum Input life : 1,000,000 times minimum Note 1: Words are written in the notes area and the size of the word is 7.5mm x 6.75mm. A word is any Alphabet / Number / Mark. The pen is as shown below and applies a force of 250g. A failure is judged to happen when the current consumption or insulation resistance or dielectric strength are not met as shown in 5.3. The location accuracy with 9 point calibration must be ±4.4 mm max. Effective input area Notes 9 mm 10mm 0. 8 ø6.0 ø2.0 3.5 110.0±1.0 3.0 ø2. 0 1.0 1.5 ø 4.6 R 9.0 3 554 SERIES n 5.6 FINGER LIFE A finger is simulated by a silicon rubber plunger R8 (Round type 8mm size) hardness 60˚C at 200g at frequency 5Hz. A failure is judged to happen when the current consumption or insulation resistance or dielectric strength are not met as shown in 5.3. The location accuracy with 9 point calibration must be ±4.4 mm max. Operating force is 150g max. n 5.7 INFORMATION ON THE PANEL Production year 99 00 etc. 901 012 [.... [..... . . . . . . .] . . . . . .] The left side number shows production year, eg 1999 The left side number shows production year, eg 2000 The first dot after the space shows production month, eg May The first dot after the space shows production month, eg June n 6 PACKAGING n 6.1 PACKING SPECIFICATION Vibration: 10~55 Hz at 1 Octave per minute 10G 20 cycles with one side 0.75mm Drop test: 60cm Drop 1 corner, 3 crease lines and 6 faces. 1 each 1 time After the test no glass: flaw or crack is seen, and no dent or scratch on the film. Also glass and film must not separate. n 6.1 PACKING DETAILS Each touch panel is placed into a plastic bag and is held in place by a slit cut into the side of the cardboard. A second insertion piece is placed into the carton to again add stability. The qty is written on the side of the box. For example the N010-0554T001 has 80 pieces per box. Insert Touch panel with bag Slit in cardboard 550 Type panel illustrated (554 type packed a similar way) 4 554 SERIES n 7.0 REJECT CRITERIA Description Film Dent Reject Criteri a Area ≥ 0.1mm2 Area ≥ 0.05mm2 & area < 0.1mm2 Area < 0.05mm2 Area > 0.1mm2 Area ≥ 0.05mm2 & area < 0.1mm2 Area < 0.05mm2 Area > 0.1mm Area ≥ 0.03mm & width
N010-0554-T347 价格&库存
很抱歉,暂时无法提供与“N010-0554-T347”相匹配的价格&库存,您可以联系我们找货
