Datamate tooling
Instruction sheets (where available) can be accessed at www.harwin.com/downloads/instructions
seParator tool
recommended for unplugging L-Tek latched connectors (tool releases the latches prior to disengagement). Can also be used with unlatched and friction lock connectors. Suitable for all sizes.
insertion/reMoVal tool
For inserting crimped contacts into the rear of mouldings. Instruction sheet available. Suitable for all Datamate signal contacts.
orDer coDe
L-Tek
orDer coDe
t5746
Signal crimps for L-Tek, J-Tek & Mix-Tek
Z80-280
HanD CriMP tool
Standard coax crimp tool for crimping the outer sleeve of Mix-Tek coax contacts. Instruction sheet available.
reMoVal tool
To aid removal of special cable contacts from Mix-Tek connectors.
orDer coDe
Outer sleeve of Mix-Tek coax contacts
orDer coDe
Z80-293
Mix-Tek special cable connectors
Z80-290
www.harwin.com
79
很抱歉,暂时无法提供与“T5746”相匹配的价格&库存,您可以联系我们找货
