HMC-T2100
HMC-T2100
    HITTITE
    HMC-T2100 - SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz - Hittite Microwave Corporation
HMC-T2100 数据手册
HMC-T2100 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz 9 The HMC-T2100 is an easy to implement test equipment solution designed to fulfill your signal generation needs. Built on a foundation of high quality and market leading Hittite MMICs, the HMC-T2100 provides the highest output power, lowest harmonic levels and broadest frequency range amongst signal generators of its size and cost. SYNTHESIZED SIGNAL GENERATOR This compact and lightweight signal generator also features a choice between a USB, GPIB* or Ethernet* interface and innovative control software ensuring carefree integration within various test environments while improving overall productivity and equipment utilization. Applications ATE Test & Measurement R&D Laboratories Performance High Output Power: +27 dBm Wide Frequency Range: 10 MHz to 20 GHz Excellent Phase Noise Performance: -113 dBc/Hz @ 100 kHz Offset @ 1 GHz Spurious Rejection: -65 dBc @ 10 GHz Power Resolution: 0.1 dB Frequency Resolution: 10 kHz Advantages Versatile: Higher Drive Simplifies Test Set-Ups Efficient: 300 μs Frequency Switching Reliable: Incorporates Hittite MMICs Flexible: Manual or Software Control Via USB, GPIB* or Ethernet* v05.0709 9 - 12 20 Alpha Road Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.hittite.com HMC-T2100 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz v05.0709 Frequency Accuracy: As Per Internal Ref. ±1.5 ppm Resolution: 10 kHz Internal Reference: 10 MHz Aging Rate: 40 dB @ 10 GHz Resolution: 0.1 dB Output Source Match: < 2.0:1 Power Accuracy: ±1 dB for leveled outputs HMC-T2100 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz v05.0709 General Specifi cations Power: 100 to 240 VAC, 50 to 60 Hz, 264 VA Max. Calibration: 1 Year Environment (for indoor use only): 0 to 35 °C Cooling: 2 Internal Fans Input / Output: 10 MHz REFOUT: BNC Connector 10 MHz REFIN: BNC Connector RS-232 (factory use only) Ethernet (not part of initial release) GPIB (not part of initial release) USB 1.1/2.0 Mechanical Vibration & Shock: MIL-STD 810 Table 415.5 C-VII; MIL-STD 202 MTD 214 1.5G Compliance: CSA, CE General Mechanical Characteristics H: 3” [76.2mm], W: 8” [203mm], D: 12” [305mm] Weight 7 lbs [3.2 kg] Warranty: 1 Year parts and labor 9 Two Tone Third Order Intercept Test Set-up HMC-T2100 I/O CONTROL HMC-T2100 SYNTHESIZED SIGNAL GENERATOR Spectrum Analyzer HMC-T2100 RF RFIN DUT LO IF Device Under Test • Amplifiers • Mixers & Converters • Modulators • RFICs & Subsystems Efficient Mixer Conversion Loss, Isolation & MxN Spurious Test Set-up Device Under Test • Single or Double-Balanced Mixers • Up/Down Converters • I/Q Mixers LO IF HMC-T2100 I/O CONTROL DUT HMC-T2100 RF Spectrum Analyzer RFIN 9 - 14 20 Alpha Road Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.hittite.com HMC-T2100 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz YNTHESIZED GHz v05.0 v05.0709 HMC-T2100 Rear Panel I/O Connections MC-T2100 Rear Panel I/O Connections 9 Connectivity & Control Its compact size, light weight, fast switching speed and USB, GBIP and Ethernet control interfaces support the standard SCPI command set ensuring smooth integration within all test environments, particularly those associated with automated test. An installation disk that accompanies each unit includes all the drivers required to remotely control the device as well as a user friendly LabWindows™ based GUI interface (right) compatible with a Windows XP ® or Windows Vista® operating system. User control is facilitated via pull down menus that allow programming of single or swept modes in frequency and/ or power. Integration of multiple units within a production test environment is easy, and affordable. Remote Interface Hardware: USB (Windows XP®, Windows Vista® Drivers Supplied), GPIB* or Ethernet* * GPIB and Ethernet software control capability planned for September 2009 Software: LabVIEW / LabWindows™ Driver (XP) Frequency Switching Speed: 300 us Typ. Local Interface Front Panel Rotary Knob & Display 20 Alpha Road Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.hittite.com 9 - 15 SYNTHESIZED SIGNAL GENERATOR HMC-T2100 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz v05.0709 HMC-T2100 HMC-T2100DRM 9 Ordering Information Model Number HMC-T2100 Description Synthesized Signal Generator 10 MHz to 20 GHz Price $7,998.00 Ordering Information Description Synthesized Signal Generator HMC-T2100DRM 10 MHz to 20 GHz, Dual Rack Mountable Model Number Price $7,998.00 Includes 100 - 240V AC Power Supply and one Power Cord at no cost. Please specify your preferred power cord part number at time of ordering. (see “Optional Power Cord” table) Includes 100 - 240V AC Power Supply and one Power Cord at no cost. Please specify your preferred power cord part number at time of ordering. (see “Optional Power Cord” table) Optional Power Cord Part Number HMC-PC01 HMC-PC02 Region Continental Europe United Kingdom China Australia, New Zealand North America South Africa / India Switzerland Denmark Israel Italy Japan Price $9.25 $20.50 $15.50 $9.25 $9.25 $20.50 $15.50 $15.50 $15.50 $9.25 $9.25 Windows ® - Windows XP ® and Windows Vista ® are registered trademarks of Microsoft Corporation. LabWindows™ - L abWindows™ is a licensed trademark of National Instruments. Test Rack Mount Kit Part Number HMC-RM02 Description Dual Rack Mounting Plate 19” 2u Chassis Price $385.00 SYNTHESIZED SIGNAL GENERATOR HMC-PC03 HMC-PC04 HMC-PC05 HMC-PC06 HMC-PC07 HMC-PC08 HMC-PC09 HMC-PC10 HMC-PC11 All pricing is in U.S. Dollars and is subject to change without notice. 9 - 16 20 Alpha Road Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.hittite.com HMC-T2100 SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 20 GHz v05.0709 Notes: 9 20 Alpha Road Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order Online at www.hittite.com 9 - 17 SYNTHESIZED SIGNAL GENERATOR
HMC-T2100 价格&库存
很抱歉,暂时无法提供与“HMC-T2100”相匹配的价格&库存,您可以联系我们找货
