HLMP-C623-T0000
HLMP-C623-T0000
    HP
    HLMP-C623-T0000 - T - 13/4 Super Ultra-Bright LED Lamps - Agilent(Hewlett-Packard)
HLMP-C623-T0000 数据手册
Agilent T-13/4 Super Ultra-Bright LED Lamps Data Sheet HLMP-C115, HLMP-C117, HLMP-C123, HLMP-C215, HLMP-C223, HLMP-C315, HLMP-C323, HLMP-C415, HLMP-C423, HLMP-C515, HLMP-C523, HLMP-C615, HLMP-C623 Description These non-diffused lamps are designed to produce a bright light source and smooth radiation pattern. A slight tint is added to the lens for easy color identification. This lamp has been designed with a 20 mil lead frame, enhanced flange, and tight meniscus controls, making it compatible with radial lead automated insertion equipment. Features • Very high intensity • Exceptional uniformity • Microtint lens for color identification • Consistent viewability All colors: AlGaAs Red High Efficiency Red Yellow Orange Green Emerald Green • 15° and 25° family • Tape and reel options available • Binned for color and intensity Applications • Ideal for backlighting front panels* • Used for lighting switches • Adapted for indoor and outdoor signs Selection Guide Color DH AS AlGaAs 2θ1/2[1] 15 Standoff Leads No Part Number HLMPC115 C115-O00xx C115-OP0xx C117-OP0xx C123 C123-L00xx C215 C215-M00xx C215-MN0xx C223 C223-L00xx C223-MN0xx C315 C315-L00xx C315-LM0xx C323 C323-K00xx C323-KL0xx C415 C415-M00xx C415-M0D0xx C415-MN0xx C423 C423-L00xx C423-LM0xx C515 C515-L00xx C515-LM0xx C523 C523-J00xx C523-KL0xx C615 C615-G00xx C623 C623-E00xx Luminous Intensity Iv (mcd) Min. Max. 290.0 – 290.0 – 290.0 1000.0 290.0 1000.0 90.2 – 90.2 – 138.0 – 138.0 – 138.0 400.0 90.2 – 90.2 – 138.0 400.0 147.0 – 147.0 – 147.0 424.0 96.2 – 96.2 – 96.2 294.0 138.0 – 138.0 – 138.0 – 138.0 400.0 90.2 – 90.2 – 90.2 276.0 170.0 – 170.0 170.0 490.0 69.8 – 69.8 – 111.7 340.0 17.0 – 17.0 – 6.7 – 6.7 – 25 Red 15 Yes No No 25 No Yellow 15 No 25 No Orange 15 No 25 No Green 15 No 25 No Emerald Green 15 25 No No 2 Part Numbering System HLMP - C x xx - x x x xx Mechanical Options 00: Bulk 01: Tape & Reel, Crimped Leads 02: Tape & Reel, Straight Leads B2: Right Angle Housing, Even Leads UQ: Ammo Pack, Horizontal Leads Color Bin Options 0: Full Color Bin Distribution D: Color Bins 4 & 5 only Maximum Iv Bin Options 0: Open (No Maximum Limit) Others: Please refer to the Iv Bin Table Minimum Iv Bin Options Please refer to the Iv Bin Table Viewing Angle & Standoffs Options 15: 15 Degree, without Standoffs 17: 15 Degree, with Standoffs 23: 25 Degree, without Standoffs Color Options 1. AS AlGaAs Red 2. High Efficiency Red 3. Yellow 4. Orange 5. Green 6. Emerald Green Package Options C: T-1 3/4 (5 mm) 3 Package Dimensions 5.00 ± 0.20 (NOTE 1) (0.197 ± 0.008) 8.71 ± 0.20 (0.343 ± 0.008) 1.14 ± 0.20 (0.045 ± 0.008) 5.00 ± 0.20 (0.197 ± 0.008) 8.71 ± 0.20 (0.343 ± 0.008) 12.60 ± 0.18 (0.496 ± 0.007) 1.85 (0.073) MAX. 0.70 (0.028) MAX. 1.14 ± 0.20 (0.045 ± 0.008) 31.60 MIN. (1.244) 1.50 ± 0.15 (0.059 ± 0.006) 0.70 (0.028) MAX. 31.60 MIN. (1.244) CATHODE LEAD CATHODE LEAD 1.00 MIN. (0.039) 0.50 ± 0.10 SQ. TYP. (0.020 ± 0.004) 1.00 MIN. (0.039) 0.50 ± 0.10 SQ. TYP. (0.020 ± 0.004) 5.80 ± 0.20 (0.228 ± 0.008) CATHODE FLAT 2.54 ± 0.38 (0.100 ± 0.015) 5.80 ± 0.20 (0.228 ± 0.008) CATHODE FLAT 2.54 ± 0.38 (0.100 ± 0.015) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS (INCHES). 2. LEADS ARE MILD STEEL, SOLDER DIPPED. 3. AN EPOXY MENISCUS MAY EXTEND ABOUT 0.5 mm (0.020 in.) DOWN THE LEADS. HLMP-Cx15 and HLMP-Cx23 HLMP-Cx17 Absolute Maximum Ratings at TA = 25° C DH AS AlGaAs Red 30 500 5 110 –20 to +100 High Efficiency Red and Orange 30 500 5 110 High Performance Green and Emerald Green 30 500 5 110 –20 to +100 Parameter DC Forward Current[1] Transient Forward Current[2] (10 µsec Pulse) Reverse Voltage (Ir = 100 µA) LED Junction Temperature Operating Temperature Range Storage Temperature Range Wave Soldering Temperature [1.59 mm (0.063 in.) from body] Lead Solder Dipping Temperature [1.59 mm (0.063 in.) from body] Yellow 20 500 5 110 Units mA mA V °C °C °C –55 to +100 –55 to +100 250 °C for 3 seconds 260 °C for 5 seconds Notes: 1. See Figure 5 for maximum current derating vs. ambient temperature. 2. The transient current is the maximum nonrecurring peak current the device can withstand without damaging the LED die and wire bond. 4 Electrical Characteristics at TA = 25° C Forward Voltage Vf (Volts) @ If = 20 mA Typ. Max. 1.8 2.2 Reverse Breakdown Vr (Volts) @ Ir = 100 µA Min. 5 Capacitance C (pF) Vf = 0 f = 1 MHz Typ. 30 Thermal Resistance RθJ-PIN ( ° C/W) 210 Speed of Response τs (ns) Time Constant e-t/τs Typ. 30 Part Number HLMP-C115 HLMP-C117 HLMP-C123 HLMP-C215 HLMP-C223 HLMP-C315 HLMP-C323 HLMP-C415 HLMP-C423 HLMP-C515 HLMP-C523 HLMP-C615 HLMP-C623 1.9 2.1 1.9 2.2 2.2 2.6 2.6 2.6 3.0 3.0 5 5 5 5 5 11 15 4 18 18 210 210 210 210 210 90 90 280 260 260 Optical Characteristics at TA = 25° C Luminous Intensity Iv (mcd) @ 20 mA[1] Min. Typ. 290 600 90 138 90 146 96 138 90 170 69 17 6 200 300 170 300 170 300 170 300 170 45 27 Peak Wavelength λpeak (nm) Typ. 645 Color, Dominant Wavelength λd[2] (nm) Typ. 637 Viewing Angle 2θ1/2 (Degrees)[3] Typ. 11 26 17 23 17 25 17 23 20 28 20 28 Luminous Efficacy ηv (lm/w) 80 Part Number HLMP-C115 HLMP-C117 HLMP-C123 HLMP-C215 HLMP-C315 HLMP-C415 HLMP-C515 HLMP-C615 635 583 600 568 558 626 585 602 570 560 145 500 380 595 656 Notes: 1. The luminous intensity, Iv, is measured at the mechanical axis of the lamp package. The actual peak of the spatial radiation pattern may not be aligned with this axis. 2. The dominant wavelength, λd, is derived from the CIE Chromaticity Diagram and represents the color of the device. 3. 2θ1/2 is the off-axis angle where the luminous intensity is 1/2 the on-axis intensity. 5 1.0 EMERALD GREEN ORANGE TS AlGaAs RED DH As AlGaAs RED TA = 25° C RELATIVE INTENSITY HIGH PERFORMANCE GREEN 0.5 YELLOW HIGH EFFICIENCY RED 0 500 550 600 650 WAVELENGTH – nm 700 750 Figure 1. Relative intensity vs. wavelength. HIGH EFFICIENCY RED, ORANGE, YELLOW, AND HIGH PERFORMANCE GREEN, EMERALD GREEN 300.0 200.0 IF – FORWARD CURRENT – mA 100 50.0 20.0 10.0 5.0 2.0 1.0 0.5 0.2 0.1 TS AlGaAs RED IF – FORWARD CURRENT – mA 100.0 DH As AlGaAs RED 80 HIGH PERFORMANCE GREEN, EMERALD GREEN HIGH EFFICIENCY RED/ORANGE YELLOW 60 40 20 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 0 0 1.0 2.0 3.0 4.0 5.0 VF – FORWARD VOLTAGE – V VF – FORWARD VOLTAGE – V Figure 2. Forward current vs. forward voltage (non-resistor lamp). HER, ORANGE, YELLOW, AND HIGH PERFORMANCE GREEN, EMERALD GREEN 5.0 1.6 RELATIVE LUMINOUS INTENSITY (NORMALIZED AT 20 mA) 1.0 0.5 0.2 0.1 0.05 0.02 0.01 0.1 0.2 0.5 DH As AlGaAs RED RELATIVE LUMINOUS INTENSITY (NORMALIZED AT 20 mA) 2.0 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 0 5 10 15 20 25 30 TS AlGaAs RED 1 2 5 10 20 30 50 IF – DC FORWARD CURRENT – mA IDC – DC CURRENT PER LED – mA Figure 3. Relative luminous intensity vs. forward current. 6 DH As AlGaAs RED 1.2 1.3 1.2 HER, ORANGE, YELLOW, HIGH PERFORMANCE GREEN, EMERALD GREEN YELLOW EMERALD GREEN ηPEAK – RELATIVE EFFICIENCY (NORMALIZED AT 20 mA) 1.0 RELATIVE EFFICIENCY (NORMALIZED AT 20 mA) 1.1 1.0 0.9 HIGH PERFORMANCE GREEN HIGH EFFICIENCY RED/ORANGE 0.8 0.6 0.4 0.2 0 0.8 0.7 0.6 0.5 0.4 0 10 20 50 100 200 300 0 10 20 30 40 50 60 70 80 90 IPEAK – PEAK FORWARD CURRENT – mA IPEAK – PEAK FORWARD CURRENT – mA Figure 4. Relative efficiency (luminous intensity per unit current) vs. peak current. DH As AlGaAs RED 40 35 IF – FORWARD CURRENT – mA HER, ORANGE, YELLOW, AND HIGH PERFORMANCE GREEN, EMERALD GREEN 40 35 HER, ORANGE, GREEN, EMERALD GREEN RθJA = 470° C/W RθJA = 300° C/W YELLOW 15 10 5 0 0 20 RθJA = 705° C/W 30 25 20 15 10 5 0 0 20 40 60 80 100 RθJA = 559° C/W RθJA = 689° C/W IF – FORWARD CURRENT – mA 30 25 20 40 60 80 100 TA – AMBIENT TEMPERATURE – °C TA – AMBIENT TEMPERATURE – °C Figure 5. Maximum forward dc current vs. ambient temperature. Derating based on TjMAX = 110 °C. 1 NORMALIZED LUMINOUS INTENSITY 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 45 40 35 30 25 20 15 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 ANGULAR DISPLACEMENT – DEGREES Figure 6. Relative luminous intensity vs. angular displacement. 15 degree family. 7 1 NORMALIZED LUMINOUS INTENSITY 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 45 40 35 30 25 20 15 10 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 ANGULAR DISPLACEMENT – DEGREES Figure 7. Relative luminous intensity vs. angular displacement. 25 degree family. Intensity Bin Limits Color Bin L M N O P Q R S T U V W X Y Z L M N O P Q R S T U V W Intensity Range (mcd) Min. Max. 101.5 162.4 162.4 234.6 234.6 340.0 340.0 540.0 540.0 850.0 850.0 1200.0 1200.0 1700.0 1700.0 2400.0 2400.0 3400.0 3400.0 4900.0 4900.0 7100.0 7100.0 10200.0 10200.0 14800.0 14800.0 21400.0 21400.0 30900.0 173.2 250.0 250.0 360.0 360.0 510.0 510.0 800.0 800.0 1250.0 1250.0 1800.0 1800.0 2900.0 2900.0 4700.0 4700.0 7200.0 7200.0 11700.0 11700.0 18000.0 18000.0 27000.0 Red/Orange Yellow 8 Intensity Bin Limits, continued Color Bin E F G H I J K L M N O P Q R S T U V W Intensity Range (mcd) Min. Max. 7.6 12.0 12.0 19.1 19.1 30.7 30.7 49.1 49.1 78.5 78.5 125.7 125.7 201.1 201.1 289.0 289.0 417.0 417.0 680.0 680.0 1100.0 1100.0 1800.0 1800.0 2700.0 2700.0 4300.0 4300.0 6800.0 6800.0 10800.0 10800.0 16000.0 16000.0 25000.0 25000.0 40000.0 Green/ Emerald Green Maximum tolerance for each bin limit is ± 18%. Color Categories Color Category # 6 5 4 3 2 1 3 2 4 5 1 2 3 4 5 6 7 8 Lambda (nm) Min. 561.5 564.5 567.5 570.5 573.5 582.0 584.5 587.0 589.5 592.0 597.0 599.5 602.0 604.5 607.5 610.5 613.5 616.5 Max. 564.5 567.5 570.5 573.5 576.5 584.5 587.0 589.5 592.0 593.0 599.5 602.0 604.5 607.5 610.5 613.5 616.5 619.5 Green Yellow Orange Tolerance for each bin limit is ± 0.5 nm. 9 Mechanical Option Matrix Mechanical Option Code 00 01 02 B2 UQ Definition Bulk Packaging, minimum increment 500 pcs/bag Tape & Reel, crimped leads, minimum increment 1300 pcs/bag Tape & Reel, straight leads, minimum increment 1300 pcs/bag Right Angle Housing, even leads, minimum increment 500 pcs/bag Ammo Pack, horizontal leads, in 1K minimum increment Note: All categories are established for classification of products. Products may not be available in all categories. Please contact your local Agilent representative for further clarification/information. www.agilent.com/semiconductors For product information and a complete list of distributors, please go to our web site. For technical assistance call: Americas/Canada: +1 (800) 235-0312 or (916) 788-6763 Europe: +49 (0) 6441 92460 China: 10800 650 0017 Hong Kong: (+65) 6756 2394 India, Australia, New Zealand: (+65) 6755 1939 Japan: (+81 3) 3335-8152 (Domestic/International), or 0120-61-1280 (Domestic Only) Korea: (+65) 6755 1989 Singapore, Malaysia, Vietnam, Thailand, Philippines, Indonesia: (+65) 6755 2044 Taiwan: (+65) 6755 1843 Data subject to change. Copyright © 2004 Agilent Technologies, Inc. Obsoletes 5965-6165E November 11, 2004 5988-2149EN
HLMP-C623-T0000 价格&库存
很抱歉,暂时无法提供与“HLMP-C623-T0000”相匹配的价格&库存,您可以联系我们找货
