JC6-T207-10
JC6-T207-10
    HUMIREL(泰科)
JC6-T207-10 数据手册
Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Engineering Notes 112 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Table of Contents—Barrier Strips Overview ……………………………………………………………………………………114-118 (Barrier Strip Selector Chart) …………………………………………………………114, 115 Tri-Barrier Strips …………………………………………………………………………119-138 0.250" Pitch ……………………………………………………………………………120-123 0.325" Pitch ……………………………………………………………………………124-127 0.375" Pitch ……………………………………………………………………………128-135 0.4375" Pitch ……………………………………………………………………………136-138 Barrier Strips Dual-Barrier Strips ………………………………………………………………………139-160 0.250" Pitch ……………………………………………………………………………141-142 0.325" Pitch ……………………………………………………………………………143-146 0.375" Pitch ……………………………………………………………………………147-150 0.4375" Pitch ……………………………………………………………………………151-154 0.375" Double Row, Panel Mount ……………………………………………………155-156 0.433" Double Row, Panel Mount …………………………………………………………157 0.437" Double Row, Panel Mount …………………………………………………………158 0.563" Double Row, Panel Mount …………………………………………………………160 Sockets and Barrier Strips ……………………………………………………………161-173 0.325" Pitch, Series USB3 Socket ………………………………………………………162 0.375" Pitch, Series RSB6B Socket ………………………………………………………163 0.325" Pitch, Series RSB3 Tri-Barrier ………………………………………………164-166 0.325" Pitch, Series SSB3 Dual-Barrier ……………………………………………168-170 0.375" Pitch, Series RSB6 Tri-Barrier ………………………………………………171-173 2 Accessories ………………………………………………………………………………174-179 113 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Barrier Strip Selector Chart Tri-Barrier 0.250” 0.325” 0.325” 0.375” 0.375” 0.375” 0.375” 0.4375” #3 #4 1546927 #6 1546833 BC6 MB6 #8 Pitch (in) 0.250” 0.325” 0.325” 0.375” 0.375” 0.375” 0.375” 0.4375” Circuits 2-32 2-30 2-8 2-30 2-8 2-16 4-40 2-26 Max Current 10A 25A 15A 25A 15A 20A 25A 30A Max Voltage 300V 300V 300V 600V 300V 300V 300V 600V Wire Range (AWG) 18-22 12-22 14-22 12-22 14-22 12-22 12-22 10-18 Description Molded to length Molded to length Molded to length Molded to length Molded to length, Modular Molded to length Double Level snapped to length Molded to length Page 120-123 124-126 127 128-131 132 133-134 135 136-138 Series Dual-Barrier .250” 0.325” 0.325” 0.375” 0.375” 0.4375” 1546657 4DB 1546734 JC6 NC6 SSB7 Pitch (in) .250” 0.325” 0.325” 0.375” 0.375” 0.4375” Circuits 2-30 2-30 2-16 2-16 2-30 2-27 Max Current 10A 20A 20A 20A 20A 20A Max Voltage 300V 150V/ 300V 300V 300V 300V 600V Wire Range (AWG) 16-30 14-22 12-22 12-22 12-22 12-26 Description Molded to length Molded to length High Rise, Molded to length Molded to length Page 141-142 143-144 145-146 147-148 Series Low Profile version, Molded to length 149-150 Cut to length 151-154 114 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Barrier Strip Selector Chart (Continued) Double Row 0.433” 0.437” 1546306 1546307 1546481 1546477 1546670 1546671 1546310 1546311 1776544 1986158 Pitch (in) 0.374” 0.433” 0.437” 0.563” 0.563” Circuits 2-30 2-26 2-26 2-18 2-18 Max Current 20A 25A 25A 30A 30A Max Voltage 300V 300V 300V 300V 600V Wire Range (AWG) 12-22 14-22 14-22 10-22 10-22 Panel Mount, molded to length Panel Mount, molded to length Panel Mount, molded to length Panel Mount, molded to length Panel Mount, molded to length 156 157 158 159 160 0.325” 0.325” 0.325” 0.375” 0.375” USB RSB3 SSB3 RSB6B RSB6 Pitch (in) 0.325” 0.325” 0.325” 0.375” 0.375” Circuits 2-12 2-36 2-36 2-10 2-36 Max Current 10A 15A 15A 10A 20A Max Voltage 300V 300V 300V 300V 300V Wire Range (AWG) n/a 14-26 14-26 n/a 12-26 For Series RSB3 & SSB3 Cut to length Cut to length For Series RSB6 Cut to length 162 164-166 168-170 163 171-173 Series Description Page 0.563” Barrier Strips 0.374” 2 Sockets and Barrier Strips Series Description Page 115 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Catalog Number Code SSB 3 F P 06 02 02 Number of Circuits Type of Block SSB = Dual-Barrier RSB = Tri-Barrier 02 through XX 11 AA Circuit Identification Options First Number in Series Designator A Top Hardware Options Contact Spacing 3 = 0.325” 6 = 0.375” 7 = 0.4375” Base Options C = Closed Base F = Flat Base R = Raised Base T = Turret Base or Mounting Piece Options R = Right-angle mounting, without bracket V = Vertical mounting Terminal Options Mounting Options E = Open end positions, with mounting inserts, with end barriers F = Open end positions, without mounting inserts, without end barriers G = Open end positions, with mounting inserts, without end barriers H = All positions filled with contacts, without end barriers M = Open end positions, without mounting inserts, with end barriers P = All positions filled with contacts, with end barriers T = Threaded mounting plate in each end position OPTIONAL TERMINAL IDENTIFICATION Select the desired version from the list below and add the CODE NUMBER (11, 12, 15 or 16) to the end of the catalog number of the connector or header. CODE 11 = 1 2 3 4 . . . 12 = . . . 4 3 2 1 15 = . . . 4 3 2 1 16 = 1 2 3 4 . . . "First Number In Series" Designator* A B C D E = = = = = 1 2 3 4 5 F G H J K = = = = = 6 7 8 9 0 * Letters in this position designate the first number to be used in the consecutive sequence. Ex.: "A" would start the sequence with the number 1. "EK" would start the sequence with the number 50. "BKK" would start the series with 200. For non-sequential numbering and special characters, consult Technical Support. Note: Some catalog number combinations are not valid. Check appropriate catalog pages before ordering. Catalog numbering code applies only to the catalog numbers on pages 125, 148-151, 164-169. 116 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Catalog Number Code (Continued) 6 PCV-04-XXX Contact Spacing 3 = 0.250” 4 = 0.325” 6 = 0.375” 8 = 0.4375” Suffix (if applicable) Number of Circuits 02 through XX Style Double Printed Circuit Pin Printed Circuit, Right Angle Printed Circuit Pin, Vertical Quick Connect Tab, Right Angle Quick Connect Tab, Vertical Solder Turret, Right Angle Solder Turret, Vertical Non Feed Thru Solderless Wire Wrap, Right Angle Solderless Wire Wrap, Vertical Barrier Strips Terminal DBL = PCR = PCV = QCR = QCV = STR = STV = TBV = WWR = WWV = 2 Note: Some catalog number combinations are not valid. Check appropriate catalog pages before ordering. Catalog numbering code applies only to the catalog numbers on pages 119-124, 127-129, 134-136. 117 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Barrier Strips – Overview Two Types of Barrier Strips and a Line of Sockets: Tri-Barrier Resilient Plastic Barriers Quality Plating Three walls or barriers surround each terminal screw. The back wall safeguards field wiring. Flexible thermoplastic material for terminal blocks was an especially important feature at the time of its introduction, since many earlier blocks were molded of more rigid, brittle thermosetting plastic compounds. Dual-Barrier Wire-Ready Raised Screws Two walls or barriers are molded on each side of the terminal screw. Wire-ready raised screws are standard on BUCHANAN terminal blocks. No need to back off the screw first. Just insert the wire and drive down the screw. Wire installation time and effort are virtually cut in half. Tyco Electronics Corporation has been known for its plating, especially on the tin-plated components, and has maintained stringent plating specifications to provide a better performing, more reliable product. (Terminals meet or exceed Tyco Electronics Specification 109-11-1.) Sockets Integral Standoffs Mounted directly to the PC board, the Barrier Strip is plugged into the socket. The socket expedites field maintenance. (Below, a tri-barrier is about to be mounted in a socket.) Standoffs help rid your PCB of any remaining corrosive agents during rinsing operations. Helps prevent trapped solutions in the immediate PC pin area. Significantly reduces the risk of postwave corrosion problems. Gas-Tight Connections Wire Clamp Screws The lower surface and edges of the clampingplates are carefully designed to securely clamp the wire—even combinations of different wire sizes—without severing stranded wire. Extra care has been taken to produce these components without burrs on any critical clamping surface or edges. UL Recognition and CSA Certification Terminal blocks and interconnect components are Recognized under the Component Recognition Program of Underwriters Laboratories Inc. and Certified by Canadian Standards Association. (Consult individual sections of this catalog for status of a specific series.) Typical Application Pictured below is a PC board with barrier strips and sockets wave soldered to it. The acid-tin plating on our terminals means more than just improved shelf-life and superior solderability. It is to provide the very basis for the heart of your wire connections. 118 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Tri-Barrier Strips Product Facts n Industrial controls and automation n Machine tools n HVAC/R n Power supplies n Security/Irrigation n Transformers Design Advantages n Back Barrier Strips barriers to safeguard field wiring n Fast wiring – backed-out wire-ready screws n Interrupted thread designed to prevent screws from falling out n Standoffs allow flux and solvents to drain during cleaning n Molded-to-length or cut-tolength versions available n Phil-slot screws are standard n RoHS compatible 2 Tri-Barrier blocks help contain stray or frayed wire ends. This helps prevent electrical shorts — not only between positions on the same block, but also between other components immediately adjacent to the block. With today’s highdensity PCB designs, this has become an increasingly important feature. Connector Index 0.250” Pitch, Series #3 …………………………120-123 0.325” Pitch, Series #4 …………………………124-126 0.325” Pitch, with Attached Safety Cover ……………127 0.375” Pitch, Series #6 …………………………128-135 0.375” Pitch, Modular with Cover ……………………132 0.375” Pitch, Series BC6, Panel Mount…………133,134 0.375” Pitch, Series MB6, Double Level ……………135 0.4375” Pitch, Series #8 …………………………136-138 119 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks .250” [6.35] Pitch, Series #3 3PCV-03-006 & 3PCV-10-006 4.1 (.16) 2.8 (.11) 4.6 (.18) 1.9 (.075) 7.9 (.31) 8.4 (.33) Material & Finish Housing Material—Polypropylene Flammability—UL94V-0 Color—Black Terminals—Bright acid tin over copper alloy Screws—Steel, zinc plating with clear chromate coating. Wire clamping screws standard. 14.0 (.55) 4.1 (.16) 4.8 (.19) 3.15 Dia. (.125) RIGHT ANGLE VERTICAL Mechanical Properties 4.1 (.16) 1.8 Dia. (.073) 6.3 (.250) Pitch (Terminal Spacing)— 0.250” [6.35] Recommended PCB Hole Dia.— 1.8mm [.073”] Recommended Tightening Torque: 5.5 in.-lbs. Optional End Mounting MOUNTING PANEL LAYOUT VERTICAL RIGHT ANGLE Right Angle Mount 6.1 (.24) 5.8 (.23) Electrical Properties 3.2/(.125) Dia. Ratings—UL Class C 10 Amps, 150V UL Class D 10 Amps, 300V CSA Type C 10 Amps, 150V CSA Type D 10 Amps, 300V Wire Range—18-22 AWG RIGHT ANGLE CENTER PRINTED CIRCUIT LAYOUT Environmental Properties Operating Temperature Range— 105°C [221°F] max. Circuit Identification—See page 179 Hardware Options TC3—Safety cover, see page 174 J3—Jumper, see page 177 LR30811 E54800 120 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 7.6 (.30) ( Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks .250” [6.35] Pitch, Series #3 (Continued) 3 PCV - 04 - 006 Ordering Information A B A Thread Size Spacing 3 = #m3 on .250" Centers B Terminal Style PCV = Printed Circuit Pin, Vertical PCR = Printed Circuit, Right Angle STV = Solder Turret, Vertical STR = Solder Turret, Right Angle WWV = Solderless Wire Wrap, Vertical PCV PCR STV WWV STR Modifier Phil-slot Head C D No. of Circuits (Not Positions) 02 through 32 Modifier Use table below. Screw Style Mounting Construction 006 Wire Clamp No Mounting 008 Wire Clamp 006 Wire Clamp 008 Wire Clamp 006 Wire Clamp 008 Wire Clamp 006 Wire Clamp 008 Wire Clamp Barrier Strips Terminal Style D C 2 No Mounting No Mounting LR30811 E54800 121 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks .250” [6.35] Pitch, Series #3 (Continued) Printed Circuit Pin Optional OptionalEnd End Mount MountEnd Optional Mount 4,8 4,8 (.19) (.19) 4,8 (.19) 5,8 5,8 (.23) (.23) 5,8 (.23) 5,1 5,1 (.20) (.20) 5,1 (.20) PCR PCR PCR PCV PCV PCV 0,8 0,8 (.036) (.036) 0,8 (.036) 4,1 4,1 (.16) (.16) 4,1 1,1 1,1 (.045) (.045) 1,1 (.045) (.16) Solder Turret Optional OptionalEnd End Mount MountEnd Optional 10,2 10,2 (.40) (.40) 10,2 Mount (.40) 5,8 5,8 (.23) (.23) 5,8 (.23) STR STR STV STV STR STV 6,4 6,0 (.25) (.24) 6,4 Dia. Dia. (.25) Dia. 3,18 3,25 Dia. Dia. (.125) (.128) 3,18 Dia. (.125) #3 #3Right RightAngle Angle Mount Bushing Mount Bushing #3 Right Angle 10,2 10,2 (.40) (.40) 10,2 (.40) 2,5 2,5 (.10) (.10) 2,5 (.10) Mount Bushing 1,1 1,1 (.045) (.045) 1,1 (.045) 2,5 2,5 (.10) (.10) 2,5 (.10) 0,9 0,9 (.035) (.035) 0,9 (.035) 4,1 4,1 (.16) (.16) 4,1 (.16) Wire Wrap Optional OptionalEnd End Mount MountEnd Optional #3WWR not available Mount WWV WWV WWV 12,7 12,7 (.50) (.50) 12,7 (.50) 1,1 1,1 (.045) (.045) 1,1 (.045) 0,9 0,9 (.035) (.035) 0,9 (.035) 4,1 4,1 (.16) (.16) 4,1 (.16) LR30811 E54800 122 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks .250” [6.35] Pitch, Series #3 (Continued) 4,1 (.16) L = A+ 1,8 (.07) 12,7 (.500) A 0,9 (.035) 3,04 (.12) Dia. 6,1 (.24) 14,0 (.55) 4,1 (.16) ,8 9) 6,1 (.24) 3,15 Dia. (.125) 1,8 Dia. (.073) 4,1 (.16) 4,1 (.16) #3-48 Wire Clamping Screw 6,1 (.24) Right Angle Mount 1,0 (.04) 7,6 6,3 (.30) (.25) 12,7 (.50) Barrier Strips 6,3 (.250) 4,8 (.19) 6,3 (.250) Optional End Mounting Vertical Mount 3,2/(.125) Dia. No. of Positions 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Dim. A 0.25 [6.3] 0.50 [12.7] 0.75 [19.0] 1.00 [25.4] 1.25 [31.7] 1.50 [38.1] 1.75 [44.4] 2.00 [50.8] 2.25 [57.1] 2.50 [63.5] 2.75 [69.8] 3.00 [76.2] 3.25 [82.5] 3.50 [88.9] 3.75 [95.2] 4.00 [101.6] No. of Positions 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 2 Dim. A 4.25 [107.9] 4.50 [114.3] 4.75 [120.6] 5.00 [127.0] 5.25 [133.3] 5.50 [139.7] 5.75 [146.0] 6.00 [152.4] 6.25 [158.8] 6.50 [165.1] 6.75 [171.5] 7.00 [177.8] 7.25 [184.2] 7.50 [190.5] 7.75 [196.9] LR30811 E54800 123 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325” [8.26] Pitch, Series #4, Tri-Barrier 4PCV-06-006 8,3 (.325) 5,8 (.23) (For Dual Pin Configuration) 9,0 .351 1,8 Dia. 4,6 (.073) (.18) 6,3 (.25) 3,8 Dia. (.150) Material & Finish Housing Material—Polyamide Flammability—UL94V-0 Color—Black Terminals—Bright acid tin over copper alloy Screws—#4-40 steel, zinc plating with clear chromate coating. Wire clamping screw and binding head screw available. Right Angle Vertical Printed Circuit Board Layout Suggested Panel Cutout 3,8 Dia. (.15) 6,3 (.25) 3,5 (.14) 3,8 Dia. (.15) 6,3 (.25) 3,5 (.14) Mechanical Properties Pitch (Terminal Spacing)— 0.325” [8.255] Recommended PCB Hole Dia.— 1.8mm [.073”] Recommended Tightening Torque—7 in.-lbs. max. 1,4 (.055) Electrical Properties 4,8 (.19) 1,4 (.055) 4,8 (.19) 6,3 (.25) 6,3 (.25) Panel Layout Ratings—UL Class C 20 Amps, 150V UL Class D 10 Amps, 300V CSA Type C 20 Amps, 150V CSA Type D 10 Amps, 300V Wire Range—12-22 AWG Environmental Properties Operating Temperature Range— 105°C [221°F] max. Circuit Identification—See page 179 Hardware Options TC4—Safety cover, see page 174 8-1437649-0—Wire clamp screw, see page 178 8-1437649-0—Binding head screw, see page 178 J4—Jumper, see page 177 LR30811 E54800 124 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325” [8.26] Pitch, Series #4, Tri-Barrier (Continued) Ordering Information 4 PCV-04-006 A B Screw Size Spacing 4 = #4-40 on .325" Centers B Terminal Style DBL = Double Printed Circuit Pin PCR = Printed Circuit, Right Angle PCV = Printed Circuit Pin, Vertical WWV = Solderless Wire Wrap, Vertical Terminal Style D C D No. of Circuits (Not Positions) 02 through 30 Modifiers Use table below. Modifier Phil-slot Head Screw Style Mounting Construction DBL 006 Wire Clamp No Mounting PCV 006 Wire Clamp No Mounting 008 Wire Clamp 006 Wire Clamp 008 Wire Clamp 006 Wire Clamp 008 Wire Clamp PCR WWV Barrier Strips A C 2 No Mounting No Mounting LR30811 E54800 125 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 4,8 (.19) Optional End Mount 0.325” [8.26] Pitch, Series #4, Tri-Barrier (Continued) Printed Circuit Pin 5,8 (.23) PCR 4,8 (.19) PCV DBL Optional End Mount 1,1 (.045) PCR 5,1 (.20) 0,9 (.035) 4,6 (.18) 3,3 .130 9,0 PCV .351 DBL 5,8 (.23) 0,9 (.035) 1,1 (.045) 5,1 (.20) Wire Wrap 4,6 (.18) 3,3 .130 9,0 .351 Optional End Mount #4 WWR Not available WWV Optional End Mount 0,9 (.035) 12,7 (.50) 1,1 (.045) WWV 4,6 (.18) 0.325” Pitch, Series #4, Tri-Barrier L = A+ 16,5 (.65) 4,6 (.18) 3,8 Dia. (.150) A 6,3 (.25) 15,2 (.60) 8,3 (.325) Optional End Mounting 6,7 (.27) 4,8 (.19) #4-40 Wire Clamping Screw Right Angle Mount 12,7 (.50) 7,6 (.30) No. of Positions 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 0,9 (.035) 12,7 (.50) 1,1 (.045) 6,3 (.25) Dim. A (0.325) 8,2 (0.65) 16,5 (0.97) 24,7 (1.30) 33,0 (1.62) 41,3 (1.95) 49,5 (2.27) 57,8 (2.60) 66,0 (2.92) 74,3 (3.25) 82,5 (3.57) 90,8 (3.90) 99,1 (4.22) 107,3 (4.55) 115,6 (4.87) 123,8 Vertical Mount 1,0 (.04) No. of Positions 17 18 19 20 21 22 23 24 25 26 27 28 29 30 Dim. A (5.20) 132,1 (5.52) 140,3 (5.85) 148,6 (6.17) 156,8 (6.50) 165,1 (6.82) 173,3 (7.15) 181,6 (7.47) 189,9 (7.80) 198,1 (8.13) 206,4 (8.45) 214,6 (8.78) 222,9 (9.10) 231,1 (9.43) 239,4 LR30811 E54800 126 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Tri-Barrier Strips with Attached Safety Covers, .325” [8.26] Centerline Product Facts n Screwdriver access holes in cover allow for efficient wiring; cover may remain closed Barrier Strips 2 Material & Finish .280 [7.11] Insulator Body—UL 94V-0 Thermoplastic, black Terminal—Brass, tin-plated .59 [14.9] Mechanical Properties Recommended screw tightening torque—12 in-lbs Combination drive screws with #2 Phillips recess and standard slot .20 [5.1] .325 [8.25] .031 [.79] Electrical Properties Current Rating—15 A Voltage Rating— 300 VAC/DC Wire Range—22-14 AWG, Cu, Solid or Stranded .61 [15.5] .047 [1.19] Dim. B ± .025 [0.6] Dim. A ± .025 [0.6] Environmental Properties Operating Temperature— -40˚C to +120˚C [-104°F to +248°F] Circuit Identification—See page 179 No. of Position* 2 3 4 5 6 7 8 Dimensions A B 0.697 [17.7] 0.325 [08.3] 1.022 [26.0] 0.650 [16.5] 1.347 [34.2] 0.975 [24.8] 1.672 [42.5] 1.300 [33.0] 1.997 [50.7] 1.625 [41.3] 2.322 [59.0] 1.950 [49.5] 2.647 [67.2] 2.275 [57.8] Part Numbers 1546927-2 1546927-3 1546927-4 1546927-5 1546927-6 1546927-7 1546927-8 *Contact Tyco Electronics for larger position sizes. Note: Samples available in Sample Room. 127 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series #6, Tri-Barrier 6PCV-03-006 & 6PCV-06-006 (For Dual Pin Configuration) 10,9 .433 1,8 Dia. 4,6 (.073) 10,9 (For Dual Pin Configuration)(.18) 9,5 (.375) 6,8 (.27) 9,5 (.375) 6,8 (.27) .433 1,8 Dia. (.073) 4,6 (.18) 7,9 (.31) 7,9 (.31) 3,8 Dia. (.150) Material & Finish 3,8 Housing Material—Polyamide Flammability—UL94V-0 Color—Black Terminals—Bright acid tin over copper alloy Screws—#6-32 steel, zinc plating with clear chromate coating. Wire clamping screws and binding head screws with undercut available. 5,6 (.22) 5,6 (.22) 4,1 (.16) 4,0 (.156) 4,0 4,1 (.16) (.156) Pitch (Terminal Spacing)— 0.375" [.525] Recommended PCB Hole Dia.— 1.8mm [.073"] Ratings—UL Class C 25 Amps, 300V UL Class D 5 Amps, 600V CSA Type C 25 Amps, 300V CSA Type D 5 Amps, 600V Wire Range—18-22 AWG Cut Out 6,3 (.25) Cut Out 2,4 Cut Out 2,4 (.094) (.094) 8,4 8,4 (.33) 7,9 (.33) 5,6 4,8 4,8 (.19) (.19) Electrical Properties 6,3 (.25) Cut Out 6,3 6,3 (.25) (.25) Mechanical Properties Dia. Right Angle (.150) Vertical Printed Circuit Board Layout 3,8 3,8 Dia. (.15)Dia. (.15) 7,9 (.31) (.31) 5,6 (.22) (.22) Right Angle Vertical Mounting Panel Layout Environmental Properties Operating Temperature Range— 105°C [221°F] max. Circuit Identification—See page 179 Hardware Options QC6—Quick connects, see page 176 ST80—Single sided solder tabs, see page 176 J6—Jumpers, see page 177 TC6—Safety covers, see page 174 1437651-2—Wire clamp screw, steel, see page 178 1437651-5—Wire clamp screw, brass, see page 178 1437651-8—Binding head screw, steel, see page 178 LO3—Binding head screw, stainless, see page 178 LR30811 E54800 128 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series #6, Tri-Barrier (Continued) 6 PCV-04-006 A B C Screw Size Spacing 6 = #6-32 on .375" Centers B Terminal Style DBL = Double Printed Circuit Pin PCR = Printed Circuit, Right Angle PCV = Printed Circuit Pin, Vertical STR = Solder Turret, Right Angle STV = Solder Turret, Vertical TBV = Non Feed Thru WWR = Solderless Wire Wrap, Right Angle WWV = Solderless Wire Wrap, Vertical Terminal Style DBL PCV PCR STV C D No. of Circuits (Not positions) 02 through 30 Modifiers Use table below. -002=-006 except brass screw -003=-007 except brass screw Barrier Strips A D Modifier Phil-slot Head Screw Style Mounting Construction 006 Wire Clamp No Mounting 007 Binding Head 006 Wire Clamp 007 Binding Head 008 Wire Clamp 009 Binding Head 006 Wire Clamp 007 Binding Head 008 Wire Clamp 009 Binding Head 006 Wire Clamp 008 Wire Clamp 006 Wire Clamp 008 Wire Clamp 006 Wire Clamp 2 No Mounting No Mounting WWV STR No Mounting WWR TBV LR30811 E54800 129 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series #6, Tri-Barrier (Continued) L=A+ 19.0 (.750) 7.9 (.31) 17.8 (.70) 8.0 (.315) 9.5 (.375) Optional End Mounting 5.6 (.22) #6-32 Wire Clamping Screw #6-32 Binding Head Screw 7.1 (.28) 1.3 (.05) No. of Positions Dim. A No. of Positions Dim. A 2 0.375 [9.5] 17 6.00 [152.4] 3 0.75 [19.1] 18 6.37 [161.9] 4 1.12 [28.6] 19 6.75 [171.4] 5 1.50 [38.1] 20 7.12 [181.9] 6 1.87 [47.6] 21 7.50 [190.5] 7 2.25 [57.1] 22 7.87 [200.0] 8 2.62 [66.7] 23 8.25 [209.5] 9 3.00 [76.2] 24 8.62 [219.1] 10 3.37 [85.7] 25 9.00 [228.6] 11 3.75 [95.2] 26 9.38 [238.1] 12 4.12 [104.8] 27 9.75 [247.7] 13 4.50 [114.3] 28 10.13 [257.2] 14 4.87 [123.8] 29 10.50 [266.7] 15 5.25 [133.3] 30 10.88 [276.2] 16 5.62 [142.9] 15.2 (.60) LR30811 E54800 130 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series #6, Tri-Barrier (Continued) Printed Circuit Pin Optional Vertical Mount 5,1 (.20) PCR 6,9 (.27) 3,3 (.13) PCV DBL 0,84 (.033) 4,8 (.19) 1,1 (.045) 4,6 (.18) 10,9 (.433) Solder Turret 9,9 (.39) Barrier Strips STR 6,9 (.27) STV 8,4 (.33) 9,4 (.37) 3,8 Dia. (.45) #6 Right Angle Mount Bushing 7,6 (.30) Dia. 3,8 (.15) 2,5 (.10) 0,9 (.035) 4,6 (.18) 1,1 .045 2 Wire Wrap 17,8 (.70) WWR WWV 6,9 (.27) 6,9 (.27) #6 Right Angle Mount Bushing 7,6 (.30) Dia. 4,1 Dia. (.16) #6 Screw Clearance 17,3 (.68) 1,1 (.045) 0,9 (.035) 4,6 (.18) Non-Feed Thru TBV TBV Molded in Clearance Holes 3,81/ (.150) Dia. LR30811 E54800 131 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Modular w/cover, Tri-Barrier DIM L±.508 [DIM L±.020] DIM A±.508 [DIM A±.020] Material & Finish Housing Material—Polyamide Flammability—UL94V-0 Color—Black Terminals—Brass, tin-plated Screws—m3.5, steel, nickel plated 16.5±.38 [.650±.015] 7.6±.38 [.300±.015] Mechanical Properties 7.5±.38 [.295±.015] Pitch (Terminal Spacing)— 0.375" [.525] Recommended PCB Hole Dia.— 1.8mm [.073"] Recommended Tightening Torque— 12 in.-lb. 17.3±.38 [.680±.015] 1.5 [.060] 9.5 [.375] Electrical Properties Ratings*—UL Class B 15 Amps, 300V UL Class D 10 Amps, 300V *Evaluated to U.S. and Canadian Standards. Wire Range—18-22 AWG Environmental Properties Operating Temperature Range—--40°C to +120°C [-104°F to +248°F] Circuit Identification—See page 179 5.08±.508 [.20±.02] .81 [.032] 4.0±.38 [.157±.015] DIM A 9.5 [.375] 1.9 [.073] 4.0 [.157] 16.5 [.650] REF 4.7 [.187] TYP Recommended PC Board Layout No. of Positions 2 3 4 5 6 7 8 Dimension A .375 [9.5] .750 [19.0] 1.125 [28.6] 1.500 [38.1] 1.875 [47.6] 2.250 [57.1] 2.625 [66.7] Part Numbers 1546833-2 1546833-3 1546833-4 1546833-5 1546833-6 1546833-7 1546833-8 LR30811 E60677 132 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series BC6 No. of Positions 2 3 4 5 6 7 8 9 Dim. A .375 [9.5] .750 [19.1] 1.125 [28.6] 1.500 [38.1] 1.875 [47.6] 2.250 [57.1] 2.625 [66.7] 3.000 [76.2] No. of Positions 10 11 12 13 14 15 16 Dim. A 3.375 [85.7] 3.750 [95.2] 4.125 [104.8] 4.500 [114.3] 4.875 [123.8] 5.250 [133.3] 5.625 [142.9] Barrier Strips 2 Printed Circuit Board Mounting Panel Layout LR30811 E54800 133 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series BC6 Ordering Information BC6 - P 1 08 - 08 A D Terminal Style P=Printed Circuit (available with 1,2,5 block style only) T=Solder Turret Q=Quick Connect .250 W=Solderless Wrap E=Extended Circuit Board F=Quick Connect .187 B Block Style 1=Flat, all positions filled (standard) 2=Flat, end mounting ears with holes (required for cover option) 3=Insulating turret, end mounting ears with holes (required for cover option) 4=Insulating turret, all positions filled 5=Flat, end positions open with mounting bushings 6=Insulating turret, end positions open with mounting bushings C Screw Hardware 07=Steel binding combo head screw 08=Steel wire-clamp combo head screw (standard) 05=Brass binding combo head screw 06=Brass wire-clamp combo head screw D No. of Circuits (Not Positions) 02 to 25 circuits Mechanical Properties Pitch (Terminal Spacing)— 0.375" [.525] Recommended PCB Hole Dia.— 1.8mm [.073"] Electrical Properties Ratings—UL Class C 20 Amps, 300V UL Class D 5 Amps, 600V CSA Type C 20 Amps, 300V Wire Range—12-22 AWG C A Material & Finish Housing Material—Polypropylene Flammability—UL94V-0 Color—Black Terminals—Bright acid tin over copper alloy Screws—#6-32 steel, zinc plating with clear chromate coating. Wire clamping screws and binding head screws available. B Environmental Properties Operating Temperature Range— 105°C [221°F] max. Circuit Identification—See page 179 Hardware Options TC2—Safety covers, see page 174 QC2x—.250 Quick connects, see page 176 QC4x—.187 Quick connects, see page 176 ST80—Single sided solder tabs, see page 176 1437661-7—Retaining clip, Insulating turret, see page 178 J6—Jumpers, see page 177 1437651-2—Wire clamp screw, steel, see page 178 1437651-5—Wire clamp screw, brass, see page 178 1437651-8—Binding head screw, steel, see page 178 LO3—Binding head screw, stainless, see page 178 LR30811 E54800 134 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 11,7 (.46) Ref. Screw (Optional) A 8,0 (.315) Typ. 7,6 (.30) Note: All part numbers 36,3 (1.43) are RoHS Compliant. BUCHANAN Terminal Blocks 3,8 (.15) 23,3 4,8 15,5 (.93) (.19) (.61) 0.375” [9.53] Pitch, Series MB6, Double Level MB6-P108-## 1,1 (.045) Typ. 9,5 (.375) Typ. ORDERING INFORMATION 0,9 1,8 1,3 (.073) (.050) Dia. Typ. 4,6 (.18) 4,6 (.18) MB6 - P1 08 - 04 (.035) Typ. 17,8 B (.70) A 17,8 (.70) C D A Series MB6=Double Level, 0.375" Centers B Terminal Style P1=Printed Circuit Pin, Vertical C Screw Hardware 08=Steel wire clamp combo head screws D 02 through 40 available in multiples of 2 Material & Finish 4,7 (.187) Typ. Printed Circuit Board Layout Barrier Strips Housing Material—Thermoplastic polyamide Flammability—UL94V-0 Color—Black Terminals—Bright acid tin over copper alloy Screws—#6-32 steel, zinc plating with clear chromate coating. End Module Mechanical Properties 6,8 (.27) REF Pitch (Terminal Spacing)— .375" [9.525] Recommended PCB Hole Dia.— 1.8mm [.073"] 2 20,1 (.79) Electrical Properties End Cover Ratings—UL Class C 25 Amps, 300V CSA Type C 25 Amps, 600V Wire Range—12-22 AWG Wire-Clamping Plate Screw 9,5 (.375) Environmental Properties 5,6 (.22) 11,7 (.46) Ref. Operating Temperature Range— 105°C [221°F] max. Binding Head Screw (Optional) A 8,0 (.315) Typ. 7,6 (.30) 36,3 (1.43) Hardware Options 3,8 (.15) 23,3 4,8 15,5 (.93) (.19) (.61) 1437651-2—Wire clamp screw, see page 178 9,5 (.375) Typ. 1,1 (.045) Typ. 1,8 1,3 (.073) (.050) Dia. Typ. 4,6 (.18) 0,9 (.035) Typ. 4,6 (.18) 17,8 (.70) 17,8 (.70) No. of Positions 4 6 8 10 12 14 16 18 20 22 Dim. A 0.375 [9.5] 0.750 [19.1] 1.125 [28.6] 1.500 [38.1] 1.875 [47.6] 2.250 [57.1] 2.625 [66.7] 3.000 [76.2] 3.375 [85.7] 3.750 [95.2] 4,7 (.187) Typ. No. of Positions 24 26 28 30 32 34 36 38 *40 Dim. A 4.125 [104.8] 4.500 [114.3] 4.875 [123.8] 5.250 [133.3] 5.625 [142.9] 6.000 [152.4] 6.375 [161.9] 6.750 [171.4] 7.125 [181.0] * Longer lengths available. Please consult Technical Support. LR49571 E60980 135 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.4375” [11.1] Pitch, Series #8 #8 Series Tri-Barriers 1,8 Dia. (.073) 11,1 (.4375) 5,1 (.20) 8,1 (.32) 3,1 (For Dual (.514) Pin Configuration) 4,5 Dia. (.18) 8,4 (.33) VERTICAL RIGHT ANGLE PRINTED CIRCUIT BOARD LAYOUT Material & Finish 5,5 (.255) Housing Material—Polypropylene Flammability—UL94V-0 Color—Black Terminals—Bright acid tin over copper alloy Screws—#8-32 steel, zinc plating with clear chromate coating. Wire clamping screws and binding head screws with undercut available. 6,1 (.24) Cut Out 8,4 (.33) 11,2 (.44) 3,0 (.12) 6,5 (.255) 4,5 Dia. (.18) 5,6 (.22) RIGHT ANGLE VERTICAL MOUNTING PANEL LAYOUT Pitch (Terminal Spacing)— .4375" [11.1] Recommended PCB Hole Dia.— 1.8mm [.073"] L = A+ Electrical Properties 22,2 (.875) A 20,3 (.80) Ratings—UL Class C 30 Amps, 600V CSA Type C 30 Amps, 600V Wire Range—10-18 AWG (UL) 10-22 AWG (CSA) 11,1 (.4375) Environmental Properties 8,1 (.32) 6,5 (.255) 8,4 (.33) 9,3 (.368) #8-32 Wire Clamping Screw 5,1 (.20 ) Right Angle Mount Hardware Options TC8—Safety covers, see page 174 QC8—Quick connects, see page 176 J8—Jumpers, see page 177 1437425-1—Wire clamp screw, see page 178 1437429-1—Binding head screw, steel, see page 178 7,6 (.30) Cut Out 7,6 (.30) Mechanical Properties Operating Temperature Range— 105°C [221°F] max. Circuit Identification—See page 179 4,5 Dia. (.18) 4,8 (.19) Vertical Mount 0,8 (.03) 8,5 (.335) 4,8 (.19) No. of Positions 2 3 4 5 6 7 8 9 10 11 12 13 14 17,8 (.770) 5,1 (.20) Dim. A 0.4375 [11.1] 0.87 [22.2] 1.31 [33.3] 1.75 [44.5] 2.19 [55.6] 2.62 [66.7] 3.06 [77.8] 3.50 [88.9] 3.93 [100.0] 4.37 [111.1] 4.81 [122.2] 5.25 [133.3] 5.69 [144.5] No. of Positions 15 16 17 18 19 20 21 22 23 24 25 26 Dim. A 6.12 [155.6] 6.56 [166.7] 7.00 [177.8] 7.44 [188.9] 7.87 [200.0] 8.31 [211.1] 8.75 [222.2] 9.19 [233.4] 9.62 [244.5] 10.06 [255.6] 10.50 [266.7] 10.94 [277.8] LR30811 E54800 136 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.4375” [11.1] Pitch, Series #8 (Continued) 8 PCV-04-006 Ordering Information A Screw Size Spacing 8 = #8-32 on .4375" Centers B Terminal Style DBL = Double Printed Circuit Pin PCR = Printed Circuit, Right Angle PCV = Printed Circuit Pin, Vertical QCR = Quick Connect Tab, Right Angle QCV = Quick Connect Tab, Vertical STR = Solder Turret, Right Angle STV = Solder Turret, Vertical TBV = Non Feed Thru WWR = Solderless Wire Wrap, Right Angle WWV = Solderless Wire Wrap, Vertical Terminal Style DBL PCV PCR Modifier Phil-slot Head B C C D D No. of Circuits (Not positions) 02 through 26 Modifiers Use table below. -002=-006 except brass screw -003=-007 except brass screw ComboHead Head Phil-slot Screw Style Mounting Construction 006 Wire Clamp No Mounting 007 Binding Head 006 Wire Clamp 007 Binding Head 008 Wire Clamp 009 Binding Head 006 Wire Clamp 007 Binding Head 008 Wire Clamp 009 Binding Head 006 Wire Clamp 008 Wire Clamp 006 Wire Clamp 008 Wire Clamp 006 Wire Clamp Barrier Strips A 2 No Mounting QCV STV WWV QCR No Mounting STR WWR TBV LR30811 E54800 137 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.4375” [11.1] Pitch, Series #8 (Continued) Printed Circuit Pin Optional Vertical Mount 5,1 (.20 ) PCR 8,1 (.32 ) 3,3 (.13 ) PCV DBL 0,84 (.033 ) 4,8 (.19 ) 1,1 (.045 ) 13,1 (.514 ) Solder Turret 5,1 (.20 ) 10,2 (.40 ) STR 8,1 (.32 ) STV 10,4 (.41 ) 11,8 (.465) 4,6 Dia. (.18 ) #8 Right Angle Mount Bushing Wire Wrap 3,8 (.15 ) 9,1 (.36 ) Dia. 3,0 (.12 ) 0,84 (.033) 5,1 (.20 ) 1,7 (.065) 13,2 (.52 ) WWR WWV 8,1 (.32 ) 1,1 (.045 ) 4,1 Dia. (.16 ) #8 Screw Clearance 6,4 (.25 ) 17,8 (.70 ) #8 Right Angle Mount Bushing Quick Connect 0,84 (.033 ) 5,1 (.20 ) 13,2 (.52 ) QCR QCV 8,1 (.32 ) 13,2 (.52 ) 0,84 (.033 ) 6,4 (.25 ) #8 Right Angle Mount Bushing 5,1 (.20 ) 4,7 (.187) Non-Feed Thru TBV TBV Vertical Mount Bushings 138 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Dual-Barrier Strips Product Facts n Industrial controls and automation n Machine tools n HVAC/R n Power supplies n Security/Irrigation n Transformers Design Advantages n Fast Barrier Strips wiring – backed-out wire-ready screws n Interrupted thread designed to prevent screws from falling out n Standoffs allow flux and solvents to drain during cleaning n Molded-to-length or cut-tolength versions available 2 The Dual-Barrier design provides a more costeffective solution than the Tri-Barrier Strips while still supplying many of the design advantages. Connector Index Single Row 0.250" Pitch, Series 1546657 ………………………141, 142 0.325" Pitch, Series 4DB ……………………………143-144 0.325" Pitch, High Rise ………………………………145-146 0.325" Pitch, Series SSB3……………………………168-170 0.375" Pitch, Series JC6 ……………………………147, 148 0.375" Pitch, Series NC6, Low Profile ……………149, 150 0.4375" Pitch, Series SSB7……………………………151-154 Double Row, Panel Mount 0.374" Pitch …………………………………………………156 0.433" Pitch …………………………………………………157 0.437" Pitch …………………………………………………158 0.563" Pitch …………………………………………………160 139 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Engineering Notes 140 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks High-Density, Dual-Barrier Strips, .250” [6.35] Centerline Product Facts n High density accommodates today's compact PCB layouts Barrier Strips 2 Material & Finish Insulator Body—UL 94V-0 thermoplastic, black Terminal—Brass, tin-plated Screw—M3, Steel, nickel-plated Mechanical Properties Recommended Tightening Torque—10 in-lbs Combination drive screws with #2 Phillips recess and standard slot Electrical Properties Current Rating—10 A Voltage Rating—300 VAC/DC per UL and CSA standards Wire Range—16-30 AWG Copper, Solid or Stranded Environmental Properties Operating Temperature—-40˚F to +221˚F [-40˚C to +115˚C] Circuit Identification—See page 179 Hardware Options TC8—Safety cover, see page 174 QC8—Quick connects, see page 176 J8—Jumpers, see page 177 1437425-1—Wire clamp screw, see page 178 1437429-1—Binding head screw, steel, see page 178 E60677 141 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks High-Density, Dual-Barrier Strips, .250” [6.35] Centerline (Continued) .55 [13.97] .55 [13.97] Dim. A ±0.02 [.5] Dim. A ±0.02 [.5] Dim. B Dim. B .21±.01 [5.3±.25] .21±.01 [5.3±.25] .59 [15.0] .33 [8.4] .59 [15.0] .33 [8.4] .17±.02 [4.3±.5] .17±.02 [4.3±.5] .039 [1.0] .250 .039 [1.0] [6.4] .250 [6.4] Dim. A Dim. A .030 [.8] .030 [.8] .13 [3.3] .13 [3.3] .16 [4.1] .13 [3.3] .16 [4.1] .13 [3.3] Ø.067 .55 [14.0] [1.7] .55 [14.0] Ø.067 [1.7] .250±.003 [6.35±.08] Non-Cumulative .250±.003 [6.35±.08] Recommended PCBNon-Cumulative Layout Recommended PCB Layout No. of Positions 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Dimension A B 0.250 [6.35] 0.54 [13.7] 0.500 [12.7] 0.79 [20.1] 0.750 [19.1] 1.04 [26.4] 1.000 [25.4] 1.29 [32.8] 1.250 [31.8] 1.54 [39.1] 1.500 [38.1] 1.79 [45.5] 1.750 [44.4] 2.04 [51.8] 2.000 [50.8] 2.29 [58.2] 2.250 [57.2] 2.54 [64.5] 2.500 [63.5] 2.79 [70.9] 2.750 [69.9] 3.04 [77.2] 3.000 [76.2] 3.29 [83.6] 3.250 [82.6] 3.54 [90.0] 3.500 [88.9] 3.79 [96.3] Part Number 1546657-2 1546657-3 1546657-4 1546657-5 1546657-6 1546657-7 1546657-8 1546657-9 1-1546657-0 1-1546657-1 1-1546657-2 1-1546657-3 1-1546657-4 1-1546657-5 No. of Positions 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 Dimension A B 3.750 [95.3] 4.04 [102.6] 4.000 [101.6] 4.29 [108.9] 4.250 [107.9] 4.54 [115.3] 4.500 [114.3] 4.79 [121.7] 4.750 [120.6] 5.04 [128.0] 5.000 [127.0] 5.29 [134.4] 5.250 [133.3] 5.54 [140.7] 5.500 [139.7] 5.79 [147.1] 5.750 [146.1] 6.04 [153.4] 6.000 [152.4] 6.29 [159.8] 6.250 [158.8] 6.54 [166.1] 6.500 [165.1] 6.79 [172.5] 6.750 [171.5] 7.04 [178.8] 7.000 [177.8] 7.29 [185.2] 7.250 [184.2] 7.54 [191.5] Part Number 1-1546657-6 1-1546657-7 1-1546657-8 1-1546657-9 2-1546657-0 2-1546657-1 2-1546657-2 2-1546657-3 2-1546657-4 2-1546657-5 2-1546657-6 2-1546657-7 2-1546657-8 2-1546657-9 3-1546657-0 E60677 142 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325” [8.26] Pitch, Series 4DB 4DB-P108-## Ordering Information 4DB - P 1 08 - 06 A D B Terminal Style P = Printed Circuit Pin W = Wire Wrap R = Right Angle C Block Style 1 = Flat, all positions filled 2 = Flat, end mounting holes D Screw Type 07 = Steel binding combo head screws 08 = Steel wire clamp combo head screws E No. of Circuits (Not Positions) 02 through 30 E Barrier Strips Series 4DB = Dual-Barrier, 0.325" Centers Mechanical Properties Pitch (Terminal Spacing)— 0.325" [9.525] Recommended PCB Hole Dia.— 1.7mm [0.07"] C A Material & Finish Housing Material—Thermoplastic Polyamide Flammability—UL94V-0 Color—Black Terminals—Bright acid-tin over copper alloy Screws—#6-32 steel, zinc plating with clear chromate coating. Wire clamping screws and binding head screws available. B 2 Electrical Properties Ratings—UL Class C 20 Amps, 150V UL Class D 10 Amps, 300V CSA Type B 20 Amps, 300V CSA Type C 20 Amps, 300V CSA Type D 10 Amps, 300V CSA Type E 20 Amps, 300V Wire Range—12-22 AWG Environmental Properties Operating Temperature Range— 105°C [221°F] max. Circuit Identification—See page 179 Hardware Options QC4—Quick connects, see page 176 J4—Jumpers, see page 177 9-1437667-9—Wire clamp screw, see page 178 LR30811 E54800 143 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325” [8.26] Pitch, Series 4DB (Continued) 8,2 L= (.325) (N+1) Optional End Mounting Holes A 12,7 (.50) 8,2 (.325) Typ. 3,3 (.13) Ref. 5,1 (.20) 6,7 (.265) Typ. 6-32 Binding Head Screw (Std.) 6-32 Wire Clamping Screw 13,5 (.53) 7,4 (.29) 1,3 (.05) Typ. 0,9 (.03) 1,7 (.070) Dia. Typ. 8,2 (.325) Typ. 4,1 (.16) 2,4 (.09) Typ. 3,8 (.150) (Dia.) PRINTED CIRCUIT BOARD LAYOUT Bend Options: A variety of bend options are available. Please consult Technical Support for details. 2,3 (.09) Right Angle Wire Wrap P. C. Pin Non Feed Thru X 0,8 (.032) Typ. 13,2 (.52) 4,0 (.16) Y No. of Positions 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Dim. A 0.325 [8.2] 0.650 [16.5] 0.975 [24.8] 1.300 [33.0] 1.625 [41.3] 1.950 [49.5] 2.275 [57.8] 2.600 [66.0] 2.925 [74.3] 3.250 [82.5] 3.575 [90.8] 3.900 [99.1] 4.225 [107.3] 4.550 [115.6] 4.875 [123.8] No. of Positions 17 18 19 20 21 22 23 24 25 26 27 28 29 30 8,6 (.34) 2,4 (.095) (All Pins) Typ. Dim. A 5.200 [132.1] 5.525 [140.3] 5.850 [148.6] 6.175 [156.8] 6.500 [165.1] 6.825 [173.3] 7.150 [181.6] 7.475 [190.0] 7.800 [198.1] 8.125 [206.4] 8.450 [214.6] 8.775 [222.8] 9.100 [231.1] 9.425 [239.4] LR30811 E54800 144 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks High Rise Dual-Barrier Strips, .325 [8.26] Centerline Product Facts n High rise profile provides wire entry access on congested PC boards n Space saving high rise design allows for dual-level wire entry when used with 4DB series barrier strips n Captive screws provided in wire-ready position Barrier Strips 2 Material & Finish Insulator Body—UL 94V-0 Thermoplastic, Black Terminal—Brass, Tin plated Mechanical Properties Recommended Tightening Torque—10 in-lbs Combination drive screws with #2 Phillips Recess and Standard Slot Electrical Properties Current Rating—10 A Voltage Rating—20 A, 300 VAC/DC per UL and CSA standards Wire Range—12-22 AWG Cu, Solid or Stranded Environmental Properties Operating Temperature—-40˚F to +221˚F [-40˚C to +105˚C] Circuit Identification—See page 179 Hardware Options J4—Jumpers, see page 177 E60677 145 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks High Rise Dual-Barrier Strips, .325 [8.26] Centerline (Continued) A B .625 [15.88] Housing, Nylon Black, UL 94V-0 Rated 6-32 SEMS Screw, Captivated, Steel, Zinc Plated Clear Chromate .915 [23.24] .580 [14.73] Terminal, Brass, Tin Plated .0315 [.80] Typ. .325 [8.26] Typ. .060 [1.52] Typ. .184±.020 [4.67±.51] Typ. .313±.008 [7.95±.20] B ± .010 [.25] .625 [15.87] .3125 [7.94] .325±.003 [8.25±.08] .077±.003 [1.96±.08] Typ. Recommended PC Board Layout No of Positions 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Dimension A B 0.725 [18.42] 0.325 [8.26] 1.050 [26.67] 0.650 [16.51] 1.375 [34.93] 0.975 [24.77] 1.700 [43.18] 1.300 [33.02] 2.025 [51.44] 1.625 [41.28] 2.350 [59.69] 1.950 [49.53] 2.675 [67.95] 2.275 [57.79] 3.000 [76.20] 2.600 [66.04] 3.325 [84.46] 2.925 [74.29] 3.650 [92.71] 3.250 [82.55] 3.975 [100.97] 3.575 [90.81] 4.300 [109.22] 3.900 [99.06] 4.625 [117.48] 4.225 [107.32] 4.950 [125.73] 4.550 [115.57] 5.275 [133.99] 4.875 [123.83] Part Number 1546734-2 1546734-3 1546734-4 1546734-5 1546734-6 1546734-7 1546734-8 1546734-9 1-1546734-0 1-1546734-1 1-1546734-2 1-1546734-3 1-1546734-4 1-1546734-5 1-1546734-6 E60677 146 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series JC6 JC6-P107-03 Ordering Information JC6 - P 1 07 - 06 A Material & Finish D E B Terminal Style C = Non Feed Thru E = Extended Circ. Bd. F = Quick Connect, .187 P = Printed Circuit Pin (available with 1, 2 Block Style) T = Solder Turret Q = Quick Connect, .250 W = Solderless Wrap C Block Style 1 = Flat, all positions filled 2 = Flat, end mounting ears (required for cover option) 3 = Insulating turret, end mounting ears with holes (required for cover option) 4 = Insulating turret, all positions filled 5 = Flat, open end with mounting bracket 6 = Flat, open end, mounting bracket, insulating turret 7 = Closed bottom, end mounting ears. (for C style terminal only) Electrical Properties D Screw Hardware 05 = Brass binding combo head screws 06 = Brass wire-clamp combo head screws 07 = Steel binding combo head screws 08 = Steel wire-clamp combo head screws (standard) E No. of Circuits (Not positions) 02 through 25 Environmental Properties Operating Temperature Range— 105°C [221°F] max. Circuit Identification—See page 179 Barrier Strips Series JC6 = Dual-Barrier, 0.375" Centers Pitch (Terminal Spacing)— 0.375" [9.525] Recommended PCB Hole Dia.— 1.8mm [.073"] Ratings—UL Class C 20 Amps, 300V UL Class D 5 Amps, 600V CSA Type B 20 Amps, 300V CSA Type C 20 Amps, 300V CSA Type D 5 Amps, 600V CSA Type E 20 Amps, 600V Wire Range—12-22 AWG C A Housing Material—Polypropylene Flammability—UL94V-0 Color—Black Terminals—Bright acid-tin over copper alloy Screws—#6-32 steel, zinc plating with clear chromate coating. Wire clamping screws and binding head screws available. Mechanical Properties B 2 Hardware Options TC9—Safety cover, see page 174 QC2x—.250 Quick connects, see page 176 QC4x—.187 Quick connects, see page 176 J6—Jumpers, see page 177 J7x—Over-the-barrier jumpers, see page 177 1437661-7—Retaining clips, insulating turrets, see page 178 1437651-2—Wire clamp screw, steel, see page 178 1437651-5—Wire clamp screw, brass, see page 178 1437651-8—Binding head screw, steel, see page 178 LO3—Binding head screw, stainless, see page 178 LR30811 E54800 147 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series JC6 (Continued) No. of Positions 2 2 3 4 5 6 7 8 9 10 11 12 13 Dim. A 0.325 [8.2] 0.375 [9.5] 0.750 [19.1] 1.125 [28.6] 1.500 [38.1] 1.875 [47.6] 2.250 [57.1] 2.625 [66.7] 3.000 [76.2] 3.375 [85.7] 3.750 [95.2] 4.125 [104.8] 4.500 [114.3] No. of Positions 14 15 16 17 18 19 20 21 22 23 *24 *25 Dim. A 4.875 [123.8] 5.250 [133.3] 5.625 [142.9] 6.000 [152.4] 6.375 [161.9] 6.750 [171.45] 7.125 [180.98] 7.500 [190.5] 7.875 [200.03] 8.250 [209.55] 8.625 [219.08] 9.000 [228.60] Ears Shown * No mounting available Bend Options A variety of bend styles are available. Please consult Technical Support for details. PRINTED CIRCUIT BOARD//MOUNTING PANEL LAYOUT Available Block Styles: 1/2/5 Available Block Styles: 2/3/4/5/6 Available Block Styles: 2/3/4/5/6 Available Block Styles: 2/3/4 Available Block Styles: 1/2/3/4/5/6 Extended Circuit Board 11,9 (.47) 1,5 (.06) Available Block Styles: 7 Insulated Quick Connect Non Feed-Thru Extended Circuit Board 13,2 (.52) LR30811 E54800 148 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, NC6 Series, Low Profile NC6-P108-03 Ordering Information NC6 - P 1 08- 04 A Material & Finish D E A Series NC6 = Dual-Barrier, 0.375" Centers, Low Profile B Terminal Style L=A+ 19,0 (.750) P = Printed Circuit Pin C Block Style 1 = Flat, all positions filled 2 = End mounting holes provided A D Mechanical Properties Pitch (Terminal Spacing)— .375" [9.525] Screw Size—#6-32 steel Recommended PCB Hole Dia.— 1.8mm [.073"] dia. C 15,9 (.63) Screw Hardware 9,5 combo head screws 05 = Brass binding 5,5 (.375) 06 = Brass wire-clamp combo head screws (.22) 1,5 Typ. 07 = Steel binding combo head (.06) screws 08 = Steel wire-clamp combo head screws 6-32 Wire Clamping E No. Screw Barrier Strips Housing Material—Thermoplastic polyamide Flammability—UL94V-0 Color—Black Terminals—Bright acid tin over copper alloy Screws—#6-32 steel, zinc plating with clear chromate coating. Wire clamping screws and binding head screws available. B 8,0 (.315) 6-32 Binding Head Screw of Circuits (Not positions) 02 through 24 2 16,4 (.65) P. C. Pin Electrical Properties 8,9 (.35) Ratings—UL Class C 20 Amps, 300V CSA Type C 20 Amps, 300V Wire Range—12-22 AWG 0,8 Environmental Properties Operating Temperature Range— 105°C [221°] max. Circuit Identification—See page 179 Hardware Options 1437651-2—Wire clamp screw, steel, see page 178 1437651-5—Wire clamp screw, brass, see page 178 1437651-8—Binding head screw, steel, see page 178 LO3—Binding head screw, stainless, see page 178 4,6 (.18) (.032) 1,8 Dia. (.073) 9,5 (.375) Typ. 1,0 (.04) 1,5 (.06) 5,5 (.22) 15,4 (.625) RECOMMENDED PCB HOLE LAYOUT LR30811 E54800 149 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, NC6 Series, Low Profile (Continued) L=A+ 19,0 (.750) A 15,9 (.63) 9,5 (.375) Typ. 6-32 Wire Clamping Screw 5,5 (.22) 1,5 (.06) 8,0 (.315) 6-32 Binding Head Screw 16,4 (.65) P. C. Pin 8,9 (.35) 0,8 4,6 (.18) (.032) 9,5 (.375) Typ. 1,0 (.04) 1,8 Dia. (.073) 1,5 (.06) 5,5 (.22) 15,4 (.625) No. of Positions 2 3 4 5 6 7 8 9 10 11 12 13 Dim. A 0.375 [9.5] 0.750 [19.1] 1.125 [28.6] 1.500 [38.1] 1.875 [47.6] 2.250 [57.1] 2.625 [66.7] 3.000 [76.2] 3.375 [85.7] 3.750 [95.2] 4.125 [104.8] 4.500 [114.3] No. of Positions 14 15 16 17 18 19 20 21 22 *23 *24 Dim. A 4.875 [123.8] 5.250 [133.3] 5.625 [142.9] 6.000 [152.4] 6.375 [161.9] 6.750 [161.9] 7.125 [171.4] 7.500 [181.0] 7.875 [190.5] 8.250 [200.0] 8.625 [209.6] * No mounting available 150 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.4375” [11.1] Pitch, Series SSB7 SSB7FP##0202 Binding Head Scew Material & Finish Barrier Strips Housing Material—Polypropylene Flammability—UL94V-2 Color—Black Terminals—Brass, bright acid tin over copper plating Screw—#6-32 Steel with zinc + chromate plating Mechanical Properties Pitch (Terminal Spacing)— .4375 in. [11.1] Recommended PCB Hole Dia.— .077" [1.955] Wire Strip Length—.38" [9.652] Recommended Tightening Torque—8 in-lbs. Recommended Screwdrivers— Stanley 1006-4, Sears Craftsman 41581, Any #2 Phillips-Head Wire Lug Width (Max.)—8.1mm [.320 in.] Electrical Properties Ratings—UL Class B 20 Amps, 600V UL Class C 20 Amps, 600V CSA Type C 20 Amps, 300V CSA Type D, 5 Amps, 600V Wire Range—12-22 AWG Dielectric Withstand—5000V Environmental Properties Operating Temperature Range—60°C to +105°C [-76°F to +221°F] Computing Barrier Block Lengths Direct Mounting—Use C1 and L1 for P & H mounting options End Position Mounting—Use L2 and C2 for M, E, F & G mounting options 2 Circuits (not positions) 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 C1 in. — 0.44 0.88 1.31 1.75 2.19 2.63 3.06 3.50 3.94 4.38 4.81 5.25 5.69 6.13 6.56 7.00 7.44 7.88 8.31 8.75 9.19 9.63 10.06 10.50 10.94 11.38 L1* in. — 1.00 1.44 1.88 2.31 2.75 3.19 3.63 4.06 4.50 4.94 5.38 5.81 6.25 6.69 7.13 7.56 8.00 8.44 8.88 9.31 9.75 10.19 10.63 11.06 11.50 11.94 C2 in. 0.88 1.31 1.75 2.19 2.63 3.06 3.50 3.94 4.38 4.81 5.25 5.69 6.13 6.56 7.00 7.44 7.88 8.31 8.75 9.19 9.63 10.06 10.50 10.94 11.38 — — L2* in. 1.44 1.88 2.31 2.75 3.19 3.63 4.06 4.50 4.94 5.38 5.81 6.25 6.69 7.13 7.56 8.00 8.44 8.88 9.31 9.75 10.19 10.63 11.06 11.50 11.94 — — LR25557 E63810 151 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.4375” [11.1] Pitch, Series SSB7 (Continued) Ordering Information SSB 7 F P 06 02 02 11 Single Screw Dual-Barrier Strip SSB B Contact Spacing (Center-to-Center) 7 =.4375 (7/16) C Base Options C=Closed Base F=Flat Base R=Raised Base T=Turret Base (Available only with 01, 04, 05, 07, 09, 12, 13, 15 style bottom terminals) D Mounting Options (See illustration below) E=Open end positions, with mounting inserts, with end barriers F=Open end positions, without mounting inserts, without end barriers G=Open end positions, with mounting inserts, without end barriers M=Open end positions, without mounting inserts, with end barriers P=All positions filled with contacts, with end barriers E C D E F G No. of Circuits (Not Positions) Must conform to mounting options 02 to 32 circuits (P & H mounting) 02 to 27 circuits (M, E, F & G mounting) Terminal Style 01=Solder Tail 02=Printed Circuit Pin 03=Non-Feed Through (with C base only) 04=Extended Printed Circuit Pin 05=Quick Connects 06=90° bend, .46" x .11" (with F base only) 07=Wire Wrap 08=90° bend, .75" x .11" (with F base only) 12=90° bend, .21" x .65" 13=90° bend, .36" x .50" 14=90° bend, .41" x .16" (with F base only) 15=90° bend, .51" x .35" 16=90° bend, .32" x .25" (with F base only) G Top Hardware Options 00=No top hardware (Separately packaged binding head screws supplied at no cost) 01=Bright zinc and chromate plated steel binding head screw 02=Bright zinc and chromate plated steel screw and captive clamp - Do not order with other top hardware 03=Stainless steel binding head screw 04=Nickel plated brass binding head screw 09=Nickel plated brass screw and captive clamp - Do not order with other top hardware 80=Single-sided solder tab 81=Double-sided solder tab Quick-Connect Blades (supplied with 01 screw) .250 wide x.032 thick 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 H .187 wide x.020 thick 40= 41= 42= 43= 44= 45= 46= 47= 48= 49= 50= 51= 52= 53= 54= 55= 56= Circuit Identification Options 11 12 13 14 15 16 = 12345... = ...54321 = = = = 1 2 3 4 5 . . . F H 1 2 3 4 5 . . . A B ...54321 12345... A LR25557 E63810 152 Catalog 1308389 Revised6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.4375” [11.1] Pitch, Series SSB7 (Continued) Contact Spacing Options: Mounting Options: Terminal Style: .4375 in (7/16") Spacing End Position Mounting Solder Tail Extra thick barriers provide higher voltage rating. Up to 27 ckts. (25 circuits for end mounted blocks) Base Options: Closed Base Flat Base Catalog Letter Code: F. Lends itself most readily to applications where direct topto-bottom feedthrough is required with no special requirement for circuit isolation on the bottom side. The most common example of this is printed circuit board mounting. Without End Barriers Catalog Letter Codes: F, G & H. Facilitates mounting-screw access when end sections are used for mounting. Direct Mounting Catalog Letter Codes: P & H. SSBs may be solder-mounted using the bottom terminals themselves, as in the case of printed circuit board applications. Direct mounting is also possible with turret base models using press-on retaining clips (Catalog No. L97, Part Number 1437661-7) on turrets. Raised Base Catalog Letter Code R. Standoffs between each circuit raise block .030" above mounting surface to allow flux and solvents to drain during soldering operations. Available only with 02 and 04 bottom terminals. Turret Base Catalog Letter Code: T. Combines top-to-bottom feed-through with bottom-side circuit isolation for panels up to .126" thick. Turret bases are available with the following terminals: solder tail, quick connect, machine wrap, extended circuit board terminal, and right-angle. Catalog Number Code: 01. For applications requiring a wrapped solder connection. Printed Circuit Pin Catalog Number Code: 02. Designed specifically for mounting on .063" thick circuit board. Special, readily solderable plating permits good fillet development in automated soldering processes. Barrier Strips Catalog Letter Code: C. For terminal junctionblocks requiring top connections only. Useful in applications requiring single point circuit terminations or circuit completion via top mounted, single- and two-sided quick-connects. Replace double-row barrier strips. Catalog Letter Codes: E, F, G or M. Supplied without contacts in end sections to allow installer to mount blocks with screws in end section holes. Base of block will support mounting screws (Codes F & M). Also available with mounting inserts installed in end mounting holes to raise mounting screw heads to the level of other top hardware (Codes E & G). Non-Feed-Through Catalog Number Code: 03. With closed base option only. 2 Extended Printed Circuit Pin Catalog Number Code: 04. Useful where extra length is needed, as in thicker printed circuit boards or single-wrap connections. Quick Connect Hardware Options 7C1xxx—Safety cover, see page 175 QC2x—.250 Quick connects, see page 176 QC4x—.187 Quick connects, see page 176 ST80—Single sided solder tabs, see page 176 1776090-x—Extra long Quick connects, see page 176 J7—Jumpers, see page 177 L91—Mounting insert, see page 178 L92—Angle bracket, see page 178 Catalog Number Code: 05. .250 in. wide x .032" thick blades accept .250" female quick connects. LR25557 E63810 153 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.4375” [11.1] Pitch, Series SSB7 (Continued) Mounting Position: Top Hardware Options: Solder Tabs Right-Angle Binding Head Screws Catalog Number Codes: 06, 08, 12, 13, 14, 15, 16. In most applications, binding head screws will provide excellent wire retention because of exclusive wire locking tabs. These binding head screws are available in 3 materials identified by codes 01, 02, and 03. Catalog Number Code: 80. Singlesided, slotted solder tabs are available for making wrapped solder connections on the top side of SSBs. Seven variations of right-angle contacts are available. Designed for circuit board and panel applications, this option saves space when printed circuit boards are stacked closely together. It provides access to top connections in restricted spaces. Mount with angle brackets. (Catalog No. L92). Catalog No. Code 06* 08* 12 13 14* 15 16* A in. 0.46 0.75 0.21 0.36 0.41 0.51 0.32 B in. 0.11 0.11 0.65 0.50 0.16 0.35 0.25 *Not available with turret base Wire Wrap Catalog Number Code: 07. Longer than extended circuit board terminals. Post alignment is compatible with tolerances required for automatic wire wrapping equipment. Post dimensions are compatible with standard wire wrapping bits. Catalog Number Code: 01 Bright Zinc and Chromate Plated Steel 02 Stainless Steel 03 Nickel Plated Brass Captive Clamp For applications requiring extra security, captive clamps under the screw heads augment the locking tabs on each contact. Scews have a unique Philslot design accepting either Phillipshead or straight screwdriver. Code 02 screw is Bright Zinc and Chromate plated steel. Code 09 screw is Nickel plated Brass. Circuit Identification Options: Catalog Number Codes: 11 through 16. SSB blocks may be ordered with circuit identification numbers in white on the molding in six different variations. Custom markings are available on special order. Catalog Number Code: 02 Bright Zinc and Chromate Plated Steel 09 Nickel Plated Brass Catalog Number Codes: 20 through 56. A complete selection of .187" and .250" quick-connect blades are available for connecting wire terminated with female quick connects. Single-and double-sided types in flat, 45º and 90º angle bends can be supplied. Material is brass with tin plating. All blades supplied with 01 screws. Various quickconnects can be combined. Molding Material Options: The standard SSB molding material is UL94V-2 polypropylene. Consult Technical Support for other materials available on special order. Molding Color Options: SSB blocks are stocked in black. Consult Technical Support for availability of other colors. 154 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Double-Row, Dual-Barrier Strips Product Facts n Double-row, dual barrier strips for wire-to-wire applications. These parts also allow end users to complete the wiring to a separate screw without disturbing the factory wiring. n Available with either binding head screws or wire clamp n Increased current-carrying capability Barrier Strips Applications n Industrial Controls Equipment n HVAC n Power Supplies n Traffic Signals n Telecom n Test 2 Key Features n Closed bottom design allows for mounting direct to sheet metal panel n Molded to length n Accessories such as QuickConnect Tabs and Jumpers available n Wire-to-wire termination: - .374 [9.5] centerline: Up to 30 positions - .433 [11.0] centerline: Up to 26 positions - .437 [11.1] centerline: Up to 26 positions - .563 [14.3] centerline: Up to 18 positions n RoHS Compliant E60677 155 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Double-Row, Dual-Barrier Strips (Continued) .374 [9.5] Centerline Dim. L ±.024 [±0.6] Material & Finish Dim. S ±.02 [±0.5] Insulator Body—UL94V-0, thermoplastic, black Terminals—Brass, tin plated Screw—#6-32 steel, nickel plated .158 [4.0] Dia. Ref. .315±.008 [8.0±0.2] Typ. Mechanical Properties .374±.008 [9.5±0.2] Typ. Screw Torque—12 in-lb .315±.008 [8.0±0.2] Typ. Electrical Properties Current Rating—20 A, 300 VAC Wire Range—12-22 AWG Withstanding Voltage—2000 VAC min. .268±.012 [6.8±0.3] .732±.012 [18.6±0.3] .512±.012 [13.0±0.3] Typ. Environmental Properties .858±.012 [21.8±0.3] Operating Temperature— -40˚F to +221˚F [-40˚C to +120˚C] Hardware Options J6140—Spade jumper, see page 177 J6240—Flanged spade jumper, see page 177 J6340—Ring tongue jumper, see page 177 J6—Spade jumper, see page 177 Dimension No. of Positions L S 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 1.42 [036.2] 1.80 [045.7] 2.17 [055.2] 2.55 [064.7] 2.92 [074.2] 3.30 [083.7] 3.67 [093.2] 4.05 [103.0] 4.41 [112.0] 4.80 [122.0] 5.16 [131.0] 5.55 [141.0] 5.91 [150.0] 6.30 [160.0] 6.65 [169.0] 7.05 [179.0] 7.40 [188.0] 7.79 [198.0] 8.15 [207.0] 8.54 [217.0] 8.90 [226.0] 9.29 [236.0] 9.65 [245.0] 10.04 [255.0] 10.39 [264.0] 10.79 [274.0] 11.14 [283.0] 11.54 [293.0] 11.89 [302.0] 1.13 [028.7] 1.50 [038.2] 1.88 [047.7] 2.25 [057.2] 2.63 [066.7] 3.00 [076.2] 3.37 [085.7] 3.75 [095.2] 4.13 [105.0] 4.49 [114.0] 4.88 [124.0] 5.24 [133.0] 5.63 [143.0] 5.98 [152.0] 6.38 [162.0] 6.73 [171.0] 7.13 [181.0] 7.48 [190.0] 7.87 [200.0] 8.23 [209.0] 8.62 [219.0] 8.98 [228.0] 9.37 [238.0] 9.72 [247.0] 10.12 [257.0] 10.47 [266.0] 10.87 [276.0] 11.22 [285.0] 11.61 [295.0] Part Numbers w/Binding Head w/Wire Screws Clamp Screws 1546306-2 1546307-2 1546306-3 1546307-3 1546306-4 1546307-4 1546306-5 1546307-5 1546306-6 1546307-6 1546306-7 1546307-7 1546306-8 1546307-8 1546306-9 1546307-9 1-1546306-0 1-1546307-0 1-1546306-1 1-1546307-1 1-1546306-2 1-1546307-2 1-1546307-3 1-1546306-3 1-1546307-4 1-1546306-4 1-1546306-5 1-1546307-5 1-1546306-6 1-1546307-6 1-1546306-7 1-1546307-7 1-1546306-8 1-1546307-8 1-1546306-9 1-1546307-9 2-1546306-0 2-1546307-0 2-1546307-1 2-1546306-1 2-1546306-2 2-1546307-2 2-1546306-3 2-1546307-3 2-1546307-4 2-1546306-4 2-1546306-5 2-1546307-5 2-1546306-6 2-1546307-6 2-1546306-7 2-1546307-7 2-1546306-8 2-1546307-8 2-1546306-9 2-1546307-9 3-1546307-0 3-1546306-0 156 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Double-Row, Dual-Barrier Strips (Continued) .433 [11.0] Centerlines Dim. L ± .08 [±2.0] Dim. S Material & Finish Insulator Body—UL94V-0, thermoplastic, black Terminals—Brass, tin plated Screw—#6-32 steel, nickel plated Mechanical Properties .177 [4.5] Dia. Typ. .413±.01 [10.5±0.3] Screw Torque—12 in-lb Electrical Properties .433±.008 [11.0±0.2] Typ. for .433 Centerline .827±.01 [21.0±0.3] .366±.008 [9.3±0.2] Typ. Environmental Properties Barrier Strips Current Rating—20 A, 300 VAC Wire Range—14-22 AWG Withstanding Voltage—2000 VAC min. .551±.01 .315±.01 [14.0±0.3] [8.0±0.3] Operating Temperature— -40˚F to +221˚F [-40˚C to +120˚C] 1.10±.02 [28.0±0.6] Dimension No. of Positions L S 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 1.65 [41.8] 2.08 [52.8] 2.51 [63.8] 2.94 [74.8] 3.38 [85.8] 3.81 [96.8] 4.24 [107.8] 4.68 [118.8] 5.11 [129.8] 5.54 [140.8] 5.98 [151.8] 6.41 [162.8] 6.84 [173.8] 7.27 [184.8] 7.71 [195.8] 8.14 [206.8] 8.57 [217.8] 9.01 [228.8] 9.44 [239.8] 9.87 [250.8] 10.31 [261.8] 10.74 [272.8] 11.17 [283.8] 11.61 [294.8] 12.04 [305.8] 1.264 [32.1] 1.697 [43.1] 2.130 [54.1] 2.563 [65.1] 2.996 [76.1] 3.429 [87.1] 3.862 [98.1] 4.295 [109.1] 4.728 [120.1] 5.161 [131.1] 5.594 [142.1] 6.028 [153.1] 6.461 [164.1] 6.894 [175.1] 7.327 [186.1] 7.760 [197.1] 8.193 [208.1] 8.626 [219.1] 9.059 [230.1] 9.492 [241.1] 9.925 [252.1] 10.358 [263.1] 10.791 [274.1] 11.224 [285.1] 11.657 [296.1] 2 Part Numbers w/Binding Head w/Wire Screws Clamp Screws 1546481-2 1546477-2 1546481-3 1546477-3 1546481-4 1546477-4 1546481-5 1546477-5 1546481-6 1546477-6 1546481-7 1546477-7 1546481-8 1546477-8 1546481-9 1546477-9 1-1546477-0 1-1546481-0 1-1546481-1 1-1546477-1 1-1546481-2 1-1546477-2 1-1546481-3 1-1546477-3 1-1546481-4 1-1546477-4 1-1546481-5 1-1546477-5 1-1546477-6 1-1546481-6 1-1546481-7 1-1546477-7 1-1546481-8 1-1546477-8 1-1546477-9 1-1546481-9 2-1546481-0 2-1546477-0 2-1546481-1 2-1546477-1 2-1546481-2 2-1546477-2 2-1546481-3 2-1546477-3 2-1546481-4 2-1546477-4 2-1546477-5 2-1546481-5 2-1546481-6 2-1546477-6 157 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Double-Row, Dual-Barrier Strips (Continued) .437 [11.1] Centerlines Dim. L ± .08 [±2.0] Dim. S Material & Finish Insulator Body—UL94V-0, thermoplastic, black Terminals—Brass, tin plated Screw—#6-32 steel, nickel plated Mechanical Properties .177 [4.5] Dia. Typ. .413±.01 [10.5±0.3] Screw Torque—12 in-lb Electrical Properties .437±.008 [11.1±0.2] Typ. for .437 Centerline Current Rating—20 A, 300 VAC Wire Range—14-22 AWG Withstanding Voltage—2000 VAC min. .827±.01 [21.0±0.3] .366±.008 [9.3±0.2] Typ. Environmental Properties .551±.01 .315±.01 [14.0±0.3] [8.0±0.3] Operating Temperature— -40˚F to +221˚F [-40˚C to +120˚C] Hardware Options 1776110-x—Single-sided Quick Connects, see page 176 1776057-x—Two-sided Quick Connects, see page 176 J7—Spade jumper, see page 177 J7140—Spade jumper, see page 177 J7240—Flanged jumper, see page 177 J7340—Ring tongue jumper, see page 177 J76—Over-the-barrier jumper, see page 177 1.10±.02 [28.0±0.6] Dimension No. of Positions L S 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 1.62 [41.2] 2.06 [52.3] 2.50 [63.4] 2.93 [74.5] 3.37 [85.6] 3.81 [96.7] 4.24 [107.8] 4.68 [118.9] 5.12 [130.0] 5.55 [141.1] 5.99 [152.2] 6.43 [163.3] 6.87 [174.4] 7.30 [185.5] 7.74 [196.6] 8.18 [207.7] 8.61 [218.8] 9.05 [229.9] 9.49 [241.0] 9.93 [252.1] 10.36 [263.2] 10.80 [274.3] 11.24 [285.4] 11.67 [296.5] 12.11 [307.6] 1.264 [32.1] 1.697 [43.1] 2.130 [54.1] 2.563 [65.1] 2.996 [76.1] 3.429 [87.1] 3.862 [98.1] 4.295 [109.1] 4.728 [120.1] 5.161 [131.1] 5.594 [142.1] 6.028 [153.1] 6.461 [164.1] 6.894 [175.1] 7.327 [186.1] 7.760 [197.1] 8.193 [208.1] 8.626 [219.1] 9.059 [230.1] 9.492 [241.1] 9.925 [252.1] 10.358 [263.1] 10.791 [274.1] 11.224 [285.1] 11.657 [296.1] Part Numbers w/Binding Head w/Wire Screws Clamp Screws 1546670-2 1546671-2 1546670-3 1546671-3 1546670-4 1546671-4 1546670-5 1546671-5 1546670-6 1546671-6 1546670-7 1546671-7 1546670-8 1546671-8 1546670-9 1546671-9 1-1546671-0 1-1546670-0 1-1546670-1 1-1546671-1 1-1546670-2 1-1546671-2 1-1546670-3 1-1546671-3 1-1546670-4 1-1546671-4 1-1546670-5 1-1546671-5 1-1546671-6 1-1546670-6 1-1546670-7 1-1546671-7 1-1546670-8 1-1546671-8 1-1546671-9 1-1546670-9 2-1546670-0 2-1546671-0 2-1546670-1 2-1546671-1 2-1546670-2 2-1546671-2 2-1546670-3 2-1546671-3 2-1546670-4 2-1546671-4 2-1546671-5 2-1546670-5 2-1546670-6 2-1546671-6 158 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Double-Row, Dual-Barrier Strips (Continued) .563 [14.3] Centerline Dim. L ±.02 [±0.5] Dim. S +.03/-.02 [+0.7/-0.5] Material & Finish Insulator Body—UL94V-0, thermoplastic, black Terminals—Brass, tin plated Screw—M4.0 steel, nickel plated .222 [5.64] Dia. Ref. 2 Plc. Mechanical Properties .492±.008 [12.5±0.2] Typ. Screw Torque—16 in-lb Electrical Properties Current Rating—30 A, 300 VAC Wire Range—10-22 AWG Withstanding Voltage—2000 VAC min. .210 [5.33] Dia. Ref. 2 Plc. .563±.008 [14.3±0.2] Typ. Environmental Properties Barrier Strips .441±.012 [11.2±.31] .394±.012 [10.0±0.3] Operating Temperature— -40˚F to +284˚F [-40˚C to +140˚C] Hardware Options .610 +.012/-.012 [15.5 +0.3/-.31] 1776174-x—Single-sided Quick Connects, see page 176 1776173-x—Two-sided Quick Connects, see page 176 1.01 ± .012 [25.6 ±0.3] 1.28 +.012/-.02 [32.5 +0.3/-.52] Dimension No. of Positions L S 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 2.13 [54.0] 2.69 [68.3] 3.25 [82.6] 3.81 [96.9] 4.38 [111.2] 4.94 [125.5] 5.50 [139.8] 6.08 [154.1] 6.63 [168.4] 7.19 [182.7] 7.75 [197.0] 8.32 [211.3] 8.88 [225.6] 9.44 [239.9] 10.02 [254.5] 10.57 [268.5] 11.13 [282.8] 1.69 [42.9] 2.25 [57.2] 2.81 [71.5] 3.38 [85.8] 3.94 [100.1] 4.50 [114.4] 5.07 [128.7] 5.63 [143.0] 6.19 [157.3] 6.76 [171.6] 7.32 [185.9] 7.88 [200.2] 8.44 [214.5] 9.01 [228.8] 9.57 [243.1] 10.13 [257.4] 10.70 [271.7] 2 Part Numbers w/Wire w/Binding Head Clamp Screws Screws 1546311-2 1546310-2 1546311-3 1546310-3 1546311-4 1546310-4 1546311-5 1546310-5 1546311-6 1546310-6 1546311-7 1546310-7 1546311-8 1546310-8 1546311-9 1546310-9 1-1546311-0 1-1546310-0 1-1546311-1 1-1546310-1 1-1546311-2 1-1546310-2 1-1546311-3 1-1546310-3 1-1546311-4 1-1546310-4 1-1546311-5 1-1546310-5 1-1546310-6 1-1546311-6 1-1546311-7 1-1546311-7 1-1546311-8 1-1546310-8 159 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Double-Row, Dual-Barrier Strips w/o Washer .563 [14.3] Centerline Dim. A .032 [±0.81] Material & Finish Dim. B .032 [±0.81] Insulator Body—UL94V-0, thermoplastic, black Terminals—Brass, tin plated Screw—M4.0 steel, nickel plated Mechanical Properties Ø.22 [5.59] 4 Plc. .22 [5.59] .492±.008 [12.5±0.2] Screw Torque—14 in-lb Electrical Properties .563±.008 [14.3±0.2] Current Rating—30 A, 600 VAC Wire Range—10-22 AWG Withstanding Voltage—2000 VAC min. .26 [6.60] 1.280±.035 [32.5 ±.889] .44±.02 [11.2±.51] Environmental Properties Operating Temperature— -40˚F to +120˚F [-40˚C to +49˚C] .39 [9.9] Hardware Options .80±.02 [20.3±.508] 1776174-x—Single-sided Quick Connects, see page 176 1776173-x—Two-sided Quick Connects, see page 176 Dimension No. of Positions L S 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 2.13 [54.0] 2.69 [68.3] 3.25 [82.6] 3.81 [96.9] 4.38 [111.2] 4.94 [125.5] 5.50 [139.8] 6.08 [154.1] 6.63 [168.4] 7.19 [182.7] 7.75 [197.0] 8.32 [211.3] 8.88 [225.6] 9.44 [239.9] 10.02 [254.5] 10.57 [268.5] 11.13 [282.8] 1.69 [42.9] 2.25 [57.2] 2.81 [71.5] 3.38 [85.8] 3.94 [100.1] 4.50 [114.4] 5.07 [128.7] 5.63 [143.0] 6.19 [157.3] 6.76 [171.6] 7.32 [185.9] 7.88 [200.2] 8.44 [214.5] 9.01 [228.8] 9.57 [243.1] 10.13 [257.4] 10.70 [271.7] 1.00±.02 [25.4±.508] Part Numbers w/Wire w/Binding Head Clamp Screws Screws 1776544-2 1986158-2 1776544-3 1986158-3 1776544-4 1986158-4 1776544-5 1986158-5 1776544-6 1986158-6 1776544-7 1986158-7 1776544-8 1986158-8 1776544-9 1986158-9 1-176544-0 1-1986158-0 1-176544-1 1-1986158-1 1-176544-2 1-1986158-2 1-176544-3 1-1986158-3 1-176544-4 1-1986158-4 1-1986158-5 1-176544-5 1-1986158-6 1-176544-6 1-176544-7 1-1986158-7 1-1986158-8 1-176544-8 160 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Barrier Strip Sockets Mateability for the socket line is given below: Socket Series USB RSB6B Connector Series RSB3, SSB3 RSB6 Product Facts mounting of USB sockets maintain circuit spacing: Two 12-circuit USB sockets can mate with one 24-circuit SSB3 or RSB3. n Secure mating with built-in locking arms n End-to-end Barrier Strips 2 This unique plug-in socket line allows quick connection of circuits simultaneously without the use of tools. They are designed to be wave-soldered to a PC board, after which the connector is plugged into the socket. 161 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325” [8.26] Pitch, Series USB Socket (for Series RSB3 and SSB3) USB3B08S & SSB3FP080202 Material & Finish Housing Material—Polyamide, Type 6/6 Flammability—UL94V-2 Color—Black Terminals Contact—Copper alloy, bright tin plating Pin—Copper alloy, bright tin plating Mechanical Properties Pitch (Terminal Spacing)— 0.325" [8.26] Recommended PCB Hole Dia.— .055" [1.40] Pullout Force—5-7 lbs. Electrical Properties Ratings—UL Class B 10 Amps, 300V CSA Type B 15 Amps, 300V CSA Type D 10 Amps, 300V Dielectric Withstand—3500V Recommended PCB Hole Pattern Environmental Properties Operating Temperature Range— -60°C to +105°C [-76°F to +221°F] No. of Circuits 2 3 4 5 6 7 8 9 10 11 12 13 14 Dimensions A B 0.650 0.325 0.975 0.650 1.300 0.975 1.625 1.300 1.950 1.625 2.275 1.950 2.600 2.275 2.925 2.600 3.250 2.925 3.250 3.575 3.900 3.575 4.225 3.900 4.550 4.225 Dual-Barrier Mating Strip Catalog Number Tri-Barrier Mating Strip Catalog Number Catalog Number SSB3FP0202... SSB3FP0302... SSB3FP0402... SSB3FP0502... SSB3FP0602... SSB3FP0702... SSB3FP0802... SSB3FP0902... SSB3FP1002... SSB3FP1102... SSB3FP1202... SSB3FP1302... SSB3FP1402... RSB3VP0212... RSB3VP0312... RSB3VP0412... RSB3VP0512... RSB3VP0612... RSB3VP0712... RSB3VP0812... RSB3VP0912... RSB3VP1012... RSB3VP1112... RSB3VP1212... RSB3VP1312... RSB3VP1412... USB3B02S USB3B03S USB3B04S USB3B05S USB3B06S USB3B07S USB3B08S USB3B09S USB3B10S USB3B11S USB3B12S USB3B13S USB3B14S Note: See page 165 to complete mating Tri-Barrier Strip Catalog Number. See page 169 to complete mating Dual-Barrier Strip Catalog Number. LR25557 E63810 162 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375” [9.53] Pitch, Series RSB6B Socket (for Series RSB6 Tri-Barrier) RSB6B06S Material & Finish Barrier Strips Housing Material—Polyamide Flammability—UL94V-2 Color—Black Terminals—Copper alloy, bright tin plating Pin—Copper alloy, bright tin plating Mechanical Properties Pitch (Terminal Spacing)— .375 in [9.53] Recommended PCB Hole Dia.— .062" [1.57] 2 Electrical Properties Ratings—UL Class B 20 Amps, 300V CSA Type B 10 Amps, 300V CSA Type D 5 Amps, 600V Dielectric Withstand—3500V Environmental Properties Operating Temperature Range— -60°C to +105°C [-76°F to +221°F] Recommended PCB Hole Pattern No. of Circuits 02 03 04 05 06 07 08 09 10 Dimensions A B 0.720 0.375 1.094 0.750 1.469 1.125 1.844 1.500 2.219 1.875 2.594 2.250 2.869 2.625 3.000 3.244 3.375 3.720 Catalog Number RSB6B02S RSB6B03S RSB6B04S RSB6B05S RSB6B06S RSB6B07S RSB6B08S RSB6B09S RSB6B10S Note: RSB6 Tri-Barrier Blocks should be ordered with Number 12 Terminal Style (printed circuit pin, V mounting) when used in combination with this plug-in socket. See page 172 for ordering information. LR25557 E63810 163 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325" [8.26] Pitch, Series RSB3 RSB3VP061202 .590 [14.98] .325 [8.25] .270 [6.85] .046 [1.16] .500 [12.7] Material & Finish Housing Material—Polypropylene Flammability—UL94V-2 Color—Black Terminals—Brass w/bright Tin plating Screws—Steel w/Zinc + Chromate plating .054 [1.37] .055 [1.39] .500 [12.7] .200 [5.08] .250 [6.35] .154 [3.91] .032 [0.81] Typ. .062 [1.57] Dia. Hole After Plating Mechanical Properties Pitch (Terminal Spacing)— .325 in [8.26] Screw Size—6-32 Recommended PCB Hole Dia.— 0.062” Wire Strip Length—.31 in [7.87] Recommended Tightening Torque—9 in-lbs. Recommended Screwdrivers— Stanley 1006-4, Sears Craftsman 41581, Any #2 Phillips-Head Wire Lug Width (Max.)— .265 in [6.73] Electrical Properties Maximum Current—15A Operating Voltage—300V Wire Range—#14-26 AWG Dielectric Withstand—4000V Environmental Properties Operating Temperature Range— -60°C to +105°C [-76°F to +221°F] For mating socket, see pg. 162. Computing Barrier Block Lengths Direct Mounting—Use C1 and L1 for Mounting Option "P". End Position Mounting—Use C2 and L2 for Mounting Option "M". LR25557 E63810 .325 [8.25] .180 [4.57] Min. Dimensions Circuits (not positions) 02 03 04 05 06 07 08 09 10 11 12 13 14 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 C1 in. 0.325 0.650 0.975 1.300 1.625 1.950 2.275 2.600 2.925 3.250 3.575 3.900 4.225 4.875 5.200 5.525 5.850 6.175 6.500 6.825 7.150 7.475 7.800 8.125 8.450 8.775 9.100 9.425 9.750 10.075 10.400 10.725 11.050 11.357 L1* in. 0.704 1.029 1.354 1.679 2.004 2.329 2.654 2.797 3.304 3.629 3.954 4.279 4.604 5.254 5.579 5.904 6.229 6.554 6.879 7.204 7.529 7.854 8.179 8.504 8.829 9.154 9.479 9.804 10.129 10.454 10.779 11.104 11.429 11.754 C2 in. 0.975 1.300 1.625 1.950 2.275 2.600 2.925 3.250 3.575 3.900 4.225 4.550 4.875 5.525 5.850 6.175 6.500 6.825 7.150 7.475 7.800 8.125 8.450 8.775 9.100 9.425 9.750 10.075 10.400 10.725 11.050 11.357 — — L2* in. 1.354 1.679 2.004 2.329 2.654 2.979 3.304 3.629 3.954 4.279 4.604 4.929 5.254 5.904 6.229 7.554 6.879 7.204 7.529 7.854 8.179 8.504 8.829 9.154 9.479 9.804 10.129 10.454 10.779 11.104 11.429 11.754 — — *L2 and L1 are based on molded-to-length strips. 164 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325" [8.26] Pitch, Series RSB3 (Continued) Ordering Information RSB 3 V P 06 12 02 11* A A Single Screw Tri-Barrier Strip RSB B Contact Spacing (Center-to-Center) 3=.325 in. Mounting Position V=Vertical Mounting D End Contact Mounting Options M=End Position Mounting: open end positions with barriers. P=Direct Mounting: all positions filled with contacts, with barriers E No. of Circuits (Not Positions) 02 through 34 for M Option 02 through 36 for P Option F Terminal Style 12=Printed Circuit Pin for use with USB3 Series Socket 15=Superseded by 4 PCR per page 125 17=Superseded by 4WWV, page 125 C G D E F Top Hardware Options 01=Bright zinc and chromate plated steel bindinghead screw 02=Bright zinc and chromate plated steel screw and captive clamp – Do not order in combination with other top hardware. G H H Circuit Identification Options Catalog Number Codes: 11 through 18 and 21 through 28. RSB3 blocks may be ordered with white circuit identification numbers on the molding in 16 variations. Custom markings available on special order. Barrier Strips C B Quick-Connect Blades (supplied with 01 screw) .110 wide x.020 thick 13 14 15 2 .187 wide x.020 thick 73= 74= 75= Catalog Number Codes: 13 through 15 and 73 through 75. A complete selection of .187” and .110” quick-connect blades for connecting wire terminated with female quick connects. Singlesided types in flat, 45º and 90º angle bends can be supplied. Material is brass with tin plating. All blades supplied with 01 screws. Various quick-connects can be combined. LR25557 For mating socket, see pg. 162. E63810 165 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325" [8.26] Pitch, Series RSB3 (Continued) Mounting Position Terminal Style Vertical Mounting Printed Circuit Pin Catalog Letter Code: V. Used where direct top-to-bottom feed-through is required with no need for circuit isolation on the bottom side. The most common example of this is printed circuit board mounting. Catalog Number Code: 12. Designed specifically for use with our USB3 socket, page 162 Hardware Options 3C1xxx—Safety cover, see page 175 J3140—Jumpers, see page 177 3L02—Wire clamp screw, see page 178 3L01—Binding head screw, see page 178 End Contact Mounting Options End Position Mounting Catalog Letter Code: M. Supplied without contact in end sections to allow installer to mount blocks with screws in end section holes. Base of block will support #6 mounting screws. Direct Mounting Catalog Letter Code: P. RSB3 may be solder-mounted using the bottom terminals themselves, as in the case of printed circuit board applications. LR25557 E63811 166 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Engineering Notes Barrier Strips 2 167 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325" [8.26] Pitch, Series SSB3 SSB3FP##0202 .500 [12.7] .325 [8.25] .270 [6.85] .046 [1.16] .054 [1.37] .055 [1.39] .200 [5.08] .350 [8.89] .048 [1.21] Typ. .032 [0.81] Typ. .250 .154 [6.35] [3.91] .062 [1.57] Dia. Hole After Plating Material & Finish Housing Material—Polypropylene Flammability—UL94V-2 Color—Black Terminals—Brass, bright acid tin over copper plating Screw—Steel w/ Zinc + Chromate plating .325 [8.25] .180 [4.57] Min. Recommended PCB Hole Pattern Dimensions Mechanical Properties Pitch (Terminal Spacing)— .325" [8.26] Screw Size—6-32 Recommended PCB Hole Dia.— .062" [1.57] Wire Strip Length—.31" [7.87] Recommended Tightening Torque—9 in-lbs. Recommended Screwdrivers— Stanley 1006-4, Sears Craftsman 41581, Any #2 Phillips Head. Wire Lug Width (Max.)— .265" [6.73] Electrical Properties Ratings—UL Class B 20 Amps, 300V UL Class C 20 Amps, 300V UL Class D 10 Amps, 300V CSA Type B 10 Amps, 300V CSA Type D 10 Amps, 300V Wire Range—#14-26 AWG Dielectric Withstand—4500V Environmental Properties Operating Temperature Range—60°C to +105°C [-76°F to +221°F] Computing Barrier Block Lengths Direct Mounting – Use C1 & L1 for Mounting Option “P". End Position Mounting – Use C2 & L2 for Mounting Options “F" and “M". For mating socket, see pg. 162. .500 [12.7] Circuits (not positions) 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 C1 in. 0.325 0.650 0.975 1.300 1.625 1.950 2.275 2.600 2.925 3.250 3.575 3.900 4.225 4.550 4.875 5.200 5.525 5.850 6.2175 6.500 6.825 7.150 7.475 7.800 8.125 8.450 8.775 9.100 9.425 9.750 10.075 10.400 10.725 11.050 11.375 L1* in. 0.704 1.029 1.354 1.679 2.004 2.329 2.654 2.979 3.304 3.629 3.954 4.279 4.604 4.949 5.254 5.579 5.904 6.229 6.554 6.879 7.204 7.529 7.854 8.179 8.504 8.829 9.154 9.479 9.804 10.129 10.454 10.779 11.104 11.429 11.754 C2 in. 0.975 1.300 1.625 1.950 2.275 2.600 2.925 3.250 3.575 3.900 4.225 4.550 4.875 5.200 5.525 5.850 6.175 6.500 6.825 7.150 7.475 7.800 8.125 8.450 8.775 9.100 9.425 9.750 10.075 10.400 10.725 11.050 11.375 — — L2* in. 1.354 1.679 2.004 2.329 2.654 2.979 3.304 3.629 3.954 4.279 4.604 4.929 5.254 5.579 5.579 6.229 7.554 6.879 7.204 7.529 7.854 8.179 8.504 8.829 9.154 9.479 9.804 10.129 10.454 10.779 11.104 11.429 11.754 — — EC/98/003-01 12241/CL LR25557 E63810 168 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325" [8.26] Pitch, Series SSB3 (Continued) Ordering Information SSB 3 F P 06 02 02 Suffix A B C D E F G H B Contact Spacing (Center-to-Center) 3=.325 in. D Mounting Options F= Open end positions without end barriers M= Open end positions with end barriers P= All positions filled with contacts, with end barriers E No. of Circuits (Not Positions) 02 through 36 F Terminal Style 02= Printed Circuit Pin 04= Extended Circuit Board 11= Right-Angle Bend .18 x .12 02= Bright zinc and chromate plated steel screw and captive clamp – Do not order in combination with other top hardware. H Circuit Identification Options Catalog Number Codes: 11 through 16. SSB blocks may be ordered with circuit identification numbers in white on the molding in six different variations. Custom markings are available on special order. Barrier Strips Base F=Raised Base Top Hardware Options 01= Bright zinc and chromate plated steel binding-head screw 11= 12345... 12= ...54321 13= 14= 15= 16= 1 2 3 4 5 . . . C G 1 2 3 4 5 . . . Single Screw Dual-Barrier Strip SSB Quick-Connect Blades (supplied with 01 screw) .110 wide x.020 thick 10 11 12 13 14 15 ...54321 12345... A 2 .187 wide x.020 thick 70= 71= 72= 73= 74= 75= Hardware Options 3C1xxx—Safety cover, see page 175 J3140—Jumpers, see page 177 3L02—Wire clamp screw, see page 178 3L01—Binding head screw, see page 178 QC1x—.110 Quick connects, see page 176 QC7x—.187 Quick connects, see page 176 For mating socket, see pg. 162. EC/98/003-01 12241/CL LR25557 E63810 169 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.325" [8.26] Pitch, Series SSB3, Options Base Printed Circuit Pin: Quick Connects Catalog Letter Code: F. Lends itself most readily to applications where direct top-to-bottom feed-through is required with no special requirement for circuit isolation on the bottom side. The most common example of this is printed circuit board mounting. Catalog Number Code: 02. Designed specifically for mounting on .063" thick circuit board. Special, readily solderable plating permits good fillet development in automated soldering processes. Catalog Number Codes: 10 through 75. A complete selection of .187" and .110" quick-connect blades are available for connecting wire terminated with female quick connects. Single-and double-sided types in flat, 45º and 90º angle bends can be supplied. Material is brass with tin plating. All blades supplied with 01 screws. Various quickconnects can be combined. Extended Printed Circuit Pin: Mounting Options Catalog Number Code: 04. Useful where extra length is needed, as in thicker printed circuit boards or singlewrap connections. End Position Mounting Catalog Letter Code: M. Provides a printed circuit board mounting option with top-side wire entry. Top Hardware Options Binding Head Screws End Position Mounting Without Barriers Catalog Letter Code: F. Facilitates mounting-screw access when end sections are used for mounting. Catalog Number Code: 01. In most applications, binding head screws will provide excellent wire retention because of exclusive wire locking tabs. Screws are bright zinc and chromate plated steel. Captive Clamp Direct Mounting: Catalog Letter Code: P. SSBs may be solder-mounted using the bottom terminals themselves, as in the case of printed circuit board applications. Catalog Number Code: 02. For applications requiring extra security, captive clamps under the screw heads augment the locking tabs on each contact. Screws have a unique Phil-slot design accepting either Phillips-head or straight screwdriver. Code 02 screw is bright zinc and chromate plated steel. Terminal Style: LR25557 E63810 170 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375" [9.53] Pitch, Series RSB6 Vertical Mount RSB6RP##1102 Right Angle Mount Wire Clamping Screw .690 [17.52] Top of Mounting Insert L91 .375 [9.52] .322 [8.17] .032 [0.81] .320 [8.12] Pitch (Terminal Spacing)— .375" [9.53] Screw Size—6-32 Recommended PCB Hole Dia.— .062" [1.57] Wire Strip Length—.38" [9.65] Recommended Tightening Torque—12 in-lbs. Recommended Screwdrivers— Stanley 1006-4, Sears Craftsman 41581, Any #2 Phillips-Head Wire Lug Width (Max.)—8.1mm [.320"] Electrical Properties Ratings—UL Class B 20 Amps, 300V CSA Type C 15 Amps, 150V CSA Type D 10 Amps, 300V Wire Range—12-22 AWG Dielectric Withstand—3500V Environmental Properties Operating Temperature Range—60ºC to +105ºC [-76ºF to +221ºF] Computing RSB Block Lengths Direct Mounting – Use C1 & L1 for VP, SP, RP mounting options End Position Mounting – Use L2 & C2 for VM, SM, RM, VE, SE, RE mounting options For mating socket, see pg. 163. Hardware Options J6—Jumpers, see page 177 L02—Wire clamp screw, steel, see page 178 L09—Wire clamp screw, brass, see page 178 L01—Binding head screw, see page 178 L04—Binding head screw, brass, see page 178 .610 [15.49] Circuits (not positions) 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 .440 [11.17] .375 [9.52] .212 [5.38] Min. Dimensions .360 [9.14] LR25557 Recommended PCB Hole Pattern C1 in. — 0.37 0.75 1.13 1.50 1.88 2.25 2.63 3.00 3.37 3.75 4.13 4.50 4.88 5.25 5.63 6.00 6.38 6.75 7.13 7.50 7.88 8.25 8.63 9.00 9.38 9.75 10.13 10.50 10.88 11.25 11.63 12.00 12.38 12.75 13.13 Barrier Strips Mechanical Properties Binding Head Screw .375 [9.52] .320 [8.12] .060 [1.52] Housing Material—Polypropylene Flammability—UL94V-2 Color—Black Terminals—Brass, bright acid tin over copper plating Screw—Steel w/Zinc + Chromate plating Binding Head Screw .610 [15.49] .390 [9.90] Material & Finish .375 [9.52] .690 [17.52] L1* in. — 0.84 1.22 1.59 1.97 2.34 2.72 3.09 3.47 3.84 4.22 4.59 4.97 5.34 5.72 6.09 6.47 6.84 7.22 7.59 7.97 8.34 8.72 9.09 9.47 9.84 10.22 10.59 10.97 11.34 11.72 12.09 12.47 12.84 13.22 13.59 C2 in. 0.75 1.13 1.50 1.88 2.25 2.63 3.00 3.37 3.75 4.13 4.50 4.88 5.25 5.63 6.00 6.38 6.75 7.13 7.50 7.88 8.25 8.63 9.00 9.75 9.75 10.13 10.50 10.88 11.25 11.63 12.00 12.38 12.75 13.13 13.50 13.88 E63810 2 L2* in. 1.22 1.59 1.97 2.34 2.72 3.09 3.47 3.84 3.84 4.59 4.97 5.34 5.72 6.09 6.47 6.84 7.22 7.59 7.97 8.34 8.72 9.09 9.47 9.84 10.22 10.59 10.97 11.34 11.72 12.09 12.47 12.84 13.22 13.59 13.97 14.34 171 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375" [9.56] Pitch, Series RSB6 (Continued) Ordering Information A B RSB 6 R P 07 12 02 11 A B C D E F G H Single Screw Tri-Barrier Strips RSB G 01= Bright zinc and chromate plated steel binding-head screw Contact Spacing 02= Bright zinc and chromate steel screw and captive clamp – Do not order in combination with other top hardware 6=.375 in. (6/16) C Mounting Position Options V= Vertical Mounting H= High Rise terminal style) D (use with Top Hardware Options 03=Stainless steel binding-head screw #18 04=Nickel plated brass bindinghead screw End Contact Options 09=Nickel plated brass screw and captive clamp – Do not order in combination with other top hardware E= Open end pos. with mounting inserts M= Open end positions P= All positions filled with contacts H Request drawing C7013624 for complete information Top 21 = 12345... 22 = ...54321 23 = 24 = 25 = 26 = 27 = 28 = 1 2 3 4 5 . . . Front 11 12 13 14 15 16 17 18 1 2 3 4 5 . . . For mating socket, see pg. 152. Circuit Identification Options 1 2 3 4 5 . . . Terminal Style 11=Superseded by 6STV, page 129 12=Circuit Board, V Mounting (select this option when block is to be used with RSB plug-in socket) 13=Superseded by 6TBV, page 129 14=Superseded by 6STR, page 129 15=Superseded by 6PCR, page 129 16=Superseded by 6WWR, page 129 17=Superseded by 6WWV, page 129 18=Circuit Board (for High Rise Mounting) .250 [6.35] wide .187 [4.75] wide x.032 [.81] x.020 [.51] thick thick 22 42= 23 43= 24 44= 25 45= 29 49= 30 50= 31 51= 33 53= 35 55= 36 56= 1 2 3 4 5 . . . F No. of Circuits (Not Positions) 02 through 34 for M Option 02 through 36 for P Option ...54321 12345... E Quick-Connect Blades (supplied with 01 screw) LR25557 E63810 172 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks 0.375" [9.56] Pitch, Series RSB6, Features/Options Terminal Style Top Hardware Options: Vertical Terminal Catalog Number Code 12: Designed specifically for use with our RSB6B Socket, page 163. Binding Head Screws Four Styles Available. Captive Clamp Mounting & Contact Position Options Catalog Code VP: This configuration is frequently used on printed circuit boards where solder connections are used to fasten the block to the board. Barrier Strips Vertical, Direct Mounting Catalog Number Code: 02 & 09. For applications requiring extra security, captive clamps under the screw heads augment the locking tabs on each contact. Screws have #8 pan head with a unique Phil-slot design accepting either Phillipshead or straight screwdriver. The body is #6 to allow use of larger wire. Quick Connects Catalog Code below: A selection of .187" and .250" quick connect blades with tin plated brass are available for connecting wire terminated with female quickconnects. They are available individually or in combination. See ordering information. 2 Vertical, End Position Mounting Catalog Code VM: Used where end sections are needed for mounting. Thickness of base is sufficient to support mounting screws. High Rise, All Positions Filled with Contacts High Rise, Mounting Standoffs Catalog Code HP: Designed for high density; two rows deep when used in conjunction with a VP configuration. Designed for high density; allows two rows of contacts on two levels when used with a VP mounting configuration. LR25557 E63810 173 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Accessories — Barrier Strip Safety Covers For Series BC6, #3, JC6 2-56 X 3/16 Steel Screw Zinc w/ clear chromate plate (TC3 Series kit only) 1,5 (.06) UL 94V-0 Rigid PVC Cover (1 Supplied) (For TC3 Series only) Aluminum Bushing tapped thru. Press into block until fully seated For Series BC6, #3, JC6 Mounting TC 3—Aluminum mounting bushings and screws TC 2, 9—Plastic fasteners attached to block with thru-bolts and nuts (not supplied) Bushing Retention Barbs Bushing or Terminal must be removed before Cover Bushings are installed Center Spacing O.H. TC 3—0.250 inch [6.35] TC 2, 9—0.375 inch [9.56] Material—Clear, rigid PVC, UL94V-0 Tri-Barrier Terminal Block For Series #4, #6, #8 Physical Properties Centerline spacing—8.2/[.325] 9.5/[.375] 11.1/[.4375] Positions—2 thru 16, molded to length Material—Black, thermoplastic, UL94V-0 Shock and Vibration—to MIL.STD. 1344 method 2005.1 Condition III. Ordering Information TC 4 - 06 - PFH - CL For Series #4, #6, #8 A Series TC = Cover B Center Spacing 2 = BC6 Series 3 = #3 Series 4 = #4 Series 6 = #6 Series 8 = #8 Series 9 = JC6 Series C D Ref. C L B Press-Fit Hold Down Tabs Centering Tabs Catalog # TC4 TC6 TC8 C A #4 / 5,4 / (.215) #6 / 6,8 / (.275) Dia. #8 / 7,4 / (.290) A B D E No. of Circuits (Not positions) 02 through 24 for Series BC6, JC6 02 through 30 for Series #3 02 through 16 for Series #4, #6, #8 A 8,2 (.325) 9,5 (.375) 11,1 (.4375) B 6,0 (.238) 6,3 (.250) 8,1 (.314) D E Access Holes PF* = Press Fit without holes PFH* = Press Fit with holes AG = Adder for Series BC6, #3, JC6 Color (add for Series #4, #6, #8 only) (blank) = Black (Series BC6, #3, JC6 are clear) CL = Translucent (Available only for Series #4, #6, #8) Overall Height (O.H.) TC2 TC3 TC9 0.970" 0 .650" 0.970" * Add for Series #4, #6, #8 C 13,5 (.531) 13,3 (.525) 21,5 (.846) D Ref. 5,7 (.225) 6,4 (.253) 11,1 (.4375) L A* (N-1)+7,9/(.312) #4 A* (N-1)+(,4/(.370) #6 A* (N-1)+10,9/(.430) #8 174 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Accessories — Barrier Strip Safety Covers (Continued) Safety Covers Dead front protection designed to prevent accidental contact with energized circuits. Access holes for test probes are provided over each terminal. Nylon clips are included with each cover. Covers meet UL94V-0, with 50°C temperature index. Blank circuit identification optional. Barrier Strips For SSB3, RSB3, RSB6 and SSB7 Series. Related Product Data Wire Pins and Ferrules Pages 109-111 For more information on Tyco Electronics Standard Terminals and Splices or Quick-Connect FASTON Receptacles and Tabs, request Catalog 82042. Ordering Information 2 3 C 1 N 07 Centerline Dimensions 3=.325 in. 7=.4375 in. Style 1=Closed Back Cover Material C=Yellow PVC Number of Circuits (Use Two Digits) 02 through 34 Max for SSB7=25 Max for RSB6=34 Max for RSB3=34 Max for SSB3=34 Circuit Identification N=No Markings F=Forward Sequence (as shown) R=Reverse Sequence 175 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Accessories — Quick-Connect (QC) Tabs Physical Properties Tabs Material—Tin plated brass Dimensions— #4 Series 0.187" wide x 0.020" thick, #6 Series 0.250" wide x 0.032" thick (0.187" x 0.020" optional), #8 Series 0.250” wide x 0.032” thick 90° 45° 180° 90° 45° 180° Ordering Information: Tabs QC4 - 180 - 3 A A B B Stackable Tabs C Style Size QC4 = for #4 Series (45° tab angle not available) QC6 = for #6 Series QC8 = for #8 Series C .375” Pitch, Double Row Tab Size 3 = 0.187 w x 0.020 4 = 0.250 w x 0.032 Tab Angle 180 = 180° (flat) 45 = 45° 90 = 90° QUICK-CONNECT Tabs Note: QC tabs may be stacked to achieve several angle configurations. .0325” Pitch, Series SSB3 Flat, Two-Sided 45°, Two-Sided 90°, Two-Sided Flat, Single-Sided 45°, Single-Sided 90°, Single-Sided Flat, Two-Sided 45°, Two-Sided 90°, Two-Sided Flat, Single-Sided 45°, Single-Sided 90°, Single-Sided QUICK-CONNECT Tabs .110 wide x .020 thick Part No. Cat. No. 5-1437402-7 QC10 5-1437402-8 QC11 5-1437402-9 QC12 6-1437402-0 QC13 6-1437402-1 QC14 6-1437402-2 QC15-BU .187 wide x .020 thick Part No. Cat. No. 7-1437402-5 QC70 7-1437402-6 QC71 7-1437402-7 QC72 7-1437402-8 QC73 7-1437402-9 QC74 8-1437402-0 QC75 .250 wide x .032 thick Part No. 1776173-1 1776173-2 1776173-3 1776173-4 1776174-1 1776174-2 1776174-3 Description Flat, Two-Sided 45°, Two-Sided 90°, Two-Sided 45°/90°, Two-Sided Flat, Single-Sided 45°, Single-Sided 90°, Single-Sided .375” & .4375” Pitch, Series JC6 and SSB7 .437” Pitch, Double Row QUICK-CONNECT Tabs QUICK-CONNECT Tabs Flat, Two-Sided .250 wide x .032 thick Part No. Cat. No. 1546986-1 QC20-BU .187 wide x .020 thick Part No. Cat. No. 6-1437402-9 QC40-BU 45°, Two-Sided 1546986-3 7-1437402-0 Description 90°, Two-Sided .187 wide x .032 thick Part No. 1776803-1 1776803-2 1776803-3 — — — .563” Pitch, Double Row QUICK-CONNECT Tabs Description .250 wide x .032 thick Part No. 1776860-1 1776860-2 1776860-3 1776843-1 1776843-2 1776843-3 Description QC21 QC41 1546986-4 QC22 7-1437402-1 QC42 Flat, Single-Sided 6-1437402-5 QC23 7-1437402-2 QC43 45°, Single-Sided 6-1437402-6 QC24 7-1437402-3 QC44 90°, Single-Sided 6-1437402-7 Flat, Two-Sided, Extra-Long 1776090-1 90°, Two-Sided, Extra-Long 1776090-2 45°, Two-Sided, Extra-Long 1776090-3 QC25 — — — 7-1437402-4 — — — QC45 — — — .250 wide x .032 thick Part No. 1776057-3 1776057-2 1776057-1 1776110-3 1776110-2 1776110-1 Description Flat, Two-Sided 45°, Two-Sided 90°, Two-Sided Flat, Single-Sided 45°, Single-Sided 90°, Single-Sided Order Number Solder Tabs: Related Product Data Wire Pins and Ferrules Pages 109-111 For more information on Tyco Electronics Standard Terminals and Splices or QuickConnect FASTON Receptacles and Tabs, request Catalog 82042. For making top-side solder connections .74 [18.80] Single-Sided Part No. 1-1437403-1 Cat. No. ST80 ST80 176 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Accessories — Jumpers AROUND-THE-BARRIER 40 circuits; snap apart to desired lengths. Catalog Number Part No. Catalog Number J3140 (for 0.325” Pitch) 5-1437418-3 Part No. Spade Jumper J7140 (for 0.4375” Pitch and #6 Screw) 5-1437418-7 Spade Jumper .15 .42 .57 Spade Jumper J6140 (for 0.375” Pitch and #6 Screw) 5-1437418-4 Barrier Strips .15 .69 .56 Flanged Spade Jumper J6240 (for 0.375” Pitch and #6 Screw) 5-1437418-5 Flanged Spade Jumper J7240 (for 0.4375” Pitch and #6 Screw) 5-1437418-8 Ring Tongue Jumper J6340 (for 0.375” Pitch and #6 Screw) 5-1437418-6 Ring Tongue Jumper J7340 (for 0.4375” Pitch and #6 Screw) 5-1437418-9 J74 (for 0.375” Pitch, Series RSB6 & SSB6; 0.4375” Pitch, SSB7) 6-1437418-0 Ring Tongue Jumper J75 (for 0.375” Pitch, Series RSB6 & SSB6; 0.4375” Pitch, SSB7) 6-1437418-1 2 Over-the-Barrier Two Circuit (Brass, Tin Plated) Spade Jumper J76 (0.4375” and 0.375" Double-Row) 1776058-1 J77 (0.563” Double-Row) 1776058-1 Order Number Jx x A A B A B Block Series J3 = #3 Series J4 = #4 Series, 4DB J6 = #6 Series, JC6, BC6, NC6, MB6 J8 = #8 Series, 1546670, 1546671 No. of Circuits (Not positions) 2 through 16 Jumpers J4, J6 and J8 Block Series J3 J4 J6 J8 Centerline Spacing A 6,4 (0.250") 8,3 (0.325") 9,5 (0.375") 11,1 (0.438") A Jumpers J3 177 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Accessories — Hardware & Brackets Catalog Number Part Number 3L01 Description Series 1437402-2 #6-32 Steel w/clear chromate RSB3, SSB3 L01 2-1437402-4 #6-32 Steel w/clear chromate SSB6, SSB7, RSB6 — 8-1437649-4 #4-40 Steel w/clear chromate Series #4 1437651-8 #6-32 Steel w/clear chromate Series #6, BC6, NC6, JC6 Binding Head Screws L03 2-1437402-6 #6-32 Stainless Steel SSB6, SSB7, RSB6 Series #6, JC6 L04 2-1437402-7 #6-32 Brass w/nickel plate SSB6, SSB7, RSB6 — 1447429-1 #8-32 Steel w/clear chromate Series #8 3L02 1437402-3 #6-32 Steel w/clear chromate RSB3, SSB3 L02 2-1437402-5 #6-32 Steel w/clear chromate SSB6, SSB7, RSB6 L09 2-1437402-8 #6-32 Brass w/nickel plate SSB6, SSB7, RSB6 — 8-1437649-0 #4-40 Steel w/clear chromate Series #4 — 1437651-5 #6-32 Brass w/nickel plate Series #6, BC6, JC6, NC6, MB6 — 1437651-2 #6-32 Steel w/clear chromate Series #6, BC6, JC6, NC6, MB6 — 1447425-1 #8-32 Steel w/clear chromate Series #8 — 9-1437667-9 #6-32 Steel w/clear chromate 4DB Wire Clamp Screws MOUNTING INSERTS (Nylon) for mounting RSBs with blank end sections Catalog Number Part No. L91 5-1437402-1 JC/BC-Retaining 1437661-7 L92 5-1437402-2 Retaining Clips Spring metal retaining clips fit around insulating barrel to provide permanent mounting of blocks to panels without the need for mounting holes. Use two per block. Catalog # JC/BC-Retaining. PRESS-ON RETAINING CLIPS (Stainless Steel) for mounting turret base SSBs, JC6, and BC6 Bottom view Angle Bracket for mounting SSBs with right angle terminals, copper alloy, tin plated 178 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Accessories — Standard and Custom Legends Product Facts n Permanent Barrier Strips markings, impervious to cleaning solvents per MIL-STD 202, Method 215 n Alphabetical and numerical legending n Numbers and characters can be in any order n Size and spacing of characters may be tailored to your application n White markings standard n Custom legends available on special request Custom legending can lend a personal touch to your product...helps in circuit identification and makes wiring faster and easier. Alphabetical and numerical markings are available in either standard or custom styles to best suit your specific applications. 2 Legending is available to the styles depicted below. Standard Legending Arrangements 2 1 1 1 2 3 3 2 1 2 3 3 2 1 Style D2 1 2 1 1 Style D3 3 2 3 1 2 1 1 2 3 3 2 1 1 2 Style C4 Style B4 3 3 2 1 Style A4 2 Style D1 Style C3 Style B3 Style A3 3 Style C2 Style B2 Style A2 3 Style C1 Style B1 Style A1 2 3 3 3 3 2 2 1 1 Style D4 179 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208 Note: All part numbers are RoHS Compliant. BUCHANAN Terminal Blocks Engineering Notes 180 Catalog 1308389 Revised 6-07 www.tycoelectronics.com Dimensions are in millimeters and inches unless otherwise specified. Dimensions are shown for reference purposes only. Specifications subject to change. USA: 1-800-522-6752 Canada: 1-905-470-4425 Mexico: 01-800-733-8926 C. America: 52-55-1106-0803 South America: 55-11-2103-6000 Hong Kong: 852-2735-1628 Japan: 81-44-844-8013 UK: 8706-080-208
JC6-T207-10 价格&库存
很抱歉,暂时无法提供与“JC6-T207-10”相匹配的价格&库存,您可以联系我们找货
JC6-T207-10
    • 1+93.08520
    • 180+37.15200
    • 480+35.91000
    • 1020+35.29440
