T1210160116-000
T1210160116-000
    HUMIREL(泰科)
    H16B-TS-PG16
T1210160116-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P LTR A A1 B B1 D DESCRIPTION DATE DWN APVD INITIAL 25MAY2015 DW CW ECR-16-013641 24SEP2016 CH CW ECR-20-008190 31JUL2020 WQR CW ECR-21-105138 23JUN2021 WQR CW D 44 44 PG/M THREAD-I PG/M -1 60 93.5 C 60 43 93.5 43 C ( 56.4 ) ( 56.4 ) PG/M THREAD-2 PG/M -2 4X M3 THREAD 4X M3 4X M3 THREAD 4X M3 27 27 SCALE 1:2 SCALE 1:2 77.5 B B 77.5 TYPE 1: LOW CONSTRUCTION, SIDE ENTRY 1: , TYPE 2: LOW CONSTRUCTION, TOP ENTRY 2: , NOTES: 1. TECHNICAL CHARACTERISTICS: HOOD MATERIAL: DIE CAST ALUMINIUM ALLOY SURFACE: POWDER COATED, GRAY DEGREE OF PROTECTION: IP65 (MATED) : 1. A : : : : IP65( THIS DRAWING IS A CONTROLLED DOCUMENT. ) DIMENSIONS: mm MATERIAL 1471-9 (3/13) - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - DWN 25MAY2015 CHK 25MAY2015 APVD 25MAY2015 DAVID.WANG CHRIS.WANG XIANG.XU TE Connectivity NAME PRODUCT SPEC A H16B-TS/TG-M/PG 108-137013 APPLICATION SPEC - 114-137013 WEIGHT Customer Drawing SIZE CAGE CODE A2 00779 RESTRICTED TO DRAWING NO T12X01601XX000 SCALE 1:1 SHEET 1 OF - 2 REV B1 4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P LTR - DESCRIPTION DATE SEE SHEET 1 DWN APVD - - - NOTES: SEE SHEET 1. D D T1210160116-000 T1210160120-000 T1210160121-000 C T1210160125-000 T1210160132-000 T1220160129-000 T1220160116-000 T1220160120-000 H16B-TS-PG16 H16B-TS-M20 H16B-TS-PG21 H16B-TS-M25 H16B-TS-M32 H16B-TG-PG29 H16B-TG-PG16 H16B-TG-M20 B T1220160121-000 T1220160125-000 T1220160132-000 T1220160136-000 ASSEMBLY PART NUMBER H16B-TG-PG21 H16B-TG-M25 H16B-TG-M32 H16B-TG-M36 H16B HOOD, SIDE ENTRY PG16, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , PG16,4 , , H16B HOOD, SIDE ENTRY M20, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , M20,4 , , H16B HOOD, SIDE ENTRY PG21, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , PG21,4 , , H16B HOOD, SIDE ENTRY M25, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , M25,4 , , H16B HOOD, SIDE ENTRY M32, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , M32,4 , , - M20 - PG21 - M25 - M32 - - PG29 - PG16 - M20 H16B HOOD, TOP ENTRY PG29, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , PG29,4 , , H16B HOOD, TOP ENTRY PG16, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , PG16,4 , , H16B HOOD, TOP ENTRY M20, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , M20,4 , , H16B HOOD, TOP ENTRY PG21, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , PG21,4 , , PG21 - M25 - M32 - M36 PG/M THREAD-1 PG/M -1 PG/M THREAD-2 PG/M -2 H16B HOOD, TOP ENTRY M32, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , M32,4 , , H16B HOOD, TOP ENTRY M36, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , M36,4 , , ASSEMBLY PART DESCRIPTION THIS DRAWING IS A CONTROLLED DOCUMENT. DIMENSIONS: mm MATERIAL - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - DWN 25MAY2015 CHK 25MAY2015 APVD 25MAY2015 DAVID.WANG CHRIS.WANG XIANG.XU TYPE 1 - H16B HOOD, TOP ENTRY M25, 4 EAR, LOW CONSTRUCTION, POWDER COATED, GRAY H16B , M25,4 , , A 1471-9 (3/13) PG16 TYPE 2 PRODUCT SPEC A H16B-TS/TG-M/PG 108-137013 APPLICATION SPEC - 114-137013 WEIGHT Customer Drawing SIZE CAGE CODE A2 00779 RESTRICTED TO DRAWING NO T12X01601XX000 SCALE 1:1 SHEET B TYPE TE Connectivity NAME C 2 OF - 2 REV B1
T1210160116-000 价格&库存
很抱歉,暂时无法提供与“T1210160116-000”相匹配的价格&库存,您可以联系我们找货
T1210160116-000
  • 1+126.852901+16.46757
  • 10+107.8233710+13.99723
  • 25+101.0680925+13.12029
  • 50+96.2415350+12.49372
  • 100+91.64848100+11.89747
  • 250+85.91437250+11.15309
  • 500+81.81775500+10.62128
  • 1000+77.917861000+10.11501
库存:18
