T1230105129-000
T1230105129-000
    HUMIREL(泰科)
    防护罩 连接器 侧面进入 PG29 H10B IP65 - 防尘,耐水
T1230105129-000 数据手册
T1230105129-000 Heavy Duty Connector Hood, Side Entry, Locking Clip, Sealable, HDC IP68 EMC T1230105129-000  ACTIVE HDC | HDC IP65, HDC IP68 EMC TE Internal #: T1230105129-000 Heavy Duty Connector Hood, Side Entry, Locking Clip, Sealable, HDC IP68 EMC View on TE.com > Connectors > Rectangular Connectors > Rectangular Connector Hoods & Bases Hood & Base Connector Product Type: Hood Cable Entry Location: Side Hood & Base Locking Device Type: Locking Clip Sealable: Yes Circuit Application: Power & Signal Features Product Type Features Hood & Base Connector Product Type Hood Sealable Yes Body Features Cable Entry Location Side Mechanical Attachment Thread Size PG29 Hood & Base Locking Device Type Locking Clip Housing Features Housing Material Die Cast Aluminum Dimensions Product Width 57 mm Product Length 73 mm Product Height 72 mm Usage Conditions  Corrosion Protected For support call+1 800 522 6752 Yes 01/03/2024 12:29AM | Page 1 T1230105129-000 Heavy Duty Connector Hood, Side Entry, Locking Clip, Sealable, HDC IP68 EMC Corrosion Protected Yes Operation/Application Circuit Application Power & Signal Packaging Features Packaging Quantity 10 Packaging Method Box Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Compliant China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts  For support call+1 800 522 6752 01/03/2024 12:29AM | Page 2 T1230105129-000 Heavy Duty Connector Hood, Side Entry, Locking Clip, Sealable, HDC IP68 EMC TE Part # T2040102101-000 TE Part # T3609290101-000 TE Part # T1415103000-000 HE-010-M DLX-29-MS H10B-AGS-EMC Also in the Series HDC IP65 Rectangular Connector Hoods & Bases (1258) Also in the Series HDC IP68 EMC Connector Caps & Covers(4) Rectangular Connector Hoods & Bases (445) Customers Also Bought  TE Part #1-480711-9 TE Part #640250-1 TE Part #T2020082201-000 TE Part #T0931003003-000 15P UMNL CAP HSG BLK 01P SL156 HSG W/LCK RAMP NATL HD-008-F CODING-PIN-M3 For support call+1 800 522 6752 01/03/2024 12:29AM | Page 3 T1230105129-000 Heavy Duty Connector Hood, Side Entry, Locking Clip, Sealable, HDC IP68 EMC TE Part #1SNA195638R2300 TE Part #T1730060000-000 TE Part #T2120100219-000 TE Part #T2120100220-000 M4/6.4A.P H6B-TBF-T ZGG-10DSTK,1-7,2-8,3-9,4-6,5-10 ZGGP-H10BSK 1-7/2-8/3-9/4-6/5-10 TE Part #1473203-1 025 CAP ASSY 16P P/BACK BRCKT Documents Product Drawings H10B-TSH-EMC-PG29 English CAD Files 3D PDF 3D Customer View Model ENG_CVM_CVM_T1230105129-000_A.2d_dxf.zip English Customer View Model ENG_CVM_CVM_T1230105129-000_A.3d_igs.zip English Customer View Model ENG_CVM_CVM_T1230105129-000_A.3d_stp.zip English By downloading the CAD file I accept and agree to the Terms and Conditions of use. Product Specifications Application Specification English  For support call+1 800 522 6752 01/03/2024 12:29AM | Page 4
T1230105129-000 价格&库存
很抱歉,暂时无法提供与“T1230105129-000”相匹配的价格&库存,您可以联系我们找货
T1230105129-000
    • 15+130.78846
    库存:30
    T1230105129-000
    • 15+90.87598
    库存:30
