T1280242120-000
T1280242120-000
    HUMIREL(泰科)
    H24B-TGBH-M20/PG21
T1280242120-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P LTR DESCRIPTION A A1 B D PG/M THREAD 2 PG/M 2 DWN APVD INITIAL 29MAY2015 DW CW ECR-17-008664 17JUN2017 CH CW ECR-20-014876 06NOV2020 WQR CW D NOTES: 1. TECHNICAL CHARACTERISTICS: HOOD MATERIAL: DIE CAST ALUMINIUM ALLOY SURFACE: POWDER COATED, GREY DEGREE OF PROTECTION: IP65 (MATED) 44 : 60 1. SCALE C DATE : : : : IP65( ) 3:5 C TYPE 2: LOW CONSTRUCTION, TOP ENTRY WITH STEEL DOUBLE LOCKING OTHER SPEC REFER TO TYPE 1 2: , , , 1 120 43 (56 ) (145 ) T1260242132-000 H24B-TGB-M32 T1260242129-000 H24B-TGB-PG29 4X M3 THREAD 4X M3 B PG/M THREAD 1 PG/M 1 T1260242125-000 H24B-TGB-M25 T1260242121-000 H24B-TGB-PG21 27 T1260240000-000 H24B-TGB T1250242132-000 H24B-TSB-M32 T1250242125-000 H24B-TSB-M25 104 SCALE TYPE 1: LOW CONSTRUCTION, SIDE ENTRY WITH STEEL DOUBLE LOCKING 1: , , A 3:5 T1250242121-000 H24B-TSB-PG21 PART NUMBER mm - M32 - PG29 - M25 - PG21 - - M32 - M25 - PG21 - H24B HOOD, TOP ENTRY M25, METAL DOUBLE LOCKING, POWDER COATED, GREY H24B , M25, , H24B HOOD, TOP ENTRY PG21, METAL DOUBLE LOCKING, POWDER COATED, GREY H24B , PG21, , H24B HOOD, NO ENTRY, METAL DOUBLE LOCKING, POWDER COATED, GREY H24B , , , H24B HOOD, SIDE ENTRY M32, METAL DOUBLE LOCKING, POWDER COATED, GREY H24B , M32, , H24B HOOD, SIDE ENTRY M25, METAL DOUBLE LOCKING, POWDER COATED, GREY H24B , M25, , H24B HOOD, SIDE ENTRY PG21, METAL DOUBLE LOCKING, POWDER COATED, GREY H24B , PG21, , THIS DRAWING IS A CONTROLLED DOCUMENT. DIMENSIONS: - H24B HOOD, TOP ENTRY PG29, METAL DOUBLE LOCKING, POWDER COATED, GREY H24B , PG29, , PART DESCRIPTION MATERIAL 1471-9 (3/13) H24B HOOD, TOP ENTRY M32, METAL DOUBLE LOCKING, POWDER COATED, GREY H24B , M32, , TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - 29MAY2015 DAVID.WANG CHK 29MAY2015 CHRIS.WANG APVD 29MAY2015 XIANG.XU TYPE TE Connectivity NAME A H24B-TSB/TGB/TSBH/TGBH-M/PG 108-137013 APPLICATION SPEC - 114-137013 WEIGHT Customer Drawing SIZE CAGE CODE A2 00779 RESTRICTED TO DRAWING NO T12X024XXXX000 SCALE 1:1 SHEET B TYPE 1 1 PG/M THREAD 1 PG/M THREAD 2 PG/M 1 PG/M 2 DWN PRODUCT SPEC TYPE 2 2 1 OF - 2 REV B 4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P LTR - D 45 DESCRIPTION DATE SEE SHEET 1 DWN APVD - - - D PG/M THREAD 2 PG/M 2 NOTES: 76 SEE SHEET 1 SCALE C 3:5 C TYPE 4: HIGH CONSTRUCTION, TOP ENTRY WITH STEEL DOUBLE LOCKING OTHER SPEC REFER TO TYPE 3 4: , , , 3 120 43 (145 ) (56 ) T1280242140-000 H10B-TGBH-M40 T1280242132-000 H24B-TGBH-M32 T1280242129-000 H24B-TGBH-PG29 4X M3 THREAD 4X M3 T1280242125-000 H24B-TGBH-M25 PG/M THREAD 1 PG/M 1 B T1280242121-000 H24B-TGBH-PG21 27 T1270242140-000 H24B-TSBH-M40 T1270242132-000 H24B-TSBH-M32 T1270242129-000 H24B-TSBH-PG29 104 SCALE 3:5 T1270242121-000 H24B-TSBH-PG21 PART NUMBER TYPE 3: HIGH CONSTRUCTION, SIDE ENTRY WITH STEEL DOUBLE LOCKING 3: , , A PART DESCRIPTION THIS DRAWING IS A CONTROLLED DOCUMENT. DIMENSIONS: mm MATERIAL 1471-9 (3/13) H24B HOOD, TOP ENTRY M40, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , M40, , , H24B HOOD, TOP ENTRY M32, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , M32, , , H24B HOOD, TOP ENTRY PG29, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , PG29, , , H24B HOOD, TOP ENTRY M25, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , M25, , , H24B HOOD, TOP ENTRY PG21, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , PG21, , , H24B HOOD, SIDE ENTRY M40, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED,GREY H24B , M40, , , H24B HOOD, SIDE ENTRY M32, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED,GREY H24B , M32, , , H24B HOOD, SIDE ENTRY PG29, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED,GREY H24B , PG29, , , H24B HOOD, SIDE ENTRY PG21, METAL DOUBLE LOCKING, HIGH CONSTRUCTION, POWDER COATED,GREY H24B , PG21, , , - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - 29MAY2015 DAVID.WANG CHK 29MAY2015 CHRIS.WANG APVD 29MAY2015 XIANG.XU M40 - M32 - PG29 - M25 - PG21 M40 - M32 - PG29 - PG21 - TYPE 4 4 B TYPE 3 3 PG/M THREAD 1 PG/M THREAD 2 PG/M 1 PG/M 2 DWN PRODUCT SPEC - TYPE TE Connectivity NAME A H24B-TSB/TGB/TSBH/TGBH-M/PG 108-137013 APPLICATION SPEC - 114-137013 WEIGHT Customer Drawing SIZE CAGE CODE A2 00779 RESTRICTED TO DRAWING NO T12X024XXXX000 SCALE 1:1 SHEET 2 OF - 2 REV B
T1280242120-000
1. 物料型号:文档列出了多个型号,例如 T1260242132-000, T1260242129-000, 等,每个型号后面有相应的描述。
2. 器件简介:文档描述了一种带有金属双锁定装置的罩子,表面涂有灰色粉末。
3. 引脚分配:提供了不同型号罩子的螺纹规格,如 M32, PG29, M25, PG21 等。
4. 参数特性:文档中提到了罩子的防护等级为 IP65(当配合使用时),材料为压铸铝合金,表面粉末涂层。
5. 功能详解:罩子分为不同类型,包括低构造顶部进入型和高构造侧面进入型等,具有金属双锁定功能。
6. 应用信息:文档中提到了应用规格编号为 108-137013。
7. 封装信息:提供了罩子的尺寸比例为 3:5,以及不同型号的封装细节。
T1280242120-000 价格&库存
很抱歉,暂时无法提供与“T1280242120-000”相匹配的价格&库存,您可以联系我们找货
T1280242120-000
  • 28+196.6639728+25.47487
