T1319320132-000
T1319320132-000
    HUMIREL(泰科)
    胶壳及附件 重载连接器 H32A-TS-M32
T1319320132-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 1 20 REVISIONS ALL RIGHTS RESERVED. BY - 20 2 3 P LTR A B DESCRIPTION DATE DWN APVD INITIAL RELEASE 11MAY2015 DL CW ECR-20-010477 28DEC2020 BS CW IG2 D D IG2 IG1 IG1 C 76 C TYPE 2 TOP ENTRY TYPE 1 SIDE ENTRY 56 82 69.4 8 16 8-M3 B T1319320116-000 H32A-TS-PG16 PG16 - T1319320120-000 H32A-TS-M20 M20 - T1319320121-000 H32A-TS-PG21 PG21 - H32A-TS-M25 M25 - T1319320129-000 H32A-TS-PG29 PG29 - T1319320132-000 H32A-TS-M32 M32 - T1319320140-000 H32A-TS-M40 M40 - T1329320121-000 H32A-TG-PG21 - PG21 T1329320125-000 H32A-TG-M25 - M25 H32A-TG-PG29 - PG29 H32A-TG-M32 - M32 T1329320140-000 H32A-TG-M40 - M40 T1329320150-000 H32A-TG-M50 - M50 IG1 IG2 16 T1319320125-000 66 T1329320129-000 A 1. ASSEMBLY PART NUMBER THIS DRAWING IS A CONTROLLED DOCUMENT. : : : , : IP65( DIMENSIONS: mm ) MATERIAL 1471-9 (3/13) TYPE 2 T1329320132-000 NOTES: 1. TECHNICAL CHARACTERISTICS: BODY MATERIAL: DIE CAST ALUMINIUM ALLOY SURFACE TREATMENT: POWDER-COATED, GRAY DEGREE OF PROTECTION: IP65 (MATED) : TYPE 1 - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - ASSEMBLY PART DESCRIPTION TYPE DWN 11MAY2015 CHK 11MAY2015 APVD 11MAY2015 DAVID LI CHRIS WANG XU XIANG B TE Connectivity NAME PRODUCT SPEC A H32A-TS/TG-PG/M 108-137010 APPLICATION SPEC - 114-137010 WEIGHT Customer Drawing SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T13X93201XX000 SCALE 1:1 SHEET 1 OF - 1 REV B
T1319320132-000 价格&库存
很抱歉,暂时无法提供与“T1319320132-000”相匹配的价格&库存,您可以联系我们找货
T1319320132-000
    • 8+160.79448
    • 50+156.97847
    库存:24
    T1319320132-000
      • 8+160.79448
      • 50+156.97847
      库存:32
      T1319320132-000
      • 8+111.72086
      • 50+109.07294
      库存:71
      T1319320132-000
        • 8+160.79448
        • 50+156.97847
        库存:15
        T1319320132-000
        • 1+61.09168
        库存:1
