T1320320129-000
T1320320129-000
    HUMIREL(泰科)
    H32B-TG-RO-PG29
T1320320129-000 数据手册
HEAVY DUTY CONNECTORS AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Contents General guide Product overview HA Series..................................................................................25-50 HD, HDD Series.......................................................................51-112 HE, HEE, HEEE Series.......................................................... 113-168 HSB Series........................................................................... 169-180 HQ Series...............................................................................181-196 HEAV Contact Series...................................................... 197-200 HMN Modular Series........................................................201-234 HK, HWK Series................................................................ 235-276 Hoods and Housings HA/HB series shells(IP65,IP68)..................................277-300 Inserts mounting elements Tools and inserts and rail mounting elements....... 301-310 Accessories Cable glands and accessories.......................................311-330 TE Heavy Duty Connectors – Applications Rolling Stock Machinery Factory Automation The broad range of Heavy Duty Connectors (HDC) are designed for reliably performing under the most demanding operating and harsh environmental conditions. With a tested salt spray and corrosion resistance of over 1000 hours and an IP 69 K rating, these connectors are suited for various applications in industrial environments. Thanks to their modular system, TE’s Heavy Duty Connectors offer power, signal and data transmission in one connector. 4 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS TE CONNECTIVITY AT YOUR SERVICE TE Connectivity Online The TE Connectivity website is an innovative and interactive source for application information, product updates and technical solutions. Our step-by-step software makes our website intuitive and user-friendly to better serve you! Please contact us at: te.com Product Information Centers You’ve got questions? TE’s Product Information Centers (PIC) will help you get answers. Contact a technical product information specialist. • Email us • Call us • Chat with us Please go to te.com/help for more information. Internet te.com 5 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Restriction on the Use of Hazardous Substances (RoHS) At TE Connectivity (TE), we are ready to support your RoHS requirements. We have assessed more than 1.5 million end items/components for RoHS compliance, and issued new part numbers where any change was required to eliminate the restricted materials. Part numbers in this catalog are identified as: ROHS COMPLIANT Part numbers in this catalog are RoHS Compliant, unless marked otherwise. These products comply with European Union Directive 2002/95/EC as amended 1 January 2006 that restricts the use of lead, mercury, cadmium, hexavalent chromium, PBB, and PBDE in certain electricelectronic products sold into the EU as of 1 July 2006. Note: For purposes of this Catalog, included within the definition of RoHS Compliant are products that are clearly “Out of Scope” of the RoHS Directive such as hand tools and other non-electrical accessories. NON-ROHS COMPLIANT These part numbers are identified with a “♦” symbol. These products do not comply with the material restrictions of the European Union Directive 2002/95/EC. 5 OF 6 COMPLIANT A “●” symbol identifies these part numbers. These products do not fully comply with the European Union Directive 2002/95/EC because they contain lead in solderable interfaces (they do not contain any of the other five restricted substances above allowable limits). However, these products may be suitable for use in RoHS applications where there is an application-based exception for lead in solders, such as the server, storage, or networking infrastructure exemption. Note: Information regarding RoHS compliance is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information provided by our suppliers. This information is subject to change. For latest compliance status, refer to our website referenced below. GETTING THE INFORMATION YOU NEED Our comprehensive on-line RoHS Customer Support Center provides a forum to answer your questions and support your RoHS needs. A RoHS FAQ (Frequently Asked Questions) is available with links to more detailed information. You can also submit RoHS questions and receive a response within 24 hours during a normal work week. The Support Center also provides: • Cross-Reference from Non-compliant to Compliant Products • Ability to browse RoHS Compliant Products in our on-line catalog: te.com/customersupport/productcoinpliance • More detailed information regarding the definitions used above So whatever your questions when it comes to RoHS, we’ve got the answers at www.te.com/leadfree 6 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS RoHS Customer Support Center General overview of heavy duty connectors General features TE’s HDC product series is designed for data, signal and power connections in harsh environments. The modular connector design provides a high degree of flexibility so solutions can be customized for different applications such as machinery, robotics, railway, wind energy and conventional energy generation and distribution. Inserts HDC products consist of three key elements: inserts, contacts and hoods and housings. The inserts and contacts are modular and assembled together to provide electrical performance offering crimp-, screw- and spring-clamp termination technology. Enclosures The hoods and housings are made of powder coated die cast aluminum alloy or of thermoplastic and are protecting the connector inserts against the ingress of dust or water according to the degree of protection IP 65, IP 68 and IP 69 K. Cable glands in different versions or DIN-rail mounts are completing the connector-solutions as accessories. Customized design For customer’s special requirement, we can provide customized design. Please contact us. 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices Specifications, Standards and Approvals 2. Standards DIN EN 175 301-801 DIN EN 60664-1 DIN EN 61 984 IEC 60 529 3. Approvals 7 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Connector components CABLE FITTING TD S21M Special cable fittings for protection up to IP69K and for electro-magnetic compatibility available HOOD Standard and corrosion-resistant connector hoods: • low and high construction • 4 different locking systems • different cable entries and directions: - M Thread - PG Thread CONTACTS Silver or gold plated Solid machined contacts with screw, spring or crimp termination Stamped and formed contacts MALE INSERT Screw, Spring clamp or crimp terminal FEMALE INSERT Screw, Spring clamp or crimp terminal HOOD AND HOUSING Standard and corrosion-resistant bottom-entry, surface-mounted and cable-to-cable hoods: • low and high construction (bottom-entry and cable-to-cable hood) with/without cover • 4 different locking systems 8 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Terminal types Screw dimensions and tightening torque for screw terminals Wire gauge (mm2) 1.5 2.5 4.0 6.0 10 16 Screw thread M3 M3 M3.5 M4 M4 M6 Test moment of torque (Nm) 0.5 0.5 0.8 1.2 1.2 1.2 Min. pull-out for stranded wire (N) 40 50 60 80 90 100 SCREW TERMINAL The screw terminal is the most common type of connection. Ratings are based on VDE 0609/EN 60 999. Please refer to the table at the left for the tightening torque. The series HE, HSB, HAVE are equipped with a wire protection, thus the use of ferrules is not necessary. The series HA is not equipped with wire protection and ferrules must be used. SPRING TERMINAL Spring terminal No special tools One conductor per termination Slot for screwdriver The spring terminal offers a vibration proof termination for solid and stranded wires with cross sections ranging from 0.14 mm2 to 2.5 mm2 (AWG 26-14). Easy operation of the spring terminal with a screw driver, which is inserted in the same direction of the cable opening. Internationally approved by UL, CSA, VDE. 60% faster CRIMP TERMINATION 1 2 3 4 A proper crimp connection is gastight, therefore corrosion free and represents a cold weld of the parts being connected. Wires to be connected must be matched with the correct size of crimp contacts. The crimp termination represents a highly reliable vibration proof connection with low contact resistance and highest contact density which can be applied with manual and automatic crimping tools. 3.5x0.5mm Screwdriver width: 3.5x0.5mm 9 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Terminal types SCREW TERMINAL Max. wire gauge mm AWG Stripping length L (mm) HA-003, HA-004 2.5 14 4.5 HA, HEAV 2.5 14 7.5 HE, HVE 2.5 14 7.5 HSB 6.0 10 7.5 HK, HWK 35.0 2.0 10.5 Inserts HA series HE, HVE series HSB series HK series HWK series HEAV series 2 CRIMP TERMINAL Inserts HD series HDD series Max. wire gauge mm AWG Stripping length L (mm) 0.5 20 8.0 0.75 18 8.0 1.0 18 8.0 1.5 16 8.0 2.5 14 6.2 2 HD HDD HMN(10A) HQ(10A) HK(10A) HAC, HEC series HEEE, HEE series HMN(16A/40A) series HQ(16A/40A) series HK(16A/40A) series Inserts HAC HEC HEE/HEEE HMN(16A/40A) HQ(16A/40A) HK(16A/40A) SPRING TERMINAL HAS series HES series HESAV series Inserts Max. wire gauge Stripping length L (mm) mm2 AWG 16A 40A 0.5 20 7.5 - 0.75 18 7.5 - 1.0 18 7.5 9.2 1.5 16 7.5 9.2 2.5 14 7.5 9.2 4.0 12 7.5 9.2 6.0 10 - 9.2 Max. wire gauge mm AWG Stripping length L (mm) 2.5 14 9-11 2 HAS, HES, HESAV RECOMMENDED TIGHTENING TORQUE AND SIZE OF SCREW DRIVER Size of screw Connector type Tightening torque [Nm] Tightening torque [Ibft] Recommended size of screwdriver M3 Screw terminal HA-003/HA-004/HQ-005 0.25 0.20 0.4x2.5 M3 Screw terminal HA-010, HA-016 0.50 0.40 0.5x3.5 or ±size 1 M3 HE, HVAE Screw terminal HE, HVAE fixing screws of all kinds, guiding pins and bushes 0.50 0.40 0.5x3.5 M4 Ground terminal HA, HE, HD, HDD 1.20 0.90 0.5x3.5 or ±size 1+2 M4 Terminal blocks HSB 1.20 0.90 0.8x4.5 M5 Ground terminal HSB 2.00 1.40 0.8x4.5/1.2x8.0 10 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Notes 11 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Degree of protection provided by enclosures For safety reasons, electrical equipment needs to be protected against outside influences. The basis for the determination is the standard IEC 529 titled ‘Degree of protection provided by enclosures (IP-Code)’. Using a standardized test procedure the extent of the protection class is verified. To classify different housings according to their protection class, a designation system is used which consists of the code – letters ‘IP’ and two code numbers. ARRANGEMENT OF THE IP-CODE (INTERNATIONAL/INGRESS PROTECTION) IP 5 6 Code Letter 1st characteristic numeral 2nd characteristic numeral MEANING OF THE 1ST CHARACTERISTIC NUMERAL The first numeral describes the protection of the housing against intrusion of foreign bodies as well as the protection of people against dangerous parts or influences. Because of this, there are two descriptions and definitions for each of the first code letter. 1st numeral Protection against solid objects and against access to hazardous parts 0 No protection short description 1 2 3 4 • protection against solid foreign bodies of Ø 50mm • protection against access to hazardous parts with the back of a hand • protection against solid foreign bodies of Ø 12mm • protection against access to hazardous parts with the finger • protection against solid foreign bodies of 2.5mm diameter and bigger • protection against access to hazardous parts with a tool • protection against solid foreign bodies of 1.0mm diameter and bigger • protection against access to hazardous parts with a wire definition A sphere of Ø 50mm, must not intrude A sphere of Ø 12mm diameter, must not intrude A sphere of Ø 2.5mm diameter, must not intrude The probe, sphere of Ø 1.0mm, must not intrude 5 Protected against dust The infiltration of dust is not completely prevented, but it does not infiltrate to such an extent that the operation or the safety of the device is affected 6 Dust proof No infiltration of dust 12 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS MEANING OF THE 2ND CHARACTERISTIC NUMERAL The second numeral describes the protection of the housing against the intrusion of water with harmful effects. 2nd numeral Protection degrees against the intrusion of water, designated by the second code digit short description definition 0 Not protected – 1 Protected against dripping water Vertically falling drops shall have not harmful effects 2 Protected against dripping water when the housing is at an angle of up to 15° Vertically falling drops shall have not harmful effects when the enclosure is tiled up to 15° 3 Protected against water spray Water sprayed at an angle up to 60°, shall have no harmful effects 4 Protected against splash water Water splashed against the enclosure from any direction, shall have no harmful effects 4K Protected against splash water with increased pressure Water splashed against the enclosure with increased pressure from any direction, shall have no harmful effects (Applies acc. to DIN 40050-9 only for road vehicles) 5 Protected against jets of water Water splashes against the enclosure from any direction as a water jet, shall have no harmful effects 6 Protected against strong jets of water Water splashes against the enclosure from any direction as a strong water jet, shall have no harmful effects 6K Protected against strong jets of water with increased pressure Water splashes directly against the enclosure from any direction as a strong water jet with increased pressure, shall have no harmful effects (Applies acc. to DIN 40050-9 only for road vehicles) 7 Protection against the effects of temporary submersion in water Quantity of water that ingresses an enclosure, when it is temporarily immersed under standardized conditions of pressure and time, shall have no harmful effects Protection against the effects of continuous submersion in water Quantity of water that ingresses an enclosure, when it is continuously immersed under conditions of pressure and time, shall have no harmful effects. The conditions must, however be harder than for code digit 7 and agreed between user and producer Protected against water during highpressure / jet-stream cleaning Water that is directed against the housing with greatly increased pressure from any direction must not have any detrimental effect (Applies acc. to DIN 40050-9 only for road vehicles) 8 9K 13 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Standards SPECIFICATIONS TE connectors are still made on IEC 664/664 A, DIN VDE 0110/01.89 and DIN VDE 0627/06.86 standards. The standards have defined normal rules and requirements which include features construction and requirements. To determine the minimum clearances and creepage distance, the recent applicable standard is the IEC 60664-1 standard (10.92), a fundamental safety standard to which all product in the committees should refer. If no notice to products in the cataloge, clearance and creepage distances of all products in the cataloge are based on DIN VDE 0110:1989-01 and degrees pollution 3. Include some contents: 1. Over-voltage categories (I, II, III, IV) 2. Degrees of pollution 3. Insulating material 4. Determination of clearances OVER-VOLTAGE CATEGORIES 1. Over-voltage category I Equipment in over-voltage category I is only intended for use in apparatus or parts of systems in which no over-voltages will occur or are specially protected against over-voltages by means of surge voltages, filters or capacitors. 2. Over-voltage category II Equipment in over-voltage category II is intended for use in systems or parts there of in which lighting over-voltages do not have to be taken into account. 3. Over-voltage category III Equipment in over-voltage category III is intended for use in equipment for fixed installation, i.e. protective devices, relays, switches and plug devices. 14 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Insulation Coordination for Electrical Connectors in Low Voltage Plants Dimensioning of Clearance and Creeping Distances acc. to DIN EN60664-1; following pages show only a part of the standards. INSULATION COORDINATION Insulation coordination includes the design of the electrical insulation of a connector depending on its use and environment. This occurs either by design of the clearance distances (basis is the expected power surge) or by design of the creeping distance (basis is the operating voltage as well as the quality of the insulating material). Furthermore, insulation-changing conditions are taken into account (pollution, protective measures against pollution, air pressure, thermal or chemical influences). Air distances are measured according to the outer or inner power surge expected. The four power surge classes (power surge categories I to IV) take the different use of the connector into account. Depending on the homogeneity of the field between the electrodes (case A – inhomogenous field, case B – homogenous field) the air distances can be determined according to table 2a (minimum air distances); industrial connectors are always determined according to case A. The influence from pollution when determining the air- and creeping distances is taken into account by using four degrees of severity (pollution degree 1 to 4). Basis of the creeping distances is the rated voltage which is deduced from the operating voltage. The minimum creeping distances are allocated in table 4 depending on the severity of pollution. If the product descriptions do not contain any additional information the products listed in this catalogue were rated according tonorm DIN VDE 0110 for surge category III and severity of pollution 3. SURGE CATEGORY I TO IV • Resources of surge category I are goods for the termination of fixed electrical installations of a building. Measures for the limitation of transient surges were taken either in the fixed installation or between the fixed installation and the equipment. • Resources of surge category II are resources which use power and are fed from a fixed installation. Note: e.g. domestic appliances, portable tools and other appliances as well as similar consumers. • Resources of surge category III are part of a fixed installation. They are resources from which a high degree of availability is expected. Note: Examples for such appliances are e.g. industrial connectors, distribution panels, power switches, distributors, switches, sockets. • Devices of surge category IV are for use at the supply terminal of the installation.Note: Examples for such appliances are electricity counters, overload cut-out switches. POLLUTION DEGREE 1 TO 4 DIN VDE 0110 defines the pollution degrees as follows: Pollution Degree 1: There is no or only dry, non-conductive pollution. The pollution is without influence. Pollution Degree 2: There is only non-conductive pollution. Occasional momentary conductivity due to condensation. Pollution Degree 3: There is conductive pollution or dry non-conductive pollution, which becomes conductive due to condensation. Pollution Degree 4: There is a continuous conductivity due to conductive dust, rain or moisture. Insulation Material The insulation materials are divided into the following four groups depending on their comparative tracking index (CTI): Insulation material I:.......................................................................................................600 ≤ CTI Insulation material II:........................................................................................ 400 ≤ CTI < 600 Insulation material III a:..................................................................................... 175 ≤ CTI < 400 15 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Measurement of Clearances DIAGRAM FOR THE DETERMINATION OF CLEARANCES rated voltage of the power supply rated surge voltage rated surge voltage acc. to table 1 surge categories, normally III degree of pollution normally 3, but acc. to EN 61984 a smaller class may be chosen if the housing has a protection class of IP54 minimum clearance L acc. to table 2 a height > 2000 m NN multiply L with height correction factor acc. to table 2 b clearance L in mm RATED SURGE VOLTAGE FOR UTILITIES Rated voltage of the power supply* in V Rated Surge Voltage in kV (1.2/50ms) for single systems in the centre utilities at the feed of the installation (surge category IV) utilities as part of a fixed installation (surge category III) utilities for connection to fixed installations (surge category II) Specially protected utilities (surge category I) 120 up to 240 4 2.5 1.5 0.8 230/400** 277/480** 6 4 2.5 1.5 400/690** 8 6 4 2.5 1000 12 8 6 4 3-phase systems *) chosen voltage values **) the / dash is for a 3-phase system with 4 lines. The lower value is for phase to neutral, the higher value is for phase to phase 16 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS MINIMUM CLEARANCE IN AIR AT INSTALLATION HEIGHTS OF UP TO 2000 M ABOVE SEA LEVEL (NN) “rated surge voltage [kV]” case A, inhomogenous field, degree of pollution case B, homogenous field, degree of pollution 1 (mm) 2 (mm) 1 (mm) 2 (mm) 0.33 _) 0.01 _) 0.01 _) 0.40 0.02 0.02 0.5 _) 0.04 0.04 0.60 0.06 0.06 0.80 _) 0.10 1.0 0.15 1.2 0.25 0.25 0.2 1.5 _) 0.5 0.5 0.3 0.3 2.0 1.0 1.0 1.0 0.45 0.5 2.5 _) 1.5 1.5 1.5 0.6 0.6 3.0 2 2 2 2 0.8 0.8 4.0 _) 3 3 3 3 1.2 1.2 1.2 5.0 4 4 4 4 1.5 1.5 1.5 6.0 _) 5.5 5.5 5.5 5.5 2 2 2 2 8.0 _) 8 8 8 8 3 3 3 3 10 11 11 11 11 3.5 3.5 3.5 3.5 12 _) 14 14 14 14 4.5 4.5 4.5 4.5 15 18 18 18 18 5.5 5.5 5.5 5.5 20 25 25 25 25 8 8 8 8 25 33 33 33 33 10 10 10 10 30 40 40 40 40 12.5 12.5 12.5 12.5 40 60 60 60 60 17 17 17 17 50 75 75 75 75 22 22 22 22 60 90 90 90 90 27 27 27 27 80 130 130 130 130 35 35 35 35 100 170 170 170 170 45 45 45 45 3 (mm) 0.2 4 (mm) 0.80 0.10 1.6 0.2 3 (mm) 4 (mm) 0.8 0.15 1.6 1) This voltage is - for functional insulation: the maximum impulse voltage expected to occur across the clearance - for basic insulation directly exposed by transient overvoltages - for other basic insulation _) Preferred values FACTORS FOR HEIGHT CORRECTION height in m 2000 3000 4000 5000 6000 7000 8000 9000 10000 15000 20000 normal air pressure in kPa 80.0 70.0 62.0 54.0 47.0 41.0 35.5 30.5 26.5 12.0 5.5 multiplication factor for distances 1.00 1.14 1.29 1.48 1.70 1.95 2.25 2.62 3.02 6.67 14.50 17 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Measurement of creepage DIAGRAM FOR THE DETERMINATION OF CREEPAGE voltage of the power supply rated surge voltage according to table 3 Insulation Class of used material, normally III minimum creepage L acc. to table 4 creepage in mm 18 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS degree of pollution normally 3, but acc. to EN 61984 a smaller class may be chosen if the housing has a protection class of minimum IP54 voltage of the power supply [V] rated voltage [V] 60 63 110/120/127 125 150 160 208 200 220/230/240 250 300 320 380/400/415 400 440 500 480/500 500 575 630 600 630 660/690 630 720/830 800 960 1000 1000 1000 Table 3 *the above shown table does not give the entire correlation of world-wide used networks and rated voltages; it is reduced to the most common ones; further details, see DIN EN60664-1 CREEPAGES IN [MM] FOR ELECTRICAL EQUIPMENTS rated voltage [V] degree of pollution 1 All Insulator Classes I II III I II III I II III 10 0.08 0.40 0.40 0.40 1.00 1.00 1.00 1.6 1.6 1.6 12.5 0.09 0.42 0.42 0.42 1.05 1.05 1.05 1.6 1.6 1.6 16 0.10 0.45 0.45 0.45 1.10 1.10 1.10 1.6 1.6 1.6 20 0.110 0.48 0.48 0.48 1.20 1.20 1.20 1.6 1.6 1.6 25 0.125 0.50 0.50 0.50 1.25 1.25 1.25 1.7 1.7 1.7 32 0.140 0.53 0.53 0.53 1.30 1.30 1.30 1.8 1.8 1.8 40 0.16 0.56 0.80 1.10 1.4 1.6 1.8 1.9 2.4 3.0 50 0.18 0.60 0.85 1.20 1.5 1.7 1.9 2.0 2.5 3.2 63 0.20 0.63 0.90 1.25 1.6 1.8 2.0 2.1 2.6 3.4 80 0.22 0.67 0.95 1.3 1.7 1.9 2.1 2.2 2.8 3.6 100 0.25 0.71 1.00 1.4 1.8 2.0 2.2 2.4 3.0 3.8 125 0.28 0.75 1.05 1.5 1.9 2.1 2.4 2.5 3.2 4.0 160 0.32 0.80 1.1 1.6 2.0 2.2 2.5 3.2 4.0 5.0 200 0.42 1.00 1.4 2.0 2.5 2.8 3.2 4.0 5.0 6.3 250 0.56 1.25 1.8 2.5 3.2 3.6 4.0 5.0 6.3 8.0 320 0.75 1.60 2.2 3.2 4.0 4.5 5.0 6.3 8.0 10.0 400 1.00 2.00 2.8 4.0 5.0 5.6 6.3 8.0 10.0 12.5 500 1.30 2.50 3.6 5.0 6.3 7.1 8.0 10.0 12.5 16.0 630 1.8 3.2 4.5 6.3 8.0 9 10.0 12.5 16 20 800 2.4 4.0 5.6 8.0 10.0 11 12.5 16.0 20 25 1000 3.2 5.0 7.1 10.0 12.5 14 16.0 20.0 25 32 2 Insulation Class 3 Insulation Class 4 Insulation Class Table 4 19 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Standards CURRENT CARRYING CAPACITY The current carrying capacity is determined in tests which are conducted on the basis of the DIN IEC 60 512 part 3. The current carrying capacity is limited by the thermal properties of materials which are used for inserts as well as by the insulating materials. These components have a maximum temperature which should not be exceeded. Upper current limit set by external factors Permissible upper temperature-limit set by applied materials Basic curve Corrected curve Permissible operation range Example of a current capacity curve The relationship between the current, the temperature rise (loss at the contact resistance) and the ambient temperature of the connector is represented by a curve. On a linear coordinate system the current lies on the vertical line (ordinate) and the ambient temperature on the horizontal line (abscissa) which ends at the permissible upper-limit temperature. In another measurement the self-heating (Δt) at different currents is determined. The corrected current carrying capacity curve is derived from this basic curve. The reasons for the correction are external factors that bring an additional limitation to the current carrying capacity, i.e. connectable wire gauge or an unequal dispersion of current. In practice it is not usual to load all terminals simultaneously with the maximum current. In such a case one contact can be loaded with a higher current as permitted by the current capacity curve, if less than 20% of the whole is loaded. current carrying capacity Permissible upper temperature-limit set by applied materials Ambient temperature 20 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Standards TIGHTENING TORQUE OF TERMINAL BLOCK SCREWS IEC 60 947-1:1996/EN 60 947-1:1977 modified, table 4 specifies tightening torques for screw connections based on the type and size of the screw for electrical and mechanical type tests. Tightening contact terminal block to this torque guarantees that the connected conductors are reliably connected. The technical product data given in this catalog differ from this value. However they indicate a practical range of tightening torques which provides a gas-tightening contact and offers long-term contact stability. Extract from IEC 60 947-1/EN 60 947, Table 4 The torque according to IEC, EN Head screw with slot Recommended tightening torque Thread Type Torque [Nm] CuZn or CuSN screw [Nm] Steel screw [Nm] M2.5 0.4 0.6 0.8 M3 0.5 0.8 1.0 M3.5 0.8 1.2 - M4 1.2 1.8 2.0 M5 2.0 3.0 4.5 M6 2.5 4.0 8.0 LOW CURRENTS AND VOLTAGES Standard contacts have a silver plated surface. This precious metal has excellent conductive properties. In the course of a contact’s lifetime, the silver surface generates a black oxide layer due to its affinity to sulphur. This layer is smooth and very thin and is partly interrupted. When the contacts are mated and unmated, thus guaranteeing very a low contact resistances. In the case of very low currents or voltages small changes to the transmitted signal may be encountered. This is illustrated below where an artifically aged contact representing a twenty year life is compared with a new contact. 1 1 2 2 2 1 New contact 2 After ageing 2 2 1 1 1 Changes to the transmitted signal after artifical ageing Recommendation Silver Gold Left is a table derived from actual experiences 21 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Selection guide TECHNICAL INFORMATION OF INSERTS Insert HA HD HDD HE HEE Type Poles Current Voltage Terminal Contacts Shells HA-003 3+PE 10A 250 V screw - H3A HA-004 4+PE 10A 250V screw - H3A HA-010 10+PE 16A 250V HA-016 16+PE 16A 250V screw crimp CEM/F(16A) DEM/F(16A) HA-032 32+PE 16A 250V HAS-003 003+PE 10A 400V spring - H3A HAS-004 004+PE 10A 400V spring - H3A HD-007 7+PE 10A 250V H3A HD-008 8 10A 50V H3A HD-015 15+PE 10A 250V H10A HD-025 25+PE 10A 250V HD-040 40+PE 10A 250V HD-050 50+PE 10A 250V HD-064 64+PE 10A 250V H24B HD-080 80+PE 10A 250V H32B HD-128 128+PE 10A 250V H48B HDD-016 16+PE 10A 250V H6B HDD-024 24+PE 10A 250V H6B HDD-042 42+PE 10A 250V HDD-072 72+PE 10A 250V HDD-108 108+PE 10A 250V HDD-144 144+PE 10A 250V H32B HDD-216 216+PE 10A 250V H48B HE-006 6+PE 16A 500V H6B HE-010 10+PE 16A 500V HE-016 16+PE 16A 500V HE-024 24+PE 16A 500V HE-032 32+PE 16A 500V HE-048 48+PE 16A 500V H48B HEE-010 10+PE 16A 500V H6B HEE-018 18+PE 16A 500V H10B HEE-032 32+PE 16A 500V HEE-046 46+PE 16A 500V HEE-064 64+PE 16A 500V H32B HEE-092 92+PE 16A 500V H48B HEE-015 14+PE 16A 200V 22 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H10A H16A H32A crimp crimp screw crimp spring double spring crimp CDM/F(10A) DDM/F(10A) CJM/F(10A) CDM/F(10A) DDM/F(10A) CJM/F(10A) H16A H16B H32A H10B H16B H24B H10B CEM/F(16A) DEM/F(16A) H16B H24B H32B CEM/F(16A) DEM/F(16A) CSF(16A) H16B H24B - Selection guide TECHNICAL INFORMATION OF INSERTS Insert HEEE HVE HSB Type Poles Current Voltage HEEE-020 20+PE 16A 400V H6B HEEE-032 32+PE 16A 400V H10B HEEE-040 40+PE 16A 500V H16B HEEE-048 48+PE 16A 400V H16B HEEE-064 64+PE 16A 500V HEEE-072 72+PE 16A 400V HEEE-080 80+PE 16A 500V H32B HEEE-096 96+PE 16A 400V H32B HEEE-128 128+PE 16A 500V H48B HEEE-144 144+PE 16A 400V H48B HVE-003 3+PE+2 16A 830V HMN crimp Contacts CEM/F(16A) DEM/F(16A) Shells H24B H24B H10B screw crimp spring CEM/F(16A) DEM/F(16A) HVE-006 6+PE+2 16A 830V HVE-010 10+PE+2 16A 830V HSB-006 6+PE 35A 400/690V screw - H16B HSB-012 12+PE 35A 400/690V screw - H32B HQ-005 5+PE 16A 400V CEM/F(16A) DEM/F(16A) H3A HQ-007 7+PE 10A 400V CDM/F(10A) DDM/F(10A) H3A HQ-008 8+PE 16A 500V CEM/F(16A) DEM/F(16A) H8A CDM/F(10A) DDM/F(10A) H3A HQ HEAV Terminal crimp H16B H24B HQ-012 12+PE 10A 400V HQ-017 17+PE 10A 250V HQ4/2 4+PE+2 40A+10A 600V+250V CDM/F(10A) DDM/F(10A) CMM/F(40A) DMM/F(40A) H8A HEAV-006 6+PE 16A 500V - H6B HEAV-010 10+PE 16A 500V - H10B HEAV-016 16+PE 16A 500V - H16B HEAV-024 24+PE 16A 500V - H24B HMN-001 1 200A 1000V crimp CHM/F(200A) - HMN-D2 2 100A 1000V crimp CNM/F(100A) - HMN-002 2 70A 1000V crimp CSM/F(70A) - HMN-003 3 40A 690V crimp CMM/F(40A) DMM/F(40A) - HMN-004 4 40A 830V crimp CMM/F(40A) DMM/F(40A) - HMN-004SC 4 - - - - - HMN-005 5 16A 400V spring - - HMN-006 6 16A 500V crimp - HMN-006P 6 16A 830V crimp CEM/F(16A) DEM/F(16A) screw spring H8A - 23 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Selection guide TECHNICAL INFORMATION OF INSERTS Insert HMN Type Poles Current Voltage Terminal Contacts Shells HMN-008 8 16A 400V crimp CEM/F(16A) DEM/F(16A) - HMN-012 12 10A 250V crimp CDM/F(10A) DDM/F(10A) - HMN-017 17 10A 160V crimp CDM/F(10A) DDM/F(10A) - HMN-020 20 16A 500V crimp CEM/F(16A) DEM/F(16A) - HMN-025 25 5A 50V crimp CAM/F(5A) DAM/F(5A) - HMN-009 9 5A 50V crimp CAM/F(5A) DAM/F(5A) - HMN-RJ45 8 1A 50V crimp - - HMN-Q1 1+1 16A 50V crimp CEM/F(16A) DEM/F(16A) - HMN-Q2 4+4 10A 50V crimp CDM/F(10A) DDM/F(10A) - HMN-Q3 8+8 5A 50V crimp CAM/F(5A) DAM/F(5A) - PIN-Q1 1 16A 50V crimp CEM/F(16A) DEM/F(16A) - PIN-Q2 4 10A 50V crimp CDM/F(10A) DDM/F(10A - PIN-Q3 8 5A 50V crimp CAM/F(5A) DAM/F(5A) - HMN-DM - - - - - - HK4/0 4+PE 80A 690V screw - H16B HK4/2 4+PE+2 80A+16A 690V+400V screw - H16B HK6/12 6+PE+12 40A+10A 690V+230/400V screw - H16B crimp CMM/F(40A) DMM/F(40A) CDM/F(10A) DDM/F(10A) H16B H16B HK12/2 HK/ HWK 12+PE+2 40A+10A 690V+250V HK6/36 6+PE+36 40A+10A 690V+160V crimp CMM/F(40A) DMM/F(40A) CDM/F(10A) DDM/F(10A) HK4/8 4+PE+8 80A+16A 400V screw - H24B H10B HK8/24 8+PE+24 16A+10A 230/400V+160V crimp CEM/F(16A) DEM/F(16A) CDM/F(10A) DDM/F(10A) HWK6/6 6+PE+6 40A+16A 690V+400V screw - H16B HWK3/3/6 3+PE+3+6 100A+40A+16A 400/690V+400/ 690V+250/400V screw - H24B 24 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HA Series 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 60664-1 DIN EN 61 984 3. Approvals 25 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD technical characteristics CURRENT CARRYING CAPACITY Specifications .................................................................... DIN VDE 0627 ...................................................................................................DIN VDE 0110 Standards ...................................................................................DIN 43 652 ............................................................................................ CECC 75 301-801 Number of contacts.....................................7,8,15,25,40,50(2x25),64, ............................................................................80(2x40),128(2x64) + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 10A max (See current carrying capacity) Working voltage ..................................................................... (8D is 50V) .............................................................................250V, Insulation group C Test voltage urms ......................................................4KV(8D is 0.8KV) Pollution degree .......................................................................................... 3 Pollution degree 2 also 10A; 250V/400V Insulation resistance ........................................................................ ≥1010Ω Material ............................................... Polycarbonate or Polybutylece Temperature range............................................ -40°C... +100°C/125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA.................................................. 600V Mechanical working life-mating cycles........................................ ≥500 Working current INSERTS CONTACTS Ambient temperature Wire gauge: 0.75 mm2 Ambient temperature Wire gauge: 1.50 mm2 Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance .............................................................................≤3mΩ Terminal .............................................................................. Crimp terminal ................................................................................................ Rolled terminal - mm2 ......................................................................................... 0.15-2.5mm2 - AWG ......................................................................................................26-14 Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 Working current HOODS, HOUSINGS 1 HD-007 26 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HD-007/008 inserts INSERTS FOR H3A HOOD/HOUSING 250V/50V 10A 7+  8 Dimensions (mm) Contact arrangement view from termination side Part Number Male insert Type Female insert 250V/10A T2020072101-000 HD-007-M T2020072201-000 HD-007-F 50V/10A T2020082101-000 HD-008-M T2020082201-000 HD-008-F 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 27 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HA technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ...................................................................................................DIN EN 61984 Number of contacts..........................................3,4,10,16,32(2x16) + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current HA-3, HA-4................................................................................................ 10A HA-10, HA-16, HA-32............................................................................... 16A Working voltage HA-3, HA-4................................................................................250V/400V HA-10, HA-16, HA-32............................................................................250V Test voltage urms HA-003, HAS-004, HA-10, HA-16, HA-32...................................... 4KV HAS-003.................................................................................................... 6KV HA-004...................................................................................................2.5KV Pollution degree .......................................................................................... 2 Insulation resistance ........................................................................ ≥1010Ω Working current INSERTS Ambient temperature Material ............................................... Polycarbonate or Polybutylece Temperature range............................................ -40°C... +100°C/125°C Flammability acc. to UL94....................................................................V0 Working voltage acc. to UL/CSA.................................................. 600V Mechanical working life-mating cycles........................................ ≥500 HA-003/HA-004 Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ..........................................................................................Hard gold-xplated Contact resistance ..............................................................................≤1mΩ Terminal .............................................................................. Screw terminal ................................................................................................ Crimp terminal ................................................................................................Spring terminal - mm2 ..................................... 0.5-2.5mm2 /0.14-4.0mm2/0.5-2.5mm2 - AWG ............................................................................20-14/26-14/20-14 - Tightening/test torque.............0.5Nm: HA-010, HA-016, HA-032 ..........................................................................0.25Nm: HA-003, HA-004 Working current CONTACTS Ambient temperature HA-010 Ambient temperature HA-016/HA-032 Material ....................................................................................Die cast zinc Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range............................................ -40°C... +100°C/125°C Degree of protection acc. to DIN40 050.....................................IP65 Working current HOODS, HOUSINGS 1 Wire gauge: 2.5mm2 2 Wire gauge: 1.5mm2 3 Wire gauge: 1.0mm2 28 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HA-003/004 inserts INSERTS FOR H3A HOOD/HOUSING 250V/400V 10A 3+  4+  Dimensions (mm) Contact arrangement view from termination side Type Part Number Male insert Female insert Screw terminal 250V/10A T2010032101-000 HA-003-M T2010032201-000 HA-003-F Spring terminal 400V/10A T2010033101-000 HA-003-MS T2010033201-000 HA-003-FS Screw terminal 250V/10A T2010042101-000 HA-004-M T2010042201-000 HA-004-F Spring terminal 400V/10A T2010043101-000 HA-004-MS T2010043201-000 HA-004-FS 29 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HQ technical characteristics CURRENT CARRYING CAPACITY Specifications ............................................................... DIN EN 60 664-1 ................................................................................................ DIN EN 61 984 Number of contacts ........................................................ 5,7,8,12,17 + PE INSERTS Working current HQ-005,008.................................................................................... 16A max HQ-007,012,017.............................................................................. 10A max Working voltage HQ-005,007,012...................................................................................400V HQ-008................................................................................................... 500V HQ-017.....................................................................................................250V Test voltage urms HQ-005,017.............................................................................................. 4KV HQ-007,008,012 .................................................................................... 6KV Pollution degree ......................................................................................... 3 Insulation resistance ....................................................................... ≥1010Ω Material ............................................................................... Polycarbonate Temperature range .......................................... -40°C... +100°C/125°C Flammability acc. to UL94 ................................................................. V0 Working voltage acc. to UL/CSA ................................................ 600V Mechanical working life-mating cycles ..................................... ≥500 CONTACTS Material ................................................................................... Copper alloy Surface ......................................................................... Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ............................................................................. ≤1mΩ Terminal ............................................................................. Crimp terminal - mm2.............................................................0.14-4.0/0.14-2.5/1.5-6mm2 - AWG.............................................................................. 26-12/26-14/16-10 - Tightening/test torque ........................................................... 0.25Nm HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 30 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. HQ-007/012 inserts INSERTS FOR H3A HOOD/HOUSING 400V MAX. 10A 7+  12+   Dimensions (mm) Contact arrangement view from termination side Part Number Male insert Type Female insert Crimp terminal (Order crimp contacts separately) T2080072101-000 HQ-007-M T2080072201-000 T2080122101-000 HQ-007-F HQ-012-M T2080122201-000 HQ-012-F 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 31 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HQ-005 inserts INSERTS FOR H3A HOOD/HOUSING 400V MAX. 16A 5+  Dimensions (mm) Contact arrangement view from termination side Part Number Male insert Type Female insert Crimp terminal (Order crimp contacts separately) T2080052101-000 HQ-005-M T2080052201-000 HQ-005-F 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 32 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Part Number H3A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG11 H3A-MTG-PG11 T1329030111-000 H3A-MTG-M20 T1329030120-000 H3A-MTS-PG11 T1319030111-000 H3A-MTS-M20 T1319030120-000 H3A-MAG T1509030000-000 H3A-MAGS T1549030000-000 H3A-MAGSV-PG11 T1619030111-000 M16 H3A-MAGSV-M16 T1619030116-000 M20 H3A-MAGSV-M20 T1619030120-000 H3A-MTGVB-PG11 T1739030111-000 H3A-MTGVB-M20 T1739030120-000 H3A-KDTP T1010031100-000 H3A-KDB T1010033100-000 Top entry M20 Side entry PG11 M20 Bulkhead mounting: Bottom entry Bulkhead mounting: Side entry Surface mounting: Side entry PG11 Cable-to-cable hood: PG11 M20 Protection covers for hoods (thermoplastic) Note: For mounted male insert and hood Metal protection covers for hoods Note: For mounted female insert and hood 33 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H3A thermoplastic hoods/housings THERMOPLASTIC HOODS, HOUSINGS Dimensions (mm) Metr. PG Type Part Number PG11 H3A-TG-PG11 H3A-TG-M20 T1329031111-000 T1329031120-000 PG11 H3A-TS-PG11 H3A-TS-M20 T1319031111-000 T1319031120-000 H3A-AG T1509031100-000 H3A-AGS T1509031111-000 PG11 H3A-AGSV-PG11 H3A-AGSV-M16 H3A-AGSV-M20 T1619031111-000 T1619031116-000 T1619031120-000 PG11 H3A-TGVB-PG11 H3A-TGVB-M20 T1739031111-000 T1739031120-000 H3A-KDTP T1010031100-000 H3A-KDBP (White) H3A-KDBPG (Grey) T1010032100-000 T1010032300-000 H3A-KDBP (White) H3A-KDBP (Grey) T1010033200-000 T1010032200-000 Top entry M20 Side entry M20 Bulkhead mounting: Bottom entry Bulkhead mounting: Side entry Surface mounting: Side entry M16 M20 Cable-to-cable hood: M20 Protection covers for hoods (thermoplastic) Note: For mounted male insert and hood Protection covers for hoods Note: For mounted female insert and hood White Grey Covers without sealing type 34 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP.3/4, HIP-K.3/4, EMV-K.3/4 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood IP 68 / IP 69 K Description Metr. PG Type Part Number 11 HIP HIP.3/4.ST0.1.11.G HIP.3/4.ST0.1.M16.G 1-1102600-5 0-1106408-1 HIP-K HIP-K.3/4.ST0.1.11.G HIP-K.3/4.ST0.1.M16.G HIP-K.3/4.ST0.1.M20.G 2-1102600-5 0-1106408-2 0-1106408-3 EMV-K EMV-K.3/4.ST0.1.11.G 4-1102700-5 EMV-K.3/4.ST0.1.M16.G EMV-K.3/4.ST0.1.M20.G 0-1106402-2 0-1106402-3 HIP HIP.3/4.AG 1-1102603-5 HIP-K HIP-K.3/4.AG 2-1102603-5 EMV-K EMV-K.3/4.AG 4-1102703-5 HIP HIP.3/4.SGF 1-1102602-5 HIP-K HIP-K.3/4.SGF 2-1102602-5 EMV-K EMV-K.3/4.SGF 4-1102702-5 Hood: Top entry M16 11 M16 M20 11 M16 M20 Surface mounted housing: Bottom entry M3x8 22 4 22 32 4,3 41 51 Panel cut-out 21 x 21 ø21 M4 Surface mounted housing: Bottom22entry (by panel cut-out) 51 41 41 4 31 M3x8 38 48 4,3 Panel cut-out ø 20 41 M4 ø20 38 35 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.3/4, HIP-K.3/4, EMV-K.3/4 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood IP 68 / IP 69 K Description Metr. PG Type Part Number HIP HIP.3/4.SG.1.11.G HIP.3/4.SG.1.M16.G HIP.3/4.SG.1.M20.G 1-1102601-5 0-1106407-1 0-1106401-4 HIP-K HIP-K.3/4.SG.1.11.G HIP-K.3/4.SG.1.M16.G 2-1102601-5 0-1106407-2 EMV-K EMV-K.3/4.SG.1.11.G EMV-K.3/4.SG.1.M16.G EMV-K.3/4.SG.1.M20.G 4-1102701-5 0-1106401-2 0-1106401-3 HIP/EMV HIP/EMV.3/4.SKB 3-1106200-5 HIP-K/EMV-K HIP-K/EMV-K.3/4.SKB 4-1106200-5 Surface mounted housing: Side entry PG11 M16 M20 PG11 M16 PG11 M16 M20 Protective covers for housings M4x22 14 51 32 36 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HA.10 contact inserts SCREW TERMINAL, SPRING CLAMP TERMINAL, CRIMP TERMINAL FOR SCREW MACHINED HE/HA CRIMP CONTACTS 250V 16A 10+  Description Type Male insert Part Number Female insert Male insert Female insert Screw terminal HA-010-M T2010102101-000 HA-010-F T2010102201-000 Spring Clamp terminal HA.10.Sti.SC.B 1-10 7-1103414-1 HA.10.Bu.SC.B 1-10 7-1103415-1 Crimp terminal HA.10.Sti.C.B 1-10 2-1103414-3 E 49.5 57 23 31 28 28 D 28 C 9.5 B 16.5 mm A 31 Dimensions 2-1103415-3 9.5 HA.10.Bu.C.B 1-10 49.5 56.5 16 22.8 Suitable crimp contacts and crimping tools: see page 48 Contact arrangement 56.5 Male insert 22.8 6 7 8 9 10 Panel cut-out Female insert C M3 10 1 2 3 4 5 D M3x10 3 1 2 3 4 5 6 7 8 9 10 *22,3 43.5 6 7 8 9 10 B Sti 16 24 Dimensions (mm) 16 22.8 49.5 56.5 1 2 3 4 5 16 49.5 49.5 E Bu 16 A *Abstand für sichere Kontaktgabe max. 24 mm M3 M3 10 D M3x10 Bu E A *Abstand für sichere Kontaktgabe max. 21 mm 27 3 43.5 3 16 24 Sti *19,5 43.5 C 16 10 24 B 1-1103415-1 All specifications subject to change. Consult TE Connectivity for latest design specifications. 49.5 Contact TE for assistance with any part number configuration. 49.5 37 H10A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H10A-TS-PG16 H10A-TS-PG21 H10A-TS-M20 H10A-TS-M25 T1319100116-000 T1319100121-000 T1319100120-000 T1319100125-000 PG16 PG21 H10A-TG-PG16 H10A-TG-PG21 H10A-TG-M20 H10A-TG-M25 T1329100116-000 T1329100121-000 T1329100120-000 T1329100125-000 H10A-KDT T1019101101-000 T1019101201-000 H10A-AGS H10A-ADMS T1509101000-000 T1519101000-000 H10A-ADMS T1519101000-000 H10A-SGRS-PG16 H10A-SGRS-PG21 H10A-SGRS-M20 H10A-SGRS-M25 H10A-SGRS-2PG16 H10A-SGRS-2PG21 H10A-SGRS-2M20 H10A-SGRS-2M25 T1619101116-000 T1619101121-000 T1619101120-000 T1619101125-000 T1619101216-000 T1619101221-000 T1619101220-000 T1619101225-000 H10A-SDRMS-PG16 H10A-SDRMS-PG21 H10A-SDRMS-M20 H10A-SDRMS-M25 H10A-SDRMS-2PG16 H10A-SDRMS-2PG21 H10A-SDRMS-2M20 H10A-SDRMS-2M25 T1629101116-000 T1629101121-000 T1629101120-000 T1629101125-000 T1629101216-000 T1629101221-000 T1629101220-000 T1629101225-000 H10A-TBFS-PG16 H10A-TBFS-M20 H10A-TBFS-M25 H10A-TBFHS-PG21 H10A-TBFHS-M25 T1739101116-000 T1739101120-000 T1739101125-000 T1779101121-000 T1779101125-000 Hood: Side entry M20 M25 Hood: Top entry M20 M25 Protection covers for hoods With plastic rope Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry 2 Side entry 1 Side entry With protection cover M20 M25 M20 M25 M20 M25 2 Side entry M20 M25 PG16 PG21 PG16 PG21 PG16 PG21 PG16 PG21 Cable-to-cable hood H Low 52.6 Hight 66.6 38 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Low construction High construction Construction M20 M25 M25 PG16 PG21 HA.16 contact inserts 250V 16A SCREW TERMINAL, SPRING CLAMP TERMINAL, CRIMP TERMINAL FOR SCREW MACHINED HE/HA CRIMP CONTACTS 16+ Description Type Male insert Part Number Female insert Male insert Female insert Screw terminal HA-016-M T2010162101-000 HA-016-F T2010162201-000 Spring Clamp terminal HA.16.Sti.SC.B 1-16 7-1103416-1 HA.16.Bu.SC.B 1-16 7-1103417-1 Crimp terminal HA-016-MC T2010164101-000 HA-016-FC T2010164201-000 B C mm 66 73 23 31 M3x10.5 16.5 31 28 28 A 16 22.8 66 73 28 9.5 Dimensions 9.5 M3x10.5 D M3x10.5E 16 66 73 Contact arrangement Male insert 1 2 3 4 5 6 7 8 Dimensions (mm) 16 22.8 Panel cut-out 66 73 22.8 9 10 11 12 13 14 15 16 Suitable crimp contacts and crimping tools: see page 48 Female insert C M3 D 9 10 11 12 13 14 15 16 10 1 2 3 4 5 6 7 8 M3x10 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 *22,3 60 3 16 24 B Sti 66 E Bu 16 A *Abstand für sichere Kontaktgabe max. 24 mm M3 60 D 3 M3 60 Bu E A *Abstand für sichere Kontaktgabe max. 21 mm 27 66 10 M3x10 *19,5 3 16 24 Sti 10 C 16 24 B 2-1103417-3 66 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 39 H16A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H16A-TS-PG16 H16A-TS-PG21 H16A-TS-M20 H16A-TS-M25 T1319160116-000 T1319160121-000 T1319160120-000 T1319160125-000 PG21 H16A-TSH-PG21 H16A-TSH-M25 T1339160121-000 T1339160125-000 PG16 PG21 H16A-TG-PG16 H16A-TG-PG21 H16A-TG-M20 H16A-TG-M25 T1329160116-000 T1329160121-000 T1329160120-000 T1329160125-000 PG21 H16A-TGH-PG21 H16A-TGH-M25 T1349160121-000 T1349160125-000 H16A-KDT T1019161101-000 T1019161201-000 H16A-AGS T1509161000-000 H16A-ADS H16A-ADMS T1519162000-000 T1519161000-000 H16A-SGRS-PG16 H16A-SGRS-PG21 H16A-SGRS-M20 H16A-SGRS-M25 H16A-SGRS-2PG16 H16A-SGRS-2PG21 H16A-SGRS-2M20 H16A-SGRS-2M25 T1619161116-000 T1619161121-000 T1619161120-000 T1619161125-000 T1619161216-000 T1619161221-000 T1619161220-000 T1619161225-000 H16A-SDRMS-PG16 H16A-SDRMS-PG21 H16A-SDRMS-M20 H16A-SDRMS-M25 H16A-SDRMS-2PG16 H16A-SDRMS-2PG21 H16A-SDRMS-2M20 H16A-SDRMS-2M25 T1629161116-000 T1629161121-000 T1629161120-000 T1629161125-000 T1629161216-000 T1629161221-000 T1629161220-000 T1629161225-000 H16A-TBFS-PG16 H16A-TBFS-M20 H16A-TBFS-M25 H16A-TBFHS-PG21 H16A-TBFHS-M25 T1739161116-000 T1739161120-000 T1739161125-000 T1779161121-000 T1779161125-000 Hood: Side entry High construction Low construction Low construction High construction M20 M25 M25 Hood: Top entry High construction Low construction Low construction High construction M20 M25 M25 Protection covers for hoods with plastic rope Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry 2 Side entry With protection cover M20 M25 M20 M25 1 Side entry M20 M25 2 Side entry M20 M25 PG16 PG21 PG16 PG21 PG16 PG21 PG16 PG21 Cable-to-cable hood H Low 66.6 Hight 80.6 40 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Low construction High construction Construction M20 M25 M25 PG16 PG21 HA.32 contact inserts SCREW TERMINAL, SPRING CLAMP TERMINAL, CRIMP TERMINAL FOR SCREW MACHINED HE/HA CRIMP CONTACT 250V 16A (2x16) 32+ Description Type Male insert Part Number Female insert Male insert Female insert Screw terminal HA-016-M(1-16) HA-016-M(17-32) T2010162101-000 T2010322101-000 HA-016-F(1-16) HA-016-F(17-32) T2010162201-000 T2010322201-000 Spring Clamp terminal HA.16.Sti.SC.B 1-16 HA.16.Sti.SC.B 17-32 7-1103416-1 7-1103416-7 HA.16.Bu.SC.B 1-16 HA.16.Bu.SC.B 17-32 7-1103417-1 7-1103417-7 Crimp terminal HA-016-MC(1-16) HA-016-MC(17-32) T2010164101-000 T2010324101-000 HA-016-FC(1-16) HA-016-FC(17-32) Dimensions A B C D E mm 66 73 23 31 28 T2010164201-000 T2010324201-000 M3x10.5 28 Suitable crimp contacts and crimping tools: see page 48 16 66 Dimensions (mm) 9.5 16.5 31 M3x10.5 73 Contact arrangement 22.8 Male insert 66 73 16 22.8 Female insert 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 C B Sti 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 D 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 M3x10 *22,3 E 25 26 27 28 29 30 31 32 16 A 17 18 19 20 21 22 23 24 Bu *Abstand für sichere Kontaktgabe max. 24 mm M3 60 Sti D M3x10 *19,5 Bu E A *Abstand für sichere Kontaktgabe max. 21 mm 27 10 C 3 16 24 B 41 66 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H32A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 PG36 H32A-TS-PG21 H32A-TS-PG29 H32A-TS-PG36 H32A-TS-M25 H32A-TS-M32 H32A-TS-M40 T1319320121-000 T1319320129-000 T1319320136-000 T1319320125-000 T1319320132-000 T1319320140-000 PG21 PG29 PG36 H32A-TG-PG21 H32A-TG-PG29 H32A-TG-PG36 H32A-TG-M25 H32A-TG-M32 H32A-TG-M40 T1329320121-000 T1329320129-000 T1329320136-000 T1329320125-000 T1329320132-000 T1329320140-000 H32A-AG T1419320000-000 H32A-SGR-PG21 H32A-SGR-PG29 H32A-SGR-M25 H32A-SGR-M32 H32A-SGR-2PG21 H32A-SGR-2PG29 H32A-SGR-2M25 H32A-SGR-2M32 T1449320121-000 T1449320129-000 T1449320125-000 T1449320132-000 T1449320221-000 T1449320229-000 T1449320225-000 T1449320232-000 Hood: Side entry M25 M32 M40 Hood: Top entry M25 M32 M40 Bulkhead mounted Surface mounted: Side entry 1 Side entry PG21 PG29 M25 M32 2 Side entry 42 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS PG21 PG29 M25 M32 HA.48 contact inserts 250V 16A SCREW TERMINAL, SPRING CLAMP TERMINAL, CRIMP TERMINAL FOR SCREW MACHINED HE/HA CRIMP CONTACT (3x16) 48+ Description Type Male insert Part Number Female insert Male insert Female insert Screw terminal HA.16.Sti.S.B 1-16 HA.16.Sti.S.B 17-32 HA.16.Sti.S.B 33-48 1-1103416-1 1-1103416-7 1-1103416-8 HA.16.Bu.S.B 1-16 HA.16.Bu.S.B 17-32 HA.16.Bu.S.B 33-48 1-1103417-1 1-1103417-7 1-1103417-8 Spring Clamp terminal HA.16.Sti.SC.B 1-16 HA.16.Sti.SC.B 17-32 HA.16.Sti.SC.B 33-48 7-1103416-1 7-1103416-7 7-1103416-8 HA.16.Bu.SC.B 1-16 HA.16.Bu.SC.B 17-32 HA.16.Bu.SC.B 33-48 7-1103417-1 7-1103417-7 7-1103417-8 Crimp terminal HA.16.Sti.C.B 1-16 HA.16.Sti.C.B 17-32 HA.16.Sti.C.B 33-48 2-1103416-3 2-1103416-7 2-1103416-8 HA.16.Bu.C.B 1-16 HA.16.Bu.C.B 17-32 HA.16.Bu.C.B 33-48 Dimensions mm A B C D E 77.5 83.5 33 34 35 2-1103417-3 2-1103417-7 2-1103417-8 C B Sti D Suitable crimp contacts and crimping tools: see page 48 M3x10 *22,3 E Bu Dimensions (mm) A Contact arrangement 16 *Abstand für sichere Kontaktgabe max. 24 mm B Male insert Female insert C Sti Bu 1 2 3 4 5 6 7 8 17 18 19 20 21 22 23 24 33 34 35 36 37 38 39 40 9 10 11 12 13 14 15 16 25 26 27 28 29 30 31 32 41 42 43 44 45 46 47 48 25 26 27 28 29 30 31 32 41 42 43 44 45 46 47 48 1 2 3 4 5 6 7 8 17 18 19 20 21 22 23 24 33 34 35 36 37 38 39 40 *19,5 9 10 11 12 13 14 15 16 D M3x10 E A 27 *Abstand für sichere Kontaktgabe max. 21 mm 43 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HA.48 housings POWDER-COATED, SILVER-GREY IP 65 Side clip at housing bottom Description Metr. PG Type Part Number 29 HA.48.STS-GR.1.29.G HA.48.STS-GR.1.M32.G 1-1102172-7 0-1102877-1 29 HA.48.STO-GR.1.29.G HA.48.STO-GR.1.M32.G 1-1102175-7 0-1102877-2 HA.48.AG-LB 1-1102176-2 HA.48.AGD-LB 1-1102177-2 Hood: Side entry, Standard construction M32 Hood: Top entry, Standard construction M/PG 79 M32 95 82.5 Surface mounted housing: Bottom entry 110 124 Ø 5.5 82 M5 71 65 1 5 34,5 1-1102175-7 65 84 33 Panel cut-out 110 Surface mounted housing with covers: Bottom entry 110 124 ø5.5 110 82 M5 65 71 1 5 34,5 1-1102176-2 65 84 33 Panel cut-out 1-1102177-2 44 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HA.48 housings POWDER-COATED, SILVER-GREY IP 65 Side clip at housing bottom Description Metr. PG Type Part Number 29 2x29 HA.48.SG-LB.1.29.Z HA.48.SG-LB.2.29.Z 1-1102179-2 1-1102181-2 29 2x29 HA.48.SGD-LB.1.29.Z HA.48.SGD-LB.2.29.Z HA.48.SGD-LB.1.M32.G HA.48.SGD-LB.2.M32.G 1-1102183-2 1-1102185-2 0-1102879-1 0-1102879-2 Surface mounted housing: Side entry, Standard construction 78,5 M/PG 4 112 126 ø5.5 67 82.5 33 Surface mounted housing: Side entry, Standard construction 1-1102181-2 112 ø5.5 126 4 78,5 M/PG 22 67 82.5 33 M32 2xM32 1-1102185-2 45 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HA.64 contact inserts SCREW TERMINAL, SPRING CLAMP TERMINAL, CRIMP TERMINAL FOR SCREW MACHINED HE CRIMP CONTACTS 250V 16A (4x16) 64+ Description Type Male insert Part Number Female insert Male insert Female insert Screw terminal HA.16.Sti.S.B HA.16.Sti.S.B HA.16.Sti.S.B HA.16.Sti.S.B 1-16 17-32 33-48 49-64 HA.16.Bu.S.B HA.16.Bu.S.B HA.16.Bu.S.B HA.16.Bu.S.B 1-16 17-32 33-48 49-64 1-1103416-1 1-1103416-7 1-1103416-8 1-1103416-9 1-1103417-1 1-1103417-7 1-1103417-8 1-1103417-9 Spring Clamp terminal HA.16.Sti.SC.B HA.16.Sti.SC.B HA.16.Sti.SC.B HA.16.Sti.SC.B 1-16 17-32 33-48 49-64 HA.16.Bu.SC.B HA.16.Bu.SC.B HA.16.Bu.SC.B HA.16.Bu.SC.B 1-16 17-32 33-48 49-64 7-1103416-1 7-1103416-7 7-1103416-8 7-1103416-9 7-1103417-1 7-1103417-7 7-1103417-8 7-1103417-9 Crimp terminal C 77.5 D 83.5 33 M3x10.5 M3x10.5 34 35 M3x10 *22,3 Suitable crimp contacts and crimping tools: see page 48 M3x10.5 E 16 16 22.8 22.8 99 1010 1111 1212 1313 1414 1515 1616 99 10 10 11 11 12 12 13 13 14 14 15 15 16 16 57 57 58 58 59 59 60 60 61 61 62 62 63 63 64 64 49 49 50 50 51 51 52 52 53 53 54 54 55 55 56 56 57 57 58 58 59 59 60 60 61 61 62 62 63 63 64 64 60 60 66 66 49 49 50 50 51 51 52 52 53 53 54 54 55 55 56 56 3 3 1616 2424 1010 49 49 50 50 51 51 52 52 53 53 54 54 55 55 56 56 33 33 34 34 35 35 36 36 37 37 38 38 39 39 40 40 M3 M3 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 57 57 58 58 59 59 60 60 61 61 62 62 63 63 64 64 25 25 26 26 27 27 28 28 29 29 30 30 31 31 32 32 41 41 42 42 43 43 44 44 45 45 46 46 47 47 48 48 25 25 26 26 27 27 28 28 29 29 30 30 31 31 32 32 33 33 34 34 35 35 36 36 37 37 38 38 39 39 40 40 41 41 42 42 43 43 44 44 45 45 46 46 47 47 48 48 *Abstand für sichere Kontaktgabe max. 21 mm 27 5757 5858 5959 6060 6161 6262 6363 6464 E A 17 17 18 18 19 19 20 20 21 21 22 22 23 23 24 24 17 17 18 18 19 19 20 20 21 21 22 22 23 23 24 24 *19,5 4949 5050 5151 5252 5353 5454 5555 5656 M3x10 Bu 46 17 17 18 18 19 19 20 20 21 21 22 22 23 23 24 24 4141 4242 4343 4444 4545 4646 4747 4848 D 41 41 42 42 43 43 44 44 45 45 46 46 47 47 48 48 11 22 33 44 55 66 77 88 3333 3434 3535 3636 3737 3838 3939 4040 C Sti Female insert 16 22.8 33 33 34 34 35 35 36 36 37 37 38 38 39 39 40 40 B 2525 2626 2727 2828 2929 3030 3131 3232 Male insert 66 73 99 10 10 11 11 12 12 13 13 14 14 15 15 16 16 66 66 Contact arrangement 73 73 16 1717 1818 1919 2020 2121 2222 2323 2424 A Dimensions (mm) *Abstand für sichere Kontaktgabe max. 24 mm 11 22 33 44 55 66 77 88 Bu M3x10.5 M3x10.5 66 66 73 73 11 22 33 44 5 5 16.5 16.5 66 31 31 77 88 mm Sti 16 16 22.8 22.8 66 E 66 73 73 D C B 2-1103417-3 2-1103417-7 2-1103417-8 2-1103417-9 M3x10.5 M3x10.5 16.5 16.5 3131 1-16 17-32 33-48 49-64 99 10 10 11 11 12 12 13 13 9.5 9.5 14 14 28 15 1528 16 16 B HA.16.Bu.C.B HA.16.Bu.C.B HA.16.Bu.C.B HA.16.Bu.C.B 2-1103416-3 2-1103416-7 2-1103416-8 2-1103416-9 11 22 33 44 55 66 77 88 A 1-16 17-32 33-48 49-64 25 25 26 26 27 27 28 28 29 29 30 30 31 31 32 32 Dimensions HA.16.Sti.C.B HA.16.Sti.C.B HA.16.Sti.C.B HA.16.Sti.C.B 16 16 22.8 22.8 HA.64 housings POWDER-COATED, SILVER-GREY IP 65 Side clip at housing bottom Description Metr. PG Type Part Number 29 36 42 HA.64.STS-GR.1.29.G HA.64.STS-GR.1.36.G HA.64.STS-GR.1.42.G HA.64.STS-GR.1.M50.G 1-1102002-7 1-1102005-7 1-1102008-7 0-1106480-2 29 36 42 HA.64.STO-GR.1.29.G HA.64.STO-GR.1.36.G HA.64.STO-GR.1.42.G HA.64.STO-GR.1.M50.G 1-1102027-7 1-1102030-7 1-1102033-7 0-1106480-1 HA.64.AGD-LB 1-1102009-2 HA.64.SGD-LB.1.29.Z HA.64.SGD-LB.2.29.Z HA.64.SGD-LB.1.36.Z HA.64.SGD-LB.2.36.Z HA.64.SGD-LB.2.M40.Z 1-1102011-2 1-1102013-2 1-1102015-2 1-1102017-2 0-1106479-1 Hood: Side entry, Standard construction M50 Hood: Top entry, Standard construction M50 148 165 ø6.5 37 11.5 Surface mounted housing: Bottom entry, Standard construction 25 70 90 43.5 81 70 M6 Panel cut-out 117 148 Surface mounted housing: Side entry, Standard construction 29 2x29 36 2x36 1-1102009-2 2xM40 47 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Crimp contacts HN.D series 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 0.5 0.75 1.0 1.5 2.5 Crimping tools HN.D series Description Type Part Number CRIMPBOX-0.5/4 T3100000001-000 RSZ.HE-HN.D-HVT 1-1105851-8 REMOV-HD T3100000003-000 SCREWD-M3 T3100000009-000 Crimp tool Wire range: 0.5-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts Crimp tool Wire range: 0.14-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts with locator and die Removal tools Used for CDM/CDF contact series M3 screw driver Used for HA/HE inserts 48 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Crimp contacts HE/HA series 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Crimping tools HE/HA series Description Type Part Number CRIMPBOX-0.5/4 T3100000001-000 RSZ.HE-HN.D-HVT 1-1105851-8 REMOV-HEE T3100000002-000 SCREWD-M3 T3100000009-000 Crimp tool Wire range: 0.5-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts Crimp tool Wire range: 0.14-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts with locator and die Removal tools Used for CEM/CEF contact series M3 screw driver Used for HA/HE inserts 49 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Notes 50 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HD, HDD Series 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 175 301-801 DIN EN 61984 3. Approvals 51 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD technical characteristics CURRENT CARRYING CAPACITY Specifications .................................................................... DIN VDE 0627 ...................................................................................................DIN VDE 0110 Standards ...................................................................................DIN 43 652 ............................................................................................ CECC 75 301-801 Number of contacts.....................................7,8,15,25,40,50(2x25),64, ............................................................................80(2x40),128(2x64) + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 10A max (See current carrying capacity) Working voltage ..................................................................... (8D is 50V) .............................................................................250V, Insulation group C Test voltage urms ......................................................4KV(8D is 0.8KV) Pollution degree .......................................................................................... 2 Insulation resistance ........................................................................ ≥1010Ω Material ............................................... Polycarbonate or Polybutylece Temperature range............................................ -40°C... +100°C/125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA.................................................. 600V Mechanical working life-mating cycles........................................ ≥500 CONTACTS Working current INSERTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance .............................................................................≤3mΩ Terminal .............................................................................. Crimp terminal ................................................................................................ Rolled terminal - mm2 ......................................................................................... 0.15-2.5mm2 - AWG ......................................................................................................26-14 Ambient temperature Wire gauge: 0.75 mm2 Ambient temperature Wire gauge: 1.50 mm2 Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 Working current HOODS/HOUSINGS 1 HD-007 2 HD-015 3 HD-025 4 HD-040 5 HD-064 52 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HDD technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts............................................16,24,42,72,84(2x42), ................................................................................................ 144(2x72) + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 10A max (See current carrying capacity) Working voltage ...........................................250V, Insulation group C Test voltage urms ..............................................................................2.5KV Pollution degree .......................................................................................... 2 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range............................................ -40°C... +100°C/125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA.................................................. 500V Mechanical working life-mating cycles........................................ ≥500 CONTACTS Working current INSERTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance .............................................................................≤3mΩ Terminal .............................................................................. Crimp terminal ................................................................................................ Rolled terminal - mm2 ......................................................................................... 0.14-2.5mm2 - AWG ......................................................................................................26-14 Ambient temperature Wire gauge: 0.75 mm2 Ambient temperature Wire gauge: 1.50 mm2 Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 Working current HOODS/HOUSINGS 1 HDD-024 2 HDD-042 3 HDD-072 4 HDD-108 53 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD, HDD series MODIFIED CONTACT ARRANGEMENT The connector series HDD and HD equipped with all contacts may be used for voltages up to 250V~insulation group C. A modified contact loading arrangement permits use up to 500V~also in insulation group C. Contact arrangement view from termination side Working contact Series HDD 380V~Insulation group C 500V~Insulation group C Series HD 500V ~ Pollution degree 3 54 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Without contact Male insert Female insert HD-007/008 inserts INSERTS FOR H3A HOOD/HOUSING 250V/50V 10A 7+  8 Dimensions (mm) Contact arrangement view from termination side Part Number Male insert Type Female insert 250V/10A T2020072101-000 HD-007-M T2020072201-000 HD-007-F 50V/10A T2020082101-000 HD-008-M T2020082201-000 HD-008-F 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 55 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H3A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG11 H3A-MTG-PG11 T1329030111-000 H3A-MTG-M20 T1329030120-000 H3A-MTS-PG11 T1319030111-000 H3A-MTS-M20 T1319030120-000 H3A-MAG T1509030000-000 H3A-MAGS T1549030000-000 H3A-MAGSV-PG11 T1619030111-000 M16 H3A-MAGSV-M16 T1619030116-000 M20 H3A-MAGSV-M20 T1619030120-000 H3A-MTGVB-PG11 T1739030111-000 H3A-MTGVB-M20 T1739030120-000 H3A-KDTP T1010031100-000 H3A-KDB T1010033100-000 Top entry M20 Side entry PG11 M20 Bulkhead mounting: Bottom entry Bulkhead mounting: Side entry Surface mounting: Side entry PG11 Cable-to-cable hood: PG11 M20 Protection covers for hoods (thermoplastic) Note: For mounted male insert and hood Metal protection covers for hoods Note: For mounted female insert and hood 56 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H3A thermoplastic hoods/housings THERMOPLASTIC HOODS, HOUSINGS Dimensions (mm) Metr. PG Type Part Number PG11 H3A-TG-PG11 H3A-TG-M20 T1329031111-000 T1329031120-000 PG11 H3A-TS-PG11 H3A-TS-M20 T1319031111-000 T1319031120-000 H3A-AG T1509031100-000 H3A-AGS T1509031111-000 PG11 H3A-AGSV-PG11 H3A-AGSV-M16 H3A-AGSV-M20 T1619031111-000 T1619031116-000 T1619031120-000 PG11 H3A-TGVB-PG11 H3A-TGVB-M20 T1739031111-000 T1739031120-000 H3A-KDTP T1010031100-000 H3A-KDBP (White) H3A-KDBPG (Grey) T1010032100-000 T1010032300-000 H3A-KDBP (White) H3A-KDBP (Grey) T1010033200-000 T1010032200-000 Top entry M20 Side entry M20 Bulkhead mounting: Bottom entry Bulkhead mounting: Side entry Surface mounting: Side entry M16 M20 Cable-to-cable hood: M20 Protection covers for hoods (thermoplastic) Note: For mounted male insert and hood Protection covers for hoods Note: For mounted female insert and hood White Grey Covers without sealing type 57 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.3/4, HIP-K.3/4, EMV-K.3/4 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood IP 68 / IP 69 K Description Metr. PG Type Part Number 11 HIP HIP.3/4.ST0.1.11.G HIP.3/4.ST0.1.M16.G 1-1102600-5 0-1106408-1 HIP-K HIP-K.3/4.ST0.1.11.G HIP-K.3/4.ST0.1.M16.G HIP-K.3/4.ST0.1.M20.G 2-1102600-5 0-1106408-2 0-1106408-3 EMV-K EMV-K.3/4.ST0.1.11.G 4-1102700-5 EMV-K.3/4.ST0.1.M16.G EMV-K.3/4.ST0.1.M20.G 0-1106402-2 0-1106402-3 HIP HIP.3/4.AG 1-1102603-5 HIP-K HIP-K.3/4.AG 2-1102603-5 EMV-K EMV-K.3/4.AG 4-1102703-5 HIP HIP.3/4.SGF 1-1102602-5 HIP-K HIP-K.3/4.SGF 2-1102602-5 EMV-K EMV-K.3/4.SGF 4-1102702-5 Hood: Top entry M16 11 M16 M20 11 M16 M20 Surface mounted housing: Bottom entry M3x8 22 4 22 32 4,3 41 51 Panel cut-out 21 x 21 ø21 M4 Surface mounted housing: Bottom22entry (by panel cut-out) 51 41 41 4 31 M3x8 38 48 4,3 Panel cut-out ø 20 41 M4 ø20 38 58 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP.3/4, HIP-K.3/4, EMV-K.3/4 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood IP 68 / IP 69 K Description Metr. PG Type Part Number HIP HIP.3/4.SG.1.11.G HIP.3/4.SG.1.M16.G HIP.3/4.SG.1.M20.G 1-1102601-5 0-1106407-1 0-1106401-4 HIP-K HIP-K.3/4.SG.1.11.G HIP-K.3/4.SG.1.M16.G 2-1102601-5 0-1106407-2 EMV-K EMV-K.3/4.SG.1.11.G EMV-K.3/4.SG.1.M16.G EMV-K.3/4.SG.1.M20.G 4-1102701-5 0-1106401-2 0-1106401-3 HIP/EMV HIP/EMV.3/4.SKB 3-1106200-5 HIP-K/EMV-K HIP-K/EMV-K.3/4.SKB 4-1106200-5 Surface mounted housing: Side entry PG11 M16 M20 PG11 M16 PG11 M16 M20 Protective covers for housings M4x22 14 51 32 59 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD-015 inserts INSERTS FOR H10A HOOD/HOUSING 15+  250V 10A (machined contacts) Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HD-015-M T2020152101-000 HD-015-F Contact arrangement view from termination side T2020152201-000 Panel cut out for inserts for use without hoods/housings 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 60 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HD-015 inserts INSERTS FOR H10A HOOD/HOUSING 15+ 250V 10A (stamped and formed contacts) Description Type Male insert Part Number Female insert Male insert Female insert Crimp terminal HD.15.Sti.C 2-1103004-3 HD.15.Bu.C Dimensions mm 2-1103005-3 A B C D E 49.5 57 23 35 35 M3x10 M3x10 Suitable crimp contacts and crimping tools: see page 111 56.5 16 56.5 23 16 Panel cut-out 23 1 2 3 4 5 Male insert 16 49.5 56.5 23 Female insert 49.5 1 2 3 4 5 Contact arrangement C B A 49.5 Dimensions (mm) 35 35 35 M3x10 C E 10 49.5 3 16 24 1 2 3 4 5 1 2 3 4 5 M3x10 *22,3 M3 A B C C B A 1 2 3 4 5 D 1 2 3 4 5 B Sti 43.5 Bu 16 A *Abstand für sichere Kontaktgabe max. 24 mm B M3 C Sti 49.5 M3 49.5 D Bu 3 16 24 3 16 24 10 10 M3x10 *19,5 E A *Abstand für sichere Kontaktgabe max. 21 mm 27 43.5 43.5 2-1103005-3 61 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H10A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H10A-TS-PG16 H10A-TS-PG21 H10A-TS-M20 H10A-TS-M25 T1319100116-000 T1319100121-000 T1319100120-000 T1319100125-000 PG16 PG21 H10A-TG-PG16 H10A-TG-PG21 H10A-TG-M20 H10A-TG-M25 T1329100116-000 T1329100121-000 T1329100120-000 T1329100125-000 H10A-KDT T1019101101-000 T1019101201-000 H10A-AGS H10A-ADMS T1509101000-000 T1519101000-000 H10A-ADMS T1519101000-000 H10A-SGRS-PG16 H10A-SGRS-PG21 H10A-SGRS-M20 H10A-SGRS-M25 H10A-SGRS-2PG16 H10A-SGRS-2PG21 H10A-SGRS-2M20 H10A-SGRS-2M25 T1619101116-000 T1619101121-000 T1619101120-000 T1619101125-000 T1619101216-000 T1619101221-000 T1619101220-000 T1619101225-000 H10A-SDRMS-PG16 H10A-SDRMS-PG21 H10A-SDRMS-M20 H10A-SDRMS-M25 H10A-SDRMS-2PG16 H10A-SDRMS-2PG21 H10A-SDRMS-2M20 H10A-SDRMS-2M25 T1629101116-000 T1629101121-000 T1629101120-000 T1629101125-000 T1629101216-000 T1629101221-000 T1629101220-000 T1629101225-000 H10A-TBFS-PG16 H10A-TBFS-M20 H10A-TBFS-M25 H10A-TBFHS-PG21 H10A-TBFHS-M25 T1739101116-000 T1739101120-000 T1739101125-000 T1779101121-000 T1779101125-000 Hood: Side entry M20 M25 Hood: Top entry M20 M25 Protection covers for hoods With plastic rope Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry 2 Side entry 1 Side entry With protection cover M20 M25 M20 M25 M20 M25 2 Side entry M20 M25 PG16 PG21 PG16 PG21 PG16 PG21 PG16 PG21 Cable-to-cable hood H Low 52.6 Hight 66.6 62 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Low construction High construction Construction M20 M25 M25 PG16 PG21 HD-025 inserts INSERTS FOR H16A HOOD/HOUSING 25+  250V 10A (machined contacts)   Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HD-025-M T2020252101-000 HD-025-F Contact arrangement view from termination side T2020252201-000 Panel cut out for inserts for use without hoods/housings 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 63 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD-025 inserts INSERTS FOR H16A HOOD/HOUSING 25+  250V 10A (stamped and formed contacts) Description Type Male insert Part Number Female insert Male insert Female insert Crimp terminal (order crimp contacts separately) HD.25.Sti.C 2-1103010-3 HD.25.Bu.C 2-1103011-3 Dimensions A B C D E mm 66 73 23 35 35 M3x10 M3x10 35 M3x10 35 Suitable crimp contacts and crimping tools: see page 111 66 73 Contact arrangement Male insert 23 Panel cut-out Female insert C 10 A B C M3 E 60 Bu 16 A *Abstand für sichere Kontaktgabe max. 24 mm M3 B 66 M3 66 3 16 24 3 16 10 24 D 10 C Sti M3x10 *19,5 Bu E A 66 3 1 2 3 4 5 6 7 8 9 M3x10 1 2 3 4 5 6 7 8 9 C B A 1 1 2 2 3 3 4 4 5 5 6 6 7 7 8 8 9 9 D 16 24 B Sti *22,3 16 23 1673 C B A 1 1 2 2 3 3 4 4 5 5 6 6 7 7 8 8 9 9 Dimensions (mm) 66 66 73 16 23 35 60 60 27 *Abstand für sichere Kontaktgabe max. 21 mm 2-1103011-3 64 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H16A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H16A-TS-PG16 H16A-TS-PG21 H16A-TS-M20 H16A-TS-M25 T1319160116-000 T1319160121-000 T1319160120-000 T1319160125-000 PG21 H16A-TSH-PG21 H16A-TSH-M25 T1339160121-000 T1339160125-000 PG16 PG21 H16A-TG-PG16 H16A-TG-PG21 H16A-TG-M20 H16A-TG-M25 T1329160116-000 T1329160121-000 T1329160120-000 T1329160125-000 PG21 H16A-TGH-PG21 H16A-TGH-M25 T1349160121-000 T1349160125-000 H16A-KDT T1019161101-000 T1019161201-000 H16A-AGS T1509161000-000 H16A-ADS H16A-ADMS T1519162000-000 T1519161000-000 H16A-SGRS-PG16 H16A-SGRS-PG21 H16A-SGRS-M20 H16A-SGRS-M25 H16A-SGRS-2PG16 H16A-SGRS-2PG21 H16A-SGRS-2M20 H16A-SGRS-2M25 T1619161116-000 T1619161121-000 T1619161120-000 T1619161125-000 T1619161216-000 T1619161221-000 T1619161220-000 T1619161225-000 H16A-SDRMS-PG16 H16A-SDRMS-PG21 H16A-SDRMS-M20 H16A-SDRMS-M25 H16A-SDRMS-2PG16 H16A-SDRMS-2PG21 H16A-SDRMS-2M20 H16A-SDRMS-2M25 T1629161116-000 T1629161121-000 T1629161120-000 T1629161125-000 T1629161216-000 T1629161221-000 T1629161220-000 T1629161225-000 H16A-TBFS-PG16 H16A-TBFS-M20 H16A-TBFS-M25 H16A-TBFHS-PG21 H16A-TBFHS-M25 T1739161116-000 T1739161120-000 T1739161125-000 T1779161121-000 T1779161125-000 Hood: Side entry High construction Low construction Low construction High construction M20 M25 M25 Hood: Top entry High construction Low construction Low construction High construction M20 M25 M25 Protection covers for hoods with plastic rope Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry 2 Side entry With protection cover M20 M25 M20 M25 1 Side entry M20 M25 2 Side entry M20 M25 PG16 PG21 PG16 PG21 PG16 PG21 PG16 PG21 Cable-to-cable hood H Low 66.6 Hight 80.6 Low construction High construction Construction M20 M25 M25 PG16 PG21 65 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD-050 inserts INSERTS FOR H32A HOOD/HOUSING 50 (2x25)+  250V 10A (Turning contacts) Dimensions (mm) Contact arrangement view from termination side Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HD-025-M(1-25) HD-025-M(26-50) T2020252101-000 T2020502101-000 HD-025-F(1-25) HD-025-F(26-50) T2020252201-000 T2020502201-000 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 66 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HD-050 inserts INSERTS FOR H32A HOOD/HOUSING 50 (2x25)+  250V 10A (stamped and formed contacts) Description Type Male insert Part Number Female insert Male insert Female insert Crimp terminal HD.25.Sti.C 2-1103010-3 HD.25.Bu.C 2-1103011-3 Dimensions A B C D E mm 66 73 23 35 35 M3x10 M3x10 M3x10 M3x10 35 Dimensions (mm) Contact arrangement 66 1666 2373 Male insert73 35 Suitable crimp contacts and crimping tools: see page 111 35 66 16 1666 2373 73 Female23insert 1 2 C B Sti 1 2 3 4 5 6 7 8 9 1 2 3 4 5 6 7 8 9 A B C 1 2 3 4 5 6 7 8 9 A B C 1 2 3 4 5 6 7 8 9 M3x10 *22,3 C B A 1 1 2 2 3 3 4 4 5 5 6 6 7 7 8 8 9 9 C B A 1 1 2 2 3 3 4 4 5 5 6 6 7 7 8 8 9 9 D E Bu 16 66 3 M3 66 3 C Sti D 60 60 M3 60 66 3 16 24 3 M3 10 16 24 10 B 66 16 10 24 M3 10 16 24 A *Abstand für sichere Kontaktgabe max. 24 mm 60 M3x10 *19,5 Bu E 2-1103011-3 A 2-1103011-3 27 *Abstand für sichere Kontaktgabe max. 21 mm 67 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H32A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 PG36 H32A-TS-PG21 H32A-TS-PG29 H32A-TS-PG36 H32A-TS-M25 H32A-TS-M32 H32A-TS-M40 T1319320121-000 T1319320129-000 T1319320136-000 T1319320125-000 T1319320132-000 T1319320140-000 PG21 PG29 PG36 H32A-TG-PG21 H32A-TG-PG29 H32A-TG-PG36 H32A-TG-M25 H32A-TG-M32 H32A-TG-M40 T1329320121-000 T1329320129-000 T1329320136-000 T1329320125-000 T1329320132-000 T1329320140-000 H32A-AG T1419320000-000 H32A-SGR-PG21 H32A-SGR-PG29 H32A-SGR-M25 H32A-SGR-M32 H32A-SGR-2PG21 H32A-SGR-2PG29 H32A-SGR-2M25 H32A-SGR-2M32 T1449320121-000 T1449320129-000 T1449320125-000 T1449320132-000 T1449320221-000 T1449320229-000 T1449320225-000 T1449320232-000 Hood: Side entry M25 M32 M40 Hood: Top entry M25 M32 M40 Bulkhead mounted Surface mounted: Side entry 1 Side entry PG21 PG29 M25 M32 2 Side entry 68 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS PG21 PG29 M25 M32 HDD-016 inserts INSERTS FOR H6B HOOD/HOUSING 16+  250V 10A (machined contacts)   Dimensions (mm) Part Number Type Male insert Female insert Crimp terminal (order crimp contacts separately) HDD-016-M T2030162101-000 HDD-016-F Contact arrangement view from termination side T2030162201-000 Panel cut out for inserts for use without hoods/housings 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 69 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HDD-016 inserts INSERTS FOR H6B HOOD/HOUSING 16+ 250V 10A (stamped and formed contacts) Description Male insert Part Number Type Female insert Male insert Female insert Crimp terminal HD.16.Sti.C 2-1103006-3 HD.16.Bu.C 2-1103007-3 Dimensions A B C D E mm 44 51 33 35 35 27 33 Dimensions (mm) 35 Suitable crimp contacts and crimping tools: see page 111 35 44 51 D Contact arrangement 27A 1 2 33 44 Female27 insert Male insert44 33 51 51 M3 A B C D 1 2 34 D C B A 1 2 34 1 2 34 C Panel cut-out B 34 37 1 2 34 20 1 2 34 27 36 44 52 5 M3 36 35 14 27 M3 2-1103007-3 37 20 27 36 44 44 52 2-1103006-3 70 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2-1103007-3 H6B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H6B-TS-PG16 H6B-TS-PG21 H6B-TS-M20 H6B-TS-M25 T1310060116-000 T1310060121-000 T1310060120-000 T1310060125-000 PG21 PG29 H6B-TSH-PG21 H6B-TSH-PG29 H6B-TSH-M20 H6B-TSH-M25 H6B-TSH-M32 T1330060121-000 T1330060129-000 T1330060120-000 T1330060125-000 T1330060132-000 PG16 PG21 H6B-TG-PG16 H6B-TG-PG21 H6B-TG-M20 H6B-TG-M25 T1320060116-000 T1320060121-000 T1320060120-000 T1320060125-000 PG21 PG29 H6B-TGH-PG21 H6B-TGH-PG29 H6B-TGH-M20 H6B-TGH-M25 H6B-TGH-M32 T1340060121-000 T1340060129-000 T1340060120-000 T1340060125-000 T1340060132-000 PG16 H6B-TBFS-PG16 H6B-TBFS-M20 H6B-TBFS-M25 H6B-TBFHS-PG21 H6B-TBFHS-PG29 H6B-TBFHS-M20 H6B-TBFHS-M25 H6B-TBFHS-M32 T1730062116-000 T1730062120-000 T1730062125-000 T1770062121-000 T1770062129-000 T1770062120-000 T1770062125-000 T1770062132-000 H6B-KDTP T1010061400-000 Hood: Side entry Low construction M20 M25 High construction M20 M25 M32 Hood: Top entry Low construction M20 M25 High construction M20 M25 M32 Cable-to-cable hood Low construction Construction M20 M25 H 62.5 Hight 74.5 High construction Low M20 M25 M32 PG21 PG29 Protection covers for hoods 71 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H6B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H6B-AGS T1500062000-000 H6B-ADS T1510062100-000 H6B-SGRS-PG16 H6B-SGRS-PG21 H6B-SGRS-M20 H6B-SGRS-M25 H6B-SGRS-2PG16 H6B-SGRS-2PG21 H6B-SGRS-2M20 H6B-SGRS-2M25 H6B-SGRHS-PG21 H6B-SGRHS-PG29 H6B-SGRHS-M25 H6B-SGRHS-M32 H6B-SGRHS-2PG21 H6B-SGRHS-2PG29 H6B-SGRHS-2M25 H6B-SGRHS-2M32 T1610062116-000 T1610062121-000 T1610062120-000 T1610062125-000 T1610062216-000 T1610062221-000 T1610062220-000 T1610062225-000 T1650062121-000 T1650062129-000 T1650062125-000 T1650062132-000 T1650062221-000 T1650062229-000 T1650062225-000 T1650062232-000 H6B-SDRS-PG16 H6B-SDRS-PG21 H6B-SDRS-M20 H6B-SDRS-M25 H6B-SDRS-2PG16 H6B-SDRS-2PG21 H6B-SDRS-2M20 H6B-SDRS-2M25 H6B-SDRHS-PG21 H6B-SDRHS-PG29 H6B-SDRHS-M25 H6B-SDRHS-M32 H6B-SDRHS-2PG21 H6B-SDRHS-2PG29 H6B-SDRHS-2M25 H6B-SDRHS-2M32 T1620062116-000 T1620062121-000 T1620062120-000 T1620062125-000 T1620062216-000 T1620062221-000 T1620062220-000 T1620062225-000 T1660062121-000 T1660062129-000 T1660062125-000 T1660062132-000 T1660062221-000 T1660062229-000 T1660062225-000 T1660062232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 40 52 56 Hight 45 57 74 Low 40 52 56 Hight 45 57 74 72 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry H High construction B 1 Side entry A 2 Side entry Low construction Construction 1 Side entry With protection cover 2 Side entry Low High construction H 1 Side entry B 2 Side entry Low construction A 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 HIP.6/16, HIP-K.6/16, EMV-K.6/16 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Screw lock on hood Description Metr. PG Type Part Number 16 HIP HIP.6/16.STS.1.16.G HIP.6/16.STS.1.M25.G 1-1102631-5 0-1106425-2 16 21 HIP-K HIP-K.6/16.STS.1.16.G HIP-K.6/16.STS.1.21.G HIP-K.6/16.STS.1.M25.G 2-1102631-5 2-1102633-5 0-1106425-4 16 EMV-K EMV-K.6/16.STS.1.16.G EMV-K.6/16.STS.1.M25.G 4-1102704-5 0-1106416-4 16 HIP HIP.6/16.STO.1.16.G HIP.6/16.STO.1.M32.G 1-1102635-5 0-1106425-1 HIP-K HIP-K.6/16.STO.1.16.G HIP-K.6/16.STO.1.21.G HIP-K.6/16.STO.1.M25.G HIP-K.6/16.STO.1.M32.G 2-1102635-5 2-1102637-5 0-1106425-6 0-1106425-3 EMV-K EMV-K.6/16.STO.1.13.G EMV-K.6/16.STO.1.16.G EMV-K.6/16.STO.1.21.G EMV-K.6/16.STO.1.M32.G 0-1108719-1 4-1102706-5 4-1102707-5 0-1106416-3 HIP HIP.6/16.AG 1-1102638-5 Hood: Side entry M25 M25 M25 Hood: Top entry M32 M25 M32 M32 16 21 13 16 21 8 22 Surface mounted housing: Bottom entry 70 96 ø4.5 32 56 HIP-K HIP-K.6/16.AG EMV-K EMV-K.6/16.AG M4 32 36 52 70 2-1102638-5 4-1102710-5 1-1102638-5 M6x20 M6x20 8 8 79 79 96 96 PanelM6cut-out M6 36 36 43 43 52 52 79 79 22 22 43 43 60 60 HIP HIP.6/16.AG.M6 1-1102606-5 HIP-K HIP-K.6/16.AG.M6 2-1102606-5 EMV-K EMV-K.6/16.AG.M6 4-1102712-5 73 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HDD-042 inserts INSERTS FOR H10B HOOD/HOUSING 42+  250V 10A (machined contacts)   Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HDD-042-M T2030422101-000 HDD-042-F Contact arrangement view from termination side T2030422201-000 Panel cut out for inserts for use without hoods/housings 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 74 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HDD-024 inserts INSERTS FOR H10B HOOD/HOUSING 24+ 250V 10A (stamped and formed contacts) Description Male insert Type Part Number Female insert Male insert Female insert Crimp terminal HD.24.Sti.C 2-1103008-3 HD.24.BU.C 2-1103009-3 Dimensions A B C D E mm 57 64 33 35 35 M3x10 19,8 35 M3x10 16 1 5 M3 1 2 3 4 5 6 36 27 20 A B C D D C B A A B C D 1 2 3 4 5 6 1 2 3 4 5 6 50 57 65 36 27 48 64 57 20 M3 57 27 36 D C B A 1 2 3 4 5 6 M3 Panel 10 cut-out 14 27 33 57 27 Female insert 64 33 57 Male insert 64 27 33 35 19.4 Contact arrangement 20 Dimensions (mm) 57 63 35 M3x10 Suitable crimp contacts and crimping tools: see page 111 48 64 2-1103008-3 2-1103009-3 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 75 H10B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H10B-TS-PG16 H10B-TS-PG21 H10B-TS-M20 H10B-TS-M25 T1210100116-000 T1210100121-000 T1210100120-000 T1210100125-000 PG21 PG29 H10B-TSH-PG21 H10B-TSH-PG29 H10B-TSH-M20 H10B-TSH-M25 H10B-TSH-M32 T1230100121-000 T1230100129-000 T1230100120-000 T1230100125-000 T1230100132-000 PG16 PG21 H10B-TG-PG16 H10B-TG-PG21 H10B-TG-M20 H10B-TG-M25 T1220100116-000 T1220100121-000 T1220100120-000 T1220100125-000 PG21 PG29 H10B-TGH-PG21 H10B-TGH-PG29 H10B-TGH-M20 H10B-TGH-M25 H10B-TGH-M32 T1240100121-000 T1240100129-000 T1240100120-000 T1240100125-000 T1240100132-000 PG16 H10B-TBFS-PG16 H10B-TBFS-M20 H10B-TBFS-M25 H10B-TBFHS-PG21 H10B-TBFHS-PG29 H10B-TBFHS-M25 H10B-TBFHS-M32 T1710101116-000 T1710101120-000 T1710101125-000 T1750101121-000 T1750101129-000 T1750101125-000 T1750101132-000 H10B-KDTP T1010101400-000 H10B-KDBP T1010102100-000 Hood: Side entry Low construction M20 M25 High construction M20 M25 M32 Hood: Top entry Low construction M20 M25 High construction M20 M25 M32 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M20 M25 M25 M32 PG21 PG29 Protection covers for hoods Housing protection cover 76 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H10B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H10B-AGS T1410101000-000 H10B-SGRS-PG16 H10B-SGRS-PG21 H10B-SGRS-M20 H10B-SGRS-M25 H10B-SGRS-2PG16 H10B-SGRS-2PG21 H10B-SGRS-2M20 H10B-SGRS-2M25 H10B-SGRHS-PG21 H10B-SGRHS-PG29 H10B-SGRHS-M25 H10B-SGRHS-M32 H10B-SGRHS-2PG21 H10B-SGRHS-2PG29 H10B-SGRHS-2M25 H10B-SGRHS-2M32 T1440101116-000 T1440101121-000 T1440101120-000 T1440101125-000 T1440101216-000 T1440101221-000 T1440101220-000 T1440101225-000 T1470101121-000 T1470101129-000 T1470101125-000 T1470101132-000 T1470101221-000 T1470101229-000 T1470101225-000 T1470101232-000 H10B-TSBS-PG16 H10B-TSBS-PG21 H10B-TSBS-M20 H10B-TSBS-M25 H10B-TSBHS-PG21 H10B-TSBHS-PG29 H10B-TSBHS-M25 H10B-TSBHS-M32 T1250103116-000 T1250103121-000 T1250103120-000 T1250103125-000 T1270103121-000 T1270103129-000 T1270103125-000 T1270103132-000 H10B-TGBS-PG16 H10B-TGBS-PG21 H10B-TGBS-M20 H10B-TGBS-M25 H10B-TGBHS-PG21 H10B-TGBHS-PG29 H10B-TGBHS-M25 H10B-TGBHS-M32 T1260103116-000 T1260103121-000 T1260103120-000 T1260103125-000 T1280103121-000 T1280103129-000 T1280103125-000 T1280103132-000 H10B-AD-BO T1430100000-000 H10B-SDR-BO-PG16 H10B-SDR-BO-PG21 H10B-SDR-BO-M20 H10B-SDR-BO-M25 H10B-SDR-BO-2PG16 H10B-SDR-BO-2PG21 H10B-SDR-BO-2M20 H10B-SDR-BO-2M25 H10B-SDRH-BO-PG21 H10B-SDRH-BO-PG29 H10B-SDRH-BO-M25 H10B-SDRH-BO-M32 H10B-SDRH-BO-2PG21 H10B-SDRH-BO-2PG29 H10B-SDRH-BO-2M25 H10B-SDRH-BO-2M32 T1460100116-000 T1460100121-000 T1460100120-000 T1460100125-000 T1460100216-000 T1460100221-000 T1460100220-000 T1460100225-000 T1490100121-000 T1490100129-000 T1490100125-000 T1490100132-000 T1490100221-000 T1490100229-000 T1490100225-000 T1490100232-000 Bulkhead mounted Surface mounted: Side entry 40 52 56 Hight 45 57 74 2 Side entry Low High construction H 1 Side entry B 2 Side entry Low construction A 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction High construction Construction H Low 60 Hight 72 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction High construction Construction H Low 60 Hight 72 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover 2 Side entry Low construction 1 Side entry M20 M25 M20 M25 82 94 40 52 22 67 54 B C D F G H Hight 82 94 45 57 20 65 74 2 Side entry High construction A Low 1 Side entry Construction M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 77 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H10B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H10B-TS-RO-PG16 H10B-TS-RO-PG21 H10B-TS-RO-M20 H10B-TS-RO-M25 T1310100116-000 T1310100121-000 T1310100120-000 T1310100125-000 PG21 PG29 H10B-TSH-RO-PG21 H10B-TSH-RO-PG29 H10B-TSH-RO-M20 H10B-TSH-RO-M25 H10B-TSH-RO-M32 T1330100121-000 T1330100129-000 T1330100120-000 T1330100125-000 T1330100132-000 PG16 PG21 H10B-TG-RO-PG16 H10B-TG-RO-PG21 H10B-TG-RO-M20 H10B-TG-RO-M25 T1320100116-000 T1320100121-000 T1320100120-000 T1320100125-000 PG21 PG29 H10B-TGH-RO-PG21 H10B-TGH-RO-PG29 H10B-TGH-RO-M20 H10B-TGH-RO-M25 H10B-TGH-RO-M32 T1340100121-000 T1340100129-000 T1340100120-000 T1340100125-000 T1340100132-000 PG16 H10B-TBF-LB-PG16 H10B-TBF-LB-M20 H10B-TBF-LB-M25 H10B-TBFH-LB-PG21 H10B-TBFH-LB-PG29 H10B-TBFH-LB-M25 H10B-TBFH-LB-M32 T1730103116-000 T1730103120-000 T1730103125-000 T1770103121-000 T1770103129-000 T1770103125-000 T1770103132-000 H10B-KDTP-LB T1010101500-000 Hood: Side entry Low construction M20 M25 High construction M20 M25 M32 Hood: Top entry Low construction M20 M25 High construction M20 M25 M32 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M20 M25 M25 M32 PG21 PG29 Protection covers for hoods 78 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H10B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H10B-AG-LB T1500103000-000 H10B-AD-LB H10B-ADM-LB T1510103000-000 T1510103001-000 H10B-SGR-LB-PG16 H10B-SGR-LB-PG21 H10B-SGR-LB-M20 H10B-SGR-LB-M25 H10B-SGR-LB-2PG16 H10B-SGR-LB-2PG21 H10B-SGR-LB-2M20 H10B-SGR-LB-2M25 H10B-SGRH-LB-PG21 H10B-SGRH-LB-PG29 H10B-SGRH-LB-M25 H10B-SGRH-LB-M32 H10B-SGRH-LB-2PG21 H10B-SGRH-LB-2PG29 H10B-SGRH-LB-2M25 H10B-SGRH-LB-2M32 T1610103116-000 T1610103121-000 T1610103120-000 T1610103125-000 T1610103216-000 T1610103221-000 T1610103220-000 T1610103225-000 T1650103121-000 T1650103129-000 T1650103125-000 T1650103132-000 T1650103221-000 T1650103229-000 T1650103225-000 T1650103232-000 H10B-SDR-LB-PG16 H10B-SDR-LB-PG21 H10B-SDR-LB-M20 H10B-SDR-LB-M25 H10B-SDR-LB-2PG16 H10B-SDR-LB-2PG21 H10B-SDR-LB-2M20 H10B-SDR-LB-2M25 H10B-SDRH-LB-PG21 H10B-SDRH-LB-PG29 H10B-SDRH-LB-M25 H10B-SDRH-LB-M32 H10B-SDRH-LB-2PG21 H10B-SDRH-LB-2PG29 H10B-SDRH-LB-2M25 H10B-SDRH-LB-2M32 T1620103116-000 T1620103121-000 T1620103120-000 T1620103125-000 T1620103216-000 T1620103221-000 T1620103220-000 T1620103225-000 T1660103121-000 T1660103129-000 T1660103125-000 T1660103132-000 T1660103221-000 T1660103229-000 T1660103225-000 T1660103232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 40 52 54 Hight 45 57 74 54 Hight 45 57 74 2 Side entry H 52 High construction B 40 1 Side entry A Low 2 Side entry Low construction Construction 1 Side entry With protection cover 2 Side entry Low High construction H 1 Side entry B 2 Side entry Low construction A 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 79 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.10/24, HIP-K.10/24, EMV-K.10/24 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 16 21 HIP HIP.10/24.STS.1.16.G HIP.10/24.STS.1.21.G HIP.10/24.STS.1.M25.G 1-1102640-5 1-1102642-5 0-1106436-2 HIP-K HIP-K.10/24.STS.1.21.G HIP-K.10/24.STS.1.M25.G HIP-K.10/24.STS.1.M32.G 2-1102642-5 0-1106436-4 0-1106436-6 EMV-K EMV-K.10/24.STS.1.21.G EMV-K.10/24.STS.1.M25.G EMV-K.10/24.STS.1.M32.G 4-1102714-5 0-1106427-3 1-1106427-0 HIP HIP.10/24.STO.1.16.G HIP.10/24.STO.1.21.G HIP.10/24.STO.1.M25.G 1-1102644-5 1-1102646-5 0-1106436-1 HIP-K HIP-K.10/24.STO.1.16.G HIP-K.10/24.STO.1.M25.G HIP-K.10/24.STO.1.M32.G 2-1102644-5 0-1106436-3 0-1106436-5 EMV-K EMV-K.10/24.STO.1.21.G EMV-K.10/24.STO.1.M25.G 4-1102715-5 0-1106427-4 HIP HIP.10/24.AG 1-1102647-5 Hood: Side entry, Standard construction M25 M25 M32 M25 M32 21 21 Hood: Top entry M25 M25 M32 M25 16 21 16 21 8 22 Surface mounted housing: Bottom entry 83 109 ø4,5 32 56 36 32 M4 65 83 80 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP-K HIP-K.10/24.AG EMV-K EMV-K.10/24.AG 2-1102647-5 4-1102718-5 HIP.10/24, HIP-K.10/24, EMV-K.10/24 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Pressure-tight up to 5 bar IP 68 / IP 69 K Description Metr. PG Type Part Number HIP HIP.10/24.AG.M6 1-1102612-5 HIP-K HIP-K.10/24.AG.M6 2-1102612-5 EMV-K EMV-K.10/24.AG.M6 4-1102720-5 HIP HIP.10/24.SG.1.21.G HIP.10/24.SG.2.21.G HIP.10/24.SG.2.M32.G 1-1102610-5 1-1102611-5 0-1106435-1 HIP-K HIP-K.10/24.SG.1.21.G HIP-K.10/24.SG.2.21.G 5-1102610-5 2-1102611-5 EMV-K EMV-K.10/24.SG.1.21.G EMV-K.10/24.SG.2.21.G EMV-K.10/24.SG.2.M32.G 5-1102716-5 4-1102717-5 0-1106426-2 HIP HIP/EMV.10/24.SKB 3-1106202-5 Surface mounted housing: Bottom entry M6x20 22 22 M6x20 43 43 60 92 92 109 109 60 Panel cut-out M6 M6 3636 43 43 65 65 92 92 Surface mounted housing: Side entry 2xM32 21 2x21 21 2x21 2xM32 21 2x21 Protective covers for hoods and housing M6x30 19 109 53 HIP-K/EMV-K HIP-K/EMV-K.10/24.SKB 4-1106202-5 81 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD-040 inserts INSERTS FOR H16B HOOD/HOUSING 40+  250V 10A (machined contacts)   Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HD-040-M T2020402101-000 HD-040-F Contact arrangement view from termination side T2020402201-000 Panel cut out for inserts for use without hoods/housings 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 82 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HD-040 inserts INSERTS FOR H16B HOOD/HOUSING 40+ 250V 10A (stamped and formed contacts) Description Type Male insert Part Number Female insert Male insert Female insert Crimp terminal HD.40.Sti.C 2-1103012-3 HD.40.BU.C Dimensions mm 2-1103013-3 A B C D E 77.5 84.5 33 35 35 C B Sti 35 D 35 M3x10 *22,3 Suitable crimp contacts and crimping tools: see page 111 E Dimensions (mm) 16 *Abstand für sichere Kontaktgabe max. 24 mm Male insert B 35 27 33 77,5 Contact arrangement 84,5 Bu A M3x10 77,5 84,5 27 77.5 Panel cut-out 83.5 33 Female insert C Sti 1 12 61 72 D A B C D M3x10 *19,5 Bu E A 1 2 3 4 5 6 7 8 9 10 D C B A 1 2 3 4 5 6 7 8 9 10 27 33 M3 1 2 3 4 5 6 7 8 9 10 36 27 20 70,5 77,5 85,5 1 2 3 4 5 6 7 8 9 10 27 *Abstand für sichere Kontaktgabe max. 21 mm 36 14 36 14 27 68,5 68,5 27 M3 5 M3 5 77,5 77,5 83 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HDD-072 inserts INSERTS FOR H16B HOOD/HOUSING 72+  250V 10A (machined contacts)   Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HDD-072-M T2030722101-000 HDD-072-F Contact arrangement view from termination side T2030722201-000 Panel cut out for inserts for use without hoods/housings 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 26-22 20 CDF-0.14 CDF-0.5 T2020002002-000 T2020002005-000 DDF-0.14 DDF-0.5 T2020012002-000 T2020012005-000 0.75 1.0 1.5 2.5 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 84 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H16B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H16B-TS-PG16 H16B-TS-PG21 H16B-TS-M20 H16B-TS-M25 H16B-TS-M32 T1210160116-000 T1210160121-000 T1210160120-000 T1210160125-000 T1210160132-000 PG21 PG29 H16B-TSH-PG21 H16B-TSH-PG29 H16B-TSH-M25 H16B-TSH-M32 H16B-TSH-M40 T1230160121-000 T1230160129-000 T1230060125-000 T1230160132-000 T1230160140-000 PG16 PG21 H16B-TG-PG16 H16B-TG-PG21 H16B-TG-M25 H16B-TG-M32 T1220160116-000 T1220160121-000 T1220160125-000 T1220160132-000 PG21 PG29 H16B-TGH-PG21 H16B-TGH-PG29 H16B-TGH-M25 H16B-TGH-M32 H16B-TGH-M40 T1240160121-000 T1240160129-000 T1240160125-000 T1240160132-000 T1240160140-000 PG21 H16B-TBFS-PG21 H16B-TBFS-M25 H16B-TBFS-M32 H16B-TBFHS-PG21 H16B-TBFHS-PG29 H16B-TBFHS-M25 H16B-TBFHS-M32 H16B-TBFHS-M40 T1710161121-000 T1710161125-000 T1710161132-000 T1750161121-000 T1750161129-000 T1750161125-000 T1750161132-000 T1750161140-000 H16B-KDTP T1010161400-000 H16B-KDBP T1010162100-000 Hood: Side entry Low construction M20 M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods Housing protection cover 85 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H16B-AGS T1410161000-000 H16B-SGRS-PG21 H16B-SGRS-M25 H16B-SGRS-2PG21 H16B-SGRS-2M25 H16B-SGRHS-PG21 H16B-SGRHS-PG29 H16B-SGRHS-M25 H16B-SGRHS-M32 H16B-SGRHS-2PG21 H16B-SGRHS-2PG29 H16B-SGRHS-2M25 H16B-SGRHS-2M32 T1440161121-000 T1440161125-000 T1440161221-000 T1440161225-000 T1470161121-000 T1470161129-000 T1470161125-000 T1470161132-000 T1470161221-000 T1470161229-000 T1470161225-000 T1470161232-000 H16B-TSBS-PG16 H16B-TSBS-PG21 H16B-TSBS-M20 H16B-TSBS-M25 H16B-TSBHS-PG21 H16B-TSBHS-PG29 H16B-TSBHS-M25 H16B-TSBHS-M32 T1250163116-000 T1250163121-000 T1250163120-000 T1250163125-000 T1270163121-000 T1270163129-000 T1270163125-000 T1270163132-000 H16B-TGBS-PG16 H16B-TGBS-PG21 H16B-TGBS-M20 H16B-TGBS-M25 H16B-TGBHS-PG21 H16B-TGBHS-PG29 H16B-TGBHS-M25 H16B-TGBHS-M32 T1260163116-000 T1260163121-000 T1260163120-000 T1260163125-000 T1280163121-000 T1280163129-000 T1280163125-000 T1280163132-000 H16B-AD-BO T1430160000-000 H16B-SDR-BO-PG21 H16B-SDR-BO-M25 H16B-SDR-BO-2PG21 H16B-SDR-BO-2M25 H16B-SDRH-BO-PG21 H16B-SDRH-BO-PG29 H16B-SDRH-BO-M25 H16B-SDRH-BO-M32 H16B-SDRH-BO-2PG21 H16B-SDRH-BO-2PG29 H16B-SDRH-BO-2M25 H16B-SDRH-BO-2M32 T1460160121-000 T1460160125-000 T1460160221-000 T1460160225-000 T1490160121-000 T1490160129-000 T1490160125-000 T1490160132-000 T1490160221-000 T1490160229-000 T1490160225-000 T1490160232-000 Bulkhead mounted Surface mounted: Side entry 81 2 Side entry Hight High construction 56 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction H Low 60 Hight 76 High construction Construction M20 M25 M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction High construction Construction H Low 60 Hight 76 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover Low construction C D F G H Low 105 117 45 57 20 65 56 Hight 105 117 45 57 20 65 81 86 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry High construction B 1 Side entry A 1 Side entry 2 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 H16B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 H16B-TS-RO-PG21 H16B-TS-RO-PG29 H16B-TS-RO-M25 H16B-TS-RO-M32 T1310160121-000 T1310160129-000 T1310160125-000 T1310160132-000 PG21 PG29 H16B-TSH-RO-PG21 H16B-TSH-RO-PG29 H16B-TSH-RO-M25 H16B-TSH-RO-M32 H16B-TSH-RO-M40 T1330160121-000 T1330160129-000 T1330160125-000 T1330160132-000 T1330160140-000 PG21 PG29 H16B-TG-RO-PG21 H16B-TG-RO-PG29 H16B-TG-RO-M25 H16B-TG-RO-M32 T1320160121-000 T1320160129-000 T1320160125-000 T1320160132-000 PG21 PG29 H16B-TGH-RO-PG21 H16B-TGH-RO-PG29 H16B-TGH-RO-M25 H16B-TGH-RO-M32 H16B-TGH-RO-M40 T1340160121-000 T1340160129-000 T1340160125-000 T1340160132-000 T1340160140-000 PG21 PG29 H16B-TBF-LB-PG21 H16B-TBF-LB-PG29 H16B-TBF-LB-M25 H16B-TBF-LB-M32 H16B-TBFH-LB-PG21 H16B-TBFH-LB-PG29 H16B-TBFH-LB-M25 H16B-TBFH-LB-M32 H16B-TBFH-LB-M40 T1730163121-000 T1730163129-000 T1730163125-000 T1730163132-000 T1770163121-000 T1770163129-000 T1770163125-000 T1770163132-000 T1770163140-000 H16B-KDTP-LB T1010161500-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods 87 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H16B-AG-LB T1500163000-000 H16B-AD-LB T1510163000-000 H16B-SGR-LB-PG16 H16B-SGR-LB-PG21 H16B-SGR-LB-M20 H16B-SGR-LB-M25 H16B-SGR-LB-2PG16 H16B-SGR-LB-2PG21 H16B-SGR-LB-2M20 H16B-SGR-LB-2M25 H16B-SGRH-LB-PG21 H16B-SGRH-LB-PG29 H16B-SGRH-LB-M25 H16B-SGRH-LB-M32 H16B-SGRH-LB-2PG21 H16B-SGRH-LB-2PG29 H16B-SGRH-LB-2M25 H16B-SGRH-LB-2M32 T1610163116-000 T1610163121-000 T1610163120-000 T1610163125-000 T1610163216-000 T1610163221-000 T1610163220-000 T1610163225-000 T1650163121-000 T1650163129-000 T1650163125-000 T1650163132-000 T1650163221-000 T1650163229-000 T1650163225-000 T1650163232-000 H16B-SDR-LB-PG16 H16B-SDR-LB-PG21 H16B-SDR-LB-M20 H16B-SDR-LB-M25 H16B-SDR-LB-2PG16 H16B-SDR-LB-2PG21 H16B-SDR-LB-2M20 H16B-SDR-LB-2M25 H16B-SDRH-LB-PG21 H16B-SDRH-LB-PG29 H16B-SDRH-LB-M25 H16B-SDRH-LB-M32 H16B-SDRH-LB-2PG21 H16B-SDRH-LB-2PG29 H16B-SDRH-LB-2M25 H16B-SDRH-LB-2M32 T1620163116-000 T1620163121-000 T1620163120-000 T1620163125-000 T1620163216-000 T1620163221-000 T1620163220-000 T1620163225-000 T1660163121-000 T1660163129-000 T1660163125-000 T1660163132-000 T1660163221-000 T1660163229-000 T1660163225-000 T1660163232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 88 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry H Low construction Construction 1 Side entry With protection cover 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 HIP.16/40, HIP-K.16/40, EMV-K.16/40 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 21 29 HIP HIP.16/40.STS.1.21.G HIP.16/40.STS.1.29.G HIP.16/40.STS.1.M32.G 1-1102649-5 1-1102651-5 0-1106454-2 29 HIP-K HIP-K.16/40.STS.1.29.G HIP-K.16/40.STS.1.M32.G 2-1102651-5 0-1106444-2 EMV-K EMV-K.16/40.STS.1.29.G EMV-K.16/40.STS.1.M32.G EMV-K.16/40.STS.1.21.G 4-1102723-5 0-1106446-4 4-1102722-5 21 29 HIP HIP.16/40.STO.1.21.G HIP.16/40.STO.1.29.G HIP.16/40.STO.1.M32.G 1-1102653-5 1-1102655-5 0-1106454-1 21 29 HIP-K HIP-K.16/40.STO.2.21.G HIP-K.16/40.STO.1.29.G HIP-K.16/40.STO.1.M32.G 0-1108534-1 2-1102655-5 0-1106444-1 29 EMV-K EMV-K.16/40.STO.1.29.G EMV-K.16/40.STO.1.M32.G 4-1102725-5 0-1106446-3 HIP HIP.16/40.AG 1-1102656-5 Hood: Side entry M32 M32 M32 29 21 Hood: Top entry M32 M32 M32 8 22 Surface mounted housing: Bottom entry 22 ø4.5 8 103 129.5 ø4.5 32 56 32 56 103 129.5 HIP-K HIP-K.16/40.AG EMV-K EMV-K.16/40.AG Panel cut-out M4 32 36 32 36 M4 86 86 103103 M6x20 1-1102656-5 8 M6x20 1-1102656-5 112.5 129.5 112.5 129.5 43 60 86 112.5 86 M6 M6 36 36 45 43 22 60 8 Panel cut-out 112.5 22 45 2-1102656-5 4-1102728-5 HIP HIP.16/40.AG.M6 1-1102618-5 HIP-K HIP-K.16/40.AG.M6 2-1102618-5 EMV-K EMV-K.16/40.AG.M6 4-1102730-5 89 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.16/40, HIP-K.16/40, EMV-K.16/40 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Pressure-tight up to 5 bar IP 68 / IP 69 K Description Metr. PG Type Part Number 21 2x21 HIP HIP.16/40.SG.1.21.G HIP.16/40.SG.2.21.G HIP.16/40.SG.2.M32.G 1-1102616-5 1-1102617-5 0-1106453-1 21 2x21 HIP-K HIP-K.16/40.SG.1.21.G HIP-K.16/40.SG.2.21.G HIP-K.16/40.SG.2.M32.G 5-1102616-5 2-1102617-5 0-1106443-1 21 2x21 EMV-K EMV-K.16/40.SG.1.21.Z EMV-K.16/40.SG.2.21.Z EMV-K.16/40.SG.2.M32.G 4-1102726-5 4-1102727-5 0-1106445-2 HIP HIP/EMV.16/40.SKB 3-1106203-5 HIP-K HIP-K.16/40.SKB 4-1106203-5 Surface mounted housing: Side entry 2xM32 2xM32 2xM32 Protective covers for housings M6x30 19 129.5 53 90 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HD-064 inserts INSERTS FOR H24B HOOD/HOUSING 64+  250V 10A (machined contacts)   Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HD-064-M T2020642101-000 HD-064-F Contact arrangement view from termination side T2020642201-000 Panel cut out for inserts for use without hoods/housings 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 91 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD-064 inserts INSERTS FOR H24B HOOD/HOUSING 64+ 250V 10A (stamped and formed contacts) Description Type Male insert Part Number Female insert Male insert Female insert Crimp terminal HD.64.Sti.C 2-1103032-3 HD.64.BU.C 2-1103033-3 C B Sti D E Bu Dimensions A (mm) Contact arrangement 16 B 27 33 Female insert 104 Male insert110 *Abstand für sichere Kontaktgabe max. 24 mm C Sti DCBA 1 16 D 1 16 M3x10 *19,5 Bu E M3 104 20 27 27 36 A *Abstand für sichere Kontaktgabe max. 21 mm 97 112 2-1103112-3 92 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 19.4 *22,3 35 M3x10 Suitable crimp contacts and crimping tools: see page 111 M3x10 Panel cut-out HDD-108 inserts INSERTS FOR H24B HOOD/HOUSING 108+  250V 10A (machined contacts)   Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HDD-108-M T 2 03 108 2101-000 HDD-108-F Contact arrangement view from termination side T 2 03 108 2201-000 Panel cut out for inserts for use without hoods/housings 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 93 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H24B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H24B-TS-PG16 H24B-TS-PG21 H24B-TS-M25 H24B-TS-M32 T1210240116-000 T1210240121-000 T1210240125-000 T1210240132-000 PG21 PG29 H24B-TSH-PG21 H24B-TSH-PG29 H24B-TSH-M25 H24B-TSH-M32 H24B-TSH-M40 T1230240121-000 T1230240129-000 T1230240125-000 T1230240132-000 T1230240140-000 PG16 PG21 H24B-TG-PG16 H24B-TG-PG21 H24B-TG-M25 H24B-TG-M32 T1220240116-000 T1220240121-000 T1220240125-000 T1220240132-000 PG21 PG29 H24B-TGH-PG21 H24B-TGH-PG29 H24B-TGH-M25 H24B-TGH-M32 H24B-TGH-M40 T1240240121-000 T1240240129-000 T1240240125-000 T1240240132-000 T1240240140-000 PG21 H24B-TBFS-PG21 H24B-TBFS-M25 H24B-TBFS-M32 H24B-TBFHS-PG21 H24B-TBFHS-PG29 H24B-TBFHS-M25 H24B-TBFHS-M32 H24B-TBFHS-M40 T1710241121-000 T1710241125-000 T1710241132-000 T1750241121-000 T1750241129-000 T1750241125-000 T1750241132-000 T1750241140-000 H24B-KDTP T1010241400-000 H24B-KDBP T1010242100-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 78.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods Housing protection cover 94 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H24B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H24B-AGS T1410241000-000 H24B-SGRS-PG21 H24B-SGRS-M25 H24B-SGRS-2PG21 H24B-SGRS-2M25 H24B-SGRHS-PG21 H24B-SGRHS-PG29 H24B-SGRHS-M25 H24B-SGRHS-M32 H24B-SGRHS-2PG21 H24B-SGRHS-2PG29 H24B-SGRHS-2M25 H24B-SGRHS-2M32 T1440241121-000 T1440241125-000 T1440241221-000 T1440241225-000 T1470241121-000 T1470241129-000 T1470241125-000 T1470241132-000 T1470241221-000 T1470241229-000 T1470241225-000 T1470241232-000 H24B-TSBS-PG16 H24B-TSBS-PG21 H24B-TSBS-M20 H24B-TSBS-M25 H24B-TSBHS-PG21 H24B-TSBHS-PG29 H24B-TSBHS-M25 H24B-TSBHS-M32 T1250243116-000 T1250243121-000 T1250243120-000 T1250243125-000 T1270243121-000 T1270243129-000 T1270243125-000 T1270243132-000 H24B-TGBS-PG16 H24B-TGBS-PG21 H24B-TGBS-M20 H24B-TGBS-M25 H24B-TGBHS-PG21 H24B-TGBHS-PG29 H24B-TGBHS-M25 H24B-TGBHS-M32 T1260243116-000 T1260243121-000 T1260243120-000 T1260243125-000 T1280243121-000 T1280243129-000 T1280243125-000 T1280243132-000 H24B-AD-BO T1430240000-000 H24B-SDR-BO-PG21 H24B-SDR-BO-M25 H24B-SDR-BO-2PG21 H24B-SDR-BO-2M25 H24B-SDRH-BO-PG21 H24B-SDRH-BO-PG29 H24B-SDRH-BO-M25 H24B-SDRH-BO-M32 H24B-SDRH-BO-2PG21 H24B-SDRH-BO-2PG29 H24B-SDRH-BO-2M25 H24B-SDRH-BO-2M32 T1460240121-000 T1460240125-000 T1460240221-000 T1460240225-000 T1490240121-000 T1490240129-000 T1490240125-000 T1490240132-000 T1490240221-000 T1490240229-000 T1490240225-000 T1490240232-000 Bulkhead mounted Surface mounted: Side entry 81 2 Side entry Hight High construction 56 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction H Low 60 Hight 76 High construction Construction M20 M25 M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction H Low 60 Hight 76 High construction Construction M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover Low construction D F G H Low 132 144 45 57 20 65 56 Hight 132 144 45 57 20 65 81 2 Side entry C High construction B 1 Side entry A 1 Side entry 2 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 95 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H24B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 H24B-TS-RO-PG21 H24B-TS-RO-PG29 H24B-TS-RO-M25 H24B-TS-RO-M32 T1310240121-000 T1310240129-000 T1310240125-000 T1310240132-000 PG21 PG29 H24B-TSH-RO-PG21 H24B-TSH-RO-PG29 H24B-TSH-RO-M25 H24B-TSH-RO-M32 H24B-TSH-RO-M40 T1330240121-000 T1330240129-000 T1330240125-000 T1330240132-000 T1330240140-000 PG21 PG29 H24B-TG-RO-PG21 H24B-TG-RO-PG29 H24B-TG-RO-M25 H24B-TG-RO-M32 T1320240121-000 T1320240129-000 T1320240125-000 T1320240132-000 PG21 PG29 H24B-TGH-RO-PG21 H24B-TGH-RO-PG29 H24B-TGH-RO-M25 H24B-TGH-RO-M32 H24B-TGH-RO-M40 T1340240121-000 T1340240129-000 T1340240125-000 T1340240132-000 T1340240140-000 PG21 PG29 H24B-TBF-LB-PG21 H24B-TBF-LB-PG29 H24B-TBF-LB-M25 H24B-TBF-LB-M32 H24B-TBFH-LB-PG21 H24B-TBFH-LB-PG29 H24B-TBFH-LB-M25 H24B-TBFH-LB-M32 H24B-TBFH-LB-M40 T1730242121-000 T1730242129-000 T1730242125-000 T1730242132-000 T1770243121-000 T1770243129-000 T1770243125-000 T1770243132-000 T1770243140-000 H24B-KDTP-LB T1010241500-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood Low construction Construction H 62.5 Hight 78.5 High construction Low M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods 96 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H24B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H24B-AG-LB T1500243000-000 H24B-AD-LB T1510243000-000 H24B-SGR-LB-PG16 H24B-SGR-LB-PG21 H24B-SGR-LB-M20 H24B-SGR-LB-M25 H24B-SGR-LB-2PG16 H24B-SGR-LB-2PG21 H24B-SGR-LB-2M20 H24B-SGR-LB-2M25 H24B-SGRH-LB-PG21 H24B-SGRH-LB-PG29 H24B-SGRH-LB-M25 H24B-SGRH-LB-M32 H24B-SGRH-LB-2PG21 H24B-SGRH-LB-2PG29 H24B-SGRH-LB-2M25 H24B-SGRH-LB-2M32 T1610243116-000 T1610243121-000 T1610243120-000 T1610243125-000 T1610243216-000 T1610243221-000 T1610243220-000 T1610243225-000 T1650243121-000 T1650243129-000 T1650243125-000 T1650243132-000 T1650243221-000 T1650243229-000 T1650243225-000 T1650243232-000 H24B-SDR-LB-PG16 H24B-SDR-LB-PG21 H24B-SDR-LB-M20 H24B-SDR-LB-M25 H24B-SDR-LB-2PG16 H24B-SDR-LB-2PG21 H24B-SDR-LB-2M20 H24B-SDR-LB-2M25 H24B-SDRH-LB-PG21 H24B-SDRH-LB-PG29 H24B-SDRH-LB-M2S H24B-SDRH-LB-M32 H24B-SDRH-LB-2PG21 H24B-SDRH-LB-2PG29 H24B-SDRH-LB-2M25 H24B-SDRH-LB-2M32 T1620243116-000 T1620243121-000 T1620243120-000 T1620243125-000 T1620243216-000 T1620243221-000 T1620243220-000 T1620243225-000 T1660243121-000 T1660243129-000 T1660243125-000 T1660243132-000 T1660243221-000 T1660243229-000 T1660243225-000 T1660243232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 81 2 Side entry Hight High construction 56 1 Side entry Low 2 Side entry H Low construction Construction 1 Side entry With protection cover 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 97 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.24/64, HIP-K.24/64, EMV-K.24/64 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number HIP HIP.24/64.AG 1-1102665-5 HIP-K HIP-K.24/64.AG 2-1102665-5 EMV-K EMV-K.24/64.AG 4-1102760-5 HIP HIP.24/64.AG.M6 1-1102626-5 HIP-K HIP-K.24/64.AG.M6 HIP-K.24/64.AG.M6.D HIP-K-I.24/64.AG.M6.D 2-1102626-5 2-1102628-5 0-1108533-1 EMV-K EMV-K.24/64.AG.M6 4-1102736-5 HIP HIP.24/64.SG.1.29.G HIP.24/64.SG.2.29.G HIP.24/64.SG.2.M40.G 1-1102624-5 1-1102625-5 0-1106472-1 8 22 Surface mounted housing: Bottom entry, Standard construction 130 156 ø4.5 32 56 32 35 130 112 M4 M6x20 22 1-1102665-5 139 156 8 43 60 139 112 35 43 M6 Surface mounted housing: Side entry, Standard construction 2xM40 2xM40 2xM40 29 2x29 29 2x29 29 2x29 HIP-K HIP-K.24/64.SG.1.29.G HIP-K.24/64.SG.2.29.G HIP-K.24/64.SG.2.M40.G EMV-K EMV-K.24/64.SG.1.29.G EMV-K.24/64.SG.2.29.G EMV-K.24/64.SG.2.M40.G 5-1102624-5 2-1102625-5 0-1106472-2 4-1102734-5 4-1102735-5 0-1106460-2 Protective cover housings M6x30 19 156 53 98 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP HIP/EMV.24/64.SKB 3-1106204-5 HIP-K/EMV-K HIP-K/EMV-K.24/64.SKB 4-1106204-5 HIP.24/64, HIP-K.24/64, EMV-K.24/64 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 21 29 HIP HIP.24/64.STS.1.21.G HIP.24/64.STS.1.29 G HIP.24/64.STS.1.M40.G 1-1102658-5 1-1102660-5 0-1106473-2 29 HIP-K HIP-K.24/64.STS.1.29.G HIP-K.24/64.STS.1.M40.G 2-1102660-5 0-1106473-4 EMV-K EMV-K.24/64.STS.1.29.G EMV-K.24/64.STS.1.M25.G EMV-K.24/64.STS.1.M32.G EMV-K.24/64.STS.1.M40.G 4-1102755-5 0-1102983-1 0-1106461-8 0-1106461-3 29 36 HIP HIP-KF.24/64.STS.1.29.G HIP-KF.24/64.STS.1.36.G HIP-KF.24/64.STS.1.M40.G 1-1102622-5 1-1102623-5 0-1106474-1 29 36 HIP-K HIP-KF/K.24/64.STS.1.29.G HIP-KF/K. 24/64.STS.1.36G HIP-KF/K.24/64.STS.1.M40.G 2-1102622-5 2-1102623-5 0-1106474-2 29 36 EMV-K EMV-KF/K.24/64.STS.1.29.G EMV-KF/K.24/64.STS.1.36.G EMV-KF/K.24/64.STS.1.M40.G 4-1102732-5 4-1102733-5 0-1106462-2 21 29 HIP HIP.24/64.STO.1.21.G HIP.24/64.STO.1.29.G HIP.24/64.STO.1.M40.G 1-1102662-5 1-1102664-5 0-1106473-1 Hood: Side entry, Standard construction M40 M40 M25 M32 M40 M40 M40 M40 29 Hood: Top entry, Standard construction M40 2xM32 M40 M/PG 90 57 142 156 M40 2xM40 29 53 29 2xM40 HIP-K HIP-K.24/64.STO.1.29.G HIP-K.24/64.STO.2.M32.G HIP-K.24/64.STO.1.M40.G EMV-K EMV-K.24/64.STO.1.29.G EMV-K.24/64.STO.1.M40.G 2-1102664-5 0-1102792-1 0-1106473-3 4-1102759-5 0-1106461-4 3-1102759-5 2xM40 99 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HF-HIP-K 8/HF-EMV-K 8, HF-HIP-K 12/HF-EMV-K 12 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood Description Metr. PG Type Part Number HF-HIP-K.8.Sto.1.M50G HF.8.EMV-K.8.Sto.1.M50G HF.HIP-K.8.Sto.2.M40G HF.EMV-K.8.Sto.2.M40G 0-1102839-4 0-1102839-3 0-1102839-2 0-1102839-1 81 mm 81 mm HF-HIP-K.8.AG.N HF-EMV-K.8.AG.N HF-HIP-K.8.AG HF-EMV-K.8.AG 0-1102837-2 0-1102837-1 0-1102836-2 0-1102836-1 2xM40 2xM40 2xM50 2xM50 HF-HIP-K.12.Sto.2.M40G HF-EMV-K.12.Sto.2.M40G HF-HIP-K.12.Sto.2.M50G HF-EMV-K.12.Sto.2.M50G 0-1102840-2 0-1102840-1 0-1102840-4 0-1102840-3 HF-HIP-K.12.AG.N HF-EMV-K.12.AG.N HF-HIP-K.12.AG HF-EMVK-K.12.AG 0-1102838-2 0-1102838-1 0-1102192-2 0-1102192-1 Hood 126 120 1xM50 1xM50 2xM40 2xM40 184 57 M50 Housing bottom 0-1102839-3 81 20 Height 20 mm 20 mm 184 130 32 32 57 27 130 27 57 184 104 104 Hood 0-1102837-1 167 135 0-1102836-1 184 92 M50 M20 84 Housing bottom 0-1102840-3 81 20 Height 20 mm 20 mm 184 130 184 67 62 67 62 92 27 92 130 104 104 0-1102838-1 0-1102838-1 100 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 81 mm 81 mm HD-080 inserts INSERTS FOR H32B HOOD/HOUSING 80 (2x40)+  250V 10A (machined contacts) Dimensions (mm) Part Number Type Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HD-040-M(1-40) HD-040-M(41-80) T2020402101-000 T2020802101-000 HD-040-F(1-40) HD-040-F(41-80) T2020402201-000 T2020802201-000 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Distance for contact max. 24mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 101 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD-080 inserts INSERTS FOR H32B HOOD/HOUSING 80 (2x40)+ 250V 10A (stamped and formed contacts) Description Type Male insert Part Number Female insert Male insert Female insert Screw terminal 2xHD.40.Sti.C 2-1103012-3 2xHD.40.Bu.C Dimensions mm 2-1103013-3 A B C D E 77.5 84.5 33 35 35 C B Sti M3x10 *22,3 35 Suitable crimp contacts and crimping tools: see page 111 35 35 D E Bu DimensionsA (mm) B 27 33 77,5 84,5 Female insert 77,5 27 84,5 33 C Sti D A B C D M3x10 *19,5 27 77,5 33 84,5 77,5 Contact arrangement 84,5 Male insert 16 *Abstand für sichere Kontaktgabe max. 24 mm Bu 1 2 3 4 5 6 7 8 9 10 A B C D 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 D C B A 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 D C B A 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 1 2 3 4 5 6 7 8 9 10 E A 27 *Abstand für sichere Kontaktgabe max. 21 mm 5 M3 68,5 102 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 77,5 68,5 36 14 27 36 14 36 27 77,5 77,5 5 M3 68,5 14 M3 27 68,5 14 27 M3 5 36 5 77,5 HDD-144 inserts INSERTS FOR H32B HOOD/HOUSING 144 (2x72)+  250V 10A (machined contacts) Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HDD-072-M(1-72) HDD-072-M(73-144) T2030722101-000 T2031442101-000 T2030722201-000 T2031442201-000 HDD-072-F(1-72) HDD-072-F(73-144) 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Distance for contact max. 24mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 103 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H32B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG29 PG36 H32B-TS-PG29 H32B-TS-PG36 H32B-TS-M32 H32B-TS-M40 T1210320129-000 T1210320136-000 T1210320132-000 T1210320140-000 PG21 PG29 PG36 PG42 H32B-TG-PG21 H32B-TG-PG29 H32B-TG-PG36 H32B-TG-PG42 H32B-TG-M25 H32B-TG-M32 H32B-TG-M40 H32B-TG-M50 T1220320121-000 T1220320129-000 T1220320136-000 T1220320142-000 T1220320125-000 T1220320132-000 T1220320140-000 T1220320150-000 H32B-AG T1410322000-000 H32B-SGR-PG29 H32B-SGR-PG36 H32B-SGR-PG42 H32B-SGR-M32 H32B-SGR-M40 H32B-SGR-M50 H32B-SGR-M63 H32B-SGR-2PG29 H32B-SGR-2PG36 H32B-SGR-2PG42 H32B-SGR-2M32 H32B-SGR-2M40 H32B-SGR-2M50 H32B-SGR-2M63 T1440322129-000 T1440322136-000 T1440322142-000 T1440322132-000 T1440322140-000 T1440322150-000 T1440322163-000 T1440322229-000 T1440322236-000 T1440322242-000 T1440322232-000 T1440322240-000 T1440322250-000 T1440322263-000 H32B-TBF-PG29 H32B-TBF-PG36 H32B-TBF-PG42 H32B-TBF-M32 H32B-TBF-M40 H32B-TBF-M50 H32B-TBF-M63 T1710322129-000 T1710322136-000 T1710322142-000 T1710322132-000 T1710322140-000 T1710322150-000 T1710322163-000 H32B-KDB T1000321220-000 Hood: Side entry M32 M40 Hood: Top entry M25 M32 M40 M50 Bulkhead mounted Surface mounted: Side entry 1 Side entry M32 M40 M50 M63 2 Side entry M32 M40 M50 M63 PG29 PG36 PG42 PG29 PG36 PG42 Cable-to-cable hood M32 M40 M50 M63 PG29 PG36 PG42 Protection covers for hoods 104 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H32B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG29 PG36 H32B-TS-RO-PG29 H32B-TS-RO-PG36 H32B-TS-RO-M32 H32B-TS-RO-M40 T1310320129-000 T1310320136-000 T1310320132-000 T1310320140-000 PG21 PG29 PG36 PG42 H32B-TG-RO-PG21 H32B-TG-RO-PG29 H32B-TG-RO-PG36 H32B-TG-RO-PG42 H32B-TG-RO-M25 H32B-TG-RO-M32 H32B-TG-RO-M40 H32B-TG-RO-M50 T1320320121-000 T1320320129-000 T1320320136-000 T1320320142-000 T1320320125-000 T1320320132-000 T1320320140-000 T1320320150-000 H32B-AG-LB T1500322000-000 H32B-AD-LB T1510322000-000 H32B-SGR-LB-PG29 H32B-SGR-LB-M32 H32B-SGR-LB-M40 H32B-SGR-LB-2PG29 H32B-SGR-LB-2M32 H32B-SGR-LB-2M40 T1610322129-000 T1610322132-000 T1610322140-000 T1610322229-000 T1610322232-000 T1610322240-000 H32B-SDR-LB-PG29 H32B-SDR-LB-M32 H32B-SDR-LB-M40 H32B-SDR-LB-2PG29 H32B-SDR-LB-2M32 H32B-SDR-LB-2M40 T1620320129-000 T1620320132-000 T1620320140-000 T1620320229-000 T1620320232-000 T1620320240-000 Hood: Side entry M32 M40 Hood: Top entry M25 M32 M40 M50 Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry 2 Side entry 1 Side entry With protection cover M32 M40 M32 M40 M32 M40 2 Side entry M32 M40 PG29 PG29 PG29 PG29 105 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HD-128 inserts INSERTS FOR H48B HOOD/HOUSING 128 (2x64)+  250V 10A (machined contacts) Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HD-064-M(1-64) HD-064-M(65-128) T2020642101-000 T2021282101-000 HD-064-F(1-64) HD-064-F(65-128) T2020642201-000 T2021282201-000 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Distance for contact max. 24mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 106 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HD.128/HEE 92 contact inserts INSERTS FOR H48B HOOD/HOUSING 128 (2x64)+ 250V 10A (stamped and formed contacts) Description Type Male insert Part Number Female insert Male insert Female insert Crimp terminal 2xHD.64.Sti.C 2-1103032-3 Dimensions mm A B C D E 104 110 33 35 35 2-1103033-3 19.4 M3x10 C B Sti 35 2xHD.64.Bu.C E Bu Contact arrangement M3x10 1 Bu M3 20 27 104 M3 104 20 A *Abstand für sichere Kontaktgabe max. 21 mm 1 E 97 112 27 36 1 16 16 D *19,5 Female insert DCBA 1 C Sti 27 33 104 110 27 36 B Male insert 16 *Abstand für sichere Kontaktgabe max. 24 mm DCBA 16 16 DimensionsA (mm) 27 33 19.4 M3x10 104 110 M3x10 *22,3 Suitable crimp contacts and crimping tools: see page 111 35 D 97 112 2-1103112-3 2-1103112-3 107 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HDD-216 inserts INSERTS FOR H48B HOOD/HOUSING 216 (2x108)+  250V 10A (machined contacts) Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HDD-108-M(1-108) HDD-108-M(109-216) T2031082101-000 T2032162101-000 HDD-108-F(1-108) HDD-108-F(109-216) T2031082201-000 T2032162201-000 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Distance for contact max. 24mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 108 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H48B hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG29 PG36 PG42 H48B-TS-PG29 H48B-TS-PG36 H4SB-TS-PG42 H48B-TS-M32 H48B-TS-M40 H48B-TS-M50 H48B-TS-M63 T1310480129-000 T1310480136-000 T1310480142-000 T1310480132-000 T1310480140-000 T1310480150-000 T1310480163-000 PG29 PG36 PG42 H48B-TG-PG29 H48B-TG-PG36 H48B-TG-PG42 H48B-TG-M32 H48B-TG-M40 H48B-TG-M50 H48B-TG-M63 T1320480129-000 T1320480136-000 T1320480142-000 T1320480132-000 T1320480140-000 T1320480150-000 T1320480163-000 H48B-AG T1500482000-000 H48B-AD-LB T1510482000-000 H48B-SGR-PG29 H48B-SGR-PG36 H48B-SGR-PG42 H48B-SGR-M32 H48B-SGR-M40 H48B-SGR-M50 H48B-SGR-2PG29 H48B-SGR-2PG36 H48B-SGR-2PG42 H48B-SGR-2M32 H48B-SGR-2M40 H48B-SGR-2M50 T1610482129-000 T1610482136-000 T1610482142-000 T1610482132-000 T1610482140-000 T1610482150-000 T1610482229-000 T1610482236-000 T1610482242-000 T1610482232-000 T1610482240-000 T1610482250-000 H48B-SDR-PG29 H48B-SDR-PG36 H48B-SDR-PG42 H48B-SDR-M32 H48B-SDR-M40 H48B-SDR-M50 H48B-SDR-2PG29 H48B-SDR-2PG36 H48B-SDR-2PG42 H48B-SDR-2M32 H48B-SDR-2M40 H48B-SDR-2M50 T1620480129-000 T1620480136-000 T1620480142-000 T1620480132-000 T1620480140-000 T1620480150-000 T1620480229-000 T1620480236-000 T1620480242-000 T1620480232-000 T1620480240-000 T1620480250-000 Hood: Side entry M32 M40 M50 M63 Hood: Top entry M32 M40 M50 M63 Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry M32 M40 M50 2 Side entry M32 M40 M50 PG29 PG36 PG42 PG29 PG36 PG42 Surface mounted with cover 1 Side entry M32 M40 M50 2 Side entry M32 M40 M50 PG29 PG36 PG42 PG29 PG36 PG42 109 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Crimp contacts HN.D series 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 Crimping tools HN.D series Description Type Part Number CRIMPBOX-0.5/4 T3100000001-000 RSZ.HE-HN.D-HVT 1-1105851-8 REMOV-HD T3100000003-000 SCREWD-M3 T3100000009-000 Crimp tool Wire range: 0.5-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts Crimp tool Wire range: 0.14-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts with locator and die Removal tools Used for CDM/CDF contact series M3 screw driver Used for HA/HE inserts 110 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Crimp contacts HD.M series 10A Contact Tech data Material: copper alloy Finish: tin plated hard gold Contact resistance: ≤3mΩ Crimp Terminal: 0.14-2.5 mm2 AWG: 26-14 Description Type Part Number Dimensions (mm2) Pin contact tin plated 1-1105000-3 2-1105000-3 4-1105000-3 0.3-0.56 0.5-1.5 1.5-2.5 Reel contact/pin tin plated 0-0164161-9 0-0166824-2 0.5-1.5 1.5-2.5 Pin contact gold plated 1-1105000-2 3-1105000-2 0.3-0.56 0.8-1.5 Reel contact/pin gold plated 0-0164160-4 0-0164161-4 0.3-0.56 0.8-1.5 Socket contact tin plated 1-1105001-3 2-1105001-3 4-1105001-3 0.3-0.56 0.5-1.5 1.5-2.5 Socket contact gold plated 1-1105001-2 3-1105001-2 0.3-0.56 0.8-1.5 Reel contact/socket gold plated 1-0163087-1 0-0163083-7 0.3-0.56 0.8-1.5 24,2 11,7 ø1,6 Pin contact Socket contact 24,2 11,7 ø1,6 14,5 Type Wire cross section Stripping 14,5 length 1 0.2-0.56 mm2 3.5 mm 2 0.5-1.5 mm2 3.5 mm 3 0.8-1.5 mm2 3.5 mm 4 1.5-2.5 mm2 3.5 mm Crimping tools HD.M series Description Designation Part Number Cross section (mm2) Crimping tool without locator and die RSZ.BAS 539635-1 Locator and die ERGO-DIE XII 539742-2 Extraction tool HD.M AWZG-HD.M-RSZ 0-1102855-1 all cross sections Insertion tool EWZG-RSZ 0-1102855-6 below 0.75mm2 0.2-2.5mm2 for contacts PN 111 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Notes 112 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HE, HEE, HEEE Series 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 60 664-1 DIN EN 61 984 3. Approvals 113 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HE technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts.................................................6,10,16,24,32(2x16), ................................................................................................. 48(2x24) + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ..............................................................................≤1mΩ Terminal ................................................................................................ Crimp terminal ................................................................................................ Screw terminal ................................................................................................Spring terminal ................................................................................Double Spring terminal -mm2 Crimp terminal.................................................................................0.14-4.0 Screw terminal...................................................................................0.5-2.5 Spring terminal..................................................................................0.5-2.5 Double Spring terminal...................................................................0.2-2.5 -AWG Crimp terminal...................................................................................... 26-12 Screw terminal..................................................................................... 20-14 Spring terminal.................................................................................... 20-14 Double Spring terminal......................................................................26-14 - Tightening/test torque ..............................................................0.5 Nm HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 114 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Ambient temperature Wire gauge: 1.5 mm2 Ambient temperature Wire gauge: 2.5 mm2 Working current Working current ........................................................................... 16A max (See current carrying capacity) Working voltage ................................................................................. 500V Test voltage urms ................................................................................. 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range............................................................-40°C...+125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA.................................................. 600V Mechanical working life-mating cycles........................................ ≥500 Working current INSERTS 1 HDC-HE-006 2 HDC-HE-010 3 HDC-HE-016 4 HDC-HE-024 HEE technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts............................................ 10,18,32,46,64(2x32), ................................................................................................. 92(2x46) + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 16A max (See current carrying capacity) Working voltage ................................................................................. 500V Test voltage urms ................................................................................. 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA.................................................. 600V Mechanical working life-mating cycles........................................ ≥500 CONTACTS Working current INSERTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ..............................................................................≤1mΩ Terminal .............................................................................. Crimp terminal - mm2 ........................................................................................ 0.14-4.0mm2 - AWG ...................................................................................................... 26-12 Ambient temperature Wire gauge: 1.5 mm2 Ambient temperature Wire gauge: 2.5 mm2 HOODS, HOUSINGS Working current Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 1 HDC-HEE-010 2 HDC-HEE-018 3 HDC-HEE-032 4 HDC-HEE-046 115 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEEE technical characteristics CURRENT CARRYING CAPACITY Specifications.................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts..............................20,32,40,48,64,72,80(2x40) ......................................................96(2x48),128(2x64), 144(2x72) + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 16A max (See current carrying capacity) Working voltage.............................................................................................. HEEE-20,32,48,72,96,144.................................................................400V HEEE-40,64,80,128............................................................................. 500V Test voltage urms ................................................................................. 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA.................................................. 600V Mechanical working life-mating cycles........................................ ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance .............................................................................≤5mΩ Terminal .............................................................................. Crimp terminal - mm2 ........................................................................................ 0.14-4.0mm2 - AWG ...................................................................................................... 26-12 HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 116 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Operating current (A) INSERTS Ambient temperature (°C) 1 HEEE-064 / 1.5 mm2 2 HEEE-064 / 2.5 mm2 3 HEEE-064 / 4.0 mm2 4 HEEE-040 / 1.5 mm2 5 HEEE-040 / 2.5 mm2 HE-006 inserts INSERTS FOR H6B HOOD/HOUSING 500V MAX. 16A 6+ Dimension (mm) Type Part Number Male insert Female insert Screw terminal HE-006-M T2040062101-000 HE-006-F T2040062201-000 Spring terminal HE-006-MS T2040063101-000 HE-006-FS T2040063201-000 Crimp terminal (Order crimp contacts separately) HE-006-MC T2040064101-000 HE-006-FC T2040064201-000 Spring terminal (Two terminals per contact) HE-006-MSS T2040065101-000 HE-006-FSS T2040065201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Distance for contact max. 21mm HE Contact arrangement view from termination side a b c d 18 33 18 35 HES/HEC 19 34 19 36 HESS 34 49 32 49 Panel cut-out for inserts for use without hoods/housings 117 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEE-010 inserts INSERTS FOR H6B HOOD/HOUSING 500V MAX. 16A 10+  Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEE-010-M T2050102101-000 HEE-010-F Contact arrangement view from termination side T2050102201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 118 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Part Number HEEE-020 inserts INSERTS FOR H6B HOOD/HOUSING 400V MAX. 16A 20+  Type Dimensions (mm) Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEEE-020-M T2050202101-000 HEEE-020-F Contact arrangement view from termination side T2050202201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 119 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H6B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H6B-TS-PG16 H6B-TS-PG21 H6B-TS-M20 H6B-TS-M25 T1310060116-000 T1310060121-000 T1310060120-000 T1310060125-000 PG21 PG29 H6B-TSH-PG21 H6B-TSH-PG29 H6B-TSH-M20 H6B-TSH-M25 H6B-TSH-M32 T1330060121-000 T1330060129-000 T1330060120-000 T1330060125-000 T1330060132-000 PG16 PG21 H6B-TG-PG16 H6B-TG-PG21 H6B-TG-M20 H6B-TG-M25 T1320060116-000 T1320060121-000 T1320060120-000 T1320060125-000 PG21 PG29 H6B-TGH-PG21 H6B-TGH-PG29 H6B-TGH-M20 H6B-TGH-M25 H6B-TGH-M32 T1340060121-000 T1340060129-000 T1340060120-000 T1340060125-000 T1340060132-000 PG16 H6B-TBFS-PG16 H6B-TBFS-M20 H6B-TBFS-M25 H6B-TBFHS-PG21 H6B-TBFHS-PG29 H6B-TBFHS-M20 H6B-TBFHS-M25 H6B-TBFHS-M32 T1730062116-000 T1730062120-000 T1730062125-000 T1770062121-000 T1770062129-000 T1770062120-000 T1770062125-000 T1770062132-000 H6B-KDTP T1010061400-000 Hood: Side entry Low construction M20 M25 High construction M20 M25 M32 Hood: Top entry Low construction M20 M25 High construction M20 M25 M32 Cable-to-cable hood Low construction Construction M20 M25 H 62.5 Hight 74.5 High construction Low M20 M25 M32 PG21 PG29 Protection covers for hoods 120 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H6B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H6B-AGS T1500062000-000 H6B-ADS T1510062100-000 H6B-SGRS-PG16 H6B-SGRS-PG21 H6B-SGRS-M20 H6B-SGRS-M25 H6B-SGRS-2PG16 H6B-SGRS-2PG21 H6B-SGRS-2M20 H6B-SGRS-2M25 H6B-SGRHS-PG21 H6B-SGRHS-PG29 H6B-SGRHS-M25 H6B-SGRHS-M32 H6B-SGRHS-2PG21 H6B-SGRHS-2PG29 H6B-SGRHS-2M25 H6B-SGRHS-2M32 T1610062116-000 T1610062121-000 T1610062120-000 T1610062125-000 T1610062216-000 T1610062221-000 T1610062220-000 T1610062225-000 T1650062121-000 T1650062129-000 T1650062125-000 T1650062132-000 T1650062221-000 T1650062229-000 T1650062225-000 T1650062232-000 H6B-SDRS-PG16 H6B-SDRS-PG21 H6B-SDRS-M20 H6B-SDRS-M25 H6B-SDRS-2PG16 H6B-SDRS-2PG21 H6B-SDRS-2M20 H6B-SDRS-2M25 H6B-SDRHS-PG21 H6B-SDRHS-PG29 H6B-SDRHS-M25 H6B-SDRHS-M32 H6B-SDRHS-2PG21 H6B-SDRHS-2PG29 H6B-SDRHS-2M25 H6B-SDRHS-2M32 T1620062116-000 T1620062121-000 T1620062120-000 T1620062125-000 T1620062216-000 T1620062221-000 T1620062220-000 T1620062225-000 T1660062121-000 T1660062129-000 T1660062125-000 T1660062132-000 T1660062221-000 T1660062229-000 T1660062225-000 T1660062232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 40 52 56 Hight 45 57 74 Low 40 52 56 Hight 45 57 74 2 Side entry H High construction B 1 Side entry A 2 Side entry Low construction Construction 1 Side entry With protection cover 2 Side entry Low High construction H 1 Side entry B 2 Side entry Low construction A 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 121 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.6/16, HIP-K.6/16, EMV-K.6/16 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Screw lock on hood Description Metr. PG Type Part Number 16 HIP HIP.6/16.STS.1.16.G HIP.6/16.STS.1.M25.G 1-1102631-5 0-1106425-2 16 21 HIP-K HIP-K.6/16.STS.1.16.G HIP-K.6/16.STS.1.21.G HIP-K.6/16.STS.1.M25.G 2-1102631-5 2-1102633-5 0-1106425-4 16 EMV-K EMV-K.6/16.STS.1.16.G EMV-K.6/16.STS.1.M25.G 4-1102704-5 0-1106416-4 16 HIP HIP.6/16.STO.1.16.G HIP.6/16.STO.1.M32.G 1-1102635-5 0-1106425-1 HIP-K HIP-K.6/16.STO.1.16.G HIP-K.6/16.STO.1.21.G HIP-K.6/16.STO.1.M25.G HIP-K.6/16.STO.1.M32.G 2-1102635-5 2-1102637-5 0-1106425-6 0-1106425-3 EMV-K EMV-K.6/16.STO.1.13.G EMV-K.6/16.STO.1.16.G EMV-K.6/16.STO.1.21.G EMV-K.6/16.STO.1.M32.G 0-1108719-1 4-1102706-5 4-1102707-5 0-1106416-3 HIP HIP.6/16.AG 1-1102638-5 Hood: Side entry M25 M25 M25 Hood: Top entry M32 M25 M32 M32 16 21 13 16 21 8 22 Surface mounted housing: Bottom entry 70 96 ø4.5 32 56 HIP-K HIP-K.6/16.AG EMV-K EMV-K.6/16.AG M4 32 36 52 70 2-1102638-5 4-1102710-5 1-1102638-5 M6x20 M6x20 8 8 79 79 96 96 22 22 43 43 60 60 PanelM6cut-out M6 36 36 43 43 52 52 79 79 122 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP HIP.6/16.AG.M6 1-1102606-5 HIP-K HIP-K.6/16.AG.M6 2-1102606-5 EMV-K EMV-K.6/16.AG.M6 4-1102712-5 HIP.6/16, HIP-K.6/16, EMV-K.6/16 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Screw lock on hood Description Metr. PG Type Part Number 16 2x16 HIP HIP.6/16.SG.1.16.G HIP.6/16.SG.2.16.G HIP.6/16.SG.2.M32.G 1-1102604-5 1-1102605-5 0-1106424-1 HIP-K HIP-K.6/16.SG.1.16.G HIP-K.6/16.SG.2.16.G HIP-K.6/16.SG.2.M25.G HIP-K.6/16.SG.2.M32.G 2-1102604-5 2-1102605-5 0-1102942-1 0-1106424-2 EMV-K EMV-K.6/16.SG.1.16.G EMV-K.6/16.SG.2.16.G EMV-K.6/16.SG.2.M25.G EMV-K.6/16.SG.2.M32.G 5-1102708-5 5-1102709-5 0-1106413-3 0-1106415-2 HIP HIP/EMV.6/16.SKB 3-1106201-5 HIP-K HIP-K/EMV-K.6/16.SKB 4-1106201-5 EMV-K HIP-K/EMV-K.6/16.SKB 4-1106201-5 Surface mounted housing: Side entry 2xM32 2xM25 2xM32 2xM25 2xM32 16 2x16 16 2x16 Protective covers for housings M6x30 19 96 53 123 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HE-010 inserts INSERTS FOR H10B HOOD/HOUSING 500V MAX. 16A 10+ Dimension (mm) Type Part Number Male insert Female insert Screw terminal HE-010-M T2040102101-000 HE-010-F T2040102201-000 Spring terminal HE-010-MS T2040103101-000 HE-010-FS T2040103201-000 Crimp terminal (Order crimp contacts separately) HE-010-MC T2040104101-000 HE-010-FC T2040104201-000 Spring terminal (Two terminals per contact) HE-010-MSS T2040105101-000 HE-010-FSS T2040105201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Distance for contact max. 21mm HE Part Number Contact arrangement view from termination side a b c d 18 33 18 35 HES/HEC 19 34 19 36 HESS 34 49 32 49 124 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Panel cut-out for inserts for use without hoods/housings HEE-018 inserts INSERTS FOR H10B HOOD/HOUSING 500V MAX. 16A 18+ Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEE-018-M T2050182101-000 HEE-018-F Contact arrangement view from termination side T2050182201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 125 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEEE-032 inserts INSERTS FOR H10B HOOD/HOUSING 400V MAX. 16A 32+ Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEEE-032-M T2050323101-000 HEEE-032-F Contact arrangement view from termination side T2050323201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 126 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Part Number H10B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H10B-TS-PG16 H10B-TS-PG21 H10B-TS-M20 H10B-TS-M25 T1210100116-000 T1210100121-000 T1210100120-000 T1210100125-000 PG21 PG29 H10B-TSH-PG21 H10B-TSH-PG29 H10B-TSH-M20 H10B-TSH-M25 H10B-TSH-M32 T1230100121-000 T1230100129-000 T1230100120-000 T1230100125-000 T1230100132-000 PG16 PG21 H10B-TG-PG16 H10B-TG-PG21 H10B-TG-M20 H10B-TG-M25 T1220100116-000 T1220100121-000 T1220100120-000 T1220100125-000 PG21 PG29 H10B-TGH-PG21 H10B-TGH-PG29 H10B-TGH-M20 H10B-TGH-M25 H10B-TGH-M32 T1240100121-000 T1240100129-000 T1240100120-000 T1240100125-000 T1240100132-000 PG16 H10B-TBFS-PG16 H10B-TBFS-M20 H10B-TBFS-M25 H10B-TBFHS-PG21 H10B-TBFHS-PG29 H10B-TBFHS-M25 H10B-TBFHS-M32 T1710101116-000 T1710101120-000 T1710101125-000 T1750101121-000 T1750101129-000 T1750101125-000 T1750101132-000 H10B-KDTP T1010101400-000 H10B-KDBP T1010102100-000 Hood: Side entry Low construction M20 M25 High construction M20 M25 M32 Hood: Top entry Low construction M20 M25 High construction M20 M25 M32 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M20 M25 M25 M32 PG21 PG29 Protection covers for hoods Housing protection cover 127 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H10B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H10B-AGS T1410101000-000 H10B-SGRS-PG16 H10B-SGRS-PG21 H10B-SGRS-M20 H10B-SGRS-M25 H10B-SGRS-2PG16 H10B-SGRS-2PG21 H10B-SGRS-2M20 H10B-SGRS-2M25 H10B-SGRHS-PG21 H10B-SGRHS-PG29 H10B-SGRHS-M25 H10B-SGRHS-M32 H10B-SGRHS-2PG21 H10B-SGRHS-2PG29 H10B-SGRHS-2M25 H10B-SGRHS-2M32 T1440101116-000 T1440101121-000 T1440101120-000 T1440101125-000 T1440101216-000 T1440101221-000 T1440101220-000 T1440101225-000 T1470101121-000 T1470101129-000 T1470101125-000 T1470101132-000 T1470101221-000 T1470101229-000 T1470101225-000 T1470101232-000 H10B-TSBS-PG16 H10B-TSBS-PG21 H10B-TSBS-M20 H10B-TSBS-M25 H10B-TSBHS-PG21 H10B-TSBHS-PG29 H10B-TSBHS-M25 H10B-TSBHS-M32 T1250103116-000 T1250103121-000 T1250103120-000 T1250103125-000 T1270103121-000 T1270103129-000 T1270103125-000 T1270103132-000 H10B-TGBS-PG16 H10B-TGBS-PG21 H10B-TGBS-M20 H10B-TGBS-M25 H10B-TGBHS-PG21 H10B-TGBHS-PG29 H10B-TGBHS-M25 H10B-TGBHS-M32 T1260103116-000 T1260103121-000 T1260103120-000 T1260103125-000 T1280103121-000 T1280103129-000 T1280103125-000 T1280103132-000 H10B-AD-BO T1430100000-000 H10B-SDR-BO-PG16 H10B-SDR-BO-PG21 H10B-SDR-BO-M20 H10B-SDR-BO-M25 H10B-SDR-BO-2PG16 H10B-SDR-BO-2PG21 H10B-SDR-BO-2M20 H10B-SDR-BO-2M25 H10B-SDRH-BO-PG21 H10B-SDRH-BO-PG29 H10B-SDRH-BO-M25 H10B-SDRH-BO-M32 H10B-SDRH-BO-2PG21 H10B-SDRH-BO-2PG29 H10B-SDRH-BO-2M25 H10B-SDRH-BO-2M32 T1460100116-000 T1460100121-000 T1460100120-000 T1460100125-000 T1460100216-000 T1460100221-000 T1460100220-000 T1460100225-000 T1490100121-000 T1490100129-000 T1490100125-000 T1490100132-000 T1490100221-000 T1490100229-000 T1490100225-000 T1490100232-000 Bulkhead mounted Surface mounted: Side entry Hight 45 57 74 2 Side entry 56 High construction H 52 1 Side entry B 40 2 Side entry Low construction A Low 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction High construction Construction H Low 60 Hight 72 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction High construction Construction H Low 60 Hight 72 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover 2 Side entry Low construction 1 Side entry M20 M25 M20 M25 82 94 40 52 22 67 54 B C D F G H Hight 82 94 45 57 20 65 74 128 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry High construction A Low 1 Side entry Construction M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 H10B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H10B-TS-RO-PG16 H10B-TS-RO-PG21 H10B-TS-RO-M20 H10B-TS-RO-M25 T1310100116-000 T1310100121-000 T1310100120-000 T1310100125-000 PG21 PG29 H10B-TSH-RO-PG21 H10B-TSH-RO-PG29 H10B-TSH-RO-M20 H10B-TSH-RO-M25 H10B-TSH-RO-M32 T1330100121-000 T1330100129-000 T1330100120-000 T1330100125-000 T1330100132-000 PG16 PG21 H10B-TG-RO-PG16 H10B-TG-RO-PG21 H10B-TG-RO-M20 H10B-TG-RO-M25 T1320100116-000 T1320100121-000 T1320100120-000 T1320100125-000 PG21 PG29 H10B-TGH-RO-PG21 H10B-TGH-RO-PG29 H10B-TGH-RO-M20 H10B-TGH-RO-M25 H10B-TGH-RO-M32 T1340100121-000 T1340100129-000 T1340100120-000 T1340100125-000 T1340100132-000 PG16 H10B-TBF-LB-PG16 H10B-TBF-LB-M20 H10B-TBF-LB-M25 H10B-TBFH-LB-PG21 H10B-TBFH-LB-PG29 H10B-TBFH-LB-M25 H10B-TBFH-LB-M32 T1730103116-000 T1730103120-000 T1730103125-000 T1770103121-000 T1770103129-000 T1770103125-000 T1770103132-000 H10B-KDTP-LB T1010101500-000 Hood: Side entry Low construction M20 M25 High construction M20 M25 M32 Hood: Top entry Low construction M20 M25 High construction M20 M25 M32 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M20 M25 M25 M32 PG21 PG29 Protection covers for hoods 129 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H10B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H10B-AG-LB T1500103000-000 H10B-AD-LB H10B-ADM-LB T1510103000-000 T1510103001-000 H10B-SGR-LB-PG16 H10B-SGR-LB-PG21 H10B-SGR-LB-M20 H10B-SGR-LB-M25 H10B-SGR-LB-2PG16 H10B-SGR-LB-2PG21 H10B-SGR-LB-2M20 H10B-SGR-LB-2M25 H10B-SGRH-LB-PG21 H10B-SGRH-LB-PG29 H10B-SGRH-LB-M25 H10B-SGRH-LB-M32 H10B-SGRH-LB-2PG21 H10B-SGRH-LB-2PG29 H10B-SGRH-LB-2M25 H10B-SGRH-LB-2M32 T1610103116-000 T1610103121-000 T1610103120-000 T1610103125-000 T1610103216-000 T1610103221-000 T1610103220-000 T1610103225-000 T1650103121-000 T1650103129-000 T1650103125-000 T1650103132-000 T1650103221-000 T1650103229-000 T1650103225-000 T1650103232-000 H10B-SDR-LB-PG16 H10B-SDR-LB-PG21 H10B-SDR-LB-M20 H10B-SDR-LB-M25 H10B-SDR-LB-2PG16 H10B-SDR-LB-2PG21 H10B-SDR-LB-2M20 H10B-SDR-LB-2M25 H10B-SDRH-LB-PG21 H10B-SDRH-LB-PG29 H10B-SDRH-LB-M25 H10B-SDRH-LB-M32 H10B-SDRH-LB-2PG21 H10B-SDRH-LB-2PG29 H10B-SDRH-LB-2M25 H10B-SDRH-LB-2M32 T1620103116-000 T1620103121-000 T1620103120-000 T1620103125-000 T1620103216-000 T1620103221-000 T1620103220-000 T1620103225-000 T1660103121-000 T1660103129-000 T1660103125-000 T1660103132-000 T1660103221-000 T1660103229-000 T1660103225-000 T1660103232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 40 52 54 Hight 45 57 74 54 Hight 45 57 74 130 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry H 52 High construction B 40 1 Side entry A Low 2 Side entry Low construction Construction 1 Side entry With protection cover 2 Side entry Low High construction H 1 Side entry B 2 Side entry Low construction A 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 HIP.10/24, HIP-K.10/24, EMV-K.10/24 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 16 21 HIP HIP.10/24.STS.1.16.G HIP.10/24.STS.1.21.G HIP.10/24.STS.1.M25.G 1-1102640-5 1-1102642-5 0-1106436-2 HIP-K HIP-K.10/24.STS.1.21.G HIP-K.10/24.STS.1.M25.G HIP-K.10/24.STS.1.M32.G 2-1102642-5 0-1106436-4 0-1106436-6 EMV-K EMV-K.10/24.STS.1.21.G EMV-K.10/24.STS.1.M25.G EMV-K.10/24.STS.1.M32.G 4-1102714-5 0-1106427-3 1-1106427-0 HIP HIP.10/24.STO.1.16.G HIP.10/24.STO.1.21.G HIP.10/24.STO.1.M25.G 1-1102644-5 1-1102646-5 0-1106436-1 HIP-K HIP-K.10/24.STO.1.16.G HIP-K.10/24.STO.1.M25.G HIP-K.10/24.STO.1.M32.G 2-1102644-5 0-1106436-3 0-1106436-5 EMV-K EMV-K.10/24.STO.1.21.G EMV-K.10/24.STO.1.M25.G 4-1102715-5 0-1106427-4 HIP HIP.10/24.AG 1-1102647-5 Hood: Side entry, Standard construction M25 M25 M32 M25 M32 21 21 Hood: Top entry M25 M25 M32 M25 16 21 16 21 8 22 Surface mounted housing: Bottom entry 83 109 ø4,5 32 56 36 32 M4 65 83 HIP-K HIP-K.10/24.AG EMV-K EMV-K.10/24.AG 2-1102647-5 4-1102718-5 131 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.10/24, HIP-K.10/24, EMV-K.10/24 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Pressure-tight up to 5 bar IP 68 / IP 69 K Description Metr. PG Type Part Number HIP HIP.10/24.AG.M6 1-1102612-5 HIP-K HIP-K.10/24.AG.M6 2-1102612-5 EMV-K EMV-K.10/24.AG.M6 4-1102720-5 HIP HIP.10/24.SG.1.21.G HIP.10/24.SG.2.21.G HIP.10/24.SG.2.M32.G 1-1102610-5 1-1102611-5 0-1106435-1 HIP-K HIP-K.10/24.SG.1.21.G HIP-K.10/24.SG.2.21.G 5-1102610-5 2-1102611-5 EMV-K EMV-K.10/24.SG.1.21.G EMV-K.10/24.SG.2.21.G EMV-K.10/24.SG.2.M32.G 5-1102716-5 4-1102717-5 0-1106426-2 HIP HIP/EMV.10/24.SKB 3-1106202-5 Surface mounted housing: Bottom entry M6x20 22 22 M6x20 43 43 60 92 92 109 109 60 Panel cut-out M6 M6 3636 43 43 65 65 92 92 Surface mounted housing: Side entry 2xM32 21 2x21 21 2x21 2xM32 21 2x21 Protective covers for hoods and housing M6x30 19 109 53 132 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP-K/EMV-K HIP-K/EMV-K.10/24.SKB 4-1106202-5 HE-016 inserts INSERTS FOR H16B HOOD/HOUSING 500V MAX. 16A 16+ Dimension (mm) Part Number Type Male insert Female insert Screw terminal HE-016-M T2040162101-000 HE-016-F T2040162201-000 Spring terminal HE-016-MS T2040163101-000 HE-016-FS T2040163201-000 Crimp terminal (Order crimp contacts separately) HE-016-MC T2040164101-000 HE-016-FC T2040164201-000 Spring terminal (Two terminals per contact) HE-016-MSS T2040165101-000 HE-016-FSS T2040165201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Distance for contact max. 21mm HE Part Number Contact arrangement view from termination side a b c d 18 33 18 35 HES/HEC 19 34 19 36 HESS 34 49 32 49 Part Number Panel cut-out for inserts for use without hoods/housings 133 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEE-032 inserts INSERTS FOR H16B HOOD/HOUSING 500V MAX. 16A 32+ Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEE-032-M T2050322101-000 HEE-032-F Contact arrangement view from termination side T2050322201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 134 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Part Number HEEE-040 inserts INSERTS FOR H16B HOOD/HOUSING 500V MAX. 16A 40+  Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEEE-040-M T2050402101-000 HEEE-040-F Contact arrangement view from termination side T2050402201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 135 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEEE-048 inserts INSERTS FOR H16B HOOD/HOUSING 400V MAX. 16A 48+ Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEEE-048-F T2050482101-000 HEEE-048-F Contact arrangement view from termination side T2050482201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 136 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Part Number H16B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H16B-TS-PG16 H16B-TS-PG21 H16B-TS-M20 H16B-TS-M25 H16B-TS-M32 T1210160116-000 T1210160121-000 T1210160120-000 T1210160125-000 T1210160132-000 PG21 PG29 H16B-TSH-PG21 H16B-TSH-PG29 H16B-TSH-M25 H16B-TSH-M32 H16B-TSH-M40 T1230160121-000 T1230160129-000 T1230060125-000 T1230160132-000 T1230160140-000 PG16 PG21 H16B-TG-PG16 H16B-TG-PG21 H16B-TG-M25 H16B-TG-M32 T1220160116-000 T1220160121-000 T1220160125-000 T1220160132-000 PG21 PG29 H16B-TGH-PG21 H16B-TGH-PG29 H16B-TGH-M25 H16B-TGH-M32 H16B-TGH-M40 T1240160121-000 T1240160129-000 T1240160125-000 T1240160132-000 T1240160140-000 PG21 H16B-TBFS-PG21 H16B-TBFS-M25 H16B-TBFS-M32 H16B-TBFHS-PG21 H16B-TBFHS-PG29 H16B-TBFHS-M25 H16B-TBFHS-M32 H16B-TBFHS-M40 T1710161121-000 T1710161125-000 T1710161132-000 T1750161121-000 T1750161129-000 T1750161125-000 T1750161132-000 T1750161140-000 H16B-KDTP T1010161400-000 H16B-KDBP T1010162100-000 Hood: Side entry Low construction M20 M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods Housing protection cover 137 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H16B-AGS T1410161000-000 H16B-SGRS-PG21 H16B-SGRS-M25 H16B-SGRS-2PG21 H16B-SGRS-2M25 H16B-SGRHS-PG21 H16B-SGRHS-PG29 H16B-SGRHS-M25 H16B-SGRHS-M32 H16B-SGRHS-2PG21 H16B-SGRHS-2PG29 H16B-SGRHS-2M25 H16B-SGRHS-2M32 T1440161121-000 T1440161125-000 T1440161221-000 T1440161225-000 T1470161121-000 T1470161129-000 T1470161125-000 T1470161132-000 T1470161221-000 T1470161229-000 T1470161225-000 T1470161232-000 H16B-TSBS-PG16 H16B-TSBS-PG21 H16B-TSBS-M20 H16B-TSBS-M25 H16B-TSBHS-PG21 H16B-TSBHS-PG29 H16B-TSBHS-M25 H16B-TSBHS-M32 T1250163116-000 T1250163121-000 T1250163120-000 T1250163125-000 T1270163121-000 T1270163129-000 T1270163125-000 T1270163132-000 H16B-TGBS-PG16 H16B-TGBS-PG21 H16B-TGBS-M20 H16B-TGBS-M25 H16B-TGBHS-PG21 H16B-TGBHS-PG29 H16B-TGBHS-M25 H16B-TGBHS-M32 T1260163116-000 T1260163121-000 T1260163120-000 T1260163125-000 T1280163121-000 T1280163129-000 T1280163125-000 T1280163132-000 H16B-AD-BO T1430160000-000 H16B-SDR-BO-PG21 H16B-SDR-BO-M25 H16B-SDR-BO-2PG21 H16B-SDR-BO-2M25 H16B-SDRH-BO-PG21 H16B-SDRH-BO-PG29 H16B-SDRH-BO-M25 H16B-SDRH-BO-M32 H16B-SDRH-BO-2PG21 H16B-SDRH-BO-2PG29 H16B-SDRH-BO-2M25 H16B-SDRH-BO-2M32 T1460160121-000 T1460160125-000 T1460160221-000 T1460160225-000 T1490160121-000 T1490160129-000 T1490160125-000 T1490160132-000 T1490160221-000 T1490160229-000 T1490160225-000 T1490160232-000 Bulkhead mounted Surface mounted: Side entry 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction H Low 60 Hight 76 High construction Construction M20 M25 M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction High construction Construction H Low 60 Hight 76 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover Low construction D F G H Low 105 117 45 57 20 65 56 Hight 105 117 45 57 20 65 81 138 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry C High construction B 1 Side entry A 1 Side entry 2 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 H16B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 H16B-TS-RO-PG21 H16B-TS-RO-PG29 H16B-TS-RO-M25 H16B-TS-RO-M32 T1310160121-000 T1310160129-000 T1310160125-000 T1310160132-000 PG21 PG29 H16B-TSH-RO-PG21 H16B-TSH-RO-PG29 H16B-TSH-RO-M25 H16B-TSH-RO-M32 H16B-TSH-RO-M40 T1330160121-000 T1330160129-000 T1330160125-000 T1330160132-000 T1330160140-000 PG21 PG29 H16B-TG-RO-PG21 H16B-TG-RO-PG29 H16B-TG-RO-M25 H16B-TG-RO-M32 T1320160121-000 T1320160129-000 T1320160125-000 T1320160132-000 PG21 PG29 H16B-TGH-RO-PG21 H16B-TGH-RO-PG29 H16B-TGH-RO-M25 H16B-TGH-RO-M32 H16B-TGH-RO-M40 T1340160121-000 T1340160129-000 T1340160125-000 T1340160132-000 T1340160140-000 PG21 PG29 H16B-TBF-LB-PG21 H16B-TBF-LB-PG29 H16B-TBF-LB-M25 H16B-TBF-LB-M32 H16B-TBFH-LB-PG21 H16B-TBFH-LB-PG29 H16B-TBFH-LB-M25 H16B-TBFH-LB-M32 H16B-TBFH-LB-M40 T1730163121-000 T1730163129-000 T1730163125-000 T1730163132-000 T1770163121-000 T1770163129-000 T1770163125-000 T1770163132-000 T1770163140-000 H16B-KDTP-LB T1010161500-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood Low construction Construction H 62.5 Hight 74.5 High construction Low M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods 139 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H16B-AG-LB T1500163000-000 H16B-AD-LB T1510163000-000 H16B-SGR-LB-PG16 H16B-SGR-LB-PG21 H16B-SGR-LB-M20 H16B-SGR-LB-M25 H16B-SGR-LB-2PG16 H16B-SGR-LB-2PG21 H16B-SGR-LB-2M20 H16B-SGR-LB-2M25 H16B-SGRH-LB-PG21 H16B-SGRH-LB-PG29 H16B-SGRH-LB-M25 H16B-SGRH-LB-M32 H16B-SGRH-LB-2PG21 H16B-SGRH-LB-2PG29 H16B-SGRH-LB-2M25 H16B-SGRH-LB-2M32 T1610163116-000 T1610163121-000 T1610163120-000 T1610163125-000 T1610163216-000 T1610163221-000 T1610163220-000 T1610163225-000 T1650163121-000 T1650163129-000 T1650163125-000 T1650163132-000 T1650163221-000 T1650163229-000 T1650163225-000 T1650163232-000 H16B-SDR-LB-PG16 H16B-SDR-LB-PG21 H16B-SDR-LB-M20 H16B-SDR-LB-M25 H16B-SDR-LB-2PG16 H16B-SDR-LB-2PG21 H16B-SDR-LB-2M20 H16B-SDR-LB-2M25 H16B-SDRH-LB-PG21 H16B-SDRH-LB-PG29 H16B-SDRH-LB-M25 H16B-SDRH-LB-M32 H16B-SDRH-LB-2PG21 H16B-SDRH-LB-2PG29 H16B-SDRH-LB-2M25 H16B-SDRH-LB-2M32 T1620163116-000 T1620163121-000 T1620163120-000 T1620163125-000 T1620163216-000 T1620163221-000 T1620163220-000 T1620163225-000 T1660163121-000 T1660163129-000 T1660163125-000 T1660163132-000 T1660163221-000 T1660163229-000 T1660163225-000 T1660163232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 140 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry 81 High construction Hight 1 Side entry 56 2 Side entry H Low Low construction Construction 1 Side entry With protection cover 2 Side entry 81 High construction Hight 1 Side entry 56 2 Side entry Low construction H Low 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 HIP.16/40, HIP-K.16/40, EMV-K.16/40 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 21 29 HIP HIP.16/40.STS.1.21.G HIP.16/40.STS.1.29.G HIP.16/40.STS.1.M32.G 1-1102649-5 1-1102651-5 0-1106454-2 29 HIP-K HIP-K.16/40.STS.1.29.G HIP-K.16/40.STS.1.M32.G 2-1102651-5 0-1106444-2 EMV-K EMV-K.16/40.STS.1.29.G EMV-K.16/40.STS.1.M32.G EMV-K.16/40.STS.1.21.G 4-1102723-5 0-1106446-4 4-1102722-5 21 29 HIP HIP.16/40.STO.1.21.G HIP.16/40.STO.1.29.G HIP.16/40.STO.1.M32.G 1-1102653-5 1-1102655-5 0-1106454-1 21 29 HIP-K HIP-K.16/40.STO.2.21.G HIP-K.16/40.STO.1.29.G HIP-K.16/40.STO.1.M32.G 0-1108534-1 2-1102655-5 0-1106444-1 29 EMV-K EMV-K.16/40.STO.1.29.G EMV-K.16/40.STO.1.M32.G 4-1102725-5 0-1106446-3 HIP HIP.16/40.AG 1-1102656-5 Hood: Side entry M32 M32 M32 29 21 Hood: Top entry M32 M32 M32 8 22 Surface mounted housing: Bottom entry 22 ø4.5 8 103 129.5 ø4.5 32 56 32 56 103 129.5 HIP-K HIP-K.16/40.AG EMV-K EMV-K.16/40.AG Panel cut-out M4 32 36 32 36 M4 86 86 103103 M6x20 1-1102656-5 8 M6x20 1-1102656-5 112.5 129.5 43 60 Panel cut-out 112.5 86 112.5 86 M6 M6 36 36 45 43 22 60 8 112.5 129.5 22 45 2-1102656-5 4-1102728-5 HIP HIP.16/40.AG.M6 1-1102618-5 HIP-K HIP-K.16/40.AG.M6 2-1102618-5 EMV-K EMV-K.16/40.AG.M6 4-1102730-5 141 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.16/40, HIP-K.16/40, EMV-K.16/40 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Pressure-tight up to 5 bar IP 68 / IP 69 K Description Metr. PG Type Part Number 21 2x21 HIP HIP.16/40.SG.1.21.G HIP.16/40.SG.2.21.G HIP.16/40.SG.2.M32.G 1-1102616-5 1-1102617-5 0-1106453-1 21 2x21 HIP-K HIP-K.16/40.SG.1.21.G HIP-K.16/40.SG.2.21.G HIP-K.16/40.SG.2.M32.G 5-1102616-5 2-1102617-5 0-1106443-1 21 2x21 EMV-K EMV-K.16/40.SG.1.21.Z EMV-K.16/40.SG.2.21.Z EMV-K.16/40.SG.2.M32.G 4-1102726-5 4-1102727-5 0-1106445-2 HIP HIP/EMV.16/40.SKB 3-1106203-5 HIP-K HIP-K.16/40.SKB 4-1106203-5 Surface mounted housing: Side entry 2xM32 2xM32 2xM32 Protective covers for housings M6x30 19 129.5 53 142 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HE-024 inserts INSERTS FOR H24B HOOD/HOUSING 500V MAX. 16A 24+  Dimension (mm) Part Number Type Male insert Female insert Screw terminal HE-024-M T2040242101-000 HE-024-F T2040242201-000 Spring terminal HE-024-MS T2040243101-000 HE-024-FS T2040243201-000 Crimp terminal (Order crimp contacts separately) HE-024-MC T2040244101-000 HE-024-FC T2040244201-000 Spring terminal (Two terminals per contact) HE-024-MSS T2040245101-000 HE-024-FSS T2040245201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 143 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEE-046 inserts INSERTS FOR H24B HOOD/HOUSING 500V MAX. 16A 46+  Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEE-046-M T2050462101-000 HEE-046-F Contact arrangement view from termination side T2050462201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 144 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Part Number HEEE-064 inserts INSERTS FOR H24B HOOD/HOUSING 500V MAX. 16A 64+  Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEEE-064-M T2050643101-000 HEEE-064-F Contact arrangement view from termination side T2050643201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 145 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEEE-072 inserts INSERTS FOR H24B HOOD/HOUSING 400V MAX. 16A 72+  Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HEEE-072-M T2050722101-000 HEEE-072-F Contact arrangement view from termination side T2050722201-000 Panel cut out for inserts for use without hoods/housings 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 146 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Part Number H24B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H24B-TS-PG16 H24B-TS-PG21 H24B-TS-M25 H24B-TS-M32 T1210240116-000 T1210240121-000 T1210240125-000 T1210240132-000 PG21 PG29 H24B-TSH-PG21 H24B-TSH-PG29 H24B-TSH-M25 H24B-TSH-M32 H24B-TSH-M40 T1230240121-000 T1230240129-000 T1230240125-000 T1230240132-000 T1230240140-000 PG16 PG21 H24B-TG-PG16 H24B-TG-PG21 H24B-TG-M25 H24B-TG-M32 T1220240116-000 T1220240121-000 T1220240125-000 T1220240132-000 PG21 PG29 H24B-TGH-PG21 H24B-TGH-PG29 H24B-TGH-M25 H24B-TGH-M32 H24B-TGH-M40 T1240240121-000 T1240240129-000 T1240240125-000 T1240240132-000 T1240240140-000 PG21 H24B-TBFS-PG21 H24B-TBFS-M25 H24B-TBFS-M32 H24B-TBFHS-PG21 H24B-TBFHS-PG29 H24B-TBFHS-M25 H24B-TBFHS-M32 H24B-TBFHS-M40 T1710241121-000 T1710241125-000 T1710241132-000 T1750241121-000 T1750241129-000 T1750241125-000 T1750241132-000 T1750241140-000 H24B-KDTP T1010241400-000 H24B-KDBP T1010242100-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 78.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods Housing protection cover 147 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H24B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H24B-AGS T1410241000-000 H24B-SGRS-PG21 H24B-SGRS-M25 H24B-SGRS-2PG21 H24B-SGRS-2M25 H24B-SGRHS-PG21 H24B-SGRHS-PG29 H24B-SGRHS-M25 H24B-SGRHS-M32 H24B-SGRHS-2PG21 H24B-SGRHS-2PG29 H24B-SGRHS-2M25 H24B-SGRHS-2M32 T1440241121-000 T1440241125-000 T1440241221-000 T1440241225-000 T1470241121-000 T1470241129-000 T1470241125-000 T1470241132-000 T1470241221-000 T1470241229-000 T1470241225-000 T1470241232-000 H24B-TSBS-PG16 H24B-TSBS-PG21 H24B-TSBS-M20 H24B-TSBS-M25 H24B-TSBHS-PG21 H24B-TSBHS-PG29 H24B-TSBHS-M25 H24B-TSBHS-M32 T1250243116-000 T1250243121-000 T1250243120-000 T1250243125-000 T1270243121-000 T1270243129-000 T1270243125-000 T1270243132-000 H24B-TGBS-PG16 H24B-TGBS-PG21 H24B-TGBS-M20 H24B-TGBS-M25 H24B-TGBHS-PG21 H24B-TGBHS-PG29 H24B-TGBHS-M25 H24B-TGBHS-M32 T1260243116-000 T1260243121-000 T1260243120-000 T1260243125-000 T1280243121-000 T1280243129-000 T1280243125-000 T1280243132-000 H24B-AD-BO T1430240000-000 H24B-SDR-BO-PG21 H24B-SDR-BO-M25 H24B-SDR-BO-2PG21 H24B-SDR-BO-2M25 H24B-SDRH-BO-PG21 H24B-SDRH-BO-PG29 H24B-SDRH-BO-M25 H24B-SDRH-BO-M32 H24B-SDRH-BO-2PG21 H24B-SDRH-BO-2PG29 H24B-SDRH-BO-2M25 H24B-SDRH-BO-2M32 T1460240121-000 T1460240125-000 T1460240221-000 T1460240225-000 T1490240121-000 T1490240129-000 T1490240125-000 T1490240132-000 T1490240221-000 T1490240229-000 T1490240225-000 T1490240232-000 Bulkhead mounted Surface mounted: Side entry 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction H Low 60 Hight 76 High construction Construction M20 M25 M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction H Low 60 Hight 76 High construction Construction M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover Low construction D F G H Low 132 144 45 57 20 65 56 Hight 132 144 45 57 20 65 81 148 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry C High construction B 1 Side entry A 1 Side entry 2 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 H24B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 H24B-TS-RO-PG21 H24B-TS-RO-PG29 H24B-TS-RO-M25 H24B-TS-RO-M32 T1310240121-000 T1310240129-000 T1310240125-000 T1310240132-000 PG21 PG29 H24B-TSH-RO-PG21 H24B-TSH-RO-PG29 H24B-TSH-RO-M25 H24B-TSH-RO-M32 H24B-TSH-RO-M40 T1330240121-000 T1330240129-000 T1330240125-000 T1330240132-000 T1330240140-000 PG21 PG29 H24B-TG-RO-PG21 H24B-TG-RO-PG29 H24B-TG-RO-M25 H24B-TG-RO-M32 T1320240121-000 T1320240129-000 T1320240125-000 T1320240132-000 PG21 PG29 H24B-TGH-RO-PG21 H24B-TGH-RO-PG29 H24B-TGH-RO-M25 H24B-TGH-RO-M32 H24B-TGH-RO-M40 T1340240121-000 T1340240129-000 T1340240125-000 T1340240132-000 T1340240140-000 PG21 PG29 H24B-TBF-LB-PG21 H24B-TBF-LB-PG29 H24B-TBF-LB-M25 H24B-TBF-LB-M32 H24B-TBFH-LB-PG21 H24B-TBFH-LB-PG29 H24B-TBFH-LB-M25 H24B-TBFH-LB-M32 H24B-TBFH-LB-M40 T1730242121-000 T1730242129-000 T1730242125-000 T1730242132-000 T1770243121-000 T1770243129-000 T1770243125-000 T1770243132-000 T1770243140-000 H24B-KDTP-LB T1010241500-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood Low construction Construction H 62.5 Hight 78.5 High construction Low M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods 149 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H24B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H24B-AG-LB T1500243000-000 H24B-AD-LB T1510243000-000 H24B-SGR-LB-PG16 H24B-SGR-LB-PG21 H24B-SGR-LB-M20 H24B-SGR-LB-M25 H24B-SGR-LB-2PG16 H24B-SGR-LB-2PG21 H24B-SGR-LB-2M20 H24B-SGR-LB-2M25 H24B-SGRH-LB-PG21 H24B-SGRH-LB-PG29 H24B-SGRH-LB-M25 H24B-SGRH-LB-M32 H24B-SGRH-LB-2PG21 H24B-SGRH-LB-2PG29 H24B-SGRH-LB-2M25 H24B-SGRH-LB-2M32 T1610243116-000 T1610243121-000 T1610243120-000 T1610243125-000 T1610243216-000 T1610243221-000 T1610243220-000 T1610243225-000 T1650243121-000 T1650243129-000 T1650243125-000 T1650243132-000 T1650243221-000 T1650243229-000 T1650243225-000 T1650243232-000 H24B-SDR-LB-PG16 H24B-SDR-LB-PG21 H24B-SDR-LB-M20 H24B-SDR-LB-M25 H24B-SDR-LB-2PG16 H24B-SDR-LB-2PG21 H24B-SDR-LB-2M20 H24B-SDR-LB-2M25 H24B-SDRH-LB-PG21 H24B-SDRH-LB-PG29 H24B-SDRH-LB-M2S H24B-SDRH-LB-M32 H24B-SDRH-LB-2PG21 H24B-SDRH-LB-2PG29 H24B-SDRH-LB-2M25 H24B-SDRH-LB-2M32 T1620243116-000 T1620243121-000 T1620243120-000 T1620243125-000 T1620243216-000 T1620243221-000 T1620243220-000 T1620243225-000 T1660243121-000 T1660243129-000 T1660243125-000 T1660243132-000 T1660243221-000 T1660243229-000 T1660243225-000 T1660243232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 81 150 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry H Low construction Construction 1 Side entry With protection cover 2 Side entry Hight High construction 56 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 HIP.24/64, HIP-K.24/64, EMV-K.24/64 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number HIP HIP.24/64.AG 1-1102665-5 HIP-K HIP-K.24/64.AG 2-1102665-5 EMV-K EMV-K.24/64.AG 4-1102760-5 HIP HIP.24/64.AG.M6 1-1102626-5 HIP-K HIP-K.24/64.AG.M6 HIP-K.24/64.AG.M6.D HIP-K-I.24/64.AG.M6.D 2-1102626-5 2-1102628-5 0-1108533-1 EMV-K EMV-K.24/64.AG.M6 4-1102736-5 HIP HIP.24/64.SG.1.29.G HIP.24/64.SG.2.29.G HIP.24/64.SG.2.M40.G 1-1102624-5 1-1102625-5 0-1106472-1 8 22 Surface mounted housing: Bottom entry, Standard construction 130 156 ø4.5 32 56 32 35 130 112 M4 M6x20 22 1-1102665-5 139 156 8 43 60 139 112 35 43 M6 Surface mounted housing: Side entry, Standard construction 2xM40 2xM40 2xM40 29 2x29 29 2x29 29 2x29 HIP-K HIP-K.24/64.SG.1.29.G HIP-K.24/64.SG.2.29.G HIP-K.24/64.SG.2.M40.G EMV-K EMV-K.24/64.SG.1.29.G EMV-K.24/64.SG.2.29.G EMV-K.24/64.SG.2.M40.G 5-1102624-5 2-1102625-5 0-1106472-2 4-1102734-5 4-1102735-5 0-1106460-2 Protective cover housings M6x30 19 156 53 HIP HIP/EMV.24/64.SKB 3-1106204-5 HIP-K/EMV-K HIP-K/EMV-K.24/64.SKB 4-1106204-5 151 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.24/64, HIP-K.24/64, EMV-K.24/64 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 21 29 HIP HIP.24/64.STS.1.21.G HIP.24/64.STS.1.29 G HIP.24/64.STS.1.M40.G 1-1102658-5 1-1102660-5 0-1106473-2 29 HIP-K HIP-K.24/64.STS.1.29.G HIP-K.24/64.STS.1.M40.G 2-1102660-5 0-1106473-4 EMV-K EMV-K.24/64.STS.1.29.G EMV-K.24/64.STS.1.M25.G EMV-K.24/64.STS.1.M32.G EMV-K.24/64.STS.1.M40.G 4-1102755-5 0-1102983-1 0-1106461-8 0-1106461-3 29 36 HIP HIP-KF.24/64.STS.1.29.G HIP-KF.24/64.STS.1.36.G HIP-KF.24/64.STS.1.M40.G 1-1102622-5 1-1102623-5 0-1106474-1 29 36 HIP-K HIP-KF/K.24/64.STS.1.29.G HIP-KF/K. 24/64.STS.1.36G HIP-KF/K.24/64.STS.1.M40.G 2-1102622-5 2-1102623-5 0-1106474-2 29 36 EMV-K EMV-KF/K.24/64.STS.1.29.G EMV-KF/K.24/64.STS.1.36.G EMV-KF/K.24/64.STS.1.M40.G 4-1102732-5 4-1102733-5 0-1106462-2 21 29 HIP HIP.24/64.STO.1.21.G HIP.24/64.STO.1.29.G HIP.24/64.STO.1.M40.G 1-1102662-5 1-1102664-5 0-1106473-1 Hood: Side entry, Standard construction M40 M40 M25 M32 M40 M40 M40 M40 29 Hood: Top entry, Standard construction M40 2xM32 M40 M/PG 90 57 142 156 M40 2xM40 29 53 29 2xM40 3-1102759-5 2xM40 152 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP-K HIP-K.24/64.STO.1.29.G HIP-K.24/64.STO.2.M32.G HIP-K.24/64.STO.1.M40.G EMV-K EMV-K.24/64.STO.1.29.G EMV-K.24/64.STO.1.M40.G 2-1102664-5 0-1102792-1 0-1106473-3 4-1102759-5 0-1106461-4 HF-HIP-K 8/HF-EMV-K 8, HF-HIP-K 12/HF-EMV-K 12 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood Description Metr. PG Type Part Number HF-HIP-K.8.Sto.1.M50G HF.8.EMV-K.8.Sto.1.M50G HF.HIP-K.8.Sto.2.M40G HF.EMV-K.8.Sto.2.M40G 0-1102839-4 0-1102839-3 0-1102839-2 0-1102839-1 81 mm 81 mm HF-HIP-K.8.AG.N HF-EMV-K.8.AG.N HF-HIP-K.8.AG HF-EMV-K.8.AG 0-1102837-2 0-1102837-1 0-1102836-2 0-1102836-1 2xM40 2xM40 2xM50 2xM50 HF-HIP-K.12.Sto.2.M40G HF-EMV-K.12.Sto.2.M40G HF-HIP-K.12.Sto.2.M50G HF-EMV-K.12.Sto.2.M50G 0-1102840-2 0-1102840-1 0-1102840-4 0-1102840-3 HF-HIP-K.12.AG.N HF-EMV-K.12.AG.N HF-HIP-K.12.AG HF-EMVK-K.12.AG 0-1102838-2 0-1102838-1 0-1102192-2 0-1102192-1 Hood 126 120 1xM50 1xM50 2xM40 2xM40 184 57 M50 Housing bottom 0-1102839-3 81 20 Height 20 mm 20 mm 184 130 32 32 57 27 130 27 57 184 104 104 Hood 0-1102837-1 167 135 0-1102836-1 184 92 M50 M20 84 Housing bottom 0-1102840-3 81 20 Height 20 mm 20 mm 184 130 184 67 62 67 62 92 27 92 130 104 104 81 mm 81 mm 0-1102838-1 0-1102838-1 153 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HE-032 inserts INSERTS FOR H32B HOOD/HOUSING 500V MAX. 16A 32 (2x16)+  Dimension (mm) Part Number Type Male insert Female insert Screw terminal HE-016-M(1-16) HE-016-M(17-32) T2040162101-000 T2040322101-000 HE-016-F(1-16) HE-016-F(17-32) T2040162201-000 T2040322201-000 Spring terminal HE-016-MS(1-16) HE-016-MS(17-32) T2040163101-000 T2040323101-000 HE-016-FS(1-16) HE-016-FS(17-32) T2040163201-000 T2040323201-000 Crimp terminal (Order crimp contacts separately) HE-016-MC(1-16) HE-016-MC(17-32) T2040164101-000 T2040324101-000 HE-016-FC(1-16) HE-016-FC(17-32) T2040164201-000 T2040324201-000 Spring terminal (Two terminals per contact) HE-016-MSS(1-16) HE-016-MSS(17-32) T2040165101-000 T2040325101-000 HE-016-FSS(1-16) HE-016-FSS(17-32) T2040165201-000 T2040325201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 154 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Part Number HEE-064 inserts INSERTS FOR H32B HOOD/HOUSING 500V MAX. 16A 64 (2x32)+  Dimensions (mm) Part Number Type Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HEE-032-M(1-32) HEE-032-M(33-64) T2050322101-000 T2050642101-000 HEE-032-F(1-32) HEE-032-F(33-64) T2050322201-000 T2050642201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Distance for contact max. 21mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 155 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEEE-080 inserts INSERTS FOR H32B HOOD/HOUSING 500V MAX. 16A 80+  Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HEEE-040-M(1-40) HEEE-040-M(41-80) T2050402101-000 T2050802101-000 HEEE-040-F(1-40) HEEE-040-F(41-80) T2050402201-000 T2050802201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Distance for contact max. 21mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 156 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HEEE-096 inserts INSERTS FOR H32B HOOD/HOUSING 400V MAX. 16A 96+  Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HEEE-048-M(1-48) HEEE-048-M(49-96) T2050482101-000 T2050962101-000 HEEE-048-F(1-48) HEEE-048-F(49-96) T2050482201-000 T2050962201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Distance for contact max. 21mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 157 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H32B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG29 PG36 H32B-TS-PG29 H32B-TS-PG36 H32B-TS-M32 H32B-TS-M40 T1210320129-000 T1210320136-000 T1210320132-000 T1210320140-000 PG21 PG29 PG36 PG42 H32B-TG-PG21 H32B-TG-PG29 H32B-TG-PG36 H32B-TG-PG42 H32B-TG-M25 H32B-TG-M32 H32B-TG-M40 H32B-TG-M50 T1220320121-000 T1220320129-000 T1220320136-000 T1220320142-000 T1220320125-000 T1220320132-000 T1220320140-000 T1220320150-000 H32B-AG T1410322000-000 H32B-SGR-PG29 H32B-SGR-PG36 H32B-SGR-PG42 H32B-SGR-M32 H32B-SGR-M40 H32B-SGR-M50 H32B-SGR-M63 H32B-SGR-2PG29 H32B-SGR-2PG36 H32B-SGR-2PG42 H32B-SGR-2M32 H32B-SGR-2M40 H32B-SGR-2M50 H32B-SGR-2M63 T1440322129-000 T1440322136-000 T1440322142-000 T1440322132-000 T1440322140-000 T1440322150-000 T1440322163-000 T1440322229-000 T1440322236-000 T1440322242-000 T1440322232-000 T1440322240-000 T1440322250-000 T1440322263-000 H32B-TBF-PG29 H32B-TBF-PG36 H32B-TBF-PG42 H32B-TBF-M32 H32B-TBF-M40 H32B-TBF-M50 H32B-TBF-M63 T1710322129-000 T1710322136-000 T1710322142-000 T1710322132-000 T1710322140-000 T1710322150-000 T1710322163-000 H32B-KDB T1000321220-000 Hood: Side entry M32 M40 Hood: Top entry M25 M32 M40 M50 Bulkhead mounted Surface mounted: Side entry 1 Side entry M32 M40 M50 M63 2 Side entry M32 M40 M50 M63 PG29 PG36 PG42 PG29 PG36 PG42 Cable-to-cable hood M32 M40 M50 M63 PG29 PG36 PG42 Protection covers for hoods 158 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H32B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG29 PG36 H32B-TS-RO-PG29 H32B-TS-RO-PG36 H32B-TS-RO-M32 H32B-TS-RO-M40 T1310320129-000 T1310320136-000 T1310320132-000 T1310320140-000 PG21 PG29 PG36 PG42 H32B-TG-RO-PG21 H32B-TG-RO-PG29 H32B-TG-RO-PG36 H32B-TG-RO-PG42 H32B-TG-RO-M25 H32B-TG-RO-M32 H32B-TG-RO-M40 H32B-TG-RO-M50 T1320320121-000 T1320320129-000 T1320320136-000 T1320320142-000 T1320320125-000 T1320320132-000 T1320320140-000 T1320320150-000 H32B-AG-LB T1500322000-000 H32B-AD-LB T1510322000-000 H32B-SGR-LB-PG29 H32B-SGR-LB-M32 H32B-SGR-LB-M40 H32B-SGR-LB-2PG29 H32B-SGR-LB-2M32 H32B-SGR-LB-2M40 T1610322129-000 T1610322132-000 T1610322140-000 T1610322229-000 T1610322232-000 T1610322240-000 H32B-SDR-LB-PG29 H32B-SDR-LB-M32 H32B-SDR-LB-M40 H32B-SDR-LB-2PG29 H32B-SDR-LB-2M32 H32B-SDR-LB-2M40 T1620320129-000 T1620320132-000 T1620320140-000 T1620320229-000 T1620320232-000 T1620320240-000 Hood: Side entry M32 M40 Hood: Top entry M25 M32 M40 M50 Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry M32 M40 2 Side entry M32 M40 With protection cover 1 Side entry M32 M40 2 Side entry M32 M40 PG29 PG29 PG29 PG29 159 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HE-048 inserts INSERTS FOR H48B HOOD/HOUSING 500V MAX. 16A 48 (2x24)+ Dimension (mm) Type Part Number Male insert Female insert Screw terminal HE-024-M(1-24) HE-024-M(25-48) T2040242101-000 T2040482101-000 HE-024-F(1-24) HE-024-F(25-18) T2040242201-000 T2040482201-000 Spring terminal HE-024-MS(1-24) HE-024-MS(25-48) T2040243101-000 T2040483101-000 HE-024-FS(1-24) HE-024-FS(25-48) T2040243201-000 T2040483201-000 Crimp terminal (Order crimp contacts separately) HE-024-MC(1-24) HE-024-MC(25-48) T2040244101-000 T2040484101-000 HE-024-FC(1-24) HE-024-FC(25-48) T2040244201-000 T2040484201-000 Spring terminal (Two terminals per contact) HE-024-MSS(1-24) HE-024-MSS(25-48) T2040245101-000 T2040485101-000 HE-024-FSS(1-24) HE-024-FSS(25-48) T2040245201-000 T2040485201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Distance for contact max. 21mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Contact arrangement view from termination side 160 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Panel cut-out for inserts for use without hoods/housings Part Number HEE-092 inserts INSERTS FOR H48B HOOD/HOUSING 500V MAX. 16A 92 (2x46)+  Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HEE-046-M(1-46) HEE-046-M(47-92) T2050462101-000 T2050922101-000 HEE-046-F(1-46) HEE-046-F(47-92) T2050462201-000 T2050922201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Distance for contact max. 21mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 161 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEEE-128 inserts INSERTS FOR H48B HOOD/HOUSING 500V MAX. 16A 128+  Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HEEE-064-M(1-64) HEEE-128-M(65-128) T2050643101-000 T2051283101-000 HEEE-064-F(1-64) HEEE-128-F(65-128) T2050643201-000 T2051283201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Distance for contact max. 21mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 162 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HEEE-144 inserts INSERTS FOR H48B HOOD/HOUSING 400V MAX. 16A 144+  Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HEEE-072-M(1-72) HEEE-144-M(73-144) T2050722101-000 T2051442101-000 HEEE-072-F(1-72) HEEE-144-F(73-144) T2050722201-000 T2051442201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Distance for contact max. 21mm Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Panel cut-out for inserts for use without hoods/housings Crimp terminal 163 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H48B hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG29 PG36 PG42 H48B-TS-PG29 H48B-TS-PG36 H4SB-TS-PG42 H48B-TS-M32 H48B-TS-M40 H48B-TS-M50 H48B-TS-M63 T1310480129-000 T1310480136-000 T1310480142-000 T1310480132-000 T1310480140-000 T1310480150-000 T1310480163-000 PG29 PG36 PG42 H48B-TG-PG29 H48B-TG-PG36 H48B-TG-PG42 H48B-TG-M32 H48B-TG-M40 H48B-TG-M50 H48B-TG-M63 T1320480129-000 T1320480136-000 T1320480142-000 T1320480132-000 T1320480140-000 T1320480150-000 T1320480163-000 H48B-AG T1500482000-000 H48B-AD-LB T1510482000-000 H48B-SGR-PG29 H48B-SGR-PG36 H48B-SGR-PG42 H48B-SGR-M32 H48B-SGR-M40 H48B-SGR-M50 H48B-SGR-2PG29 H48B-SGR-2PG36 H48B-SGR-2PG42 H48B-SGR-2M32 H48B-SGR-2M40 H48B-SGR-2M50 T1610482129-000 T1610482136-000 T1610482142-000 T1610482132-000 T1610482140-000 T1610482150-000 T1610482229-000 T1610482236-000 T1610482242-000 T1610482232-000 T1610482240-000 T1610482250-000 H48B-SDR-PG29 H48B-SDR-PG36 H48B-SDR-PG42 H48B-SDR-M32 H48B-SDR-M40 H48B-SDR-M50 H48B-SDR-2PG29 H48B-SDR-2PG36 H48B-SDR-2PG42 H48B-SDR-2M32 H48B-SDR-2M40 H48B-SDR-2M50 T1620480129-000 T1620480136-000 T1620480142-000 T1620480132-000 T1620480140-000 T1620480150-000 T1620480229-000 T1620480236-000 T1620480242-000 T1620480232-000 T1620480240-000 T1620480250-000 Hood: Side entry M32 M40 M50 M63 Hood: Top entry M32 M40 M50 M63 Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry M32 M40 M50 2 Side entry M32 M40 M50 PG29 PG36 PG42 PG29 PG36 PG42 Surface mounted with cover 1 Side entry 2 Side entry 164 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS M32 M40 M50 M32 M40 M50 PG29 PG36 PG42 PG29 PG36 PG42 Crimp contacts HE/HA series 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Crimping tools HE/HA series Description Type Part Number CRIMPBOX-0.5/4 T3100000001-000 RSZ.HE-HN.D-HVT 1-1105851-8 REMOV-HEE T3100000002-000 SCREWD-M3 T3100000009-000 Crimp tool Wire range: 0.5-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts Crimp tool Wire range: 0.14-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts with locator and die Removal tools Used for CEM/CEF contact series M3 screw driver Used for HA/HE inserts 165 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HVE technical characteristics CURRENT CARRYING CAPACITY Specifications ............................................................... DIN EN 60 664-1 ................................................................................................ DIN EN 61 984 Number of contacts .................................. 3+PE+2,6+PE+2,10+PE+2 The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current .......................................................................... 16A max (See current carrying capacity) Working voltage ..................................................................................830V Test voltage urms ................................................................................. 8KV Pollution degree .......................................................................................... 3 Insulation resistance........................................................................ ≥1010Ω Material ............................................................................... Polycarbonate Temperature range ........................................................ -40°C... +125°C Flammability acc. to UL94 ................................................................. V0 Working voltage acc. to UL/CSA ................................................ 600V Mechanical working life-mating cycles ..................................... ≥500 Working current INSERTS CONTACTS Ambient temperature Working current Material ................................................................................... Copper alloy Surface ......................................................................... Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ............................................................................ ≤5mΩ Terminal ............................................................................. Screw terminal ................................................................................................ Crimp terminal ................................................................................................Spring terminal - mm2 Screw terminal......................................................................... 0.5-2.5mm2 Crimp terminal .......................................................................... 0.14-4mm2 Spring terminal ....................................................................... 0.5-2.5mm2 - AWG Screw terminal..................................................................................... 20-14 Crimp terminal ..................................................................................... 26-12 Spring terminal.................................................................................... 20-14 - Tightening/test torque ............................................................. 0.5 Nm Ambient temperature HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 166 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 1 HVE-003 2 HVE-006 3 HVE-010 HEE series (high voltage) inserts MODIFIED CONTACT ARRANGEMENT The connector series HEE equipped with all contacts may be used for voltages up to 500V~insulation group C. A modified contact loading arrangement permits use up to 1000V~also in insulation group C. Contact arrangement view from termination side 4+ 8+ 14+ 20+ 2+ 4+ 8+ 12+ Working contact Without contact Male insert Female insert Series HEE 690V~ Insulation group C 1000V~ Insulation group C 167 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HVE series INSERTS FOR H10B, H16B, H24B HOOD/HOUSING Dimension (mm) Type 830V MAX. 16A Part Number Male insert Female insert 3+ +2 Screw terminal HVE-003-M T2300033101-000 HVE-003-F T2300033201-000 6+ +2 Screw terminal HVE-006-M T2300063101-000 HVE-006-F T2300063201-000 +2 10+ Screw terminal HVE-010-M HVE-010-F 168 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS T2300103101-000 T2300103201-000 HSB Series 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 60 664-1 DIN EN 61 984 3. Approvals 169 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HSB technical characteristics CURRENT CARRYING CAPACITY Specifications ............................................................... DIN EN 60 664-1 ................................................................................................ DIN EN 61 984 Number of contacts ........................................................ 6,12(2x6) + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ......................................................................... 35A max (See current carrying capacity) Working voltage Conductor - ground..........................................................................400 V Conductor - conductor.................................................................... 690 V Test voltage urms ................................................................................ 6KV Pollution degree .......................................................................................... 3 Insulation resistance ....................................................................... ≥1010Ω Material ............................................................................... Polycarbonate Temperature range ........................................................ -40°C... +125°C Flammability acc. to UL94 ................................................................. V0 Working voltage acc. to UL/CSA ................................................ 600V Mechanical working life-mating cycles ..................................... ≥500 CONTACTS Material ................................................................................... Copper alloy Surface ......................................................................... Hard silver-plated Contact resistance ............................................................................. ≤1mΩ Terminal ............................................................................. Screw terminal - mm2 .............................................................................................. 1.5-6mm2 - AWG ..................................................................................................... 16-10 - Tightening/test torque .............................................................. 1.2 Nm HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 170 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 Wire gauge: 4.0mm2 2 Wire gauge: 6.0mm2 HSB-006 inserts INSERTS FOR H16B HOOD/HOUSING 690V 35A 6+ Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (order crimp contacts separately) HSB-006-M HSB-006-F Contact arrangement view from termination side T2060062101-000 T2060062201-000 Panel cut out for inserts for use without hoods/housings 171 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H16B-TS-PG16 H16B-TS-PG21 H16B-TS-M20 H16B-TS-M25 H16B-TS-M32 T1210160116-000 T1210160121-000 T1210160120-000 T1210160125-000 T1210160132-000 PG21 PG29 H16B-TSH-PG21 H16B-TSH-PG29 H16B-TSH-M25 H16B-TSH-M32 H16B-TSH-M40 T1230160121-000 T1230160129-000 T1230060125-000 T1230160132-000 T1230160140-000 PG16 PG21 H16B-TG-PG16 H16B-TG-PG21 H16B-TG-M25 H16B-TG-M32 T1220160116-000 T1220160121-000 T1220160125-000 T1220160132-000 PG21 PG29 H16B-TGH-PG21 H16B-TGH-PG29 H16B-TGH-M25 H16B-TGH-M32 H16B-TGH-M40 T1240160121-000 T1240160129-000 T1240160125-000 T1240160132-000 T1240160140-000 PG21 H16B-TBFS-PG21 H16B-TBFS-M25 H16B-TBFS-M32 H16B-TBFHS-PG21 H16B-TBFHS-PG29 H16B-TBFHS-M25 H16B-TBFHS-M32 H16B-TBFHS-M40 T1710161121-000 T1710161125-000 T1710161132-000 T1750161121-000 T1750161129-000 T1750161125-000 T1750161132-000 T1750161140-000 H16B-KDTP T1010161400-000 H16B-KDBP T1010162100-000 Hood: Side entry Low construction M20 M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods Housing protection cover 172 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H16B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H16B-AGS T1410161000-000 H16B-SGRS-PG21 H16B-SGRS-M25 H16B-SGRS-2PG21 H16B-SGRS-2M25 H16B-SGRHS-PG21 H16B-SGRHS-PG29 H16B-SGRHS-M25 H16B-SGRHS-M32 H16B-SGRHS-2PG21 H16B-SGRHS-2PG29 H16B-SGRHS-2M25 H16B-SGRHS-2M32 T1440161121-000 T1440161125-000 T1440161221-000 T1440161225-000 T1470161121-000 T1470161129-000 T1470161125-000 T1470161132-000 T1470161221-000 T1470161229-000 T1470161225-000 T1470161232-000 H16B-TSBS-PG16 H16B-TSBS-PG21 H16B-TSBS-M20 H16B-TSBS-M25 H16B-TSBHS-PG21 H16B-TSBHS-PG29 H16B-TSBHS-M25 H16B-TSBHS-M32 T1250163116-000 T1250163121-000 T1250163120-000 T1250163125-000 T1270163121-000 T1270163129-000 T1270163125-000 T1270163132-000 H16B-TGBS-PG16 H16B-TGBS-PG21 H16B-TGBS-M20 H16B-TGBS-M25 H16B-TGBHS-PG21 H16B-TGBHS-PG29 H16B-TGBHS-M25 H16B-TGBHS-M32 T1260163116-000 T1260163121-000 T1260163120-000 T1260163125-000 T1280163121-000 T1280163129-000 T1280163125-000 T1280163132-000 H16B-AD-BO T1430160000-000 H16B-SDR-BO-PG21 H16B-SDR-BO-M25 H16B-SDR-BO-2PG21 H16B-SDR-BO-2M25 H16B-SDRH-BO-PG21 H16B-SDRH-BO-PG29 H16B-SDRH-BO-M25 H16B-SDRH-BO-M32 H16B-SDRH-BO-2PG21 H16B-SDRH-BO-2PG29 H16B-SDRH-BO-2M25 H16B-SDRH-BO-2M32 T1460160121-000 T1460160125-000 T1460160221-000 T1460160225-000 T1490160121-000 T1490160129-000 T1490160125-000 T1490160132-000 T1490160221-000 T1490160229-000 T1490160225-000 T1490160232-000 Bulkhead mounted Surface mounted: Side entry 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction Construction M20 M25 H 60 Hight 76 High construction Low M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction High construction Construction H Low 60 Hight 76 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover Low construction D F G H Low 105 117 45 57 20 65 56 Hight 105 117 45 57 20 65 81 2 Side entry C High construction B 1 Side entry A 1 Side entry 2 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 173 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 H16B-TS-RO-PG21 H16B-TS-RO-PG29 H16B-TS-RO-M25 H16B-TS-RO-M32 T1310160121-000 T1310160129-000 T1310160125-000 T1310160132-000 PG21 PG29 H16B-TSH-RO-PG21 H16B-TSH-RO-PG29 H16B-TSH-RO-M25 H16B-TSH-RO-M32 H16B-TSH-RO-M40 T1330160121-000 T1330160129-000 T1330160125-000 T1330160132-000 T1330160140-000 PG21 PG29 H16B-TG-RO-PG21 H16B-TG-RO-PG29 H16B-TG-RO-M25 H16B-TG-RO-M32 T1320160121-000 T1320160129-000 T1320160125-000 T1320160132-000 PG21 PG29 H16B-TGH-RO-PG21 H16B-TGH-RO-PG29 H16B-TGH-RO-M25 H16B-TGH-RO-M32 H16B-TGH-RO-M40 T1340160121-000 T1340160129-000 T1340160125-000 T1340160132-000 T1340160140-000 PG21 PG29 H16B-TBF-LB-PG21 H16B-TBF-LB-PG29 H16B-TBF-LB-M25 H16B-TBF-LB-M32 H16B-TBFH-LB-PG21 H16B-TBFH-LB-PG29 H16B-TBFH-LB-M25 H16B-TBFH-LB-M32 H16B-TBFH-LB-M40 T1730163121-000 T1730163129-000 T1730163125-000 T1730163132-000 T1770163121-000 T1770163129-000 T1770163125-000 T1770163132-000 T1770163140-000 H16B-KDTP-LB T1010161500-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods 174 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H16B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H16B-AG-LB T1500163000-000 H16B-AD-LB T1510163000-000 H16B-SGR-LB-PG16 H16B-SGR-LB-PG21 H16B-SGR-LB-M20 H16B-SGR-LB-M25 H16B-SGR-LB-2PG16 H16B-SGR-LB-2PG21 H16B-SGR-LB-2M20 H16B-SGR-LB-2M25 H16B-SGRH-LB-PG21 H16B-SGRH-LB-PG29 H16B-SGRH-LB-M25 H16B-SGRH-LB-M32 H16B-SGRH-LB-2PG21 H16B-SGRH-LB-2PG29 H16B-SGRH-LB-2M25 H16B-SGRH-LB-2M32 T1610163116-000 T1610163121-000 T1610163120-000 T1610163125-000 T1610163216-000 T1610163221-000 T1610163220-000 T1610163225-000 T1650163121-000 T1650163129-000 T1650163125-000 T1650163132-000 T1650163221-000 T1650163229-000 T1650163225-000 T1650163232-000 H16B-SDR-LB-PG16 H16B-SDR-LB-PG21 H16B-SDR-LB-M20 H16B-SDR-LB-M25 H16B-SDR-LB-2PG16 H16B-SDR-LB-2PG21 H16B-SDR-LB-2M20 H16B-SDR-LB-2M25 H16B-SDRH-LB-PG21 H16B-SDRH-LB-PG29 H16B-SDRH-LB-M25 H16B-SDRH-LB-M32 H16B-SDRH-LB-2PG21 H16B-SDRH-LB-2PG29 H16B-SDRH-LB-2M25 H16B-SDRH-LB-2M32 T1620163116-000 T1620163121-000 T1620163120-000 T1620163125-000 T1620163216-000 T1620163221-000 T1620163220-000 T1620163225-000 T1660163121-000 T1660163129-000 T1660163125-000 T1660163132-000 T1660163221-000 T1660163229-000 T1660163225-000 T1660163232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 2 Side entry 81 High construction Hight 1 Side entry 56 2 Side entry H Low Low construction Construction 1 Side entry With protection cover 2 Side entry 81 High construction Hight 1 Side entry 56 2 Side entry Low construction H Low 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 175 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.16/40, HIP-K.16/40, EMV-K.16/40 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 21 29 HIP HIP.16/40.STS.1.21.G HIP.16/40.STS.1.29.G HIP.16/40.STS.1.M32.G 1-1102649-5 1-1102651-5 0-1106454-2 29 HIP-K HIP-K.16/40.STS.1.29.G HIP-K.16/40.STS.1.M32.G 2-1102651-5 0-1106444-2 EMV-K EMV-K.16/40.STS.1.29.G EMV-K.16/40.STS.1.M32.G EMV-K.16/40.STS.1.21.G 4-1102723-5 0-1106446-4 4-1102722-5 21 29 HIP HIP.16/40.STO.1.21.G HIP.16/40.STO.1.29.G HIP.16/40.STO.1.M32.G 1-1102653-5 1-1102655-5 0-1106454-1 21 29 HIP-K HIP-K.16/40.STO.2.21.G HIP-K.16/40.STO.1.29.G HIP-K.16/40.STO.1.M32.G 0-1108534-1 2-1102655-5 0-1106444-1 29 EMV-K EMV-K.16/40.STO.1.29.G EMV-K.16/40.STO.1.M32.G 4-1102725-5 0-1106446-3 HIP HIP.16/40.AG 1-1102656-5 Hood: Side entry M32 M32 M32 29 21 Hood: Top entry M32 M32 M32 8 22 Surface mounted housing: Bottom entry 22 ø4.5 8 103 129.5 ø4.5 32 56 32 56 103 129.5 Panel cut-out M4 HIP-K HIP-K.16/40.AG EMV-K EMV-K.16/40.AG 32 36 32 36 M4 86 86 103103 M6x20 1-1102656-5 8 M6x20 1-1102656-5 112.5 129.5 43 22 60 8 112.5 129.5 22 43 60 Panel cut-out 112.5 86 112.5 86 M6 M6 36 36 45 45 176 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2-1102656-5 4-1102728-5 HIP HIP.16/40.AG.M6 1-1102618-5 HIP-K HIP-K.16/40.AG.M6 2-1102618-5 EMV-K EMV-K.16/40.AG.M6 4-1102730-5 HIP.16/40, HIP-K.16/40, EMV-K.16/40 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Pressure-tight up to 5 bar IP 68 / IP 69 K Description Metr. PG Type Part Number 21 2x21 HIP HIP.16/40.SG.1.21.G HIP.16/40.SG.2.21.G HIP.16/40.SG.2.M32.G 1-1102616-5 1-1102617-5 0-1106453-1 21 2x21 HIP-K HIP-K.16/40.SG.1.21.G HIP-K.16/40.SG.2.21.G HIP-K.16/40.SG.2.M32.G 5-1102616-5 2-1102617-5 0-1106443-1 21 2x21 EMV-K EMV-K.16/40.SG.1.21.Z EMV-K.16/40.SG.2.21.Z EMV-K.16/40.SG.2.M32.G 4-1102726-5 4-1102727-5 0-1106445-2 HIP HIP/EMV.16/40.SKB 3-1106203-5 HIP-K HIP-K.16/40.SKB 4-1106203-5 Surface mounted housing: Side entry 2xM32 2xM32 2xM32 Protective covers for housings M6x30 19 129.5 53 177 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HSB-012 inserts INSERTS FOR H32B HOOD/HOUSING 690V 35A 12 (2x6)+ Dimensions (mm) Type Part Number Male insert Female insert Screw terminal HSB-006-M(1-6) HSB-006-M(7-12) HSB-006-F(1-6) HSB-006-F(7-12) Contact arrangement view from termination side Panel cut out for inserts for use without hoods/housings 178 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS T2060062101-000 T2060122101-000 T2060062201-000 T2060122201-000 H32B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG29 PG36 H32B-TS-PG29 H32B-TS-PG36 H32B-TS-M32 H32B-TS-M40 T1210320129-000 T1210320136-000 T1210320132-000 T1210320140-000 PG21 PG29 PG36 PG42 H32B-TG-PG21 H32B-TG-PG29 H32B-TG-PG36 H32B-TG-PG42 H32B-TG-M25 H32B-TG-M32 H32B-TG-M40 H32B-TG-M50 T1220320121-000 T1220320129-000 T1220320136-000 T1220320142-000 T1220320125-000 T1220320132-000 T1220320140-000 T1220320150-000 H32B-AG T1410322000-000 H32B-SGR-PG29 H32B-SGR-PG36 H32B-SGR-PG42 H32B-SGR-M32 H32B-SGR-M40 H32B-SGR-M50 H32B-SGR-M63 H32B-SGR-2PG29 H32B-SGR-2PG36 H32B-SGR-2PG42 H32B-SGR-2M32 H32B-SGR-2M40 H32B-SGR-2M50 H32B-SGR-2M63 T1440322129-000 T1440322136-000 T1440322142-000 T1440322132-000 T1440322140-000 T1440322150-000 T1440322163-000 T1440322229-000 T1440322236-000 T1440322242-000 T1440322232-000 T1440322240-000 T1440322250-000 T1440322263-000 H32B-TBF-PG29 H32B-TBF-PG36 H32B-TBF-PG42 H32B-TBF-M32 H32B-TBF-M40 H32B-TBF-M50 H32B-TBF-M63 T1710322129-000 T1710322136-000 T1710322142-000 T1710322132-000 T1710322140-000 T1710322150-000 T1710322163-000 H32B-KDB T1000321220-000 Hood: Side entry M32 M40 Hood: Top entry M25 M32 M40 M50 Bulkhead mounted Surface mounted: Side entry 1 Side entry M32 M40 M50 M63 2 Side entry M32 M40 M50 M63 PG29 PG36 PG42 PG29 PG36 PG42 Cable-to-cable hood M32 M40 M50 M63 PG29 PG36 PG42 Protection covers for hoods 179 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H32B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG29 PG36 H32B-TS-RO-PG29 H32B-TS-RO-PG36 H32B-TS-RO-M32 H32B-TS-RO-M40 T1310320129-000 T1310320136-000 T1310320132-000 T1310320140-000 PG21 PG29 PG36 PG42 H32B-TG-RO-PG21 H32B-TG-RO-PG29 H32B-TG-RO-PG36 H32B-TG-RO-PG42 H32B-TG-RO-M25 H32B-TG-RO-M32 H32B-TG-RO-M40 H32B-TG-RO-M50 T1320320121-000 T1320320129-000 T1320320136-000 T1320320142-000 T1320320125-000 T1320320132-000 T1320320140-000 T1320320150-000 H32B-AG-LB T1500322000-000 H32B-AD-LB T1510322000-000 H32B-SGR-LB-PG29 H32B-SGR-LB-M32 H32B-SGR-LB-M40 H32B-SGR-LB-2PG29 H32B-SGR-LB-2M32 H32B-SGR-LB-2M40 T1610322129-000 T1610322132-000 T1610322140-000 T1610322229-000 T1610322232-000 T1610322240-000 H32B-SDR-LB-PG29 H32B-SDR-LB-M32 H32B-SDR-LB-M40 H32B-SDR-LB-2PG29 H32B-SDR-LB-2M32 H32B-SDR-LB-2M40 T1620320129-000 T1620320132-000 T1620320140-000 T1620320229-000 T1620320232-000 T1620320240-000 Hood: Side entry M32 M40 Hood: Top entry M25 M32 M40 M50 Bulkhead mounted With protection cover Surface mounted: Side entry 1 Side entry M32 M40 2 Side entry M32 M40 With protection cover 1 Side entry 2 Side entry 180 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS M32 M40 M32 M40 PG29 PG29 PG29 PG29 HQ Series 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 175 301-801 DIN EN 61 984 3. Approvals 181 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HQ technical characteristics CURRENT CARRYING CAPACITY Specifications ............................................................... DIN EN 60 664-1 ................................................................................................ DIN EN 61 984 Number of contacts ................................................ 5,7,8,12,17,4/2 + PE INSERTS Working current HQ-005,008.................................................................................... 16A max HQ-007,012,017.............................................................................. 10A max HQ4/2....................................................................... Power area 40A max ......................................................................................Signal area 10A max Working voltage HQ-005,007,012...................................................................................400V HQ-008................................................................................................... 500V HQ-017.....................................................................................................250V HQ4/2...........................................Power area 600V Signal area 250V Test voltage urms HQ-005,017.............................................................................................. 4KV HQ-007,008,012,4/2............................................................................. 6KV Pollution degree ......................................................................................... 3 Insulation resistance ....................................................................... ≥1010Ω Material ............................................................................... Polycarbonate Temperature range .......................................... -40°C... +100°C/125°C Flammability acc. to UL94 ................................................................. V0 Working voltage acc. to UL/CSA ................................................ 600V Mechanical working life-mating cycles ..................................... ≥500 CONTACTS Material ................................................................................... Copper alloy Surface ......................................................................... Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ............................................................................. ≤1mΩ Terminal ............................................................................. Crimp terminal - mm2.............................................................0.14-4.0/0.14-2.5/1.5-6mm2 - AWG.............................................................................. 26-12/26-14/16-10 - Tightening/test torque ........................................................... 0.25Nm HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 182 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. HQ-005 inserts INSERTS FOR H3A HOOD/HOUSING 400V MAX. 16A 5+  Dimensions (mm) Contact arrangement view from termination side Part Number Male insert Type Female insert Crimp terminal (Order crimp contacts separately) T2080052101-000 HQ-005-M T2080052201-000 HQ-005-F 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 183 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HQ-007/012 inserts INSERTS FOR H3A HOOD/HOUSING 400V MAX. 10A 7+  12+   Dimensions (mm) Contact arrangement view from termination side Part Number Male insert Type Female insert Crimp terminal (Order crimp contacts separately) T2080072101-000 HQ-007-M T2080072201-000 T2080122101-000 HQ-007-F HQ-012-M T2080122201-000 HQ-012-F 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 184 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H3A metal hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG11 H3A-MTG-PG11 T1329030111-000 H3A-MTG-M20 T1329030120-000 H3A-MTS-PG11 T1319030111-000 H3A-MTS-M20 T1319030120-000 H3A-MAG T1509030000-000 H3A-MAGS T1549030000-000 H3A-MAGSV-PG11 T1619030111-000 M16 H3A-MAGSV-M16 T1619030116-000 M20 H3A-MAGSV-M20 T1619030120-000 H3A-MTGVB-PG11 T1739030111-000 H3A-MTGVB-M20 T1739030120-000 H3A-KDTP T1010031100-000 H3A-KDB T1010033100-000 Top entry M20 Side entry PG11 M20 Bulkhead mounting: Bottom entry Bulkhead mounting: Side entry Surface mounting: Side entry PG11 Cable-to-cable hood: PG11 M20 Protection covers for hoods (thermoplastic) Note: For mounted male insert and hood Metal protection covers for hoods Note: For mounted female insert and hood 185 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H3A thermoplastic hoods/housings THERMOPLASTIC HOODS, HOUSINGS Dimensions (mm) Metr. PG Type Part Number PG11 H3A-TG-PG11 H3A-TG-M20 T1329031111-000 T1329031120-000 PG11 H3A-TS-PG11 H3A-TS-M20 T1319031111-000 T1319031120-000 H3A-AG T1509031100-000 H3A-AGS T1509031111-000 PG11 H3A-AGSV-PG11 H3A-AGSV-M16 H3A-AGSV-M20 T1619031111-000 T1619031116-000 T1619031120-000 PG11 H3A-TGVB-PG11 H3A-TGVB-M20 T1739031111-000 T1739031120-000 H3A-KDTP T1010031100-000 H3A-KDBP (White) H3A-KDBPG (Grey) T1010032100-000 T1010032300-000 H3A-KDBP (White) H3A-KDBP (Grey) T1010033200-000 T1010032200-000 Top entry M20 Side entry M20 Bulkhead mounting: Bottom entry Bulkhead mounting: Side entry Surface mounting: Side entry M16 M20 Cable-to-cable hood: M20 Protection covers for hoods (thermoplastic) Note: For mounted male insert and hood Protection covers for hoods Note: For mounted female insert and hood White Grey Covers without sealing type 186 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP.3/4, HIP-K.3/4, EMV-K.3/4 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood IP 68 / IP 69 K Description Metr. PG Type Part Number 11 HIP HIP.3/4.ST0.1.11.G HIP.3/4.ST0.1.M16.G 1-1102600-5 0-1106408-1 HIP-K HIP-K.3/4.ST0.1.11.G HIP-K.3/4.ST0.1.M16.G HIP-K.3/4.ST0.1.M20.G 2-1102600-5 0-1106408-2 0-1106408-3 EMV-K EMV-K.3/4.ST0.1.11.G 4-1102700-5 EMV-K.3/4.ST0.1.M16.G EMV-K.3/4.ST0.1.M20.G 0-1106402-2 0-1106402-3 HIP HIP.3/4.AG 1-1102603-5 HIP-K HIP-K.3/4.AG 2-1102603-5 EMV-K EMV-K.3/4.AG 4-1102703-5 HIP HIP.3/4.SGF 1-1102602-5 HIP-K HIP-K.3/4.SGF 2-1102602-5 EMV-K EMV-K.3/4.SGF 4-1102702-5 Hood: Top entry M16 11 M16 M20 11 M16 M20 Surface mounted housing: Bottom entry M3x8 22 4 22 32 4,3 41 51 Panel cut-out 21 x 21 ø21 M4 Surface mounted housing: Bottom22entry (by panel cut-out) 51 41 41 4 31 M3x8 38 48 4,3 Panel cut-out ø 20 41 M4 ø20 38 187 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.3/4, HIP-K.3/4, EMV-K.3/4 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood IP 68 / IP 69 K Description Metr. PG Type Part Number HIP HIP.3/4.SG.1.11.G HIP.3/4.SG.1.M16.G HIP.3/4.SG.1.M20.G 1-1102601-5 0-1106407-1 0-1106401-4 HIP-K HIP-K.3/4.SG.1.11.G HIP-K.3/4.SG.1.M16.G 2-1102601-5 0-1106407-2 EMV-K EMV-K.3/4.SG.1.11.G EMV-K.3/4.SG.1.M16.G EMV-K.3/4.SG.1.M20.G 4-1102701-5 0-1106401-2 0-1106401-3 HIP/EMV HIP/EMV.3/4.SKB 3-1106200-5 HIP-K/EMV-K HIP-K/EMV-K.3/4.SKB 4-1106200-5 Surface mounted housing: Side entry PG11 M16 M20 PG11 M16 PG11 M16 M20 Protective covers for housings M4x22 14 51 32 188 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HQ-017, 4/2, 8, 10 inserts INSERTS FOR H8A HOOD/HOUSING 17+ 4/2+ 8+ 10 Dimension (mm) Part Number Type Male insert Female 0-1108808-1insert Crimp terminal (order crimp contacts separately) 250V max. 10A Termination HQ-017-M T2080172101-000 side 0-1108808-1 HQ-017-F 400V/250V max. 40A/10A Termination HQ-4/2-M T2080062101-100 side HQ-008-M 13,4 T2019092101-000 Connecting side HQ-008-F 32,2 1103070 3095-1 T2019092201-000 10 9 13,4 3 side 10 8 9 25,6 HG-Q.10.Bu.C 42 0-1103091-1 21,4 41,5 22 3 45 Suitable crimp contacts and crimping tools: see page 190 21,4 41,5 25,6 22 Contact arrangement view from termination side 44,8 1 2 45 39,7 Contact arrangement view from termination side Kontaktanordnung Anschlussseite 1 2 45 0-1108808-1 39,7 48 HG-Q.10.Sti.C Connecting 32,2 26 8 25,6 37 26 T2080062201-100 37 1103070 HQ-4/2-F PN 0-1103095-1 T2080172201-000 Kontaktanordnung HE-Q.4/2 HE-Q.8 Anschlussseite HE-Q.10 Contact arrangement Male insert 1 2 11 12 3 2 4 1 12 11 4 3 1 4 2 3 5 5 6 3 7 2 8 1 5 8 7 4 1 3 2 4 6 5 9 8 6 9 8 4 7 1 10 10 6 5 2 7 3 Contact arrangement Female insert 2 1 12 11 4 3 1 4 2 3 5 6 3 7 2 8 1 4 1 8 7 6 4 8 3 2 6 5 9 10 9 8 7 4 1 10 6 5 2 7 3 189 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Crimp contacts HN.D series 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 26-22 20 18 18 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 1.5 2.5 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-1.5 CDF-2.5 T2020002015-000 T2020002025-000 DDF-1.5 DDF-2.5 T2020012015-000 T2020012025-000 Crimping tools HN.D series Description Type Part Number CRIMPBOX-0.5/4 T3100000001-000 RSZ.HE-HN.D-HVT 1-1105851-8 REMOV-HD T3100000003-000 SCREWD-M3 T3100000009-000 Crimp tool Wire range: 0.5-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts Crimp tool Wire range: 0.14-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts with locator and die Removal tools Used for CDM/CDF contact series M3 screw driver Used for HA/HE inserts 190 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Crimp contacts HE/HA series 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 26-22 20 18 CEF-0.3 CEF-0.5 CEF-0.75 T2030002002-000 T2030002005-000 T2030002008-000 DEF-0.3 DEF-0.5 DEF-0.75 T2030012002-000 T2030012005-000 T2030012008-000 1.0 1.5 2.5 4.0 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 Crimping tools HE/HA series Description Type Part Number CRIMPBOX-0.5/4 T3100000001-000 RSZ.HE-HN.D-HVT 1-1105851-8 REMOV-HEE T3100000002-000 SCREWD-M3 T3100000009-000 Crimp tool Wire range: 0.5-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts Crimp tool Wire range: 0.14-4.0mm2 Suitable for CDM/CDF and CEM/CEF contacts with locator and die Removal tools Used for CEM/CEF contact series M3 screw driver Used for HA/HE inserts 191 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Crimp contacts HGQ10 series Tech data Material: copper alloy Finish: tin plated Contact resistance: ≤3mΩ Crimp Terminal: 0.2-4.0 mm2 AWG: 24-12 Type Part Number (mm2) Tool Pin contact tin plated 962966-1 962967-1 962968-1 962969-1 0.2 – 0.4 0.5 – 1.0 1.0 – 2.5 2.5 – 4.0 734285-1 734285-1 734285-2 734285-3 Reel contact/pin tin plated 929962-1 929963-1 929964-1 929965-1 0.2 – 0.4 0.5 – 1.0 1.0 – 2.5 2.5 – 4.0 734285-1 734285-1 734285-2 734285-3 Socket contact tin plated 962976-1 962977-1 962978-1 962979-1 0.2 – 0.4 0.5 – 1.0 1.0 – 2.5 2.5 – 4.0 734285-1 734285-1 734285-2 734285-3 Reel contact/socket tin plated 929969-1 929970-1 929971-1 929972-1 0.2 – 0.4 0.5 – 1.0 1.0 – 2.5 2.5 – 4.0 734285-1 734285-1 734285-2 734285-3 Other finishes and Materials on request Appl. Spec.: 114-18018 Crimping tools HGQ10 series Description Type Part Number Extraction tool Extraction tool 1-1579007-8 Handtool 734285-11,5 mm2 734285-22,5 mm2 734285-34,0 mm2 Crimping tool with locator Safety Press SSC-2FP 1481004-7 Bench and Automatic tooling on request Ergo Die Adapter 1579000-7 192 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H8A with 1 lever on the hoods/housings THERMOPLASTIC HOODS, HOUSINGS Dimensions (mm) Metr. PG Type Part Number PG16 M20 M25 H8A-TS-PG16 H8A-TS-M20 H8A-TS-M25 T1359090116-000 T1319080120-000 T1319080125-000 M25 EMV HG-Q-EMV.STO.1.M25.Z 0-1103073-3 M20 M25 H8A-TG-M20 H8A-TG-M25 T1329080120-000 T1329080125-000 M25 EMV HG-Q-EMV.STO.1.M25.Z 0-1103073-4 Hood: Side entry Hood: Top entry 193 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HG-Q housings Plastic glass-fibre reinforced EMV: Protection against electro-magnetic interference IP 65 Description Metr. PG Type Part Number M25 HG-Q.KDO-LB.1.M25.Z 0-1108795-1 M25 EMV HG-Q-EMV.KDO-LB.1.M25.Z 0-1108795-3 M25 HG-Q.KDS-LB.1.M25.Z 0-1108795-2 M25 EMV HG-Q-EMV.KDS-LB.1.M25.Z 0-1108795-4 M25 HG-Q.AG-LB 0-1103072-1 M25 EMV HG-Q-EMV.AG-LB 0-1103072-2 Cable-to-cable hood: Bottom entry 0-1108795-1 26,6 Cable-to-cable hood: Side entry 0-1108795-2 34 PN Surface mount housing: Bottom entry 0-1103072-1 26,6 45,6 57 18,8 13,4 44 34 194 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HG-Q.10 motor housings Plastic glass-fibre reinforced EMV: Protection against electro-magnetic interference 400V 20A IP 65 Description Metr. PG Type Part Number HG-Q.10.MC.1 0-1103092-1 EMV HG-Q.10-EMV.MC.1 0-1103092-8 HG-Q.10.MC.2 0-1103092-2 EMV HG-Q.10-EMV.MC.2 0-1103092-9 HG-Q.10.MC.3 0-1103092-3 EMV HG-Q.10-EMV.MC.3 1-1103092-0 HG-Q.10.MC.4 0-1103092-4 EMV HG-Q.10-EMV.MC.4 1-1103092-1 HG-Q.10.MC.5 0-1103092-5 EMV HG-Q.10-EMV.MC.5 1-1103092-2 11030921 Dimensions (mm) PN A B C D 0-1, 0-8 70 58 54 66 0-2, 0-9 70 60 60 70 0-3, 1-0 74 56 56 74 0-4, 1-1 75 64 64 75 0-5, 1-2 120 105 105 120 195 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HG-Q accessories Plastic glass-fibre reinforced EMV: Protection against electro-magnetic interference SIZE Q IP 65 Description 0-1108794-2 Metr. PG Type Part Number Conductive HG-Q.FI-dicht-L 0-1108794-2 HG-Q.M25.6,5/4,0 HG-Q.M25.8,0/5,0 HG-Q.M25.9,5/6,5 HG-Q.M25.10,5/7,0 HG-Q.M25.13,0/9,0 HG-Q.M25.15,5/11,5 0-1103074-1 0-1103074-2 0-1103074-3 0-1103074-4 0-1103074-5 0-1103074-6 Set-HG-Q.8.SKP 0-1108818-1 Sich-Stift.HVE.C 0-1110984-4 Flange sealing for HG-Q.8 Surface mount housing Gland fitting, IP68 plastic All glands are supplied with a black M25 nut M25 (Yellow) M25 (Grey) M25 (Black) M25 (Green) M25 (Red) M25 (White) Cover for all HG-Q housing Coding pin for Q.5 and Q.8, HE, HEE 196 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HEAV Contact Series 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 60 664-1 DIN EN 61 984 3. Approvals 197 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEAV/HESAV technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ........................................................ 6,10,16,24 + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 16A max (See current carrying capacity) Working voltage ................................................................................. 500V Test voltage urms................................................................................... 6KV Test voltage urms acc. to TUV.......................................................... 4KV Pollution degree........................................................................................... 2 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 Working current INSERTS CONTACTS HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 Ambient temperature Wire gauge: 1.5 mm2 Ambient temperature Wire gauge: 2.50 mm2 Working current Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated Contact resistance .............................................................................≤4mΩ HEAV Terminal ................................................................. Screw terminal - mm2 ...........................................................................................0.2-2.5mm2 - AWG ......................................................................................................24-14 HESAV Terminal ...............................................................Spring terminal - mm2 .......................................................................................... 0.5-2.5mm2 - AWG ..................................................................................................... 20-14 1 HEAV-006/HESAV-006 2 HEAV-010/HESAV-010 3 HEAV-016/HESAV-016 4 HEAV-024/HESAV-024 198 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HEAV inserts LEFT HAND VERSION SCREW TERMINAL 6+  16+  500V MAX. 16A 10+ 24+ Dimensions (mm) Type Type Part Number Male insert Female insert Screw terminal 6+ HEAV-006-M T2090062101-000 6-pole HEAV-006-F T2090062201-000 Screw terminal 10+ HEAV-010-M T2090102101-000 10-pole HEAV-010-F T2090102201-000 Left hand version Male insert/ Female insert A B 44 HEAV-006 20 HEAV-010 34 57 HEAV-016 54 77.5 HEAV-024 81 104 Screw terminal 16+ HEAV-016-M T2090162101-000 16-pole HEAV-016-F T2090162201-000 Screw terminal 24+ HEAV-024-M T2090242101-000 24-pole HEAV-024-F T2090242201-000 Left hand version Male insert/ Female insert A B 44 HEAV-006 20 HEAV-010 34 57 HEAV-016 54 77.5 HEAV-024 81 104 199 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HESAV inserts LEFT HAND VERSION SPRING TERMINAL 6+  16+  500V MAX. 16A 10+ 24+ Dimensions (mm) Type Type Part Number Male insert Female insert Spring terminal 6+ HEAV-006-MS T2100063101-000 6-pole HEAV-006-FS T2100063201-000 Spring terminal 10+ HEAV-010-MS T2100103101-000 10-pole HEAV-010-FS T2100103201-000 Left hand version Male insert/ Female insert A B 44 HEAV-006 20 HEAV-010 34 57 HEAV-016 54 77.5 HEAV-024 81 104 Spring terminal 16+ HEAV-016-MS T2100163101-000 16-pole HEAV-016-FS T2100163201-000 Spring terminal 24+ HEAV-024-MS T2100243101-000 24-pole HEAV-024-FS Left hand version Male insert/ Female insert A B HEAV-006 20 44 HEAV-010 34 57 HEAV-016 54 77.5 HEAV-024 81 104 200 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS T2100243201-000 HMN Modular Series • • • • Mutually compatible with other brands More convenient to install Complete series Can be developed according to customer requirements 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 175 301-801 DIN EN 61 984 3. Approvals 201 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HMN modular connectors overview H10A MODULAR UNITS, INSTALL AND REMOVE WITHOUT SPECIAL TOOLS! H6B H10B H16B H24B HMN MODULE FIXING FRAME Hood/Housing NO. of modules a b H10A 1 49.5 56.5 H6B 2 44 51 H10B 3 57 64.1 H16B 4 77.5 84.5 H24B 6 104 111 Distance for electrical contacts max. 21mm. For pneumatic contacts max. 20.5mm. Each frame is composed of an upper and a lower bracket. 202 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Description Size H10A frame for 1 modules H10A H6B frame for 2 modules H6B H10B frame for 3 modules H10B H16B frame for 4 modules H16B H24B frame for 6 modules H24B Part Number Type T2079104201-M H10A-T1-M T2079104101-F H10A-T1-F T2070064101-000 H6BN-T2-M T2070064201-000 H6BN-T2-F T2070104101-000 H10BN-T3-M T2070104201-000 H10BN-T3-F T2070164101-000 H16BN-T4-M T2070164201-000 H16BN-T4-F T2070244101-000 H24BN-T6-M T2070244201-000 H24BN-T6-F Notes 203 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 200A/1 Pole module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .......................................................................... 1 pole The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ....................................................................... 200A max (See current carrying capacity) Working voltage ............................................................................... 1000V Test voltage urms ................................................................................. 8KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA.................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated Contact resistance ......................................................................... ≤0.3mΩ Terminal............................................................................... Crimp terminal - mm2 .............................................................................................25-70mm2 - AWG ..........................................................................................................2-0 204 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 3 modules; wire gauge: 50mm2 2 H24B hood/housing with 3 modules; wire gauge: 70mm2 HMN-001 module inserts CRIMP TERMINAL 1000V MAX. 200A 1 Pole Dimensions (mm) Type Part Number Male insert Crimp terminal Female insert Size chart HMN-001-MC T2111013101-000 HMN-001-FC T2111013201-000 200A Contact Tech data Material: copper Contact resistance: ≤0.3mΩ Terminal: crimp connection CHM/Male 200A Male crimp contacts CHF/Female 200A Female crimp contacts Wire gauge Ø mm2 Stripping length Crimp contacts, silver-plated mm Type Part Number 25 35 50 70 7.0 8.2 10.0 11.5 22.5 22.5 22.5 22.5 CHM-25 CHM-35 CHM-50 CHM-70 T2060001025-000 T2060001035-000 T2060001050-000 T2060001070-000 25 35 50 70 7.0 8.2 10.0 11.5 22.5 22.5 22.5 22.5 CHF-25 CHF-35 CHF-50 CHF-70 T2060002025-000 T2060002035-000 T2060002050-000 T2060002070-000 205 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 100A/2 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ....................................................................... 2 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................ 100A max (See current carrying capacity) Working voltage ............................................................................... 1000V Test voltage urms ................................................................................. 8KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA.................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated Contact resistance ......................................................................... ≤0.3mΩ Terminal............................................................................... Crimp terminal - mm2 ............................................................................................. 10-35mm2 - AWG ..........................................................................................................6-2 206 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 3 modules; wire gauge: 35mm2 2 H24B hood/housing with 3 modules; wire gauge: 25mm2 HMN-D2 module inserts CRIMP TERMINAL 1000V MAX. 100A 2 Poles Dimensions (mm) Type Part Number Male insert Crimp terminal Female insert Size chart HMN-D2-MC T2111028101-000 HMN-D2-FC T2111028201-000 Contact arrangement view from termination side 100A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CDM/Male 100A Male crimp contacts CDF/Female 100A Female crimp contacts Wire gauge Ø mm2 Stripping length Crimp contacts, silver-plated mm Type Part Number 10 16 25 35 4.3 5.5 7 8.2 19 19 19 16 CNM-10 CNM-16 CNM-25 CNM-35 T2050001010-000 T2050001016-000 T2050001025-000 T2050001035-000 10 16 25 35 4.3 5.5 7 8.2 19 19 19 16 CNF-10 CNF-16 CNF-25 CNF-35 T2050002010-000 T2050002016-000 T2050002025-000 T2050002035-000 207 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 70A/2 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ....................................................................... 2 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current .......................................................................... 70A max (See current carrying capacity) Working voltage ............................................................................... 1000V Test voltage urms ................................................................................. 8KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated Contact resistance ......................................................................... ≤0.5mΩ Terminal .............................................................................. Crimp terminal - mm2 ............................................................................................... 6-22mm2 - AWG ..........................................................................................................8-4 208 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 6 modules; wire gauge: 6mm2 2 H24B hood/housing with 6 modules; wire gauge: 16mm2 3 H24B hood/housing with 6 modules; wire gauge: 22mm2 HMN-002 module inserts CRIMP TERMINAL 1000V MAX. 70A 2 Poles Dimensions (mm) Type Part Number Male insert Crimp terminal (order crimp contacts separately) Female insert Contact arrangement view from termination side HMN-002-MC T2111020101-000 HMN-002-FC T2111020201-000 70A Contact Male Female A Wire gauge mm2 AWG 10.0mm2 16.0mm2 25.0mm2 AWG7 AWG5 AWG3 4.3 5.5 7.0 10.0mm2 16.0mm2 25.0mm2 AWG7 AWG5 AWG3 4.3 5.5 7.0 B Crimp contacts, silver-plated Type Part Number 5.6 8.5 10.0 CSM-10 CSM-16 CSM-25 T2400001100-000 T2400001160-000 T2400001250-000 5.6 8.5 10.0 CSF-10 CSF-16 CSF-25 T2400002100-000 T2400002160-000 T2400002250-000 209 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 40A/3 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ....................................................................... 3 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ..........................................................................40A max (See current carrying capacity) Working voltage Cable ø up to 5mm............................................................................. 690V Cable ø up to 7.5mm.......................................................................... 500V Test voltage urms ................................................................................. 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated Contact resistance ......................................................................... ≤0.3mΩ Terminal .............................................................................. Crimp terminal - mm2 ...............................................................................................1.0-6mm2 - AWG .......................................................................................................18-10 210 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 6 modules; wire gauge: 6.0mm2 2 H24B hood/housing with 6 modules; wire gauge: 4.0mm2 3 H24B hood/housing with 6 modules; wire gauge: 10.0mm2 HMN-003 module inserts CRIMP TERMINAL 690V MAX. 40A 3 Poles Dimensions (mm) Type Part Number Male insert Crimp terminal Female insert Size chart HMN-003-M T2111032101-000 HMN-003-F T2111032201-000 Contact arrangement view from termination side 40A Contact Tech data Material: copper alloy Contact resistance: ≤0.3mΩ Terminal: crimp connection CMM/Male 40A Male crimp contacts CMF/Female 40A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated mm2 AWG mm Type Part Number 1.5 2.5 4.0 6.0 10 16 14 12 10 7 8.0 8.0 8.0 8.0 8.0 CMM-1.5 CMM-2.5 CMM-4.0 CMM-6.0 CMM-10 T2040001015-000 T2040001025-000 T2040001040-000 T2040001060-000 T2040001100-000 1.5 2.5 4.0 6.0 10 16 14 12 10 7 8.0 8.0 8.0 8.0 8.0 CMF-1.5 CMF-2.5 CMF-4.0 CMF-6.0 CMF-10 T2040002015-000 T2040002025-000 T2040002040-000 T2040002060-000 T2040002100-000 211 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 40A/4 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .......................................................................4 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ..........................................................................40A max (See current carrying capacity) Working voltage Cable ø up to 5mm..............................................................................830V Cable ø up to 7.5mm.......................................................................... 500V Test voltage urms ................................................................................. 8KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated Contact resistance ......................................................................... ≤0.3mΩ Terminal .............................................................................. Crimp terminal - mm2 ...............................................................................................1.0-6mm2 - AWG .......................................................................................................18-10 212 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 6 modules; wire gauge: 6.0mm2 2 H24B hood/housing with 6 modules; wire gauge: 4.0mm2 HMN-004 module inserts CRIMP TERMINAL 830V MAX. 40A 4 Poles Dimensions (mm) Type Part Number Male insert Crimp terminal Female insert Size chart HMN-004-M T2111042101-000 HMN-004-F T2111042201-000 Contact arrangement view from termination side 40A Contact Tech data Material: copper alloy Contact resistance: ≤0.3mΩ Terminal: crimp connection CMM/Male 40A Male crimp contacts CMF/Female 40A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated mm2 AWG mm Type Part Number 1.5 2.5 4.0 6.0 10 16 14 12 10 7 8.0 8.0 8.0 8.0 8.0 CMM-1.5 CMM-2.5 CMM-4.0 CMM-6.0 CMM-10 T2040001015-000 T2040001025-000 T2040001040-000 T2040001060-000 T2040001100-000 1.5 2.5 4.0 6.0 10 16 14 12 10 7 8.0 8.0 8.0 8.0 8.0 CMF-1.5 CMF-2.5 CMF-4.0 CMF-6.0 CMF-10 T2040002015-000 T2040002025-000 T2040002040-000 T2040002060-000 T2040002100-000 213 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 16A/5 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ....................................................................... 5 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 16A max (See current carrying capacity) Working voltage..................................................................................400V Test voltage urms ................................................................................. 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ........................................................ -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance .............................................................................≤3mΩ Terminal ..............................................................................Spring terminal - mm2 .......................................................................................... 0.5-2.5mm2 - AWG ..................................................................................................... 20-14 214 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 6 modules; wire gauge: 2.5mm2 2 H24B hood/housing with 6 modules; wire gauge: 1.5mm2 HMN-005 module inserts SPRING TERMINAL 400V MAX. 16A 5 Poles  Dimensions (mm) Type Part Number Male insert Spring terminal Female insert Size chart HMN-005-MS HMN-005-FS T2110052101-000 T2110052201-000 Contact arrangement view from termination side 215 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 16A/6 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .......................................................................6 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 16A max (See current carrying capacity) Working voltage........................................................................ 500/830V Test voltage urms HMN-006-M/F......................................................................................... 6KV HMN-006-PM/F...................................................................................... 8KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ..............................................................................≤1mΩ Terminal .............................................................................. Crimp terminal - mm2 ........................................................................................ 0.14-4.0mm2 - AWG ...................................................................................................... 26-12 216 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 6 modules; wire gauge: 1.5mm2 2 H24B hood/housing with 6 modules; wire gauge: 2.5mm2 2 H24B hood/housing with 6 modules; wire gauge: 4mm2 HMN-006 module inserts CRIMP TERMINAL 6 Poles  Dimensions (mm) Type Part Number Male insert Crimp terminal Female insert Contact arrangement view from termination side 500V max. 16A HMN-006-M T2111062101-000 HMN-006-F T2111062201-000 830V Max. 16A HMN-006-PM T2111063101-000 HMN-006-PF T2111063201-000 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 217 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 16A/8 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .......................................................................8 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 16A max (See current carrying capacity) Working voltage..................................................................................400V Test voltage urms ................................................................................. 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ..............................................................................≤1mΩ Terminal .............................................................................. Crimp terminal - mm2 ........................................................................................ 0.14-4.0mm2 - AWG ...................................................................................................... 26-12 218 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 6 modules; wire gauge: 2.5mm2 2 H24B hood/housing with 6 modules; wire gauge: 1.5mm2 HMN-008 module inserts CRIMP TERMINAL 400V MAX. 16A 8 Poles  Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HMN-008-M T2111082101-000 HMN-008-F T2111082201-000 Contact arrangement view from termination side 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 219 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 10A/12 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ......................................................................12 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 10A max (See current carrying capacity) Working voltage...................................................................................250V Test voltage urms ................................................................................. 4KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance .............................................................................≤3mΩ Terminal .............................................................................. Crimp terminal - mm2 ......................................................................................... 0.14-2.5mm2 - AWG ......................................................................................................26-14 220 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 6 modules; wire gauge: 1.5mm2 2 H24B hood/housing with 6 modules; wire gauge: 1.0mm2 HMN-012 module inserts CRIMP TERMINAL 250V MAX. 10A 12 Poles  Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HMN-012-M T2111122101-000 HMN-012-F T2111122201-000 Contact arrangement view from termination side 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 221 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 10A/17 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ......................................................................17 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 10A max (See current carrying capacity) Working voltage....................................................................................160V Test voltage urms ..............................................................................2.5KV Pollution degree .......................................................................................... 3 Pollution degree acc. to TUV.................................................................. 2 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance .............................................................................≤3mΩ Terminal .............................................................................. Crimp terminal - mm2 ......................................................................................... 0.14-2.5mm2 - AWG ......................................................................................................26-14 222 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 6 modules; wire gauge: 1.5mm2 2 H24B hood/housing with 6 modules; wire gauge: 1.0mm2 HMN-017 module inserts CRIMP TERMINAL 160V MAX. 10A 17 Poles  Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HMN-017-M T2111172101-000 HMN-017-F T2111172201-000 Contact arrangement view from termination side 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 26-22 20 CDF-0.14 CDF-0.5 T2020002002-000 T2020002005-000 DDF-0.14 DDF-0.5 T2020012002-000 T2020012005-000 0.75 1.0 1.5 2.5 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 223 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 16A/20 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .................................................................... 20 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ........................................................................... 16A max (See current carrying capacity) Working voltage.................................................................................. 500V Test voltage urms ................................................................................. 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ..............................................................................≤1mΩ Terminal .............................................................................. Crimp terminal - mm2 ........................................................................................ 0.14-4.0mm2 - AWG ...................................................................................................... 26-12 224 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 H24B hood/housing with 3 modules; wire gauge: 1.5mm2 2 H24B hood/housing with 3 modules; wire gauge: 2.5mm2 3 H24B hood/housing with 3 modules; wire gauge: 4mm2 HMN-020 module inserts CRIMP TERMINAL 500V MAX. 16A 20 Poles  Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HMN-020-M T2111202101-000 HMN-020-F T2111202201-000 Contact arrangement view from termination side 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated Type mm2 AWG mm Type Part Number Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 225 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. 5A/25 Poles module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .....................................................................25 poles The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Working current ............................................................................. 5A max (See current carrying capacity) Working voltage..................................................................................... 50V Test voltage urms ............................................................................. 0.8KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ..............................................................................≤1mΩ Terminal .............................................................................. Crimp terminal - mm2 .....................................................................................0.08-0.52mm2 - AWG .....................................................................................................28-20 Working current INSERTS Ambient temperature Turned contacts 1 H24B hood/housing with 6 modules; wire gauge: 0.5mm2 Stamped contacts 2 H24B hood/housing with 6 modules; wire gauge: 0.5mm2 226 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HMN-025 module inserts CRIMP TERMINAL 50V MAX. 5A 25 poles  Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HMN-025-M T2111252101-000 HMN-025-F T2111252201-000 Contact arrangement view from termination side 5A Contact Male Female Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.08-0.21 0.13-0.33 0.33-0.52 28-24 26-22 22-20 5.0 5.0 5.0 CAM-08 CAM-13 CAM-33 T2070001008-000 T2070001013-000 T2070001033-000 DAM-08 DAM-13 DAM-33 T2070011008-000 T2070011013-000 T2070011033-000 0.08-0.21 0.13-0.33 0.33-0.52 28-24 26-22 22-20 5.0 5.0 5.0 CAF-08 CAF-13 CAF-33 T2070002008-000 T2070002013-000 T2070002033-000 DAF-08 DAF-13 DAF-33 T2070012008-000 T2070012013-000 T2070012033-000 227 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. D-Sub & RJ45 module technical characteristics D-SUB MODULE TECHNICAL CHARACTERISTICS RJ45 MODULE TECHNICAL CHARACTERISTICS Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .......................................................................9 poles Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .......................................................................8 poles INSERTS INSERTS Working current ............................................................................. 5A max (See current carrying capacity) Working voltage..................................................................................... 50V Test voltage urms ............................................................................. 0.8KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Mechanical working life-mating cycles ...................................... ≥500 Working current .............................................................................. 1A max (See current carrying capacity) Working voltage..................................................................................... 50V Test voltage urms ............................................................................. 0.8KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range ...........................................................-40°C... +85°C Flammability acc. to UL94 ...................................................................V0 Mechanical working life-mating cycles ...................................... ≥500 CONTACTS MODULE WITH RJ45 TERMINAL Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance ..............................................................................≤1mΩ Terminal .............................................................................. Crimp terminal Material ................................................................................ Polycarbonate Temperature range........................................................... -40°C... +70°C Flammability acc. to UL94 ...................................................................V0 Stranded wire diameter.................................................... 0.89-0.99mm Wire gauge................................................................................. AWG24-26 Material ................................................................................ Polycarbonate Temperature range........................................................... -40°C... +70°C Flammability acc. to UL94 ...................................................................V0 Stranded wire diameter..................................................... 0.94-1.07mm Wire gauge..................................................................................AWG22-24 228 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS D-Sub/RJ45/USB module inserts CRIMP TERMINAL 9 Poles & 8 Poles & USB  Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HMN-009-M T2111092101-000 HMN-009-F HMN-RJ45-MC T2111092201-000 T2113000101-100 HMN-RJ45-F HMN-USB-M HMN-USB-F T2113000201-000 T2114000101-000 T2114000201-000 229 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Quint module technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 INSERTS Number of contacts ................................................................................... 2 Insulation resistance.......................................................................≥ 1010 Ω Material................................................................................. Polycarbonate Temperature range......................................................... -40°C ... +125°C Flammability acc. to UL 94...................................................................V0 Mechanical working life-mating cycles....................................... ≥500 QUINT CONTACTS Number of contacts - Quint 1 + shielding - Quint 4 + shielding - High Density Quint 8 + shielding Working current - Quint 1............................................................................................. 16A max - Quint 4 .......................................................................................... 10A max - Quint 8 ............................................................................................ 5A max Working voltage..................................................................................... 50V Test voltage urms............................................................................... 0.8KV Pollution degree .......................................................................................... 3 Quint 8 Pollution degree acc. to TUV.................................................. 2 Insulation resistance...................................................................... ≥ 1010 Ω Material ................................................................................ Polycarbonate Temperature range......................................................... -40°C ... +125°C Flammability acc. to UL 94...................................................................V0 Mechanical working life-mating cycles....................................... ≥500 CONTACTS Material.....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance..............................................................................≤3mΩ Terminal .............................................................................. Crimp terminal - mm2 - Quint 1......................................................................................... 0.14-4mm2 - Quint 4 ................................................................................... 0.14-2.5mm2 - Quint 8 ...............................................................................0.08-0.52mm2 - AWG - Quint 1.................................................................................................... 26-12 - Quint 4................................................................................................. 26-14 - Quint 8 ................................................................................................28-20 230 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Quint module inserts CRIMP TERMINAL 2 Poles Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HMN-Q1-M T2111027101-000 HMN-Q1-F HMN-Q2-M T2111027201-000 T2111027101-001 HMN-Q2-F HMN-Q3-M T2111027201-001 T2111027101-002 HMN-Q3-F T2111027201-002 Quint 1-pos For 16A crimp contacts PIN-Q1-M T2580011154-000 PIN-Q1-F T2580012154-000 Quint 4-pos For 10A crimp contacts PIN-Q2-M T2580031154-000 PIN-Q2-F T2580032154-000 Quint 8-pos For D-Sub crimp contacts PIN-Q3-M PIN-Q3-F T2580081154-000 T2580082154-000 231 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Dummy module inserts 1 Dimensions (mm) Type Part Number Male insert Size chart HMN-DM 232 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS T3110009902-000 Female insert HMN-P2, P3 module for pneumatic contacts PNEUMATIC CONTACTS, MODULAR UNITS, WITH 2 OR 3 SEATS P2, P3  Dimensions (mm) Type Part Number Male insert Female insert Contact arrangement view from termination side HMN-PA3 T2111032301-000 HMN-PA2 T2111022301-000 Male contacts without closing valve For tubes with internal ø 1.6mm (For HMN P3 module) For tubes with internal ø 3.0mm (For HMN P3 module) For tubes with internal ø 4.0mm (For HMN P3 module) For tubes with internal ø 6.0mm (For HMN P2 module) Pneu-c-M1.6 Pneu-c-M3.0 Pneu-c-M4.0 Pneu-c-M6.0 T2090002101-001 T2090002101-002 T2090002101-003 T2090002101-004 Female contacts without closing valve For tubes with internal ø 1.6mm (For HMN P3 module) For tubes with internál ø 3.0mm (For HMN P3 module) For tubes with internal ø 4.0mm (For HMN P3 module) For tubes with internal ø 6.0mm (For HMN P2 module) Pneu-c-F1.6 Pneu-c-F3.0 Pneu-c-F4.0 Pneu-c-F6.0 T2090002201-001 T2090002201-002 T2090002201-003 T2090002201-004 Female contacts with closing valve For tubes with internal ø 1.6mm (For HMN P3 module) For tubes with internál ø 3.0mm (For HMN P3 module) For tubes with internal ø 4.0mm (For HMN P3 module) For tubes with internal ø 6.0mm (For HMN P3 module) Pneu-c-Fw1.6 Pneu-c-Fw3.0 Pneu-c-Fw4.0 Pneu-c-Fw6.0 T2090012201-001 T2090012201-002 T2090012201-003 T2090012201-004 Pneumatic contacts with or without closing valve Male contacts (use contacts without closing valve) 233 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Notes 234 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HK, HWK Series 1. Specifications DIN VDE 0110 Concerning clearance and creepage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 60 664-1 DIN EN 61 984 3. Approvals 235 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HK8/24 technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ................................................................. 8/24 + PE INSERTS Rated current Power contact................................................................................ 16A max Signal contact................................................................................. 10A max Working voltage Power contact Conductor - ground............................................................................230V Conductor - conductor.....................................................................400V Signal contact.........................................................................................160V Test voltage urms Power contact......................................................................................... 4KV Signal contact.......................................................................................2.5KV Pollution degree .......................................................................................... 2 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA..................................... 600V/300V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance .............................................................................≤3mΩ Terminal .............................................................................. Crimp terminal - mm2 Power contact.........................................................................0.15-4.0mm2 Signal contact.......................................................................... 0.15-2.5mm2 - AWG Powder contact.................................................................................... 26-12 Signal contact........................................................................................26-14 HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 236 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. HK8/24 inserts INSERTS FOR H10B HOOD/HOUSING 400V/160V MAX. 16A/10A 8/24+ Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (Order crimp contacts separately) HK8/24-032-M T2100322101-000 HK8/24-032-F T2100322201-000 Contact arrangement view from termination side 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 CDF/Female 10A Female crimp contacts 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Type 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T2030001002-000 T2030001005-000 T2030001008-000 T2030001010-000 T2030001015-000 T2030001025-000 T2030001040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 CEF/Female 16A Female crimp contacts 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T2030002002-000 T2030002005-000 T2030002008-000 T2030002010-000 T2030002015-000 T2030002025-000 T2030002040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 16A Contact Part Number Part Number 237 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H10B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H10B-TS-PG16 H10B-TS-PG21 H10B-TS-M20 H10B-TS-M25 T1210100116-000 T1210100121-000 T1210100120-000 T1210100125-000 PG21 PG29 H10B-TSH-PG21 H10B-TSH-PG29 H10B-TSH-M20 H10B-TSH-M25 H10B-TSH-M32 T1230100121-000 T1230100129-000 T1230100120-000 T1230100125-000 T1230100132-000 PG16 PG21 H10B-TG-PG16 H10B-TG-PG21 H10B-TG-M20 H10B-TG-M25 T1220100116-000 T1220100121-000 T1220100120-000 T1220100125-000 PG21 PG29 H10B-TGH-PG21 H10B-TGH-PG29 H10B-TGH-M20 H10B-TGH-M25 H10B-TGH-M32 T1240100121-000 T1240100129-000 T1240100120-000 T1240100125-000 T1240100132-000 PG16 H10B-TBFS-PG16 H10B-TBFS-M20 H10B-TBFS-M25 H10B-TBFHS-PG21 H10B-TBFHS-PG29 H10B-TBFHS-M25 H10B-TBFHS-M32 T1710101116-000 T1710101120-000 T1710101125-000 T1750101121-000 T1750101129-000 T1750101125-000 T1750101132-000 H10B-KDTP T1010101400-000 H10B-KDBP T1010102100-000 Hood: Side entry Low construction M20 M25 High construction M20 M25 M32 Hood: Top entry Low construction M20 M25 High construction M20 M25 M32 Cable-to-cable hood Low construction Construction H 62.5 Hight 74.5 High construction Low M20 M25 M25 M32 PG21 PG29 Protection covers for hoods Housing protection cover 238 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H10B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H10B-AGS T1410101000-000 H10B-SGRS-PG16 H10B-SGRS-PG21 H10B-SGRS-M20 H10B-SGRS-M25 H10B-SGRS-2PG16 H10B-SGRS-2PG21 H10B-SGRS-2M20 H10B-SGRS-2M25 H10B-SGRHS-PG21 H10B-SGRHS-PG29 H10B-SGRHS-M25 H10B-SGRHS-M32 H10B-SGRHS-2PG21 H10B-SGRHS-2PG29 H10B-SGRHS-2M25 H10B-SGRHS-2M32 T1440101116-000 T1440101121-000 T1440101120-000 T1440101125-000 T1440101216-000 T1440101221-000 T1440101220-000 T1440101225-000 T1470101121-000 T1470101129-000 T1470101125-000 T1470101132-000 T1470101221-000 T1470101229-000 T1470101225-000 T1470101232-000 H10B-TSBS-PG16 H10B-TSBS-PG21 H10B-TSBS-M20 H10B-TSBS-M25 H10B-TSBHS-PG21 H10B-TSBHS-PG29 H10B-TSBHS-M25 H10B-TSBHS-M32 T1250103116-000 T1250103121-000 T1250103120-000 T1250103125-000 T1270103121-000 T1270103129-000 T1270103125-000 T1270103132-000 H10B-TGBS-PG16 H10B-TGBS-PG21 H10B-TGBS-M20 H10B-TGBS-M25 H10B-TGBHS-PG21 H10B-TGBHS-PG29 H10B-TGBHS-M25 H10B-TGBHS-M32 T1260103116-000 T1260103121-000 T1260103120-000 T1260103125-000 T1280103121-000 T1280103129-000 T1280103125-000 T1280103132-000 H10B-AD-BO T1430100000-000 H10B-SDR-BO-PG16 H10B-SDR-BO-PG21 H10B-SDR-BO-M20 H10B-SDR-BO-M25 H10B-SDR-BO-2PG16 H10B-SDR-BO-2PG21 H10B-SDR-BO-2M20 H10B-SDR-BO-2M25 H10B-SDRH-BO-PG21 H10B-SDRH-BO-PG29 H10B-SDRH-BO-M25 H10B-SDRH-BO-M32 H10B-SDRH-BO-2PG21 H10B-SDRH-BO-2PG29 H10B-SDRH-BO-2M25 H10B-SDRH-BO-2M32 T1460100116-000 T1460100121-000 T1460100120-000 T1460100125-000 T1460100216-000 T1460100221-000 T1460100220-000 T1460100225-000 T1490100121-000 T1490100129-000 T1490100125-000 T1490100132-000 T1490100221-000 T1490100229-000 T1490100225-000 T1490100232-000 Bulkhead mounted Surface mounted: Side entry Hight 45 57 74 2 Side entry 56 High construction H 52 1 Side entry B 40 2 Side entry Low construction A Low 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction High construction Construction H Low 60 Hight 72 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction High construction Construction H Low 60 Hight 72 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover 2 Side entry Low construction 1 Side entry M20 M25 M20 M25 82 94 40 52 22 67 54 B C D F G H Hight 82 94 45 57 20 65 74 2 Side entry High construction A Low 1 Side entry Construction M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 239 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H10B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H10B-TS-RO-PG16 H10B-TS-RO-PG21 H10B-TS-RO-M20 H10B-TS-RO-M25 T1310100116-000 T1310100121-000 T1310100120-000 T1310100125-000 PG21 PG29 H10B-TSH-RO-PG21 H10B-TSH-RO-PG29 H10B-TSH-RO-M20 H10B-TSH-RO-M25 H10B-TSH-RO-M32 T1330100121-000 T1330100129-000 T1330100120-000 T1330100125-000 T1330100132-000 PG16 PG21 H10B-TG-RO-PG16 H10B-TG-RO-PG21 H10B-TG-RO-M20 H10B-TG-RO-M25 T1320100116-000 T1320100121-000 T1320100120-000 T1320100125-000 PG21 PG29 H10B-TGH-RO-PG21 H10B-TGH-RO-PG29 H10B-TGH-RO-M20 H10B-TGH-RO-M25 H10B-TGH-RO-M32 T1340100121-000 T1340100129-000 T1340100120-000 T1340100125-000 T1340100132-000 PG16 H10B-TBF-LB-PG16 H10B-TBF-LB-M20 H10B-TBF-LB-M25 H10B-TBFH-LB-PG21 H10B-TBFH-LB-PG29 H10B-TBFH-LB-M25 H10B-TBFH-LB-M32 T1730103116-000 T1730103120-000 T1730103125-000 T1770103121-000 T1770103129-000 T1770103125-000 T1770103132-000 H10B-KDTP-LB T1010101500-000 Hood: Side entry Low construction M20 M25 High construction M20 M25 M32 Hood: Top entry Low construction M20 M25 High construction M20 M25 M32 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M20 M25 M25 M32 PG21 PG29 Protection covers for hoods 240 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H10B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H10B-AG-LB T1500103000-000 H10B-AD-LB H10B-ADM-LB T1510103000-000 T1510103001-000 H10B-SGR-LB-PG16 H10B-SGR-LB-PG21 H10B-SGR-LB-M20 H10B-SGR-LB-M25 H10B-SGR-LB-2PG16 H10B-SGR-LB-2PG21 H10B-SGR-LB-2M20 H10B-SGR-LB-2M25 H10B-SGRH-LB-PG21 H10B-SGRH-LB-PG29 H10B-SGRH-LB-M25 H10B-SGRH-LB-M32 H10B-SGRH-LB-2PG21 H10B-SGRH-LB-2PG29 H10B-SGRH-LB-2M25 H10B-SGRH-LB-2M32 T1610103116-000 T1610103121-000 T1610103120-000 T1610103125-000 T1610103216-000 T1610103221-000 T1610103220-000 T1610103225-000 T1650103121-000 T1650103129-000 T1650103125-000 T1650103132-000 T1650103221-000 T1650103229-000 T1650103225-000 T1650103232-000 H10B-SDR-LB-PG16 H10B-SDR-LB-PG21 H10B-SDR-LB-M20 H10B-SDR-LB-M25 H10B-SDR-LB-2PG16 H10B-SDR-LB-2PG21 H10B-SDR-LB-2M20 H10B-SDR-LB-2M25 H10B-SDRH-LB-PG21 H10B-SDRH-LB-PG29 H10B-SDRH-LB-M25 H10B-SDRH-LB-M32 H10B-SDRH-LB-2PG21 H10B-SDRH-LB-2PG29 H10B-SDRH-LB-2M25 H10B-SDRH-LB-2M32 T1620103116-000 T1620103121-000 T1620103120-000 T1620103125-000 T1620103216-000 T1620103221-000 T1620103220-000 T1620103225-000 T1660103121-000 T1660103129-000 T1660103125-000 T1660103132-000 T1660103221-000 T1660103229-000 T1660103225-000 T1660103232-000 Bulkhead mounted With protection cover Surface mounted: Side entry Hight 45 57 74 54 Hight 45 57 74 2 Side entry H 52 High construction B 40 1 Side entry A Low 2 Side entry Low construction Construction 1 Side entry With protection cover 2 Side entry 54 High construction H 52 1 Side entry B 40 2 Side entry Low construction A Low 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 241 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.10/24, HIP-K.10/24, EMV-K.10/24 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 16 21 HIP HIP.10/24.STS.1.16.G HIP.10/24.STS.1.21.G HIP.10/24.STS.1.M25.G 1-1102640-5 1-1102642-5 0-1106436-2 HIP-K HIP-K.10/24.STS.1.21.G HIP-K.10/24.STS.1.M25.G HIP-K.10/24.STS.1.M32.G 2-1102642-5 0-1106436-4 0-1106436-6 EMV-K EMV-K.10/24.STS.1.21.G EMV-K.10/24.STS.1.M25.G EMV-K.10/24.STS.1.M32.G 4-1102714-5 0-1106427-3 1-1106427-0 HIP HIP.10/24.STO.1.16.G HIP.10/24.STO.1.21.G HIP.10/24.STO.1.M25.G 1-1102644-5 1-1102646-5 0-1106436-1 HIP-K HIP-K.10/24.STO.1.16.G HIP-K.10/24.STO.1.M25.G HIP-K.10/24.STO.1.M32.G 2-1102644-5 0-1106436-3 0-1106436-5 EMV-K EMV-K.10/24.STO.1.21.G EMV-K.10/24.STO.1.M25.G 4-1102715-5 0-1106427-4 HIP HIP.10/24.AG 1-1102647-5 Hood: Side entry, Standard construction M25 M25 M32 M25 M32 21 21 Hood: Top entry M25 M25 M32 M25 16 21 16 21 8 22 Surface mounted housing: Bottom entry 83 109 ø4,5 32 56 36 32 M4 65 83 242 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP-K HIP-K.10/24.AG EMV-K EMV-K.10/24.AG 2-1102647-5 4-1102718-5 HIP.10/24, HIP-K.10/24, EMV-K.10/24 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Pressure-tight up to 5 bar IP 68 / IP 69 K Description Metr. PG Type Part Number HIP HIP.10/24.AG.M6 1-1102612-5 HIP-K HIP-K.10/24.AG.M6 2-1102612-5 EMV-K EMV-K.10/24.AG.M6 4-1102720-5 HIP HIP.10/24.SG.1.21.G HIP.10/24.SG.2.21.G HIP.10/24.SG.2.M32.G 1-1102610-5 1-1102611-5 0-1106435-1 HIP-K HIP-K.10/24.SG.1.21.G HIP-K.10/24.SG.2.21.G 5-1102610-5 2-1102611-5 EMV-K EMV-K.10/24.SG.1.21.G EMV-K.10/24.SG.2.21.G EMV-K.10/24.SG.2.M32.G 5-1102716-5 4-1102717-5 0-1106426-2 HIP HIP/EMV.10/24.SKB 3-1106202-5 Surface mounted housing: Bottom entry M6x20 22 22 M6x20 43 43 60 92 92 109 109 60 Panel cut-out M6 M6 3636 43 43 65 65 92 92 Surface mounted housing: Side entry 2xM32 21 2x21 21 2x21 2xM32 21 2x21 Protective covers for hoods and housing M6x30 19 109 53 HIP-K/EMV-K HIP-K/EMV-K.10/24.SKB 4-1106202-5 243 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HWK 6/6 technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ...................................................................... 6/6+PE INSERTS Rated current Power contact...............................................................................40A max Signal contact ............................................................................... 16A max Working voltage Power contact ..................................................................................... 690V Signal contact.......................................................................................400V Test voltage urms Power contact......................................................................................... 6KV Signal contact.......................................................................................... 4KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA ................................................. 600V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance Power contact ................................................................................. ≤0.3mΩ Signal contact........................................................................................≤1mΩ Terminal .............................................................................. Screw terminal - mm2 Power contact.............................................................................2.5-10mm2 Signal contact........................................................................... 0.5-2.5mm2 - AWG Power contact......................................................................................... 14-8 Signal contact....................................................................................... 20-14 - Tightening/test torque Power contact.................................................................................... 1.2 Nm Signal contact....................................................................................0.5 Nm HOODS, HOUSINGS Material........................................................................ Die cast aluminium Surface........................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 244 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. HWK 6/6 inserts POWER 690V/35A SIGNAL 400V/16A INSERTS FOR H16B HOOD/HOUSING 6/6   Dimensions (mm) Type Part Number Male insert Screw terminal Female insert Contact arrangement view from termination side HWK6/6-012-M HWK6/6-012-F T2106062101-000 T2106062201-000 245 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HK4/0, HK4/2 technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts .......................................................... 4/0, 4/2 + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Rated current Power contact .............................................................................. 80A max Signal contact ............................................................................... 16A max (See current carrying capacity) Working voltage Power contact .................................................................................... 690V Signal contact .................................................................................... 400V Test voltage urms Power contact ........................................................................................ 8KV Signal contact........................................................................................ 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA..................................... 600V/300V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance Power contact ................................................................................. ≤0.3mΩ Signal contact ..................................................................................... ≤1mΩ Terminal .............................................................................. Screw terminal - mm2 Power contact .............................................................................1.5-16mm2 Signal contact ....................................................................... 0.5-2.5mm2 - AWG Power contact ....................................................................................... 16-6 Signal contact .................................................................................... 20-14 - Tightening/test torque Power contact .................................................................................. 1.2 Nm Signal contact ................................................................................. 0.5 Nm HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 246 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 Wire gauge: 16mm2 2 Wire gauge: 10mm2 Wire gauge: 1.5 mm2 HK4/0, HK4/2 inserts INSERTS FOR H16B HOOD/HOUSING 4/0+ 690V/400V MAX. 80A/16A 4/2+  Dimensions (mm) Type Part Number Male insert Screw terminal Female insert Size chart HK4/0-004-M T2100042101-000 HK4/0-004-F T2100042201-000 Contact arrangement view from termination side Dimensions (mm) Type Part Number Male insert Screw terminal Female insert Size chart HK4/2-006-M HK4/2-006-F T2100062101-000 T2100062201-000 Contact arrangement view from termination side 247 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HK12/2 technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ...................................................................12/2 + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Rated current Power contact ..............................................................................40A max Signal contact ............................................................................... 10A max (See current carrying capacity) Working voltage Power contact ..................................................................................... 690V Signal contact......................................................................................250V Test voltage urms Power contact ........................................................................................ 8KV Signal contact ........................................................................................ 4KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA..................................... 600V/300V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance Power contact.................................................................................. ≤0.3mΩ Signal contact.......................................................................................≤3mΩ Terminal .............................................................................. Crimp terminal - mm2 Power contact...................................................................................1-6mm2 Signal contact.......................................................................... 0.14-2.5mm2 - AWG Power contact........................................................................................18-10 Signal contact........................................................................................26-14 HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 248 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 Wire gauge: 6.0mm2 2 Wire gauge: 4.0mm2 Wire gauge: 1.5 mm2 HK12/2 inserts INSERT FOR H16B HOOD/HOUSING 690V/250V MAX. 40A/10A 12/2+  Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HK12/2-014-M T2120142101-000 HK12/2-014-F T2120142201-000 Contact arrangement view from termination side 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 40A Contact Tech data Material: copper alloy Contact resistance: ≤0.3mΩ Terminal: crimp connection CMM/Male 40A Male crimp contacts CMF/Female 40A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated mm2 AWG mm Type Part Number 1.5 2.5 4.0 6.0 16 14 12 10 8.0 8.0 8.0 8.0 CMM-1.5 CMM-2.5 CMM-4.0 CMM-6.0 T2040001015-000 T2040001025-000 T2040001040-000 T2040001060-000 1.5 2.5 4.0 6.0 10 16 14 12 10 7 8.0 8.0 8.0 8.0 8.0 CMF-1.5 CMF-2.5 CMF-4.0 CMF-6.0 CMF-10 T2040002015-000 T2040002025-000 T2040002040-000 T2040002060-000 T2040002100-000 249 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HK6/36 technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ................................................................. 6/36 + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Rated current Power contact ..............................................................................40A max Signal contact ............................................................................... 10A max (See current carrying capacity) Working voltage Power contact ..................................................................................... 690V Signal contact .......................................................................................160V Test voltage urms Power contact ........................................................................................ 6KV Signal contact .....................................................................................2.5KV Pollution degree .......................................................................................... 2 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA..................................... 600V/300V Mechanical working life-mating cycles ...................................... ≥500 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance Power contact.................................................................................. ≤0.3mΩ Signal contact.......................................................................................≤3mΩ Terminal .............................................................................. Crimp terminal - mm2 Power contact...................................................................................1-6mm2 Signal contact.......................................................................... 0.14-2.5mm2 - AWG Power contact........................................................................................18-10 Signal contact........................................................................................26-14 HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 250 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Working current INSERTS Ambient temperature 1 Wire gauge: 6.0mm2 2 Wire gauge: 4.0mm2 Wire gauge: 1.5 mm2 HK6/36 inserts INSERT FOR H16B HOOD/HOUSING 690V/250V MAX. 40A/10A 6/36+  Dimensions (mm) Type Part Number Male insert Crimp terminal (Order crimp contacts separately) Female insert Size chart HK6/36-042-M T2120422101-000 HK6/36-042-F T2120422201-000 Contact arrangement view from termination side 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 40A Contact Tech data Material: copper alloy Contact resistance: ≤0.3mΩ Terminal: crimp connection CMM/Male 40A Male crimp contacts CMF/Female 40A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated mm2 AWG mm Type Part Number 1.5 2.5 4.0 6.0 16 14 12 10 8.0 8.0 8.0 8.0 CMM-1.5 CMM-2.5 CMM-4.0 CMM-6.0 T2040001015-000 T2040001025-000 T2040001040-000 T2040001060-000 1.5 2.5 4.0 6.0 10 16 14 12 10 7 8.0 8.0 8.0 8.0 8.0 CMF-1.5 CMF-2.5 CMF-4.0 CMF-6.0 CMF-10 T2040002015-000 T2040002025-000 T2040002040-000 T2040002060-000 T2040002100-000 251 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H16B-TS-PG16 H16B-TS-PG21 H16B-TS-M20 H16B-TS-M25 H16B-TS-M32 T1210160116-000 T1210160121-000 T1210160120-000 T1210160125-000 T1210160132-000 PG21 PG29 H16B-TSH-PG21 H16B-TSH-PG29 H16B-TSH-M25 H16B-TSH-M32 H16B-TSH-M40 T1230160121-000 T1230160129-000 T1230160125-000 T1230160132-000 T1230160140-000 PG16 PG21 H16B-TG-PG16 H16B-TG-PG21 H16B-TG-M25 H16B-TG-M32 T1220160116-000 T1220160121-000 T1220160125-000 T1220160132-000 PG21 PG29 H16B-TGH-PG21 H16B-TGH-PG29 H16B-TGH-M25 H16B-TGH-M32 H16B-TGH-M40 T1240160121-000 T1240160129-000 T1240160125-000 T1240160132-000 T1240160140-000 PG21 H16B-TBFS-PG21 H16B-TBFS-M25 H16B-TBFS-M32 H16B-TBFHS-PG21 H16B-TBFHS-PG29 H16B-TBFHS-M25 H16B-TBFHS-M32 H16B-TBFHS-M40 T1710161121-000 T1710161125-000 T1710161132-000 T1750161121-000 T1750161129-000 T1750161125-000 T1750161132-000 T1750161140-000 H16B-KDTP T1010161400-000 H16B-KDBP T1010162100-000 Hood: Side entry Low construction M20 M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods Housing protection cover 252 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H16B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H16B-AGS T1410161000-000 H16B-SGRS-PG21 H16B-SGRS-M25 H16B-SGRS-2PG21 H16B-SGRS-2M25 H16B-SGRHS-PG21 H16B-SGRHS-PG29 H16B-SGRHS-M25 H16B-SGRHS-M32 H16B-SGRHS-2PG21 H16B-SGRHS-2PG29 H16B-SGRHS-2M25 H16B-SGRHS-2M32 T1440161121-000 T1440161125-000 T1440161221-000 T1440161225-000 T1470161121-000 T1470161129-000 T1470161125-000 T1470161132-000 T1470161221-000 T1470161229-000 T1470161225-000 T1470161232-000 H16B-TSBS-PG16 H16B-TSBS-PG21 H16B-TSBS-M20 H16B-TSBS-M25 H16B-TSBHS-PG21 H16B-TSBHS-PG29 H16B-TSBHS-M25 H16B-TSBHS-M32 T1250163116-000 T1250163121-000 T1250163120-000 T1250163125-000 T1270163121-000 T1270163129-000 T1270163125-000 T1270163132-000 H16B-TGBS-PG16 H16B-TGBS-PG21 H16B-TGBS-M20 H16B-TGBS-M25 H16B-TGBHS-PG21 H16B-TGBHS-PG29 H16B-TGBHS-M25 H16B-TGBHS-M32 T1260163116-000 T1260163121-000 T1260163120-000 T1260163125-000 T1280163121-000 T1280163129-000 T1280163125-000 T1280163132-000 H16B-AD-BO T1430160000-000 H16B-SDR-BO-PG21 H16B-SDR-BO-M25 H16B-SDR-BO-2PG21 H16B-SDR-BO-2M25 H16B-SDRH-BO-PG21 H16B-SDRH-BO-PG29 H16B-SDRH-BO-M25 H16B-SDRH-BO-M32 H16B-SDRH-BO-2PG21 H16B-SDRH-BO-2PG29 H16B-SDRH-BO-2M25 H16B-SDRH-BO-2M32 T1460160121-000 T1460160125-000 T1460160221-000 T1460160225-000 T1490160121-000 T1490160129-000 T1490160125-000 T1490160132-000 T1490160221-000 T1490160229-000 T1490160225-000 T1490160232-000 Bulkhead mounted Surface mounted: Side entry 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction M20 M25 High construction M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction High construction Construction H Low 60 Hight 76 M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover Low construction C D F G H Low 105 117 45 57 20 65 56 Hight 105 117 45 57 20 65 81 2 Side entry High construction B 1 Side entry A 1 Side entry 2 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 253 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 H16B-TS-RO-PG21 H16B-TS-RO-PG29 H16B-TS-RO-M25 H16B-TS-RO-M32 T1310160121-000 T1310160129-000 T1310160125-000 T1310160132-000 PG21 PG29 H16B-TSH-RO-PG21 H16B-TSH-RO-PG29 H16B-TSH-RO-M25 H16B-TSH-RO-M32 H16B-TSH-RO-M40 T1330160121-000 T1330160129-000 T1330160125-000 T1330160132-000 T1330160140-000 PG21 PG29 H16B-TG-RO-PG21 H16B-TG-RO-PG29 H16B-TG-RO-M25 H16B-TG-RO-M32 T1320160121-000 T1320160129-000 T1320160125-000 T1320160132-000 PG21 PG29 H16B-TGH-RO-PG21 H16B-TGH-RO-PG29 H16B-TGH-RO-M25 H16B-TGH-RO-M32 H16B-TGH-RO-M40 T1340160121-000 T1340160129-000 T1340160125-000 T1340160132-000 T1340160140-000 PG21 PG29 H16B-TBF-LB-PG21 H16B-TBF-LB-PG29 H16B-TBF-LB-M25 H16B-TBF-LB-M32 H16B-TBFH-LB-PG21 H16B-TBFH-LB-PG29 H16B-TBFH-LB-M25 H16B-TBFH-LB-M32 H16B-TBFH-LB-M40 T1730163121-000 T1730163129-000 T1730163125-000 T1730163132-000 T1770163121-000 T1770163129-000 T1770163125-000 T1770163132-000 T1770163140-000 H16B-KDTP-LB T1010161500-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 74.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods 254 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H16B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H16B-AG-LB T1500163000-000 H16B-AD-LB T1510163000-000 H16B-SGR-LB-PG16 H16B-SGR-LB-PG21 H16B-SGR-LB-M20 H16B-SGR-LB-M25 H16B-SGR-LB-2PG16 H16B-SGR-LB-2PG21 H16B-SGR-LB-2M20 H16B-SGR-LB-2M25 H16B-SGRH-LB-PG21 H16B-SGRH-LB-PG29 H16B-SGRH-LB-M25 H16B-SGRH-LB-M32 H16B-SGRH-LB-2PG21 H16B-SGRH-LB-2PG29 H16B-SGRH-LB-2M25 H16B-SGRH-LB-2M32 T1610163116-000 T1610163121-000 T1610163120-000 T1610163125-000 T1610163216-000 T1610163221-000 T1610163220-000 T1610163225-000 T1650163121-000 T1650163129-000 T1650163125-000 T1650163132-000 T1650163221-000 T1650163229-000 T1650163225-000 T1650163232-000 H16B-SDR-LB-PG16 H16B-SDR-LB-PG21 H16B-SDR-LB-M20 H16B-SDR-LB-M25 H16B-SDR-LB-2PG16 H16B-SDR-LB-2PG21 H16B-SDR-LB-2M20 H16B-SDR-LB-2M25 H16B-SDRH-LB-PG21 H16B-SDRH-LB-PG29 H16B-SDRH-LB-M25 H16B-SDRH-LB-M32 H16B-SDRH-LB-2PG21 H16B-SDRH-LB-2PG29 H16B-SDRH-LB-2M25 H16B-SDRH-LB-2M32 T1620163116-000 T1620163121-000 T1620163120-000 T1620163125-000 T1620163216-000 T1620163221-000 T1620163220-000 T1620163225-000 T1660163121-000 T1660163129-000 T1660163125-000 T1660163132-000 T1660163221-000 T1660163229-000 T1660163225-000 T1660163232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 2 Side entry 81 High construction Hight 1 Side entry 56 2 Side entry H Low Low construction Construction 1 Side entry With protection cover 2 Side entry 81 High construction Hight 1 Side entry 56 2 Side entry Low construction H Low 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 255 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.16/40, HIP-K.16/40, EMV-K.16/40 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 21 29 HIP HIP.16/40.STS.1.21.G HIP.16/40.STS.1.29.G HIP.16/40.STS.1.M32.G 1-1102649-5 1-1102651-5 0-1106454-2 29 HIP-K HIP-K.16/40.STS.1.29.G HIP-K.16/40.STS.1.M32.G 2-1102651-5 0-1106444-2 EMV-K EMV-K.16/40.STS.1.29.G EMV-K.16/40.STS.1.M32.G EMV-K.16/40.STS.1.21.G 4-1102723-5 0-1106446-4 4-1102722-5 21 29 HIP HIP.16/40.STO.1.21.G HIP.16/40.STO.1.29.G HIP.16/40.STO.1.M32.G 1-1102653-5 1-1102655-5 0-1106454-1 21 29 HIP-K HIP-K.16/40.STO.2.21.G HIP-K.16/40.STO.1.29.G HIP-K.16/40.STO.1.M32.G 0-1108534-1 2-1102655-5 0-1106444-1 29 EMV-K EMV-K.16/40.STO.1.29.G EMV-K.16/40.STO.1.M32.G 4-1102725-5 0-1106446-3 HIP HIP.16/40.AG 1-1102656-5 Hood: Side entry M32 M32 M32 29 21 Hood: Top entry M32 M32 M32 8 22 Surface mounted housing: Bottom entry 22 ø4.5 8 103 129.5 ø4.5 32 56 32 56 103 129.5 HIP-K HIP-K.16/40.AG EMV-K EMV-K.16/40.AG Panel cut-out M4 32 36 32 36 M4 86 86 103103 M6x20 1-1102656-5 8 M6x20 1-1102656-5 112.5 129.5 43 22 60 8 112.5 129.5 22 43 60 Panel cut-out 112.5 86 112.5 86 M6 M6 36 36 45 45 256 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2-1102656-5 4-1102728-5 HIP HIP.16/40.AG.M6 1-1102618-5 HIP-K HIP-K.16/40.AG.M6 2-1102618-5 EMV-K EMV-K.16/40.AG.M6 4-1102730-5 HIP.16/40, HIP-K.16/40, EMV-K.16/40 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Pressure-tight up to 5 bar IP 68 / IP 69 K Description Metr. PG Type Part Number 21 2x21 HIP HIP.16/40.SG.1.21.G HIP.16/40.SG.2.21.G HIP.16/40.SG.2.M32.G 1-1102616-5 1-1102617-5 0-1106453-1 21 2x21 HIP-K HIP-K.16/40.SG.1.21.G HIP-K.16/40.SG.2.21.G HIP-K.16/40.SG.2.M32.G 5-1102616-5 2-1102617-5 0-1106443-1 21 2x21 EMV-K EMV-K.16/40.SG.1.21.Z EMV-K.16/40.SG.2.21.Z EMV-K.16/40.SG.2.M32.G 4-1102726-5 4-1102727-5 0-1106445-2 HIP HIP/EMV.16/40.SKB 3-1106203-5 HIP-K HIP-K.16/40.SKB 4-1106203-5 Surface mounted housing: Side entry 2xM32 2xM32 2xM32 Protective covers for housings M6x30 19 129.5 53 257 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HK4/8 technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ....................................................................4/8 + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. Rated current Power contact .............................................................................. 80A max Signal contact ............................................................................... 16A max (See current carrying capacity) Working voltage Power contact .....................................................................................400V Signal contact .....................................................................................400V Test voltage urms Power contact ........................................................................................ 6KV Signal contact ........................................................................................ 6KV Pollution degree .......................................................................................... 3 Insulation resistance ........................................................................ ≥1010Ω Material ................................................................................ Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94 ...................................................................V0 Working voltage acc. to UL/CSA..................................... 600V/400V Mechanical working life-mating cycles ...................................... ≥500 Ambient temperature 1 Wire gauge: 16mm2 CONTACTS 2 Wire gauge: 10mm2 Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance Power contact................................................................................... ≤0.1mΩ Signal contact.......................................................................................≤5mΩ Terminal .............................................................................. Crimp terminal - mm2 Power contact..............................................................................1.5-16mm2 Signal contact........................................................................... 0.5-2.5mm2 - AWG Power contact......................................................................................... 16-6 Signal contact....................................................................................... 20-14 - Tightening/test torque - Power contact Working current INSERTS mm2 Nm 1.5 1.2 2.5 2 4 3 6 3 10 3 16 3 - Signal contact ...............................................................................0.5 Nm HOODS, HOUSINGS Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 258 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HK4/8 inserts INSERTS FOR H24B HOOD/HOUSING 690V/400V MAX. 80A/16A 4/8+  Dimensions (mm) Type Part Number Male insert Screw terminal Female insert Size chart HK4/8-012-M HK4/8-012-F T2100122101-000 T2100122201-000 Contact arrangement view from termination side 259 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HWK3/3/6 technical characteristics CURRENT CARRYING CAPACITY Specifications ................................................................DIN EN 60 664-1 ................................................................................................. DIN EN 61 984 Number of contacts ................................................................3/3/6 + PE The current carrying is limited by maximum temperature of materials for inserts and contacts including terminals. Control and test procedures according to DIN IEC 60512-3. INSERTS HOODS, HOUSINGS Rated current Power 1 contact.......................................................................... 100A max Power 2 contact...........................................................................40A max Signal contact................................................................................. 16A max (See current carrying capacity) Working voltage Power 1 contact Conductor - ground ..........................................................................400V Conductor - conductor..................................................................... 690V Power 2 contact Conductor - ground ..........................................................................400V Conductor - conductor..................................................................... 690V Signal contact Conductor - ground ...........................................................................250V Conductor - conductor ....................................................................400V Test voltage urms Power 1 contact...................................................................................... 6KV Power 2 contact..................................................................................... 6KV Signal contact........................................................................................ 3KV Pollution degree........................................................................................... 3 Insulation resistance......................................................................... ≥1010Ω Material ....................................................................... Die cast aluminium Surface .......................................................Powder-coated (RAL 7037) Locking element..............................Stainless steel, steel-zinc plated Temperature range.......................................................... -40°C... +125°C Degree of protection acc. to DIN40 050.....................................IP65 Material................................................................................. Polycarbonate Temperature range.......................................................... -40°C... +125°C Flammability acc. to UL94....................................................................V0 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance Power contact................................................................................... ≤0.1mΩ Signal contact.......................................................................................≤5mΩ Terminal .............................................................................. Screw terminal - mm2 Power 1 contact...........................................................................16-35mm2 Power 2 contact.......................................................................... 2.5-6mm2 Signal contact........................................................................... 0.5-2.5mm2 - AWG Power 1 contact...................................................................................... 16-6 Power 2 contact.................................................................................. 20-14 Signal contact....................................................................................... 20-14 - Tightening/test torque - Power contact mm2 1.5 2.5 4 6 10 16 Nm 1.2 2 3 3 3 3 - Signal contact ...............................................................................0.5 Nm 260 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HWK3/3/6 inserts 690V MAX. 100A 690V MAX. 40A 400V MAX. 16A INSERTS FOR H24B HOOD/HOUSING 3/3/6+   Dimensions (mm) Type Part Number Male insert Screw terminal Female insert Contact arrangement view from termination side HK3/3/6-012-M HK3/3/6-012-F T2093362101-000 T2093362201-000 CONTACTS Material ....................................................................................Copper alloy Surface ...........................................................................Hard silver-plated ............................................................................................ Hard gold-plated Contact resistance Power contact................................................................................... ≤0.1mΩ Signal contact...................................................................................... ≤5mΩ Terminal .............................................................................. Screw terminal 100A contact pin - mm2 Power 1 contact......................................................................... 16-35 mm2 Power 2 contact.........................................................................2.5-6 mm2 Signal contact.......................................................................... 0.5-2.5 mm2 - AWG Power 1 contact........................................................................................6-2 Power 2 contact................................................................................... 14-10 Signal contact....................................................................................... 20-14 - Tightening/test torque mm2 1.5 2.5 4 6 10 16 - Power contact Nm 1.2 2 3 3 3 3 - Signal contact.................................................................................. 0.5Nm 261 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H24B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG16 PG21 H24B-TS-PG16 H24B-TS-PG21 H24B-TS-M25 H24B-TS-M32 T1210240116-000 T1210240121-000 T1210240125-000 T1210240132-000 PG21 PG29 H24B-TSH-PG21 H24B-TSH-PG29 H24B-TSH-M25 H24B-TSH-M32 H24B-TSH-M40 T1230240121-000 T1230240129-000 T1230240125-000 T1230240132-000 T1230240140-000 PG16 PG21 H24B-TG-PG16 H24B-TG-PG21 H24B-TG-M25 H24B-TG-M32 T1220240116-000 T1220240121-000 T1220240125-000 T1220240132-000 PG21 PG29 H24B-TGH-PG21 H24B-TGH-PG29 H24B-TGH-M25 H24B-TGH-M32 H24B-TGH-M40 T1240240121-000 T1240240129-000 T1240240125-000 T1240240132-000 T1240240140-000 PG21 H24B-TBFS-PG21 H24B-TBFS-M25 H24B-TBFS-M32 H24B-TBFHS-PG21 H24B-TBFHS-PG29 H24B-TBFHS-M25 H24B-TBFHS-M32 H24B-TBFHS-M40 T1710241121-000 T1710241125-000 T1710241132-000 T1750241121-000 T1750241129-000 T1750241125-000 T1750241132-000 T1750241140-000 H24B-KDTP T1010241400-000 H24B-KDBP T1010242100-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood H 62.5 Hight 78.5 High construction Low Low construction Construction M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods Housing protection cover 262 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H24B with 2 levers on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H24B-AGS T1410241000-000 H24B-SGRS-PG21 H24B-SGRS-M25 H24B-SGRS-2PG21 H24B-SGRS-2M25 H24B-SGRHS-PG21 H24B-SGRHS-PG29 H24B-SGRHS-M25 H24B-SGRHS-M32 H24B-SGRHS-2PG21 H24B-SGRHS-2PG29 H24B-SGRHS-2M25 H24B-SGRHS-2M32 T1440241121-000 T1440241125-000 T1440241221-000 T1440241225-000 T1470241121-000 T1470241129-000 T1470241125-000 T1470241132-000 T1470241221-000 T1470241229-000 T1470241225-000 T1470241232-000 H24B-TSBS-PG16 H24B-TSBS-PG21 H24B-TSBS-M20 H24B-TSBS-M25 H24B-TSBHS-PG21 H24B-TSBHS-PG29 H24B-TSBHS-M25 H24B-TSBHS-M32 T1250243116-000 T1250243121-000 T1250243120-000 T1250243125-000 T1270243121-000 T1270243129-000 T1270243125-000 T1270243132-000 H24B-TGBS-PG16 H24B-TGBS-PG21 H24B-TGBS-M20 H24B-TGBS-M25 H24B-TGBHS-PG21 H24B-TGBHS-PG29 H24B-TGBHS-M25 H24B-TGBHS-M32 T1260243116-000 T1260243121-000 T1260243120-000 T1260243125-000 T1280243121-000 T1280243129-000 T1280243125-000 T1280243132-000 H24B-AD-BO T1430240000-000 H24B-SDR-BO-PG21 H24B-SDR-BO-M25 H24B-SDR-BO-2PG21 H24B-SDR-BO-2M25 H24B-SDRH-BO-PG21 H24B-SDRH-BO-PG29 H24B-SDRH-BO-M25 H24B-SDRH-BO-M32 H24B-SDRH-BO-2PG21 H24B-SDRH-BO-2PG29 H24B-SDRH-BO-2M25 H24B-SDRH-BO-2M32 T1460240121-000 T1460240125-000 T1460240221-000 T1460240225-000 T1490240121-000 T1490240129-000 T1490240125-000 T1490240132-000 T1490240221-000 T1490240229-000 T1490240225-000 T1490240232-000 Bulkhead mounted Surface mounted: Side entry 81 2 Side entry Hight High construction 56 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 Side entry housing with two levers Low construction H Low 60 Hight 76 High construction Construction M20 M25 M25 M32 PG16 PG21 PG21 PG29 Top entry housing with two levers Low construction H Low 60 Hight 76 High construction Construction M20 M25 M25 M32 PG16 PG21 PG21 PG29 Bulkhead mounted with 4 bolts With protection cover Low construction D F G H Low 132 144 45 57 20 65 56 Hight 132 144 45 57 20 65 81 2 Side entry C High construction B 1 Side entry A 1 Side entry 2 Side entry Construction M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 263 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H24B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number PG21 PG29 H24B-TS-RO-PG21 H24B-TS-RO-PG29 H24B-TS-RO-M25 H24B-TS-RO-M32 T1310240121-000 T1310240129-000 T1310240125-000 T1310240132-000 PG21 PG29 H24B-TSH-RO-PG21 H24B-TSH-RO-PG29 H24B-TSH-RO-M25 H24B-TSH-RO-M32 H24B-TSH-RO-M40 T1330240121-000 T1330240129-000 T1330240125-000 T1330240132-000 T1330240140-000 PG21 PG29 H24B-TG-RO-PG21 H24B-TG-RO-PG29 H24B-TG-RO-M25 H24B-TG-RO-M32 T1320240121-000 T1320240129-000 T1320240125-000 T1320240132-000 PG21 PG29 H24B-TGH-RO-PG21 H24B-TGH-RO-PG29 H24B-TGH-RO-M25 H24B-TGH-RO-M32 H24B-TGH-RO-M40 T1340240121-000 T1340240129-000 T1340240125-000 T1340240132-000 T1340240140-000 PG21 PG29 H24B-TBF-LB-PG21 H24B-TBF-LB-PG29 H24B-TBF-LB-M25 H24B-TBF-LB-M32 H24B-TBFH-LB-PG21 H24B-TBFH-LB-PG29 H24B-TBFH-LB-M25 H24B-TBFH-LB-M32 H24B-TBFH-LB-M40 T1730242121-000 T1730242129-000 T1730242125-000 T1730242132-000 T1770243121-000 T1770243129-000 T1770243125-000 T1770243132-000 T1770243140-000 H24B-KDTP-LB T1010241500-000 Hood: Side entry Low construction M25 M32 High construction M25 M32 M40 Hood: Top entry Low construction M25 M32 High construction M25 M32 M40 Cable-to-cable hood Low construction Construction H 62.5 Hight 78.5 High construction Low M25 M32 M25 M32 M40 PG21 PG29 Protection covers for hoods 264 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H24B with 1 lever on the hoods/housings POWDER-COATED, RAL 7037 Dimensions (mm) Metr. PG Type Part Number H24B-AG-LB T1500243000-000 H24B-AD-LB T1510243000-000 H24B-SGR-LB-PG16 H24B-SGR-LB-PG21 H24B-SGR-LB-M20 H24B-SGR-LB-M25 H24B-SGR-LB-2PG16 H24B-SGR-LB-2PG21 H24B-SGR-LB-2M20 H24B-SGR-LB-2M25 H24B-SGRH-LB-PG21 H24B-SGRH-LB-PG29 H24B-SGRH-LB-M25 H24B-SGRH-LB-M32 H24B-SGRH-LB-2PG21 H24B-SGRH-LB-2PG29 H24B-SGRH-LB-2M25 H24B-SGRH-LB-2M32 T1610243116-000 T1610243121-000 T1610243120-000 T1610243125-000 T1610243216-000 T1610243221-000 T1610243220-000 T1610243225-000 T1650243121-000 T1650243129-000 T1650243125-000 T1650243132-000 T1650243221-000 T1650243229-000 T1650243225-000 T1650243232-000 H24B-SDR-LB-PG16 H24B-SDR-LB-PG21 H24B-SDR-LB-M20 H24B-SDR-LB-M25 H24B-SDR-LB-2PG16 H24B-SDR-LB-2PG21 H24B-SDR-LB-2M20 H24B-SDR-LB-2M25 H24B-SDRH-LB-PG21 H24B-SDRH-LB-PG29 H24B-SDRH-LB-M2S H24B-SDRH-LB-M32 H24B-SDRH-LB-2PG21 H24B-SDRH-LB-2PG29 H24B-SDRH-LB-2M25 H24B-SDRH-LB-2M32 T1620243116-000 T1620243121-000 T1620243120-000 T1620243125-000 T1620243216-000 T1620243221-000 T1620243220-000 T1620243225-000 T1660243121-000 T1660243129-000 T1660243125-000 T1660243132-000 T1660243221-000 T1660243229-000 T1660243225-000 T1660243232-000 Bulkhead mounted With protection cover Surface mounted: Side entry 81 2 Side entry Hight High construction 56 1 Side entry Low 2 Side entry H Low construction Construction 1 Side entry With protection cover 2 Side entry 81 High construction 56 Hight 1 Side entry Low 2 Side entry Low construction H 1 Side entry Construction M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 265 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.24/64, HIP-K.24/64, EMV-K.24/64 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 21 29 HIP HIP.24/64.STS.1.21.G HIP.24/64.STS.1.29 G HIP.24/64.STS.1.M40.G 1-1102658-5 1-1102660-5 0-1106473-2 29 HIP-K HIP-K.24/64.STS.1.29.G HIP-K.24/64.STS.1.M40.G 2-1102660-5 0-1106473-4 EMV-K EMV-K.24/64.STS.1.29.G EMV-K.24/64.STS.1.M25.G EMV-K.24/64.STS.1.M32.G EMV-K.24/64.STS.1.M40.G 4-1102755-5 0-1102983-1 0-1106461-8 0-1106461-3 29 36 HIP HIP-KF.24/64.STS.1.29.G HIP-KF.24/64.STS.1.36.G HIP-KF.24/64.STS.1.M40.G 1-1102622-5 1-1102623-5 0-1106474-1 29 36 HIP-K HIP-KF/K.24/64.STS.1.29.G HIP-KF/K. 24/64.STS.1.36G HIP-KF/K.24/64.STS.1.M40.G 2-1102622-5 2-1102623-5 0-1106474-2 29 36 EMV-K EMV-KF/K.24/64.STS.1.29.G EMV-KF/K.24/64.STS.1.36.G EMV-KF/K.24/64.STS.1.M40.G 4-1102732-5 4-1102733-5 0-1106462-2 21 29 HIP HIP.24/64.STO.1.21.G HIP.24/64.STO.1.29.G HIP.24/64.STO.1.M40.G 1-1102662-5 1-1102664-5 0-1106473-1 Hood: Side entry, Standard construction M40 M40 M25 M32 M40 M40 M40 M40 29 Hood: Top entry, Standard construction M40 2xM32 M40 M/PG 90 57 142 156 M40 2xM40 29 53 29 2xM40 3-1102759-5 2xM40 266 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP-K HIP-K.24/64.STO.1.29.G HIP-K.24/64.STO.2.M32.G HIP-K.24/64.STO.1.M40.G EMV-K EMV-K.24/64.STO.1.29.G EMV-K.24/64.STO.1.M40.G 2-1102664-5 0-1102792-1 0-1106473-3 4-1102759-5 0-1106461-4 HIP.10/24, HIP-K.10/24, EMV-K.10/24 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Pressure-tight up to 5 bar IP 68 / IP 69 K Description Metr. PG Type Part Number HIP HIP.10/24.AG.M6 1-1102612-5 HIP-K HIP-K.10/24.AG.M6 2-1102612-5 EMV-K EMV-K.10/24.AG.M6 4-1102720-5 HIP HIP.10/24.SG.1.21.G HIP.10/24.SG.2.21.G HIP.10/24.SG.2.M32.G 1-1102610-5 1-1102611-5 0-1106435-1 HIP-K HIP-K.10/24.SG.1.21.G HIP-K.10/24.SG.2.21.G 5-1102610-5 2-1102611-5 EMV-K EMV-K.10/24.SG.1.21.G EMV-K.10/24.SG.2.21.G EMV-K.10/24.SG.2.M32.G 5-1102716-5 4-1102717-5 0-1106426-2 HIP HIP/EMV.10/24.SKB 3-1106202-5 Surface mounted housing: Bottom entry M6x20 22 22 M6x20 43 43 60 92 92 109 109 60 Panel cut-out M6 M6 3636 43 43 65 65 92 92 Surface mounted housing: Side entry 2xM32 21 2x21 21 2x21 2xM32 21 2x21 Protective covers for hoods and housing M6x30 19 109 53 HIP-K/EMV-K HIP-K/EMV-K.10/24.SKB 4-1106202-5 267 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HF-HIP-K 8/HF-EMV-K 8, HF-HIP-K 12/HF-EMV-K 12 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black Screw lock on hood Description Metr. PG Type Part Number HF-HIP-K.8.Sto.1.M50G HF.8.EMV-K.8.Sto.1.M50G HF.HIP-K.8.Sto.2.M40G HF.EMV-K.8.Sto.2.M40G 0-1102839-4 0-1102839-3 0-1102839-2 0-1102839-1 81 mm 81 mm HF-HIP-K.8.AG.N HF-EMV-K.8.AG.N HF-HIP-K.8.AG HF-EMV-K.8.AG 0-1102837-2 0-1102837-1 0-1102836-2 0-1102836-1 2xM40 2xM40 2xM50 2xM50 HF-HIP-K.12.Sto.2.M40G HF-EMV-K.12.Sto.2.M40G HF-HIP-K.12.Sto.2.M50G HF-EMV-K.12.Sto.2.M50G 0-1102840-2 0-1102840-1 0-1102840-4 0-1102840-3 HF-HIP-K.12.AG.N HF-EMV-K.12.AG.N HF-HIP-K.12.AG HF-EMVK-K.12.AG 0-1102838-2 0-1102838-1 0-1102192-2 0-1102192-1 Hood 126 120 1xM50 1xM50 2xM40 2xM40 184 57 M50 Housing bottom 0-1102839-3 81 20 Height 20 mm 20 mm 184 130 32 32 57 27 130 27 57 184 104 104 Hood 0-1102837-1 167 135 0-1102836-1 184 92 M50 M20 84 Housing bottom 0-1102840-3 81 20 Height 20 mm 20 mm 184 130 184 67 62 67 62 92 27 92 130 104 104 0-1102838-1 0-1102838-1 268 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 81 mm 81 mm Connectors for Power Supply and Power Circuits The demand for shortest possible periods of machine shutdowns and assembly times requires the use of connectors at the interfaces of the connector wires, as well as energy feeding and power circuites. To satisfy the demand of the various applications the series Power Connector was designed. On the basis of the standard series HSB.6/35 (power supply up to 35 A – 6-poles) the development and the elaboration of this series is being continued rigorously as a result, almost any application up to current of 350 A can be realized by using a series of differnet power contacts. Due to the modular structure the differnet varieties of customer requirements in this sector can be met. We also offer solutions for your application specific requirements. POWER CONTACT SERIE HPC GRADED BY DIMENSIONAL LEVELS UP TO 350 A FOR VARIOUS INDUSTRIAL APPLICATIONS 65 % higher current consumption than other available contact systems of the same size. F. e. Tulip contact 250 A – Coil spring contact 350 A. 269 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Coil Spring Power Contact 2 3 4 5 2 1 1 2 3 4 5 1 Insulating material plastic Crimp ferrule Female contact Coil spring Male contact CRIMP FERRULE MALE/FEMALE CONTACT • • • • • • • • • • Optimum material adaptation according to customer’s application Adaptation to special customer wire size and crimping tools Same crimp ferrule for male, female and grounding contact Robust crimp ferrule for tough industrial applications 270 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Wear-resistant basic material Worn parts can be individually exchanged Surface coating according to customer application 30% reducted mating and pulling forces 50% increase of making cycles Variable wire termination Connector overview Series HF-13 Power circuit 350A (3KV) Signal circuit 16A (400V) Pollution degree 3(C) Type of terminals Crimp Pole Modul 1 Page 16 271 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HF-13 module 350A/3KV Description Dimensions (mm) Type Part Number SW 37,5 Male insert 0-1110950-2 HF.13.Sti.E 0-1110950-4 45 ø 40 SW 37,5 77,5 0-1110950-2 20 30,5 43,5 ø 40 SW 37,5 HF.13.Sti. Female insert 0-1110950-4 HF.13.Bu. 0-1110951-2 HF.13.Bu.E 0-1110951-4 45 ø 40 82,5 SW 37,5 0-1110951-2 20 30,5 ø 40 52 Top Bottom 0-1110955-3 0-1110955-1 0-1110955-4 0-1110955-2 0-1110960-2 0-1110960-1 0-1110951-4 43.5 49.5 55 130 113 104 79 75 62 3 x for power 1 x for earth 1 x for signal (HA.10) Assembly in HF.12 Housings 10 16 24 0-1110955-1 37 44 52 130 113 104 79 75 62 0-1110955-2 M3 20 104 42 2 x for power 1 x signal Assembly in HF.8 Housings 20 27 8 27 3 x for power 1 x for earth 1x for signal (HE.6) Assembly in HF.12 Housings 21 112 0-1110960-2 272 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HF.8 housings EMV-K: corrosion-resistant, black; HIP-K: black IP 68 / IP 69 K Screw lock on hood Description Metr. Height Type Part Number HF-HIP-K.8.Sto.1.M50G HF.8.EMV-K.8.Sto.1.M50G HF.HIP-K.8.Sto.2.M40G HF.EMV-K.8.Sto.2.M40G HF.HlP.K8.Sto.2.M40G.1M16G HF.EMV.K8.Sto.2.M40G.1M16G 0-1102839-4 0-1102839-3 0-1102839-2 0-1102839-1 0-1102839-6 0-1102839-5 HF-HIP-K.8.AG.N HF-EMV-K.8.AG.N HF-HIP-K.8.AG HF-EMV-K.8.AG 0-1102837-2 0-1102837-1 0-1102836-2 0-1102836-1 Hood 1xM50 1xM50 2xM40 2xM40 120 126 184 M50 57 2xM40+1xM16 2xM40+1xM16 0-1102839-3 20 20 81 81 20 Housing bottom 81 184 130 32 27 57 184 104 32 57 27 130 104 0-1102837-1 0-1102836-1 HF.12 housings IP 68 / IP 69 K Screw lock on hood 167 Metr. Height Type Part Number HF-HIP-K.12.Sto.2.M40.1M20G HF-EMV-K.12.Sto.2.M40.1M20G HF-HIP-K.12.Sto.2.M50.1M20G HF-EMV-K.12.Sto.2.M50.1M20G 0-1102840-2 0-1102840-1 0-1102840-4 0-1102840-3 HF-HIP-K.12.AG.N HF-EMV-K.12.AG.N HF-HIP-K.12.AG HF-EMVK-K.12.AG 0-1102838-2 0-1102838-1 0-1102192-2 0-1102192-1 135 Description Hood 184 167 2xM40 2xM40 2xM50 2xM50 135 92 M50 M20 84 184 92 M50 0-1102840-3 Housing bottom 20 M20 84 81 184 130 0-1102840-3 67 104 67 62 92 27 130 62 92 184 104 20 20 81 81 0-1102838-1 0-1102838-1 273 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. EMV-K 10/24 housings EMV-K: Protection against electro magnetic interference, pressure-tight, corrosion-resistant IP 68 / IP 69 K Screw lock on hood Description Metr. PG Type Part Number 21 EMV-K.10/24.Sto.1.21G EMV-K.10/24.Sto.1.M25G 4-1102715-5 0-1106427-4 EMV-K.10/24.AG 4-1102718-5 EMV-K.10/24.SG.1.21G EMV-K.10/24.SG.2.M32G 4-1102716-5 0-1106426-2 Hood: Top entry M25 M4 ø4,5 32 56 8 83 109 83 ø4,5 32 56 36 M4 65 83 36 32 32 Panel 109 cut-out 22 8 22 Surface mounted housing: Bottom entry 65 83 Surface mounted housing: side entry 21 2xM32 274 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Crimping sleeves CRIMPING SLEEVES FOR CONTACT SERIES HF-13 Description Type Part Number CH.50mm2-13/16mm CH.70mm2-13/16mm CH.95rmm2-13/16mm CH.105mm2-13/16mm CH.120mm2-13/16mm CH.150mm2-13/16mm 0-1110953-5 0-1110953-6 0-1110953-7 0-1110953-8 0-1110953-9 1-1110953-1 Description Type Part Number Crimping tool without crimping jaws HSS-CSZ.2.5-70mm2 1-1105653-8 CB-HSS-CSZ.6mm2 CB-HSS-CSZ.10mm2 CB-HSS-CSZ.16mm2 CB-HSS-CSZ.25mm2 CB-HSS-CSZ.35mm2 CB-HSS-CSZ.50mm2 CB-HSS-CSZ.70mm2 2-1105653-8 3-1105653-8 4-1105653-8 5-1105653-8 6-1105653-8 7-1105653-8 8-1105653-8 HF-CHZ 0-1110956-1 SET-50-150mm2 0-1110956-7 0-1110956-6 0-1110956-5 0-1110956-4 0-1110956-3 0-1110956-2 Crimp barrel for pin-/socket side - shrink tube - crimp barrel - adapter Dimensions (mm) MAX. 350A SUITABLE TOOL Crimping jaws for HSL, HSS Hydraulic Crimping tool Dies 150mm2-KZ22 120mm2-KZ20 95mm2-KZ18 70mm2-KZ16 50mm2-KZ14 275 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Notes 276 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS IP68, IP65 Hoods and Housings overview 1. Specifications DIN VDE 0110 Concerning clearance and clearage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 60 664-1 DIN EN 61 984 3. Approvals 277 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HPR (IP68) series hoods/housings H3APR (IP68) SERIES Opposite angle locking Metr. PG Type Part Number PG16 H3APR-MTG-PG16 H3APR-MTG-M20 T1920030116-000 T1920030120-000 H3APR-MAG T1930030000-000 H3APR-MAGS T1946030000-000 (Black) T1946032000-000 (Grey) T1946031000-000 (Silver) Top entry M20 Bulkhead mounted: Bottom entry Bulkhead mounted: Side entry 278 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HB hoods/housings with central locking lever HB (IP67) SERIES Central locking Size H24B Metr. M25 M32 M40 M25 M32 PG PG21 PG29 PG21 Type Top entry H24BK-TGHC-PG21 H24BK-TGHC-PG29 H24BK-TGHC-M25 H24BK-TGHC-M32 H24BK-TGHC-M40 Side entry H24BK-TSHC-PG21 H24BK-TSHC-M25 H24BK-TSHC-M32 Part Number T1822242121-000 T1822242129-000 T1822242125-000 T1822242132-000 T1822242140-000 T1812242121-000 T1812242125-000 T1812242132-000 Surface mounted side entry H24B M25 M25 PG21 PG21 1 side entry H24BK-SGR-PG21 H24BK-SGR-M25 2 side entry H24BK-SGR-2PG21 H24BK-SGR-2M25 T1852242121-000 T1852242125-000 T1852242221-000 T1852242225-000 279 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Special hoods SPECIAL HOODS (IP65) SERIES Double cable entry Size Metr. PG Type Part Number 2xPG16 H10B-TGH-2PG16 H10B-TGH-2M20 T1240102116-000 T1240102120-000 2xPG21 H16B-TGH-2PG21 H16B-TGH-2M25 T1240162121-000 T1240162125-000 2xPG21 H24B-TGH-2PG21 H24B-TGH-2M25 T1240242121-000 T1240242125-000 2xPG16 H10B-TFH-2PG16 H10B-TFH-2M20 T1230102116-000 T1230102120-000 2xPG21 H16B-TFH-2PG21 H16B-TFH-2M25 T1230162121-000 T1230162125-000 2xPG21 H24B-TFH-2PG21 H24B-TFH-2M25 T1230242121-000 T1230242125-000 Hood: Top entry H10B H16B H24B 2xM20 2xM25 2xM25 Hood: Side entry H10B H16B H24B 280 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2xM20 2xM25 2xM25 HA series hoods/housings H3A INCLUDE METAL AND PLASTIC SHELLS H3A6 LEVERS INCLUDE METAL, PLASTIC AND STAINLESS STEEL H3A metal hoods, housings Metr. PG H3A thermoplastic hoods, housings Type Top entry Metr. PG Type PG11 H3A-TG-PG11 H3A-TG-M20 PG11 H3A-TS-PG11 H3A-TS-M20 Top entry PG11 M20 H3A-MTG-PG11 H3A-MTG-M20 Side entry M20 Side entry PG11 M20 H3A-MTS-PG11 H3A-MTS-M20 Bulkhead mounting: Bottom entry M20 Bulkhead mounting: Bottom entry H3A-AG H3A-MAG Bulkhead mounting: Side entry Bulkhead mounting: Side entry H3A-MAGS H3A-AGS Surface mounting: Side entry Surface mounting: Side entry PG11 M16 M20 H3A-MAGSV-PG11 H3A-MAGSV-M16 H3A-MAGSV-M20 Cable-to-cable hood PG11 H3A-AGSV-PG11 H3A-AGSV-M16 H3A-AGSV-M20 PG11 H3A-TGVB-PG11 H3A-TGVB-M20 M16 M20 Cable-to-cable hood PG11 M20 H3A-MTGVB-PG11 H3A-MTGVB-M20 Protection covers for hoods (thermoplastic) Note: For mounted male insert and hood Protection covers for hoods Note: For mounted male insert and hood H3A-KDTP Metal protection covers for hoods Note: For mounted female insert and housings M20 H3A-KDTP Protection covers for hoods H3A-KDB White Grey Note: For mounted female insert and housings H3A-KDBP (White) H3A-KDBPG (Grey) 281 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HA series hoods/housings H10A INCLUDE METAL AND STAINLESS STEEL LEVER H16A INCLUDE METAL AND STAINLESS STEEL LEVER H10A metal hoods, housings Metr. PG Type Hood: Side entry H16A metal hoods, housings Metr. PG Type PG16 PG21 H16A-TS-PG16 H16A-TS-PG21 H16A-TS-M20 H16A-TS-M25 H16A-TSH-PG21 H16A-TSH-M25 Hood: Side entry Low construction High construction Low construction High construction M20 M25 PG16 PG21 H10A-TS-PG16 H10A-TS-PG21 H10A-TS-M20 H10A-TS-M25 M20 M25 M25 PG21 Hood: Top entry Low construction Low construction H10A-TG-PG16 H10A-TG-PG21 H10A-TG-M20 H10A-TG-M25 Protection covers for hood High construction High construction M20 M25 PG16 PG21 M20 M25 M25 PG16 PG21 PG21 H16A-TG-PG16 H16A-TG-PG21 H16A-TG-M20 H16A-TG-M25 H16A-TGH-PG21 H16A-TGH-M25 Protection covers for hood H10A-KDT Bulkhead mounted H16A-KDT Bulkhead mounted H10A-AGS H16A-AGS H10A-ADS H16A-ADS Surface mounted: Side entry PG16 PG21 H10A-SDRMS-PG16 H10A-SDRMS-PG21 H10A-SDRMS-M20 H10A-SDRMS-M25 H10A-SDRMS-2PG16 H10A-SDRMS-2PG21 H10A-SDRMS-2M20 H10A-SDRMS-2M25 Cable-to-cable hood 2 Side entry 2 Side entry M20 M25 PG16 PG21 1 Side entry 1 Side entry M20 M25 PG16 PG21 H10A-SGRS-PG16 H10A-SGRS-PG21 H10A-SGRS-M20 H10A-SGRS-M25 H10A-SGRS-2PG16 H10A-SGRS-2PG21 H10A-SGRS-2M20 H10A-SGRS-2M25 2 Side entry 2 Side entry M20 M25 PG16 PG21 1 Side entry 1 Side entry M20 M25 Surface mounted: Side entry M20 M25 M20 M25 M20 M25 M20 M25 PG16 PG21 PG16 PG21 PG16 PG21 PG16 PG21 H16A-SGRS-PG16 H16A-SGRS-PG21 H16A-SGRS-M20 H16A-SGRS-M25 H16A-SGRS-2PG16 H16A-SGRS-2PG21 H16A-SGRS-2M20 H16A-SGRS-2M25 H16A-SDRS-PG16 H16A-SDRS-PG21 H16A-SDRS-M20 H16A-SDRS-M25 H16A-SDRS-2PG16 H16A-SDRS-2PG21 H16A-SDRS-2M20 H16A-SDRS-2M25 Cable-to-cable hood M25 PG16 PG21 H10A-TBFS-PG16 H10A-TBFS-M20 H10A-TBFS-M25 H10A-TBFHS-PG21 H10A-TBFHS-M25 282 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Low construction High construction Low construction High construction M20 M25 M20 M25 M25 PG16 PG21 H16A-TBFS-PG16 H16A-TBFS-M20 H16A-TBFS-M25 H16A-TBFHS-PG21 H16A-TBFHS-M25 HA series hoods/housings H32A metal hoods, housings Metr. PG H8A thermoplastic hoods, housings Type Hood: Side entry Metr. PG Type PG16 H8A-TS-PG16 H8A-TS-M20 PG16 H8A-TG-PG16 H8A-TG-M20 Hood: Side entry PG21 PG29 PG36 M25 M32 M40 H32A-TS-PG21 H32A-TS-PG29 H32A-TS-PG36 H32A-TS-M25 H32A-TS-M32 H32A-TS-M40 Hood: Top entry M20 Hood: Top entry PG21 PG29 PG36 M25 M32 M40 H32A-TG-PG21 H32A-TG-PG29 H32A-TG-PG36 H32A-TG-M25 H32A-TG-M32 H32A-TG-M40 Bulkhead mounted M20 Bulkhead mounted H32A-AG H8A-AG Surface mounted: Side entry 1 Side entry PG21 PG29 M25 M32 2 Side entry PG21 PG29 M25 M32 H32A-SGR-PG21 H32A-SGR-PG29 H32A-SGR-M25 H32A-SGR-M32 H32A-SGR-2PG21 H32A-SGR-2PG29 H32A-SGR-2M25 H32A-SGR-2M32 283 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H6B series hoods/housings H6B LEVERS INCLUDE METAL, PLASTIC AND STAINLESS STEEL H6B COVERS INCLUDE PLASTIC AND METAL COVERS H6B metal hoods Metr. PG Type Hood: Side entry H6B metal housings Metr. PG Type Bulkhead mounted M20 M25 M20 M25 M32 PG16 PG21 H6B-TS-PG16 H6B-TS-PG21 H6B-TS-M20 H6B-TS-M25 H6B-AGS PG21 PG29 H6B-TSH-PG21 H6B-TSH-PG29 H6B-TSH-M20 H6B-TSH-M25 H6B-TSH-M32 H6B-ADS Hood: Top entry Surface mounted: Side entry Protection covers for hoods H6B-KDTP 284 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry High construction PG21 PG29 H6B-TBFS-PG16 H6B-TBFS-M20 H6B-TBFS-M25 H6B-TBFHS-PG21 H6B-TBFHS-PG29 H6B-TBFHS-M20 H6B-TBFHS-M25 H6B-TBFHS-M32 1 Side entry High construction M20 M25 M32 PG16 2 Side entry Low construction Low construction M20 M25 1 Side entry Cable-to-cable hood 2 Side entry High construction H6B-TGH-PG21 H6B-TGH-PG29 H6B-TGH-M20 H6B-TGH-M25 H6B-TGH-M32 1 Side entry M20 M25 M32 PG21 PG29 2 Side entry Low construction H6B-TG-PG16 H6B-TG-PG21 H6B-TG-M20 H6B-TG-M25 1 Side entry M20 M25 PG16 PG21 M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 H6B-SGRS-PG16 H6B-SGRS-PG21 H6B-SGRS-M20 H6B-SGRS-M25 H6B-SGRS-2PG16 H6B-SGRS-2PG21 H6B-SGRS-2M20 H6B-SGRS-2M25 H6B-SGRHS-PG21 H6B-SGRHS-PG29 H6B-SGRHS-M25 H6B-SGRHS-M32 H6B-SGRHS-2PG21 H6B-SGRHS-2PG29 H6B-SGRHS-2M25 H6B-SGRHS-2M32 H6B-SDRS-PG16 H6B-SDRS-PG21 H6B-SDRS-M20 H6B-SDRS-M25 H6B-SDRS-2PG16 H6B-SDRS-2PG21 H6B-SDRS-2M20 H6B-SDRS-2M25 H6B-SDRHS-PG21 H6B-SDRHS-PG29 H6B-SDRHS-M25 H6B-SDRHS-M32 H6B-SDRHS-2PG21 H6B-SDRHS-2PG29 H6B-SDRHS-2M25 H6B-SDRHS-2M32 H10B with 2 levers on the hoods/housings H10B LEVERS INCLUDE METAL, PLASTIC AND STAINLESS STEEL H10B COVERS INCLUDE PLASTIC AND METAL COVERS H10B metal hoods Metr. PG Type H10B metal housings Hood: Side entry Metr. PG Type Bulkhead mounted M20 M25 Surface mounted: Side entry H10B-TG-PG16 H10B-TG-PG21 H10B-TG-M20 H10B-TG-M25 2 Side entry High construction M20 M25 PG16 PG21 1 Side entry Hood: Top entry 2 Side entry H10B-TSH-PG21 H10B-TSH-PG29 H10B-TSH-M20 H10B-TSH-M25 H10B-TSH-M32 H10B-AGS Low construction PG21 PG29 H10B-TS-PG16 H10B-TS-PG21 H10B-TS-M20 H10B-TS-M25 1 Side entry M20 M25 M32 PG16 PG21 High construction H10B-TGH-PG21 H10B-TGH-PG29 H10B-TGH-M20 H10B-TGH-M25 H10B-TGH-M32 Low construction High construction M25 M32 PG21 PG29 High construction Low construction M20 M25 H10B-TBFS-PG16 H10B-TBFS-M20 H10B-TBFS-M25 H10B-TBFHS-PG21 H10B-TBFHS-PG29 H10B-TBFHS-M25 H10B-TBFHS-M32 M25 M32 M20 M25 M25 M32 M20 M25 M25 M32 PG16 PG21 PG21 PG29 H10B-TSBS-PG16 H10B-TSBS-PG21 H10B-TSBS-M20 H10B-TSBS-M25 H10B-TSBHS-PG21 H10B-TSBHS-PG29 H10B-TSBHS-M25 H10B-TSBHS-M32 PG16 PG21 PG21 PG29 H10B-TGBS-PG16 H10B-TGBS-PG21 H10B-TGBS-M20 H10B-TGBS-M25 H10B-TGBHS-PG21 H10B-TGBHS-PG29 H10B-TGBHS-M25 H10B-TGBHS-M32 H10B-AD-BO 2 Side entry Low construction 1 Side entry M20 M25 M20 M25 2 Side entry High construction 1 Side entry Housing protection cover H10B-KDBP PG21 PG29 Bulkhead mounted with 4 bolts Protection covers for hoods H10B-KDTP M25 M32 PG21 PG29 Top entry housing with two levers Cable-to-cable hood PG16 M20 M25 PG16 PG21 H10B-SGRS-PG16 H10B-SGRS-PG21 H10B-SGRS-M20 H10B-SGRS-M25 H10B-SGRS-2PG16 H10B-SGRS-2PG21 H10B-SGRS-2M20 H10B-SGRS-2M25 H10B-SGRHS-PG21 H10B-SGRHS-PG29 H10B-SGRHS-M25 H10B-SGRHS-M32 H10B-SGRHS-2PG21 H10B-SGRHS-2PG29 H10B-SGRHS-2M25 H10B-SGRHS-2M32 Side entry housing with two levers Low construction M20 M25 M32 PG21 PG29 M20 M25 PG16 PG21 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 H10B-SDR-BO-PG16 H10B-SDR-BO-PG21 H10B-SDR-BO-M20 H10B-SDR-BO-M25 H10B-SDR-BO-2PG16 H10B-SDR-BO-2PG21 H10B-SDR-BO-2M20 H10B-SDR-BO-2M25 H10B-SDRH-BO-PG21 H10B-SDRH-BO-PG29 H10B-SDRH-BO-M25 H10B-SDRH-BO-M32 H10B-SDRH-BO-2PG21 H10B-SDRH-BO-2PG29 H10B-SDRH-BO-2M25 H10B-SDRH-BO-2M32 285 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H10B with 1 lever on the hoods/housings H10B LEVERS INCLUDE METAL, PLASTIC AND STAINLESS STEEL H10B COVERS INCLUDE PLASTIC AND METAL COVERS H10B metal hoods Metr. PG Type Hood: Side entry H10B metal housings Metr. PG Type Bulkhead mounted M20 M25 M20 M25 M32 PG16 PG21 H10B-TS-RO-PG16 H10B-TS-RO-PG21 H10B-TS-RO-M20 H10B-TS-RO-M25 H10B-AG-LB PG21 PG29 H10B-TSH-RO-PG21 H10B-TSH-RO-PG29 H10B-TSH-RO-M20 H10B-TSH-RO-M25 H10B-TSH-RO-M32 H10B-AD-LB Hood: Top entry Surface mounted: Side entry 286 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry H10B-KDTP-LB High construction Protection covers for hoods 1 Side entry High construction M25 M32 PG21 PG29 H10B-TBF-LB-PG16 H10B-TBF-LB-M20 H10B-TBF-LB-M25 H10B-TBFH-LB-PG21 H10B-TBFH-LB-PG29 H10B-TBFH-LB-M25 H10B-TBFH-LB-M32 2 Side entry Low construction Low construction PG16 M20 M25 1 Side entry Cable-to-cable hood 2 Side entry High construction H10B-TGH-RO-PG21 H10B-TGH-RO-PG29 H10B-TGH-RO-M20 H10B-TGH-RO-M25 H10B-TGH-RO-M32 1 Side entry M20 M25 M32 PG21 PG29 2 Side entry Low construction H10B-TG-RO-PG16 H10B-TG-RO-PG21 H10B-TG-RO-M20 H10B-TG-RO-M25 1 Side entry M20 M25 PG16 PG21 M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 H10B-SGR-LB-PG16 H10B-SGR-LB-PG21 H10B-SGR-LB-M20 H10B-SGR-LB-M25 H10B-SGR-LB-2PG16 H10B-SGR-LB-2PG21 H10B-SGR-LB-2M20 H10B-SGR-LB-2M25 H10B-SGRH-LB-PG21 H10B-SGRH-LB-PG29 H10B-SGRH-LB-M25 H10B-SGRH-LB-M32 H10B-SGRH-LB-2PG21 H10B-SGRH-LB-2PG29 H10B-SGRH-LB-2M25 H10B-SGRH-LB-2M32 H10B-SDR-LB-PG16 H10B-SDR-LB-PG21 H10B-SDR-LB-M20 H10B-SDR-LB-M25 H10B-SDR-LB-2PG16 H10B-SDR-LB-2PG21 H10B-SDR-LB-2M20 H10B-SDR-LB-2M25 H10B-SDRH-LB-PG21 H10B-SDRH-LB-PG29 H10B-SDRH-LB-M25 H10B-SDRH-LB-M32 H10B-SDRH-LB-2PG21 H10B-SDRH-LB-2PG29 H10B-SDRH-LB-2M25 H10B-SDRH-LB-2M32 H16B with 2 levers on the hoods/housings H16B LEVERS INCLUDE METAL, PLASTIC AND STAINLESS STEEL H16B COVERS INCLUDE PLASTIC AND METAL COVERS H16B metal hoods Metr. PG H16B metal housings Type Metr. PG Type Bulkhead mounted Hood: Side entry M25 M32 PG16 PG21 H16B-TS-PG16 H16B-TS-PG21 H16B-TS-M25 H16B-TS-M32 H16B-AGS Surface mounted: Side entry 2 Side entry 2 Side entry High construction 1 Side entry Hood: Top entry Low construction H16B-TSH-PG21 H16B-TSH-PG29 H16B-TSH-M25 H16B-TSH-M32 H16B-TSH-M40 1 Side entry M25 M32 M40 PG21 PG29 M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 H16B-SGRS-PG21 H16B-SGRS-M25 H16B-SGRS-2PG21 H16B-SGRS-2M25 H16B-SGRHS-PG21 H16B-SGRHS-PG29 H16B-SGRHS-M25 H16B-SGRHS-M32 H16B-SGRHS-2PG21 H16B-SGRHS-2PG29 H16B-SGRHS-2M25 H16B-SGRHS-2M32 Side entry housing with two levers Low construction H16B-TG-PG16 H16B-TG-PG21 H16B-TG-M25 H16B-TG-M32 High construction M25 M32 PG16 PG21 M20 M25 M25 M32 PG16 PG21 PG21 PG29 H16B-TSBS-PG16 H16B-TSBS-PG21 H16B-TSBS-M20 H16B-TSBS-M25 H16B-TSBHS-PG21 H16B-TSBHS-PG29 H16B-TSBHS-M25 H16B-TSBHS-M32 Top entry housing with two levers Low construction H16B-TGH-PG21 H16B-TGH-PG29 H16B-TGH-M25 H16B-TGH-M32 H16B-TGH-M40 Cable-to-cable hood High construction M25 M32 M40 PG21 PG29 M20 M25 M25 M32 PG16 PG21 PG21 PG29 H16B-TGBS-PG16 H16B-TGBS-PG21 H16B-TGBS-M20 H16B-TGBS-M25 H16B-TGBHS-PG21 H16B-TGBHS-PG29 H16B-TGBHS-M25 H16B-TGBHS-M32 Bulkhead mounted with 4 bolts Low construction M25 M32 High construction M25 M32 M40 PG21 PG21 PG29 H16B-TBFS-PG21 H16B-TBFS-M25 H16B-TBFS-M32 H16B-TBFHS-PG21 H16B-TBFHS-PG29 H16B-TBFHS-M25 H16B-TBFHS-M32 H16B-TBFHS-M40 H16B-AD-BO 2 Side entry High construction H16B-KDBP 1 Side entry Housing protection cover 2 Side entry Low construction H16B-KDTP 1 Side entry Protection covers for hoods M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 H16B-SDR-BO-PG21 H16B-SDR-BO-M25 H16B-SDR-BO-2PG21 H16B-SDR-BO-2M25 H16B-SDRH-BO-PG21 H16B-SDRH-BO-PG29 H16B-SDRH-BO-M25 H16B-SDRH-BO-M32 H16B-SDRH-BO-2PG21 H16B-SDRH-BO-2PG29 H16B-SDRH-BO-2M25 H16B-SDRH-BO-2M32 287 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H16B with 1 lever on the hoods/housings H16B LEVERS INCLUDE METAL, PLASTIC AND STAINLESS STEEL H16B COVERS INCLUDE PLASTIC AND METAL COVERS H16B metal hoods Metr. PG Type Hood: Side entry H16B metal housings Metr. PG Type Bulkhead mounted M25 M32 M25 M32 M40 PG21 PG29 H16B-TS-RO-PG21 H16B-TS-RO-PG29 H16B-TS-RO-M25 H16B-TS-RO-M32 H16B-AG-LB PG21 PG29 H16B-TSH-RO-PG21 H16B-TSH-RO-PG29 H16B-TSH-RO-M25 H16B-TSH-RO-M32 H16B-TSH-RO-M40 H16B-AD-LB Hood: Top entry Surface mounted: Side entry 288 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry H16B-KDTP-LB High construction Protection covers for hoods 1 Side entry High construction M25 M32 M40 PG21 PG29 H16B-TBF-LB-PG21 H16B-TBF-LB-PG29 H16B-TBF-LB-M25 H16B-TBF-LB-M32 H16B-TBFH-LB-PG21 H16B-TBFH-LB-PG29 H16B-TBFH-LB-M25 H16B-TBFH-LB-M32 H16B-TBFH-LB-M40 2 Side entry Low construction Low construction M25 M32 PG21 PG29 1 Side entry Cable-to-cable hood 2 Side entry High construction H16B-TGH-RO-PG21 H16B-TGH-RO-PG29 H16B-TGH-RO-M25 H16B-TGH-RO-M32 H16B-TGH-RO-M40 1 Side entry M25 M32 M40 PG21 PG29 2 Side entry Low construction H16B-TG-RO-PG21 H16B-TG-RO-PG29 H16B-TG-RO-M25 H16B-TG-RO-M32 1 Side entry M25 M32 PG21 PG29 M20 M25 M20 M25 M25 M32 M25 M32 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 H16B-SGR-LB-PG16 H16B-SGR-LB-PG21 H16B-SGR-LB-M20 H16B-SGR-LB-M25 H16B-SGR-LB-2PG16 H16B-SGR-LB-2PG21 H16B-SGR-LB-2M20 H16B-SGR-LB-2M25 H16B-SGRH-LB-PG21 H16B-SGRH-LB-PG29 H16B-SGRH-LB-M25 H16B-SGRH-LB-M32 H16B-SGRH-LB-2PG21 H16B-SGRH-LB-2PG29 H16B-SGRH-LB-2M25 H16B-SGRH-LB-2M32 H16B-SDR-LB-PG16 H16B-SDR-LB-PG21 H16B-SDR-LB-M20 H16B-SDR-LB-M25 H16B-SDR-LB-2PG16 H16B-SDR-LB-2PG21 H16B-SDR-LB-2M20 H16B-SDR-LB-2M25 H16B-SDRH-LB-PG21 H16B-SDRH-LB-PG29 H16B-SDRH-LB-M25 H16B-SDRH-LB-M32 H16B-SDRH-LB-2PG21 H16B-SDRH-LB-2PG29 H16B-SDRH-LB-2M25 H16B-SDRH-LB-2M32 H24B with 2 levers on the hoods/housings H24B LEVERS INCLUDE METAL, PLASTIC AND STAINLESS STEEL H24B COVERS INCLUDE PLASTIC AND METAL COVERS H24B metal hoods Metr. H24B metal housings Hood: Side entry Metr. PG Type Bulkhead mounted M25 M32 PG16 PG21 H24B-TS-PG16 H24B-TS-PG21 H24B-TS-M25 H24B-TS-M32 H24B-AGS Surface mounted: Side entry 2 Side entry 2 Side entry High construction 1 Side entry Hood: Top entry Low construction H24B-TSH-PG21 H24B-TSH-PG29 H24B-TSH-M25 H24B-TSH-M32 H24B-TSH-M40 1 Side entry M25 M32 M40 PG21 PG29 M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 H24B-SGRS-PG21 H24B-SGRS-M25 H24B-SGRS-2PG21 H24B-SGRS-2M25 H24B-SGRHS-PG21 H24B-SGRHS-PG29 H24B-SGRHS-M25 H24B-SGRHS-M32 H24B-SGRHS-2PG21 H24B-SGRHS-2PG29 H24B-SGRHS-2M25 H24B-SGRHS-2M32 Side entry housing with two levers Low construction H24B-TG-PG16 H24B-TG-PG21 H24B-TG-M25 H24B-TG-M32 High construction M25 M32 PG16 PG21 M20 M25 M25 M32 PG16 PG21 PG21 PG29 H24B-TSBS-PG16 H24B-TSBS-PG21 H24B-TSBS-M20 H24B-TSBS-M25 H24B-TSBHS-PG21 H24B-TSBHS-PG29 H24B-TSBHS-M25 H24B-TSBHS-M32 Top entry housing with two levers Low construction H24B-TGH-PG21 H24B-TGH-PG29 H24B-TGH-M25 H24B-TGH-M32 H24B-TGH-M40 Cable-to-cable hood High construction M25 M32 M40 PG21 PG29 M20 M25 M25 M32 PG16 PG21 PG21 PG29 H24B-TGBS-PG16 H24B-TGBS-PG21 H24B-TGBS-M20 H24B-TGBS-M25 H24B-TGBHS-PG21 H24B-TGBHS-PG29 H24B-TGBHS-M25 H24B-TGBHS-M32 Bulkhead mounted with 4 bolts Low construction M25 M32 High construction M25 M32 M40 PG21 PG21 PG29 H24B-TBFS-PG21 H24B-TBFS-M25 H24B-TBFS-M32 H24B-TBFHS-PG21 H24B-TBFHS-PG29 H24B-TBFHS-M25 H24B-TBFHS-M32 H24B-TBFHS-M40 H24B-AD-BO 2 Side entry High construction H24B-KDBP 1 Side entry Housing protection cover 2 Side entry Low construction H24B-KDTP 1 Side entry Protection covers for hoods M25 M25 M25 M32 M25 M32 PG21 PG21 PG21 PG29 PG21 PG29 H24B-SDR-BO-PG21 H24B-SDR-BO-M25 H24B-SDR-BO-2PG21 H24B-SDR-BO-2M25 H24B-SDRH-BO-PG21 H24B-SDRH-BO-PG29 H24B-SDRH-BO-M25 H24B-SDRH-BO-M32 H24B-SDRH-BO-2PG21 H24B-SDRH-BO-2PG29 H24B-SDRH-BO-2M25 H24B-SDRH-BO-2M32 289 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H24B with 1 lever on the hoods/housings H24B metal hoods Metr. PG Type Hood: Side entry H24B metal housings Metr. PG Type Bulkhead mounted M25 M32 M25 M32 M40 PG21 PG29 H24B-TS-RO-PG21 H24B-TS-RO-PG29 H24B-TS-RO-M25 H24B-TS-RO-M32 H24B-AG-LB PG21 PG29 H24B-TSH-RO-PG21 H24B-TSH-RO-PG29 H24B-TSH-RO-M25 H24B-TSH-RO-M32 H24B-TSH-RO-M40 H24B-AD-LB Hood: Top entry Surface mounted: Side entry 2 Side entry 2 Side entry High construction 1 Side entry H24B-TGH-RO-PG21 H24B-TGH-RO-PG29 H24B-TGH-RO-M25 H24B-TGH-RO-M32 H24B-TGH-RO-M40 Low construction M25 M32 M40 PG21 PG29 H24B-TG-RO-PG21 H24B-TG-RO-PG29 H24B-TG-RO-M25 H24B-TG-RO-M32 1 Side entry M25 M32 PG21 PG29 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 H24B-SGR-LB-PG16 H24B-SGR-LB-PG21 H24B-SGR-LB-M20 H24B-SGR-LB-M25 H24B-SGR-LB-2PG16 H24B-SGR-LB-2PG21 H24B-SGR-LB-2M20 H24B-SGR-LB-2M25 H24B-SGRH-LB-PG21 H24B-SGRH-LB-PG29 H24B-SGRH-LB-M25 H24B-SGRH-LB-M32 H24B-SGRH-LB-2PG21 H24B-SGRH-LB-2PG29 H24B-SGRH-LB-2M25 H24B-SGRH-LB-2M32 Cable-to-cable hood AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 2 Side entry 290 High construction H24B-KDTP-LB 1 Side entry Protection covers for hoods 2 Side entry Low construction High construction M25 M32 M40 PG21 PG29 H24B-TBF-LB-PG21 H24B-TBF-LB-PG29 H24B-TBF-LB-M25 H24B-TBF-LB-M32 H24B-TBFH-LB-PG21 H24B-TBFH-LB-PG29 H24B-TBFH-LB-M25 H24B-TBFH-LB-M32 H24B-TBFH-LB-M40 1 Side entry Low construction M25 M32 PG21 PG29 M20 M25 M20 M25 M25 M32 M25 M32 PG16 PG21 PG16 PG21 PG21 PG29 PG21 PG29 H24B-SDR-LB-PG16 H24B-SDR-LB-PG21 H24B-SDR-LB-M20 H24B-SDR-LB-M25 H24B-SDR-LB-2PG16 H24B-SDR-LB-2PG21 H24B-SDR-LB-2M20 H24B-SDR-LB-2M25 H24B-SDRH-LB-PG21 H24B-SDRH-LB-PG29 H24B-SDRH-LB-M25 H24B-SDRH-LB-M32 H24B-SDRH-LB-2PG21 H24B-SDRH-LB-2PG29 H24B-SDRH-LB-2M25 H24B-SDRH-LB-2M32 H32B with 2 levers on the hoods/housings H32B with 2 levers on the hoods, housings Metr. PG H32B with 1 levers on the hoods, housings Type Hood: Side entry Metr. PG Type PG29 PG36 H32B-TS-RO-PG29 H32B-TS-RO-PG36 H32B-TS-RO-M25 H32B-TS-RO-M32 H32B-TS-RO-M40 H32B-TS-RO-M50 PG29 PG36 PG42 H32B-TG-RO-PG29 H32B-TG-RO-PG36 H32B-TG-RO-PG42 H32B-TG-RO-M25 H32B-TG-RO-M32 H32B-TG-RO-M40 H32B-TG-RO-M50 Hood: Side entry M25 M32 M40 M50 PG29 PG36 H32B-TS-PG29 H32B-TS-PG36 H32B-TS-M25 H32B-TS-M32 H32B-TS-M40 H32B-TS-M50 Hood: Top entry M25 M32 M40 M50 Hood: Top entry M25 M32 M40 M50 PG29 PG36 PG42 H32B-TG-PG29 H32B-TG-PG36 H32B-TG-PG42 H32B-TG-M25 H32B-TG-M32 H32B-TG-M40 H32B-TG-M50 Bulkhead mounted M25 M32 M40 M50 Bulkhead mounted H32B-AG H32B-AG-LB Surface mounted: Side entry 1 Side entry M32 M40 M50 M63 2 Side entry M32 M40 M50 M63 PG29 PG36 PG42 PG29 PG36 PG42 H32B-SGR-PG29 H32B-SGR-PG36 H32B-SGR-PG42 H32B-SGR-M32 H32B-SGR-M40 H32B-SGR-M50 H32B-SGR-M63 H32B-SGR-2PG29 H32B-SGR-2PG36 H32B-SGR-2PG42 H32B-SGR-2M32 H32B-SGR-2M40 H32B-SGR-2M50 H32B-SGR-2M63 Cable-to-cable hood H32B-AD-LB Surface mounted: Side entry M32 M40 2 Side entry M32 M40 1 Side entry M32 M40 2 Side entry H32B-TBF-PG29 H32B-TBF-PG36 H32B-TBF-PG42 H32B-TBF-M32 H32B-TBF-M40 H32B-TBF-M50 H32B-TBF-M63 1 Side entry M32 M40 M50 M63 PG29 PG36 PG42 M32 M40 PG29 PG29 H32B-SGR-LB-PG29 H32B-SGR-LB-M32 H32B-SGR-LB-M40 H32B-SGR-LB-2PG29 H32B-SGR-LB-2M32 H32B-SGR-LB-2M40 Protection covers for hoods H32B-KDB PG29 PG29 H32B-SDR-LB-PG29 H32B-SDR-LB-M32 H32B-SDR-LB-M40 H32B-SDR-LB-2PG29 H32B-SDR-LB-2M32 H32B-SDR-LB-2M40 291 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. H48B series hoods/housings H48B metal hoods Metr. PG Type Hood: Side entry EMC metal hoods Metr. PG Type Hood: Side entry M32 M40 M50 M63 PG29 PG36 PG42 H48B-TS-PG29 H48B-TS-PG36 H48B-TS-PG42 H48B-TS-M32 H48B-TS-M40 H48B-TS-M50 H48B-TS-M63 Hood: Top entry H6B-TSH-EMCS H10B-TSH-EMCS H16B-TSH-EMCS H24B-TSH-EMCS Hood: Top entry M32 M40 M50 M63 PG29 PG36 PG42 H48B-TG-PG29 H48B-TG-PG36 H48B-TG-PG42 H48B-TG-M32 H48B-TG-M40 H48B-TG-M50 H48B-TG-M63 Bulkhead mounted H6B-TGH-EMCS H10B-TGH-EMCS H16B-TGH-EMCS H24B-TGH-EMCS Bulkhead mounted H6B-AG-EMCS H10B-AG-EMCS H16B-AG-EMCS H24B-AG-EMCS H48B-AG Hood: Side entry H3A-MTS-EMC-M20 H3A-MTS-EMC-PG11 H6B-TSBHS-EMC H10B-TSBHS-EMC H16B-TSBHS-EMC H24B-TSBHS-EMC H48B-AD-LB Surface mounted: Side entry 1 Side entry M32 M40 M50 2 Side entry M32 M40 M50 Hood: Top entry PG29 PG36 PG42 PG29 PG36 PG42 H48B-SGR-PG29 H48B-SGR-PG36 H48B-SGR-PG42 H48B-SGR-M32 H48B-SGR-M40 H48B-SGR-M50 H48B-SGR-2PG29 H48B-SGR-2PG36 H48B-SGR-2PG42 H48B-SGR-2M32 H48B-SGR-2M40 H48B-SGR-2M50 Surface mounted with cover 1 Side entry M32 M40 M50 2 Side entry M32 M40 M50 H3A-MTG-EMC-PG11 H3A-MTG-EMC-M20 H6B-TGBHS-EMC H10B-TGBHS-EMC H16B-TGBHS-EMC H24B-TGBHS-EMC Bulkhead mounted PG29 PG36 PG42 PG29 PG36 PG42 H48B-SDR-PG29 H48B-SDR-PG36 H48B-SDR-PG42 H48B-SDR-M32 H48B-SDR-M40 H48B-SDR-M50 H48B-SDR-2PG29 H48B-SDR-2PG36 H48B-SDR-2PG42 H48B-SDR-2M32 H48B-SDR-2M40 H48B-SDR-2M50 292 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS H3A-MAG-S-EMC H3A-MAG-EMC H3A-MAGS-EMC H6B-AG-BO-EMC H10B-AG-BO-EMC H16B-AG-BO-EMC H24B-AG-BO-EMC HIP.24/64, HIP-K.24/64, EMV-K.24/64 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number 21 29 HIP HIP.24/64.STS.1.21.G HIP.24/64.STS.1.29 G HIP.24/64.STS.1.M40.G 1-1102658-5 1-1102660-5 0-1106473-2 29 HIP-K HIP-K.24/64.STS.1.29.G HIP-K.24/64.STS.1.M40.G 2-1102660-5 0-1106473-4 EMV-K EMV-K.24/64.STS.1.29.G EMV-K.24/64.STS.1.M25.G EMV-K.24/64.STS.1.M32.G EMV-K.24/64.STS.1.M40.G 4-1102755-5 0-1102983-1 0-1106461-8 0-1106461-3 29 36 HIP HIP-KF.24/64.STS.1.29.G HIP-KF.24/64.STS.1.36.G HIP-KF.24/64.STS.1.M40.G 1-1102622-5 1-1102623-5 0-1106474-1 29 36 HIP-K HIP-KF/K.24/64.STS.1.29.G HIP-KF/K. 24/64.STS.1.36G HIP-KF/K.24/64.STS.1.M40.G 2-1102622-5 2-1102623-5 0-1106474-2 29 36 EMV-K EMV-KF/K.24/64.STS.1.29.G EMV-KF/K.24/64.STS.1.36.G EMV-KF/K.24/64.STS.1.M40.G 4-1102732-5 4-1102733-5 0-1106462-2 21 29 HIP HIP.24/64.STO.1.21.G HIP.24/64.STO.1.29.G HIP.24/64.STO.1.M40.G 1-1102662-5 1-1102664-5 0-1106473-1 Hood: Side entry, Standard construction M40 M40 M25 M32 M40 M40 M40 M40 29 Hood: Top entry, Standard construction M40 2xM32 M40 M/PG 90 57 142 156 M40 2xM40 29 53 29 2xM40 HIP-K HIP-K.24/64.STO.1.29.G HIP-K.24/64.STO.2.M32.G HIP-K.24/64.STO.1.M40.G EMV-K EMV-K.24/64.STO.1.29.G EMV-K.24/64.STO.1.M40.G 2-1102664-5 0-1102792-1 0-1106473-3 4-1102759-5 0-1106461-4 3-1102759-5 2xM40 293 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HIP.24/64, HIP-K.24/64, EMV-K.24/64 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, housings corrosion-resistant, black IP 68 / IP 69 K Pressure-tight up to 5 bar Description Metr. PG Type Part Number HIP HIP.24/64.AG 1-1102665-5 HIP-K HIP-K.24/64.AG 2-1102665-5 EMV-K EMV-K.24/64.AG 4-1102760-5 HIP HIP.24/64.AG.M6 1-1102626-5 HIP-K HIP-K.24/64.AG.M6 HIP-K.24/64.AG.M6.D HIP-K-I.24/64.AG.M6.D 2-1102626-5 2-1102628-5 0-1108533-1 EMV-K EMV-K.24/64.AG.M6 4-1102736-5 HIP HIP.24/64.SG.1.29.G HIP.24/64.SG.2.29.G HIP.24/64.SG.2.M40.G 1-1102624-5 1-1102625-5 0-1106472-1 8 22 Surface mounted housing: Bottom entry, Standard construction 130 156 ø4.5 32 56 32 35 130 112 M4 M6x20 22 1-1102665-5 139 156 8 43 60 139 112 35 43 M6 Surface mounted housing: Side entry, Standard construction 2xM40 2xM40 2xM40 29 2x29 29 2x29 29 2x29 HIP-K HIP-K.24/64.SG.1.29.G HIP-K.24/64.SG.2.29.G HIP-K.24/64.SG.2.M40.G EMV-K EMV-K.24/64.SG.1.29.G EMV-K.24/64.SG.2.29.G EMV-K.24/64.SG.2.M40.G 5-1102624-5 2-1102625-5 0-1106472-2 4-1102734-5 4-1102735-5 0-1106460-2 Protective cover housings M6x30 19 156 53 294 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HIP HIP/EMV.24/64.SKB 3-1106204-5 HIP-K/EMV-K HIP-K/EMV-K.24/64.SKB 4-1106204-5 HF-HIP-K 8/HF-EMV-K 8, HF-HIP-K 12/HF-EMV-K 12 housings HIP: Pressure-tight, silver-grey HIP-K: Housings corrosion-resistant, black, according to DIN IEC 68 T2-52 and ASTM B117-09 > 1000h EMV-K: Protection against electro-magnetic interference, pressure-tight, IP68 - IP69K, housings corrosion-resistant, black Screw lock on hood Description Metr. PG Type Part Number HF-HIP-K.8.Sto.1.M50G HF.8.EMV-K.8.Sto.1.M50G HF.HIP-K.8.Sto.2.M40G HF.EMV-K.8.Sto.2.M40G 0-1102839-4 0-1102839-3 0-1102839-2 0-1102839-1 81 mm 81 mm HF-HIP-K.8.AG.N HF-EMV-K.8.AG.N HF-HIP-K.8.AG HF-EMV-K.8.AG 0-1102837-2 0-1102837-1 0-1102836-2 0-1102836-1 2xM40 2xM40 2xM50 2xM50 HF-HIP-K.12.Sto.2.M40G HF-EMV-K.12.Sto.2.M40G HF-HIP-K.12.Sto.2.M50G HF-EMV-K.12.Sto.2.M50G 0-1102840-2 0-1102840-1 0-1102840-4 0-1102840-3 HF-HIP-K.12.AG.N HF-EMV-K.12.AG.N HF-HIP-K.12.AG HF-EMVK-K.12.AG 0-1102838-2 0-1102838-1 0-1102192-2 0-1102192-1 Hood 126 120 1xM50 1xM50 2xM40 2xM40 184 57 M50 Housing bottom 0-1102839-3 81 20 Height 20 mm 20 mm 184 130 32 32 57 27 130 27 57 184 104 104 Hood 0-1102837-1 167 135 0-1102836-1 184 92 M50 M20 84 Housing bottom 0-1102840-3 81 20 Height 20 mm 20 mm 184 130 184 67 62 67 62 92 27 92 130 104 104 81 mm 81 mm 0-1102838-1 0-1102838-1 295 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Protective covers for hoods/housings Reinforced plastic shell (UV-resistant), Versions with/without attachment string Metal-Version Size 3, 4, 6 + 8 Description Type Part Number SKP.6 SKP.8 0-1110684-3 0-1110661-3 with attachment string SKP.6.F SKP.8.F 0-1106258-3 0-1106258-4 SKP.6/R SKP.8/R 0-1110684-4 0-1110661-4 with attachment string SKP.6/R.F SKP.8/R.F 0-1106259-3 0-1106259-4 HIP HIP/EMV.6/16.SKB 3-1106201-5 HIP-K HIP-K/EMV-K.6/16.SKB 4-1106201-5 HIP HIP/EMV.10/24.SKB 3-1106202-5 HIP-K/EMV-K HIP-K/EMV-K.10/24.SKB 4-1106202-5 HIP HIP/EMV.16/40.SKB 3-1106203-5 HIP-K HIP-K.16/40.SKB 4-1106203-5 HIP HIP/EMV.24/64.SKB 3-1106204-5 HIP-K/EMV-K HIP-K/EMV-K.24/64.SKB 4-1106204-5 Protective cover for hoods and housings with bolts 29.3 41 A Size A=mm 6 Size 6/8 105 8 132 0-1110684-3 Protective cover for hoods with central locking clip 50 29.3 41 A Size Size 6/8 6 A=mm 105 8 132 0-1110684-4 Protective covers for housings series HIP, EMV, EMV-K M6x30 19 96 53 M6x30 19 109 53 M6x30 19 129.5 53 M6x30 19 156 296 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS 53 HPR (IP68) series hoods/housings HBPR (IP68) SERIES Opposite angle locking Size Metr. PG Type Part Number PG16 PG21 PG29 H6BPR-TSH-PG16 H6BPR-TSH-PG21 H6BPR-TSH-PG29 H6BPR-TSH-M20 H6BPR-TSH-M25 H6BPR-TSH-M32 T1910060116-000 T1910060121-000 T1910060129-000 T1910060120-000 T1910060125-000 T1910060132-000 PG16 PG21 PG29 H10BPR-TSH-PG16 H10BPR-TSH-PG21 H10BPR-TSH-PG29 H10BPR-TSH-M20 H10BPR-TSH-M25 H10BPR-TSH-M32 T1910100116-000 T1910100121-000 T1910100129-000 T1910100120-000 T1910100125-000 T1910100132-000 PG16 PG21 PG29 H16BPR-TSH-PG16 H16BPR-TSH-PG21 H16BPR-TSH-PG29 H16BPR-TSH-M25 H16BPR-TSH-M32 H16BPR-TSH-M40 T1910160116-000 T1910160121-000 T1910160129-000 T1910160125-000 T1910160132-000 T1910160140-000 PG16 PG21 PG29 H24BPR-TSH-PG16 H24BPR-TSH-PG21 H24BPR-TSH-PG29 H24BPR-TSH-M25 H24BPR-TSH-M32 H24BPR-TSH-M40 T1910240116-000 T1910240121-000 T1910240129-000 T1910240125-000 T1910240132-000 T1910240140-000 PG16 PG21 PG29 H6BPR-TGH-PG16 H6BPR-TGH-PG21 H6BPR-TGH-PG29 H6BPR-TGH-M20 H6BPR-TGH-M25 H6BPR-TGH-M32 T1920060116-000 T1920060121-000 T1920060129-000 T1920060120-000 T1920060125-000 T1920060132-000 PG16 PG21 PG29 H10BPR-TGH-PG16 H10BPR-TGH-PG21 H10BPR-TGH-PG29 H10BPR-TGH-M20 H10BPR-TGH-M25 H10BPR-TGH-M32 T1920100116-000 T1920100121-000 T1920100129-000 T1920100120-000 T1920100125-000 T1920100132-000 PG16 PG21 PG29 H16BPR-TGH-PG16 H16BPR-TGH-PG21 H16BPR-TGH-PG29 H16BPR-TGH-M25 H16BPR-TGH-M32 H16BPR-TGH-M40 T1920160116-000 T1920160121-000 T1920160129-000 T1920160125-000 T1920160132-000 T1920160140-000 PG16 PG21 PG29 H24BPR-TGH-PG16 H24BPR-TGH-PG21 H24BPR-TGH-PG29 H24BPR-TGH-M25 H24BPR-TGH-M32 H24BPR-TGH-M40 T1920240116-000 T1920240121-000 T1920240129-000 T1920240125-000 T1920240132-000 T1920240140-000 Hood: Side entry H6BPR M20 M25 M32 SIZE A H H6BPR 133 101 H10BPR 146 101 H16BPR 166 111 H24BPR 193 111 H10BPR H16BPR H24BPR M20 M25 M32 M25 M32 M40 M25 M32 M40 Hood: Top entry H6BPR SIZE A H H6BPR 133 101 H10BPR 146 101 H16BPR 166 111 H24BPR 193 111 H10BPR H16BPR H24BPR M20 M25 M32 M20 M25 M32 M25 M32 M40 M25 M32 M40 297 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HPR (IP68) series hoods/housings HBPR (IP68) SERIES Opposite angle locking Size Metr. PG Type Part Number H6BPR-AG H10BPR-AG H16BPR-AG H24BPR-AG T1930060000-000 T1930100000-000 T1930160000-000 T1930240000-000 H10BPR-SGRH-PG21 H10BPR-SGRH-PG29 H10BPR-SGRH-M25 H10BPR-SGRH-M32 T1950100121-000 T1950100129-000 T1950100125-000 T1950100132-000 H6BPR H10BPR H16BPR H24BPR H6BPR-KDB H10BPR-KDB H16BPR-KDB H24BPR-KDB T1990060000-000 T1990100000-000 T1990160000-000 T1990240000-000 H24BPR H24BPR-FRAME T1990240001-000 Bulkhead mounted SIZE H6BPR A 70 B 133 H10BPR 83 146 H16BPR 103 166 H24BPR 130 193 C 48 60 82 108 H6BPR H10BPR H16BPR H24BPR Straight surface mounted H6BPR H10BPR H16BPR H24BPR SIZE H10BPR A B 140 169 M25 M32 PG21 PG29 Cover SIZE A H6BPR 133 H10BPR 146 H16BPR 166 H24BPR 193 SIZE A B 130 156 Frame H24BPR 298 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS HPR (IP68) series hoods/housings HBPR (IP68) SERIES Central locking Size Metr. PG Type Part Number PG21 H6BPR-TSHC-PG21 H6BPR-TSHC-M25 H10BPR-TSHC-PG21 H10BPR-TSHC-PG29 H10BPR-TSHC-M25 H10BPR-TSHC-M32 H16BPR-TSHC-PG21 H16BPR-TSHC-PG29 H16BPR-TSHC-M25 H16BPR-TSHC-M32 H16BPR-TSHC-M40 H24BPR-TSHC-PG21 H24BPR-TSHC-PG29 H24BPR-TSHC-PG36 H24BPR-TSHC-M25 H24BPR-TSHC-M32 H24BPR-TSHC-M40 T1912061121-000 T1912061125-000 T1912101121-000 T1912101129-000 T1912101125-000 T1912101132-000 T1912161121-000 T1912161129-000 T1912161125-000 T1912161132-000 T1912161140-000 T1912241121-000 T1912241129-000 T1912241136-000 T1912241125-000 T1912241132-000 T1912241140-000 H6BPR-TGHC-PG21 H6BPR-TGHC-PG29 H6BPR-TGHC-PG36 H6BPR-TGHC-M25 H6BPR-TGHC-M32 H6BPR-TGHC-M40 H10BPR-TGHC-PG21 H10BPR-TGHC-PG29 H10BPR-TGHC-PG36 H10BPR-TGHC-M25 H10BPR-TGHC-M32 H10BPR-TGHC-M40 H16BPR-TGHC-PG21 H16BPR-TGHC-PG29 H16BPR-TGHC-PG36 H16BPR-TGHC-M25 H16BPR-TGHC-M32 H16BPR-TGHC-M40 H24BPR-TGHC-PG21 H24BPR-TGHC-PG29 H24BPR-TGHC-PG36 H24BPR-TGHC-M2S H24BPR-TGHC-M32 H24BPR-TGHC-M40 T1922061121-000 T1922061129-000 T1922061136-000 T1922061125-000 T1922061132-000 T1922061140-000 T1922101121-000 T1922101129-000 T1922101136-000 T1922101125-000 T1922101132-000 T1922101140-000 T1922161121-000 T1922161129-000 T1922161136-000 T1922161125-000 T1922161132-000 T1922161140-000 T1922241121-000 T1922241129-000 T1922241136-000 T1922241125-000 T1922241132-000 T1922241140-000 H6BPR H10BPR H16BPR H24BPR H6BPR-AGC H10BPR-AGC H16BPR-AGC H24BPR-AGC T1932061000-000 T1932101000-000 T1932161000-000 T1932241000-000 H24BPR H24BPR-KDBP T1990240000-000 Hood: Side entry H6BPR PG21 PG29 M32 SIZE A H H6BPR 96 70 H10BPR 110 70 H16BPR 130 80 H24BPR 156 80 H10BPR H16BPR M25 M32 M40 M25 M32 M40 PG21 PG29 PG21 PG29 PG36 H24BPR Hood: Top entry H6BPR SIZE A H H6BPR 96 70 H10BPR 110 70 H16BPR 130 80 H24BPR 156 80 H10BPR H16BPR H24BPR M25 M32 M40 M25 M32 M40 M25 M32 M40 M25 M32 M40 PG21 PG29 PG36 PG21 PG29 PG36 PG21 PG29 PG36 PG21 PG29 PG36 Bulkhead mounted SIZE H6BPR H10BPR H16BPR H24BPR A 70 83 103 130 B 96 110 130 156 C 48 60 82 108 Cover 299 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Notes 300 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Tools and inserts and rail mounting elements 1. Specifications DIN VDE 0110 Concerning clearance and clearage distances DIN VDE 0627 Connectors and plug devices 2. Standards DIN EN 60 664-1 DIN EN 61 984 3. Approvals 301 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Tools and accessories Crimping tools and remove tools Crimp tool Crimp tool Wire range: 0.54.0mm2 Suitable for CDM/CDF and CEM/CEF contacts Wire range: 4.0-10.0mm2 Used for CMM/ CMF contacts Type CRIMPBOX-0.5/4 Type CRIMPBOX-4.0/10.0 Part Number T3100000001-000 Part Number T3100001001-000 Crimp tool Remove tool Wire range: 0.144.0mm2 Suitable for CDM/ CDF and CEM/ CEF contacts with locator and die Used for CDM/ CDF contact series Type RSZ.HE-HN.D-HVT Type REMOV-HD Part Number 1-1105851-8 Part Number T3100000003-000 Remove tool Remove tool Used for CEM/ CMF contact series Used for 5A contacts (Ø1mm) Type REMOV-HEE REMOV-HEEE Material Metal Plastic Part Number T3100000002-000 T3100000016-000 Part Number T3100000017-000 T3100000018-000 Remove tool Used for CMM/ CMF contact series Type REMOV-MM Part Number T3100000013-000 Axial screw tool and crimping tool M3 screw driver Tool Used for HA/ HE inserts Used for 100A inserts Type SCREWD-M3 Type HEXA-D1 Part Number T3100000009-000 Part Number T3100000010-000 Tool Crimping tool Used for 40A inserts Wire range: 10.0-120.0mm2 Used for 200A contacts Type HEXA-D2 Type CRIMPBOX-10/120 Part Number T3100000012-000 Part Number T3100000015-000 302 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Crimp contacts 10A Contact Tech data Material: copper alloy Contact resistance: ≤3mΩ Terminal: crimp connection CDM/Male 10A Male crimp contacts CDF/Female 10A Female crimp contacts Wire gauge Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDM-0.14 CDM-0.5 CDM-0.75 CDM-1.0 CDM-1.5 CDM-2.5 T2020001002-000 T2020001005-000 T2020001008-000 T2020001010-000 T2020001015-000 T2020001025-000 DDM-0.14 DDM-0.5 DDM-0.75 DDM-1.0 DDM-1.5 DDM-2.5 T2020011002-000 T2020011005-000 T2020011008-000 T2020011010-000 T2020011015-000 T2020011025-000 0.14-0.37 0.5 0.75 1.0 26-22 20 18 18 16 14 8.0 8.0 8.0 8.0 8.0 6.0 CDF-0.14 CDF-0.5 CDF-0.75 CDF-1.0 CDF-1.5 CDF-2.5 T2020002002-000 T2020002005-000 T2020002008-000 T2020002010-000 T2020002015-000 T2020002025-000 DDF-0.14 DDF-0.5 DDF-0.75 DDF-1.0 DDF-1.5 DDF-2.5 T2020012002-000 T2020012005-000 T2020012008-000 T2020012010-000 T2020012015-000 T2020012025-000 Stripping length Crimp contacts, silver-plated Crimp contacts, gold-plated 1.5 2.5 16A Contact Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CEM/Male 16A Male crimp contacts CEF/Female 16A Female crimp contacts Wire gauge mm2 AWG mm Type Part Number Type Part Number 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEM-0.3 CEM-0.5 CEM-0.75 CEM-1.0 CEM-1.5 CEM-2.5 CEM-4.0 T 2 03 000 1002-000 T 2 03 000 1005-000 T 2 03 000 1008-000 T 2 03 000 1010-000 T 2 03 000 1015-000 T 2 03 000 1025-000 T 2 03 000 1040-000 DEM-0.3 DEM-0.5 DEM-0.75 DEM-1.0 DEM-1.5 DEM-2.5 DEM-4.0 T2030011002-000 T2030011005-000 T2030011008-000 T2030011010-000 T2030011015-000 T2030011025-000 T2030011040-000 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 26-22 20 18 18 16 14 12 7.5 7.5 7.5 7.5 7.5 7.5 7.5 CEF-0.3 CEF-0.5 CEF-0.75 CEF-1.0 CEF-1.5 CEF-2.5 CEF-4.0 T 2 03 000 2002-000 T 2 03 000 2005-000 T 2 03 000 2008-000 T 2 03 000 2010-000 T 2 03 000 2015-000 T 2 03 000 2025-000 T 2 03 000 2040-000 DEF-0.3 DEF-0.5 DEF-0.75 DEF-1.0 DEF-1.5 DEF-2.5 DEF-4.0 T2030012002-000 T2030012005-000 T2030012008-000 T2030012010-000 T2030012015-000 T2030012025-000 T2030012040-000 303 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Crimp contacts 40A Contact Tech data Material: copper alloy Contact resistance: ≤0.3mΩ Terminal: crimp connection CMM/Male 40A Male crimp contacts CMF/Female Wire gauge Stripping length Crimp contacts, silver-plated mm2 AWG mm Type Part Number 1.5 2.5 4.0 6.0 16 14 12 10 8.0 8.0 8.0 8.0 CMM-1.5 CMM-2.5 CMM-4.0 CMM-6.0 T2040001015-000 T2040001025-000 T2040001040-000 T2040001060-000 40A Female crimp contacts 1.5 2.5 4.0 6.0 10 16 14 12 10 7 8.0 8.0 8.0 8.0 8.0 CMF-1.5 CMF-2.5 CMF-4.0 CMF-6.0 CMF-10 T2040002015-000 T2040002025-000 T2040002040-000 T2040002060-000 T2040002100-000 Tech data Material: copper alloy Contact resistance: ≤1mΩ Terminal: crimp connection CDM/Male 100A Male crimp contacts Wire gauge Ø Stripping length Crimp contacts, silver-plated mm Type Part Number CDF/Female 100A Female crimp contacts 100A Contact mm2 10 16 25 35 4.3 5.5 7 8.2 19 19 19 16 CNM-10 CNM-16 CNM-25 CNM-35 T2050001010-000 T2050001016-000 T2050001025-000 T2050001035-000 10 16 25 35 4.3 5.5 7 8.2 19 19 19 16 CNF-10 CNF-16 CNF-25 CNF-35 T2050002010-000 T2050002016-000 T2050002025-000 T2050002035-000 304 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Crimp contacts 200A Contact Tech data Material: copper Contact resistance: ≤0.3mΩ Terminal: crimp connection CHM/Male 200A Male crimp contacts CHF/Female 200A Female crimp contacts Wire gauge Ø mm2 Stripping length Crimp contacts, silver-plated mm Type Part Number 25 35 50 70 7.0 8.2 10.0 11.5 22.5 22.5 22.5 22.5 CHM-25 CHM-35 CHM-50 CHM-70 T2060001025-000 T2060001035-000 T2060001050-000 T2060001070-000 25 35 50 70 7.0 8.2 10.0 11.5 22.5 22.5 22.5 22.5 CHF-25 CHF-35 CHF-50 CHF-70 T2060002025-000 T2060002035-000 T2060002050-000 T2060002070-000 PCB Adapter Type PCB-adapter-EE Type CEF-adapter Part Number T2040000000-000 Part Number T2030002000-000 305 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Insert mounting element Set Parts order Type Part Number H6B-RaiI-top HB-Rail-base H10B-Rail-top HB-Rail-base H16B-Rail-top HB-Rail-base H24B-Rail-top HB-Rail-base T1870062101-000 T1870002201-000 T1870102101-000 T1870002201-000 T1870162101-000 T1870002201-000 T1870242101-000 T1870002201-000 Insert mounting with carrier element H6B set Top H10B set H16B set H24B set Base 1 4 2 Top Base Top Base Top Base Top Base 3 5 6 1 Attach insert in top carrier element 4 Adjust base element to the dimensions of the insert 2 Set up strain relief e.g. by cable ties 5 Attach base assembly to base element 3 Attach fixing clamps to base insert 6 Connect top and base inserts 306 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Installation elements Coding of hoods/housings and inserts Type Part Number Ordinary type CODING-PIN-M3-TM CODING-PIN-M3-TF Ordinary type T0931000423-000 T0931006524-000 Stainless steel CODING-PIN-M3-STM CODING-PIN-M3-STF Stainless steel T0932000423-000 T0932006524-000 Ordinary type King-size CODING-PIN-M3-LTM CODING-PIN-M3-LTF Ordinary type King-size T0931000425-000 T0931006527-000 Stainless steel, King-size CODING-PIN-M3-LSTM CODING-PIN-M3-LSTF Stainless steel, King-size T0931100425-000 T0931106527-000 Ordinary type (screw thread extended) CODING-PIN-M3-LTM CODING-PIN-M3-LTF Ordinary type (screw thread extended) T0931100425-000 T0931106527-000 Stainless steel (screw thread extended) CODING-PIN-M3-STM CODING-PIN-M3-STF Ordinary type (screw thread extended) T0931100423-000 T0931106524-000 Standard code pin (Stainless steel) Guiding pins (Stainless steel) Guiding pins (screw thread extended) 307 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. HEE-015 insert INSERTS MOUNTING WITHOUT HOOD/HOUSING 15+  200V MAX. 16A   Dimensions (mm) Type Part Number Male insert Female insert Crimp terminal (Order crimp contacts separately) HEE-015-M HEE-015-F Contact arrangement view from termination side Panel cut out for inserts for use without hoods/housings Order crimp contacts separately Female contact type: CSF-1.5 Female contact p/n: T0080002015-010 308 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS T2800152101-000 T2800152201-000 Other connectors Designation Type Part Number 3 poles male insert 3 poles female insert HCC-003-M HCC-003-F T2100032101-000 T2100032201-000 3-poles connector Rated: 25A, 500V Contact surface: Silver plated Flammability acc. to UL94: V0 Terminal: Screw terminal 309 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Installation elements Grip frame, screw adapter and screw Type Part Number HB-SB-024 T3403121350-000 HB-GDZ-S T3403121000-000 HB-GDZ-X T3403122000-000 FIX-M5 T0932406003-000 EXTEND-PE T0926003000-000 H24B grip frame (further variants are avialable on request) Screw adapter and screw M5 Screw Extend earth terminal 310 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable glands and accessories Cable glands made from plastic and brass EMC cable glands For hazardous areas in accordance with DIN EN 50014 DIN EN 50019 311 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Cross reference from PG thread to metric thread M PG PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 Metr. M20 M25 M32 M40 M50 PG Clamp range (mm) Type Part Number PG7 2~5 3~6.5 DLX-7-MTS DLX-7-MS T3609070111-000 T3609070101-000 PG9 2~6 4~8 DLX-9-MTS DLX-9-MS T3609090111-000 T3609090101-000 PG11 3~7 5~10 DLX-11-MTS DLX-11-MS T3609110111-000 T3609110101-000 PG13.5 5~9 6~12 DLX-13-MTS DLX-13-MS T3609130111-000 T3609130101-000 PG16 7~12 10~14 DLX-16-MTS DLX-16-MS T3609160111-000 T3609160101-000 PG21 9~16 13~18 DLX-21-MTS DLX-21-MS T3609210111-000 T3609210101-000 PG29 13~20 18~25 DLX-29-MTS DLX-29-MS T3609290111-000 T3609290101-000 PG36 20~26 22~32 DLX-36-MTS DLX-36-MS T3609360111-000 T3609360101-000 PG42 25~31 32~38 DLX-42-MTS DLX-42-MS T3609420111-000 T3609420101-000 PG48 29~35 37~44 DLX-48-MTS DLX-48-MS T3609480111-000 T3609480101-000 M12 X 1.5 2~5 3~6.5 DLX-12-MT DLX-12-M T3609120112-000 T3609120102-000 M16 X 1.5 2~6 4~8 5~10 DLX-16-MT DLX-16-M DLX-16-MB T3609160112-000 T3609160102-000 T3609160122-000 M20 X 1.5 5~9 6~12 10~14 DLX-20-MT DLX-20-M DLX-20-MB T3609200112-000 T3609200102-000 T3609200122-000 M25 X 1.5 9~16 13~18 DLX-25-MT DLX-25-M T3609250112-000 T3609250102-000 M32 X 1.5 13~20 18~25 DLX-32-MT DLX-32-M T3609320112-000 T3609320102-000 M40 X 1.5 20~26 22~32 DLX-40-MT DLX-40-M T3609400112-000 T3609400102-000 M50 X 1.5 25~31 32~38 DLX-50-MT DLX-50-M T3609500112-000 T3609500102-000 M63 X 1.5 29~35 37~44 DLX-63-MT DLX-63-M T3609630112-000 T3609630102-000 Cable glands, brass nicked plated Material: Nickel plated brass Press seal material: PA Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP68 312 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG7 2~5 3~6.5 DLX-7-PT DLX-7-P T3209070161-000 T3209070160-000 PG9 2~6 4~8 DLX-9-PT DLX-9-P T3209090161-000 T3209090160-000 PG11 3~7 5~10 DLX-11-PT DLX-11-P T3209110161-000 T3209110160-000 PG13.5 5~9 6~12 DLX-13-PT DLX-13-P T3209130161-000 T3209130160-000 PG16 7~12 10~14 DLX-16-PT DLX-16-P T3209160161-000 T3209160160-000 PG21 9~16 13~18 DLX-21-PT DLX-21-P T3209210161-000 T3209210160-000 PG29 13~20 18~25 DLX-29-PT DLX-29-P T3209290161-000 T3209290160-000 PG36 20~26 22~32 DLX-36-PT DLX-36-P T3209360161-000 T3209360160-000 PG42 25~31 32~38 DLX-42-PT DLX-42-P T3209420161-000 T3209420160-000 PG48 29~35 37~44 DLX-48-PT DLX-48-P T3209480161-000 T3209480160-000 M12 X 1.5 2~5 3~6.5 DLX-12-PMT DLX-12-PM T3209120112-000 T3209120102-000 M16 X 1.5 2~6 4~8 DLX-16-PMT DLX-16-PM T3209160112-000 T3209160102-000 M20 X 1.5 5~9 6~12 DLX-20-PMT DLX-20-PM T3209200112-000 T3209200102-000 M25 X 1.5 9~16 13~18 DLX-25-PMT DLX-25-PM T3209250112-000 T3209250102-000 M32 X 1.5 13~20 18~25 DLX-32-PMT DLX-32-PM T3209320112-000 T3209320102-000 M40 X 1.5 20~26 22~32 DLX-40-PMT DLX-40-PM T3209400112-000 T3209400102-000 M50 X 1.5 25~31 32~38 DLX-50-PMT DLX-50-PM T3209500112-000 T3209500102-000 M63 X 1.5 29~35 37~44 DLX-63-PMT DLX-63-PM T3209630112-000 T3209630102-000 Cable glands, polyamide Material: Polyamide Press seal material: PA Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP68 313 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG13.5 PG16 PG16 PG21 PG21 PG21 PG21 PG29 PG29 PG29 PG36 PG36 PG42 PG42 PG48 PG48 2x3 3x4 2x5 4 x 6.5 3x7 2x6 2x8 6 x 6.5 4x9 3x9 5x9 6x8 4 x 12 5 x 10 6 x 12 3 x 18 2x3 3x4 2x5 4 x 6.5 3x7 2x6 2x8 6 x 6.5 4x9 3x9 5x9 6x8 4 x 12 5 x 10 6 x 12 3 x 18 DLX-13-KMS DLX-16-KMS DLX-16-KMS DLX-21-1KMS DLX-21-2KMS DLX-21-3KMS DLX-21-4KMS DLX-29-1KMS DLX-29-2KMS DLX-29-3KMS DLX-36-1KMS DLX-36-2KMS DLX-42-1KMS DLX-42-2KMS DLX-48-1KMS DLX-48-2KMS DLX-16-KM DLX-20-KM DLX-20-KM DLX-25-1KM DLX-25-2KM DLX-25-3KM DLX-25-4KM DLX-32-1KM DLX-32-2KM DLX-32-3KM DLX-40-1KM DLX-40-2KM DLX-50-1KM DLX-50-2KM DLX-63-1KM DLX-63-2KM T3729130101-000 T3729160101-000 T3729160201-000 T3729210101-000 T3729210201-000 T3729210301-000 T3729210401-000 T3729290101-000 T3729290201-000 T3729290301-000 T3729360101-000 T3729360201-000 T3729420101-000 T3729420201-000 T3729480101-000 T3729480201-000 T3729160102-000 T3729200102-000 T3729200202-000 T3729250102-000 T3729250202-000 T3729250302-000 T3729250402-000 T3729320102-000 T3729320202-000 T3729320302-000 T3729400102-000 T3729400202-000 T3729500102-000 T3729500202-000 T3729630102-000 T3729630202-000 PG13.5 PG16 PG16 PG21 PG21 PG21 PG21 PG29 PG29 PG29 PG36 PG36 PG42 PG42 PG48 PG48 2x3 3x4 2x5 4 x 6.5 3x7 2x6 2x8 6 x 6.5 4x9 3x9 5x9 6x8 4 x 12 5 X 10 6 x 12 3 x 18 2x3 3x4 2x5 4 x 6.5 3x7 2x6 2x8 6 x 6.5 4x9 3x9 5x9 6x8 4 x 12 5 x 10 6 x 12 3 x 18 DLX-13-KPMS DLX-16-KPMS DLX-16-KPMS DLX-21-1KPMS DLX-21-2KPMS DLX-21-3KPMS DLX-21-4KPMS DLX-29-1KPMS DLX-29-2KPMS DLX-29-3KPMS DLX-36-1KPMS DLX-36-2KPMS DLX-42-1KPMS DLX-42-2KPMS DLX-48-1KPMS DLX-48-2KPMS DLX-16-KPM DLX-20-KPM DLX-20-KPM DLX-25-1KPM DLX-25-2KPM DLX-25-3KPM DLX-25-4KPM DLX-32-1KPM DLX-32-2KPM DLX-32-3KPM DLX-40-1KPM DLX-40-2KPM DLX-50-1KPM DLX-50-2KPM DLX-63-1KPM DLX-63-2KPM T3229130101-000 T3229160101-000 T3229160201-000 T3229210101-000 T3229210201-000 T3229210301-000 T3229210401-000 T3229290101-000 T3229290201-000 T3229290301-000 T3229360101-000 T3229360201-000 T3229420101-000 T3229420201-000 T3229480101-000 T3229480201-000 T3229160102-000 T3229200102-000 T3229200202-000 T3229250102-000 T3229250202-000 T3229250302-000 T3229250402-000 T3229320102-000 T3229320202-000 T3229320302-000 T3229400102-000 T3229400202-000 T3229500102-000 T3229500202-000 T3229630102-000 T3229630202-000 Multiple sealing insert metal cable gland Material: Nickel plated brass Seal material: TPE/EPDM Temperature range: -40ºC ~ + 100ºC Protection: IP65 Seal material colors: White (other colors need consulting) M16 X 1.5 M20 X 1.5 M20 X 1.5 M25 X 1.5 M25 X 1.5 M25 X 1.5 M25 X 1.5 M32 X 1.5 M32 X 1.5 M32 X 1.5 M40 X 1.5 M40 X 1.5 M50 X 1.5 M50 X 1.5 M63 X 1.5 M63 X 1.5 Multiple sealing insert nylon cable gland Material: PA Seal material: EPDM Temperature range: -40ºC ~ + 100ºC Protection: IP65 Seal material colors: White (other colors need consulting) M16 X 1.5 M20 X 1.5 M20 X 1.5 M25 X 1.5 M25 X 1.5 M25 X 1.5 M25 X 1.5 M32 X 1.5 M32 X 1.5 M32 X 1.5 M40 X 1.5 M40 X 1.5 M50 X 1.5 M50 X 1.5 M63 X 1.5 M63 X 1.5 314 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG9 2~3.5 3.5~6 6~9 DLX-9-MSET DLX-9-MSEZ DLX-9-MSE T3709090111-000 T3709090121-000 T3709090101-000 PG11 6~8.5 8.5~11 11 ~13.5 DLX-11-MSET DLX-11-MSEZ DLX-11-MSE T3709110111-000 T3709110121-000 T3709110101-000 PG13.5 8.5~11 11~13.5 13.5~15 DLX-13-MSET DLX-13-MSEZ DLX-13-MSE T3709130111-000 T3709130121-000 T3709130101-000 PG16 9~12 12~14 14~16 DLX-16-MSET DLX-16-MSEZ DLX-16-MSE T3709160111-000 T3709160121-000 T3709160101-000 PG21 13.5~16 16~17.5 17.5~19 DLX-21-MSET DLX-21-MSEZ DLX-21-MSE T3709210111-000 T3709210121-000 T3709210101-000 PG29 17.5~21 21~22.5 22.5~25 DLX-29-MSET DLX-29-MSEZ DLX-29-MSE T3709290111-000 T3709290121-000 T3709290101-000 PG36 20~24 24~28 28~32 DLX-36-MSET DLX-36-MSEZ DLX-36-MSE T3709360111-000 T3709360121-000 T3709360101-000 M16 X 1.5 2~3.5 3.5~6 6~9 DLX-16-MET DLX-16-MEZ DLX-16-ME T3709160112-000 T3709160122-000 T3709160102-000 M20 X 1.5 8.5~11 11~13.5 13.5~15 DLX-20-MET DLX-20-MEZ DLX-20-ME T3709200112-000 T3709200122-000 T3709200102-000 M25 X 1.5 13.5~16 16~17.5 17.5~19 18~22 DLX-25-MET DLX-25-MEZ DLX-25-ME DLX-25-MEA T3709250112-000 T3709250122-000 T3709250102-000 T3709250132-000 M32 X 1.5 17.5~21 21~22.5 22.5~25 DLX-32-MET DLX-32-MEZ DLX-32-ME T3709320112-000 T3709320122-000 T3709320102-000 M40 X 1.5 20~24 24~28 28~32 DLX-40-MET DLX-40-MEZ DLX-40-ME T3709400112-000 T3709400122-000 T3709400102-000 4~8 5~10 6~12 10~14 13~18 18~25 22~32 32~38 37~44 2~6 4~8 5~9 6~12 9~16 13~18 13~20 18~25 20~26 22~32 25~31 32~38 29~35 37~44 DLX-9-MSC DLX-11-MSC DLX-13-MSC DLX-16-MSC DLX-21-MSC DLX-29-MSC DLX-36-MSC DLX-42-MSC DLX-48-MSC DLX-16-MTC DLX-16-MC DLX-20-MTC DLX-20-MC DLX-25-MTC DLX-25-MC DLX-32-MTC DLX-32-MC DLX-40-MTC DLX-40-MC DLX-50-MTC DLX-50-MC DLX-63-MTC DLX-63-MC T3707090101-000 T3706110113-000 T3707130101-000 T3707160101-000 T3707210101-000 T3707290101-000 T3707360101-000 T3707420101-000 T3707480101-000 T3707160113-000 T3609160103-000 T3707200113-Z00 T3706200103-000 T3707250113-000 T3609250103-000 T3707320113-000 T3609320103-000 T3707400113-000 T3706400103-000 T3707500113-000 T3707500103-000 T3707630113-000 T3707630103-000 Special sealing insert gland Sealing with different colors Material: Nickel plated brass Seal material: TPE/EPDM Temperature range: -40ºC ~ +100ºC Protection: IP65 Seal material colors: Black (other colors need consulting) EMC cable glands PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 M16 X 1.5 Material: Nickel plated brass Press seal material: PA Seal material: EPDM Temperature range: -40ºC ~ +100ºC Protection: IP68 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 315 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 5~10 7~12 7~12 7~15 10~19 18~27 24~32 30~39 36~45 5~10 6.5~10 8.5~13.5 13~20 19~28 24~34 34~40 39~46 DSM-9 DSM-11 DSM-13 DSM-16 DSM-21 DSM-29 DSM-36 DSM-42 DSM-48 DSM-12-M DSM-16-M DSM-20-M DSM-25-M DSM-32-M DSM-40-M DSM-50-M DSM-63-M T3201090101-000 T3201110101-000 T3201130101-000 T3201160101-000 T3201210101-000 T3201290101-000 T3201360101-000 T3201420101-000 T3201480101-000 T3201120102-000 T3201160102-000 T3201200102-000 T3201250102-000 T3201320102-000 T3201400102-000 T3201500102-000 T3201630102-000 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 8~10 10~12 12~14 14~16 17~19 23~25 33~35 39~41 45~47 5~7 8~10 10~12 15~17 24~26 28~30 39~41 45~47 DSM-9-S DSM-11-S DSM-13-S DSM-16-S DSM-21-S DSM-29-S DSM-36-S DSM-42-S DSM-48-S DSM-12-SM DSM-16-SM DSM-20-SM DSM-25-SM DSM-32-SM DSM-40-SM DSM-50-SM DSM-63-SM T3211090101-000 T3211110101-000 T3211130101-000 T3211160101-000 T3211210101-000 T3211290101-000 T3211360101-000 T3211420101-000 T3211480101-000 T3211120102-000 T3211160102-000 T3211200102-000 T3211250102-000 T3211320102-000 T3211400102-000 T3211500102-000 T3211630102-000 Metal glands with multiple seal Material: Nickel plated brass Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP65 M12 M16 M20 M25 M32 M40 M50 M63 Metal glands with multiple seal Material: Nickel plated brass Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP54 M12 M16 M20 M25 M32 M40 M50 M63 316 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 5~10 7~12 7~12 7~15 10~19 18~27 24~32 30~39 36~45 5~10 6.5~10 8.5~13.5 13~20 19~28 24~34 34~40 39~46 DCSM-9 DCSM-11 DCSM-13 DCSM-16 DCSM-21 DCSM-29 DCSM-36 DCSM-42 DCSM-48 DCSM-12-M DCSM-16-M DCSM-20-M DCSM-25-M DCSM-32-M DCSM-40-M DCSM-50-M DCSM-63-M T3101090101-000 T3101110101-000 T3101130101-000 T3101160101-000 T3101210101-000 T3101290101-000 T3101360101-000 T3101420101-000 T3101480101-000 T3101120102-000 T3101160102-000 T3101200102-000 T3101250102-000 T3101320102-000 T3101400102-000 T3101500102-000 T3101630102-000 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 8~10 10~12 12~14 14~16 17~19 23~25 33~35 39~41 45~47 5~7 8~10 10~12 15~17 24~26 28~30 39~41 45~47 DCSM-9-S DCSM-11-S DCSM-13-S DCSM-16-S DCSM-21-S DCSM-29-S DCSM-36-S DCSM-42-S DCSM-48-S DCSM-12-SM DCSM-16-SM DCSM-20-SM DCSM-25-SM DCSM-32-SM DCSM-40-SM DCSM-50-SM DCSM-63-SM T3111090101-000 T3111110101-000 T3111130101-000 T3111160101-000 T3111210101-000 T3111290101-000 T3111360101-000 T3111420101-000 T3111480101-000 T3111120102-000 T3111160102-000 T3111200102-000 T3111250102-000 T3111320102-000 T3111400102-000 T3111500102-000 T3111630102-000 Metal glands with multiple seal Material: Nickel plated brass Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP65 M12 M16 M20 M25 M32 M40 M50 M63 Metal glands with multiple seal Material: Nickel plated brass Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP54 M12 M16 M20 M25 M32 M40 M50 M63 317 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 5~10 7~12 7~12 7~15 10~19 18~27 24~32 30~39 36~45 5~10 6.5~10 8.5~13.5 13~20 19~28 24~34 34~40 39~46 MSL-9 MSL-11 MSL-13 MSL-16 MSL-21 MSL-29 MSL-36 MSL-42 MSL-48 MSL-12-M MSL-16-M MSL-20-M MSL-25-M MSL-32-M MSL-40-M MSL-50-M MSL-63-M T3100090001-000 T3100110101-000 T3100130001-000 T3100160001-000 T3100210001-000 T3100290001-000 T3100360001-000 T3100420001-000 T3100480001-000 T3100120002-000 T3100160002-000 T3100200002-000 T3100250002-000 T3100320002-000 T3100400002-000 T3100500002-000 T3100630002-000 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 8~10 10~12 12~14 14~16 17~19 23~25 33~35 39~41 45~47 5~7 8~10 10~12 15~17 24~26 28~30 39~41 45~47 SGL-9 SGL-11 SGL-13 SGL-16 SGL-21 SGL-29 SGL-36 SGL-42 SGL-48 SGL-12-M SGL-16-M SGL-20-M SGL-25-M SGL-32-M SGL-40-M SGL-50-M SGL-63-M T0910004109-000 T0910004111-000 T0910004113-000 T0910004116-000 T0910004121-000 T0910004129-000 T0910004136-000 T0910004142-000 T0910004148-000 T3300120002-000 T3300160002-000 T3300200002-000 T3300250002-000 T3300320102-000 T3300400002-000 T3300500002-000 T3300630002-000 Multiple seal Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP65 M12 M16 M20 M25 M32 M40 M50 M63 Normal seal Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP54 M12 M16 M20 M25 M32 M40 M50 M63 318 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 6.5~10 7.5~12 8.5~13.5 10.5~16 13~20 19~28 24~34 34~40 39~46 6.5~10 7.5~12 13~20 19~28 24~34 34~40 39~46 ZSM-9 ZSM-11 ZSM-13 ZSM-16 ZSM-21 ZSM-29 ZSM-36 ZSM-42 ZSM-48 ZSM-16-M ZSM-20-M ZSM-25-M ZSM-32-M ZSM-40-M ZSM-50-M ZSM-63-M T3135090101-000 T3135110101-000 T3135130101-000 T3135160101-000 T3135210101-000 T3135290101-000 T3135360101-000 T3135420101-000 T3135480101-000 T3135160121-000 T3135200121-000 T3135250121-000 T3135320121-000 T3135400121-000 T3135500121-000 T3135630121-000 PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 6~8 8~10 10~12 12~14 14~16 17~19 26~28 33~35 39~41 43~45 6~8 8~12 10~12 12~14 17~19 25~27 39~41 43~45 ZSM-7-S ZSM-9-S ZSM-11-S ZSM-13-S ZSM-16-S ZSM-21-S ZSM-29-S ZSM-36-S ZSM-42-S ZSM-48-S ZSM-12-SM ZSM-16-SM ZSM-20-SM ZSM-25-SM ZSM-32-SM ZSM-40-SM ZSM-50-SM ZSM-63-SM T3115070101-000 T3115090101-000 T3115110101-000 T3115130101-000 T3115160101-000 T3115210101-000 T3115290101-000 T3115360101-000 T3115420101-000 T3115480101-000 T3115120121-000 T3115160121-000 T3115200121-000 T3115250121-000 T3115320121-000 T3115400121-000 T3115500121-000 T3115630121-000 Metal clamp glands with multiple seal Material: Nickel plated brass Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP65 M16 M20 M25 M32 M40 M50 M63 Metal clamp glands with normal seal Material: Nickel plated brass Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP54 M12 M16 M20 M25 M32 M40 M50 M63 319 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 5.5~8 6.5~10 7.5~12 8.5~14 9.5~16 12~21 19~30 25~37 31~43 35~48 5~7.5 7~10 10~14 12~21.5 16~27 23~33 25~38.5 39~46 KSM-7-MS KSM-9-MS KSM-11-MS KSM-13-MS KSM-16-MS KSM-21-MS KSM-29-MS KSM-36-MS KSM-42-MS KSM-48-MS KSM-12-M KSM-16-M KSM-20-M KSM-25-M KSM-32-M KSM-40-M KSM-50-M KSM-63-M T3105070101-000 T3105090101-000 T3105110101-000 T3105130101-000 T3105160101-000 T3105210101-000 T3105290101-000 T3105360101-000 T3105420101-000 T3105480101-000 T3105120121-000 T3105160121-000 T3105200121-000 T3105250121-000 T3105320121-000 T3105400121-000 T3105500121-000 T3105630121-000 PG11 PG13.5 PG13.5 PG13.5 PG16 PG16 PG16 PG21 PG21 PG29 PG29 PG36 PG42 PG48 Ø6 Ø8 Ø10 Ø12 Ø10 Ø12 Ø16 Ø16 Ø20 Ø20 Ø25 Ø32 Ø38 Ø51 Ø6 Ø8 Ø10 Ø12 Ø10 Ø12 Ø16 Ø16 Ø20 Ø20 Ø25 Ø32 Ø38 Ø51 NTC-11-MS NTC-13-MTS NTC-13-MS NTC-13-MES NTC-16-MTS NTC-16-MS NTC-16-MES NTC-21-MTS NTC-21-MS NTC-29-MTS NTC-29-MS NTC-36-MS NTC-42-MS NTC-48-MS NTC-12-M NTC-16-MT NTC-16-M NTC-16-ME NTC-20-MT NTC-20-M NTC-20-MT NTC-25-MT NTC-25-M NTG-32-MT NTC-32-M NTC-40-M NTC-50-M NTC-63-M T3510111201-000 T3510130124-000 T3510130114-000 T3510130134-000 T3510160124-000 T3510160114-000 T3510161501-000 T3510210124-000 T3510212001-000 T3510290124-000 T3510292501-000 T3510363201-000 T3510420114-000 T3510480114-000 T3510120124-000 T3510161002-000 T3510160102-000 T3510160122-000 T3510201602-000 T3510201202-000 T3510201502-000 T3510251502-000 T3510252002-000 T3510320112-000 T3510322002-000 T3510403202-000 T3510500102-000 T3510635102-000 Metal clamp glands Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC M12 M16 M20 M25 M32 M40 M50 M63 Metal flexible tube fittings Material: Zinc alloy Seal material: PA Temperature range: -40ºC ~ +100ºC Protection: IP40-IP65 M12 X 1.5 M16 X 1.5 M16 X 1.5 M16 X 1.5 M20 X 1.5 M20 X 1.5 M20 X 1.5 M25 X 1.5 M25 X 1.5 M32 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 320 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable fittings and accessories Metr. PG Clamp range (mm) Type Part Number PG7 PG9 PG11 PG13.5 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD AD NTC-7-PMS NTC-9-PMS NTC-11-PMS NTC-13-PMES NTC-13-PMZS NTC-16-PMS NTC-21-PMS NTC-29-PMS NTC-36-PMS NTC-42-PMS NTC-48-PMS NTC-10-PM NTC-12-PMT NTC-12-PM NTC-16-PMT NTC-16-PM NTC-20-PMT NTC-20-PM NTC-25-PMT NTC-25-PM NTC-25-PME NTC-32-PMT NTC-32-PM NTC-32-PME NTC-40-PMT NTC-40-PM NTC-50-PMT NTC-50-PM NTC-63-PM T3511070701-000 T3511091001-000 T3511111201-000 T3511131401-000 T3511131401-001 T3511161701-000 T3511212301-000 T3511292901-000 T3511363601-000 T3511424301-000 T3511484801-000 T3511100602-000 T3511120702-000 T3511120702-001 T3511161002-000 T3511161202-000 T3511201402-000 T3511201702-000 T3511251702-000 T3511252002-000 T3511252302-000 T3511322302-000 T3511322602-000 T3511322902-000 T3511402802-000 T3511403602-000 T3511503502-000 T3511504802-000 T3511634802-000 DN-9-P DN-11-P DN-13-P DN-16-P DN-21-P DN-29-P DN-36-P DN-42-P DN-48-P DN-12-PM DN-16-PM DN-20-PM DN-25-PM DN-32-PM DN-40-PM DN-50-PM DN-63-PM T3169090101-000 T3169110101-000 T3169130101-000 T3169160101-000 T3169210101-000 T3169290101-000 T3169360101-000 T3169420101-000 T3169480101-000 T3169120121-000 T3169160111-000 T3169200111-000 T3169250111-000 T3169320111-000 T3169400111-000 T3169500111-000 T3169630111-000 Nylon flexible tube fittings Material: PA Temperature range: -40ºC ~ +100ºC Protection: IP65 M10 X 1.5 M12 X 1.5 M12 X 1.5 M16 X 1.5 M16 X 1.5 M20 X 1.5 M20 X 1.5 M25 X 1.5 M25 X 1.5 M25 X 1.5 M32 X 1.5 M32 X 1.5 M32 X 1.5 M40 X 1.5 M40 X 1.5 M50 X 1.5 M50 X 1.5 M63 X 1.5 10.0 13.0 15.8 18.5 21.2 21.2 28.5 34.5 42.5 54.5 54.5 10.0 10.0 13.0 13.0 15.8 18.5 21.2 21.2 25.8 28.5 28.5 31.5 34.5 34.5 42.5 42.5 54.5 54.5 Nylon blind plugs PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 Material: PA Temperature range: -20ºC ~ +70ºC Protection: IP65 M12 M16 M20 M25 M32 M40 M50 M63 5-7.5 7-10 10-14 12-21.5 16-27 23-33 25-38.5 39-46 321 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Metr. PG Type Part Number PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 BLIND-7-MS BLIND-9-MS BLIND-11-MS BLIND-13-MS BLIND-16-MS BLIND-21-MS BLIND-29-MS BLIND-36-MS BLIND-42-MS BLIND-48-MS BLIND-12-M BLIND-16-M BLIND-20-M BLIND-25-M BLIND-32-M BLIND-40-M BLIND-50-M BLIND-63-M T3165070101-000 T3165090101-000 T3165110101-000 T3165130101-000 T3165160101-000 T3165210101-000 T3165290101-000 T3165360101-000 T3165420101-000 T3165480101-000 T3165120111-000 T3165160111-000 T3165200111-000 T3165250111-000 T3165320111-000 T3165400111-000 T3165500111-000 T3165630111-000 PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 BLIND-7-P BLIND-9-P BLIND-11-P BLIND-13-P BLIND-16-P BLIND-21-P BLIND-29-P BLIND-36-P BLIND-42-P BLIND-48-P BLIND-12-PM BLIND-16-PM BLIND-20-PM BLIND-25-PM BLIND-32-PM BLIND-40-PM BLIND-50-PM BLIND-63-PM T3166070101-000 T3166090101-000 T3166110101-000 T3166130101-000 T3166160101-000 T3166210101-000 T3166290101-000 T3166360101-000 T3166420101-000 T3166480101-000 T3166120111-000 T3166160111-000 T3166200111-000 T3166250111-000 T3166320111-000 T3166400111-000 T3166500111-000 T3166630111-000 Metal blind plugs Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC Protection: IP65 M12 X 1.5 M16 X 1.5 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 Nylon blind plugs Material: PA Temperature range: -40ºC ~ +100ºC Protection: IP65 M12 X 1.5 M16 X 1.5 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 322 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable fittings and accessories Metr. PG Type Part Number PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 BLIND-7-HMS BLIND-9-HMS BLIND-11-HMS BLIND-13-HMS BLIND-16-HMS BLIND-21-HMS BLIND-29-HMS BLIND-36-HMS BLIND-42-HMS BLIND-48-HMS BLIND-12-HM BLIND-16-HM BLIND-20-HM BLIND-25-HM BLIND-32-HM BLIND-40-HM BLIND-50-HM BLIND-63-HM T3165070201-000 T3165090201-000 T3165110201-000 T3165130201-000 T3165160201-000 T3165210201-000 T3165290201-000 T3165360201-000 T3165420201-000 T3165480201-000 T3165120211-000 T3165160211-000 T3165200211-000 T3165250211-000 T3165320211-000 T3165400211-000 T3165500211-000 T3165630211-000 Metal blind plugs Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC Protection: IP65 M12 X 1.5 M16 X 1.5 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 323 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Metr. PG Type Part Number PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 LN-7-MS LN-9-MS LN-11-MS LN-13-MS LN-16-MS LN-21-MS LN-29-MS LN-36-MS LN-42-MS LN-48-MS LN-12-M LN-16-M LN-20-M LN-25-M LN-32-M LN-40-M LN-50-M LN-63-M T3161070001-000 T3161090001-000 T3161110001-000 T3161130001-000 T3161160001-000 T3161210001-000 T3161290001-000 T3161360001-000 T3161420001-000 T3161480001-000 T3161120050-000 T3161160050-000 T3161200050-000 T3161250050-000 T3161320050-000 T3161400050-000 T3161500050-000 T3161630050-000 PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 LN-7-P LN-9-P LN-11-P LN-13-P LN-16-P LN-21-P LN-29-P LN-36-P LN-42-P LN-48-P LN-12-PM LN-16-PM LN-20-PM LN-25-PM LN-32-PM LN-40-PM LN-50-PM LN-63-PM T3262070001-000 T3262090001-000 T3262110001-000 T3262130001-000 T3262160001-000 T3262210001-000 T3262290001-000 T3262360001-000 T3262420001-000 T3262480001-000 T3262120050-000 T3262160050-000 T3262200050-000 T3262250050-000 T3262320050-000 T3262400050-000 T3262500050-000 T3262630050-000 Metal lock units Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC M12 X 1.5 M16 X 1.5 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 Nylon lock units Material: PA Temperature range: -40ºC ~ +100ºC M12 X 1.5 M16 X 1.5 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 324 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable fittings and accessories Metr. PG Type Part Number PG7-PG9 PG9-PG11 PG11-PG13.5 PG11-PG16 PG13.5-PG16 PG13.5-PG21 PG16-PG21 PG21-PG29 PG29-PG36 PG36-PG42 INCR-7/9-PG INCR-9/11-PG INCR-11/13-PG INCR-11/16-PG INCR-13/16-PG INCR-13/21-PG INCR-16/21-PG INCR-21/29-PG INCR-29/36-PG INCR-36/42-PG INCR-16/20-M INCR-20/25-M INCR-25/32-M INCR-32/40-M INCR-40/50-M INCR-50/63-M T3033070901-000 T3033091101-000 T3033111301-000 T3033111601-000 T3033131601-000 T3033132101-000 T3033162101-000 T3033212901-000 T3033293601-000 T3033364201-000 T3033162050-000 T3033202550-000 T3033253250-000 T3033324050-000 T3033405050-000 T3033506350-000 PG9-PG7 PG11-PG7 PG13.5-PG9 PG13.5-PG11 PG16-PG9 PG16-PG11 PG16-PG13.5 PG21-PG11 PG21-PG13.5 PG21-PG16 PG29-PG16 PG29-PG21 PG36-PG21 PG36-PG29 PG42-PG29 PG42-PG36 PG48-PG36 PG48-PG42 REDU-9/7-PG REDU-11/7-PG REDU-13/9-PG REDU-13/11-PG REDU-16/9-PG REDU-16/11-PG REDU-16/13-PG REDU-21/11-PG REDU-21/13-PG REDU-21/16-PG REDU-29/16-PG REDU-29/21-PG REDU-36/21-PG REDU-36/29-PG REDU-42/29-PG REDU-42/36-PG REDU-48/36-PG REDU-48/42-PG REDU-16/12-M REDU-20/12-M REDU-20/16-M REDU-25/20-M REDU-32/20-M REDU-32/25-M REDU-40/25-M REDU-40/32-M REDU-50/32-M REDU-50/40-M REDU-63/40-M REDU-63/50-M T3071090701-000 T3071110701-000 T3071130901-000 T3071131101-000 T3071160901-000 T3071161101-000 T3071161301-000 T3071211101-000 T3071211301-000 T3071211601-000 T3071291601-000 T3071292101-000 T3071362101-000 T3071362901-000 T3071422901-000 T3071423601-000 T3071483601-000 T3071484201-000 T3071161250-000 T3071201250-000 T3071201650-000 T3071252050-000 T3071322050-000 T3071322550-000 T3071402550-000 T3071403250-000 T3071503250-000 T3071504050-000 T3071634050-000 T3071635050-000 Metal increasers Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC M16-M20 M20-M25 M25-M32 M32-M40 M40-M50 M50-M63 Metal reducers Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC M16-M12 M20-M12 M20-M16 M25-M20 M32-M20 M32-M25 M40-M25 M40-M32 M50-M32 M50-M40 M63-M40 M63-M50 325 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Type Dimension Part Number BK BK BK BK BK BK BK BK BK BK BK BK BK BK 12~14 14~18 18~22 22~26 26~32 30~34 34~38 38~42 42~48 48~52 52~56 56~60 60~64 64~70 T1918121400-000 T1918121800-000 T1922182200-000 T1926222600-000 T1932263200-000 T1934303400-000 T1912063800-000 T1942384200-000 T1912064800-000 T1912065200-000 T1912065600-000 T1912066000-000 T1964566400-000 T1970667000-000 3-8 4-13.5 10-20 15-32 3-8 4-13.5 10-20 15-32 2-6 3-8 4-13.5 10-20 15-32 1.5-6.5 5-11 10-17 T3920030801-000 T3920041301-000 T3920102001-000 T3920153201-000 T3930030801-000 T3930041301-000 T3930102001-000 T3930153201-000 T3910020601-000 T3910030801-000 T3910041301-000 T3910102001-000 T3910153201-000 T3930010600-000 T3930051100-000 T3930101700-000 Cable clamper Material: Metal Protection: IP65 C-Type rail T 19 0000 0000-000 rail adaptor system 14 18 22 26 32 34 38 42 48 52 56 60 64 70 Cable clamper SKT3-8SC SKT4-13SC SKT10-20SC SKT15-32SC SKTP3-8SC SKTP4-13SC SKTP10-20SC SKTP15-32SC SKT2-6 SKT3-8 SKT4-13.5 SKT10-20 SKT15-32 QSKT 1-6 QSKT 5-11 QSKT 10-17 Direct installation yokes Direct rail mounting Mounting rails Quick installation yokes Type Dimension Type Part Number AD10 AD13 AD15.8 AD21.2 AD28.5 AD34.5 AD42.5 AD54.5 AD80 AD106 10 13 15 22 28 34 40 54 79 105 Clip-06 Clip-09 Clip-11 Clip-16 Clip-21 Clip-29 Clip-36 Clip-48 Clip-70 Clip-95 T3310010000-000 T3310013000-000 T3310015000-000 T3310022000-000 T3310028000-000 T3310034000-000 T3310040000-000 T3310054000-000 T3310079000-000 T3310105000-000 Clips Material: Stainless steel Temperature range: -40ºC ~ +105ºC 326 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Cable fittings and accessories PG Clamp range Type Part Number PG7 2~5 3~6.5 DLX-7-NMTS DLX-7-NMS T3629070111-000 T3629070101-000 PG9 2~6 4~8 DLX-9-NMTS DLX-9-NMS T3629090111-000 T3629090101-000 PG11 3~7 5~10 DLX-11-NMTS DLX-11-NMS T3629110111-000 T3629110101-000 PG13.5 5~9 6~12 DLX-13-NMTS DLX-13-NMS T3629130111-000 T3629130101-000 PG16 7~12 10~14 DLX-16-NMTS DLX-16-NMS T3629160111-000 T3629160101-000 PG21 9~16 13~18 DLX-21-NMTS DLX-21-NMS T3629210111-000 T3629210101-000 PG29 13~20 18~25 DLX-29-NMTS DLX-29-NMS T3629290111-000 T3629290101-000 PG36 20~26 22~32 DLX-36-NMTS DLX-36-NMS T3629360111-000 T3629360101-000 PG42 25~31 32~38 DLX-42-NMTS DLX-42-NMS T3629420111-000 T3629420101-000 PG48 29~35 37~44 DLX-48-NMTS DLX-48-NMS T3629480111-000 T3629480101-000 M12 X 1.5 2~5 3~6.5 DLX-12-NMT DLX-12-NM T3629120112-000 T3629120102-000 M16 X 1.5 2~6 4~8 DLX-16-NMT DLX-16-NM T3629160112-000 T3629160102-000 M20 X 1.5 5~9 6~12 DLX-20-NMT DLX-20-NM T3629200112-000 T3629200102-000 M25 X 1.5 9~16 13~18 DLX-25-NMT DLX-25-NM T3629250112-000 T3629250102-000 M32 X 1.5 13~20 18~25 DLX-32-NMT DLX-32-NM T3629320112-000 T3629320102-000 M40 X 1.5 20~26 22~32 DLX-40-NMT DLX-40-NM T3629400112-000 T3629400102-000 M50 X 1.5 25~31 32~38 DLX-50-NMT DLX-50-NM T3629500112-000 T3629500102-000 M63 X 1.5 29~35 37~44 DLX-63-NMT DLX-63-NM T3629630112-000 T3629630102-000 Ø11 Ø14 Ø16 Ø18 Ø21 Ø31 Ø12 Ø15.5 Ø20.5 Ø27.5 Ø34.5 STUD-9-MS STUD-11-MS STUD-13-MS STUD-16-MS STUD-21-MS STUD-29-MS STUD-16-M STUD-20-M STUD-25-M STUD-32-M STUD-40-M T3265090901-000 T3265111101-000 T3265131301-000 T3265160101-000 T3265212101-000 T3265292901-000 T3265161611-000 T3265202011-000 T3265252511-000 T3265252511-000 T3265404011-000 Metr. Metal cable gland Material: Nickel plated brass Press seal material: PA Seal material: NBR Temperature range: -40ºC ~ +100ºC Protection: IP68 Angled metal cable glands Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC Protection: IP68 M16 X 1.5 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 PG11 PG13.5 PG16 PG21 PG29 PG36 327 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Cable fittings and accessories Metr. PG Clamp range Type Part Number VSM-7-MS VSM-9-MS VSM-11-MS VSM-13-MS VSM-16-MS VSM-21-MS VSM-29-MS VSM-36-MS VSM-42-MS VSM-48-MS VSM-12-M VSM-16-M VSM-20-M VSM-20T-M VSM-25-M VSM-25T-M VSM-32-M VSM-40-M VSM-50-M VSM-50T-M VSM-63-M T3105070101-000 T3105090101-000 T3105110101-000 T3105130101-000 T3105160101-000 T3105210101-000 T3105290101-000 T3105360101-000 T3105420101-000 T3105480101-000 T3105120021-000 T3105160021-000 T3105200021-000 T3105200121-000 T3105250021-000 T3105250121-000 T3105320021-000 T3105400021-000 T3105500021-000 T3105500121-000 T3105630021-000 STUD-PG11 T3333111112-000 T3333131312-000 T3333161612-000 T3333212112-000 T3333292912-000 T3333363612-000 T3333121211-000 T3333161611-000 T3333202011-000 T3333252511-000 T3333323211-000 T3333404011-000 T3333505011-000 T3333636311-000 Metal cable gland PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 PG42 PG48 Material: Nickel plated brass Seal material: NBR Temperature range: -30ºC ~ +100ºC Protection: IP55 M12 X 1.5 M16 X 1.5 M20 X 1.5 M20 X 1.5 M25 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M50 X 1.5 M63 X 1.5 6~8 5~10 7~12 7~12 7~15 10~19 18~27 24~32 30~39 36~45 4.5~7 6.5~9 6.5~9 6~11.5 8~13 12.5~18 17~26 17~26 27~32 35~38.5 38~44 Extender PG11 PG13.5 PG16 PG21 PG29 PG36 Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC M12 X 1.5 M16 X 1.5 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 328 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS STUD-PG13.5 STUD-PG16 STUD-PG21 STUD-PG29 STUD-PG36 STUD-M12 STUD-M16 STUD-M20 STUD-M25 STUD-M32 STUD-M40 STUD-M50 STUD-M63 Cable fittings and accessories Metr. PG Type Part Number PG11 PG13.5 PG16 PG21 PG29 PG36 STUD-PG11 STUD-PG13.5 STUD-PG16 STUD-PG21 STUD-PG29 STUD-PG36 STUD-M12 STUD-M16 STUD-M20 STUD-M25 STUD-M32 STUD-M40 STUD-M50 STUD-M63 T3333111102-000 T3333131302-000 T3333161602-000 T3333212102-000 T3333292902-000 T3333363602-000 T3333121201-000 T3333161601-000 T3333202001-000 T3333252501-000 T3333323201-000 T3333404001-000 T3333505001-000 T3333636301-000 WSM-16-MS T3125160111-000 WSM-21-MS T3125210111-000 WSM-32-M T3125320001-000 Inside and outside thread adapter Material: Nickel plated brass Temperature range: -40ºC ~ +100ºC M12 X 1.5 M16 X 1.5 M20 X 1.5 M25 X 1.5 M32 X 1.5 M40 X 1.5 M50 X 1.5 M63 X 1.5 Cable gland clamps Material: Nickel plated brass Temperature range: -30ºC ~ +100ºC Protection: IP65 329 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Housings mounting dimensions H10A, H16A, H32A/HA series housings H6B, H10B, H16B, H24B, H32B, H48B/HB series housings H3A housing Shell type H3A H10A H16A H32A H6B H10B H16B H24B H32B H48B Mounted type Dimensions (mm) A B C E F G Ød Bulkhead 40 28 21 21 30 - 3.2 Surface 40 28 - - 30 - 3.2 Bulkhead 81 29.5 57.5 24 17.5 70 3.4 Surface 80 50 - - 40 48 4.5 Bulkhead 96 29.5 73.7 24 17.5 86 3.4 Surface 96 50 - - 40 64 4.5 Bulkhead 102 56 74.2 48.4 42 92 4.4 Surface 106 57 - - 46 94 5.5 Bulkhead 80 43 52.2 35 32 70 4.4 Surface 82 52 - - 40 70 5.5 Bulkhead 93 43 65.2 35 32 83 4.3 Surface 94 52 - - 40 82 5.5 Bulkhead 113 43 85.5 35 32 103 4.3 Surface 117 57 - - 45 105 5.5 Bulkhead 140 43 112.2 35 32 130 4.3 Surface 144 57 - - 45 132 5.5 Bulkhead 124 79 85.5 71 65 110 5.4 Surface 124.5 81 - - 67 112 5.4 Bulkhead 165 90 124 82 70 148 6.4 Surface 132 120 - - 106 111 6.5 330 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page 0-0163083-7.....................................................111 0-0164160-4.....................................................111 0-0164161-4......................................................111 0-0164161-9......................................................111 0-0166824-2.....................................................111 0-1102192-1.....................................................100 0-1102192-1......................................................153 0-1102192-1.....................................................268 0-1102192-1.....................................................273 0-1102192-1.....................................................295 0-1102192-2....................................................100 0-1102192-2.....................................................153 0-1102192-2....................................................268 0-1102192-2....................................................273 0-1102192-2....................................................295 0-1102792-1......................................................99 0-1102792-1.....................................................152 0-1102792-1................................................... 266 0-1102792-1....................................................293 0-1102836-1....................................................100 0-1102836-1.....................................................153 0-1102836-1....................................................268 0-1102836-1....................................................273 0-1102836-1....................................................295 0-1102836-2...................................................100 0-1102836-2....................................................153 0-1102836-2...................................................268 0-1102836-2...................................................273 0-1102836-2...................................................295 0-1102837-1.....................................................100 0-1102837-1......................................................153 0-1102837-1.....................................................268 0-1102837-1.....................................................273 0-1102837-1.....................................................295 0-1102837-2...................................................100 0-1102837-2....................................................153 0-1102837-2...................................................268 0-1102837-2...................................................273 0-1102837-2...................................................295 0-1102838-1....................................................100 0-1102838-1.....................................................153 0-1102838-1....................................................268 0-1102838-1....................................................273 0-1102838-1....................................................295 0-1102838-2...................................................100 0-1102838-2....................................................153 0-1102838-2...................................................268 0-1102838-2...................................................273 0-1102838-2...................................................295 0-1102839-1....................................................100 0-1102839-1.....................................................153 0-1102839-1....................................................268 0-1102839-1....................................................273 0-1102839-1....................................................295 0-1102839-2...................................................100 0-1102839-2....................................................153 Part Number Page 0-1102839-2...................................................268 0-1102839-2...................................................273 0-1102839-2...................................................295 0-1102839-3...................................................100 0-1102839-3....................................................153 0-1102839-3...................................................268 0-1102839-3...................................................273 0-1102839-3...................................................295 0-1102839-4...................................................100 0-1102839-4....................................................153 0-1102839-4...................................................268 0-1102839-4...................................................295 0-1102839-4...................................................273 0-1102839-5...................................................273 0-1102839-6...................................................273 0-1102840-1....................................................100 0-1102840-1.....................................................153 0-1102840-1....................................................268 0-1102840-1....................................................273 0-1102840-1....................................................295 0-1102840-2..................................................100 0-1102840-2...................................................153 0-1102840-2..................................................268 0-1102840-2..................................................273 0-1102840-2..................................................295 0-1102840-3..................................................100 0-1102840-3...................................................153 0-1102840-3..................................................268 0-1102840-3..................................................273 0-1102840-3..................................................295 0-1102840-4..................................................100 0-1102840-4...................................................153 0-1102840-4..................................................268 0-1102840-4..................................................273 0-1102840-4..................................................295 0-1102855-1.......................................................111 0-1102855-6......................................................111 0-1102877-1.......................................................44 0-1102877-2.....................................................44 0-1102879-1...................................................... 45 0-1102879-2..................................................... 45 0-1102942-1.....................................................123 0-1102983-1......................................................99 0-1102983-1.....................................................152 0-1102983-1................................................... 266 0-1102983-1....................................................293 0-1103072-1.................................................... 194 0-1103072-2................................................... 194 0-1103073-3....................................................193 0-1103073-4....................................................193 0-1103074-1.................................................... 196 0-1103074-2................................................... 196 0-1103074-3................................................... 196 0-1103074-4................................................... 196 0-1103074-5................................................... 196 0-1103074-6................................................... 196 Part Number Page 0-1103091-1......................................................189 0-1103092-1.....................................................195 0-1103092-2....................................................195 0-1103092-3....................................................195 0-1103092-4...................................................195 0-1103092-5....................................................195 0-1103092-8....................................................195 0-1103092-9...................................................195 0-1106258-3.................................................. 296 0-1106258-4.................................................. 296 0-1106259-3.................................................. 296 0-1106259-4.................................................. 296 0-1106401-2 .................................................... 36 0-1106401-2 .................................................... 59 0-1106401-2 ...................................................188 0-1106401-3..................................................... 36 0-1106401-3..................................................... 59 0-1106401-3....................................................188 0-1106401-4..................................................... 36 0-1106401-4..................................................... 59 0-1106401-4....................................................188 0-1106402-2 ................................................... 35 0-1106402-2 ................................................... 58 0-1106402-2 ..................................................187 0-1106402-3.................................................... 35 0-1106402-3.................................................... 58 0-1106402-3...................................................187 0-1106407-1 .................................................... 36 0-1106407-1 .................................................... 59 0-1106407-1 ...................................................188 0-1106407-2..................................................... 36 0-1106407-2..................................................... 59 0-1106407-2....................................................188 0-1106408-1..................................................... 35 0-1106408-1..................................................... 58 0-1106408-1....................................................187 0-1106408-2.................................................... 35 0-1106408-2.................................................... 58 0-1106408-2...................................................187 0-1106408-3.................................................... 35 0-1106408-3.................................................... 58 0-1106408-3...................................................187 0-1106413-3.....................................................123 0-1106415-2.....................................................123 0-1106416-3...................................................... 73 0-1106416-3.....................................................122 0-1106416-4..................................................... 73 0-1106416-4....................................................122 0-1106424-1.....................................................123 0-1106424-2....................................................123 0-1106425-1...................................................... 73 0-1106425-1.....................................................122 0-1106425-2..................................................... 73 0-1106425-2....................................................122 0-1106425-3..................................................... 73 0-1106425-3....................................................122 331 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page 0-1106425-4.................................................... 73 0-1106425-4...................................................122 0-1106425-6..................................................... 73 0-1106425-6....................................................122 0-1106426-2...................................................... 81 0-1106426-2....................................................132 0-1106426-2...................................................243 0-1106426-2...................................................267 0-1106426-2................................................... 274 0-1106427-3.....................................................80 0-1106427-3.....................................................131 0-1106427-3...................................................242 0-1106427-4.....................................................80 0-1106427-4.....................................................131 0-1106427-4...................................................242 0-1106427-4................................................... 274 0-1106435-1....................................................... 81 0-1106435-1.....................................................132 0-1106435-1....................................................243 0-1106435-1....................................................267 0-1106436-1......................................................80 0-1106436-1......................................................131 0-1106436-1....................................................242 0-1106436-2.....................................................80 0-1106436-2.....................................................131 0-1106436-2...................................................242 0-1106436-3.....................................................80 0-1106436-3.....................................................131 0-1106436-3...................................................242 0-1106436-4....................................................80 0-1106436-4....................................................131 0-1106436-4..................................................242 0-1106436-5.....................................................80 0-1106436-5.....................................................131 0-1106436-5...................................................242 0-1106436-6....................................................80 0-1106436-6....................................................131 0-1106436-6..................................................242 0-1106443-1......................................................90 0-1106443-1.....................................................142 0-1106443-1.....................................................177 0-1106443-1....................................................257 0-1106444-1..................................................... 89 0-1106444-1.....................................................141 0-1106444-1....................................................176 0-1106444-1...................................................256 0-1106444-2.................................................... 89 0-1106444-2....................................................141 0-1106444-2...................................................176 0-1106444-2..................................................256 0-1106445-2....................................................90 0-1106445-2...................................................142 0-1106445-2...................................................177 0-1106445-2..................................................257 0-1106446-3.................................................... 89 0-1106446-3....................................................141 Part Number Page 0-1106446-3...................................................176 0-1106446-3..................................................256 0-1106446-4.................................................... 89 0-1106446-4....................................................141 0-1106446-4...................................................176 0-1106446-4..................................................256 0-1106453-1......................................................90 0-1106453-1.....................................................142 0-1106453-1.....................................................177 0-1106453-1....................................................257 0-1106454-1...................................................... 89 0-1106454-1......................................................141 0-1106454-1.....................................................176 0-1106454-1....................................................256 0-1106454-2.................................................... 89 0-1106454-2....................................................141 0-1106454-2...................................................176 0-1106454-2..................................................256 0-1106460-2.................................................... 98 0-1106460-2....................................................151 0-1106460-2................................................. 294 0-1106461-3......................................................99 0-1106461-3.....................................................152 0-1106461-3................................................... 266 0-1106461-3....................................................293 0-1106461-4.....................................................99 0-1106461-4....................................................152 0-1106461-4.................................................. 266 0-1106461-4...................................................293 0-1106461-8......................................................99 0-1106461-8.....................................................152 0-1106461-8................................................... 266 0-1106461-8....................................................293 0-1106462-2.....................................................99 0-1106462-2....................................................152 0-1106462-2.................................................. 266 0-1106462-2...................................................293 0-1106472-1...................................................... 98 0-1106472-1......................................................151 0-1106472-1................................................... 294 0-1106472-2..................................................... 98 0-1106472-2.....................................................151 0-1106472-2.................................................. 294 0-1106473-1......................................................99 0-1106473-1.....................................................152 0-1106473-1................................................... 266 0-1106473-1....................................................293 0-1106473-2.....................................................99 0-1106473-2....................................................152 0-1106473-2.................................................. 266 0-1106473-2...................................................293 0-1106473-3.....................................................99 0-1106473-3....................................................152 0-1106473-3.................................................. 266 0-1106473-3...................................................293 0-1106473-4.....................................................99 332 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page 0-1106473-4....................................................152 0-1106473-4.................................................. 266 0-1106473-4...................................................293 0-1106474-1......................................................99 0-1106474-1.....................................................152 0-1106474-1................................................... 266 0-1106474-1....................................................293 0-1106474-2.....................................................99 0-1106474-2....................................................152 0-1106474-2.................................................. 266 0-1106474-2...................................................293 0-1106479-1...................................................... 47 0-1106480-1..................................................... 47 0-1106480-2.................................................... 47 0-1108533-1...................................................... 98 0-1108533-1......................................................151 0-1108533-1................................................... 294 0-1108534-1...................................................... 89 0-1108534-1......................................................141 0-1108534-1.....................................................176 0-1108534-1....................................................256 0-1108719-1....................................................... 73 0-1108719-1......................................................122 0-1108794-2................................................... 196 0-1108795-1.................................................... 194 0-1108795-2................................................... 194 0-1108795-3................................................... 194 0-1108795-4................................................... 194 0-1108808-1.....................................................189 0-1108818-1..................................................... 196 0-1110661-3.................................................... 296 0-1110661-4.................................................... 296 0-1110684-3................................................... 296 0-1110684-4.................................................. 296 0-1110950-2.................................................... 272 0-1110950-4................................................... 272 0-1110951-2..................................................... 272 0-1110951-4..................................................... 272 0-1110953-5.................................................... 275 0-1110953-6.................................................... 275 0-1110953-7.................................................... 275 0-1110953-8.................................................... 275 0-1110953-9.................................................... 275 0-1110955-1 .................................................... 272 0-1110955-2.................................................... 272 0-1110955-3 ................................................... 272 0-1110955-4.................................................... 272 0-1110956-1..................................................... 275 0-1110956-2.................................................... 275 0-1110956-3.................................................... 275 0-1110956-4.................................................... 275 0-1110956-5.................................................... 275 0-1110956-6.................................................... 275 0-1110956-7.................................................... 275 0-1110960-1..................................................... 272 0-1110960-2................................................... 272 Part Number Page 0-1110984-4................................................... 196 1-0163087-1 ......................................................111 1-1102002-7...................................................... 47 1-1102005-7...................................................... 47 1-1102008-7...................................................... 47 1-1102009-2...................................................... 47 1-1102011-2........................................................ 47 1-1102013-2....................................................... 47 1-1102015-2....................................................... 47 1-1102017-2....................................................... 47 1-1102027-7....................................................... 47 1-1102030-7...................................................... 47 1-1102033-7...................................................... 47 1-1102172-7........................................................44 1-1102175-7........................................................44 1-1102176-2........................................................44 1-1102177-2........................................................44 1-1102179-2........................................................ 45 1-1102181-2......................................................... 45 1-1102183-2........................................................ 45 1-1102185-2........................................................ 45 1-1102600-5 .................................................... 35 1-1102600-5 .................................................... 58 1-1102600-5 ...................................................187 1-1102601-5 ...................................................... 36 1-1102601-5 ...................................................... 59 1-1102601-5 .....................................................188 1-1102602-5...................................................... 35 1-1102602-5...................................................... 58 1-1102602-5.....................................................187 1-1102603-5...................................................... 35 1-1102603-5...................................................... 58 1-1102603-5.....................................................187 1-1102604-5.....................................................123 1-1102605-5.....................................................123 1-1102606-5...................................................... 73 1-1102606-5.....................................................122 1-1102610-5........................................................ 81 1-1102610-5......................................................132 1-1102610-5.....................................................243 1-1102610-5.....................................................267 1-1102611-5.......................................................... 81 1-1102611-5........................................................132 1-1102611-5.......................................................243 1-1102611-5.......................................................267 1-1102612-5......................................................... 81 1-1102612-5.......................................................132 1-1102612-5......................................................243 1-1102612-5......................................................267 1-1102616-5.......................................................90 1-1102616-5......................................................142 1-1102616-5......................................................177 1-1102616-5.....................................................257 1-1102617-5........................................................90 1-1102617-5.......................................................142 1-1102617-5.......................................................177 Part Number Page 1-1102617-5......................................................257 1-1102618-5....................................................... 89 1-1102618-5.......................................................141 1-1102618-5......................................................176 1-1102618-5.....................................................256 1-1102622-5.......................................................99 1-1102622-5......................................................152 1-1102622-5.................................................... 266 1-1102622-5.....................................................293 1-1102623-5......................................................99 1-1102623-5.....................................................152 1-1102623-5................................................... 266 1-1102623-5....................................................293 1-1102624-5...................................................... 98 1-1102624-5......................................................151 1-1102624-5................................................... 294 1-1102625-5....................................................... 98 1-1102625-5.......................................................151 1-1102625-5.................................................... 294 1-1102626-5...................................................... 98 1-1102626-5......................................................151 1-1102626-5................................................... 294 1-1102631-5........................................................ 73 1-1102631-5.......................................................122 1-1102635-5....................................................... 73 1-1102635-5......................................................122 1-1102638-5...................................................... 73 1-1102638-5.....................................................122 1-1102640-5......................................................80 1-1102640-5......................................................131 1-1102640-5....................................................242 1-1102642-5......................................................80 1-1102642-5......................................................131 1-1102642-5....................................................242 1-1102644-5......................................................80 1-1102644-5......................................................131 1-1102644-5....................................................242 1-1102646-5......................................................80 1-1102646-5......................................................131 1-1102646-5....................................................242 1-1102647-5.......................................................80 1-1102647-5.......................................................131 1-1102647-5.....................................................242 1-1102649-5...................................................... 89 1-1102649-5......................................................141 1-1102649-5.....................................................176 1-1102649-5....................................................256 1-1102651-5....................................................... 89 1-1102651-5.......................................................141 1-1102651-5......................................................176 1-1102651-5.....................................................256 1-1102653-5...................................................... 89 1-1102653-5......................................................141 1-1102653-5.....................................................176 1-1102653-5....................................................256 1-1102655-5...................................................... 89 Part Number Page 1-1102655-5......................................................141 1-1102655-5.....................................................176 1-1102655-5....................................................256 1-1102656-5...................................................... 89 1-1102656-5......................................................141 1-1102656-5.....................................................176 1-1102656-5....................................................256 1-1102658-5......................................................99 1-1102658-5.....................................................152 1-1102658-5................................................... 266 1-1102658-5....................................................293 1-1102660-5......................................................99 1-1102660-5.....................................................152 1-1102660-5................................................... 266 1-1102660-5....................................................293 1-1102662-5......................................................99 1-1102662-5.....................................................152 1-1102662-5................................................... 266 1-1102662-5....................................................293 1-1102664-5......................................................99 1-1102664-5.....................................................152 1-1102664-5................................................... 266 1-1102664-5....................................................293 1-1102665-5...................................................... 98 1-1102665-5......................................................151 1-1102665-5................................................... 294 1-1103092-0.....................................................195 1-1103092-1......................................................195 1-1103092-2.....................................................195 1-1103416-1........................................................ 43 1-1103416-1........................................................ 43 1-1103416-7....................................................... 43 1-1103416-8....................................................... 43 1-1103416-9.......................................................46 1-1103416-7....................................................... 43 1-1103416-8....................................................... 43 1-1103417-1......................................................... 43 1-1103417-1.........................................................46 1-1103417-7........................................................ 43 1-1103417-7........................................................46 1-1103417-8........................................................ 43 1-1103417-8........................................................46 1-1103417-9.......................................................46 1-1105000-2......................................................111 1-1105000-3......................................................111 1-1105001-2........................................................111 1-1105001-3........................................................111 1-1105653-8.................................................... 275 1-1105851-8.......................................................48 1-1105851-8.......................................................49 1-1105851-8...................................................... 110 1-1105851-8......................................................165 1-1105851-8..................................................... 190 1-1105851-8.......................................................191 1-1105851-8.................................................... 302 1-1106427-0......................................................80 333 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page 1-1106427-0......................................................131 1-1106427-0....................................................242 1-1110953-1....................................................... 275 1-1579007-8....................................................192 2-1102600-5..................................................... 35 2-1102600-5..................................................... 58 2-1102600-5....................................................187 2-1102601-5...................................................... 36 2-1102601-5...................................................... 59 2-1102601-5.....................................................188 2-1102602-5..................................................... 35 2-1102602-5..................................................... 58 2-1102602-5....................................................187 2-1102603-5..................................................... 35 2-1102603-5..................................................... 58 2-1102603-5....................................................187 2-1102604-5....................................................123 2-1102605-5....................................................123 2-1102606-5..................................................... 73 2-1102606-5....................................................122 2-1102611-5......................................................... 81 2-1102611-5.......................................................132 2-1102611-5......................................................243 2-1102611-5......................................................267 2-1102612-5........................................................ 81 2-1102612-5......................................................132 2-1102612-5.....................................................243 2-1102612-5.....................................................267 2-1102617-5.......................................................90 2-1102617-5......................................................142 2-1102617-5......................................................177 2-1102617-5.....................................................257 2-1102618-5...................................................... 89 2-1102618-5......................................................141 2-1102618-5.....................................................176 2-1102618-5....................................................256 2-1102622-5......................................................99 2-1102622-5.....................................................152 2-1102622-5................................................... 266 2-1102622-5....................................................293 2-1102623-5......................................................99 2-1102623-5.....................................................152 2-1102623-5................................................... 266 2-1102623-5....................................................293 2-1102625-5...................................................... 98 2-1102625-5......................................................151 2-1102625-5................................................... 294 2-1102626-5..................................................... 98 2-1102626-5.....................................................151 2-1102626-5.................................................. 294 2-1102628-5..................................................... 98 2-1102628-5.....................................................151 2-1102628-5.................................................. 294 2-1102631-5....................................................... 73 2-1102631-5......................................................122 2-1102633-5..................................................... 73 Part Number Page 2-1102633-5....................................................122 2-1102635-5...................................................... 73 2-1102635-5.....................................................122 2-1102637-5...................................................... 73 2-1102637-5.....................................................122 2-1102638-5..................................................... 73 2-1102638-5....................................................122 2-1102642-5.....................................................80 2-1102642-5.....................................................131 2-1102642-5...................................................242 2-1102644-5.....................................................80 2-1102644-5.....................................................131 2-1102644-5...................................................242 2-1102647-5......................................................80 2-1102647-5......................................................131 2-1102647-5....................................................242 2-1102651-5....................................................... 89 2-1102651-5.......................................................141 2-1102651-5......................................................176 2-1102651-5.....................................................256 2-1102655-5..................................................... 89 2-1102655-5.....................................................141 2-1102655-5....................................................176 2-1102655-5...................................................256 2-1102656-5..................................................... 89 2-1102656-5.....................................................141 2-1102656-5....................................................176 2-1102656-5...................................................256 2-1102660-5.....................................................99 2-1102660-5....................................................152 2-1102660-5.................................................. 266 2-1102660-5...................................................293 2-1102664-5.....................................................99 2-1102664-5....................................................152 2-1102664-5.................................................. 266 2-1102664-5...................................................293 2-1102665-5..................................................... 98 2-1102665-5.....................................................151 2-1102665-5.................................................. 294 2-1103004-3...................................................... 61 2-1103005-3...................................................... 61 2-1103006-3.....................................................70 2-1103007-3.....................................................70 2-1103008-3..................................................... 75 2-1103009-3..................................................... 75 2-1103010-3......................................................64 2-1103010-3...................................................... 67 2-1103011-3.......................................................64 2-1103011-3....................................................... 67 2-1103012-3...................................................... 83 2-1103012-3.................................................... 102 2-1103013-3...................................................... 83 2-1103013-3.................................................... 102 2-1103032-3..................................................... 92 2-1103032-3....................................................107 2-1103033-3..................................................... 92 334 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page 2-1103033-3....................................................107 2-1103414-3...................................................... 37 2-1103415-3...................................................... 37 2-1103416-3...................................................... 43 2-1103416-3......................................................46 2-1103416-7....................................................... 43 2-1103416-7.......................................................46 2-1103416-8...................................................... 43 2-1103416-8......................................................46 2-1103416-9......................................................46 2-1103417-3....................................................... 43 2-1103417-3.......................................................46 2-1103417-7....................................................... 43 2-1103417-7.......................................................46 2-1103417-8....................................................... 43 2-1103417-8.......................................................46 2-1103417-9......................................................46 2-1105000-3.....................................................111 2-1105001-3.......................................................111 2-1105653-8................................................... 275 3-1105000-2.....................................................111 3-1105001-2.......................................................111 3-1105653-8................................................... 275 3-1106200-5..................................................... 36 3-1106200-5..................................................... 59 3-1106200-5....................................................188 3-1106201-5.....................................................123 3-1106201-5................................................... 296 3-1106202-5...................................................... 81 3-1106202-5....................................................132 3-1106202-5...................................................243 3-1106202-5...................................................267 3-1106202-5.................................................. 296 3-1106203-5.....................................................90 3-1106203-5....................................................142 3-1106203-5....................................................177 3-1106203-5...................................................257 3-1106203-5.................................................. 296 3-1106204-5..................................................... 98 3-1106204-5.....................................................151 3-1106204-5.................................................. 294 3-1106204-5.................................................. 296 4-1102700-5 ................................................... 35 4-1102700-5 ................................................... 58 4-1102700-5 ..................................................187 4-1102701-5 ..................................................... 36 4-1102701-5 ..................................................... 59 4-1102701-5 ....................................................188 4-1102702-5..................................................... 35 4-1102702-5..................................................... 58 4-1102702-5....................................................187 4-1102703-5..................................................... 35 4-1102703-5..................................................... 58 4-1102703-5....................................................187 4-1102704-5..................................................... 73 4-1102704-5....................................................122 Part Number Page 4-1102706-5..................................................... 73 4-1102706-5....................................................122 4-1102707-5..................................................... 73 4-1102707-5....................................................122 4-1102710-5...................................................... 73 4-1102710-5.....................................................122 4-1102712-5...................................................... 73 4-1102712-5.....................................................122 4-1102714-5......................................................80 4-1102714-5......................................................131 4-1102714-5....................................................242 4-1102715-5......................................................80 4-1102715-5......................................................131 4-1102715-5....................................................242 4-1102715-5.................................................... 274 4-1102716-5.................................................... 274 4-1102717-5........................................................ 81 4-1102717-5......................................................132 4-1102717-5.....................................................243 4-1102717-5.....................................................267 4-1102718-5......................................................80 4-1102718-5......................................................131 4-1102718-5....................................................242 4-1102718-5.................................................... 274 4-1102720-5...................................................... 81 4-1102720-5....................................................132 4-1102720-5...................................................243 4-1102720-5...................................................267 4-1102722-5...................................................... 89 4-1102722-5......................................................141 4-1102722-5.....................................................176 4-1102722-5....................................................256 4-1102723-5...................................................... 89 4-1102723-5......................................................141 4-1102723-5.....................................................176 4-1102723-5....................................................256 4-1102725-5...................................................... 89 4-1102725-5......................................................141 4-1102725-5.....................................................176 4-1102725-5....................................................256 4-1102726-5.....................................................90 4-1102726-5....................................................142 4-1102726-5....................................................177 4-1102726-5...................................................257 4-1102727-5......................................................90 4-1102727-5.....................................................142 4-1102727-5.....................................................177 4-1102727-5....................................................257 4-1102728-5..................................................... 89 4-1102728-5.....................................................141 4-1102728-5....................................................176 4-1102728-5...................................................256 4-1102730-5..................................................... 89 4-1102730-5.....................................................141 4-1102730-5....................................................176 4-1102730-5...................................................256 Part Number Page 4-1102732-5......................................................99 4-1102732-5.....................................................152 4-1102732-5................................................... 266 4-1102732-5....................................................293 4-1102733-5......................................................99 4-1102733-5.....................................................152 4-1102733-5................................................... 266 4-1102733-5....................................................293 4-1102734-5..................................................... 98 4-1102734-5.....................................................151 4-1102734-5.................................................. 294 4-1102735-5...................................................... 98 4-1102735-5......................................................151 4-1102735-5................................................... 294 4-1102736-5..................................................... 98 4-1102736-5.....................................................151 4-1102736-5.................................................. 294 4-1102755-5......................................................99 4-1102755-5.....................................................152 4-1102755-5................................................... 266 4-1102755-5....................................................293 4-1102759-5.....................................................99 4-1102759-5....................................................152 4-1102759-5.................................................. 266 4-1102759-5...................................................293 4-1102760-5..................................................... 98 4-1102760-5.....................................................151 4-1102760-5.................................................. 294 4-1105000-3.....................................................111 4-1105001-3......................................................111 4-1105653-8................................................... 275 4-1106200-5.................................................... 36 4-1106200-5.................................................... 59 4-1106200-5...................................................188 4-1106201-5.....................................................123 4-1106201-5.....................................................123 4-1106201-5................................................... 296 4-1106202-5...................................................... 81 4-1106202-5....................................................132 4-1106202-5...................................................243 4-1106202-5...................................................267 4-1106202-5.................................................. 296 4-1106203-5.....................................................90 4-1106203-5....................................................142 4-1106203-5....................................................177 4-1106203-5...................................................257 4-1106203-5.................................................. 296 4-1106204-5.................................................... 98 4-1106204-5....................................................151 4-1106204-5................................................. 294 4-1106204-5................................................. 296 5-1102610-5....................................................... 81 5-1102610-5.....................................................132 5-1102610-5....................................................243 5-1102610-5....................................................267 5-1102616-5......................................................90 Part Number Page 5-1102616-5.....................................................142 5-1102616-5.....................................................177 5-1102616-5....................................................257 5-1102624-5..................................................... 98 5-1102624-5.....................................................151 5-1102624-5.................................................. 294 5-1102708-5....................................................123 5-1102709-5....................................................123 5-1102716-5........................................................ 81 5-1102716-5......................................................132 5-1102716-5.....................................................243 5-1102716-5.....................................................267 5-1105653-8................................................... 275 6-1105653-8................................................... 275 7-1103414-1....................................................... 37 7-1103415-1........................................................ 37 7-1103416-1........................................................ 39 7-1103416-1......................................................... 41 7-1103416-1........................................................ 43 7-1103416-1........................................................ 43 7-1103416-7....................................................... 43 7-1103416-8...................................................... 43 7-1103416-9......................................................46 7-1103416-7........................................................ 41 7-1103416-7....................................................... 43 7-1103416-8...................................................... 43 7-1103417-1........................................................ 39 7-1103417-1......................................................... 41 7-1103417-1........................................................ 43 7-1103417-1........................................................46 7-1103417-7........................................................ 41 7-1103417-7....................................................... 43 7-1103417-7.......................................................46 7-1103417-8....................................................... 43 7-1103417-8.......................................................46 7-1103417-9.......................................................46 7-1105653-8................................................... 275 8-1105653-8................................................... 275 539635-1............................................................111 539742-2............................................................111 929962-1..........................................................192 929963-1..........................................................192 929964-1..........................................................192 929965-1..........................................................192 929969-1..........................................................192 929970-1..........................................................192 929971-1...........................................................192 929972-1..........................................................192 962966-1..........................................................192 962967-1..........................................................192 962968-1..........................................................192 962969-1..........................................................192 962976-1..........................................................192 962977-1..........................................................192 962978-1..........................................................192 962979-1..........................................................192 335 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page 1481004-7........................................................192 1579000-7.......................................................192 T0926003000-000................................... 310 T0931000423-000.................................... 307 T0931000425-000.................................... 307 T0931006524-000.................................... 307 T0931006527-000.................................... 307 T0931100423-000..................................... 307 T0931100425-000..................................... 307 T0931100425-000..................................... 307 T0931106524-000..................................... 307 T0931106527-000...................................... 307 T0931106527-000...................................... 307 T0932000423-000................................... 307 T0932006524-000................................... 307 T0932406003-000................................... 310 T0910004109-000......................................318 T0910004111-000.........................................318 T0910004113-000........................................318 T0910004116-000.......................................318 T0910004121-000........................................318 T0910004129-000......................................318 T0910004136-000......................................318 T0910004142-000......................................318 T0910004148-000......................................318 T1000321220-000...................................... 104 T1000321220-000.......................................158 T1000321220-000.......................................179 T1010031100-000.......................................... 33 T1010031100-000.......................................... 34 T1010031100-000.......................................... 56 T1010031100-000.......................................... 57 T1010031100-000.........................................185 T1010031100-000.........................................186 T1010032100-000......................................... 34 T1010032100-000......................................... 57 T1010032100-000........................................186 T1010032200-000........................................ 34 T1010032200-000........................................ 57 T1010032200-000.......................................186 T1010032300-000........................................ 34 T1010032300-000........................................ 57 T1010032300-000.......................................186 T1010033100-000......................................... 33 T1010033100-000......................................... 56 T1010033100-000........................................185 T1010033200-000........................................ 34 T1010033200-000........................................ 57 T1010033200-000.......................................186 T1010061400-000......................................... 71 T1010061400-000...................................... 120 T1010101400-000......................................... 76 T1010101400-000........................................127 T1010101400-000.......................................238 T1010101500-000.......................................... 78 T1010101500-000.........................................129 Part Number Page T1010101500-000....................................... 240 T1010102100-000.......................................... 76 T1010102100-000.........................................127 T1010102100-000........................................238 T1010161400-000.......................................... 85 T1010161400-000.........................................137 T1010161400-000.........................................172 T1010161400-000........................................252 T1010161500-000.......................................... 87 T1010161500-000.........................................139 T1010161500-000.........................................174 T1010161500-000........................................254 T1010162100-000.......................................... 85 T1010162100-000.........................................137 T1010162100-000.........................................172 T1010162100-000........................................252 T1010241400-000.........................................94 T1010241400-000........................................147 T1010241400-000.......................................262 T1010241500-000.........................................96 T1010241500-000....................................... 149 T1010241500-000...................................... 264 T1010242100-000.........................................94 T1010242100-000........................................147 T1010242100-000.......................................262 T1019101101-000............................................ 38 T1019101101-000............................................ 62 T1019101201-000........................................... 38 T1019101201-000........................................... 62 T1019161101-000............................................. 65 T1019161201-000............................................40 T1019161101-000.............................................40 T1019161201-000............................................ 65 T1210100116-000........................................... 76 T1210100116-000..........................................127 T1210100116-000.........................................238 T1210100120-000.......................................... 76 T1210100120-000.........................................127 T1210100120-000........................................238 T1210100121-000............................................ 76 T1210100121-000...........................................127 T1210100121-000..........................................238 T1210100125-000.......................................... 76 T1210100125-000.........................................127 T1210100125-000........................................238 T1210160116-000............................................ 85 T1210160116-000...........................................137 T1210160116-000...........................................172 T1210160116-000..........................................252 T1210160120-000.......................................... 85 T1210160125-000........................................... 85 T1210160120-000.........................................137 T1210160125-000..........................................137 T1210160120-000.........................................172 T1210160125-000..........................................172 T1210160120-000........................................252 336 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T1210160125-000.........................................252 T1210160121-000............................................ 85 T1210160121-000...........................................137 T1210160121-000...........................................172 T1210160121-000..........................................252 T1210160132-000........................................... 85 T1210160132-000..........................................137 T1210160132-000..........................................172 T1210160132-000.........................................252 T1210240116-000...........................................94 T1210240116-000..........................................147 T1210240116-000.........................................262 T1210240121-000...........................................94 T1210240121-000..........................................147 T1210240121-000.........................................262 T1210240125-000..........................................94 T1210240125-000.........................................147 T1210240125-000........................................262 T1210240132-000..........................................94 T1210240132-000.........................................147 T1210240132-000........................................262 T1210320129-000........................................ 104 T1210320129-000.........................................158 T1210320129-000.........................................179 T1210320132-000........................................ 104 T1210320132-000.........................................158 T1210320132-000.........................................179 T1210320136-000........................................ 104 T1210320136-000.........................................158 T1210320136-000.........................................179 T1210320140-000....................................... 104 T1210320140-000........................................158 T1210320140-000........................................179 T1220100116-000.......................................... 76 T1220100116-000.........................................127 T1220100116-000........................................238 T1220100120-000......................................... 76 T1220100120-000........................................127 T1220100120-000.......................................238 T1220100121-000........................................... 76 T1220100121-000..........................................127 T1220100121-000.........................................238 T1220100125-000.......................................... 76 T1220100125-000.........................................127 T1220100125-000........................................238 T1220160116-000........................................... 85 T1220160116-000..........................................137 T1220160116-000..........................................172 T1220160116-000.........................................252 T1220160121-000........................................... 85 T1220160121-000..........................................137 T1220160121-000..........................................172 T1220160121-000.........................................252 T1220160125-000.......................................... 85 T1220160125-000.........................................137 T1220160125-000.........................................172 Part Number Page T1220160125-000........................................252 T1220160132-000.......................................... 85 T1220160132-000.........................................137 T1220160132-000.........................................172 T1220160132-000........................................252 T1220240116-000..........................................94 T1220240116-000.........................................147 T1220240116-000........................................262 T1220240121-000..........................................94 T1220240121-000.........................................147 T1220240121-000........................................262 T1220240125-000.........................................94 T1220240125-000........................................147 T1220240125-000.......................................262 T1220240132-000.........................................94 T1220240132-000........................................147 T1220240132-000.......................................262 T1220320121-000........................................ 104 T1220320121-000.........................................158 T1220320121-000.........................................179 T1220320125-000....................................... 104 T1220320125-000........................................158 T1220320125-000........................................179 T1220320129-000....................................... 104 T1220320129-000........................................158 T1220320129-000........................................179 T1220320132-000....................................... 104 T1220320132-000........................................158 T1220320132-000........................................179 T1220320136-000....................................... 104 T1220320136-000........................................158 T1220320136-000........................................179 T1220320140-000...................................... 104 T1220320140-000.......................................158 T1220320140-000.......................................179 T1220320142-000....................................... 104 T1220320142-000........................................158 T1220320142-000........................................179 T1220320150-000...................................... 104 T1220320150-000.......................................158 T1220320150-000.......................................179 T1230060125-000........................................ 85 T1230060125-000.......................................137 T1230060125-000.......................................172 T1230060125-000......................................252 T1230100120-000......................................... 76 T1230100120-000........................................127 T1230100120-000.......................................238 T1230100121-000.......................................... 76 T1230100121-000.........................................127 T1230100121-000........................................238 T1230100125-000......................................... 76 T1230100125-000........................................127 T1230100125-000.......................................238 T1230100129-000......................................... 76 T1230100129-000........................................127 Part Number Page T1230100129-000.......................................238 T1230100132-000......................................... 76 T1230100132-000........................................127 T1230100132-000.......................................238 T1230102116-000........................................ 280 T1230102120-000....................................... 280 T1230160121-000........................................... 85 T1230160121-000..........................................137 T1230160121-000..........................................172 T1230160121-000.........................................252 T1230160129-000.......................................... 85 T1230160129-000.........................................137 T1230160129-000.........................................172 T1230160129-000........................................252 T1230160132-000.......................................... 85 T1230160132-000.........................................137 T1230160132-000.........................................172 T1230160132-000........................................252 T1230160140-000......................................... 85 T1230160140-000........................................137 T1230160140-000........................................172 T1230160140-000.......................................252 T1230162121-000........................................ 280 T1230162125-000....................................... 280 T1230240121-000..........................................94 T1230240121-000.........................................147 T1230240121-000........................................262 T1230240125-000.........................................94 T1230240125-000........................................147 T1230240125-000.......................................262 T1230240129-000.........................................94 T1230240129-000........................................147 T1230240129-000.......................................262 T1230240132-000.........................................94 T1230240132-000........................................147 T1230240132-000.......................................262 T1230240140-000........................................94 T1230240140-000.......................................147 T1230240140-000......................................262 T1230242121-000....................................... 280 T1230242125-000...................................... 280 T1240100120-000......................................... 76 T1240100120-000........................................127 T1240100120-000.......................................238 T1240100121-000.......................................... 76 T1240100121-000.........................................127 T1240100121-000........................................238 T1240100125-000......................................... 76 T1240100125-000........................................127 T1240100125-000.......................................238 T1240100129-000......................................... 76 T1240100129-000........................................127 T1240100129-000.......................................238 T1240100132-000......................................... 76 T1240100132-000........................................127 T1240100132-000.......................................238 Part Number Page T1240102116-000........................................ 280 T1240102120-000...................................... 280 T1240160121-000........................................... 85 T1240160121-000..........................................137 T1240160121-000..........................................172 T1240160121-000.........................................252 T1240160125-000.......................................... 85 T1240160125-000.........................................137 T1240160125-000.........................................172 T1240160125-000........................................252 T1240160129-000......................................... 85 T1240160129-000........................................137 T1240160129-000........................................172 T1240160129-000.......................................252 T1240160132-000.......................................... 85 T1240160132-000.........................................137 T1240160132-000.........................................172 T1240160132-000........................................252 T1240160140-000......................................... 85 T1240160140-000........................................137 T1240160140-000........................................172 T1240160140-000.......................................252 T1240162121-000........................................ 280 T1240162125-000....................................... 280 T1240240121-000..........................................94 T1240240121-000.........................................147 T1240240121-000........................................262 T1240240125-000.........................................94 T1240240125-000........................................147 T1240240125-000.......................................262 T1240240129-000........................................94 T1240240129-000.......................................147 T1240240129-000......................................262 T1240240132-000.........................................94 T1240240132-000........................................147 T1240240132-000.......................................262 T1240240140-000........................................94 T1240240140-000.......................................147 T1240240140-000......................................262 T1240242121-000....................................... 280 T1240242125-000...................................... 280 T1250103116-000........................................... 77 T1250103116-000..........................................128 T1250103116-000.........................................239 T1250103120-000......................................... 77 T1250103120-000........................................128 T1250103120-000.......................................239 T1250103121-000........................................... 77 T1250103121-000..........................................128 T1250103121-000.........................................239 T1250103125-000.......................................... 77 T1250103125-000.........................................128 T1250103125-000........................................239 T1250163116-000........................................... 86 T1250163116-000..........................................138 T1250163116-000..........................................173 337 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T1250163116-000.........................................253 T1250163120-000.......................................... 86 T1250163120-000.........................................138 T1250163120-000.........................................173 T1250163120-000........................................253 T1250163121-000........................................... 86 T1250163121-000..........................................138 T1250163121-000..........................................173 T1250163121-000.........................................253 T1250163125-000.......................................... 86 T1250163125-000.........................................138 T1250163125-000.........................................173 T1250163125-000........................................253 T1250243116-000.......................................... 95 T1250243116-000........................................ 148 T1250243116-000........................................263 T1250243120-000......................................... 95 T1250243120-000....................................... 148 T1250243120-000.......................................263 T1250243121-000.......................................... 95 T1250243121-000........................................ 148 T1250243121-000........................................263 T1250243125-000......................................... 95 T1250243125-000....................................... 148 T1250243125-000.......................................263 T1260103116-000........................................... 77 T1260103116-000..........................................128 T1260103116-000.........................................239 T1260103120-000......................................... 77 T1260103120-000........................................128 T1260103120-000.......................................239 T1260103121-000........................................... 77 T1260103121-000..........................................128 T1260103121-000.........................................239 T1260103125-000.......................................... 77 T1260103125-000.........................................128 T1260103125-000........................................239 T1260163116-000........................................... 86 T1260163116-000..........................................138 T1260163116-000..........................................173 T1260163116-000.........................................253 T1260163120-000.......................................... 86 T1260163120-000.........................................138 T1260163120-000.........................................173 T1260163120-000........................................253 T1260163121-000........................................... 86 T1260163121-000..........................................138 T1260163121-000..........................................173 T1260163121-000.........................................253 T1260163125-000.......................................... 86 T1260163125-000.........................................138 T1260163125-000.........................................173 T1260163125-000........................................253 T1260243116-000.......................................... 95 T1260243116-000........................................ 148 T1260243116-000........................................263 Part Number Page T1260243120-000......................................... 95 T1260243120-000....................................... 148 T1260243120-000.......................................263 T1260243121-000.......................................... 95 T1260243121-000........................................ 148 T1260243121-000........................................263 T1260243125-000......................................... 95 T1260243125-000....................................... 148 T1260243125-000.......................................263 T1270103121-000........................................... 77 T1270103121-000..........................................128 T1270103121-000.........................................239 T1270103125-000.......................................... 77 T1270103125-000.........................................128 T1270103125-000........................................239 T1270103129-000.......................................... 77 T1270103129-000.........................................128 T1270103129-000........................................239 T1270103132-000.......................................... 77 T1270103132-000.........................................128 T1270103132-000........................................239 T1270163121-000........................................... 86 T1270163121-000..........................................138 T1270163121-000..........................................173 T1270163121-000.........................................253 T1270163125-000.......................................... 86 T1270163125-000.........................................138 T1270163125-000.........................................173 T1270163125-000........................................253 T1270163129-000.......................................... 86 T1270163129-000.........................................138 T1270163129-000.........................................173 T1270163129-000........................................253 T1270163132-000.......................................... 86 T1270163132-000.........................................138 T1270163132-000.........................................173 T1270163132-000........................................253 T1270243121-000.......................................... 95 T1270243121-000........................................ 148 T1270243121-000........................................263 T1270243125-000......................................... 95 T1270243125-000....................................... 148 T1270243125-000.......................................263 T1270243129-000......................................... 95 T1270243129-000....................................... 148 T1270243129-000.......................................263 T1270243132-000......................................... 95 T1270243132-000....................................... 148 T1270243132-000.......................................263 T1280103121-000........................................... 77 T1280103121-000..........................................128 T1280103121-000.........................................239 T1280103125-000.......................................... 77 T1280103125-000.........................................128 T1280103125-000........................................239 T1280103129-000.......................................... 77 338 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T1280103129-000.........................................128 T1280103129-000........................................239 T1280103132-000.......................................... 77 T1280103132-000.........................................128 T1280103132-000........................................239 T1280163121-000........................................... 86 T1280163121-000..........................................138 T1280163121-000..........................................173 T1280163121-000.........................................253 T1280163125-000.......................................... 86 T1280163125-000.........................................138 T1280163125-000.........................................173 T1280163125-000........................................253 T1280163129-000.......................................... 86 T1280163129-000.........................................138 T1280163129-000.........................................173 T1280163129-000........................................253 T1280163132-000.......................................... 86 T1280163132-000.........................................138 T1280163132-000.........................................173 T1280163132-000........................................253 T1280243121-000.......................................... 95 T1280243121-000........................................ 148 T1280243121-000........................................263 T1280243125-000......................................... 95 T1280243125-000....................................... 148 T1280243125-000.......................................263 T1280243129-000......................................... 95 T1280243129-000....................................... 148 T1280243129-000.......................................263 T1280243132-000......................................... 95 T1280243132-000....................................... 148 T1280243132-000.......................................263 T1310060116-000........................................... 71 T1310060116-000........................................ 120 T1310060120-000.......................................... 71 T1310060120-000....................................... 120 T1310060121-000........................................... 71 T1310060121-000........................................ 120 T1310060125-000.......................................... 71 T1310060125-000....................................... 120 T1310100116-000........................................... 78 T1310100116-000..........................................129 T1310100116-000........................................ 240 T1310100120-000.......................................... 78 T1310100120-000.........................................129 T1310100120-000....................................... 240 T1310100121-000........................................... 78 T1310100121-000..........................................129 T1310100121-000........................................ 240 T1310100125-000.......................................... 78 T1310100125-000.........................................129 T1310100125-000....................................... 240 T1310160121-000............................................ 87 T1310160121-000...........................................139 T1310160121-000...........................................174 Part Number Page T1310160121-000..........................................254 T1310160125-000........................................... 87 T1310160125-000..........................................139 T1310160125-000..........................................174 T1310160125-000.........................................254 T1310160129-000........................................... 87 T1310160129-000..........................................139 T1310160129-000..........................................174 T1310160129-000.........................................254 T1310160132-000........................................... 87 T1310160132-000..........................................139 T1310160132-000..........................................174 T1310160132-000.........................................254 T1310240121-000...........................................96 T1310240121-000......................................... 149 T1310240121-000........................................ 264 T1310240125-000..........................................96 T1310240125-000........................................ 149 T1310240125-000....................................... 264 T1310240129-000..........................................96 T1310240129-000........................................ 149 T1310240129-000....................................... 264 T1310240132-000..........................................96 T1310240132-000........................................ 149 T1310240132-000....................................... 264 T1310320129-000........................................ 105 T1310320129-000.........................................159 T1310320129-000........................................ 180 T1310320132-000........................................ 105 T1310320132-000.........................................159 T1310320132-000........................................ 180 T1310320136-000........................................ 105 T1310320136-000.........................................159 T1310320136-000........................................ 180 T1310320140-000....................................... 105 T1310320140-000........................................159 T1310320140-000....................................... 180 T1310480129-000....................................... 109 T1310480129-000....................................... 164 T1310480132-000....................................... 109 T1310480132-000....................................... 164 T1310480136-000....................................... 109 T1310480136-000....................................... 164 T1310480140-000....................................... 109 T1310480140-000....................................... 164 T1310480142-000....................................... 109 T1310480142-000....................................... 164 T1310480150-000....................................... 109 T1310480150-000....................................... 164 T1310480163-000....................................... 109 T1310480163-000....................................... 164 T1319030111-000............................................ 33 T1319030111-000............................................ 56 T1319030111-000...........................................185 T1319030120-000......................................... 33 T1319030120-000......................................... 56 Part Number Page T1319030120-000........................................185 T1319031111-000............................................. 34 T1319031120-000........................................... 34 T1319031111-000............................................. 34 T1319031120-000........................................... 57 T1319031111-000............................................. 57 T1319031120-000..........................................186 T1319100116-000............................................ 38 T1319100121-000............................................ 38 T1319100120-000.......................................... 38 T1319100125-000........................................... 38 T1319100116-000............................................ 38 T1319100121-000............................................ 38 T1319100120-000.......................................... 38 T1319100125-000........................................... 62 T1319160116-000............................................40 T1319160116-000............................................ 65 T1319160120-000...........................................40 T1319160120-000........................................... 65 T1319160121-000............................................40 T1319160121-000............................................ 65 T1319160125-000...........................................40 T1319160125-000........................................... 65 T1319320121-000........................................... 42 T1319320121-000........................................... 68 T1319320125-000.......................................... 42 T1319320125-000.......................................... 68 T1319320129-000.......................................... 42 T1319320129-000.......................................... 68 T1319320132-000.......................................... 42 T1319320132-000.......................................... 68 T1319320136-000.......................................... 42 T1319320136-000.......................................... 68 T1319320140-000......................................... 42 T1319320140-000......................................... 68 T1320060116-000.......................................... 71 T1320060116-000....................................... 120 T1320060120-000......................................... 71 T1320060120-000...................................... 120 T1320060121-000.......................................... 71 T1320060121-000....................................... 120 T1320060125-000......................................... 71 T1320060125-000...................................... 120 T1320100116-000.......................................... 78 T1320100116-000.........................................129 T1320100116-000....................................... 240 T1320100120-000......................................... 78 T1320100120-000........................................129 T1320100120-000...................................... 240 T1320100121-000.......................................... 78 T1320100121-000.........................................129 T1320100121-000....................................... 240 T1320100125-000......................................... 78 T1320100125-000........................................129 T1320100125-000...................................... 240 T1320160121-000........................................... 87 Part Number Page T1320160121-000..........................................139 T1320160121-000..........................................174 T1320160121-000.........................................254 T1320160125-000.......................................... 87 T1320160125-000.........................................139 T1320160125-000.........................................174 T1320160125-000........................................254 T1320160129-000.......................................... 87 T1320160129-000.........................................139 T1320160129-000.........................................174 T1320160129-000........................................254 T1320160132-000.......................................... 87 T1320160132-000.........................................139 T1320160132-000.........................................174 T1320160132-000........................................254 T1320240121-000..........................................96 T1320240121-000........................................ 149 T1320240121-000....................................... 264 T1320240125-000.........................................96 T1320240125-000....................................... 149 T1320240125-000...................................... 264 T1320240129-000.........................................96 T1320240129-000....................................... 149 T1320240129-000...................................... 264 T1320240132-000.........................................96 T1320240132-000....................................... 149 T1320240132-000...................................... 264 T1320320121-000........................................ 105 T1320320121-000.........................................159 T1320320121-000........................................ 180 T1320320125-000....................................... 105 T1320320125-000........................................159 T1320320125-000....................................... 180 T1320320129-000....................................... 105 T1320320129-000........................................159 T1320320129-000....................................... 180 T1320320132-000....................................... 105 T1320320132-000........................................159 T1320320132-000....................................... 180 T1320320136-000....................................... 105 T1320320136-000........................................159 T1320320136-000....................................... 180 T1320320140-000...................................... 105 T1320320140-000.......................................159 T1320320140-000...................................... 180 T1320320142-000....................................... 105 T1320320142-000........................................159 T1320320142-000....................................... 180 T1320320150-000...................................... 105 T1320320150-000.......................................159 T1320320150-000...................................... 180 T1320480129-000...................................... 109 T1320480129-000...................................... 164 T1320480132-000...................................... 109 T1320480132-000...................................... 164 T1320480136-000...................................... 109 339 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T1320480136-000...................................... 164 T1320480140-000...................................... 109 T1320480140-000...................................... 164 T1320480142-000...................................... 109 T1320480142-000...................................... 164 T1320480150-000...................................... 109 T1320480150-000...................................... 164 T1320480163-000...................................... 109 T1320480163-000...................................... 164 T1329030111-000........................................... 33 T1329030111-000........................................... 56 T1329030111-000..........................................185 T1329030120-000........................................ 33 T1329030120-000........................................ 56 T1329030120-000.......................................185 T1329031111-000............................................ 34 T1329031120-000.......................................... 34 T1329031111-000............................................ 57 T1329031120-000.......................................... 57 T1329031111-000...........................................186 T1329031120-000.........................................186 T1329080120-000.......................................193 T1329080125-000........................................193 T1329100116-000........................................... 38 T1329100116-000........................................... 62 T1329100120-000......................................... 38 T1329100120-000......................................... 62 T1329100121-000........................................... 38 T1329100121-000........................................... 62 T1329100125-000.......................................... 38 T1329100125-000.......................................... 62 T1329160116-000...........................................40 T1329160116-000........................................... 65 T1329160120-000..........................................40 T1329160120-000.......................................... 65 T1329160121-000...........................................40 T1329160121-000........................................... 65 T1329160125-000..........................................40 T1329160125-000.......................................... 65 T1329320121-000.......................................... 42 T1329320121-000.......................................... 68 T1329320125-000......................................... 42 T1329320125-000......................................... 68 T1329320129-000......................................... 42 T1329320129-000......................................... 68 T1329320132-000......................................... 42 T1329320132-000......................................... 68 T1329320136-000......................................... 42 T1329320136-000......................................... 68 T1329320140-000........................................ 42 T1329320140-000........................................ 68 T1330060120-000......................................... 71 T1330060120-000...................................... 120 T1330060121-000.......................................... 71 T1330060121-000....................................... 120 T1330060125-000......................................... 71 Part Number Page T1330060125-000...................................... 120 T1330060129-000......................................... 71 T1330060129-000...................................... 120 T1330060132-000......................................... 71 T1330060132-000...................................... 120 T1330100120-000......................................... 78 T1330100120-000........................................129 T1330100120-000...................................... 240 T1330100121-000.......................................... 78 T1330100121-000.........................................129 T1330100121-000....................................... 240 T1330100125-000......................................... 78 T1330100125-000........................................129 T1330100125-000...................................... 240 T1330100129-000......................................... 78 T1330100129-000........................................129 T1330100129-000...................................... 240 T1330100132-000......................................... 78 T1330100132-000........................................129 T1330100132-000...................................... 240 T1330160121-000........................................... 87 T1330160121-000..........................................139 T1330160121-000..........................................174 T1330160121-000.........................................254 T1330160125-000.......................................... 87 T1330160125-000.........................................139 T1330160125-000.........................................174 T1330160125-000........................................254 T1330160129-000.......................................... 87 T1330160129-000.........................................139 T1330160129-000.........................................174 T1330160129-000........................................254 T1330160132-000.......................................... 87 T1330160132-000.........................................139 T1330160132-000.........................................174 T1330160132-000........................................254 T1330160140-000......................................... 87 T1330160140-000........................................139 T1330160140-000........................................174 T1330160140-000.......................................254 T1330240121-000..........................................96 T1330240121-000........................................ 149 T1330240121-000....................................... 264 T1330240125-000.........................................96 T1330240125-000....................................... 149 T1330240125-000...................................... 264 T1330240129-000.........................................96 T1330240129-000....................................... 149 T1330240129-000...................................... 264 T1330240132-000.........................................96 T1330240132-000....................................... 149 T1330240132-000...................................... 264 T1330240140-000........................................96 T1330240140-000...................................... 149 T1330240140-000..................................... 264 T1339160121-000...........................................40 340 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T1339160121-000........................................... 65 T1339160125-000..........................................40 T1339160125-000.......................................... 65 T1340060120-000......................................... 71 T1340060120-000...................................... 120 T1340060121-000.......................................... 71 T1340060121-000....................................... 120 T1340060125-000......................................... 71 T1340060125-000...................................... 120 T1340060129-000......................................... 71 T1340060129-000...................................... 120 T1340060132-000......................................... 71 T1340060132-000...................................... 120 T1340100120-000......................................... 78 T1340100120-000........................................129 T1340100120-000...................................... 240 T1340100121-000.......................................... 78 T1340100121-000.........................................129 T1340100121-000....................................... 240 T1340100125-000......................................... 78 T1340100125-000........................................129 T1340100125-000...................................... 240 T1340100129-000......................................... 78 T1340100129-000........................................129 T1340100129-000...................................... 240 T1340100132-000......................................... 78 T1340100132-000........................................129 T1340100132-000...................................... 240 T1340160121-000.......................................... 87 T1340160121-000.........................................139 T1340160121-000.........................................174 T1340160121-000........................................254 T1340160125-000......................................... 87 T1340160125-000........................................139 T1340160125-000........................................174 T1340160125-000.......................................254 T1340160129-000......................................... 87 T1340160129-000........................................139 T1340160129-000........................................174 T1340160129-000.......................................254 T1340160132-000......................................... 87 T1340160132-000........................................139 T1340160132-000........................................174 T1340160132-000.......................................254 T1340160140-000......................................... 87 T1340160140-000........................................139 T1340160140-000........................................174 T1340160140-000.......................................254 T1340240121-000..........................................96 T1340240121-000........................................ 149 T1340240121-000....................................... 264 T1340240125-000........................................96 T1340240125-000...................................... 149 T1340240125-000..................................... 264 T1340240129-000........................................96 T1340240129-000...................................... 149 Part Number Page T1340240129-000..................................... 264 T1340240132-000........................................96 T1340240132-000...................................... 149 T1340240132-000..................................... 264 T1340240140-000........................................96 T1340240140-000...................................... 149 T1340240140-000..................................... 264 T1349160121-000...........................................40 T1349160121-000........................................... 65 T1349160125-000..........................................40 T1349160125-000.......................................... 65 T1359090116-000........................................193 T1319080120-000........................................193 T1319080125-000.........................................193 T1410101000-000......................................... 77 T1410101000-000........................................128 T1410101000-000.......................................239 T1410161000-000.......................................... 86 T1410161000-000.........................................138 T1410161000-000.........................................173 T1410161000-000........................................253 T1410241000-000......................................... 95 T1410241000-000....................................... 148 T1410241000-000.......................................263 T1410322000-000...................................... 104 T1410322000-000.......................................158 T1410322000-000.......................................179 T1419320000-000........................................ 42 T1419320000-000........................................ 68 T1430100000-000....................................... 77 T1460100116-000.......................................... 77 T1430100000-000......................................128 T1460100116-000.........................................128 T1430100000-000.....................................239 T1460100116-000........................................239 T1430160000-000....................................... 86 T1460160121-000.......................................... 86 T1430160000-000......................................138 T1460160121-000.........................................138 T1430160000-000......................................173 T1460160121-000.........................................173 T1430160000-000.....................................253 T1460160121-000........................................253 T1430240000-000...................................... 95 T1430240000-000.................................... 148 T1430240000-000....................................263 T1440101116-000........................................... 77 T1440101116-000..........................................128 T1440101116-000.........................................239 T1440101120-000.......................................... 77 T1440101120-000.........................................128 T1440101120-000........................................239 T1440101121-000........................................... 77 T1440101121-000..........................................128 T1440101121-000.........................................239 T1440101125-000.......................................... 77 Part Number Page T1440101125-000.........................................128 T1440101125-000........................................239 T1440101216-000.......................................... 77 T1440101216-000.........................................128 T1440101216-000........................................239 T1440101220-000......................................... 77 T1440101220-000........................................128 T1440101220-000.......................................239 T1440101221-000.......................................... 77 T1440101221-000.........................................128 T1440101221-000........................................239 T1440101225-000......................................... 77 T1440101225-000........................................128 T1440101225-000.......................................239 T1440161121-000............................................ 86 T1440161121-000...........................................138 T1440161121-000...........................................173 T1440161121-000..........................................253 T1440161125-000........................................... 86 T1440161125-000..........................................138 T1440161125-000..........................................173 T1440161125-000.........................................253 T1440161221-000........................................... 86 T1440161221-000..........................................138 T1440161221-000..........................................173 T1440161221-000.........................................253 T1440161225-000.......................................... 86 T1440161225-000.........................................138 T1440161225-000.........................................173 T1440161225-000........................................253 T1440241121-000........................................... 95 T1440241121-000......................................... 148 T1440241121-000.........................................263 T1440241125-000.......................................... 95 T1440241125-000........................................ 148 T1440241125-000........................................263 T1440241221-000.......................................... 95 T1440241221-000........................................ 148 T1440241221-000........................................263 T1440241225-000......................................... 95 T1440241225-000....................................... 148 T1440241225-000.......................................263 T1440322129-000....................................... 104 T1440322129-000........................................158 T1440322129-000........................................179 T1440322132-000....................................... 104 T1440322132-000........................................158 T1440322132-000........................................179 T1440322136-000....................................... 104 T1440322136-000........................................158 T1440322136-000........................................179 T1440322140-000...................................... 104 T1440322140-000.......................................158 T1440322140-000.......................................179 T1440322142-000....................................... 104 T1440322142-000........................................158 Part Number Page T1440322142-000........................................179 T1440322150-000...................................... 104 T1440322150-000.......................................158 T1440322150-000.......................................179 T1440322163-000....................................... 104 T1440322163-000........................................158 T1440322163-000........................................179 T1440322229-000...................................... 104 T1440322229-000.......................................158 T1440322229-000.......................................179 T1440322232-000...................................... 104 T1440322232-000.......................................158 T1440322232-000.......................................179 T1440322236-000...................................... 104 T1440322236-000.......................................158 T1440322236-000.......................................179 T1440322240-000..................................... 104 T1440322240-000......................................158 T1440322240-000......................................179 T1440322242-000...................................... 104 T1440322242-000.......................................158 T1440322242-000.......................................179 T1440322250-000..................................... 104 T1440322250-000......................................158 T1440322250-000......................................179 T1440322263-000...................................... 104 T1440322263-000.......................................158 T1440322263-000.......................................179 T1449320121-000.......................................... 42 T1449320121-000.......................................... 68 T1449320125-000......................................... 42 T1449320125-000......................................... 68 T1449320129-000......................................... 42 T1449320129-000......................................... 68 T1449320132-000......................................... 42 T1449320132-000......................................... 68 T1449320221-000......................................... 42 T1449320221-000......................................... 68 T1449320225-000........................................ 42 T1449320225-000........................................ 68 T1449320229-000........................................ 42 T1449320229-000........................................ 68 T1449320232-000........................................ 42 T1449320232-000........................................ 68 T1460100120-000......................................... 77 T1460100120-000........................................128 T1460100120-000.......................................239 T1460100121-000.......................................... 77 T1460100121-000.........................................128 T1460100121-000........................................239 T1460100125-000......................................... 77 T1460100125-000........................................128 T1460100125-000.......................................239 T1460100216-000......................................... 77 T1460100216-000........................................128 T1460100216-000.......................................239 341 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T1460100220-000........................................ 77 T1460100220-000.......................................128 T1460100220-000......................................239 T1460100221-000......................................... 77 T1460100221-000........................................128 T1460100221-000.......................................239 T1460100225-000........................................ 77 T1460100225-000.......................................128 T1460100225-000......................................239 T1460160125-000......................................... 86 T1460160125-000........................................138 T1460160125-000........................................173 T1460160125-000.......................................253 T1460160221-000......................................... 86 T1460160221-000........................................138 T1460160221-000........................................173 T1460160221-000.......................................253 T1460160225-000........................................ 86 T1460160225-000.......................................138 T1460160225-000.......................................173 T1460160225-000......................................253 T1460240121-000......................................... 95 T1460240121-000....................................... 148 T1460240121-000.......................................263 T1460240125-000........................................ 95 T1460240125-000...................................... 148 T1460240125-000......................................263 T1460240221-000........................................ 95 T1460240221-000...................................... 148 T1460240221-000......................................263 T1460240225-000....................................... 95 T1460240225-000..................................... 148 T1460240225-000.....................................263 T1470101121-000............................................ 77 T1470101121-000...........................................128 T1470101121-000..........................................239 T1470101125-000........................................... 77 T1470101125-000..........................................128 T1470101125-000.........................................239 T1470101129-000........................................... 77 T1470101129-000..........................................128 T1470101129-000.........................................239 T1470101132-000........................................... 77 T1470101132-000..........................................128 T1470101132-000.........................................239 T1470101221-000........................................... 77 T1470101221-000..........................................128 T1470101221-000.........................................239 T1470101225-000.......................................... 77 T1470101225-000.........................................128 T1470101225-000........................................239 T1470101229-000.......................................... 77 T1470101229-000.........................................128 T1470101229-000........................................239 T1470101232-000.......................................... 77 T1470101232-000.........................................128 Part Number Page T1470101232-000........................................239 T1470161121-000............................................ 86 T1470161121-000...........................................138 T1470161121-000...........................................173 T1470161121-000..........................................253 T1470161125-000........................................... 86 T1470161125-000..........................................138 T1470161125-000..........................................173 T1470161125-000.........................................253 T1470161129-000........................................... 86 T1470161129-000..........................................138 T1470161129-000..........................................173 T1470161129-000.........................................253 T1470161132-000........................................... 86 T1470161132-000..........................................138 T1470161132-000..........................................173 T1470161132-000.........................................253 T1470161221-000........................................... 86 T1470161221-000..........................................138 T1470161221-000..........................................173 T1470161221-000.........................................253 T1470161225-000.......................................... 86 T1470161225-000.........................................138 T1470161225-000.........................................173 T1470161225-000........................................253 T1470161229-000.......................................... 86 T1470161229-000.........................................138 T1470161229-000.........................................173 T1470161229-000........................................253 T1470161232-000.......................................... 86 T1470161232-000.........................................138 T1470161232-000.........................................173 T1470161232-000........................................253 T1470241121-000........................................... 95 T1470241121-000......................................... 148 T1470241121-000.........................................263 T1470241125-000.......................................... 95 T1470241125-000........................................ 148 T1470241125-000........................................263 T1470241129-000.......................................... 95 T1470241129-000........................................ 148 T1470241129-000........................................263 T1470241132-000.......................................... 95 T1470241132-000........................................ 148 T1470241132-000........................................263 T1470241221-000.......................................... 95 T1470241221-000........................................ 148 T1470241221-000........................................263 T1470241225-000......................................... 95 T1470241225-000....................................... 148 T1470241225-000.......................................263 T1470241229-000......................................... 95 T1470241229-000....................................... 148 T1470241229-000.......................................263 T1470241232-000......................................... 95 T1470241232-000....................................... 148 342 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T1470241232-000.......................................263 T1490100121-000.......................................... 77 T1490100121-000.........................................128 T1490100121-000........................................239 T1490100125-000......................................... 77 T1490100125-000........................................128 T1490100125-000.......................................239 T1490100129-000......................................... 77 T1490100129-000........................................128 T1490100129-000.......................................239 T1490100132-000......................................... 77 T1490100132-000........................................128 T1490100132-000.......................................239 T1490100221-000......................................... 77 T1490100221-000........................................128 T1490100221-000.......................................239 T1490100225-000........................................ 77 T1490100225-000.......................................128 T1490100225-000......................................239 T1490100229-000........................................ 77 T1490100229-000.......................................128 T1490100229-000......................................239 T1490100232-000........................................ 77 T1490100232-000.......................................128 T1490100232-000......................................239 T1490160121-000.......................................... 86 T1490160121-000.........................................138 T1490160121-000.........................................173 T1490160121-000........................................253 T1490160125-000......................................... 86 T1490160125-000........................................138 T1490160125-000........................................173 T1490160125-000.......................................253 T1490160129-000......................................... 86 T1490160129-000........................................138 T1490160129-000........................................173 T1490160129-000.......................................253 T1490160132-000......................................... 86 T1490160132-000........................................138 T1490160132-000........................................173 T1490160132-000.......................................253 T1490160221-000......................................... 86 T1490160221-000........................................138 T1490160221-000........................................173 T1490160221-000.......................................253 T1490160225-000........................................ 86 T1490160225-000.......................................138 T1490160225-000.......................................173 T1490160225-000......................................253 T1490160229-000........................................ 86 T1490160229-000.......................................138 T1490160229-000.......................................173 T1490160229-000......................................253 T1490160232-000........................................ 86 T1490160232-000.......................................138 T1490160232-000.......................................173 Part Number Page T1490160232-000......................................253 T1490240121-000......................................... 95 T1490240121-000....................................... 148 T1490240121-000.......................................263 T1490240125-000........................................ 95 T1490240125-000...................................... 148 T1490240125-000......................................263 T1490240129-000........................................ 95 T1490240129-000...................................... 148 T1490240129-000......................................263 T1490240132-000........................................ 95 T1490240132-000...................................... 148 T1490240132-000......................................263 T1490240221-000........................................ 95 T1490240221-000...................................... 148 T1490240221-000......................................263 T1490240225-000....................................... 95 T1490240225-000..................................... 148 T1490240225-000.....................................263 T1490240229-000....................................... 95 T1490240229-000..................................... 148 T1490240229-000.....................................263 T1490240232-000....................................... 95 T1490240232-000..................................... 148 T1490240232-000.....................................263 T1500062000-000...................................... 72 T1500062000-000......................................121 T1500103000-000....................................... 79 T1500103000-000..................................... 130 T1500103000-000......................................241 T1500163000-000....................................... 88 T1500163000-000..................................... 140 T1500163000-000......................................175 T1500163000-000.....................................255 T1500243000-000...................................... 97 T1500243000-000.................................... 150 T1500243000-000....................................265 T1500322000-000..................................... 105 T1500322000-000......................................159 T1500322000-000..................................... 180 T1500482000-000.................................... 109 T1500482000-000.................................... 164 T1509030000-000...................................... 33 T1509030000-000...................................... 56 T1509030000-000.....................................185 T1509031100-000......................................... 34 T1509031100-000......................................... 57 T1509031100-000........................................186 T1509031111-000............................................ 34 T1509031111-000............................................ 57 T1509031111-000...........................................186 T1509101000-000........................................ 38 T1509101000-000........................................ 62 T1509161000-000.........................................40 T1509161000-000......................................... 65 T1510062100-000......................................... 72 Part Number Page T1510062100-000.........................................121 T1510103000-000......................................... 79 T1510103000-000....................................... 130 T1510103000-000........................................241 T1510103001-000.......................................... 79 T1510103001-000........................................ 130 T1510103001-000.........................................241 T1510163000-000......................................... 88 T1510163000-000....................................... 140 T1510163000-000........................................175 T1510163000-000.......................................255 T1510243000-000........................................ 97 T1510243000-000...................................... 150 T1510243000-000......................................265 T1510322000-000...................................... 105 T1510322000-000.......................................159 T1510322000-000...................................... 180 T1510482000-000...................................... 109 T1510482000-000...................................... 164 T1519101000-000.......................................... 38 T1519101000-000.......................................... 38 T1519101000-000.......................................... 62 T1519101000-000.......................................... 62 T1519161000-000..........................................40 T1519161000-000.......................................... 65 T1519162000-000.........................................40 T1519162000-000......................................... 65 T1549030000-000...................................... 33 T1549030000-000...................................... 56 T1549030000-000.....................................185 T1610062116-000.......................................... 72 T1610062116-000..........................................121 T1610062120-000......................................... 72 T1610062120-000.........................................121 T1610062121-000........................................... 72 T1610062121-000...........................................121 T1610062125-000.......................................... 72 T1610062125-000..........................................121 T1610062216-000......................................... 72 T1610062216-000.........................................121 T1610062220-000........................................ 72 T1610062220-000........................................121 T1610062221-000.......................................... 72 T1610062221-000..........................................121 T1610062225-000......................................... 72 T1610062225-000.........................................121 T1610103116-000............................................ 79 T1610103116-000.......................................... 130 T1610103116-000...........................................241 T1610103120-000.......................................... 79 T1610103120-000........................................ 130 T1610103120-000.........................................241 T1610103121-000............................................ 79 T1610103121-000.......................................... 130 T1610103121-000...........................................241 T1610103125-000........................................... 79 Part Number Page T1610103125-000......................................... 130 T1610103125-000..........................................241 T1610103216-000........................................... 79 T1610103216-000......................................... 130 T1610103216-000..........................................241 T1610103220-000......................................... 79 T1610103220-000....................................... 130 T1610103220-000........................................241 T1610103221-000........................................... 79 T1610103221-000......................................... 130 T1610103221-000..........................................241 T1610103225-000.......................................... 79 T1610103225-000........................................ 130 T1610103225-000.........................................241 T1610163116-000............................................ 88 T1610163116-000.......................................... 140 T1610163116-000...........................................175 T1610163116-000..........................................255 T1610163120-000........................................... 88 T1610163120-000......................................... 140 T1610163120-000..........................................175 T1610163120-000.........................................255 T1610163121-000............................................ 88 T1610163121-000.......................................... 140 T1610163121-000...........................................175 T1610163121-000..........................................255 T1610163125-000........................................... 88 T1610163125-000......................................... 140 T1610163125-000..........................................175 T1610163125-000.........................................255 T1610163216-000........................................... 88 T1610163216-000......................................... 140 T1610163216-000..........................................175 T1610163216-000.........................................255 T1610163220-000.......................................... 88 T1610163220-000........................................ 140 T1610163220-000.........................................175 T1610163220-000........................................255 T1610163221-000........................................... 88 T1610163221-000......................................... 140 T1610163221-000..........................................175 T1610163221-000.........................................255 T1610163225-000.......................................... 88 T1610163225-000........................................ 140 T1610163225-000.........................................175 T1610163225-000........................................255 T1610243116-000........................................... 97 T1610243116-000......................................... 150 T1610243116-000.........................................265 T1610243120-000.......................................... 97 T1610243120-000........................................ 150 T1610243120-000........................................265 T1610243121-000........................................... 97 T1610243121-000......................................... 150 T1610243121-000.........................................265 T1610243125-000.......................................... 97 343 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T1610243125-000........................................ 150 T1610243125-000........................................265 T1610243216-000.......................................... 97 T1610243216-000........................................ 150 T1610243216-000........................................265 T1610243220-000......................................... 97 T1610243220-000....................................... 150 T1610243220-000.......................................265 T1610243221-000.......................................... 97 T1610243221-000........................................ 150 T1610243221-000........................................265 T1610243225-000......................................... 97 T1610243225-000....................................... 150 T1610243225-000.......................................265 T1610322129-000........................................ 105 T1610322129-000.........................................159 T1610322129-000........................................ 180 T1610322132-000........................................ 105 T1610322132-000.........................................159 T1610322132-000........................................ 180 T1610322140-000........................................ 105 T1610322140-000.........................................159 T1610322140-000........................................ 180 T1610322229-000....................................... 105 T1610322229-000........................................159 T1610322229-000....................................... 180 T1610322232-000....................................... 105 T1610322232-000........................................159 T1610322232-000....................................... 180 T1610322240-000....................................... 105 T1610322240-000........................................159 T1610322240-000....................................... 180 T1610482129-000........................................ 109 T1610482129-000........................................ 164 T1610482132-000........................................ 109 T1610482132-000........................................ 164 T1610482136-000........................................ 109 T1610482136-000........................................ 164 T1610482140-000....................................... 109 T1610482140-000....................................... 164 T1610482142-000........................................ 109 T1610482142-000........................................ 164 T1610482150-000....................................... 109 T1610482150-000....................................... 164 T1610482229-000....................................... 109 T1610482229-000....................................... 164 T1610482232-000....................................... 109 T1610482232-000....................................... 164 T1610482236-000....................................... 109 T1610482236-000....................................... 164 T1610482240-000...................................... 109 T1610482240-000...................................... 164 T1610482242-000....................................... 109 T1610482242-000....................................... 164 T1610482250-000...................................... 109 T1610482250-000...................................... 164 Part Number Page T1619030111-000............................................ 33 T1619030111-000............................................ 56 T1619030111-000...........................................185 T1619030116-000.......................................... 33 T1619030116-000.......................................... 56 T1619030116-000.........................................185 T1619030120-000......................................... 33 T1619030120-000......................................... 56 T1619030120-000........................................185 T1619031111-000............................................. 34 T1619031116-000............................................ 34 T1619031120-000........................................... 34 T1619031111-000............................................. 34 T1619031116-000............................................ 34 T1619031120-000........................................... 57 T1619031111-000............................................. 57 T1619031116-000............................................ 57 T1619031120-000..........................................186 T1619101116-000............................................. 38 T1619101116-000............................................. 62 T1619101120-000............................................ 38 T1619101120-000............................................ 62 T1619101121-000............................................. 38 T1619101121-000............................................. 62 T1619101125-000............................................ 38 T1619101125-000............................................ 62 T1619101216-000............................................ 38 T1619101216-000............................................ 62 T1619101220-000........................................... 38 T1619101220-000........................................... 62 T1619101221-000............................................ 38 T1619101221-000............................................ 62 T1619101225-000........................................... 38 T1619101225-000........................................... 62 T1619161116-000.............................................40 T1619161116-000............................................. 65 T1619161120-000............................................40 T1619161120-000............................................ 65 T1619161121-000.............................................40 T1619161121-000............................................. 65 T1619161125-000............................................40 T1619161125-000............................................ 65 T1619161216-000............................................40 T1619161216-000............................................ 65 T1619161220-000...........................................40 T1619161220-000........................................... 65 T1619161221-000............................................40 T1619161221-000............................................ 65 T1619161225-000...........................................40 T1619161225-000........................................... 65 T1620062116-000......................................... 72 T1620062116-000.........................................121 T1620062120-000........................................ 72 T1620062120-000........................................121 T1620062121-000.......................................... 72 T1620062121-000..........................................121 344 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T1620062125-000......................................... 72 T1620062125-000.........................................121 T1620062216-000........................................ 72 T1620062216-000........................................121 T1620062220-000....................................... 72 T1620062220-000.......................................121 T1620062221-000......................................... 72 T1620062221-000.........................................121 T1620062225-000........................................ 72 T1620062225-000........................................121 T1620103116-000........................................... 79 T1620103116-000......................................... 130 T1620103116-000..........................................241 T1620103120-000......................................... 79 T1620103120-000....................................... 130 T1620103120-000........................................241 T1620103121-000........................................... 79 T1620103121-000......................................... 130 T1620103121-000..........................................241 T1620103125-000.......................................... 79 T1620103125-000........................................ 130 T1620103125-000.........................................241 T1620103216-000.......................................... 79 T1620103216-000........................................ 130 T1620103216-000.........................................241 T1620103220-000........................................ 79 T1620103220-000...................................... 130 T1620103220-000.......................................241 T1620103221-000.......................................... 79 T1620103221-000........................................ 130 T1620103221-000.........................................241 T1620103225-000......................................... 79 T1620103225-000....................................... 130 T1620103225-000........................................241 T1620163116-000........................................... 88 T1620163116-000......................................... 140 T1620163116-000..........................................175 T1620163116-000.........................................255 T1620163120-000.......................................... 88 T1620163120-000........................................ 140 T1620163120-000.........................................175 T1620163120-000........................................255 T1620163121-000........................................... 88 T1620163121-000......................................... 140 T1620163121-000..........................................175 T1620163121-000.........................................255 T1620163125-000.......................................... 88 T1620163125-000........................................ 140 T1620163125-000.........................................175 T1620163125-000........................................255 T1620163216-000.......................................... 88 T1620163216-000........................................ 140 T1620163216-000.........................................175 T1620163216-000........................................255 T1620163220-000......................................... 88 T1620163220-000....................................... 140 Part Number Page T1620163220-000........................................175 T1620163220-000.......................................255 T1620163221-000.......................................... 88 T1620163221-000........................................ 140 T1620163221-000.........................................175 T1620163221-000........................................255 T1620163225-000......................................... 88 T1620163225-000....................................... 140 T1620163225-000........................................175 T1620163225-000.......................................255 T1620243116-000.......................................... 97 T1620243116-000........................................ 150 T1620243116-000........................................265 T1620243120-000......................................... 97 T1620243120-000....................................... 150 T1620243120-000.......................................265 T1620243121-000.......................................... 97 T1620243121-000........................................ 150 T1620243121-000........................................265 T1620243125-000......................................... 97 T1620243125-000....................................... 150 T1620243125-000.......................................265 T1620243216-000......................................... 97 T1620243216-000....................................... 150 T1620243216-000.......................................265 T1620243220-000........................................ 97 T1620243220-000...................................... 150 T1620243220-000......................................265 T1620243221-000......................................... 97 T1620243221-000....................................... 150 T1620243221-000.......................................265 T1620243225-000........................................ 97 T1620243225-000...................................... 150 T1620243225-000......................................265 T1620320129-000....................................... 105 T1620320129-000........................................159 T1620320129-000....................................... 180 T1620320132-000....................................... 105 T1620320132-000........................................159 T1620320132-000....................................... 180 T1620320140-000...................................... 105 T1620320140-000.......................................159 T1620320140-000...................................... 180 T1620320229-000...................................... 105 T1620320229-000.......................................159 T1620320229-000...................................... 180 T1620320232-000...................................... 105 T1620320232-000.......................................159 T1620320232-000...................................... 180 T1620320240-000..................................... 105 T1620320240-000......................................159 T1620320240-000..................................... 180 T1620480129-000...................................... 109 T1620480129-000...................................... 164 T1620480132-000...................................... 109 T1620480132-000...................................... 164 Part Number Page T1620480136-000...................................... 109 T1620480136-000...................................... 164 T1620480140-000...................................... 109 T1620480140-000...................................... 164 T1620480142-000...................................... 109 T1620480142-000...................................... 164 T1620480150-000...................................... 109 T1620480150-000...................................... 164 T1620480229-000..................................... 109 T1620480229-000..................................... 164 T1620480232-000..................................... 109 T1620480232-000..................................... 164 T1620480236-000..................................... 109 T1620480236-000..................................... 164 T1620480240-000..................................... 109 T1620480240-000..................................... 164 T1620480242-000..................................... 109 T1620480242-000..................................... 164 T1620480250-000..................................... 109 T1620480250-000..................................... 164 T1629101116-000............................................ 38 T1629101116-000............................................ 62 T1629101120-000........................................... 38 T1629101120-000........................................... 62 T1629101121-000............................................ 38 T1629101121-000............................................ 62 T1629101125-000........................................... 38 T1629101125-000........................................... 62 T1629101216-000........................................... 38 T1629101216-000........................................... 62 T1629101220-000.......................................... 38 T1629101220-000.......................................... 62 T1629101221-000........................................... 38 T1629101221-000........................................... 62 T1629101225-000.......................................... 38 T1629101225-000.......................................... 62 T1629161116-000............................................40 T1629161116-000............................................ 65 T1629161120-000...........................................40 T1629161120-000........................................... 65 T1629161121-000............................................40 T1629161121-000............................................ 65 T1629161125-000...........................................40 T1629161125-000........................................... 65 T1629161216-000...........................................40 T1629161216-000........................................... 65 T1629161220-000..........................................40 T1629161220-000.......................................... 65 T1629161221-000...........................................40 T1629161221-000........................................... 65 T1629161225-000..........................................40 T1629161225-000.......................................... 65 T1650062121-000.......................................... 72 T1650062121-000..........................................121 T1650062125-000......................................... 72 T1650062125-000.........................................121 Part Number Page T1650062129-000........................................ 72 T1650062129-000........................................121 T1650062132-000......................................... 72 T1650062132-000.........................................121 T1650062221-000......................................... 72 T1650062221-000.........................................121 T1650062225-000........................................ 72 T1650062225-000........................................121 T1650062229-000....................................... 72 T1650062229-000.......................................121 T1650062232-000........................................ 72 T1650062232-000........................................121 T1650103121-000........................................... 79 T1650103121-000......................................... 130 T1650103121-000..........................................241 T1650103125-000.......................................... 79 T1650103125-000........................................ 130 T1650103125-000.........................................241 T1650103129-000.......................................... 79 T1650103129-000........................................ 130 T1650103129-000.........................................241 T1650103132-000.......................................... 79 T1650103132-000........................................ 130 T1650103132-000.........................................241 T1650103221-000.......................................... 79 T1650103221-000........................................ 130 T1650103221-000.........................................241 T1650103225-000......................................... 79 T1650103225-000....................................... 130 T1650103225-000........................................241 T1650103229-000......................................... 79 T1650103229-000....................................... 130 T1650103229-000........................................241 T1650103232-000......................................... 79 T1650103232-000....................................... 130 T1650103232-000........................................241 T1650163121-000........................................... 88 T1650163121-000......................................... 140 T1650163121-000..........................................175 T1650163121-000.........................................255 T1650163125-000.......................................... 88 T1650163125-000........................................ 140 T1650163125-000.........................................175 T1650163125-000........................................255 T1650163129-000.......................................... 88 T1650163129-000........................................ 140 T1650163129-000.........................................175 T1650163129-000........................................255 T1650163132-000.......................................... 88 T1650163132-000........................................ 140 T1650163132-000.........................................175 T1650163132-000........................................255 T1650163221-000.......................................... 88 T1650163221-000........................................ 140 T1650163221-000.........................................175 T1650163221-000........................................255 345 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T1650163225-000......................................... 88 T1650163225-000....................................... 140 T1650163225-000........................................175 T1650163225-000.......................................255 T1650163229-000......................................... 88 T1650163229-000....................................... 140 T1650163229-000........................................175 T1650163229-000.......................................255 T1650163232-000......................................... 88 T1650163232-000....................................... 140 T1650163232-000........................................175 T1650163232-000.......................................255 T1650243121-000.......................................... 97 T1650243121-000........................................ 150 T1650243121-000........................................265 T1650243125-000......................................... 97 T1650243125-000....................................... 150 T1650243125-000.......................................265 T1650243129-000......................................... 97 T1650243129-000....................................... 150 T1650243129-000.......................................265 T1650243132-000......................................... 97 T1650243132-000....................................... 150 T1650243132-000.......................................265 T1650243221-000......................................... 97 T1650243221-000....................................... 150 T1650243221-000.......................................265 T1650243225-000........................................ 97 T1650243225-000...................................... 150 T1650243225-000......................................265 T1650243229-000........................................ 97 T1650243229-000...................................... 150 T1650243229-000......................................265 T1650243232-000........................................ 97 T1650243232-000...................................... 150 T1650243232-000......................................265 T1660062121-000......................................... 72 T1660062121-000.........................................121 T1660062125-000........................................ 72 T1660062125-000........................................121 T1660062129-000........................................ 72 T1660062129-000........................................121 T1660062132-000........................................ 72 T1660062132-000........................................121 T1660062221-000........................................ 72 T1660062221-000........................................121 T1660062225-000....................................... 72 T1660062225-000.......................................121 T1660062229-000....................................... 72 T1660062229-000.......................................121 T1660062232-000....................................... 72 T1660062232-000.......................................121 T1660103121-000........................................... 79 T1660103121-000......................................... 130 T1660103121-000..........................................241 T1660103125-000.......................................... 79 Part Number Page T1660103125-000........................................ 130 T1660103125-000.........................................241 T1660103129-000......................................... 79 T1660103129-000....................................... 130 T1660103129-000........................................241 T1660103132-000.......................................... 79 T1660103132-000........................................ 130 T1660103132-000.........................................241 T1660103221-000.......................................... 79 T1660103221-000........................................ 130 T1660103221-000.........................................241 T1660103225-000......................................... 79 T1660103225-000....................................... 130 T1660103225-000........................................241 T1660103229-000........................................ 79 T1660103229-000...................................... 130 T1660103229-000.......................................241 T1660103232-000......................................... 79 T1660103232-000....................................... 130 T1660103232-000........................................241 T1660163121-000........................................... 88 T1660163121-000......................................... 140 T1660163121-000..........................................175 T1660163121-000.........................................255 T1660163125-000.......................................... 88 T1660163125-000........................................ 140 T1660163125-000.........................................175 T1660163125-000........................................255 T1660163129-000.......................................... 88 T1660163129-000........................................ 140 T1660163129-000.........................................175 T1660163129-000........................................255 T1660163132-000.......................................... 88 T1660163132-000........................................ 140 T1660163132-000.........................................175 T1660163132-000........................................255 T1660163221-000.......................................... 88 T1660163221-000........................................ 140 T1660163221-000.........................................175 T1660163221-000........................................255 T1660163225-000......................................... 88 T1660163225-000....................................... 140 T1660163225-000........................................175 T1660163225-000.......................................255 T1660163229-000......................................... 88 T1660163229-000....................................... 140 T1660163229-000........................................175 T1660163229-000.......................................255 T1660163232-000......................................... 88 T1660163232-000....................................... 140 T1660163232-000........................................175 T1660163232-000.......................................255 T1660243121-000.......................................... 97 T1660243121-000........................................ 150 T1660243121-000........................................265 T1660243125-000......................................... 97 346 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T1660243125-000....................................... 150 T1660243125-000.......................................265 T1660243129-000......................................... 97 T1660243129-000....................................... 150 T1660243129-000.......................................265 T1660243132-000......................................... 97 T1660243132-000....................................... 150 T1660243132-000.......................................265 T1660243221-000......................................... 97 T1660243221-000....................................... 150 T1660243221-000.......................................265 T1660243225-000........................................ 97 T1660243225-000...................................... 150 T1660243225-000......................................265 T1660243229-000........................................ 97 T1660243229-000...................................... 150 T1660243229-000......................................265 T1660243232-000........................................ 97 T1660243232-000...................................... 150 T1660243232-000......................................265 T1710101116-000............................................. 76 T1710101116-000............................................127 T1710101116-000...........................................238 T1710101120-000........................................... 76 T1710101120-000..........................................127 T1710101120-000.........................................238 T1710101125-000............................................ 76 T1710101125-000...........................................127 T1710101125-000..........................................238 T1710161121-000............................................. 85 T1710161121-000............................................137 T1710161121-000............................................172 T1710161121-000...........................................252 T1710161125-000............................................ 85 T1710161125-000...........................................137 T1710161125-000...........................................172 T1710161125-000..........................................252 T1710161132-000............................................ 85 T1710161132-000...........................................137 T1710161132-000...........................................172 T1710161132-000..........................................252 T1710241121-000............................................94 T1710241121-000...........................................147 T1710241121-000..........................................262 T1710241125-000...........................................94 T1710241125-000..........................................147 T1710241125-000.........................................262 T1710241132-000...........................................94 T1710241132-000..........................................147 T1710241132-000.........................................262 T1710322129-000........................................ 104 T1710322129-000.........................................158 T1710322129-000.........................................179 T1710322132-000........................................ 104 T1710322132-000.........................................158 T1710322132-000.........................................179 Part Number Page T1710322136-000........................................ 104 T1710322136-000.........................................158 T1710322136-000.........................................179 T1710322140-000........................................ 104 T1710322140-000.........................................158 T1710322140-000.........................................179 T1710322142-000........................................ 104 T1710322142-000.........................................158 T1710322142-000.........................................179 T1710322150-000........................................ 104 T1710322150-000.........................................158 T1710322150-000.........................................179 T1710322163-000........................................ 104 T1710322163-000.........................................158 T1710322163-000.........................................179 T1730062116-000........................................... 71 T1730062116-000........................................ 120 T1730062120-000......................................... 71 T1730062120-000...................................... 120 T1730062125-000.......................................... 71 T1730062125-000....................................... 120 T1730103116-000........................................... 78 T1730103116-000..........................................129 T1730103116-000........................................ 240 T1730103120-000.......................................... 78 T1730103120-000.........................................129 T1730103120-000....................................... 240 T1730103125-000.......................................... 78 T1730103125-000.........................................129 T1730103125-000....................................... 240 T1730163121-000........................................... 87 T1730163121-000..........................................139 T1730163121-000..........................................174 T1730163121-000.........................................254 T1730163125-000.......................................... 87 T1730163125-000.........................................139 T1730163125-000.........................................174 T1730163125-000........................................254 T1730163129-000.......................................... 87 T1730163129-000.........................................139 T1730163129-000.........................................174 T1730163129-000........................................254 T1730163132-000.......................................... 87 T1730163132-000.........................................139 T1730163132-000.........................................174 T1730163132-000........................................254 T1730242121-000..........................................96 T1730242121-000........................................ 149 T1730242121-000....................................... 264 T1730242125-000.........................................96 T1730242125-000....................................... 149 T1730242125-000...................................... 264 T1730242129-000.........................................96 T1730242129-000....................................... 149 T1730242129-000...................................... 264 T1730242132-000.........................................96 Part Number Page T1730242132-000....................................... 149 T1730242132-000...................................... 264 T1739030111-000........................................... 33 T1739030111-000........................................... 56 T1739030111-000..........................................185 T1739030120-000........................................ 33 T1739030120-000........................................ 56 T1739030120-000.......................................185 T1739031111-000............................................ 34 T1739031120-000.......................................... 34 T1739031111-000............................................ 57 T1739031120-000.......................................... 57 T1739031111-000...........................................186 T1739031120-000.........................................186 T1739101116-000............................................ 38 T1739101116-000............................................ 62 T1739101120-000........................................... 38 T1739101120-000........................................... 62 T1739101125-000........................................... 38 T1739101125-000........................................... 62 T1739161116-000............................................40 T1739161116-000............................................ 65 T1739161120-000...........................................40 T1739161120-000........................................... 65 T1739161125-000............................................40 T1739161125-000............................................ 65 T1750101121-000............................................ 76 T1750101121-000...........................................127 T1750101121-000..........................................238 T1750101125-000........................................... 76 T1750101125-000..........................................127 T1750101125-000.........................................238 T1750101129-000........................................... 76 T1750101129-000..........................................127 T1750101129-000.........................................238 T1750101132-000........................................... 76 T1750101132-000..........................................127 T1750101132-000.........................................238 T1750161121-000............................................ 85 T1750161121-000...........................................137 T1750161121-000...........................................172 T1750161121-000..........................................252 T1750161125-000........................................... 85 T1750161125-000..........................................137 T1750161125-000..........................................172 T1750161125-000.........................................252 T1750161129-000........................................... 85 T1750161129-000..........................................137 T1750161129-000..........................................172 T1750161129-000.........................................252 T1750161132-000........................................... 85 T1750161132-000..........................................137 T1750161132-000..........................................172 T1750161132-000.........................................252 T1750161140-000........................................... 85 T1750161140-000..........................................137 Part Number Page T1750161140-000..........................................172 T1750161140-000.........................................252 T1750241121-000...........................................94 T1750241121-000..........................................147 T1750241121-000.........................................262 T1750241125-000..........................................94 T1750241125-000.........................................147 T1750241125-000........................................262 T1750241129-000..........................................94 T1750241129-000.........................................147 T1750241129-000........................................262 T1750241132-000..........................................94 T1750241132-000.........................................147 T1750241132-000........................................262 T1750241140-000..........................................94 T1750241140-000.........................................147 T1750241140-000........................................262 T1770062120-000......................................... 71 T1770062120-000...................................... 120 T1770062121-000........................................... 71 T1770062121-000........................................ 120 T1770062125-000.......................................... 71 T1770062125-000....................................... 120 T1770062129-000.......................................... 71 T1770062129-000....................................... 120 T1770062132-000.......................................... 71 T1770062132-000....................................... 120 T1770103121-000........................................... 78 T1770103121-000..........................................129 T1770103121-000........................................ 240 T1770103125-000.......................................... 78 T1770103125-000.........................................129 T1770103125-000....................................... 240 T1770103129-000.......................................... 78 T1770103129-000.........................................129 T1770103129-000....................................... 240 T1770103132-000.......................................... 78 T1770103132-000.........................................129 T1770103132-000....................................... 240 T1770163121-000........................................... 87 T1770163121-000..........................................139 T1770163121-000..........................................174 T1770163121-000.........................................254 T1770163125-000.......................................... 87 T1770163125-000.........................................139 T1770163125-000.........................................174 T1770163125-000........................................254 T1770163129-000.......................................... 87 T1770163129-000.........................................139 T1770163129-000.........................................174 T1770163129-000........................................254 T1770163132-000.......................................... 87 T1770163132-000.........................................139 T1770163132-000.........................................174 T1770163132-000........................................254 T1770163140-000.......................................... 87 347 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T1770163140-000.........................................139 T1770163140-000.........................................174 T1770163140-000........................................254 T1770243121-000..........................................96 T1770243121-000........................................ 149 T1770243121-000....................................... 264 T1770243125-000.........................................96 T1770243125-000....................................... 149 T1770243125-000...................................... 264 T1770243129-000.........................................96 T1770243129-000....................................... 149 T1770243129-000...................................... 264 T1770243132-000.........................................96 T1770243132-000....................................... 149 T1770243132-000...................................... 264 T1770243140-000.........................................96 T1770243140-000....................................... 149 T1770243140-000...................................... 264 T1779101121-000............................................ 38 T1779101121-000............................................ 62 T1779101125-000........................................... 38 T1779101125-000........................................... 62 T1779161121-000.............................................40 T1779161121-000............................................. 65 T1779161125-000............................................40 T1779161125-000............................................ 65 T1812242121-000..........................................279 T1812242125-000.........................................279 T1812242132-000.........................................279 T1822242121-000.........................................279 T1822242125-000........................................279 T1822242129-000.......................................279 T1822242132-000........................................279 T1822242140-000.......................................279 T1852242121-000.........................................279 T1852242125-000........................................279 T1852242221-000........................................279 T1852242225-000.......................................279 T1870002201-000..................................... 306 T1870002201-000..................................... 306 T1870002201-000..................................... 306 T1870002201-000..................................... 306 T1870062101-000...................................... 306 T1870102101-000........................................ 306 T1870162101-000........................................ 306 T1870242101-000....................................... 306 T1910060116-000........................................297 T1910060120-000.......................................297 T1910060121-000........................................297 T1910060125-000.......................................297 T1910060129-000.......................................297 T1910060132-000.......................................297 T1910100116-000.........................................297 T1910100120-000........................................297 T1910100121-000.........................................297 T1910100125-000........................................297 Part Number Page T1910100129-000........................................297 T1910100132-000........................................297 T1910160116-000.........................................297 T1910160121-000..........................................297 T1910160125-000.........................................297 T1910160129-000........................................297 T1910160132-000.........................................297 T1910160140-000........................................297 T1910240116-000........................................297 T1910240121-000.........................................297 T1910240125-000........................................297 T1910240129-000.......................................297 T1910240132-000........................................297 T1910240140-000.......................................297 T1912061121-000......................................... 299 T1912061125-000........................................ 299 T1912101121-000.......................................... 299 T1912101125-000......................................... 299 T1912101129-000......................................... 299 T1912101132-000......................................... 299 T1912161121-000........................................... 299 T1912161125-000.......................................... 299 T1912161129-000......................................... 299 T1912161132-000.......................................... 299 T1912161140-000......................................... 299 T1912241121-000.......................................... 299 T1912241125-000......................................... 299 T1912241129-000........................................ 299 T1912241132-000......................................... 299 T1912241136-000........................................ 299 T1912241140-000........................................ 299 T1920030116-000.......................................278 T1920030120-000......................................278 T1920060116-000.......................................297 T1920060120-000......................................297 T1920060121-000.......................................297 T1920060125-000......................................297 T1920060129-000......................................297 T1920060132-000......................................297 T1920100116-000........................................297 T1920100120-000.......................................297 T1920100121-000........................................297 T1920100125-000.......................................297 T1920100129-000.......................................297 T1920100132-000.......................................297 T1920160116-000........................................297 T1920160121-000.........................................297 T1920160125-000........................................297 T1920160129-000.......................................297 T1920160132-000........................................297 T1920160140-000.......................................297 T1920240116-000........................................297 T1920240121-000........................................297 T1920240125-000.......................................297 T1920240129-000.......................................297 T1920240132-000.......................................297 348 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T1920240140-000......................................297 T1922061121-000........................................ 299 T1922061125-000....................................... 299 T1922061129-000....................................... 299 T1922061132-000....................................... 299 T1922061136-000....................................... 299 T1922061140-000...................................... 299 T1922101121-000......................................... 299 T1922101125-000........................................ 299 T1922101129-000........................................ 299 T1922101132-000........................................ 299 T1922101136-000........................................ 299 T1922101140-000........................................ 299 T1922161121-000.......................................... 299 T1922161125-000......................................... 299 T1922161129-000........................................ 299 T1922161132-000......................................... 299 T1922161136-000........................................ 299 T1922161140-000........................................ 299 T1922241121-000......................................... 299 T1922241125-000........................................ 299 T1922241129-000....................................... 299 T1922241132-000........................................ 299 T1922241136-000....................................... 299 T1922241140-000....................................... 299 T1930030000-000....................................278 T1930060000-000....................................298 T1930100000-000.....................................298 T1930160000-000.....................................298 T1930240000-000....................................298 T1932061000-000..................................... 299 T1932101000-000...................................... 299 T1932161000-000...................................... 299 T1932241000-000..................................... 299 T1946030000-000....................................278 T1946031000-000.....................................278 T1946032000-000....................................278 T1950100121-000........................................298 T1950100125-000.......................................298 T1950100129-000.......................................298 T1950100132-000.......................................298 T1990060000-000....................................298 T1990100000-000.....................................298 T1990160000-000.....................................298 T1990240000-000....................................298 T1990240000-000................................... 299 T1990240001-000......................................298 T1912063800-000......................................326 T1912064800-000......................................326 T1912065200-000......................................326 T1912065600-000......................................326 T1912066000-000.....................................326 T1918121400-000........................................326 T1918121800-000.........................................326 T1922182200-000.......................................326 T1926222600-000.....................................326 Part Number Page T1932263200-000......................................326 T1934303400-000.....................................326 T1942384200-000.....................................326 T1964566400-000.....................................326 T1970667000-000.....................................326 T2010032101-000......................................... 29 T2010032201-000........................................ 29 T2010033101-000......................................... 29 T2010033201-000........................................ 29 T2010042101-000......................................... 29 T2010042201-000........................................ 29 T2010043101-000......................................... 29 T2010043201-000........................................ 29 T2010102101-000.......................................... 37 T2010102201-000......................................... 37 T2010162101-000.......................................... 39 T2010162101-000........................................... 41 T2010162201-000......................................... 39 T2010162201-000.......................................... 41 T2010164101-000.......................................... 39 T2010164101-000.......................................... 39 T2010324101-000.......................................... 41 T2010164201-000......................................... 39 T2010164201-000.......................................... 41 T2010322101-000........................................... 41 T2010322201-000.......................................... 41 T2010324201-000......................................... 41 T2019092101-000........................................189 T2019092201-000.......................................189 T2020001002-000...................................... 27 T2020001005-000...................................... 27 T2020001008-000...................................... 27 T2020001010-000....................................... 27 T2020001015-000........................................ 27 T2020001025-000....................................... 27 T2020001002-000....................................... 31 T2020001005-000....................................... 31 T2020001008-000....................................... 31 T2020001010-000........................................ 31 T2020001015-000......................................... 31 T2020001025-000........................................ 31 T2020001002-000......................................48 T2020001005-000......................................48 T2020001008-000......................................48 T2020001010-000.......................................48 T2020001015-000........................................48 T2020001025-000.......................................48 T2020001002-000...................................... 55 T2020001005-000...................................... 55 T2020001008-000...................................... 55 T2020001010-000....................................... 55 T2020001015-000........................................ 55 T2020001025-000....................................... 55 T2020001002-000......................................60 T2020001005-000......................................60 T2020001008-000......................................60 Part Number Page T2020001010-000.......................................60 T2020001015-000........................................60 T2020001025-000.......................................60 T2020001002-000...................................... 63 T2020001005-000...................................... 63 T2020001008-000...................................... 63 T2020001010-000....................................... 63 T2020001015-000........................................ 63 T2020001025-000....................................... 63 T2020001002-000......................................66 T2020001005-000......................................66 T2020001008-000......................................66 T2020001010-000.......................................66 T2020001015-000........................................66 T2020001025-000.......................................66 T2020001002-000...................................... 69 T2020001005-000...................................... 69 T2020001008-000...................................... 69 T2020001010-000....................................... 69 T2020001015-000........................................ 69 T2020001025-000....................................... 69 T2020001002-000...................................... 74 T2020001005-000...................................... 74 T2020001008-000...................................... 74 T2020001010-000....................................... 74 T2020001015-000........................................ 74 T2020001025-000....................................... 74 T2020001002-000...................................... 82 T2020001005-000...................................... 82 T2020001008-000...................................... 82 T2020001010-000....................................... 82 T2020001015-000........................................ 82 T2020001025-000....................................... 82 T2020001002-000......................................84 T2020001005-000......................................84 T2020001008-000......................................84 T2020001010-000.......................................84 T2020001015-000........................................84 T2020001025-000.......................................84 T2020001002-000....................................... 91 T2020001005-000....................................... 91 T2020001008-000....................................... 91 T2020001010-000........................................ 91 T2020001015-000......................................... 91 T2020001025-000........................................ 91 T2020001002-000...................................... 93 T2020001005-000...................................... 93 T2020001008-000...................................... 93 T2020001010-000....................................... 93 T2020001015-000........................................ 93 T2020001025-000....................................... 93 T2020001002-000..................................... 101 T2020001005-000..................................... 101 T2020001008-000..................................... 101 T2020001010-000...................................... 101 T2020001015-000....................................... 101 Part Number Page T2020001025-000...................................... 101 T2020001002-000.................................... 103 T2020001005-000.................................... 103 T2020001008-000.................................... 103 T2020001010-000..................................... 103 T2020001015-000...................................... 103 T2020001025-000..................................... 103 T2020001002-000.................................... 106 T2020001005-000.................................... 106 T2020001008-000.................................... 106 T2020001010-000..................................... 106 T2020001015-000...................................... 106 T2020001025-000..................................... 106 T2020001002-000.................................... 108 T2020001005-000.................................... 108 T2020001008-000.................................... 108 T2020001010-000..................................... 108 T2020001015-000...................................... 108 T2020001025-000..................................... 108 T2020001002-000..................................... 110 T2020001005-000..................................... 110 T2020001008-000..................................... 110 T2020001010-000...................................... 110 T2020001015-000....................................... 110 T2020001025-000...................................... 110 T2020001002-000.................................... 184 T2020001005-000.................................... 184 T2020001008-000.................................... 184 T2020001010-000..................................... 184 T2020001015-000...................................... 184 T2020001025-000..................................... 184 T2020001002-000.................................... 190 T2020001005-000.................................... 190 T2020001008-000.................................... 190 T2020001010-000..................................... 190 T2020001015-000...................................... 190 T2020001025-000..................................... 190 T2020001002-000.....................................221 T2020001005-000.....................................221 T2020001008-000.....................................221 T2020001010-000......................................221 T2020001015-000.......................................221 T2020001025-000......................................221 T2020001002-000....................................223 T2020001005-000....................................223 T2020001008-000....................................223 T2020001010-000.....................................223 T2020001015-000......................................223 T2020001025-000.....................................223 T2020001002-000....................................237 T2020001005-000....................................237 T2020001008-000....................................237 T2020001010-000.....................................237 T2020001015-000......................................237 T2020001025-000.....................................237 T2020001002-000....................................249 349 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T2020001005-000....................................249 T2020001008-000....................................249 T2020001010-000.....................................249 T2020001015-000......................................249 T2020001025-000.....................................249 T2020001002-000.....................................251 T2020001005-000.....................................251 T2020001008-000.....................................251 T2020001010-000......................................251 T2020001015-000.......................................251 T2020001025-000......................................251 T2020001002-000................................... 303 T2020001005-000................................... 303 T2020001008-000................................... 303 T2020001010-000.................................... 303 T2020001015-000..................................... 303 T2020001025-000.................................... 303 T2020002002-000..................................... 27 T2020002005-000..................................... 27 T2020002008-000..................................... 27 T2020002010-000...................................... 27 T2020002015-000....................................... 27 T2020002025-000...................................... 27 T2020002002-000...................................... 31 T2020002005-000...................................... 31 T2020002008-000...................................... 31 T2020002010-000....................................... 31 T2020002015-000........................................ 31 T2020002025-000....................................... 31 T2020002002-000.....................................48 T2020002005-000.....................................48 T2020002008-000.....................................48 T2020002010-000......................................48 T2020002015-000.......................................48 T2020002025-000......................................48 T2020002002-000..................................... 55 T2020002005-000..................................... 55 T2020002008-000..................................... 55 T2020002010-000...................................... 55 T2020002015-000....................................... 55 T2020002025-000...................................... 55 T2020002002-000.....................................60 T2020002005-000.....................................60 T2020002008-000.....................................60 T2020002010-000......................................60 T2020002015-000.......................................60 T2020002025-000......................................60 T2020002002-000..................................... 63 T2020002005-000..................................... 63 T2020002008-000..................................... 63 T2020002010-000...................................... 63 T2020002015-000....................................... 63 T2020002025-000...................................... 63 T2020002002-000.....................................66 T2020002005-000.....................................66 T2020002008-000.....................................66 Part Number Page T2020002010-000......................................66 T2020002015-000.......................................66 T2020002025-000......................................66 T2020002002-000..................................... 69 T2020002005-000..................................... 69 T2020002008-000..................................... 69 T2020002010-000...................................... 69 T2020002015-000....................................... 69 T2020002025-000...................................... 69 T2020002002-000..................................... 74 T2020002005-000..................................... 74 T2020002008-000..................................... 74 T2020002010-000...................................... 74 T2020002015-000....................................... 74 T2020002025-000...................................... 74 T2020002002-000..................................... 82 T2020002005-000..................................... 82 T2020002008-000..................................... 82 T2020002010-000...................................... 82 T2020002015-000....................................... 82 T2020002025-000...................................... 82 T2020002002-000.....................................84 T2020002005-000.....................................84 T2020002008-000.....................................84 T2020002010-000......................................84 T2020002015-000.......................................84 T2020002025-000......................................84 T2020002002-000...................................... 91 T2020002005-000...................................... 91 T2020002008-000...................................... 91 T2020002010-000....................................... 91 T2020002015-000........................................ 91 T2020002025-000....................................... 91 T2020002002-000..................................... 93 T2020002005-000..................................... 93 T2020002008-000..................................... 93 T2020002010-000...................................... 93 T2020002015-000....................................... 93 T2020002025-000...................................... 93 T2020002002-000.................................... 101 T2020002005-000.................................... 101 T2020002008-000.................................... 101 T2020002010-000..................................... 101 T2020002015-000...................................... 101 T2020002025-000..................................... 101 T2020002002-000................................... 103 T2020002005-000................................... 103 T2020002008-000................................... 103 T2020002010-000.................................... 103 T2020002015-000..................................... 103 T2020002025-000.................................... 103 T2020002002-000................................... 106 T2020002005-000................................... 106 T2020002008-000................................... 106 T2020002010-000.................................... 106 T2020002015-000..................................... 106 350 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T2020002025-000.................................... 106 T2020002002-000................................... 108 T2020002005-000................................... 108 T2020002008-000................................... 108 T2020002010-000.................................... 108 T2020002015-000..................................... 108 T2020002025-000.................................... 108 T2020002002-000.................................... 110 T2020002005-000.................................... 110 T2020002008-000.................................... 110 T2020002010-000..................................... 110 T2020002015-000...................................... 110 T2020002025-000..................................... 110 T2020002002-000................................... 184 T2020002005-000................................... 184 T2020002008-000................................... 184 T2020002010-000.................................... 184 T2020002015-000..................................... 184 T2020002025-000.................................... 184 T2020002002-000................................... 190 T2020002005-000................................... 190 T2020002008-000................................... 190 T2020002010-000.................................... 190 T2020002015-000..................................... 190 T2020002025-000.................................... 190 T2020002002-000....................................221 T2020002005-000....................................221 T2020002008-000....................................221 T2020002010-000.....................................221 T2020002015-000......................................221 T2020002025-000.....................................221 T2020002002-000...................................223 T2020002005-000...................................223 T2020002008-000...................................223 T2020002010-000....................................223 T2020002015-000.....................................223 T2020002025-000....................................223 T2020002002-000...................................237 T2020002005-000...................................237 T2020002008-000...................................237 T2020002010-000....................................237 T2020002015-000.....................................237 T2020002025-000....................................237 T2020002002-000...................................249 T2020002005-000...................................249 T2020002008-000...................................249 T2020002010-000....................................249 T2020002015-000.....................................249 T2020002025-000....................................249 T2020002002-000....................................251 T2020002005-000....................................251 T2020002008-000....................................251 T2020002010-000.....................................251 T2020002015-000......................................251 T2020002025-000.....................................251 T2020002002-000.................................. 303 Part Number Page T2020002005-000.................................. 303 T2020002008-000.................................. 303 T2020002010-000................................... 303 T2020002015-000.................................... 303 T2020002025-000................................... 303 T2020011002-000........................................ 27 T2020011005-000........................................ 27 T2020011008-000........................................ 27 T2020011010-000......................................... 27 T2020011015-000......................................... 27 T2020011025-000........................................ 27 T2020011002-000......................................... 31 T2020011005-000......................................... 31 T2020011008-000......................................... 31 T2020011010-000.......................................... 31 T2020011015-000.......................................... 31 T2020011025-000......................................... 31 T2020011002-000........................................48 T2020011005-000........................................48 T2020011008-000........................................48 T2020011010-000.........................................48 T2020011015-000.........................................48 T2020011025-000........................................48 T2020011002-000........................................ 55 T2020011005-000........................................ 55 T2020011008-000........................................ 55 T2020011010-000......................................... 55 T2020011015-000......................................... 55 T2020011025-000........................................ 55 T2020011002-000........................................60 T2020011005-000........................................60 T2020011008-000........................................60 T2020011010-000.........................................60 T2020011015-000.........................................60 T2020011025-000........................................60 T2020011002-000........................................ 63 T2020011005-000........................................ 63 T2020011008-000........................................ 63 T2020011010-000......................................... 63 T2020011015-000......................................... 63 T2020011025-000........................................ 63 T2020011002-000........................................66 T2020011005-000........................................66 T2020011008-000........................................66 T2020011010-000.........................................66 T2020011015-000.........................................66 T2020011025-000........................................66 T2020011002-000........................................ 69 T2020011005-000........................................ 69 T2020011008-000........................................ 69 T2020011010-000......................................... 69 T2020011015-000......................................... 69 T2020011025-000........................................ 69 T2020011002-000........................................ 74 T2020011005-000........................................ 74 T2020011008-000........................................ 74 Part Number Page T2020011010-000......................................... 74 T2020011015-000......................................... 74 T2020011025-000........................................ 74 T2020011002-000........................................ 82 T2020011005-000........................................ 82 T2020011008-000........................................ 82 T2020011010-000......................................... 82 T2020011015-000......................................... 82 T2020011025-000........................................ 82 T2020011002-000........................................84 T2020011005-000........................................84 T2020011008-000........................................84 T2020011010-000.........................................84 T2020011015-000.........................................84 T2020011025-000........................................84 T2020011002-000......................................... 91 T2020011005-000......................................... 91 T2020011008-000......................................... 91 T2020011010-000.......................................... 91 T2020011015-000.......................................... 91 T2020011025-000......................................... 91 T2020011002-000........................................ 93 T2020011005-000........................................ 93 T2020011008-000........................................ 93 T2020011010-000......................................... 93 T2020011015-000......................................... 93 T2020011025-000........................................ 93 T2020011002-000....................................... 101 T2020011005-000....................................... 101 T2020011008-000....................................... 101 T2020011010-000........................................ 101 T2020011015-000........................................ 101 T2020011025-000....................................... 101 T2020011002-000...................................... 103 T2020011005-000...................................... 103 T2020011008-000...................................... 103 T2020011010-000....................................... 103 T2020011015-000....................................... 103 T2020011025-000...................................... 103 T2020011002-000...................................... 106 T2020011005-000...................................... 106 T2020011008-000...................................... 106 T2020011010-000....................................... 106 T2020011015-000....................................... 106 T2020011025-000...................................... 106 T2020011002-000...................................... 108 T2020011005-000...................................... 108 T2020011008-000...................................... 108 T2020011010-000....................................... 108 T2020011015-000....................................... 108 T2020011025-000...................................... 108 T2020011002-000....................................... 110 T2020011005-000....................................... 110 T2020011008-000....................................... 110 T2020011010-000........................................ 110 T2020011015-000........................................ 110 Part Number Page T2020011025-000....................................... 110 T2020011002-000...................................... 184 T2020011005-000...................................... 184 T2020011008-000...................................... 184 T2020011010-000....................................... 184 T2020011015-000....................................... 184 T2020011025-000...................................... 184 T2020011002-000...................................... 190 T2020011005-000...................................... 190 T2020011008-000...................................... 190 T2020011010-000....................................... 190 T2020011015-000....................................... 190 T2020011025-000...................................... 190 T2020011002-000.......................................221 T2020011005-000.......................................221 T2020011008-000.......................................221 T2020011010-000........................................221 T2020011015-000........................................221 T2020011025-000.......................................221 T2020011002-000......................................223 T2020011005-000......................................223 T2020011008-000......................................223 T2020011010-000.......................................223 T2020011015-000.......................................223 T2020011025-000......................................223 T2020011002-000......................................237 T2020011005-000......................................237 T2020011008-000......................................237 T2020011010-000.......................................237 T2020011015-000.......................................237 T2020011025-000......................................237 T2020011002-000......................................249 T2020011005-000......................................249 T2020011008-000......................................249 T2020011010-000.......................................249 T2020011015-000.......................................249 T2020011025-000......................................249 T2020011002-000.......................................251 T2020011005-000.......................................251 T2020011008-000.......................................251 T2020011010-000........................................251 T2020011015-000........................................251 T2020011025-000.......................................251 T2020011002-000..................................... 303 T2020011005-000..................................... 303 T2020011008-000..................................... 303 T2020011010-000...................................... 303 T2020011015-000...................................... 303 T2020011025-000..................................... 303 T2020012002-000....................................... 27 T2020012005-000....................................... 27 T2020012008-000....................................... 27 T2020012010-000........................................ 27 T2020012015-000........................................ 27 T2020012025-000....................................... 27 T2020012002-000........................................ 31 351 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T2020012005-000........................................ 31 T2020012008-000........................................ 31 T2020012010-000......................................... 31 T2020012015-000......................................... 31 T2020012025-000........................................ 31 T2020012002-000.......................................48 T2020012005-000.......................................48 T2020012008-000.......................................48 T2020012010-000........................................48 T2020012015-000........................................48 T2020012025-000.......................................48 T2020012002-000....................................... 55 T2020012005-000....................................... 55 T2020012008-000....................................... 55 T2020012010-000........................................ 55 T2020012015-000........................................ 55 T2020012025-000....................................... 55 T2020012002-000.......................................60 T2020012005-000.......................................60 T2020012008-000.......................................60 T2020012010-000........................................60 T2020012015-000........................................60 T2020012025-000.......................................60 T2020012002-000....................................... 63 T2020012005-000....................................... 63 T2020012008-000....................................... 63 T2020012010-000........................................ 63 T2020012015-000........................................ 63 T2020012025-000....................................... 63 T2020012002-000.......................................66 T2020012005-000.......................................66 T2020012008-000.......................................66 T2020012010-000........................................66 T2020012015-000........................................66 T2020012025-000.......................................66 T2020012002-000....................................... 69 T2020012005-000....................................... 69 T2020012008-000....................................... 69 T2020012010-000........................................ 69 T2020012015-000........................................ 69 T2020012025-000....................................... 69 T2020012002-000....................................... 74 T2020012005-000....................................... 74 T2020012008-000....................................... 74 T2020012010-000........................................ 74 T2020012015-000........................................ 74 T2020012025-000....................................... 74 T2020012002-000....................................... 82 T2020012005-000....................................... 82 T2020012008-000....................................... 82 T2020012010-000........................................ 82 T2020012015-000........................................ 82 T2020012025-000....................................... 82 T2020012002-000.......................................84 T2020012005-000.......................................84 T2020012008-000.......................................84 Part Number Page T2020012010-000........................................84 T2020012015-000........................................84 T2020012025-000.......................................84 T2020012002-000........................................ 91 T2020012005-000........................................ 91 T2020012008-000........................................ 91 T2020012010-000......................................... 91 T2020012015-000......................................... 91 T2020012025-000........................................ 91 T2020012002-000....................................... 93 T2020012005-000....................................... 93 T2020012008-000....................................... 93 T2020012010-000........................................ 93 T2020012015-000........................................ 93 T2020012025-000....................................... 93 T2020012002-000...................................... 101 T2020012005-000...................................... 101 T2020012008-000...................................... 101 T2020012010-000....................................... 101 T2020012015-000....................................... 101 T2020012025-000...................................... 101 T2020012002-000..................................... 103 T2020012005-000..................................... 103 T2020012008-000..................................... 103 T2020012010-000...................................... 103 T2020012015-000...................................... 103 T2020012025-000..................................... 103 T2020012002-000..................................... 106 T2020012005-000..................................... 106 T2020012008-000..................................... 106 T2020012010-000...................................... 106 T2020012015-000...................................... 106 T2020012025-000..................................... 106 T2020012002-000..................................... 108 T2020012005-000..................................... 108 T2020012008-000..................................... 108 T2020012010-000...................................... 108 T2020012015-000...................................... 108 T2020012025-000..................................... 108 T2020012002-000...................................... 110 T2020012005-000...................................... 110 T2020012008-000...................................... 110 T2020012010-000....................................... 110 T2020012015-000....................................... 110 T2020012025-000...................................... 110 T2020012002-000..................................... 184 T2020012005-000..................................... 184 T2020012008-000..................................... 184 T2020012010-000...................................... 184 T2020012015-000...................................... 184 T2020012025-000..................................... 184 T2020012002-000..................................... 190 T2020012005-000..................................... 190 T2020012008-000..................................... 190 T2020012010-000...................................... 190 T2020012015-000...................................... 190 352 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T2020012025-000..................................... 190 T2020012002-000......................................221 T2020012005-000......................................221 T2020012008-000......................................221 T2020012010-000.......................................221 T2020012015-000.......................................221 T2020012025-000......................................221 T2020012002-000.....................................223 T2020012005-000.....................................223 T2020012008-000.....................................223 T2020012010-000......................................223 T2020012015-000......................................223 T2020012025-000.....................................223 T2020012002-000.....................................237 T2020012005-000.....................................237 T2020012008-000.....................................237 T2020012010-000......................................237 T2020012015-000......................................237 T2020012025-000.....................................237 T2020012002-000.....................................249 T2020012005-000.....................................249 T2020012008-000.....................................249 T2020012010-000......................................249 T2020012015-000......................................249 T2020012025-000.....................................249 T2020012002-000......................................251 T2020012005-000......................................251 T2020012008-000......................................251 T2020012010-000.......................................251 T2020012015-000.......................................251 T2020012025-000......................................251 T2020012002-000.................................... 303 T2020012005-000.................................... 303 T2020012008-000.................................... 303 T2020012010-000..................................... 303 T2020012015-000..................................... 303 T2020012025-000.................................... 303 T2020072101-000........................................ 27 T2020072101-000........................................ 55 T2020072201-000....................................... 27 T2020072201-000....................................... 55 T2020082101-000........................................ 27 T2020082101-000........................................ 55 T2020082201-000....................................... 27 T2020082201-000....................................... 55 T2020152101-000..........................................60 T2020152201-000.........................................60 T2020252101-000......................................... 63 T2020252101-000.........................................66 T2020252201-000........................................ 63 T2020252201-000........................................66 T2020402101-000....................................... 101 T2020402101-000........................................ 82 T2020402201-000....................................... 82 T2020402201-000...................................... 101 T2020502101-000........................................66 Part Number Page T2020502201-000.......................................66 T2020642101-000......................................... 91 T2020642101-000...................................... 106 T2020642201-000........................................ 91 T2020642201-000..................................... 106 T2020802101-000....................................... 101 T2020802201-000...................................... 101 T2021282101-000........................................ 106 T2021282201-000....................................... 106 T2030001002-000...................................... 32 T2030001005-000...................................... 32 T2030001008-000...................................... 32 T2030001010-000....................................... 32 T2030001015-000........................................ 32 T2030001025-000....................................... 32 T2030001040-000...................................... 32 T2030001002-000......................................49 T2030001005-000......................................49 T2030001008-000......................................49 T2030001010-000.......................................49 T2030001015-000........................................49 T2030001025-000.......................................49 T2030001040-000......................................49 T2030001002-000......................................117 T2030001005-000......................................117 T2030001008-000......................................117 T2030001010-000.......................................117 T2030001015-000........................................117 T2030001025-000.......................................117 T2030001040-000......................................117 T2030001002-000......................................118 T2030001005-000......................................118 T2030001008-000......................................118 T2030001010-000.......................................118 T2030001015-000........................................118 T2030001025-000.......................................118 T2030001040-000......................................118 T2030001002-000......................................119 T2030001005-000......................................119 T2030001008-000......................................119 T2030001010-000.......................................119 T2030001015-000........................................119 T2030001025-000.......................................119 T2030001040-000......................................119 T2030001002-000.....................................124 T2030001005-000.....................................124 T2030001008-000.....................................124 T2030001010-000......................................124 T2030001015-000.......................................124 T2030001025-000......................................124 T2030001040-000.....................................124 T2030001002-000.....................................125 T2030001005-000.....................................125 T2030001008-000.....................................125 T2030001010-000......................................125 T2030001015-000.......................................125 Part Number Page T2030001025-000......................................125 T2030001040-000.....................................125 T2030001002-000.....................................126 T2030001005-000.....................................126 T2030001008-000.....................................126 T2030001010-000......................................126 T2030001015-000.......................................126 T2030001025-000......................................126 T2030001040-000.....................................126 T2030001002-000.....................................133 T2030001005-000.....................................133 T2030001008-000.....................................133 T2030001010-000......................................133 T2030001015-000.......................................133 T2030001025-000......................................133 T2030001040-000.....................................133 T2030001002-000.....................................134 T2030001005-000.....................................134 T2030001008-000.....................................134 T2030001010-000......................................134 T2030001015-000.......................................134 T2030001025-000......................................134 T2030001040-000.....................................134 T2030001002-000.....................................135 T2030001005-000.....................................135 T2030001008-000.....................................135 T2030001010-000......................................135 T2030001015-000.......................................135 T2030001025-000......................................135 T2030001040-000.....................................135 T2030001002-000.....................................136 T2030001005-000.....................................136 T2030001008-000.....................................136 T2030001010-000......................................136 T2030001015-000.......................................136 T2030001025-000......................................136 T2030001040-000.....................................136 T2030001002-000.....................................143 T2030001005-000.....................................143 T2030001008-000.....................................143 T2030001010-000......................................143 T2030001015-000.......................................143 T2030001025-000......................................143 T2030001040-000.....................................143 T2030001002-000.................................... 144 T2030001005-000.................................... 144 T2030001008-000.................................... 144 T2030001010-000..................................... 144 T2030001015-000...................................... 144 T2030001025-000..................................... 144 T2030001040-000.................................... 144 T2030001002-000.....................................145 T2030001005-000.....................................145 T2030001008-000.....................................145 T2030001010-000......................................145 T2030001015-000.......................................145 Part Number Page T2030001025-000......................................145 T2030001040-000.....................................145 T2030001002-000.................................... 146 T2030001005-000.................................... 146 T2030001008-000.................................... 146 T2030001010-000..................................... 146 T2030001015-000...................................... 146 T2030001025-000..................................... 146 T2030001040-000.................................... 146 T2030001002-000.....................................154 T2030001005-000.....................................154 T2030001008-000.....................................154 T2030001010-000......................................154 T2030001015-000.......................................154 T2030001025-000......................................154 T2030001040-000.....................................154 T2030001002-000.....................................155 T2030001005-000.....................................155 T2030001008-000.....................................155 T2030001010-000......................................155 T2030001015-000.......................................155 T2030001025-000......................................155 T2030001040-000.....................................155 T2030001002-000.....................................156 T2030001005-000.....................................156 T2030001008-000.....................................156 T2030001010-000......................................156 T2030001015-000.......................................156 T2030001025-000......................................156 T2030001040-000.....................................156 T2030001002-000.....................................157 T2030001005-000.....................................157 T2030001008-000.....................................157 T2030001010-000......................................157 T2030001015-000.......................................157 T2030001025-000......................................157 T2030001040-000.....................................157 T2030001002-000.................................... 160 T2030001005-000.................................... 160 T2030001008-000.................................... 160 T2030001010-000..................................... 160 T2030001015-000...................................... 160 T2030001025-000..................................... 160 T2030001040-000.................................... 160 T2030001002-000......................................161 T2030001005-000......................................161 T2030001008-000......................................161 T2030001010-000.......................................161 T2030001015-000........................................161 T2030001025-000.......................................161 T2030001040-000......................................161 T2030001002-000.....................................162 T2030001005-000.....................................162 T2030001008-000.....................................162 T2030001010-000......................................162 T2030001015-000.......................................162 353 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T2030001025-000......................................162 T2030001040-000.....................................162 T2030001002-000.....................................163 T2030001005-000.....................................163 T2030001008-000.....................................163 T2030001010-000......................................163 T2030001015-000.......................................163 T2030001025-000......................................163 T2030001040-000.....................................163 T2030001002-000.....................................165 T2030001005-000.....................................165 T2030001008-000.....................................165 T2030001010-000......................................165 T2030001015-000.......................................165 T2030001025-000......................................165 T2030001040-000.....................................165 T2030001002-000.....................................183 T2030001005-000.....................................183 T2030001008-000.....................................183 T2030001010-000......................................183 T2030001015-000.......................................183 T2030001025-000......................................183 T2030001040-000.....................................183 T2030001002-000......................................191 T2030001005-000......................................191 T2030001008-000......................................191 T2030001010-000.......................................191 T2030001015-000........................................191 T2030001025-000.......................................191 T2030001040-000......................................191 T2030001002-000.....................................217 T2030001005-000.....................................217 T2030001008-000.....................................217 T2030001010-000......................................217 T2030001015-000.......................................217 T2030001025-000......................................217 T2030001040-000.....................................217 T2030001002-000.....................................219 T2030001005-000.....................................219 T2030001008-000.....................................219 T2030001010-000......................................219 T2030001015-000.......................................219 T2030001025-000......................................219 T2030001040-000.....................................219 T2030001002-000....................................225 T2030001005-000....................................225 T2030001008-000....................................225 T2030001010-000.....................................225 T2030001015-000......................................225 T2030001025-000.....................................225 T2030001040-000....................................225 T2030001002-000....................................237 T2030001005-000....................................237 T2030001008-000....................................237 T2030001010-000.....................................237 T2030001015-000......................................237 Part Number Page T2030001025-000.....................................237 T2030001040-000....................................237 T2030001002-000................................... 303 T2030001005-000................................... 303 T2030001008-000................................... 303 T2030001010-000.................................... 303 T2030001015-000..................................... 303 T2030001025-000.................................... 303 T2030001040-000................................... 303 T2030002000-000.................................. 305 T2030002002-000..................................... 32 T2030002005-000..................................... 32 T2030002008-000..................................... 32 T2030002010-000...................................... 32 T2030002015-000....................................... 32 T2030002025-000...................................... 32 T2030002040-000..................................... 32 T2030002002-000.....................................49 T2030002005-000.....................................49 T2030002008-000.....................................49 T2030002010-000......................................49 T2030002015-000.......................................49 T2030002025-000......................................49 T2030002040-000.....................................49 T2030002002-000.....................................117 T2030002005-000.....................................117 T2030002008-000.....................................117 T2030002010-000......................................117 T2030002015-000.......................................117 T2030002025-000......................................117 T2030002040-000.....................................117 T2030002002-000.....................................118 T2030002005-000.....................................118 T2030002008-000.....................................118 T2030002010-000......................................118 T2030002015-000.......................................118 T2030002025-000......................................118 T2030002040-000.....................................118 T2030002002-000.....................................119 T2030002005-000.....................................119 T2030002008-000.....................................119 T2030002010-000......................................119 T2030002015-000.......................................119 T2030002025-000......................................119 T2030002040-000.....................................119 T2030002002-000....................................124 T2030002005-000....................................124 T2030002008-000....................................124 T2030002010-000.....................................124 T2030002015-000......................................124 T2030002025-000.....................................124 T2030002040-000....................................124 T2030002002-000....................................125 T2030002005-000....................................125 T2030002008-000....................................125 T2030002010-000.....................................125 354 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T2030002015-000......................................125 T2030002025-000.....................................125 T2030002040-000....................................125 T2030002002-000....................................126 T2030002005-000....................................126 T2030002008-000....................................126 T2030002010-000.....................................126 T2030002015-000......................................126 T2030002025-000.....................................126 T2030002040-000....................................126 T2030002002-000....................................133 T2030002005-000....................................133 T2030002008-000....................................133 T2030002010-000.....................................133 T2030002015-000......................................133 T2030002025-000.....................................133 T2030002040-000....................................133 T2030002002-000....................................134 T2030002005-000....................................134 T2030002008-000....................................134 T2030002010-000.....................................134 T2030002015-000......................................134 T2030002025-000.....................................134 T2030002040-000....................................134 T2030002002-000....................................135 T2030002005-000....................................135 T2030002008-000....................................135 T2030002010-000.....................................135 T2030002015-000......................................135 T2030002025-000.....................................135 T2030002040-000....................................135 T2030002002-000....................................136 T2030002005-000....................................136 T2030002008-000....................................136 T2030002010-000.....................................136 T2030002015-000......................................136 T2030002025-000.....................................136 T2030002040-000....................................136 T2030002002-000....................................143 T2030002005-000....................................143 T2030002008-000....................................143 T2030002010-000.....................................143 T2030002015-000......................................143 T2030002025-000.....................................143 T2030002040-000....................................143 T2030002002-000................................... 144 T2030002005-000................................... 144 T2030002008-000................................... 144 T2030002010-000.................................... 144 T2030002015-000..................................... 144 T2030002025-000.................................... 144 T2030002040-000................................... 144 T2030002002-000....................................145 T2030002005-000....................................145 T2030002008-000....................................145 T2030002010-000.....................................145 Part Number Page T2030002015-000......................................145 T2030002025-000.....................................145 T2030002040-000....................................145 T2030002002-000................................... 146 T2030002005-000................................... 146 T2030002008-000................................... 146 T2030002010-000.................................... 146 T2030002015-000..................................... 146 T2030002025-000.................................... 146 T2030002040-000................................... 146 T2030002002-000....................................154 T2030002005-000....................................154 T2030002008-000....................................154 T2030002010-000.....................................154 T2030002015-000......................................154 T2030002025-000.....................................154 T2030002040-000....................................154 T2030002002-000....................................155 T2030002005-000....................................155 T2030002008-000....................................155 T2030002010-000.....................................155 T2030002015-000......................................155 T2030002025-000.....................................155 T2030002040-000....................................155 T2030002002-000....................................156 T2030002005-000....................................156 T2030002008-000....................................156 T2030002010-000.....................................156 T2030002015-000......................................156 T2030002025-000.....................................156 T2030002040-000....................................156 T2030002002-000....................................157 T2030002005-000....................................157 T2030002008-000....................................157 T2030002010-000.....................................157 T2030002015-000......................................157 T2030002025-000.....................................157 T2030002040-000....................................157 T2030002002-000................................... 160 T2030002005-000................................... 160 T2030002008-000................................... 160 T2030002010-000.................................... 160 T2030002015-000..................................... 160 T2030002025-000.................................... 160 T2030002040-000................................... 160 T2030002002-000.....................................161 T2030002005-000.....................................161 T2030002008-000.....................................161 T2030002010-000......................................161 T2030002015-000.......................................161 T2030002025-000......................................161 T2030002040-000.....................................161 T2030002002-000....................................162 T2030002005-000....................................162 T2030002008-000....................................162 T2030002010-000.....................................162 Part Number Page T2030002015-000......................................162 T2030002025-000.....................................162 T2030002040-000....................................162 T2030002002-000....................................163 T2030002005-000....................................163 T2030002008-000....................................163 T2030002010-000.....................................163 T2030002015-000......................................163 T2030002025-000.....................................163 T2030002040-000....................................163 T2030002002-000....................................165 T2030002005-000....................................165 T2030002008-000....................................165 T2030002010-000.....................................165 T2030002015-000......................................165 T2030002025-000.....................................165 T2030002040-000....................................165 T2030002002-000....................................183 T2030002005-000....................................183 T2030002008-000....................................183 T2030002010-000.....................................183 T2030002015-000......................................183 T2030002025-000.....................................183 T2030002040-000....................................183 T2030002002-000.....................................191 T2030002005-000.....................................191 T2030002008-000.....................................191 T2030002010-000......................................191 T2030002015-000.......................................191 T2030002025-000......................................191 T2030002040-000.....................................191 T2030002002-000....................................217 T2030002005-000....................................217 T2030002008-000....................................217 T2030002010-000.....................................217 T2030002015-000......................................217 T2030002025-000.....................................217 T2030002040-000....................................217 T2030002002-000....................................219 T2030002005-000....................................219 T2030002008-000....................................219 T2030002010-000.....................................219 T2030002015-000......................................219 T2030002025-000.....................................219 T2030002040-000....................................219 T2030002002-000...................................225 T2030002005-000...................................225 T2030002008-000...................................225 T2030002010-000....................................225 T2030002015-000.....................................225 T2030002025-000....................................225 T2030002040-000...................................225 T2030002002-000...................................237 T2030002005-000...................................237 T2030002008-000...................................237 T2030002010-000....................................237 Part Number Page T2030002015-000.....................................237 T2030002025-000....................................237 T2030002040-000...................................237 T2030002002-000.................................. 303 T2030002005-000.................................. 303 T2030002008-000.................................. 303 T2030002010-000................................... 303 T2030002015-000.................................... 303 T2030002025-000................................... 303 T2030002040-000.................................. 303 T2030011002-000........................................ 32 T2030011005-000........................................ 32 T2030011008-000....................................... 32 T2030011010-000......................................... 32 T2030011015-000......................................... 32 T2030011025-000........................................ 32 T2030011040-000....................................... 32 T2030011002-000........................................49 T2030011005-000........................................49 T2030011008-000.......................................49 T2030011010-000.........................................49 T2030011015-000.........................................49 T2030011025-000........................................49 T2030011040-000.......................................49 T2030011002-000........................................117 T2030011005-000........................................117 T2030011008-000.......................................117 T2030011010-000.........................................117 T2030011015-000.........................................117 T2030011025-000........................................117 T2030011040-000.......................................117 T2030011002-000........................................118 T2030011005-000........................................118 T2030011008-000.......................................118 T2030011010-000.........................................118 T2030011015-000.........................................118 T2030011025-000........................................118 T2030011040-000.......................................118 T2030011002-000........................................119 T2030011005-000........................................119 T2030011008-000.......................................119 T2030011010-000.........................................119 T2030011015-000.........................................119 T2030011025-000........................................119 T2030011040-000.......................................119 T2030011002-000.......................................124 T2030011005-000.......................................124 T2030011008-000......................................124 T2030011010-000........................................124 T2030011015-000........................................124 T2030011025-000.......................................124 T2030011040-000......................................124 T2030011002-000.......................................125 T2030011005-000.......................................125 T2030011008-000......................................125 T2030011010-000........................................125 355 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T2030011015-000........................................125 T2030011025-000.......................................125 T2030011040-000......................................125 T2030011002-000.......................................126 T2030011005-000.......................................126 T2030011008-000......................................126 T2030011010-000........................................126 T2030011015-000........................................126 T2030011025-000.......................................126 T2030011040-000......................................126 T2030011002-000.......................................133 T2030011005-000.......................................133 T2030011008-000......................................133 T2030011010-000........................................133 T2030011015-000........................................133 T2030011025-000.......................................133 T2030011040-000......................................133 T2030011002-000.......................................134 T2030011005-000.......................................134 T2030011008-000......................................134 T2030011010-000........................................134 T2030011015-000........................................134 T2030011025-000.......................................134 T2030011040-000......................................134 T2030011002-000.......................................135 T2030011005-000.......................................135 T2030011008-000......................................135 T2030011010-000........................................135 T2030011015-000........................................135 T2030011025-000.......................................135 T2030011040-000......................................135 T2030011002-000.......................................136 T2030011005-000.......................................136 T2030011008-000......................................136 T2030011010-000........................................136 T2030011015-000........................................136 T2030011025-000.......................................136 T2030011040-000......................................136 T2030011002-000.......................................143 T2030011005-000.......................................143 T2030011008-000......................................143 T2030011010-000........................................143 T2030011015-000........................................143 T2030011025-000.......................................143 T2030011040-000......................................143 T2030011002-000...................................... 144 T2030011005-000...................................... 144 T2030011008-000..................................... 144 T2030011010-000....................................... 144 T2030011015-000....................................... 144 T2030011025-000...................................... 144 T2030011040-000..................................... 144 T2030011002-000.......................................145 T2030011005-000.......................................145 T2030011008-000......................................145 T2030011010-000........................................145 Part Number Page T2030011015-000........................................145 T2030011025-000.......................................145 T2030011040-000......................................145 T2030011002-000...................................... 146 T2030011005-000...................................... 146 T2030011008-000..................................... 146 T2030011010-000....................................... 146 T2030011015-000....................................... 146 T2030011025-000...................................... 146 T2030011040-000..................................... 146 T2030011002-000.......................................154 T2030011005-000.......................................154 T2030011008-000......................................154 T2030011010-000........................................154 T2030011015-000........................................154 T2030011025-000.......................................154 T2030011040-000......................................154 T2030011002-000.......................................155 T2030011005-000.......................................155 T2030011008-000......................................155 T2030011010-000........................................155 T2030011015-000........................................155 T2030011025-000.......................................155 T2030011040-000......................................155 T2030011002-000.......................................156 T2030011005-000.......................................156 T2030011008-000......................................156 T2030011010-000........................................156 T2030011015-000........................................156 T2030011025-000.......................................156 T2030011040-000......................................156 T2030011002-000.......................................157 T2030011005-000.......................................157 T2030011008-000......................................157 T2030011010-000........................................157 T2030011015-000........................................157 T2030011025-000.......................................157 T2030011040-000......................................157 T2030011002-000...................................... 160 T2030011005-000...................................... 160 T2030011008-000..................................... 160 T2030011010-000....................................... 160 T2030011015-000....................................... 160 T2030011025-000...................................... 160 T2030011040-000..................................... 160 T2030011002-000........................................161 T2030011005-000........................................161 T2030011008-000.......................................161 T2030011010-000.........................................161 T2030011015-000.........................................161 T2030011025-000........................................161 T2030011040-000.......................................161 T2030011002-000.......................................162 T2030011005-000.......................................162 T2030011008-000......................................162 T2030011010-000........................................162 356 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T2030011015-000........................................162 T2030011025-000.......................................162 T2030011040-000......................................162 T2030011002-000.......................................163 T2030011005-000.......................................163 T2030011008-000......................................163 T2030011010-000........................................163 T2030011015-000........................................163 T2030011025-000.......................................163 T2030011040-000......................................163 T2030011002-000.......................................165 T2030011005-000.......................................165 T2030011008-000......................................165 T2030011010-000........................................165 T2030011015-000........................................165 T2030011025-000.......................................165 T2030011040-000......................................165 T2030011002-000.......................................183 T2030011005-000.......................................183 T2030011008-000......................................183 T2030011010-000........................................183 T2030011015-000........................................183 T2030011025-000.......................................183 T2030011040-000......................................183 T2030011002-000........................................191 T2030011005-000........................................191 T2030011008-000.......................................191 T2030011010-000.........................................191 T2030011015-000.........................................191 T2030011025-000........................................191 T2030011040-000.......................................191 T2030011002-000.......................................217 T2030011005-000.......................................217 T2030011008-000......................................217 T2030011010-000........................................217 T2030011015-000........................................217 T2030011025-000.......................................217 T2030011040-000......................................217 T2030011002-000.......................................219 T2030011005-000.......................................219 T2030011008-000......................................219 T2030011010-000........................................219 T2030011015-000........................................219 T2030011025-000.......................................219 T2030011040-000......................................219 T2030011002-000......................................225 T2030011005-000......................................225 T2030011008-000.....................................225 T2030011010-000.......................................225 T2030011015-000.......................................225 T2030011025-000......................................225 T2030011040-000.....................................225 T2030011002-000......................................237 T2030011005-000......................................237 T2030011008-000.....................................237 T2030011010-000.......................................237 Part Number Page T2030011015-000.......................................237 T2030011025-000......................................237 T2030011040-000.....................................237 T2030011002-000..................................... 303 T2030011005-000..................................... 303 T2030011008-000.................................... 303 T2030011010-000...................................... 303 T2030011015-000...................................... 303 T2030011025-000..................................... 303 T2030011040-000.................................... 303 T2030012002-000....................................... 32 T2030012005-000....................................... 32 T2030012008-000...................................... 32 T2030012010-000........................................ 32 T2030012015-000........................................ 32 T2030012025-000....................................... 32 T2030012040-000...................................... 32 T2030012002-000.......................................49 T2030012005-000.......................................49 T2030012008-000......................................49 T2030012010-000........................................49 T2030012015-000........................................49 T2030012025-000.......................................49 T2030012040-000......................................49 T2030012002-000.......................................117 T2030012005-000.......................................117 T2030012008-000......................................117 T2030012010-000........................................117 T2030012015-000........................................117 T2030012025-000.......................................117 T2030012040-000......................................117 T2030012002-000.......................................118 T2030012005-000.......................................118 T2030012008-000......................................118 T2030012010-000........................................118 T2030012015-000........................................118 T2030012025-000.......................................118 T2030012040-000......................................118 T2030012002-000.......................................119 T2030012005-000.......................................119 T2030012008-000......................................119 T2030012010-000........................................119 T2030012015-000........................................119 T2030012025-000.......................................119 T2030012040-000......................................119 T2030012002-000......................................124 T2030012005-000......................................124 T2030012008-000.....................................124 T2030012010-000.......................................124 T2030012015-000.......................................124 T2030012025-000......................................124 T2030012040-000.....................................124 T2030012002-000......................................125 T2030012005-000......................................125 T2030012008-000.....................................125 T2030012010-000.......................................125 Part Number Page T2030012015-000.......................................125 T2030012025-000......................................125 T2030012040-000.....................................125 T2030012002-000......................................126 T2030012005-000......................................126 T2030012008-000.....................................126 T2030012010-000.......................................126 T2030012015-000.......................................126 T2030012025-000......................................126 T2030012040-000.....................................126 T2030012002-000......................................133 T2030012005-000......................................133 T2030012008-000.....................................133 T2030012010-000.......................................133 T2030012015-000.......................................133 T2030012025-000......................................133 T2030012040-000.....................................133 T2030012002-000......................................134 T2030012005-000......................................134 T2030012008-000.....................................134 T2030012010-000.......................................134 T2030012015-000.......................................134 T2030012025-000......................................134 T2030012040-000.....................................134 T2030012002-000......................................135 T2030012005-000......................................135 T2030012008-000.....................................135 T2030012010-000.......................................135 T2030012015-000.......................................135 T2030012025-000......................................135 T2030012040-000.....................................135 T2030012002-000......................................136 T2030012005-000......................................136 T2030012008-000.....................................136 T2030012010-000.......................................136 T2030012015-000.......................................136 T2030012025-000......................................136 T2030012040-000.....................................136 T2030012002-000......................................143 T2030012005-000......................................143 T2030012008-000.....................................143 T2030012010-000.......................................143 T2030012015-000.......................................143 T2030012025-000......................................143 T2030012040-000.....................................143 T2030012002-000..................................... 144 T2030012005-000..................................... 144 T2030012008-000.................................... 144 T2030012010-000...................................... 144 T2030012015-000...................................... 144 T2030012025-000..................................... 144 T2030012040-000.................................... 144 T2030012002-000......................................145 T2030012005-000......................................145 T2030012008-000.....................................145 T2030012010-000.......................................145 Part Number Page T2030012015-000.......................................145 T2030012025-000......................................145 T2030012040-000.....................................145 T2030012002-000..................................... 146 T2030012005-000..................................... 146 T2030012008-000.................................... 146 T2030012010-000...................................... 146 T2030012015-000...................................... 146 T2030012025-000..................................... 146 T2030012040-000.................................... 146 T2030012002-000......................................154 T2030012005-000......................................154 T2030012008-000.....................................154 T2030012010-000.......................................154 T2030012015-000.......................................154 T2030012025-000......................................154 T2030012040-000.....................................154 T2030012002-000......................................155 T2030012005-000......................................155 T2030012008-000.....................................155 T2030012010-000.......................................155 T2030012015-000.......................................155 T2030012025-000......................................155 T2030012040-000.....................................155 T2030012002-000......................................156 T2030012005-000......................................156 T2030012008-000.....................................156 T2030012010-000.......................................156 T2030012015-000.......................................156 T2030012025-000......................................156 T2030012040-000.....................................156 T2030012002-000......................................157 T2030012005-000......................................157 T2030012008-000.....................................157 T2030012010-000.......................................157 T2030012015-000.......................................157 T2030012025-000......................................157 T2030012040-000.....................................157 T2030012002-000..................................... 160 T2030012005-000..................................... 160 T2030012008-000.................................... 160 T2030012010-000...................................... 160 T2030012015-000...................................... 160 T2030012025-000..................................... 160 T2030012040-000.................................... 160 T2030012002-000.......................................161 T2030012005-000.......................................161 T2030012008-000......................................161 T2030012010-000........................................161 T2030012015-000........................................161 T2030012025-000.......................................161 T2030012040-000......................................161 T2030012002-000......................................162 T2030012005-000......................................162 T2030012008-000.....................................162 T2030012010-000.......................................162 357 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T2030012015-000.......................................162 T2030012025-000......................................162 T2030012040-000.....................................162 T2030012002-000......................................163 T2030012005-000......................................163 T2030012008-000.....................................163 T2030012010-000.......................................163 T2030012015-000.......................................163 T2030012025-000......................................163 T2030012040-000.....................................163 T2030012002-000......................................165 T2030012005-000......................................165 T2030012008-000.....................................165 T2030012010-000.......................................165 T2030012015-000.......................................165 T2030012025-000......................................165 T2030012040-000.....................................165 T2030012002-000......................................183 T2030012005-000......................................183 T2030012008-000.....................................183 T2030012010-000.......................................183 T2030012015-000.......................................183 T2030012025-000......................................183 T2030012040-000.....................................183 T2030012002-000.......................................191 T2030012005-000.......................................191 T2030012008-000......................................191 T2030012010-000........................................191 T2030012015-000........................................191 T2030012025-000.......................................191 T2030012040-000......................................191 T2030012002-000......................................217 T2030012005-000......................................217 T2030012008-000.....................................217 T2030012010-000.......................................217 T2030012015-000.......................................217 T2030012025-000......................................217 T2030012040-000.....................................217 T2030012002-000......................................219 T2030012005-000......................................219 T2030012008-000.....................................219 T2030012010-000.......................................219 T2030012015-000.......................................219 T2030012025-000......................................219 T2030012040-000.....................................219 T2030012002-000.....................................225 T2030012005-000.....................................225 T2030012008-000....................................225 T2030012010-000......................................225 T2030012015-000......................................225 T2030012025-000.....................................225 T2030012040-000....................................225 T2030012002-000.....................................237 T2030012005-000.....................................237 T2030012008-000....................................237 T2030012010-000......................................237 Part Number Page T2030012015-000......................................237 T2030012025-000.....................................237 T2030012040-000....................................237 T2030012002-000.................................... 303 T2030012005-000.................................... 303 T2030012008-000................................... 303 T2030012010-000..................................... 303 T2030012015-000..................................... 303 T2030012025-000.................................... 303 T2030012040-000................................... 303 T2030162101-000......................................... 69 T2030162201-000........................................ 69 T2030422101-000........................................ 74 T2030422201-000....................................... 74 T2030722101-000.........................................84 T2030722101-000....................................... 103 T2030722201-000........................................84 T2030722201-000...................................... 103 T2031082101-000......................................... 93 T2031082101-000....................................... 108 T2031082201-000........................................ 93 T2031082201-000...................................... 108 T2031442101-000....................................... 103 T2031442201-000...................................... 103 T2032162101-000........................................ 108 T2032162201-000....................................... 108 T2040000000-000................................. 305 T2040001015-000.......................................211 T2040001015-000......................................213 T2040001015-000.....................................249 T2040001015-000......................................251 T2040001015-000.................................... 304 T2040001025-000......................................211 T2040001025-000.....................................213 T2040001025-000....................................249 T2040001025-000.....................................251 T2040001025-000................................... 304 T2040001040-000......................................211 T2040001040-000.....................................213 T2040001040-000....................................249 T2040001040-000.....................................251 T2040001040-000................................... 304 T2040001060-000......................................211 T2040001060-000.....................................213 T2040001060-000....................................249 T2040001060-000.....................................251 T2040001060-000................................... 304 T2040002015-000......................................211 T2040002015-000.....................................213 T2040002015-000....................................249 T2040002015-000.....................................251 T2040002015-000................................... 304 T2040002025-000.....................................211 T2040002025-000....................................213 T2040002025-000...................................249 T2040002025-000....................................251 358 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T2040002025-000.................................. 304 T2040002040-000.....................................211 T2040002040-000....................................213 T2040002040-000...................................249 T2040002040-000....................................251 T2040002040-000.................................. 304 T2040002060-000.....................................211 T2040002060-000....................................213 T2040002060-000...................................249 T2040002060-000....................................251 T2040002060-000.................................. 304 T2040002100-000......................................211 T2040002100-000.....................................213 T2040002100-000....................................249 T2040002100-000.....................................251 T2040002100-000................................... 304 T2040062101-000........................................117 T2040062201-000.......................................117 T2040063101-000........................................117 T2040063201-000.......................................117 T2040064101-000.......................................117 T2040064201-000......................................117 T2040065101-000........................................117 T2040065201-000.......................................117 T2040102101-000........................................124 T2040102201-000.......................................124 T2040103101-000........................................124 T2040103201-000.......................................124 T2040104101-000........................................124 T2040104201-000.......................................124 T2040105101-000........................................124 T2040105201-000.......................................124 T2040162101-000........................................133 T2040162101-000........................................154 T2040162201-000.......................................133 T2040162201-000.......................................154 T2040163101-000........................................133 T2040163101-000........................................154 T2040163201-000.......................................133 T2040163201-000.......................................154 T2040164101-000........................................133 T2040164101-000........................................154 T2040164201-000.......................................133 T2040164201-000.......................................154 T2040165101-000........................................133 T2040165101-000........................................154 T2040165201-000.......................................133 T2040165201-000.......................................154 T2040242101-000.......................................143 T2040242101-000...................................... 160 T2040242201-000......................................143 T2040242201-000..................................... 160 T2040243101-000.......................................143 T2040243101-000...................................... 160 T2040243201-000......................................143 T2040243201-000..................................... 160 Part Number Page T2040244101-000.......................................143 T2040244101-000...................................... 160 T2040244201-000......................................143 T2040244201-000..................................... 160 T2040245101-000.......................................143 T2040245101-000...................................... 160 T2040245201-000......................................143 T2040245201-000..................................... 160 T2040322101-000.......................................154 T2040322201-000......................................154 T2040323101-000.......................................154 T2040323201-000......................................154 T2040324101-000.......................................154 T2040324201-000......................................154 T2040325101-000.......................................154 T2040325201-000......................................154 T2040482101-000...................................... 160 T2040482201-000..................................... 160 T2040483101-000...................................... 160 T2040483201-000..................................... 160 T2040484101-000...................................... 160 T2040484201-000..................................... 160 T2040485101-000...................................... 160 T2040485201-000..................................... 160 T2050001010-000.....................................207 T2050001010-000.................................... 304 T2050001016-000.....................................207 T2050001016-000.................................... 304 T2050001025-000.....................................207 T2050001025-000.................................... 304 T2050001035-000.....................................207 T2050001035-000.................................... 304 T2050002010-000....................................207 T2050002010-000................................... 304 T2050002016-000....................................207 T2050002016-000................................... 304 T2050002025-000....................................207 T2050002025-000................................... 304 T2050002035-000....................................207 T2050002035-000................................... 304 T2050102101-000.........................................118 T2050102201-000........................................118 T2050182101-000........................................125 T2050182201-000.......................................125 T2050202101-000........................................119 T2050202201-000.......................................119 T2050322101-000.......................................134 T2050322101-000.......................................155 T2050322201-000......................................134 T2050322201-000......................................155 T2050323101-000.......................................126 T2050323201-000......................................126 T2050402101-000.......................................135 T2050402101-000.......................................156 T2050402201-000......................................135 T2050402201-000......................................156 Part Number Page T2050462101-000...................................... 144 T2050462101-000........................................161 T2050462201-000..................................... 144 T2050462201-000.......................................161 T2050482101-000.......................................136 T2050482101-000.......................................157 T2050482201-000......................................136 T2050482201-000......................................157 T2050642101-000.......................................155 T2050642201-000......................................155 T2050643101-000.......................................145 T2050643101-000.......................................162 T2050643201-000......................................145 T2050643201-000......................................162 T2050722101-000....................................... 146 T2050722101-000........................................163 T2050722201-000...................................... 146 T2050722201-000.......................................163 T2050802101-000.......................................156 T2050802201-000......................................156 T2050922101-000........................................161 T2050922201-000.......................................161 T2050962101-000.......................................157 T2050962201-000......................................157 T2051283101-000.........................................162 T2051283201-000........................................162 T2051442101-000........................................163 T2051442201-000.......................................163 T2060001025-000................................... 205 T2060001025-000................................... 305 T2060001035-000................................... 205 T2060001035-000................................... 305 T2060001050-000................................... 205 T2060001050-000................................... 305 T2060001070-000................................... 205 T2060001070-000................................... 305 T2060002025-000.................................. 205 T2060002025-000.................................. 305 T2060002035-000.................................. 205 T2060002035-000.................................. 305 T2060002050-000.................................. 205 T2060002050-000.................................. 305 T2060002070-000.................................. 205 T2060002070-000.................................. 305 T2060062101-000........................................171 T2060062101-000.......................................178 T2060062201-000.......................................171 T2060062201-000......................................178 T2060122101-000........................................178 T2060122201-000.......................................178 T2070002008-000...................................227 T2070002013-000.....................................227 T2070002033-000....................................227 T2070011008-000......................................227 T2070011013-000.......................................227 T2070011033-000......................................227 Part Number Page T2070012008-000.....................................227 T2070012013-000......................................227 T2070012033-000.....................................227 T2070064101-000..................................... 202 T2070064201-000.................................... 202 T2070104101-000...................................... 202 T2070104201-000..................................... 202 T2070164101-000...................................... 202 T2070164201-000..................................... 202 T2070244101-000..................................... 202 T2070244201-000.................................... 202 T2079104101-000...................................... 202 T2079104201-000..................................... 202 T2070001008-000....................................227 T2070001013-000......................................227 T2070001033-000.....................................227 T2080052101-000........................................ 32 T2080052101-000.......................................183 T2080052201-000....................................... 32 T2080052201-000......................................183 T2080062101-100........................................189 T2080062201-100.......................................189 T2080072101-000......................................... 31 T2080072101-000...................................... 184 T2080072201-000........................................ 31 T2080072201-000..................................... 184 T2080122101-000.......................................... 31 T2080122101-000....................................... 184 T2080122201-000......................................... 31 T2080122201-000...................................... 184 T2800152101-000...................................... 308 T2800152201-000..................................... 308 T2080172101-000.........................................189 T2080172201-000........................................189 T2090002101-001.......................................233 T2090002101-002......................................233 T2090002101-003......................................233 T2090002101-004......................................233 T2090002201-001......................................233 T2090002201-002.....................................233 T2090002201-003.....................................233 T2090002201-004.....................................233 T2090012201-001.......................................233 T2090012201-002......................................233 T2090012201-003......................................233 T2090012201-004......................................233 T2090062101-000...................................... 199 T2090062201-000..................................... 199 T2090102101-000....................................... 199 T2090102201-000...................................... 199 T2090162101-000....................................... 199 T2090162201-000...................................... 199 T2090242101-000...................................... 199 T2090242201-000..................................... 199 T2093362101-000........................................261 T2093362201-000.......................................261 359 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T2100032101-000...................................... 309 T2100032201-000..................................... 309 T2100042101-000.......................................247 T2100042201-000......................................247 T2100062101-000.......................................247 T2100062201-000......................................247 T2100063101-000......................................200 T2100122101-000.........................................259 T2100122201-000........................................259 T2100322101-000........................................237 T2100322201-000.......................................237 T2100063201-000.....................................200 T2100103101-000.......................................200 T2100103201-000......................................200 T2100163101-000.......................................200 T2100163201-000......................................200 T2100243101-000......................................200 T2100243201-000.....................................200 T2106062101-000.......................................245 T2106062201-000......................................245 T2110052101-000..........................................215 T2110052201-000.........................................215 T2111013101-000.......................................... 205 T2111013201-000......................................... 205 T2111020101-000......................................... 209 T2111020201-000........................................ 209 T2111022301-000.........................................233 T2111027101-000...........................................231 T2111027101-001.............................................231 T2111027101-002............................................231 T2111027201-000..........................................231 T2111027201-001............................................231 T2111027201-002...........................................231 T2111028101-000..........................................207 T2111028201-000.........................................207 T2111032101-000............................................211 T2111032201-000...........................................211 T2111032301-000.........................................233 T2111042101-000...........................................213 T2111042201-000..........................................213 T2111062101-000...........................................217 T2111062201-000..........................................217 T2111063101-000...........................................217 T2111063201-000..........................................217 T2111082101-000...........................................219 T2111082201-000..........................................219 T2111092101-000..........................................229 T2111092201-000.........................................229 T2111122101-000............................................221 T2111122201-000...........................................221 T2111172101-000............................................223 T2111172201-000...........................................223 T2111202101-000..........................................225 T2111202201-000.........................................225 T2111252101-000..........................................227 T2111252201-000.........................................227 Part Number Page T2113000101-100..........................................229 T2113000201-000.......................................229 T2114000101-000........................................229 T2114000201-000.......................................229 T2120142101-000.........................................249 T2120142201-000........................................249 T2120422101-000.........................................251 T2120422201-000........................................251 T2300033101-000.......................................168 T2300033201-000......................................168 T2300063101-000.......................................168 T2300063201-000......................................168 T2300103101-000........................................168 T2300103201-000.......................................168 T2400001100-000.................................... 209 T2400001160-000.................................... 209 T2400001250-000................................... 209 T2400002100-000................................... 209 T2400002160-000................................... 209 T2400002250-000.................................. 209 T2580011154-000........................................231 T2580012154-000.......................................231 T2580031154-000.......................................231 T2580032154-000......................................231 T2580081154-000.......................................231 T2580082154-000......................................231 T3100000001-000.......................................48 T3100000001-000.......................................49 T3100000001-000...................................... 110 T3100000001-000......................................165 T3100000001-000..................................... 190 T3100000001-000.......................................191 T3100000001-000.................................... 302 T3100000002-000......................................49 T3100000002-000.....................................165 T3100000002-000......................................191 T3100000003-000......................................48 T3100000003-000..................................... 110 T3100000003-000.................................... 190 T3100000003-000................................... 302 T3100000009-000.....................................48 T3100000009-000.....................................49 T3100000009-000.................................... 110 T3100000009-000....................................165 T3100000009-000................................... 190 T3100000009-000.....................................191 T3100000009-000.................................. 302 T3100000010-000.................................... 302 T3100000012-000.................................... 302 T3100000013-000.................................... 302 T3100000015-000.................................... 302 T3100000016-000.................................... 302 T3100000017-000.................................... 302 T3100000018-000.................................... 302 T3100001001-000..................................... 302 T3110009902-000......................................232 360 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T3033070901-000.....................................325 T3033091101-000.......................................325 T3033111301-000.........................................325 T3033111601-000.........................................325 T3033131601-000........................................325 T3033132101-000........................................325 T3033162050-000.....................................325 T3033162101-000........................................325 T3033202550-000....................................325 T3033212901-000.......................................325 T3033253250-000.....................................325 T3033293601-000......................................325 T3033324050-000....................................325 T3033364201-000.....................................325 T3033405050-000....................................325 T3033506350-000....................................325 T3403121000-000...................................... 310 T3403121350-000....................................... 310 T3403122000-000..................................... 310 T3071090701-000......................................325 T3071110701-000.........................................325 T3071130901-000.......................................325 T3071131101-000..........................................325 T3071160901-000.......................................325 T3071161101-000..........................................325 T3071161250-000........................................325 T3071161301-000.........................................325 T3071201250-000.......................................325 T3071201650-000......................................325 T3071211101-000..........................................325 T3071211301-000.........................................325 T3071211601-000.........................................325 T3071252050-000......................................325 T3071291601-000........................................325 T3071292101-000........................................325 T3071322050-000.....................................325 T3071322550-000......................................325 T3071362101-000........................................325 T3071362901-000.......................................325 T3071402550-000.....................................325 T3071403250-000.....................................325 T3071422901-000.......................................325 T3071423601-000.......................................325 T3071483601-000......................................325 T3071484201-000......................................325 T3071503250-000.....................................325 T3071504050-000.....................................325 T3071634050-000.....................................325 T3071635050-000.....................................325 T3100090001-000......................................318 T3100110101-000..........................................318 T3100120002-000.......................................318 T3100130001-000.......................................318 T3100160001-000.......................................318 T3100160002-000......................................318 T3100200002-000.....................................318 Part Number Page T3100210001-000........................................318 T3100250002-000......................................318 T3100290001-000......................................318 T3100320002-000......................................318 T3100360001-000......................................318 T3100400002-000.....................................318 T3100420001-000......................................318 T3100480001-000......................................318 T3100500002-000.....................................318 T3100630002-000.....................................318 T3101090101-000.........................................317 T3101110101-000...........................................317 T3101120102-000..........................................317 T3101130101-000..........................................317 T3101160101-000..........................................317 T3101160102-000.........................................317 T3101200102-000........................................317 T3101210101-000..........................................317 T3101250102-000........................................317 T3101290101-000.........................................317 T3101320102-000........................................317 T3101360101-000.........................................317 T3101400102-000........................................317 T3101420101-000.........................................317 T3101480101-000.........................................317 T3101500102-000........................................317 T3101630102-000........................................317 T3105070101-000...................................... 320 T3105070101-000.......................................328 T3105090101-000...................................... 320 T3105090101-000.......................................328 T3105110101-000........................................ 320 T3105110101-000.........................................328 T3105120021-000.......................................328 T3105120121-000........................................ 320 T3105130101-000....................................... 320 T3105160021-000.......................................328 T3105160101-000....................................... 320 T3105160101-000........................................328 T3105160121-000........................................ 320 T3105200021-000......................................328 T3105200121-000...................................... 320 T3105200121-000.......................................328 T3105210101-000....................................... 320 T3105210101-000........................................328 T3105250021-000......................................328 T3105250121-000....................................... 320 T3105250121-000........................................328 T3105290101-000...................................... 320 T3105290101-000.......................................328 T3105320021-000......................................328 T3105320121-000....................................... 320 T3105360101-000...................................... 320 T3105360101-000.......................................328 T3105400021-000......................................328 T3105400121-000...................................... 320 Part Number Page T3105420101-000...................................... 320 T3105420101-000.......................................328 T3105480101-000...................................... 320 T3105480101-000.......................................328 T3105500021-000......................................328 T3105500121-000...................................... 320 T3105500121-000.......................................328 T3105630021-000......................................328 T3105630121-000....................................... 320 T3111090101-000..........................................317 T3111110101-000.............................................317 T3111120102-000...........................................317 T3111130101-000............................................317 T3111160101-000............................................317 T3111160102-000...........................................317 T3111200102-000..........................................317 T3111210101-000............................................317 T3111250102-000..........................................317 T3111290101-000...........................................317 T3111320102-000..........................................317 T3111360101-000...........................................317 T3111400102-000.........................................317 T3111420101-000...........................................317 T3111480101-000...........................................317 T3111500102-000.........................................317 T3111630102-000..........................................317 T3115070101-000..........................................319 T3115090101-000.........................................319 T3115110101-000............................................319 T3115120121-000...........................................319 T3115130101-000...........................................319 T3115160101-000...........................................319 T3115160121-000...........................................319 T3115200121-000..........................................319 T3115210101-000...........................................319 T3115250121-000..........................................319 T3115290101-000..........................................319 T3115320121-000..........................................319 T3115360101-000..........................................319 T3115400121-000..........................................319 T3115420101-000..........................................319 T3115480101-000.........................................319 T3115500121-000..........................................319 T3115630121-000..........................................319 T3125160111-000..........................................329 T3125210111-000..........................................329 T3125320001-000......................................329 T3135090101-000........................................319 T3135110101-000...........................................319 T3135130101-000..........................................319 T3135160101-000..........................................319 T3135160121-000..........................................319 T3135200121-000.........................................319 T3135210101-000..........................................319 T3135250121-000.........................................319 T3135290101-000.........................................319 Part Number Page T3135320121-000.........................................319 T3135360101-000.........................................319 T3135400121-000.........................................319 T3135420101-000.........................................319 T3135480101-000........................................319 T3135500121-000.........................................319 T3135630121-000.........................................319 T3161070001-000.......................................324 T3161090001-000.......................................324 T3161110001-000.........................................324 T3161120050-000.......................................324 T3161130001-000........................................324 T3161160001-000........................................324 T3161160050-000.......................................324 T3161200050-000......................................324 T3161210001-000........................................324 T3161250050-000......................................324 T3161290001-000.......................................324 T3161320050-000......................................324 T3161360001-000.......................................324 T3161400050-000......................................324 T3161420001-000.......................................324 T3161480001-000.......................................324 T3161500050-000......................................324 T3161630050-000......................................324 T3165070101-000.......................................322 T3165070201-000......................................323 T3165090101-000.......................................322 T3165090201-000......................................323 T3165110101-000..........................................322 T3165110201-000.........................................323 T3165120111-000..........................................322 T3165120211-000.........................................323 T3165130101-000.........................................322 T3165130201-000........................................323 T3165160101-000.........................................322 T3165160111-000..........................................322 T3165160201-000........................................323 T3165160211-000.........................................323 T3165200111-000.........................................322 T3165200211-000........................................323 T3165210101-000.........................................322 T3165210201-000........................................323 T3165250111-000.........................................322 T3165250211-000........................................323 T3165290101-000........................................322 T3165290201-000.......................................323 T3165320111-000.........................................322 T3165320211-000........................................323 T3165360101-000.......................................322 T3165360201-000.......................................323 T3165400111-000........................................322 T3165400211-000.......................................323 T3165420101-000.......................................322 T3165420201-000......................................323 T3165480101-000.......................................322 361 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T3165480201-000......................................323 T3165500111-000.........................................322 T3165500211-000........................................323 T3165630111-000.........................................322 T3165630211-000........................................323 T3166070101-000.......................................322 T3166090101-000.......................................322 T3166110101-000..........................................322 T3166120111-000..........................................322 T3166130101-000.........................................322 T3166160101-000........................................322 T3166160111-000..........................................322 T3166200111-000.........................................322 T3166210101-000.........................................322 T3166250111-000.........................................322 T3166290101-000.......................................322 T3166320111-000.........................................322 T3166360101-000.......................................322 T3166400111-000........................................322 T3166420101-000.......................................322 T3166480101-000.......................................322 T3166500111-000........................................322 T3166630111-000.........................................322 T3169090101-000........................................321 T3169110101-000...........................................321 T3169120121-000..........................................321 T3169130101-000..........................................321 T3169160101-000.........................................321 T3169160111-000...........................................321 T3169200111-000..........................................321 T3169210101-000..........................................321 T3169250111-000..........................................321 T3169290101-000........................................321 T3169320111-000..........................................321 T3169360101-000........................................321 T3169400111-000.........................................321 T3169420101-000........................................321 T3169480101-000........................................321 T3169500111-000..........................................321 T3169630111-000..........................................321 T3201090101-000........................................316 T3201110101-000..........................................316 T3201120102-000.........................................316 T3201130101-000.........................................316 T3201160101-000.........................................316 T3201160102-000........................................316 T3201200102-000.......................................316 T3201210101-000..........................................316 T3201250102-000........................................316 T3201290101-000........................................316 T3201320102-000.......................................316 T3201360101-000........................................316 T3201400102-000.......................................316 T3201420101-000........................................316 T3201480101-000........................................316 T3201500102-000.......................................316 Part Number Page T3201630102-000.......................................316 T3209070160-000......................................313 T3209070161-000.......................................313 T3209090160-000.....................................313 T3209090161-000.......................................313 T3209110160-000........................................313 T3209110161-000..........................................313 T3209120102-000.......................................313 T3209120112-000.........................................313 T3209130160-000.......................................313 T3209130161-000.........................................313 T3209160102-000.......................................313 T3209160112-000.........................................313 T3209160160-000.......................................313 T3209160161-000........................................313 T3209200102-000......................................313 T3209200112-000.......................................313 T3209210160-000.......................................313 T3209210161-000.........................................313 T3209250102-000......................................313 T3209250112-000........................................313 T3209290160-000......................................313 T3209290161-000.......................................313 T3209320102-000......................................313 T3209320112-000........................................313 T3209360160-000......................................313 T3209360161-000.......................................313 T3209400102-000......................................313 T3209400112-000.......................................313 T3209420160-000......................................313 T3209420161-000.......................................313 T3209480160-000......................................313 T3209480161-000.......................................313 T3209500102-000......................................313 T3209500112-000.......................................313 T3209630102-000......................................313 T3209630112-000........................................313 T3211090101-000.........................................316 T3211110101-000............................................316 T3211120102-000..........................................316 T3211130101-000...........................................316 T3211160101-000...........................................316 T3211160102-000..........................................316 T3211200102-000.........................................316 T3211210101-000...........................................316 T3211250102-000.........................................316 T3211290101-000..........................................316 T3211320102-000.........................................316 T3211360101-000..........................................316 T3211400102-000........................................316 T3211420101-000..........................................316 T3211480101-000..........................................316 T3211500102-000........................................316 T3211630102-000.........................................316 T3229130101-000.........................................314 T3229160101-000.........................................314 362 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T3229160102-000........................................314 T3229160201-000........................................314 T3229200102-000......................................314 T3229200202-000.....................................314 T3229210101-000.........................................314 T3229210201-000........................................314 T3229210301-000........................................314 T3229210401-000........................................314 T3229250102-000.......................................314 T3229250202-000......................................314 T3229250302-000......................................314 T3229250402-000......................................314 T3229290101-000........................................314 T3229290201-000.......................................314 T3229290301-000.......................................314 T3229320102-000.......................................314 T3229320202-000......................................314 T3229320302-000......................................314 T3229360101-000........................................314 T3229360201-000.......................................314 T3229400102-000......................................314 T3229400202-000.....................................314 T3229420101-000.......................................314 T3229420201-000.......................................314 T3229480101-000.......................................314 T3229480201-000......................................314 T3229500102-000......................................314 T3229500202-000.....................................314 T3229630102-000.......................................314 T3229630202-000......................................314 T3262070001-000.....................................324 T3262090001-000.....................................324 T3262110001-000.......................................324 T3262120050-000.....................................324 T3262130001-000......................................324 T3262160001-000......................................324 T3262160050-000.....................................324 T3262200050-000....................................324 T3262210001-000......................................324 T3262250050-000....................................324 T3262290001-000.....................................324 T3262320050-000....................................324 T3262360001-000.....................................324 T3262400050-000....................................324 T3262420001-000.....................................324 T3262480001-000.....................................324 T3262500050-000....................................324 T3262630050-000....................................324 T3300120002-000......................................318 T3300160002-000.....................................318 T3300200002-000....................................318 T3300250002-000.....................................318 T3300320102-000......................................318 T3300400002-000....................................318 T3300500002-000....................................318 T3300630002-000....................................318 Part Number Page T3310010000-000.....................................326 T3310013000-000.....................................326 T3310015000-000.....................................326 T3310022000-000.....................................326 T3310028000-000....................................326 T3310034000-000....................................326 T3310040000-000....................................326 T3310054000-000....................................326 T3310079000-000....................................326 T3310105000-000.....................................326 T3333111102-000.........................................329 T3333111112-000...........................................328 T3333121201-000........................................329 T3333121211-000..........................................328 T3333131302-000.......................................329 T3333131312-000.........................................328 T3333161601-000........................................329 T3333161602-000.......................................329 T3333161611-000.........................................328 T3333161612-000........................................328 T3333202001-000.....................................329 T3333202011-000.......................................328 T3333212102-000.......................................329 T3333212112-000.........................................328 T3333252501-000......................................329 T3333252511-000........................................328 T3333292902-000.....................................329 T3333292912-000......................................328 T3333323201-000......................................329 T3333323211-000........................................328 T3333363602-000.....................................329 T3333363612-000......................................328 T3333404001-000.....................................329 T3333404011-000......................................328 T3333505001-000.....................................329 T3333505011-000.......................................328 T3333636301-000......................................329 T3333636311-000.......................................328 T3510111201-000......................................... 320 T3510120124-000....................................... 320 T3510130114-000........................................ 320 T3510130124-000....................................... 320 T3510130134-000....................................... 320 T3510160102-000...................................... 320 T3510161002-000...................................... 320 T3510160114-000....................................... 320 T3510160122-000....................................... 320 T3510160124-000....................................... 320 T3510161501-000........................................ 320 T3510201202-000...................................... 320 T3510201602-000..................................... 320 T3510201502-000..................................... 320 T3510212001-000...................................... 320 T3510210124-000....................................... 320 T3510252002-000..................................... 320 T3510251502-000...................................... 320 Part Number Page T3510292501-000...................................... 320 T3510290124-000...................................... 320 T3510322002-000.................................... 320 T3510320112-000....................................... 320 T3510363201-000...................................... 320 T3510403202-000.................................... 320 T3510420114-000...................................... 320 T3510480114-000...................................... 320 T3510500102-000..................................... 320 T3510635102-000...................................... 320 T3511070701-000.........................................321 T3511091001-000.........................................321 T3511100602-000........................................321 T3511111201-000............................................321 T3511120702-000.........................................321 T3511120702-001...........................................321 T3511131401-000...........................................321 T3511131401-001............................................321 T3511161002-000..........................................321 T3511161202-000..........................................321 T3511161701-000...........................................321 T3511201402-000.........................................321 T3511201702-000.........................................321 T3511212301-000..........................................321 T3511251702-000.........................................321 T3511252002-000........................................321 T3511252302-000........................................321 T3511292901-000.........................................321 T3511322302-000........................................321 T3511322602-000........................................321 T3511322902-000........................................321 T3511363601-000.........................................321 T3511402802-000........................................321 T3511403602-000.......................................321 T3511424301-000.........................................321 T3511484801-000.........................................321 T3511503502-000........................................321 T3511504802-000.......................................321 T3511634802-000........................................321 T3609070101-000.......................................312 T3609070111-000........................................312 T3609090101-000......................................312 T3609090111-000........................................312 T3609110101-000.........................................312 T3609110111-000...........................................312 T3609120102-000.......................................312 T3609120112-000.........................................312 T3609130101-000........................................312 T3609130111-000.........................................312 T3609160101-000........................................312 T3609160102-000.......................................312 T3609160111-000.........................................312 T3609160112-000........................................312 T3609160122-000.......................................312 T3609200102-000......................................312 T3609200112-000.......................................312 Part Number Page T3609200122-000......................................312 T3609210101-000........................................312 T3609210111-000..........................................312 T3609250102-000......................................312 T3609250112-000........................................312 T3609290101-000.......................................312 T3609290111-000........................................312 T3609320102-000......................................312 T3609320112-000........................................312 T3609360101-000.......................................312 T3609360111-000........................................312 T3609400102-000.....................................312 T3609400112-000.......................................312 T3609420101-000.......................................312 T3609420111-000........................................312 T3609480101-000.......................................312 T3609480111-000........................................312 T3609500102-000......................................312 T3609500112-000.......................................312 T3609630102-000......................................312 T3609630112-000.......................................312 T3629070101-000......................................327 T3629070111-000........................................327 T3629090101-000......................................327 T3629090111-000.......................................327 T3629110101-000.........................................327 T3629110111-000..........................................327 T3629120102-000.......................................327 T3629120112-000........................................327 T3629130101-000........................................327 T3629130111-000.........................................327 T3629160101-000.......................................327 T3629160102-000......................................327 T3629160111-000.........................................327 T3629160112-000........................................327 T3629200102-000.....................................327 T3629200112-000.......................................327 T3629210101-000........................................327 T3629210111-000.........................................327 T3629250102-000......................................327 T3629250112-000.......................................327 T3629290101-000......................................327 T3629290111-000........................................327 T3629320102-000......................................327 T3629320112-000.......................................327 T3629360101-000......................................327 T3629360111-000........................................327 T3629400102-000.....................................327 T3629400112-000......................................327 T3629420101-000......................................327 T3629420111-000........................................327 T3629480101-000......................................327 T3629480111-000........................................327 T3629500102-000.....................................327 T3629500112-000.......................................327 T3629630102-000.....................................327 363 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Part Number Page T3629630112-000.......................................327 T3707090101-000.......................................315 T3706110113-000..........................................315 T3707130101-000.........................................315 T3707160101-000.........................................315 T3609160103-000.......................................315 T3707160113-000.........................................315 T3706200103-000......................................315 T3707200113-Z00........................................315 T3707210101-000.........................................315 T3609250103-000......................................315 T3707250113-000........................................315 T3707290101-000........................................315 T3609320103-000......................................315 T3707320113-000........................................315 T3707360101-000........................................315 T3706400103-000......................................315 T3707400113-000........................................315 T3707420101-000........................................315 T3707480101-000........................................315 T3707500103-000......................................315 T3707500113-000........................................315 T3707630103-000.......................................315 T3707630113-000........................................315 T3709090101-000.......................................315 T3709090111-000........................................315 T3709090121-000.......................................315 T3709110101-000.........................................315 T3709110111-000...........................................315 T3709110121-000..........................................315 T3709130101-000........................................315 T3709130111-000..........................................315 T3709130121-000.........................................315 T3709160101-000........................................315 T3709160102-000.......................................315 T3709160111-000..........................................315 T3709160112-000.........................................315 T3709160121-000.........................................315 T3709160122-000........................................315 T3709200102-000......................................315 T3709200112-000........................................315 T3709200122-000.......................................315 T3709210101-000.........................................315 T3709210111-000..........................................315 T3709210121-000.........................................315 T3709250102-000.......................................315 T3709250112-000........................................315 T3709250122-000.......................................315 T3709250132-000.......................................315 T3709290101-000.......................................315 T3709290111-000.........................................315 T3709290121-000........................................315 T3709320102-000.......................................315 T3709320112-000........................................315 T3709320122-000.......................................315 T3709360101-000.......................................315 Part Number Page T3709360111-000.........................................315 T3709360121-000........................................315 T3709400102-000......................................315 T3709400112-000.......................................315 T3709400122-000......................................315 T3729130101-000.........................................314 T3729160101-000.........................................314 T3729160102-000........................................314 T3729160201-000........................................314 T3729200102-000.......................................314 T3729200202-000......................................314 T3729210101-000.........................................314 T3729210201-000........................................314 T3729210301-000........................................314 T3729210401-000........................................314 T3729250102-000.......................................314 T3729250202-000......................................314 T3729250302-000......................................314 T3729250402-000......................................314 T3729290101-000........................................314 T3729290201-000.......................................314 T3729290301-000.......................................314 T3729320102-000.......................................314 T3729320202-000......................................314 T3729320302-000......................................314 T3729360101-000........................................314 T3729360201-000.......................................314 T3729400102-000......................................314 T3729400202-000.....................................314 T3729420101-000........................................314 T3729420201-000.......................................314 T3729480101-000........................................314 T3729480201-000.......................................314 T3729500102-000......................................314 T3729500202-000......................................314 T3729630102-000.......................................314 T3729630202-000......................................314 T3265090901-000.....................................327 T3265111101-000..........................................327 T3265131301-000........................................327 T3265160101-000........................................327 T3265161611-000.........................................327 T3265202011-000.......................................327 T3265212101-000........................................327 T3265252511-000........................................327 T3265252511-000........................................327 T3265292901-000......................................327 T3265404011-000......................................327 T3910020601-000......................................326 T3910030801-000......................................326 T3910041301-000.......................................326 T3910102001-000.......................................326 T3910153201-000........................................326 T3920030801-000.....................................326 T3920041301-000......................................326 T3920102001-000......................................326 364 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Part Number Page T3920153201-000.......................................326 T3930010600-000....................................326 T3930030801-000.....................................326 T3930041301-000......................................326 T3930051100-000......................................326 T3930101700-000......................................326 T3930102001-000......................................326 T3930153201-000.......................................326 T3105130101-000........................................328 T3100000002-000................................... 302 Notes 365 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. Notes 366 AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS Notes 367 All specifications subject to change. Consult TE Connectivity for latest design specifications. Contact TE for assistance with any part number configuration. te.com TE Connectivity, TE Connectivity (logo) and Every Connection Counts are trademarks. All other logos, products and/or company names referred to herein might be trademarks of their respective owners. While TE has made every reasonable effort to ensure the accuracy of the information in this brochure, TE does not guarantee that it is error-free, nor does TE make any other representation, warranty, or guarantee that the information is accurate, correct, reliable, or current. TE reserves the right to make any adjustments to the information contained herein at any time without notice. TE expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. The dimensions in this catalog are for reference purposes only and are subject to change without notice. Specifications are subject to change without notice. Consult TE for the latest dimensions and design specifications. © 2017 TE Connectivity Ltd. family of companies 1-1773869-8 05/2017 Original: WR AUTOMATION & CONTROL /// HEAVY DUTY CONNECTORS All Rights Reserved. CATALOG TE Connectivity Automation & Control Pfnorstr. 1 D-64293 Darmstadt Germany +49 6151 607 1999 te.com
T1320320129-000 价格&库存
很抱歉,暂时无法提供与“T1320320129-000”相匹配的价格&库存,您可以联系我们找货
T1320320129-000
    • 1+64.44360
    • 200+25.71480
    • 500+24.85080
    • 1000+24.42960
    T1320320129-000
    • 1+263.842371+34.30678
    • 10+224.2590910+29.15986
    库存:24
