4
RELEASED FOR PUBLICATION
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
3
1
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
LTR
A
B
DESCRIPTION
DATE
DWN
APVD
INTIAL RELEASE
19JUN2015
DL
CW
ECR-20-008190
09SEP2020
WQR
CW
117
105
4-M3
45
57
4-
D
77.5
5.5
27
D
( 119 )
53.8
C
33
IG1
19.5
( 73.4 )
56.6
IG2
19.5
C
45
4- R 5
TYPE 3: BODY + STAINLESS STEEL LOCKING
BOTTOM CUT OUT
OTHER SPEC REFER TO TYPE 1
TYPE 1: BODY + STAINLESS STEEL LOCKING
B
B
NOTES:
1. TECHNICAL CHARACTERISTICS:
BODY MATERIAL: DIE CAST ALUMINIUM ALLOY
SURFACE TREATMENT: POWDER-COATED, COLOR SEE TABLE
DEGREE OF PROTECTION: IP65 (MATED)
1.
: IP65(
T1440161121-000
H16B-SGRS-PG21
T1440161125-000
T1440161221-000
A
H16B-SGRS-2M25
M25
PG21
PG21
M25
M25
TYPE 2
H16B-SGRS-PG21
SILVER WHITE
PG21
T1440160000-000
TYPE 3
H16B-SGRS-T
GRAY
ASSEMBLY PART
NUMBER
TYPE
ASSEMBLY PART
DESCRIPTION
COLOR
IG1
IG2
mm
MATERIAL
T1440161121-100
DIMENSIONS:
TYPE 2: BODY + STAINLESS STEEL LOCKING
SILVER WHITE COATED
GRAY
H16B-SGRS-2PG21
T1440161225-000
THIS DRAWING IS A CONTROLLED DOCUMENT.
1471-9 (3/13)
H16B-SGRS-M25
TYPE 1
PG21
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
0 PLC
1 PLC
2 PLC
3 PLC
4 PLC
ANGLES
FINISH
DWN
DAVID LI
19JUN2015
CHK
19JUN2015
APVD
19JUN2015
CHRIS WANG
XU XIANG
TE Connectivity
NAME
PRODUCT SPEC
A
H16B-SGRS-PG/M
108-137013
APPLICATION SPEC
114-137013
WEIGHT
CUSTOMER DRAWING
SIZE
A2
CAGE CODE
RESTRICTED TO
DRAWING NO
T144016XXXXX00
SCALE
1:1
SHEET
1
OF
2
REV
B
4
C
COPYRIGHT
3
1
REVISIONS
BY -
P
LTR
DESCRIPTION
DATE
SEE SHEET 1
DWN
APVD
D
D
53.4
( 120 )
C
C
( 75.3 )
IG4
IG2
IG1
TYPE 4: BODY + STEEL LOCKING
TYPE 6: BODY + STEEL LOCKING
BOTTOM 1 HOLE
OTHER SPEC REFER TO TYPE 4
B
B
6-IG3
T1440162121-000
H16B-SGR-PG21
PG21
T1440162125-000
H16B-SGR-M25
M25
T1440162221-000
H16B-SGR-2PG21
PG21
PG21
H16B-SGR-2M25
M25
M25
M25
PG16
T1440162225-000
TYPE 4
T1440161625-000
H16B-SGR-M25/PG16
T1440162521-000
H16B-SGR-M25/PG21
M25
PG21
T1440162532-000
H16B-SGR-M25/M32
M25
M32
T1440162609-000
TYPE 5
H16B-SGR-6PG9
PG9
T1440165125-000
TYPE 6
H16B-SGR-TM25
M25
IG1
IG2
IG3
IG4
ASSEMBLY PART
NUMBER
TYPE
A
DIMENSIONS:
mm
TYPE 5: BODY+ STEEL LOCKING
FRONT/BACK 6 HOLE
1471-9 (3/13)
GRAY
MATERIAL
TOLERANCES UNLESS
0 PLC
1 PLC
2 PLC
3 PLC
4 PLC
ANGLES
FINISH
ASSEMBLY PART
DESCRIPTION
DWN
19JUN2015
CHK
19JUN2015
APVD
19JUN2015
DAVID LI
CHRIS WANG
XU XIANG
COLOR
TE Connectivity
NAME
PRODUCT SPEC
A
H16B-SGR-PG/M
108-137013
APPLICATION SPEC
114-137013
WEIGHT
CUSTOMER DRAWING
SIZE
A2
CAGE CODE
RESTRICTED TO
DRAWING NO
T144016XXXXX00
SCALE
4:5
SHEET
2
OF
2
REV
B
很抱歉,暂时无法提供与“T1440161625-000”相匹配的价格&库存,您可以联系我们找货
