T1440165125-000
T1440165125-000
    HUMIREL(泰科)
    H16B-SGR-TM25
T1440165125-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P LTR A B DESCRIPTION DATE DWN APVD INTIAL RELEASE 19JUN2015 DL CW ECR-20-008190 09SEP2020 WQR CW 117 105 4-M3 45 57 4- D 77.5 5.5 27 D ( 119 ) 53.8 C 33 IG1 19.5 ( 73.4 ) 56.6 IG2 19.5 C 45 4- R 5 TYPE 3: BODY + STAINLESS STEEL LOCKING BOTTOM CUT OUT OTHER SPEC REFER TO TYPE 1 TYPE 1: BODY + STAINLESS STEEL LOCKING B B NOTES: 1. TECHNICAL CHARACTERISTICS: BODY MATERIAL: DIE CAST ALUMINIUM ALLOY SURFACE TREATMENT: POWDER-COATED, COLOR SEE TABLE DEGREE OF PROTECTION: IP65 (MATED) : 1. : : : , : IP65( T1440161121-000 H16B-SGRS-PG21 T1440161125-000 T1440161221-000 A H16B-SGRS-2M25 M25 - PG21 PG21 M25 M25 TYPE 2 H16B-SGRS-PG21 SILVER WHITE PG21 - T1440160000-000 TYPE 3 H16B-SGRS-T GRAY - - ASSEMBLY PART NUMBER TYPE ASSEMBLY PART DESCRIPTION COLOR IG1 IG2 mm MATERIAL - T1440161121-100 DIMENSIONS: TYPE 2: BODY + STAINLESS STEEL LOCKING SILVER WHITE COATED OTHER SPEC REFER TO TYPE 1 GRAY H16B-SGRS-2PG21 T1440161225-000 ) THIS DRAWING IS A CONTROLLED DOCUMENT. 1471-9 (3/13) H16B-SGRS-M25 TYPE 1 PG21 - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - DWN DAVID LI 19JUN2015 CHK 19JUN2015 APVD 19JUN2015 CHRIS WANG XU XIANG TE Connectivity NAME PRODUCT SPEC A H16B-SGRS-PG/M 108-137013 APPLICATION SPEC - 114-137013 WEIGHT CUSTOMER DRAWING SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T144016XXXXX00 SCALE 1:1 SHEET 1 OF 2 REV B 4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P LTR - DESCRIPTION DATE SEE SHEET 1 DWN APVD - - - D D 53.4 ( 120 ) C C ( 75.3 ) IG4 IG2 IG1 TYPE 4: BODY + STEEL LOCKING TYPE 6: BODY + STEEL LOCKING BOTTOM 1 HOLE OTHER SPEC REFER TO TYPE 4 OTHER SPEC REFER TO TYPE 1 B B 6-IG3 T1440162121-000 H16B-SGR-PG21 PG21 - - - T1440162125-000 H16B-SGR-M25 M25 - - - T1440162221-000 H16B-SGR-2PG21 PG21 PG21 - - H16B-SGR-2M25 M25 M25 - - M25 PG16 - - T1440162225-000 TYPE 4 T1440161625-000 H16B-SGR-M25/PG16 T1440162521-000 H16B-SGR-M25/PG21 M25 PG21 - - T1440162532-000 H16B-SGR-M25/M32 M25 M32 - - T1440162609-000 TYPE 5 H16B-SGR-6PG9 - - PG9 - T1440165125-000 TYPE 6 H16B-SGR-TM25 - - - M25 IG1 IG2 IG3 IG4 ASSEMBLY PART NUMBER TYPE THIS DRAWING IS A CONTROLLED DOCUMENT. A DIMENSIONS: mm TYPE 5: BODY+ STEEL LOCKING FRONT/BACK 6 HOLE OTHER SPEC REFER TO TYPE 4 1471-9 (3/13) GRAY MATERIAL - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - ASSEMBLY PART DESCRIPTION DWN 19JUN2015 CHK 19JUN2015 APVD 19JUN2015 DAVID LI CHRIS WANG XU XIANG COLOR TE Connectivity NAME PRODUCT SPEC A H16B-SGR-PG/M 108-137013 APPLICATION SPEC - 114-137013 WEIGHT CUSTOMER DRAWING SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T144016XXXXX00 SCALE 4:5 SHEET 2 OF 2 REV B
T1440165125-000 价格&库存
很抱歉,暂时无法提供与“T1440165125-000”相匹配的价格&库存,您可以联系我们找货
T1440165125-000
  • 24+153.3658224+19.92145
