T1470242932-000
T1470242932-000
    HUMIREL(泰科)
    H24B-SGRH-PG29/M32
T1470242932-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P LTR A TYPE 1: HIGH CONSTRUCTION + STATINLESS STELL LOCKING. 1: + . A1 B C DESCRIPTION DATE DWN APVD INITIAL 30DEC2016 DL CW ECR-16-018258 30DEC2016 BS CW ECR-18-016391 22OCT2018 GY CW ECR-20-014876 21JUL2021 WQR CW D 27 D NOTES: 104 1. TECHNICAL CHARACTERISTICS: HOUSING MATERIAL: DIE CAST ALUMINIUM ALLOY HOUSING SURFACE: POWDER COATED, GREY DEGREE OF PROTECTION: IP65 (MATED) 4X M3 THREAD 4X M3 ( 147.8 ) : 1. : : : : IP65( ) C PG/M THREAD-2 -2 144 ( 93.9 ) 75.6 C PG/M THREAD-1 -1 T1470241121-000 T1470241129-000 57 45 B T1470241132-000 T1470241221-000 4X 5.5 H24B-SGRHS-PG21 H24B-SGRHS-PG29 H24B-SGRHS-M32 H24B-SGRHS-2PG21 132 T1470241229-000 HOUSING T1470241232-000 H24B-SGRHS-2PG29 H24B-SGRHS-2M32 H24B HOUSING, SURFACE MOUNTED, STAINLESS STEEL DOUBLE LOCKING, PG21, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,PG21, , H24B HOUSING, SURFACE MOUNTED, STAINLESS STEEL DOUBLE LOCKING, PG29, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,PG29, , H24B HOUSING, SURFACE MOUNTED, STAINLESS STEEL DOUBLE LOCKING, 2M32, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,2M32, , PART DESCRIPTION A DIMENSIONS: mm MATERIAL 1471-9 (3/13) TBD - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - 17JUN2015 CHK 17JUN2015 APVD 17JUN2015 DAVID LI CHRIS WANG XU XIANG - TYPE 1 1 PG21 PG21 PG29 PG29 M32 M32 PG/M THREAD-1 -1 PG/M THREAD-2 -2 H24B HOUSING, SURFACE MOUNTED, STAINLESS STEEL DOUBLE LOCKING, 2PG29, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,2PG29, , DWN PG29 M32 H24B HOUSING, SURFACE MOUNTED, STAINLESS STEEL DOUBLE LOCKING, 2PG21, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,2PG21, , THIS DRAWING IS A CONTROLLED DOCUMENT. - B H24B HOUSING, SURFACE MOUNTED, STAINLESS STEEL DOUBLE LOCKING, M32, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,M32, , PART NUMBER PG21 TYPE TE Connectivity NAME PRODUCT SPEC A H24B-SGRHS-PG/M 108-137013 APPLICATION SPEC - 114-137013 WEIGHT CUSTOMER DRAWING SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T147024XXXX000 SCALE 4:5 SHEET 1 OF 2 REV C 4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P LTR - TYPE 2: HIGH CONSTRUCTION + STELL LOCKING, OTHER SPEC REFER TO TYPE 1. 2: + , 1. DESCRIPTION DATE SEE SHEET 1 DWN - - APVD - D D NOTES: SEE SHEET 1 ( 147.8 ) C ( 93.9 ) T1470242121-000 T1470242125-000 T1470242129-000 T1470242132-000 T1470242221-000 PG/M THREAD-1 -1 PG/M THREAD-2 -2 T1470242225-000 T1470242229-000 B T1470242232-000 T1470242921-000 PG/M THREAD-3 -3 T1470242932-000 T1470243216-000 T1470242229-001 H24B-SGRH-PG21 H24B-SGRH-M25 H24B-SGRH-PG29 H24B-SGRH-M32 H24B-SGRH-2PG21 H24B-SGRH-2M25 H24B-SGRH-2PG29 H24B-SGRH-2M32 H24B-SGRH-PG21/PG29 H24B-SGRH-PG29/M32 H24B-SGRH-M32/M16 H24B-SGRH-2PG29/M32 H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, M25, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,M25, , H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, PG29, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,PG29, , H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, M32, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,M32, , H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, 2PG21, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,2PG21, , H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, 2M25, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,2M25, , H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, PG29/M32, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,PG29/M32, , H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, M32/M16, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,M32/M16, , H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, 2PG29, BOTTOM ENTRY M32, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,2PG29, M32, , PART DESCRIPTION A DIMENSIONS: mm MATERIAL TBD - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - 17JUN2015 CHK 17JUN2015 APVD 17JUN2015 DAVID LI CHRIS WANG XU XIANG - M25 - - PG29 - - M32 - - PG21 PG21 - M25 M25 - PG29 - B H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, PG21/PG29, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,PG21/PG29, , DWN - PG29 H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, 2M32, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,2M32, , THIS DRAWING IS A CONTROLLED DOCUMENT. PG21 TYPE 2 2 H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, 2PG29, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,2PG29, , PART NUMBER 1471-9 (3/13) C H24B HOUSING, SURFACE MOUNTED, METAL DOUBLE LOCKING, PG21, HIGH CONSTRUCTION, POWDER COATED, GREY H24B , , ,PG21, , M32 M32 - PG21 PG29 - PG29 M32 - M32 M16 - PG29 PG29 M32 PG/M THREAD-1 -1 PG/M THREAD-2 -2 PG/M THREAD-3 -3 TYPE TE Connectivity NAME PRODUCT SPEC A H24B-SGRH-PG/M 108-137013 APPLICATION SPEC - 114-137013 WEIGHT CUSTOMER DRAWING SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T147024XXXX000 SCALE 1:2 SHEET 2 OF 2 REV C
T1470242932-000 价格&库存
很抱歉,暂时无法提供与“T1470242932-000”相匹配的价格&库存,您可以联系我们找货
T1470242932-000
