T1510162000-000
T1510162000-000
    HUMIREL(泰科)
    基座 - 面板安装 连接器 底部进入 H16B IP65 - 防尘,耐水
T1510162000-000 数据手册
T1510162000-000 Heavy Duty Connector Base Housing, Locking Clip, Sealable, HDC IP65 T1510162000-000  ACTIVE HDC | HDC IP65 TE Internal #: T1510162000-000 Heavy Duty Connector Base Housing, Locking Clip, Sealable, HDC IP65 View on TE.com > Connectors > Rectangular Connectors > Rectangular Connector Hoods & Bases Hood & Base Connector Product Type: Base Housing Hood & Base Locking Device Type: Locking Clip Sealable: Yes Circuit Application: Power & Signal Features Product Type Features Hood & Base Connector Product Type Base Housing Sealable Yes Mechanical Attachment Hood & Base Locking Device Type Locking Clip Housing Features Housing Material Die Cast Aluminum Usage Conditions Corrosion Protected Yes Operation/Application Circuit Application Power & Signal Product Compliance For compliance documentation, visit the product page on TE.com>  EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Compliant China RoHS 2 Directive MIIT Order No 32, 2016 For support call+1 800 522 6752 No Restricted Materials Above Threshold 01/03/2024 12:29AM | Page 1 T1510162000-000 Heavy Duty Connector Base Housing, Locking Clip, Sealable, HDC IP65 EU ELV Directive 2000/53/EC Compliant China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JAN 2022 (223) Does not contain REACH SVHC Halogen Content Not Low Halogen - contains Br or Cl > 900 ppm. Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts TE Part # T2040162201-000 TE Part # T1310160132-000 HE-016-F H16B-TS-RO-M32 Also in the Series HDC IP65 Rectangular Connector Hoods & Bases (1258) Customers Also Bought  For support call+1 800 522 6752 01/03/2024 12:29AM | Page 2 T1510162000-000 Heavy Duty Connector Base Housing, Locking Clip, Sealable, HDC IP65 TE Part #T4111501041-000 TE Part #0462-209-16141 TE Part #1648568-1 TE Part #1650589-1 M12,MALE,STRAIGHT,D CODE,4P, PG7,GOLD DEUTSCH Solid Contacts 295-0093-01100=CONN,PIN,MARKED 903-19-02113=SCREW,SHOULDER,M4 TE Part #T1510102100-000 TE Part #T2030001002-000 TE Part #T2030001030-000 TE Part #T2030002002-000 H10B-ADMS-LB CEM-0.3 CEM-3.0 CEF-0.3 TE Part #T2030002030-000 CEF-3.0 Documents Product Drawings H16B-ADS-LB English CAD Files 3D PDF 3D Customer View Model ENG_CVM_CVM_T1510162000-000_A.2d_dxf.zip English Customer View Model ENG_CVM_CVM_T1510162000-000_A.3d_igs.zip English Customer View Model ENG_CVM_CVM_T1510162000-000_A.3d_stp.zip English By downloading the CAD file I accept and agree to the Terms and Conditions of use. Product Specifications  Application Specification For support call+1 800 522 6752 01/03/2024 12:29AM | Page 3 T1510162000-000 Heavy Duty Connector Base Housing, Locking Clip, Sealable, HDC IP65 Application Specification English  For support call+1 800 522 6752 01/03/2024 12:29AM | Page 4
T1510162000-000 价格&库存
很抱歉,暂时无法提供与“T1510162000-000”相匹配的价格&库存,您可以联系我们找货
T1510162000-000
  • 6+160.84661
  • 18+135.31041
  • 36+100.29487
  • 50+97.98549
  • 100+93.28209
  • 250+88.48196
  • 500+81.46918
库存:33
T1510162000-000
    • 6+231.49632
    • 18+194.74081
    • 36+144.34959
    • 50+141.03078
    • 100+134.25643
    • 250+127.34535
    • 500+117.25219
    库存:33
    T1510162000-000
    • 1+194.555291+25.20283
    • 10+165.3154710+21.41509
    • 25+154.9646525+20.07423
    库存:30
