T1660243121-000
T1660243121-000
    HUMIREL(泰科)
    T1660243121-000
T1660243121-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P LTR A A1 4X M3 THREAD 4X M3 B 104 DESCRIPTION DATE DWN APVD INITIAL RELEASE 02JUL2015 DL CW ECR-18-019196 02JAN2019 WQR CW ECR-20-014876 27JUL2021 WQR CW D (93.1) 43 27 D 120 135.7 ( 114.7 ) IG2 TYPE 2: H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING+PLASTIC PROTECTION OTHER SPEC REFER TO TYPE 1 2: H24B , , + 1 COVER (96.8) ( 76.8 ) 5.5 57 4- 45 IG1 C 20 20 C 56.6 ( 76.6 ) 130.5 132 144 TYPE 1: H24B HOUSING, SURFACE MOUNTED, METAL SINGLE LOCKING. 1: H24B , , . B 139.6 ( 114.9 ) B NOTES: 1. TECHNICAL CHARACTERISTICS: BODY MATERIAL: DIE CAST ALUMINIUM ALLOY SURFACE TREATMENT: POWDER-COATED, GRAY DEGREE OF PROTECTION: IP65 (MATED) : 1. A : : : , : IP65( TYPE 3: H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING+METAL PROTECTION COVER OTHER SPEC REFER TO TYPE 1 3: H24B , , + 1 THIS DRAWING IS A CONTROLLED DOCUMENT. ) DIMENSIONS: mm MATERIAL 1471-9 (3/13) - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - DWN 02JUL2015 CHK 02JUL2015 APVD 02JUL2015 DAVID LI CHRIS WANG XU XIANG TE Connectivity NAME PRODUCT SPEC 108-137013 A H24B-SGR/SDR/SDRM/SGRH/SDRH/ SDRHM-LB-PG/M APPLICATION SPEC - 114-137013 WEIGHT Customer Drawing SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T16X0243XXXX00 SCALE 1:2 SHEET 1 OF - 4 REV B 4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P - M20 DESCRIPTION DATE SEE SHEET 1 DWN APVD - - - D (93.1) D LTR ( 114.7 ) 135.7 C H24B-SGR-LB-PG21 H24B HOUSING,SURFACE MOUNTED, METAL SINGLE LOCKING,PG21,POWDER COATED,GREY H24B , , ,PG21, H24B-SGR-LB-M25 H24B HOUSING,SURFACE MOUNTED, METAL SINGLE LOCKING,M25,POWDER COATED,GREY H24B , , ,M25, H24B-SGR-LB-2PG21 H24B HOUSING,SURFACE MOUNTED, METAL SINGLE LOCKING,2PG21,POWDER COATED,GREY H24B , , ,2PG21, H24B-SGR-LB-2M25 H24B HOUSING,SURFACE MOUNTED, METAL SINGLE LOCKING,2M25,POWDER COATED,GREY H24B , , ,2M25, H24B-SDR-LB-PG21 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,PG21, PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,PG21, , H24B-SDR-LB-M25 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,M25, PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,M25, , H24B-SDR-LB-2PG21 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2PG21, PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,2PG21, , T1620243225-000 H24B-SDR-LB-2M25 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2M25, PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,2M25, , T1620243421-000 H24B-SDRM-LB-PG21 T1620243425-000 T1610243121-000 T1610243125-000 T1610243221-000 TYPE 4: H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,SIDE ENTRY 2M25, BOTTOM ENTRY M20+PLASTIC PROTECTION COVER OTHER SPEC REFER TO TYPE 2 4: H24B , , , 2M25, M20+ 2 T1610243225-000 T1620243121-000 T1620243125-000 T1620243221-000 B - M25 - C TYPE 1 1 PG21 PG21 M25 M25 PG21 - M25 TYPE 2 2 PG21 PG21 M25 M25 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, PG21,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,PG21, , PG21 - H24B-SDRM-LB-M25 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, M25,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,M25, , M25 - T1620243321-000 H24B-SDRM-LB-2PG21 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, 2PG21,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,2PG21, , PG21 PG21 T1620243325-000 H24B-SDRM-LB-2M25 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, 2M25,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,2M25, , M25 M25 M25 M25 IG1 IG2 T1620242520-000 H24B-SDR-LB-2M25/M20 DESCRIPTION THIS DRAWING IS A CONTROLLED DOCUMENT. A DIMENSIONS: mm MATERIAL - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - DWN 02JUL2015 CHK 02JUL2015 APVD 02JUL2015 DAVID LI CHRIS WANG XU XIANG B TYPE 3 3 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,SIDE ENTRY 2M25, BOTTOM ENTRY M20,PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , , 2M25, M20, , PART NUMBER 1471-9 (3/13) PG21 TYPE 4 4 TYPE TE Connectivity NAME PRODUCT SPEC 108-137013 A H24B-SGR/SDR/SDRM/SGRH/SDRH/ SDRHM-LB-PG/M APPLICATION SPEC - 114-137013 WEIGHT Customer Drawing SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T16X0243XXXX00 SCALE 1:2 SHEET 2 OF - 4 REV B 4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P LTR 4X M3 THREAD 4X M3 DESCRIPTION DATE SEE SHEET 1 DWN APVD - - - 104 (93.1) 27 43 D D 120 135.7 IG1 ( 77 ) 57 45 5.5 ( 133.7 ) TYPE 6: H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, HIGH CONSTRUCTION+PLASTIC PROTECTION COVER OTHER SPEC REFER TO TYPE 5 6: H24B , , , + 5 (96.8) IG2 4- C 26 26 C 75.6 ( 95.8 ) 130.5 132 144 TYPE 5: H24B HOUSING,SURFACE MOUNTED, METAL SINGLE LOCKING,HIGH CONSTRUCTION 5: H24B , , , 139.6 B ( 133.9 ) B TYPE 7: H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, HIGH CONSTRUCTION+METAL PROTECTION COVER OTHER SPEC REFER TO TYPE 5 7: H24B , , , + 5 THIS DRAWING IS A CONTROLLED DOCUMENT. A DIMENSIONS: mm MATERIAL 1471-9 (3/13) - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - DWN 02JUL2015 CHK 02JUL2015 APVD 02JUL2015 DAVID LI CHRIS WANG XU XIANG TE Connectivity NAME PRODUCT SPEC 108-137013 A H24B-SGR/SDR/SDRM/SGRH/SDRH/ SDRHM-LB-PG/M APPLICATION SPEC - 114-137013 WEIGHT Customer Drawing SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T16X0243XXXX00 SCALE 1:2 SHEET 3 OF - 4 REV B 4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P LTR - D C B DATE SEE SHEET 1 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, PG21,HIGH CONSTRUCTION,POWDER COATED,GREY H24B , , ,PG21, , PG21 - T1650243125-000 H24B-SGRH-LB-M25 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, M25,HIGH CONSTRUCTION,POWDER COATED,GREY H24B , , ,M25, , M25 - T1650243129-000 H24B-SGRH-LB-PG29 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, PG29,HIGH CONSTRUCTION,POWDER COATED,GREY H24B , , ,PG29, , PG29 - T1650243132-000 H24B-SGRH-LB-M32 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, M32,HIGH CONSTRUCTION,POWDER COATED,GREY H24B , , ,M32, , M32 - T1650243221-000 H24B-SGRH-LB-2PG21 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, 2PG21,HIGH CONSTRUCTION,POWDER COATED,GREY H24B , , ,2PG21, , PG21 PG21 T1650243229-000 H24B-SGRH-LB-2PG29 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, 2PG29,HIGH CONSTRUCTION,POWDER COATED,GREY H24B , , ,2PG29, , PG29 PG29 T1650243232-000 H24B-SGRH-LB-2M32 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING, 2M32,HIGH CONSTRUCTION,POWDER COATED,GREY H24B , , ,2M32, , M32 M32 T1660243121-000 H24B-SDRH-LB-PG21 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,PG21, HIGH CONSTRUCTION,PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,PG21, , , PG21 - T1660243129-000 H24B-SDRH-LB-PG29 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,PG29, HIGH CONSTRUCTION,PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,PG29, , , PG29 - T1660243132-000 H24B-SDRH-LB-M32 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,M32, HIGH CONSTRUCTION,PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,M32, , , M32 - T1660243221-000 H24B-SDRH-LB-2PG21 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2PG21, HIGH CONSTRUCTION,PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,2PG21, , , PG21 PG21 T1660243229-000 H24B-SDRH-LB-2PG29 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2PG29, HIGH CONSTRUCTION,PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,2PG29, , , PG29 PG29 T1660243232-000 H24B-SDRH-LB-2M32 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2M32, HIGH CONSTRUCTION,PLASTIC PROTECTION COVER,POWDER COATED,GREY H24B , , ,2M32, , , M32 M32 T1660243121-100 H24B-SDRHM-LB-PG21 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,PG21, HIGH CONSTRUCTION,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,PG21, , , PG21 - T1660243129-100 H24B-SDRHM-LB-PG29 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,PG29, HIGH CONSTRUCTION,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,PG29, , , PG29 - H24B-SDRHM-LB-M32 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,M32, HIGH CONSTRUCTION,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,M32, , , M32 - T1660243221-100 H24B-SDRHM-LB-2PG21 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2PG21, HIGH CONSTRUCTION,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,2PG21, , , PG21 PG21 T1660243229-100 H24B-SDRHM-LB-2PG29 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2PG29, HIGH CONSTRUCTION,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,2PG29, , , PG29 PG29 H24B-SDRHM-LB-2M32 H24B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2M32, HIGH CONSTRUCTION,METAL PROTECTION COVER,POWDER COATED,GREY H24B , , ,2M32, , , M32 M32 IG1 IG2 PART NUMBER A DIMENSIONS: mm MATERIAL - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - DWN 02JUL2015 CHK 02JUL2015 APVD 02JUL2015 DAVID LI CHRIS WANG XU XIANG - - TYPE 5 5 C TYPE 6 6 B TYPE 7 7 DESCRIPTION THIS DRAWING IS A CONTROLLED DOCUMENT. APVD D H24B-SGRH-LB-PG21 T1660243232-100 DWN - T1650243121-000 T1660243132-100 1471-9 (3/13) DESCRIPTION TYPE TE Connectivity NAME PRODUCT SPEC 108-137013 A H24B-SGR/SDR/SDRM/SGRH/SDRH/ SDRHM-LB-PG/M APPLICATION SPEC - 114-137013 WEIGHT Customer Drawing SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T16X0243XXXX00 SCALE 1:2 SHEET 4 OF - 4 REV B
T1660243121-000 价格&库存
很抱歉,暂时无法提供与“T1660243121-000”相匹配的价格&库存,您可以联系我们找货
T1660243121-000
  • 1+278.430971+36.01930
  • 13+183.3529313+23.71950
库存:20
T1660243121-000
  • 4+243.86343
  • 12+205.18431
  • 25+192.89985
  • 30+152.10481
  • 50+148.46542
  • 100+141.36800
  • 250+134.16177
  • 500+123.42496
库存:20
T1660243121-000
    • 4+350.98591
    • 12+295.31194
    • 25+277.63648
    • 30+218.91716
    • 50+213.68413
    • 100+203.46667
    • 250+193.08762
    • 500+177.63713
    库存:20
