T1912100116-009
T1912100116-009
    HUMIREL(泰科)
    防护罩 连接器 侧面进入 PG16 H10B IP68 - 防尘,防水
T1912100116-009 数据手册
T1912100116-009 Heavy Duty Connector Hood, Side Entry, Screwlock, HDC IP68 EMC T1912100116-009  ACTIVE HDC | HDC IP68 EMC TE Internal #: T1912100116-009 Heavy Duty Connector Hood, Side Entry, Screwlock, HDC IP68 EMC View on TE.com > Connectors > Rectangular Connectors > Rectangular Connector Hoods & Bases Hood & Base Connector Product Type: Hood Cable Entry Location: Side Hood & Base Locking Device Type: Screwlock Features Product Type Features Hood & Base Connector Product Type Hood Body Features Primary Product Color Black Cable Entry Location Side Mechanical Attachment Locking Device Location Hood Thread Size PG16 Hood & Base Locking Device Type Screwlock Housing Features Housing Material Die Cast Aluminum Dimensions Product Width 53.2 mm[2.095 in] Product Length 110 mm[4.331 in] Product Height 70 mm[2.756 in] Usage Conditions Corrosion Protected  Packaging Features For support call+1 800 522 6752 Yes 01/03/2024 12:30AM | Page 1 T1912100116-009 Heavy Duty Connector Hood, Side Entry, Screwlock, HDC IP68 EMC Packaging Features Packaging Quantity 1 Packaging Method Bag Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Compliant China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JAN 2022 (223) Does not contain REACH SVHC Halogen Content BFR/CFR/PVC Free, but Br/Cl >900 ppm in other sources. Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts TE Part # T1932100000-009 H10BPR-AGC-EMC-C Also in the Series HDC IP68 EMC  For support call+1 800 522 6752 01/03/2024 12:30AM | Page 2 T1912100116-009 Heavy Duty Connector Hood, Side Entry, Screwlock, HDC IP68 EMC Connector Caps & Covers(4) Rectangular Connector Hoods & Bases (445) Customers Also Bought TE Part #1-480711-9 TE Part #640250-1 TE Part #T2020082201-000 TE Part #T0931003003-000 15P UMNL CAP HSG BLK 01P SL156 HSG W/LCK RAMP NATL HD-008-F CODING-PIN-M3 TE Part #1SNA195638R2300 TE Part #T1730060000-000 TE Part #T2120100219-000 TE Part #T2120100220-000 M4/6.4A.P H6B-TBF-T ZGG-10DSTK,1-7,2-8,3-9,4-6,5-10 ZGGP-H10BSK 1-7/2-8/3-9/4-6/5-10 TE Part #1473203-1 025 CAP ASSY 16P P/BACK BRCKT Documents Product Drawings H10BPR-TSHC-PG16-EMC-C English CAD Files 3D PDF 3D Customer View Model ENG_CVM_CVM_T1912100116-009_A.2d_dxf.zip  English For support call+1 800 522 6752 01/03/2024 12:30AM | Page 3 T1912100116-009 Heavy Duty Connector Hood, Side Entry, Screwlock, HDC IP68 EMC ENG_CVM_CVM_T1912100116-009_A.2d_dxf.zip English Customer View Model ENG_CVM_CVM_T1912100116-009_A.3d_igs.zip English Customer View Model ENG_CVM_CVM_T1912100116-009_A.3d_stp.zip English By downloading the CAD file I accept and agree to the Terms and Conditions of use. Product Specifications Application Specification English Application Specification  For support call+1 800 522 6752 01/03/2024 12:30AM | Page 4
T1912100116-009 价格&库存
很抱歉,暂时无法提供与“T1912100116-009”相匹配的价格&库存,您可以联系我们找货
T1912100116-009
  • 4+205.962204+26.62280
  • 20+185.3310220+23.95600
库存:21
T1912100116-009
    • 7+199.73767
    • 50+195.02670
    • 100+185.64205
    • 250+176.24497
    • 500+162.14935
    库存:21
    T1912100116-009
    • 7+138.78053
    • 50+135.50387
    • 100+128.98682
    • 250+122.45767
    • 500+112.66396
    库存:21
