T2010033101-000
T2010033101-000
    HUMIREL(泰科)
    Housings
    胶壳及附件 3Pin 14-20AWG
T2010033101-000 数据手册
Product Specification 108-137045 Sep 10th, 2015 Rev. B HA Insert Series Table of contents 1. SCOPE .......................................................................................................................................2 1.1. Content ............................................................................................................................. 2 1.2. Qualification ..................................................................................................................... 2 2. APPLICABLE DOCUMENTS ..................................................................................................... 2 2.1. TE Connectivity Documents ...........................................................................................2 2.2. Other Documents ............................................................................................................. 2 3. REQUIREMENTS .......................................................................................................................3 3.1. Design and Construction ................................................................................................3 3.2. Materials ...........................................................................................................................3 3.3. Rated .................................................................................................................................3 3.4. Performance and Test Description .................................................................................3 3.5. Test Requirements and Procedures Summary.............................................................. 3 3.6. Test Sequences ................................................................................................................7 4. QUALITY ASSURANCE PROVISIONS......................................................................................8 4.1. Qualification Testing........................................................................................................8 4.2. Requalification Testing.................................................................................................... 8 4.3. Acceptance .......................................................................................................................8 4.4. Quality Conformance Inspection .................................................................................... 8 This specification is a controlled document © Copyright 2012 by TE Connectivity Corporation All rights reserved 1 of 8 Product Specification 108-137045 Sep 10th, 2015 Rev. B 1. SCOPE 1.1. Content This specification covers the performance, tests and quality standards for the contact inserts of heavy duty connector series HA-003/ HA-004/ HA-010/ HA-016/ HA-032(2x 16)/ HA-048(3x 16)/ HA-064(4x 16). The contact inserts are available for positions number 3/4/10/16/32/48/64. The termination conductor-contact insert is affected via: 1).a crimp contact which is fitted into the contact insert. The contact insert is designed for conductors of 0.14 mm² up to 4.0 mm². 2). a screw contact which is integrate into the contact insert. The contact insert is designed for conductors 0.5 mm² up to 2.5 mm². 3).a spring clamp contact which is integrate into the contact insert. The contact insert is designed for conductors 0.5 mm² up to 2.5mm². 1.2. Qualification When tests are performed, the following specified specifications and standards shall be used. All inspections shall be performed using the applicable inspection plan and product drawing. 2. APPLICABLE DOCUMENTS The following documents form part of this specification to the extent specified herein. In the case of a conflict between the requirements of this specification and the product drawing or of conflicts between the requirements of this specification and the referenced documents, this specification shall take precedence. 2.1. TE Connectivity Documents A. Customer drawing and name HA insert series 2.2. Other Documents        EN 61984: Connectors - Safety requirements and tests IEC 60068: Environmental testing IEC 60512: Connectors for electronic equipment -Test and measurements IEC 60529: Degrees of Protection Provided by Enclosures (IP Code) IEC 60664-1: Insulation coordination for equipment within low-voltage systems (Part 1) EN 61373: Railway application - Rolling stock equipment - Shock and vibration test ISO 6988: Metallic and other non-organic coatings - Sulfur dioxide test with general condensation of moisture This specification is a controlled document © Copyright 2012 by TE Connectivity Corporation All rights reserved 2 of 8 Product Specification 108-137045 Sep 10th, 2015 Rev. B 3. REQUIREMENTS 3.1. Design and Construction Product shall be of the design, construction and physical dimensions specified on the applicable product drawing. 3.2. Materials Materials used in the construction of this product shall be as specified on the applicable product drawing. 3.3. Rated  Rated Current / Voltage / Impulse Voltage / Pollution Degree     16A 250V 4KV 3 Except for the below: HA-003-M/ F (Screw type.): 10A 250V 4KV 3 HA-004-M/ F (Screw type.): 10A 250V 2.5KV 3 HA-003-MS/ FS (Spring type.): 10A 400V 6KV 3 HA-004-MS/ FS (Spring type.): 10A 400V 4KV 3 Operation Temperature -40°C ~+125°C Degree of Protection IP20 Protection Class II Overvoltage Category III 3.4. Performance and Test Description Product shall be designed to meet the electrical, mechanical and environmental performance requirements specified in Paragraph 3.5. Unless otherwise specified, all tests shall be performed at ambient environmental conditions per IEC 60512 / EN 61984. 3.5. Test Requirements and Procedures Summary General No. Test Items Requirements Condition according to 3.5.1 Visual and dimensional examination Meets requirements of product drawing Visual and dimensional examination IEC 60512-1-1/-2, Test 1a and 1b 6.2 of EN 61984 Marking shall be still readable according to 6.2 of EN61984 (If marking made by impression, molding, pressing or engraving or the like are not subjected to this test) Test piston: No. 1 Wet test with liquid: water Duration: 10 cycles Force:5N IEC 60068-2-70 Test Xb 7.3.2 of EN61984 Mechanical 3.5.2 Durability of marking This specification is a controlled document © Copyright 2012 by TE Connectivity Corporation All rights reserved 3 of 8 Product Specification 108-137045 Sep 10th, 2015 Rev. B Polarisation and coding For unenclosed connector (internal For multi-pole connector, require connections) 20N provision against incorrect mating For enclosed connector (external according to 6.3 & 6.9.1 of EN 61984 connections) 1.5 x Mating force, but No damage likely to impair function not higher than 80N Test 13e of IEC 60512-13-5 Pull out force of terminations See 6.6 of EN 61984 See 6.6 of EN 61984 The conductor shall not slip out of crimp barrel and pull out force as specified in Table 1 of EN 60352-2 Visual tests on the crimp barrel and tensile strength test of the crimp connection as specified in IEC 60352-2. The conductor of the smallest and largest cross-sectional area shall not slip out of the clamping unit, and pull out force as specified in Table 3, and torque force as specified in Table 4 IEC 60999-1 or IEC 60999-2 Mechanical tests on the conductor connection as specified in 9.3~9.6 of IEC 60999-1 or IEC 60999-2 Only for spring clamp connection The conductor of the smallest and largest cross-sectional area shall not slip out of the clamping unit, and pull out force as specified in Table 3 IEC 60999-1 or IEC 60999-2 Mechanical tests on the conductor connection as specified in 9.3~9.5 of IEC 60999-1 or IEC 60999-2 or IEC 60352-7 Contact retention force in insert No axial displacement likely to impair normal operation, min 50N force for each pin or socket 6.18.2 of EN 61984 Test load applied in axial direction, test speed:20mm/min, permissible shift contacts of 1.0mm, Test 15a of IEC 60512-15-1 Connector and internal insulation shall no damage to impair normal use. A reduction of clearance and creepage distance is not allowed. 6.18.1 & 6.18.3 of EN 61984 Dropping height: - 750mm for specimens of mass≤ 250g - 500mm for specimens of mass>250g Dropping cycles:8 positions in 45°step, one cycles per position IEC 60512-7-2 Test 7b 3.5.7 Mechanical Operation (Durability) 500 operation cycles without load No damage likely to impair normal use 6.14.1 of EN 61984 Shall be engaged and disengaged by means of A) a device simulating normal operating conditions at the speed of approximately 50mm/min B) manual mating/un-mating 300 Max. cycle per hour IEC 60512-9-1 Test 9a 7.3.9 of EN 61984 3.5.8 Vibration, Random No damage likely to impair function No discontinuities greater than t>1µs Frequency:5~150Hz Per EN 61373, Category 1, Class B (IEC60068-2-6 Test Fc) No damage likely to impair function No discontinuities greater than t>1µs Acceleration:50m/s2 Duration:30ms Total 18 shocks(three positive and three negative in each of the three orthogonal axes) Per EN 61373 3.5.3 a 3.5.4 Only for crimp contact connection a Only for screw contact connection a 3.5.5 3.5.6 3.5.9 Mechanical strength impact Shock This specification is a controlled document © Copyright 2012 by TE Connectivity Corporation All rights reserved 4 of 8 Product Specification 108-137045 Sep 10th, 2015 Rev. B Electrical 3.5.10 Contact Resistance Initial Max.5mΩ Final The change of contact resistance shall be no more than 50 % of the reference value or ≤5 mΩ. The higher value is permissible Test current: 1A Measure pointsb at the end of the termination Max three contacts per specimen plus protective earthing, if any IEC 60512-2-2 Test 2b Temperature Rise Test The sum of the ambient temperature and the temperature rise (△T ) of a connector shall not exceed the upper limiting temperature 6.16 of EN 61984 Length of test cable see table 7 of 7.3.8 of EN 61984 Carry its rated current Upper limiting temperature:125℃ (Table 5b) IEC 60512-5-1 Test 5a 3.5.12 Dielectric Voltage Withstand Test No flashover or breakdown of voltage 6.13 of EN 61984 Impulse test voltage according to Table 8, applied three impulses of each polarity and interval of at least 1s between impulses. 7.3.12 of EN 61984 3.5.13 Insulation Resistance Not less than 400MΩ Test voltage 1000V DC Time:60s IEC 60512-3-1 Test 3a Method B No damage likely to impair function Subject mated specimen to -40℃ Duration time:16h, Test Ab Per IEC 60512-11-10 Test 11j (IEC 60068-2-1) No damage likely to impair function Subject mated specimen to +125℃ Duration time:168h Test Bb Per IEC 60512-11-9 Test 11i (IEC 60068-2-2) 3.5.11 Environmental 3.5.14 3.5.15 3.5.16 3.5.17 Cold Dry Heat Damp Heat, cyclic Rapid Change of temperature (Temperature Cycle) No damage likely to impair function No damage likely to impair function Subject mated specimen to Min ambient temperature: 25±2℃ Max ambient temperature: 40±2℃ Number of cycles:21 Duration time:12h+12h Variant 1 IEC 60512-11-12 Test 11m Subject mated specimen to Ta=-40±2℃ to Tb=+125±2℃, duration t1: 1h each extreme, 100 cycles IEC 60512-11-4 Test 11d (IEC 60068-2-14 Test Na) This specification is a controlled document © Copyright 2012 by TE Connectivity Corporation All rights reserved 5 of 8 Product Specification 108-137045 Sep 10th, 2015 Rev. B 3.5.18 3.5.19 Corrosion (Alternative) No damage likely to impair function Per 6.21 of EN 61984 no live parts shall be accessible by test finger, 6.4.2.2 or 6.4.2.3 of EN 61984 Protection against electric shock Test 1: Flowing mixed gas corrosion according to test 11g, method 1 or method 4 (Table 1) Duration time: 4day (96h) IEC 60512-11-7 Test 11g 7.3.14 of EN 61984 Test 2: Sulphur dioxide test with general condensation of moisture according to EN ISO 6988 Duration time:24h (1 test cycle) 7.3.14 of EN 61984 Unenclosed connector. Test finger or 50mm sphere pressed with 20N against the surface as specified by the manufacture Mated specimen and socket connector (if application) 7.3.6.1 of EN 61984 a test items are for themselves separate tests and are performed on new specimens. point: at the conductors as close as possible to the termination, if this is not possible, the conductor resistance shall be recalculated. b measuring Number of Specimen as below table: Table 1 - Number of Specimen Test Group A Description Numbers & consist of 3 pairs connectors Mechanical Test Group B Service life Test 3 pairs connectors Group C Temperature rise Test, Mated 3 pairs connectors Group D Climatic Test, Mated 3 pairs connectors Group E Degree of protection Test 3 pairs connectors Group F Temperature Cycle Test 3 pairs connectors Group G Vibration and Shock Test 3 pairs connectors (assemble with Hood & Housing) Note: For connector family of the same design and comparable size, test may be made only on that member of the family which represents the worse case for that test. This specification is a controlled document © Copyright 2012 by TE Connectivity Corporation All rights reserved 6 of 8 Product Specification 108-137045 Sep 10th, 2015 Rev. B 3.6. Test Sequences Test Group Test or Examination A B C D E F G 1,3 1,8 1,6 2,8 2,5 3 4 2,5 3,9 4,10 5 6 6 7 Test Sequence Visual and dimensional examination Durability of marking Polarisation and coding (If application) Pull out force of terminations Only for Crimped connections Only for Screw contact connections Contact retention force in insert Mechanical strength impact Mechanical Operation (Durability) Vibration, Random Shock Contact Resistance Temperature Rise Test Dielectric Voltage Withstand Test Insulation Resistance Cold Dry Heat Damp Heat, cyclic Rapid Change of temperature (Temperature Cycle) Corrosion Protection against electric shock 1,6 2 3 1,5 1,3 1,11 7a 4 5 3 2,4 2 4 3 7 2 Notes: 1) Numbers indicate the sequence in which the tests are performed. 2) a test items are for themselves separate tests and are performed on new specimens. This specification is a controlled document © Copyright 2012 by TE Connectivity Corporation All rights reserved 7 of 8 Product Specification 108-137045 Sep 10th, 2015 Rev. B 4. QUALITY ASSURANCE PROVISIONS 4.1. Qualification Testing A. Specimen Selection Specimens shall be prepared in accordance with product drawing and shall be selected at random from current production. B. Test Sequence The samples shall be prepared in accordance with product drawings. They shall be selected at random from current production. 4.2. Requalification Testing If changes significantly affecting form, fit or functions are made to the product or manufacturing process, product assurance shall coordinate requalification testing, consisting of all or part of the original testing sequence as determined by development/product, quality and reliability engineering. 4.3. Acceptance Acceptance is based on verification that the product meets the requirements of paragraph 3.5. Failures attributed to equipment, test setup or operator deficiencies shall not disqualify the product. If product failure occurs, corrective action shall be taken and specimens resubmitted for qualification. Testing to confirm corrective action is required before re-submittal. 4.4. Quality Conformance Inspection The applicable quality inspection plan shall specify the sampling acceptable quality level to be used. Dimensional and functional requirements shall be in accordance with the applicable product drawing and this specification. Bulk wire resistance shall be subtracted from resistance readings. This specification is a controlled document © Copyright 2012 by TE Connectivity Corporation All rights reserved 8 of 8
T2010033101-000 价格&库存
很抱歉,暂时无法提供与“T2010033101-000”相匹配的价格&库存,您可以联系我们找货
T2010033101-000
    • 1+20.70112
    库存:1
