T2010162101-000
T2010162101-000
    HUMIREL(泰科)
    插件
    线对线连接器 16Pin(2x8) 16A 直插
T2010162101-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - P B B1 66 D B2 16X M3 SCREW, RECOMMENDED TIGHTENING TORQUE 0.5Nm 1 C : 1. M4 SCREW RECOMMENDED TIGHTENING TORQUE 1.2Nm DWN APVD ECR-15-013750 17SEP2015 DW CW ECR-15-016224 05NOV2015 DW CW ECR-18-008588 09JUL2018 KW CW ECR-20-016101 09JUN2021 BS CW : : : : : 23 : : : : : 73.2 B DATE NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 250 V RATED CURRENT: 16 A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 4 KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES WIRE RANGE: 0.5-2.5 mm² (20-14 AWG) CONTACT FINISH: SILVER PLATED CONTACT TYPE: SCREW CONTACT 29 14.7 16 C 4X M3 SCREW, RECOMMENDED TIGHTENING TORQUE 0.5Nm DESCRIPTION LTR C PC 250V 16A >=400M ^ : 4 KV 3 UL94V-0 500 0.5-2.5 mm² (20-14 AWG) : B PANEL CUT FOR INSERTS FOR USE WITHOUT HOODS/ HOUSINGS 3 60 THIS DRAWING IS A CONTROLLED DOCUMENT. 3.3 TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm 66 A MATERIAL 1470-19 (3/13) HA-016-M PART NUMBER 24 16 10 T2010162101-000 4X D 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 10NOV2014 CHK 10NOV2014 APVD 10NOV2014 David Wang Chris Wang Xiang Xu PRODUCT SPEC HA-016 MALE INSERT HA-016 PART DESCRIPTION TE Connectivity NAME HA-016-M A 108-137045 APPLICATION SPEC - 114-137045 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2010162101000 SCALE 1:1 SHEET 1 OF 1 REV C
T2010162101-000 价格&库存
很抱歉,暂时无法提供与“T2010162101-000”相匹配的价格&库存,您可以联系我们找货
T2010162101-000
  • 1+94.57847
  • 2+92.50612
  • 3+90.51708
库存:15
T2010162101-000
  • 1+48.14600
库存:1
