4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
3
RELEASED FOR PUBLICATION
1
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
A
B
D
B1
C
M3 SCREW
RECOMMENDED TIGHTENING
TORQUE 0.5Nm
M3
0.5Nm
TYPE-1,T2020072201-000,TE LOGO
10.5
C
( 18.9 )
14
2.
21
B
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
A
21
1470-19 (3/13)
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
DWN
APVD
INITIAL RELEASE
16DEC2014
HMR
CW
ECR-15-013292
16SEP2015
DL
CW
ECR-16-015492
04NOV2016
QY
CW
ECR-21-105750
02JUL2021
BS
CW
33.5
1.
mm
DATE
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PBT
RATED VOLTAGE: 250 V
RATED CURRENT: 10 A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 4 KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYLCES
WIRE RANGE: 0.14-2.5 mm² (26-14 AWG)
CONTACT TYPE: CRIMP CONTACT
2. CONTACT NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING:T20200X20XX000)
10.2
10.2
DESCRIPTION
LTR
FINISH
C
PBT
250V
10A
>=400M ^
: 4 KV
3
UL94V-0
500
16DEC2014
RAGHAVENDRA H M
CHK
16DEC2014
CHRIS WANG
APVD
16DEC2014
XU XIANG
: T20200X20XX000)
B
DWN
PRODUCT SPEC
TE Connectivity
NAME
HD-007-F
A
108-137042
APPLICATION SPEC
D
114-137042
WEIGHT
CUSTOMER DRAWING
SIZE
A3
CAGE CODE
DRAWING NO
RESTRICTED TO
T2020072201000
SCALE
2:1
SHEET
1
OF
2
REV
C
4
C
COPYRIGHT
BY -
2
3
1
REVISIONS
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
D
NOTE:
SEE SHEET 1
1
TYPE-2,T2020072201-001,STAINLESS STEEL SCREW,NO LOGO
-2,T2020072201-001,
, LOGO
C
C
B
B
T2020072201-001
HD-007-F
T2020072201-000
HD-007-F
HD-007 FEMALE INSERT,STAINLESS STEEL SCREW,NO LOGO
HD-007
, LOGO
TYPE-2
-2
PART DESCRIPTION
TYPE
HD-007
PART NUMBER
TOLERANCES UNLESS
DIMENSIONS:
mm
A
ALL DIMENSIONS ARE SAME AS TYPE 1,
EXCEPT THOSE DEFINED IN THIS TYPE.
1
1470-19 (3/13)
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
16DEC2014
RAGHAVENDRA H M
CHK
16DEC2014
CHRIS WANG
APVD
16DEC2014
XU XIANG
TYPE-1
-1
DWN
PRODUCT SPEC
TE Connectivity
NAME
HD-007-F
A
108-137042
APPLICATION SPEC
114-137042
WEIGHT
CUSTOMER DRAWING
SIZE
A3
CAGE CODE
DRAWING NO
RESTRICTED TO
T2020072201000
SCALE
2:1
SHEET
2
OF
2
REV
C
很抱歉,暂时无法提供与“T2020072201-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+71.074541+9.23632
- 10+60.3750610+7.84590
- 30+55.8690630+7.26033
- 50+53.8904650+7.00321
- 100+51.31741100+6.66883
- 250+48.10538250+6.25142
- 500+45.81042500+5.95318
- 1000+43.626141000+5.66933
- 国内价格
- 30+47.32419
- 60+40.87968
- 150+38.77585
- 300+36.85338
- 400+35.12437
- 500+32.24671
- 1000+29.93733
- 国内价格
- 30+68.11640
- 60+58.83119
- 150+55.81070
- 300+53.03881
- 400+50.55281
- 500+46.41362
- 1000+43.08238
- 国内价格
- 30+68.11640
- 60+58.83119
- 150+55.81070
- 300+53.03881
- 400+50.55281
- 500+46.41362
- 1000+43.08238
