T2020252101-000
T2020252101-000
    HUMIREL(泰科)
    电源连接器 25Pin 26–14AWG
T2020252101-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - TYPT-1/ P TYPT-2/ -1 LTR A -2 B B1 ( 73.4 ) C DESCRIPTION DATE DWN APVD INITIAL RELEASE 16DEC2014 HMR CW ECR-15-013292 24SEP2015 DL CW ECR-16-011552 11AUG2016 QY CW ECR-21-105750 30JUN2021 BS CW D D 23 NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 250 V RATED CURRENT: 10 A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 4 KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES WIRE RANGE: 0.14-2.5 mm² (26-14 AWG) CONTACT TYPE: CRIMP CONTACT 2. CONTACT NEED TO BE ORDERED SEPARATELY. (ORDER No. REFER TO DRAWING:T20200X10XX000) 4X M3 SCREW RECOMMENDED TIGHTENING TORQUE 0.5Nm 4X M3 0.5Nm : 16 1. : : : : : (1) 35 C DETAIL DETAIL : : : : : A C 2. M4 SCREW RECOMMENDED TIGHTENING TORQUE 1.2Nm M4 1.2Nm PC 250V 10A >=400M ^ : 4 KV 3 UL94V-0 500 0.14-2.5 mm² (26-14 AWG) C . : T20200X10XX000) ( 66 B B 16 DETAIL B NOTE:TYPE-2 ALL THE DIMENSIONS ARE THE SAME WITH TYPE-1 EXCEPT THE LASER PRINT MARKINGS : -2 -1 , , B DETAIL SCALE 5:1 DETAIL SCALE 60 C 5:1 32 DETAIL SCALE 16 10 7.75 T2020252101-Z00 HD-025-M/Z T2020252101-000 HD-025-M THIS DRAWING IS A CONTROLLED DOCUMENT. 4X 3.3 DIMENSIONS: 66 PANEL CUT OUT FOR INSERTS FOR USE WITHOUT HOODS/HOUSINGS 1471-9 (3/13) SCALE mm 1:1 MATERIAL TBD - TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH - - 16DEC2014 RAGHAVENDRA H M CHK 16DEC2014 CHRIS WANG APVD 16DEC2014 XU XIANG HD-025 MALE INSERT(Z) HD-025 (Z) TYPE-2 -2 HD-025 MALE INSERT HD-025 PART NUMBER A A 5:1 TYPE-1 -1 PART DESCRIPTION TYPE DWN TE Connectivity NAME PRODUCT SPEC A HD-025-M 108-137042 APPLICATION SPEC - 114-137042 WEIGHT CUSTOMER DRAWING SIZE A2 CAGE CODE - RESTRICTED TO DRAWING NO T2020252101000 SCALE 3:2 SHEET 1 OF 1 REV C
T2020252101-000 价格&库存
很抱歉,暂时无法提供与“T2020252101-000”相匹配的价格&库存,您可以联系我们找货
T2020252101-000
    • 1+74.52142
    • 2+72.89686
    • 3+71.32437
    库存:2
    T2020252101-000
    • 1+106.059551+13.71820
    • 7+93.129727+12.04580
    • 21+86.6648121+11.20960
    • 35+83.6070835+10.81410
    • 49+81.8598049+10.58810
    • 70+79.5883570+10.29430
    • 105+77.14216105+9.97790
    • 140+75.91907140+9.81970
    • 175+74.87070175+9.68410
    • 210+74.25916210+9.60500
    库存:7
    T2020252101-000
    • 20+63.05458
    • 50+61.60366
    • 100+58.64136
    • 250+55.66698
    • 500+51.25376
    • 1000+47.50555
    库存:9
    T2020252101-000
      • 20+90.75143
      • 50+88.66319
      • 100+84.39970
      • 250+80.12378
      • 500+73.77205
      • 1000+68.37743
      库存:9
      T2020252101-000
        • 1+38.26900
        库存:1
