4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
3
RELEASED FOR PUBLICATION
LOC
ALL RIGHTS RESERVED.
BY -
1
REVISIONS
DIST
P
B
B1
104
D
DESCRIPTION
LTR
B2
4X M3 SCREW RECOMMENDED
TIGHTENING TORQUE 0.5Nm
4X M3 ,
0.5Nm
DWN
APVD
ECR-15-013292
24SEP2015
DL
CW
ECR-15-017530
02DEC2015
GY
CW
ECR-16-015492
12NOV2016
QY
CW
ECR-21-105750
01JUL2021
BS
CW
D
27
C
DATE
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 250 V
RATED CURRENT: 10 A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 4 KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
WIRE RANGE: 0.14-2.5 mm² (26-14 AWG)
CONTACT TYPE: CRIMP CONTACT
2. CONTACT NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING:T20200X10XX000)
1.2
C
36.8
21.8
M4 SCREW RECOMMENDED
TIGHTENING TORQUE 1.2Nm
M4
1.2Nm
34
1.
( 110.4 )
B
95
4X
3.3
36
27
THIS DRAWING IS A CONTROLLED DOCUMENT.
mm
104
PANEL CUT FOR INSERTS FOR USE
WITHOUT HOODS/ HOUSINGS
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
30OCT2014
CHK
30OCT2014
APVD
30OCT2014
David Wang
Chris Wang
Xiang Xu
: T20200X10XX000)
B
TE Connectivity
NAME
PRODUCT SPEC
HD-064-M
A
108-137042
APPLICATION SPEC
114-137042
WEIGHT
Customer Drawing
1470-19 (3/11)
TYPE-2,T2020642101-001,STAINLESS STEEL SCREW,TE LOGO
-2,T2020642101-001,
,TE LOGO
DIMENSIONS:
A
PC
250V
10A
>=400M ^
: 4 KV
3
UL94V-0
500
TYPE-1,T2020642101-000,TE LOGO
18
7.75
2.
C
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2020642101000
SCALE
1:1
SHEET
1
OF
2
REV
C
4
C
COPYRIGHT
BY -
2
3
LOC
1
REVISIONS
DIST
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
D
NOTE:
SEE SHEET 1
1
C
C
TYPE-3,T2020642101-002,STAINLESS STEEL SCREW,NO LOGO
-3,T2020642101-002,
, LOGO
B
T2020642101-002
HD-064-M
T2020642101-001
HD-064-M
T2020642101-000
HD-064-M
PART NUMBER
ALL DIMENSIONS ARE SAME AS TYPE 1,
EXCEPT THOSE DEFINED IN THIS TYPE.
1
mm
TOLERANCES UNLESS
A
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
TYPE-3
-3
HD-064 MALE INSERT
HD-064
TYPE-1
-1
HD-064 MALE INSERT,STAINLESS STEEL SCREW
HD-064
DWN
30OCT2014
CHK
30OCT2014
APVD
30OCT2014
David Wang
Chris Wang
Xiang Xu
NAME
HD-064-M
A
108-137042
APPLICATION SPEC
114-137042
WEIGHT
Customer Drawing
1470-19 (3/11)
TYPE
TE Connectivity
PRODUCT SPEC
B
TYPE-2
-2
PART DESCRIPTION
DIMENSIONS:
HD-064 MALE INSERT,
HD-064
, LOGO
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2020642101000
SCALE
1:1
SHEET
2
OF
2
REV
C
很抱歉,暂时无法提供与“T2020642101-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+152.61554
- 50+149.01084
- 100+141.77658
- 250+134.67905
- 500+123.95196
- 1000+114.92778
